<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Nach Nodejs Update kein Adapter mehr updatebar]]></title><description><![CDATA[<p dir="auto">Hallo,<br />
nach einen Nodejs Updaten von 14 auf 16 kann ich leider keine Adapter mehr aktualisieren. Weder über die Weboberfläche noch per Kommandozeile.</p>
<pre><code>ERROR: process exited with code 25
</code></pre>
<pre><code>root@iobroker-ubuntu:~# uname -m &amp;&amp; type -P nodejs node npm &amp;&amp; nodejs -v &amp;&amp; node -v &amp;&amp; npm -v &amp;&amp; whoami &amp;&amp; pwd &amp;&amp; sudo apt update &amp;&gt; /dev/null &amp;&amp; sudo apt update &amp;&amp; apt policy nodejs
x86_64
/usr/bin/nodejs
/usr/bin/node
/usr/bin/npm
v16.16.0
v16.16.0
8.11.0
root
/root
OK:1 https://deb.nodesource.com/node_16.x bionic InRelease
OK:2 http://archive.ubuntu.com/ubuntu bionic InRelease
OK:3 http://archive.ubuntu.com/ubuntu bionic-updates InRelease
OK:4 http://archive.ubuntu.com/ubuntu bionic-backports InRelease
OK:5 http://archive.ubuntu.com/ubuntu bionic-security InRelease
Alle Pakete sind aktuell.
nodejs:
  Installiert:           16.16.0-1nodesource1
  Installationskandidat: 16.16.0-1nodesource1
  Versionstabelle:
 *** 16.16.0-1nodesource1 500
        500 https://deb.nodesource.com/node_16.x bionic/main amd64 Packages
        100 /var/lib/dpkg/status
     8.10.0~dfsg-2ubuntu0.4 500
        500 http://archive.ubuntu.com/ubuntu bionic-updates/universe amd64 Packages
     8.10.0~dfsg-2ubuntu0.2 500
        500 http://archive.ubuntu.com/ubuntu bionic-security/universe amd64 Packages
     8.10.0~dfsg-2 500
        500 http://archive.ubuntu.com/ubuntu bionic/universe amd64 Packages
</code></pre>
<table class="table table-bordered table-striped">
<thead>
<tr>
<th>Systemdata</th>
<th>Bitte Ausfüllen</th>
</tr>
</thead>
<tbody>
<tr>
<td>Hardwaresystem:</td>
<td>NUC</td>
</tr>
<tr>
<td>Arbeitsspeicher:</td>
<td>1GB</td>
</tr>
<tr>
<td>Festplattenart:</td>
<td>SSD</td>
</tr>
<tr>
<td>Betriebssystem:</td>
<td>Ubuntu 18.04.6 LTS</td>
</tr>
<tr>
<td>Node-Version:</td>
<td>16.16.0</td>
</tr>
<tr>
<td>Nodejs-Version:</td>
<td>16.16.0</td>
</tr>
<tr>
<td>NPM-Version:</td>
<td>8.11.0</td>
</tr>
<tr>
<td>Installationsart:</td>
<td>Skript/Manuell</td>
</tr>
<tr>
<td>Image genutzt:</td>
<td>Ja/Nein</td>
</tr>
<tr>
<td>Ort/Name der Imagedatei:</td>
<td>Link</td>
</tr>
</tbody>
</table>
]]></description><link>https://forum.iobroker.net/topic/56543/nach-nodejs-update-kein-adapter-mehr-updatebar</link><generator>RSS for Node</generator><lastBuildDate>Tue, 17 Nov 2026 11:09:58 GMT</lastBuildDate><atom:link href="https://forum.iobroker.net/topic/56543.rss" rel="self" type="application/rss+xml"/><pubDate>Thu, 21 Jul 2022 10:09:03 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Nach Nodejs Update kein Adapter mehr updatebar on Mon, 25 Jul 2022 13:13:03 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/tilly" aria-label="Profile: tilly">@<bdi>tilly</bdi></a></p>
<p dir="auto">Theoretisch ja.<br />
In der Praxis können Fallstricke lauern.</p>
<p dir="auto">Je mehr am System 'rumgefrickelt' würde, umso höher die Wahrscheinlichkeit da in Stolperfallen zu laufen</p>
<p dir="auto">Auch deswegen halt der Rat, das System nicht mutwillig auf links zu drehen<br />
Das 'do-release-upgrade-Skript' geht nämlich von einem unverfummelten System aus.</p>
]]></description><link>https://forum.iobroker.net/post/833746</link><guid isPermaLink="true">https://forum.iobroker.net/post/833746</guid><dc:creator><![CDATA[Thomas Braun]]></dc:creator><pubDate>Mon, 25 Jul 2022 13:13:03 GMT</pubDate></item><item><title><![CDATA[Reply to Nach Nodejs Update kein Adapter mehr updatebar on Mon, 25 Jul 2022 13:10:02 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/tilly" aria-label="Profile: tilly">@<bdi>tilly</bdi></a> da bin ich leider raus. Ich habe ja nur debian auf dem Raspberry und das ist ja ein richtiges Release Update, also als ob Du Windows 10 auf Windows 11 upgradest. Das kann ggf. böse enden. Würde ich vielleicht schon mal machen. Aber nur mit Komplettsicherungen und da bist glaub länger beschäftigt um sicher zu stellen, dass alles wieder läuft. Aber irgendwann wirst Du wohl in diesen Apfel beißen müssen.</p>
]]></description><link>https://forum.iobroker.net/post/833742</link><guid isPermaLink="true">https://forum.iobroker.net/post/833742</guid><dc:creator><![CDATA[mickym]]></dc:creator><pubDate>Mon, 25 Jul 2022 13:10:02 GMT</pubDate></item><item><title><![CDATA[Reply to Nach Nodejs Update kein Adapter mehr updatebar on Mon, 25 Jul 2022 13:06:26 GMT]]></title><description><![CDATA[<p dir="auto">ok eine Frage noch. Nutze momentan Ubuntu 18.04.6 LTS<br />
Beim Einloggen erhalte ich die Meldung zum Update auf 20.04.4 LTS. Ist das so einfach zu machen?</p>
<pre><code>New release '20.04.4 LTS' available.
Run 'do-release-upgrade' to upgrade to it.
</code></pre>
]]></description><link>https://forum.iobroker.net/post/833740</link><guid isPermaLink="true">https://forum.iobroker.net/post/833740</guid><dc:creator><![CDATA[tilly]]></dc:creator><pubDate>Mon, 25 Jul 2022 13:06:26 GMT</pubDate></item><item><title><![CDATA[Reply to Nach Nodejs Update kein Adapter mehr updatebar on Mon, 25 Jul 2022 13:05:05 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/mickym" aria-label="Profile: mickym">@<bdi>mickym</bdi></a></p>
<p dir="auto">Ich gehe jetzt Mal davon aus, dass der use case 'Es reden Maschinen miteinander' beim TE nicht vorliegt.<br />
Und selbst dann würde man diesen Maschinenuser per sudoers auf das beschränken, was der halt machen können darf.</p>
]]></description><link>https://forum.iobroker.net/post/833739</link><guid isPermaLink="true">https://forum.iobroker.net/post/833739</guid><dc:creator><![CDATA[Thomas Braun]]></dc:creator><pubDate>Mon, 25 Jul 2022 13:05:05 GMT</pubDate></item><item><title><![CDATA[Reply to Nach Nodejs Update kein Adapter mehr updatebar on Mon, 25 Jul 2022 13:03:59 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/thomas-braun" aria-label="Profile: thomas-braun">@<bdi>thomas-braun</bdi></a> sagte in <a href="/post/833736">Nach Nodejs Update kein Adapter mehr updatebar</a>:</p>
<blockquote>
<p dir="auto">Im Netz findet man alles. Auch wie man z.B.  nodejs irgendwie an allem vorbei in die Keramik donnert.<br />
Da bin ich ja Leid gewohnt.</p>
</blockquote>
<p dir="auto">Ja gebe Dir da Recht. Mit der Zeit bekommt man aber bissi Übung - Gutes von Schlechtem zu unterscheiden. Insbesondere ein Filter, der Posts von anno dazumal rausfiltert, sollte man in der Regel nutzen.</p>
<p dir="auto">In diesem Fall, wenn man ohne PW über SSH auf ein entferntes System zugreifen will, dann macht es auch Sinn, das Passwort von sudo für diesen EINEN User zu disablen. - Ist halt meine Meinung - Du bist allerdings hier der Fachmann im Vergleich zu mir - und trotzdem müssen wir ja nicht immer gleicher Meinung sein ;) - bzw. muss ich Deiner Meinung sein, weil Du auf diesem Gebiet die höhere Kompetenz hast. (Gibt ja noch so 1-2 Punkte, wo wir unterschiedliche Auffassungen haben. ;) )</p>
]]></description><link>https://forum.iobroker.net/post/833737</link><guid isPermaLink="true">https://forum.iobroker.net/post/833737</guid><dc:creator><![CDATA[mickym]]></dc:creator><pubDate>Mon, 25 Jul 2022 13:03:59 GMT</pubDate></item><item><title><![CDATA[Reply to Nach Nodejs Update kein Adapter mehr updatebar on Mon, 25 Jul 2022 12:57:07 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/mickym" aria-label="Profile: mickym">@<bdi>mickym</bdi></a></p>
]]></description><link>https://forum.iobroker.net/post/833736</link><guid isPermaLink="true">https://forum.iobroker.net/post/833736</guid><dc:creator><![CDATA[Thomas Braun]]></dc:creator><pubDate>Mon, 25 Jul 2022 12:57:07 GMT</pubDate></item><item><title><![CDATA[Reply to Nach Nodejs Update kein Adapter mehr updatebar on Mon, 25 Jul 2022 12:52:20 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/thomas-braun" aria-label="Profile: thomas-braun">@<bdi>thomas-braun</bdi></a> Na ja wenn Du mit ssh Dich ohne Passwort verbinden willst, dann macht es halt nicht wirklich Sinn. Aber ich hab ja in einem anderen Thread schon mal gepostet, wie es geht und im Netz findet man ja auch genug Input. Ich hantiere lieber mit meinem pi und passwortlosem Sudo, als mit root auf entfernten Systemen und kann damit eigentlich einiges machen. So gibts inzwischen bei mir gelben Alarm wenn Updates anstehen. ;)</p>
<p dir="auto"><img src="/assets/uploads/files/1658753536210-a7268841-fac5-409b-a8eb-b4fbcf4c99a3-image-resized.png" alt="a7268841-fac5-409b-a8eb-b4fbcf4c99a3-image.png" class="img-markdown  img-fluid" /></p>
]]></description><link>https://forum.iobroker.net/post/833732</link><guid isPermaLink="true">https://forum.iobroker.net/post/833732</guid><dc:creator><![CDATA[mickym]]></dc:creator><pubDate>Mon, 25 Jul 2022 12:52:20 GMT</pubDate></item><item><title><![CDATA[Reply to Nach Nodejs Update kein Adapter mehr updatebar on Mon, 25 Jul 2022 12:48:37 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/mickym" aria-label="Profile: mickym">@<bdi>mickym</bdi></a> sagte in <a href="/post/833723">Nach Nodejs Update kein Adapter mehr updatebar</a>:</p>
<blockquote>
<p dir="auto">Muss aber jeder selbst wissen.</p>
</blockquote>
<p dir="auto">Erfahrungsgemäß weiß aber nur die absolute Minderheit damit gescheit umzugehen.<br />
Deswegen mein allgemeiner Rat: Finger weg von der Userverwaltung und dem seitens der Distribution vorgesehenen Rechtemanagement. Das hat schon einen Sinn, das es so eingestellt wurde wie es 'ab Werk' eingestellt ist.</p>
<p dir="auto">Ich würde da vielleicht allenfalls die sog. 'grace time' etwas höher setzen. In dieser Zeitspanne wird dann nicht erneut nach dem PW gefragt.</p>
]]></description><link>https://forum.iobroker.net/post/833727</link><guid isPermaLink="true">https://forum.iobroker.net/post/833727</guid><dc:creator><![CDATA[Thomas Braun]]></dc:creator><pubDate>Mon, 25 Jul 2022 12:48:37 GMT</pubDate></item><item><title><![CDATA[Reply to Nach Nodejs Update kein Adapter mehr updatebar on Mon, 25 Jul 2022 12:38:18 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/thomas-braun" aria-label="Profile: thomas-braun">@<bdi>thomas-braun</bdi></a> Muss aber jeder selbst wissen.</p>
<p dir="auto">Ich habe wie gesagt die sudo Passwortabfrage deaktiviert. Ansonsten muss man halt die beiden Befehle als root machen. Sonst kann man eben mit sudo und passwortlosem ssh arbeiten. Das ist im Übrigen auch wichtig, wenn man mit dem Linux Control Adapter arbeiten will. Der kann dann nämlich auch automatisch Upgraden wenn man will und sich nicht mit root Rechten anmelden will.</p>
<p dir="auto"><img src="/assets/uploads/files/1658752608999-a7150b52-dda6-411c-9480-30b36544d837-image.png" alt="a7150b52-dda6-411c-9480-30b36544d837-image.png" class="img-markdown  img-fluid" /></p>
]]></description><link>https://forum.iobroker.net/post/833723</link><guid isPermaLink="true">https://forum.iobroker.net/post/833723</guid><dc:creator><![CDATA[mickym]]></dc:creator><pubDate>Mon, 25 Jul 2022 12:38:18 GMT</pubDate></item><item><title><![CDATA[Reply to Nach Nodejs Update kein Adapter mehr updatebar on Mon, 25 Jul 2022 12:36:55 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/tilly" aria-label="Profile: tilly">@<bdi>tilly</bdi></a> sagte in <a href="/post/833689">Nach Nodejs Update kein Adapter mehr updatebar</a>:</p>
<blockquote>
<p dir="auto">Kann man das anders lösen?</p>
</blockquote>
<p dir="auto">Ja, kann man.<br />
Nein, tut man nicht.</p>
<p dir="auto">Die Verzeichnislöschorgie kann man übrigens mit dem Einzeiler automatisieren:</p>
<pre><code>cd /opt/iobroker/node_modules
for i in $(ls -d .[^.]*-*/); do rm -rf ${i%%/}; done
</code></pre>
]]></description><link>https://forum.iobroker.net/post/833707</link><guid isPermaLink="true">https://forum.iobroker.net/post/833707</guid><dc:creator><![CDATA[Thomas Braun]]></dc:creator><pubDate>Mon, 25 Jul 2022 12:36:55 GMT</pubDate></item><item><title><![CDATA[Reply to Nach Nodejs Update kein Adapter mehr updatebar on Mon, 25 Jul 2022 12:14:50 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/tilly" aria-label="Profile: tilly">@<bdi>tilly</bdi></a> man kann das Lösen, in dem man sudo so konfiguriert, dass man kein Passwort mehr braucht, aber ich bekomme glaube gleich Haue von Thomas.😉</p>
<p dir="auto">Und wie Thomas beschrieben hat, kann man auf das get verzichten.</p>
]]></description><link>https://forum.iobroker.net/post/833694</link><guid isPermaLink="true">https://forum.iobroker.net/post/833694</guid><dc:creator><![CDATA[mickym]]></dc:creator><pubDate>Mon, 25 Jul 2022 12:14:50 GMT</pubDate></item><item><title><![CDATA[Reply to Nach Nodejs Update kein Adapter mehr updatebar on Mon, 25 Jul 2022 11:53:49 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/thomas-braun" aria-label="Profile: thomas-braun">@<bdi>thomas-braun</bdi></a></p>
<p dir="auto">hab einen ssh key für user hinterlegt, womit ich mich per ssh automatisch anmelden kann. Wenn ich nun per sudo Behle ausführe, wird ja wieder das Passwort verlangt. Kann man das anders lösen?</p>
]]></description><link>https://forum.iobroker.net/post/833689</link><guid isPermaLink="true">https://forum.iobroker.net/post/833689</guid><dc:creator><![CDATA[tilly]]></dc:creator><pubDate>Mon, 25 Jul 2022 11:53:49 GMT</pubDate></item><item><title><![CDATA[Reply to Nach Nodejs Update kein Adapter mehr updatebar on Mon, 25 Jul 2022 11:37:29 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/tilly" aria-label="Profile: tilly">@<bdi>tilly</bdi></a> sagte in <a href="/post/833679">Nach Nodejs Update kein Adapter mehr updatebar</a>:</p>
<blockquote>
<p dir="auto">oder mache ich update und upgrade als root?</p>
</blockquote>
<p dir="auto">Nein, nie direkt als root hantieren.<br />
Das wird per sudo angeleiert:</p>
<pre><code>sudo apt update
sudo apt full-upgrade
</code></pre>
]]></description><link>https://forum.iobroker.net/post/833682</link><guid isPermaLink="true">https://forum.iobroker.net/post/833682</guid><dc:creator><![CDATA[Thomas Braun]]></dc:creator><pubDate>Mon, 25 Jul 2022 11:37:29 GMT</pubDate></item><item><title><![CDATA[Reply to Nach Nodejs Update kein Adapter mehr updatebar on Mon, 25 Jul 2022 11:34:12 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/mickym" aria-label="Profile: mickym">@<bdi>mickym</bdi></a></p>
<p dir="auto">habe es wie du vorgeschlagen gemacht und es hat alles prima funktioniert.</p>
<p dir="auto">wenn ich nun apt-get update mache erhalte ich folgendes:</p>
<pre><code>user@iobroker-ubuntu:~$ apt-get update
E: Sperrdatei /var/lib/apt/lists/lock konnte nicht geöffnet werden. - open (13: Permission denied)
E: Das Verzeichnis /var/lib/apt/lists/ kann nicht gesperrt werden.
W: Problem beim Entfernen (unlink) der Datei /var/cache/apt/pkgcache.bin - RemoveCaches (13: Permission denied)
W: Problem beim Entfernen (unlink) der Datei /var/cache/apt/srcpkgcache.bin - RemoveCaches (13: Permission denied)
</code></pre>
]]></description><link>https://forum.iobroker.net/post/833679</link><guid isPermaLink="true">https://forum.iobroker.net/post/833679</guid><dc:creator><![CDATA[tilly]]></dc:creator><pubDate>Mon, 25 Jul 2022 11:34:12 GMT</pubDate></item><item><title><![CDATA[Reply to Nach Nodejs Update kein Adapter mehr updatebar on Fri, 22 Jul 2022 11:59:28 GMT]]></title><description><![CDATA[<p dir="auto">Na ja bevor ich ein Backup zurück sichern würde, würde ich eher meine Methode noch versuchen, das ist wesentlich weniger zeitaufwändig. Habs noch ergänzt bevor man das macht natürlich - Image oder komplettsicherung des Systems und IOB stop ( hab ich noch ergänzt).</p>
]]></description><link>https://forum.iobroker.net/post/831707</link><guid isPermaLink="true">https://forum.iobroker.net/post/831707</guid><dc:creator><![CDATA[mickym]]></dc:creator><pubDate>Fri, 22 Jul 2022 11:59:28 GMT</pubDate></item><item><title><![CDATA[Reply to Nach Nodejs Update kein Adapter mehr updatebar on Fri, 22 Jul 2022 11:36:43 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/tilly" aria-label="Profile: tilly">@<bdi>tilly</bdi></a></p>
<p dir="auto"><a href="https://forum.iobroker.net/topic/56343/vorgehensweise-im-bezug-auf-update-node-js-16-probleme?_=1658397690595">https://forum.iobroker.net/topic/56343/vorgehensweise-im-bezug-auf-update-node-js-16-probleme?_=1658397690595</a></p>
<p dir="auto">schätze Du meinst den Thread ( <a class="plugin-mentions-user plugin-mentions-a" href="/user/thomas-braun" aria-label="Profile: Thomas-Braun">@<bdi>Thomas-Braun</bdi></a> )</p>
]]></description><link>https://forum.iobroker.net/post/831703</link><guid isPermaLink="true">https://forum.iobroker.net/post/831703</guid><dc:creator><![CDATA[haselchen]]></dc:creator><pubDate>Fri, 22 Jul 2022 11:36:43 GMT</pubDate></item><item><title><![CDATA[Reply to Nach Nodejs Update kein Adapter mehr updatebar on Fri, 22 Jul 2022 11:33:00 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/tilly" aria-label="Profile: tilly">@<bdi>tilly</bdi></a></p>
<p dir="auto">Dann versuch die Roßkur, die <a class="plugin-mentions-user plugin-mentions-a" href="/user/crunchip" aria-label="Profile: crunchip">@<bdi>crunchip</bdi></a> schon mal vorgestellt hat.</p>
]]></description><link>https://forum.iobroker.net/post/831702</link><guid isPermaLink="true">https://forum.iobroker.net/post/831702</guid><dc:creator><![CDATA[Thomas Braun]]></dc:creator><pubDate>Fri, 22 Jul 2022 11:33:00 GMT</pubDate></item><item><title><![CDATA[Reply to Nach Nodejs Update kein Adapter mehr updatebar on Fri, 22 Jul 2022 11:30:14 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/thomas-braun" aria-label="Profile: thomas-braun">@<bdi>thomas-braun</bdi></a></p>
<p dir="auto">Habe ich gelöscht und wollte Alexa2 installieren, da sagt er mir ist up to date, komisch.</p>
<p dir="auto">Als ich dann cloud aktualisieren wollte:</p>
<pre><code>user@iobroker-ubuntu:/opt/iobroker$ iobroker upgrade cloud --debug
This upgrade of "cloud" will introduce the following changes:
-&gt; 4.2.1:
Used new version of socket library.
Would you like to upgrade cloud from @4.2.0 to @4.2.1 now? [(y)es, (n)o]: y
Update cloud from @4.2.0 to @4.2.1
NPM version: 8.11.0
Installing iobroker.cloud@4.2.1... (System call)
npm ERR! code ENOTEMPTY
npm ERR! syscall rename
npm ERR! path /opt/iobroker/node_modules/abbrev
npm ERR! dest /opt/iobroker/node_modules/.abbrev-5eNud0FY
npm ERR! errno -39
npm ERR! ENOTEMPTY: directory not empty, rename '/opt/iobroker/node_modules/abbrev' -&gt; '/opt/iobroker/node_modules/.abbrev-5eNud0FY'
npm ERR!     /home/iobroker/.npm/_logs/2022-07-22T11_25_03_406Z-debug-0.log
host.iobroker-ubuntu Cannot install iobroker.cloud@4.2.1: 217
</code></pre>
<p dir="auto">und die ganzen Verzeichnisse mit.xyz sind auf einmal alle wieder da, obwohl iobroker die ganze zeit aus ist.</p>
]]></description><link>https://forum.iobroker.net/post/831697</link><guid isPermaLink="true">https://forum.iobroker.net/post/831697</guid><dc:creator><![CDATA[tilly]]></dc:creator><pubDate>Fri, 22 Jul 2022 11:30:14 GMT</pubDate></item><item><title><![CDATA[Reply to Nach Nodejs Update kein Adapter mehr updatebar on Fri, 22 Jul 2022 11:24:27 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/tilly" aria-label="Profile: tilly">@<bdi>tilly</bdi></a> sagte in <a href="/post/831686">Nach Nodejs Update kein Adapter mehr updatebar</a>:</p>
<blockquote>
<p dir="auto">ENOTEMPTY: directory not empty, rename  /opt/iobroker/node_modules/node-red-node-email/node_modules/encoding-japanese/src' -&gt; '/opt/iobroker/node_modules/.node-red-node-email-1lk8B7Gi/node_modules/encoding-japanese/src</p>
</blockquote>
<p dir="auto">Das Spiel ist immer das gleiche...</p>
<pre><code>rm -rf /opt/iobroker/node_modules/.node-red-node-email-1lk8B7Gi/node_modules/encoding-japanese/src
</code></pre>
]]></description><link>https://forum.iobroker.net/post/831689</link><guid isPermaLink="true">https://forum.iobroker.net/post/831689</guid><dc:creator><![CDATA[Thomas Braun]]></dc:creator><pubDate>Fri, 22 Jul 2022 11:24:27 GMT</pubDate></item><item><title><![CDATA[Reply to Nach Nodejs Update kein Adapter mehr updatebar on Fri, 22 Jul 2022 11:19:38 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/thomas-braun" aria-label="Profile: thomas-braun">@<bdi>thomas-braun</bdi></a></p>
<p dir="auto">zwave gelöscht und alexa2 erneut versucht zu installieren</p>
<pre><code>user@iobroker-ubuntu:/opt/iobroker$ iobroker upgrade alexa2 --debug
This upgrade of "alexa2" will introduce the following changes:
-&gt; 3.18.6:
Fix deviceStop sequence command
-&gt; 3.18.5:
Fix crash case reported by Sentry
Add image for Fire Cube
-&gt; 3.18.3:
Fix doNotDisturb and doNotDisturb for All devices
Update do not disturb status after set for all devices
preserve a changed name for a "This device" device object
-&gt; 3.18.2:
Enable commands again for Apps with type A2TF17PFR55MTB - will only work sometimes as it seems
Would you like to upgrade alexa2 from @3.18.1 to @3.18.6 now? [(y)es, (n)o]: y
Update alexa2 from @3.18.1 to @3.18.6
NPM version: 8.11.0
Installing iobroker.alexa2@3.18.6... (System call)
npm WARN deprecated dgram@1.0.1: npm is holding this package for security reasons. As it's a core Node module, we will not transfer it over to other users. You may safely remove the package from your dependencies.
npm WARN deprecated crypto@1.0.1: This package is no longer supported. It's now a built-in Node module. If you've depended on crypto, you should switch to the one that's built-in.
npm WARN deprecated node-xmpp-tls-connect@1.0.1: this package is deprecated please use https://github.com/xmppjs/xmpp.js
npm WARN deprecated request-promise-native@1.0.9: request-promise-native has been deprecated because it extends the now deprecated request package, see https://github.com/request/request/issues/3142
npm WARN deprecated har-validator@5.1.5: this library is no longer supported
npm WARN deprecated request-promise@4.2.6: request-promise has been deprecated because it extends the now deprecated request package, see https://github.com/request/request/issues/3142
npm WARN deprecated node-xmpp-core@5.0.9: this package is deprecated please use https://github.com/xmppjs/xmpp.js
npm WARN deprecated json3@3.3.2: Please use the native JSON object instead of JSON 3
npm WARN deprecated querystring@0.2.1: The querystring API is considered Legacy. new code should use the URLSearchParams API instead.
npm WARN deprecated node-inspect@2.0.0: This module is part of Node.js core and does not need to be installed separately. It is now unmaintained.
npm WARN deprecated multer@1.4.4: Multer 1.x is affected by CVE-2022-24434. This is fixed in v1.4.4-lts.1 which drops support for versions of Node.js before 6. Please upgrade to at least Node.js 6 and version 1.4.4-lts.1 of Multer. If you need support for older versions of Node.js, we are open to accepting patches that would fix the CVE on the main 1.x release line, whilst maintaining compatibility with Node.js 0.10.
npm WARN deprecated debug@4.1.1: Debug versions &gt;=3.2.0 &lt;3.2.7 || &gt;=4 &lt;4.3.1 have a low-severity ReDos regression when used in a Node.js environment. It is recommended you upgrade to 3.2.7 or 4.3.1. (https://github.com/visionmedia/debug/issues/797)
npm WARN deprecated querystring@0.2.0: The querystring API is considered Legacy. new code should use the URLSearchParams API instead.
npm WARN deprecated uuid@3.4.0: Please upgrade  to version 7 or higher.  Older versions may use Math.random() in certain circumstances, which is known to be problematic.  See https://v8.dev/blog/math-random for details.
npm WARN deprecated uuid@3.3.2: Please upgrade  to version 7 or higher.  Older versions may use Math.random() in certain circumstances, which is known to be problematic.  See https://v8.dev/blog/math-random for details.
npm WARN deprecated request@2.88.2: request has been deprecated, see https://github.com/request/request/issues/3142
npm WARN deprecated appium-logger@2.1.0: Moved into appium-support
npm WARN deprecated node-xmpp-client@3.2.0: this package is deprecated please use https://www.npmjs.com/package/@xmpp/client
npm WARN deprecated axios@0.27.0: Formdata complete broken, incorrect build size
npm WARN deprecated core-js@1.2.7: core-js@&lt;3.23.3 is no longer maintained and not recommended for usage due to the number of issues. Because of the V8 engine whims, feature detection in old core-js versions could cause a slowdown up to 100x even if nothing is polyfilled. Some versions have web compatibility issues. Please, upgrade your dependencies to the actual version of core-js.
npm WARN deprecated core-js@2.6.12: core-js@&lt;3.23.3 is no longer maintained and not recommended for usage due to the number of issues. Because of the V8 engine whims, feature detection in old core-js versions could cause a slowdown up to 100x even if nothing is polyfilled. Some versions have web compatibility issues. Please, upgrade your dependencies to the actual version of core-js.
npm ERR! path /opt/iobroker/node_modules/node-red-node-email/node_modules/encoding-japanese/src
npm ERR! dest /opt/iobroker/node_modules/.node-red-node-email-1lk8B7Gi/node_modules/encoding-japanese/src
npm ERR! errno -39
npm ERR! ENOTEMPTY: directory not empty, rename '/opt/iobroker/node_modules/node-red-node-email/node_modules/encoding-japanese/src' -&gt; '/opt/iobroker/node_modules/.node-red-node-email-1lk8B7Gi/node_modules/encoding-japanese/src'
npm ERR!     /home/iobroker/.npm/_logs/2022-07-22T11_15_10_431Z-debug-0.log
host.iobroker-ubuntu Cannot install iobroker.alexa2@3.18.6: 217
</code></pre>
]]></description><link>https://forum.iobroker.net/post/831686</link><guid isPermaLink="true">https://forum.iobroker.net/post/831686</guid><dc:creator><![CDATA[tilly]]></dc:creator><pubDate>Fri, 22 Jul 2022 11:19:38 GMT</pubDate></item><item><title><![CDATA[Reply to Nach Nodejs Update kein Adapter mehr updatebar on Fri, 22 Jul 2022 10:14:34 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/tilly" aria-label="Profile: tilly">@<bdi>tilly</bdi></a></p>
<pre><code>iobroker del zwave
</code></pre>
]]></description><link>https://forum.iobroker.net/post/831640</link><guid isPermaLink="true">https://forum.iobroker.net/post/831640</guid><dc:creator><![CDATA[Thomas Braun]]></dc:creator><pubDate>Fri, 22 Jul 2022 10:14:34 GMT</pubDate></item><item><title><![CDATA[Reply to Nach Nodejs Update kein Adapter mehr updatebar on Tue, 01 Nov 2022 16:35:01 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/tilly" aria-label="Profile: tilly">@<bdi>tilly</bdi></a> sagte in <a href="/post/831630">Nach Nodejs Update kein Adapter mehr updatebar</a>:</p>
<blockquote>
<p dir="auto">wie würde ich da vorgehen?</p>
</blockquote>
<p dir="auto">also in das /opt/iobroker Verzeichnis wechseln.<br />
IOB stoppen natürlich:</p>
<pre><code>iob stop
</code></pre>
</code></pre>
<p dir="auto">komplettes node_modules Verzeichnis löschen oder das Verzeichnis umbenennen</p>
<pre><code>sudo rm -rf node_modules
</code></pre>
<p dir="auto">bzw.</p>
<pre><code>sudo mv node_modules node_modules.bak
</code></pre>
<p dir="auto">etwaige package-lock.json löschen</p>
<pre><code>sudo rm package-lock.json
</code></pre>
<p dir="auto">Den cache sicherheitshalber noch leeren:</p>
<pre><code>npm cache clean --force
</code></pre>
<p dir="auto">Dann das node_modules neu aufbauen lassen:</p>
<pre><code>npm install
</code></pre>
<p dir="auto">Die ganzen Informationen über die Adapter und deren Abhängigkeiten stehen in der package.json.</p>
<p dir="auto">Eine datensicherung oder ein Image würde ich aber in jedem Fall machen, falls was nicht geht. Ist aber noch schneller, als das ganze System neu aufzubauen.</p>
<p dir="auto">zum Schluss in dem Verzeichnis /opt/iobroker noch den Befehl</p>
<pre><code>npm list
</code></pre>
<p dir="auto">und schauen, ob Du einen sauberen Baum hast. npm cache hast ja soweit ich sehe schon gelöscht.</p>
]]></description><link>https://forum.iobroker.net/post/831638</link><guid isPermaLink="true">https://forum.iobroker.net/post/831638</guid><dc:creator><![CDATA[mickym]]></dc:creator><pubDate>Tue, 01 Nov 2022 16:35:01 GMT</pubDate></item><item><title><![CDATA[Reply to Nach Nodejs Update kein Adapter mehr updatebar on Fri, 22 Jul 2022 09:57:06 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/mickym" aria-label="Profile: mickym">@<bdi>mickym</bdi></a></p>
]]></description><link>https://forum.iobroker.net/post/831630</link><guid isPermaLink="true">https://forum.iobroker.net/post/831630</guid><dc:creator><![CDATA[tilly]]></dc:creator><pubDate>Fri, 22 Jul 2022 09:57:06 GMT</pubDate></item><item><title><![CDATA[Reply to Nach Nodejs Update kein Adapter mehr updatebar on Fri, 22 Jul 2022 09:55:07 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/thomas-braun" aria-label="Profile: thomas-braun">@<bdi>thomas-braun</bdi></a></p>
<p dir="auto">der kommt vom zwave adapter. Den lösche ich dann mit: iobroker del zwave2?</p>
<pre><code>user@iobroker-ubuntu:/opt/iobroker$ npm ls openzwave-shared
[sudo] password for user:
iobroker.inst@2.0.2 /opt/iobroker
└─┬ iobroker.zwave@2.0.1
  └── openzwave-shared@1.7.2
</code></pre>
]]></description><link>https://forum.iobroker.net/post/831628</link><guid isPermaLink="true">https://forum.iobroker.net/post/831628</guid><dc:creator><![CDATA[tilly]]></dc:creator><pubDate>Fri, 22 Jul 2022 09:55:07 GMT</pubDate></item></channel></rss>
