  4. Test Adapter KNX v2.x
421 Beiträge 70 Kommentatoren 148.1k Aufrufe 62 Beobachtet
  • L lessthanmore
    @jojos said in Test Adapter KNX v2.x:
    wo kann ich nochmal sehen ob ich das benutze
    iob status
    gibt dann sowas:
    iob status
    At least one iobroker host is running.
    Objects type: redis
    States  type: redis
    JojoS
    schrieb am zuletzt editiert von JojoS
    #315
    @lessthanmore danke, ich benutze json1
    @chefkoch009
    knx.0	2022-06-15 13:15:24.204	info	( 4.b ) return to STATE_READY, processing : false
    knx.0	2022-06-15 13:15:24.204	info	( 4 ) Sending Tunnel_Request ACK : 06 10 04 21 00 0a 04 59 10 00 ChID : 89 SeqCntIN : 16 SeqCntOUT : 142 queue length : 0
    knx.0	2022-06-15 13:15:24.203	info	=====> STATE_TUNNELING_ACK
    knx.0	2022-06-15 13:15:24.202	info	WRITE : mappedName : Terasse Steckdose3 li Status dest : 3/1/3 val: 0 (DPT1.011) Terasse_Steckdose3_li_Status
    knx.0	2022-06-15 13:15:24.202	info	( 3.2 ) Received TUNNEL_REQUEST (WRITE - send ACK ) : 06 10 04 20 00 15 04 59 10 00 29 00 bc e0 11 03 19 03 01 00 80 ChID: 89
    knx.0	2022-06-15 13:15:24.149	info	( 4.b ) return to STATE_READY, processing : false
    knx.0	2022-06-15 13:15:24.149	info	( 4 ) Sending Tunnel_Request ACK : 06 10 04 21 00 0a 04 59 0f 00 ChID : 89 SeqCntIN : 15 SeqCntOUT : 142 queue length : 0
    knx.0	2022-06-15 13:15:24.148	info	=====> STATE_TUNNELING_ACK
    knx.0	2022-06-15 13:15:24.148	info	( 3.6a ) Received L_DATA.con 06 10 04 20 00 15 04 59 0f 00 2e 00 bc e0 11 64 18 03 01 00 80 was successfully processed by receiver.
    knx.0	2022-06-15 13:15:24.131	info	==> easy-knx.js: signal runtime : 0s 1.209669ms
    knx.0	2022-06-15 13:15:24.131	info	==> successful acknowledged previous package... processing next of 0
    knx.0	2022-06-15 13:15:24.131	info	( 2 ) Received TUNNEL_ACK : 06 10 04 21 00 0a 04 59 8d 00 from 192.168.100.64:3671 SeqCntIN : 14 SeqCntOUT : 142 GA : 0/0/0
    knx.0	2022-06-15 13:15:24.130	info	easy-knx: task.data : 06 10 04 20 00 15 04 59 8d 00 11 00 bc e0 11 64 18 03 01 00 80 byteLen : 21
    knx.0	2022-06-15 13:15:24.130	info	( 1 ) Sending : GroupValueWrite : 06 10 04 20 00 15 04 59 8d 00 11 00 bc e0 11 64 18 03 01 00 80 sent to 192.168.100.64:3671 ChID: 89 SeqCntIN : 14 SeqCntOUT : 141 GA : 3/0/3 conCheck.conected : true
    knx.0	2022-06-15 13:15:24.130	info	Has todo still 1 tasks, just processing : false
    knx.0	2022-06-15 13:15:24.129	info	Received CONNECTIONSTATE_RESPONSE : 06 10 02 08 00 08 59 00 192.168.100.64:3671 ChID : 89 SeqCntIN : 14 SeqCntOUT : 141 msgCode : [object Object]
    knx.0	2022-06-15 13:15:24.129	info	Send : conCheck Connection State Request : 06 10 02 07 00 10 59 00 08 01 00 00 00 00 9d 01 sent to 192.168.100.64:3671
    knx.0	2022-06-15 13:15:24.128	info	checkConnectionState 192.168.100.64 State : true
    knx.0	2022-06-15 13:15:17.897	info	BINARY CHANGE change from false to 0
    knx.0	2022-06-15 13:15:17.896	info	easy-knx.js groupValueWrite value: 0 dpt : DPT1.001{"type":"Buffer","data":[6,16,4,32,0,21,4,89,141,0,17,0,188,224,17,100,24,3,1,0,128]}
    knx.0	2022-06-15 13:15:17.896	info	main.js : tGA.write on Statechange : 3/0/3 P-0AC9-0_GA-52 typeof val: boolean false DPT1.001
    das müsste ein Ausschnitt sein wo die Reaktion lange gedauert hat.
    chefkoch009C 1 Antwort Letzte Antwort
    • J JojoS
      @chefkoch009
      chefkoch009C Offline
      chefkoch009
      #316
      @jojos Zwischen Zeile 18 und 19 liegen 7Sek?..... In Zeile 19 hat er alles soweit vorbereitet zum Senden. Dann passiert nix, deshalb fragt er nach, ob die Verbindung noch besteht und bekommt ein OK zurück und sendet unmittelbar danach.
      Die Frage ist nun kann oder will er nicht senden? Tritt das erst nach längerem Betrieb auf, oder direkt beim Start?
      chefkoch009
      J S 2 Antworten Letzte Antwort
      • chefkoch009C chefkoch009
        chefkoch009
        JojoS
        #317
        @chefkoch009 das passiert auch direkt beim Start. Ist das vielleicht was mit Zusammenspiel mit neuem Admin/Controller?
        ich hatte es vorher nochmal mit level silly, da sieht man in der Pause aber auch nichts.
        2022-06-15 12:59:58.628 - info: knx.0 (4178186) =====> STATE_TUNNELING_ACK
        2022-06-15 12:59:58.629 - info: knx.0 (4178186) ( 4 ) Sending Tunnel_Request ACK : 06 10 04 21 00 0a 04 58 d1 00 ChID : 88 SeqCntIN : 209 SeqCntOUT : 106 queue length : 0
        2022-06-15 12:59:58.629 - info: knx.0 (4178186) ( 4.b ) return to STATE_READY, processing : false
        2022-06-15 12:59:58.630 - info: knx.0 (4178186) ( 3.2 ) Received TUNNEL_REQUEST (WRITE - send ACK ) : 06 10 04 20 00 17 04 58 d2 00 29 00 bc e0 11 04 30 03 03 00 80 0c 92 ChID: 88
        2022-06-15 12:59:58.630 - info: knx.0 (4178186) WRITE : mappedName : Schlafzimmer dest : 6/0/3 val: 23.400000000000002 (DPT9.001) Schlafzimmer
        2022-06-15 12:59:58.630 - info: knx.0 (4178186) =====> STATE_TUNNELING_ACK
        2022-06-15 12:59:58.630 - info: knx.0 (4178186) ( 4 ) Sending Tunnel_Request ACK : 06 10 04 21 00 0a 04 58 d2 00 ChID : 88 SeqCntIN : 210 SeqCntOUT : 106 queue length : 0
        2022-06-15 12:59:58.630 - info: knx.0 (4178186) ( 4.b ) return to STATE_READY, processing : false
        2022-06-15 12:59:58.643 - silly: knx.0 (4178186) States user redis pmessage knx.0.*/knx.0.Sensoren.Licht.HelligkeitSchlafzimmer:{"val":511.04,"ack":true,"ts":1655290798641,"q":0,"from":"system.adapter.knx.0","user":"system.user.admin","lc":1655290797661}
        2022-06-15 12:59:58.644 - silly: knx.0 (4178186) States user redis pmessage knx.0.*/knx.0.Sensoren.Temperaturen.Schlafzimmer:{"val":23.400000000000002,"ack":true,"ts":1655290798641,"q":0,"from":"system.adapter.knx.0","user":"system.user.admin","lc":1655290078077}
        2022-06-15 13:00:00.785 - silly: knx.0 (4178186) States user redis pmessage knx.0.*/knx.0.Dosen_schalten.Schalten.Terasse_Steckdose3_li:{"val":true,"ack":false,"ts":1655290800784,"q":0,"from":"system.adapter.web.0","user":"system.user.admin","lc":1655290800784}
        2022-06-15 13:00:00.785 - info: knx.0 (4178186) main.js : tGA.write on Statechange : 3/0/3 P-0AC9-0_GA-52 typeof val: boolean true DPT1.001
        2022-06-15 13:00:00.785 - info: knx.0 (4178186) easy-knx.js groupValueWrite value: 1 dpt : DPT1.001{"type":"Buffer","data":[6,16,4,32,0,21,4,88,106,0,17,0,188,224,17,100,24,3,1,0,129]}
        2022-06-15 13:00:00.786 - info: knx.0 (4178186) BINARY CHANGE change from true to 1
        2022-06-15 13:00:08.631 - info: knx.0 (4178186) checkConnectionState 192.168.100.64 State : true
        2022-06-15 13:00:08.632 - info: knx.0 (4178186) Send : conCheck Connection State Request : 06 10 02 07 00 10 58 00 08 01 00 00 00 00 cd e1 sent to 192.168.100.64:3671
        2022-06-15 13:00:08.632 - info: knx.0 (4178186) Received CONNECTIONSTATE_RESPONSE : 06 10 02 08 00 08 58 00 192.168.100.64:3671 ChID : 88 SeqCntIN : 210 SeqCntOUT : 106 msgCode : [object Object]
        2022-06-15 13:00:08.632 - info: knx.0 (4178186) Has todo still 1 tasks, just processing : false
        2022-06-15 13:00:08.632 - info: knx.0 (4178186) ( 1 ) Sending : GroupValueWrite : 06 10 04 20 00 15 04 58 6a 00 11 00 bc e0 11 64 18 03 01 00 81 sent to 192.168.100.64:3671 ChID: 88 SeqCntIN : 210 SeqCntOUT : 106 GA : 3/0/3 conCheck.conected : true
        2022-06-15 13:00:08.633 - info: knx.0 (4178186) easy-knx: task.data : 06 10 04 20 00 15 04 58 6a 00 11 00 bc e0 11 64 18 03 01 00 81 byteLen : 21
        2022-06-15 13:00:08.633 - info: knx.0 (4178186) ( 2 ) Received TUNNEL_ACK : 06 10 04 21 00 0a 04 58 6a 00 from 192.168.100.64:3671 SeqCntIN : 210 SeqCntOUT : 107 GA : 0/0/0
        2022-06-15 13:00:08.633 - info: knx.0 (4178186) ==> successful acknowledged previous package... processing next of 0
        2022-06-15 13:00:08.633 - info: knx.0 (4178186) ==> easy-knx.js: signal runtime : 0s 0.917653ms
        • J JojoS
          chefkoch009
          schrieb am zuletzt editiert von chefkoch009
          #318
          @jojos Auf meinem Dev-System und Produktionssystem habe ich den 5er Admin laufen.
          Wenn das der einzige Unterschied ist, dann möchte ich einmal in die Runde fragen, ob jemand das bestätigen kann, oder so etwas beobachtet hat.
          Hast Du dieses Verhalten auch, wenn Du direkt über den Objektbaum schaltest oder nur über die Visu?
          chefkoch009
            chefkoch009
            JojoS
            #319
            @chefkoch009 Verzögerungen gab es auch bei Logik über Node Red. Beim Schalten über den Objektbaum gibt es die Verzögerung auch.
            Den Admin habe ich bis 5.4.8 zurück installiert, die Verzögerung tritt trotzdem nur bei KNX 2.0.15 auf. Reproduzierbar, mehrmals verschiedene Versionen installiert.
            Garfonso hat das doch auch beobachtet?
            jojo@iobroker-prod:~$ iob info
            Platform       : linux
            os             : linux
            Architecture   : x64
            CPUs           : 1
            Speed          : 2600 MHz
            Model          : Intel(R) Core(TM) i3-10110U CPU @ 2.10GHz
            RAM            : 4 GB
            System uptime  : 17d. 23:07:09
            Node.js        : v14.19.3
            time           : 1655378041359
            timeOffset     : -120
            adapters count : 501
            NPM            : v6.14.17
            Disk size      : 15.6 GiB
            Disk free      : 7.3 GiB
            jojo@iobroker-prod:~$ iobroker v
            4.0.23
            GarfonsoG 1 Antwort Letzte Antwort
            • J JojoS
              Platform       : linux
              os             : linux
              Architecture   : x64
              CPUs           : 1
              Speed          : 2600 MHz
              RAM            : 4 GB
              Node.js        : v14.19.3
              timeOffset     : -120
              NPM            : v6.14.17
              Disk free      : 7.3 GiB
              4.0.23
              GarfonsoG Offline
              GarfonsoG Offline
              Garfonso
              #320
              @jojos
              ja, hab das mit Admin 5.x und auch Admin 6 beobachtet. Schalten per Javascript, Visu (Lovelace) oder Objektbaum macht keinen Unterschied, kann alles verzögert sein.
              Ultimativer Lovelace Leitfaden: https://forum.iobroker.net/topic/35937/der-ultimative-iobroker-lovelace-leitfaden-dokumentation
              Lovelace UI Beispiele: https://forum.iobroker.net/topic/35950/zeigt-her-eure-lovelace-visualisierung
              • GarfonsoG Garfonso
                @jojos
                chefkoch009
                #321
                Vielen Dank für eure Mühen. Tritt es nur bei "Schalten" oder auch bei "dimmen Wert" auf?
                chefkoch009
                GarfonsoG W 2 Antworten Letzte Antwort
                  chefkoch009
                  schmid_no1
                  #322
                  @chefkoch009 kann ich bestätigen mit admin 6.
                  Verzögerungen geschaltet über die vis kommen bis zu 7 Sekunden später an
                  L 1 Antwort Letzte Antwort
                    chefkoch009
                    GarfonsoG Offline
                    GarfonsoG Offline
                    Garfonso
                    #323
                    @chefkoch009
                    bei dimmen bin ich mir nicht 100% sicher, ich meine aber auch das schon gesehen zu haben. Sicher gesehen habe ich es schon bei farbtemperatur und bei rolladen position (also 0-100, müsste dann ja der gleiche Datentyp sein) (Rolladenposition ließ sich gerade reproduzieren).
                    • L Offline
                      leachim200
                      #324
                      Hallo ich verzweifle gerade an der Iobroker-KNX verbindung.
                      Ich habe in der ETS mein MD Ip Interface 0003 Secure mit der physicalischen Adresse 1.1.1 ausgestattet Tunnel 1-4 liegen dann auf 1.1.2-5
                      Die physikalische Adresse der verbindung ist 1.0.250. Wenn ich nun 1.1.4 als physikalische Adresse eintrage bekomme ich keine Geräte verbindung zu stande.
                      Ich hab im Interface bereits auf Set gedrück somit sollte er die Adressen ausgerollt haben. Wo liegt mein Gedanken fehler?
                      logauszug:
                      2022-07-12 19:40:52.079 - info: knx.0 (27588) Debuglevel: 2 3
                      2022-07-12 19:40:52.085 - info: knx.0 (27588) Event : UDP - listening
                      2022-07-12 19:40:52.092 - info: knx.0 (27588) Connected - local UDP Server listening on xxxxxxxxxxxxxxx:51181
                      2022-07-12 19:40:52.096 - info: knx.0 (27588) Send : UDP Connection Request : 06 10 02 05 00 1a 08 01 c0 a8 58 fc c7 ed 08 01 00 00 00 00 c7 ed 04 04 02 00 sent to 192.168.88.240:3671
                      2022-07-12 19:40:52.104 - info: knx.0 (27588) Connection persists.....closing now
                      2022-07-12 19:40:52.106 - info: knx.0 (27588) ... not able to close connection, because already closed
                      2022-07-12 19:40:52.108 - info: knx.0 (27588) STATE_NOT_CONNECTED : Try to connect / reconnect : STATE_CONNECTION_STATE_REQUEST(5) to STATE_NOT_CONNECTED(0).
                      2022-07-12 19:40:54.104 - info: knx.0 (27588) STATE_CONNECTION_STATE_REQUEST : Not acceptable step... disconnecting
                      2022-07-12 19:40:54.114 - info: knx.0 (27588) ( END ) Sending DISCONNECT_REQUEST : 06 10 02 09 00 10 00 00 08 01 c0 a8 58 fc c7 ed ChID : 0 SeqCntIN : 0 SeqCntOUT : 0 msgCode : [object Object]
                      2022-07-12 19:40:54.117 - info: knx.0 (27588) STATE_DISCONNECT_REQUEST : no defined handling for transition from State: STATE_CONNECTION_STATE_REQUEST(5) to STATE_DISCONNECT_REQUEST(15).
                      2022-07-12 19:40:54.118 - info: knx.0 (27588) Connection persists.....closing now
                      • L Offline
                        leachim200
                        schrieb am zuletzt editiert von leachim200
                        #325
                        So ich bin weiter es dürfte an der physikalischen Adresse liegen.
                        Wenn ich das Interface auf werkseinstellungen setzte und die physikalische Standart IP nehme funktioniert alles. Sobald ich Secure darüber spiele geht nix mehr.
                        Wenn ich das ganze Ohne IP-Secure aufspiele funktioniert alles fehlerfrei.
                        Unterstützt der Adapter IP-Secure?
                        • S schmid_no1
                          leachim200
                          #326
                          @schmid_no1 Kann ich bestätigen. Ich habe direkt am Objekt Befehle abgesätzt, egal ob Tag/Nach umschaltung oder Rolläden Positionen die Befehle kommen oft bis zu 7 Sekunden später an.
                          • L Offline
                            leachim200
                            #327
                            ich bin auf ein weiteres Problem gestoßen und wäre echt froh über Hilfe.
                            Ich versuche einen Text über iobroker an den MDT Glastaster in form eines Statustextes zu senden.
                            GA ist angelegt und auch im iobroker hinterlegt. Schalten und prozentwerte senden funktioniert aber der Text nicht. Was mache ich falsch?
                            Hier noch die Screenshots
                            iobroker_objekt.JPG iobroker_GA.JPG Statustext.JPG Infodisplay.JPG ETS_KO.JPG
                            • L Offline
                              leachim200
                              #328
                              Ich bin einen Schritt weiter. Wenn ich das Ganze am Gruppenmonitor in der ETS durchführe wird der Wert ohne Probleme geschrieben. Daher gehe ich davon aus, dass es am Iobroker liegt. Logfile zeigt bei einer Wertänderung keine Regung das hier etwas gesendet wurde.
                                chefkoch009
                                W Offline
                                W Offline
                                Weissnicht
                                #329
                                @chefkoch009
                                Habe diesen Verzögerungseffekt zB auch beim Senden von Datum / Uhrzeit aus ioBroker an KNX. In Version 2.0.13 passiert das nicht.
                                • J Offline
                                  JojoS
                                  #330
                                  eine neue Version 2.0.16. Soll das delay da behoben sein? Habe langsam keine Lust mehr auf Betatester wenn ich schon so viel Geld für den Adapter bezahle.
                                  M T 2 Antworten Letzte Antwort
                                  • J JojoS
                                    mikah111
                                    schrieb am zuletzt editiert von mikah111
                                    #331
                                    @jojos Ist bei mir mit der 2.0.16 nicht besser geworden. Bin und bleibe nun wohl auf der 2.0.13
                                    • J JojoS
                                      Tobi68
                                      #332
                                      @jojos ich hatte letztes Jahr immer wieder Verzögerungen.
                                      Hatte den IOBroker sogar einmal die Woche neu gestartet, das half zu 90%
                                      Dann musste ich den IOBroker wegen Absturz kpl. neu installieren.
                                      Danach waren die Verzögerungen weg.
                                      Es hatte bei mir teilweise schon mal 30sec. Gedauert bis ne Lampe über die vis geschaltet wurde. War nur bei Knx objekten so, Meross oder Tasmota hatte das Problem nicht.
                                      Erst nach IOBroker neuinstallation und backup aufspielen was das Problem behoben.
                                      • T Tobi68
                                        chefkoch009
                                        #333
                                        @tobi68 Danke für die Info. Ist eventuell bei "irgendwelchen" Updates etwas schief gelaufen?
                                        chefkoch009
                                        T Alex4A P A 4 Antworten Letzte Antwort
                                          chefkoch009
                                          Tobi68
                                          #334
                                          @chefkoch009
                                          Keine Ahnung, ist ja nicht mehr nachvollziehbar..
                                          Hatte im letzten Jahr halt wegen ner anderen Sache Support bei mir auf der Kiste, der hatte sich über einige Sachen in meiner Iob Installation bei mir gewundert.
                                          Nach dem neu Aufsetzen des IOBs waren auch die Verzögerungen im KNX Geschichte..
