  4. JavaScript
  5. Hilfe bei der Script erstellung
98 Beiträge 6 Kommentatoren 13.0k Aufrufe 5 Beobachtet
  • T T0biT3ch
    @ticaki
    jetzt kommt das in die log
    error	javascript.0 (6446) script.js.Pager_Alarmierung.Funktion05_2wayS_Status_abfrage: ReferenceError: setIntervall is not defined
    error	javascript.0 (6446) at script.js.Pager_Alarmierung.Funktion05_2wayS_Status_abfrage:17:1
    error	javascript.0 (6446) at script.js.Pager_Alarmierung.Funktion05_2wayS_Status_abfrage:48:3
    T0biT3ch
    #74
    wenn ich es so mache
    var axios = require('axios');
    var trid = "0_userdata.0.E-Message.E-Message-TrackingID";
    var token = "0_userdata.0.E-Message.E-Message-Token";
    var data = '';
    var config = {
      method: 'get',
      url: 'https://api.emessage.de/rs/eGetMessages/External/' + getState(trid).val ,
      headers: {
        'Authorization':  'Bearer ' + getState(token).val,
      data : data
    shedule("*/5 * * * * *", function() {
        axios(config)
        .then(function (response)
       {var recipients = response.data.data.recipients;
            setState("0_userdata.0.E-Message_Response.QuittierungCode", recipients[0].status[0].answer, true);
            console.log('Rueckmeldung: ' + recipients[0].status[0].answer)
            setState("0_userdata.0.E-Message_Response.Identifer", recipients[0].identifier, true);
            console.log('PagerRufnummer: ' + recipients[0].identifier)
            setState("0_userdata.0.E-Message_Response.Service", recipients[0].service, true);
            console.log('ServiceTyp: ' + recipients[0].service)
            setState("0_userdata.0.E-Message_Response.PagerName", recipients[0].status[0].devices[0].deviceName, true);
            console.log('PagerName: ' + recipients[0].status[0].devices[0].deviceName)
            setState("0_userdata.0.E-Message_Response.PagerSerial", recipients[0].status[0].devices[0].deviceSerial, true);
            console.log('Seriennummer: ' + recipients[0].status[0].devices[0].deviceSerial)
       .catch(function(error) {
           console.log(error);
    kommt in der log
    error	javascript.0 (6446) script.js.Pager_Alarmierung.Funktion05_2wayS_Status_abfrage compile failed: at script.js.Pager_Alarmierung.Funktion05_2wayS_Status_abfrage:48
    aber der code hat ja keine 48 zeilen 🤔
    • T T0biT3ch
      var data = '';
      var config = {
        method: 'get',
        headers: {
        data : data
          axios(config)
             console.log(error);
      kommt in der log
      ticaki
      #75
      @t0bit3ch
      Du müsstest zumindest kleine Syntaxfehler selbst beheben. shedule - ein Schreibfehler es ist schedule und bei meinem Beispiel setIntervall ist setInterval ebenfalls ein Schreibfehler der ohne Editor halt mal vorkommt. Die sind meist unterstrichen, was nicht heißt das alles unterstrichene ein Fehler ist.
      in deinem Beispiel code fehlt auch ein weiteres:
      am Ende
      hier siehst du die ioBroker Funktionen: https://github.com/ioBroker/ioBroker.javascript/blob/master/docs/en/javascript.md
      Außerdem hat der Adapter zumindest bei mir den Bug das er mir die letzten 3-5 Zeilen nicht anzeigt und ich erstmal ganz ans ende mit den Cursortasten gehe und ein paar Leerzeilen einfüge.
      Spenden
      • T ticaki
        @t0bit3ch
        am Ende
        T0biT3ch
        #76
        @ticaki
        sorry für die späte rückmeldung. erstmal danke für deine hilfe, leider bin ich mit dem javascript noch nicht so ganz vertraut.
        habe mir übers wochenende aber schon einiges an lektüre durchgelesen. jetzt wo ich den tip mit den schreibfehler bekommen habe hatte ich gesehen das es im code unterstrichen war. hab ich wohl vor lauter code übersehen.
        habe den code jetzt mit
        setIntervall(function() { axios(config).then(function (response) {... }).catch(function(error) { console.log(error); }); }, 5 * 1000);
        am laufen.
        vielen dank euch nochmal für die unterstützung, ihr seid klasse. 👍
          T0biT3ch
          schrieb am zuletzt editiert von T0biT3ch
          #77
          @OliverIO @ticaki @fastfoot
          Guten Abend Profis,
          Ich habe folgendes Problem welches schnellstmöglich gelöst werden muss da ich leider keine Alarme mehr bekomme.
          Heute hat mein ioBroker ein Update gemacht und jetzt läuft meine Alarmierung nicht mehr.
          hier mein bis heute vor dem Update funktionierendes Skript
          const axios = require('axios');
          var alarmmeldung_ml = "0_userdata.0.Alarmmeldungen.Alarmierungstext_Variable";
          console.log(getState("0_userdata.0.E-Message_Data.E-Message-TrackingID").val);
          function auth() {
              axios.post('https://api.emessage.de/auth/login',{
                  username: '******',         //* E*Message Benutzername */
                  password: '*******'   //* E*Message Kennwort */
                  headers: {
                      'Authorization': 'Basic Og==',
                      'Content-Type': 'application/json',
              }).then(function (response) {
                  if (response.status==200) {
                      var token = response.data.data.jwt;
                      setState("0_userdata.0.E-Message_Data.E-Message-Token", response.data.data.jwt, true);
                      sendMessage(token)
              .catch(function (error) {
                  console.log(error);
          function sendMessage(token) {
              axios.post('https://api.emessage.de/rs/eSendMessages',{
                  "messageText": getState(alarmmeldung_ml).val,     //* Pocsag Nachricht an Pager */ //* bei mir durch einen Datenpunkt ersetzt */
                  "recipients": [
                      "serviceName": "2wayS",  //* Alarmierungstyp */ //* eCityruf - eBos - 2wayS */ eCityruf */
                      "identifier": "******"     //* E*Message Funkrufnummer */
                      headers: {
                          'Authorization': 'Bearer ' + token,
                      setState("0_userdata.0.E-Message_Data.E-Message-TrackingID", response.data.data.trackingId, true);
                      var recipients = JSON.stringify(response.data.data.recipients);
                      setState("0_userdata.0.E-Message_Data.E-Message-Recipients", recipients, true);
                      console.log (JSON.stringify(response.data.data));  //(tridneu);
                      createEventlog("Alarmierung :" , getState(alarmmeldung_ml).val);
                      //var trid = JSON.stringify(response.data.data.trackingId);
                      //var tridneu = trid.substr(1, trid.length - 2);
                      //setState("0_userdata.0.E-Message.E-Message-TrackingID", tridneu);
                  console.log(error);
          auth();
          nach dem Update kommt folgender fehler in der Log
          javascript.0 (4430) script.js.Alarmierung_Pager_via_Wago.Pager_ausloesen.Pager_ausloesen: {'message':'Request failed with status code 401','name':'AxiosError','config':{'transitional':{'silentJSONParsing':true,'forcedJSONParsing':true,'clarifyTimeoutError':false},'transformRequest':[null],'transformResponse':[null],'timeout':0,'xsrfCookieName':'XSRF-TOKEN','xsrfHeaderName':'X-XSRF-TOKEN','maxContentLength':-1,'maxBodyLength':-1,'env':{},'headers':{'Accept':'application/json, text/plain, */*','Content-Type':'application/json','User-Agent':'axios/0.27.2','Content-Length':100},'method':'post','url':'https://api.emessage.de/rs/eSendMessages','data':'{\'messageText\':\'keine Aktive Meldung\',\'recipients\':[{\'serviceName\':\'2wayS\',\'identifier\':\'******\'}]}'},'code':'ERR_BAD_REQUEST','status':401}
          Ich hoffe Ihr könnt mir bei dem Problem behilflich sein.
          HomoranH OliverIOO 2 Antworten Letzte Antwort
          • T T0biT3ch
            Guten Abend Profis,
            function auth() {
                    headers: {
                        sendMessage(token)
                    console.log(error);
                    "recipients": [
                        headers: {
                    console.log(error);
            auth();
            #78
            @t0bit3ch hat das irgendwas mit dem bisherigen Thread zu tun?
            wenn nein, bitte neuen Thread mit allen notwendigen Informationen aufmachen
            • T T0biT3ch
              Guten Abend Profis,
              function auth() {
                      headers: {
                          sendMessage(token)
                      console.log(error);
                      "recipients": [
                          headers: {
                      console.log(error);
              auth();
              OliverIOO Offline
              OliverIOO Offline
              OliverIO
              #79
              @t0bit3ch sagte in Hilfe bei der Script erstellung:
              api.emessage.de
              @Homoran ja hat es.
              @T0biT3ch
              Die Fehlermeldung ist etwas uneinheitlich
              1. Fehlermeldung 401 bedeutet eigentlich Unauthorized
                https://developer.mozilla.org/de/docs/Web/HTTP/Status/401
                Stimmen deine Anmeldeparameter?
              2. Weiterhin steht aber auch ERR_BAD_REQUEST (was auch der Fehlercode 400 sein kann)
                Der steht dafür das der Server die Anfrage nicht verarbeiten kann, was auf eine evtl API-Änderung hinweisen kann
              3. als messageText steht auch "keine Aktive Meldung"
                Was ja als normale Rückmeldung zu werten wäre.
              Kannst du mal 1+2 Überprüfen ob es da Änderungen gab?
              Meine Adapter und Widgets
              Links im Profil
              • OliverIOO OliverIO
                api.emessage.de
                @Homoran ja hat es.
                @T0biT3ch
                T0biT3ch
                #80
                @oliverio
                zu 1. Ja die Anmeldeparameter Stimmen, habe alles mit dem Programm Postman überprüft.
                zu 2. Ich denke die API Parameter sind noch korrekt da ich Sie grad in Postman getestet habe und Sie heute Vormittag vor dem Update auch noch Funktioniert haben.
                zu 3. der Text "keine Aktive Meldung" wir nach jedem Senden einer Alarmmeldung Automatisch in den Datenpunkt geschrieben und dient nur als Dummy
                • T T0biT3ch
                  @oliverio
                  OliverIOO Offline
                  OliverIOO Offline
                  OliverIO
                  #81
                  @t0bit3ch
                  und mit postman kannst du dich anmelden, den token abholen
                  und auch die daten abrufen?
                  Links im Profil
                  T 2 Antworten Letzte Antwort
                    @t0bit3ch
                    T0biT3ch
                    #82
                    @oliverio
                    ja damit funktioniert es
                      @t0bit3ch
                      T0biT3ch
                      #83
                      @oliverio
                      Es wurde an den Programmen nichts verändert oder an den Einstellungen vom ioBroker. Es lief alles wunderbar und nach dem Update habe ich mich gewundert das kein Alarm mehr gesendet wird. habe auch versucht den JavaScript Adapter auf eine vorherige Version zurück zu setzen, aber ohne erfolg.
                      • T T0biT3ch
                        @oliverio
                        OliverIOO Offline
                        OliverIOO Offline
                        OliverIO
                        #84
                        @t0bit3ch
                        dann muss es noch ein unterschied zwischen deinen aufbereiteten daten und den vom postman geben.
                        kann ich aber schlecht vergleichen
                        der abruf des tokens funktionier?
                        dann kann man den ersten teil schon mal abhaken.
                        für den 2.Teil jede einzelne Information prüfen, ob sie in der richtigen form in das objekt wandert. am besten das objekt vor absenden einmal ausgeben. also das hier
                                "recipients": [
                                    headers: {
                        und dann auch mit den daten vom postman vergleichen, ob das genau identisch aufgebaut ist.
                        nicht das in der message zeichen enthalten sind die nicht erlaubt sind
                        oder nicht escapete Anführungsstriche
                        Links im Profil
                          @t0bit3ch
                                  "recipients": [
                                      headers: {
                          T0biT3ch
                          #85
                          @oliverio
                          hatte es nochmal im ioBroker mit diesen Scripten probiert
                          var data = JSON.stringify({
                            "username": "USERNAME",
                            "password": "PASSWORD"
                          var config = {
                            method: 'post',
                            url: 'https://api.emessage.de/auth/login',
                            headers: {
                            data : data
                          axios(config)
                            console.log(JSON.stringify(response.data));
                            console.log(error);
                            "messageText": "Testnachricht",
                            "recipients": [
                                "serviceName": "eCityruf",
                                "identifier": "********"
                          var config = {
                            method: 'post',
                            url: 'https://api.emessage.de/rs/eSendMessages',
                            headers: {
                              'Authorization': 'Bearer hgöfhogsioghösibnovdjuös<opriheourhweidjmanspkf<gob vuodsöahgbfdosuib0dsifohw84u0ü93rhfouisjhbgnvsoifedsökgpfingüer4984utißqü+äowfmägjhipoqehwfüouasdhgousgjohugurhgjiwehfgiwhfwquhbdcasukojgbhikgögloadfjasfghitiu<fbghkjybgvidfgdhfhgkjhlkzthgtzjklioölzfkdtjrhgstgfzhjui.k,mnjhbgvfadeshgjm',
                            data : data
                          axios(config)
                            console.log(error);
                          und damit hat es funktioniert. Ich kann in meinem Script keinen unterschied feststellen
                            @t0bit3ch
                                    "recipients": [
                                        headers: {
                            T0biT3ch
                            #86
                            @oliverio
                            Hatte jetzt nochmal dieses Script genommen
                            function auth() {
                                    username: 'USERNAME',
                                    password: 'PASSWORD'
                                    headers: {
                                        sendMessage(token)
                                    console.log(error);
                                    "recipients": [
                                        headers: {
                                    console.log(error);
                            auth();
                            und bekomme diese Log
                            javascript.0 (4430) script.js.Alarmierung_Pager_via_Wago.Pager_ausloesen.Test: {'message':'Request failed with status code 401','name':'AxiosError','config':{'transitional':{'silentJSONParsing':true,'forcedJSONParsing':true,'clarifyTimeoutError':false},'transformRequest':[null],'transformResponse':[null],'timeout':0,'xsrfCookieName':'XSRF-TOKEN','xsrfHeaderName':'X-XSRF-TOKEN','maxContentLength':-1,'maxBodyLength':-1,'env':{},'headers':{'Accept':'application/json, text/plain, */*','Content-Type':'application/json','User-Agent':'axios/0.27.2','Content-Length':93},'method':'post','url':'https://api.emessage.de/rs/eSendMessages','data':'{\'messageText\':\'Testnachricht\',\'recipients\':[{\'serviceName\':\'2wayS\',\'identifier\':\'*****\'}]}'},'code':'ERR_BAD_REQUEST','status':401}
                            und der Pager bleibt still
                            • T T0biT3ch
                              @oliverio
                              function auth() {
                                      headers: {
                                          sendMessage(token)
                                      console.log(error);
                                      "recipients": [
                                          headers: {
                                      console.log(error);
                              auth();
                              OliverIOO Offline
                              OliverIOO Offline
                              OliverIO
                              #87
                              @t0bit3ch
                              der unterschied ist, das du einmal das token fest vorgegeben hast und beim anderen life abfragst
                              dann stimmt an der abfrage des tokens oder dem einfügen des tokens etwas nicht
                              Links im Profil
                              • T T0biT3ch
                                @oliverio
                                function auth() {
                                        headers: {
                                            sendMessage(token)
                                        console.log(error);
                                        "recipients": [
                                            headers: {
                                        console.log(error);
                                auth();
                                OliverIOO Offline
                                OliverIOO Offline
                                OliverIO
                                #88
                                @t0bit3ch
                                und beim ersten wird data als JSON.stringify hinzugefügt
                                Beim 2. direkt als Objekt.
                                mach da auch mal ein stringify drum rum
                                beim 2. sind auch noch header dabei, beim ersten nicht
                                Links im Profil
                                  @t0bit3ch
                                  T0biT3ch
                                  #89
                                  @oliverio
                                  aber in diesem Script wird der Token doch in keinem Datenpunkt hinterlegt oder?
                                  function auth() {
                                          headers: {
                                              sendMessage(token)
                                          console.log(error);
                                          "recipients": [
                                              headers: {
                                          console.log(error);
                                  auth();
                                    @t0bit3ch
                                    T0biT3ch
                                    #90
                                    @oliverio
                                    ich verstehe nur Bahnhof 🤦
                                      @t0bit3ch
                                      T0biT3ch
                                      #91
                                      @oliverio
                                      habe es jetzt erstmal so gelöst damit zumindest wieder Alarmierungen kommen...
                                      das Script zum Token holen
                                        "username": "********",
                                        "password": "********"
                                      var config = {
                                        method: 'post',
                                        headers: {
                                        data : data
                                      axios(config)
                                        console.log(error);
                                      await wait(2000);
                                      setState("javascript.0.scriptEnabled.Alarmierung_Pager_via_Wago.Pager_ausloesen.abfrage"/*scriptEnabled.Alarmierung_Pager_via_Wago.Pager_ausloesen.abfrage*/, true);
                                      await wait(1000);
                                      setState("javascript.0.scriptEnabled.Alarmierung_Pager_via_Wago.Pager_ausloesen.Test"/*scriptEnabled.Alarmierung_Pager_via_Wago.Pager_ausloesen.Pager_ausloesen_CityRuf*/, false);
                                      dann starte ich das Script zum Meldungen senden
                                      var token = "0_userdata.0.E-Message_Data.E-Message-Token";
                                        "recipients": [
                                            "identifier": "*******"
                                      var config = {
                                        method: 'post',
                                        headers: {
                                        data : data
                                      axios(config)
                                        console.log(error);
                                      await wait(1000);
                                      setState("javascript.0.scriptEnabled.Alarmierung_Pager_via_Wago.Pager_ausloesen.abfrage"/*scriptEnabled.Alarmierung_Pager_via_Wago.Pager_ausloesen.abfrage*/, false);
                                      Die abfrage der Quittung funktioniert weiter wie bisher.
                                      vielleicht könnt ihr mir ja helfen die Scripte wieder zu vereinen. damit es so wie vor dem Update läuft.
                                      Vielen dank und einen schönen Abend
                                      • T T0biT3ch
                                        @oliverio
                                        var config = {
                                          method: 'post',
                                          headers: {
                                          data : data
                                        axios(config)
                                          console.log(error);
                                        await wait(2000);
                                        await wait(1000);
                                          "recipients": [
                                        var config = {
                                          method: 'post',
                                          headers: {
                                          data : data
                                        axios(config)
                                          console.log(error);
                                        await wait(1000);
                                        OliverIOO Offline
                                        OliverIOO Offline
                                        OliverIO
                                        #92
                                        @t0bit3ch
                                        sehr gut, du hast selber rausgefunden was ich mit meinem post gemeint habe, oder?
                                        JSON.stringify mit den Messagedaten und
                                        die header aus der Anfrage entfernt.
                                        Links im Profil
                                          @t0bit3ch
                                          T0biT3ch
                                          #93
                                          @oliverio
                                          Moin,
                                          Ja nach langem lesen, vergleichen und probieren hab ich mir was zusammen gestrickt. Wirklich schlauer bin ich aber immer noch nicht. mir ist es schleierhaft warum das alte funktionierende script nicht mehr funktioniert
