  4. KNX Adapter überholt
1.0k Beiträge 123 Kommentatoren 595.0k Aufrufe 26 Beobachtet
  • M
    M
    Max2106
    #265
    KNX adapter bekomme ich nicht zum laufen.
    Schon mehr fach neu istalliert.
    Im LOG file steht:
    host.KNXbroker 2017-06-02 15:39:36.481 info Restart adapter system.adapter.knx.0 because enabled
    host.KNXbroker 2017-06-02 15:39:36.481 error instance system.adapter.knx.0 terminated with code 8 (node.js: Cannot find module)
    host.KNXbroker 2017-06-02 15:39:36.271 info instance system.adapter.knx.0 started with pid 13389
    host.KNXbroker 2017-06-02 15:39:35.987 info Restart adapter system.adapter.knx.0 because enabled
    host.KNXbroker 2017-06-02 15:39:35.987 error instance system.adapter.knx.0 terminated with code 8 (node.js: Cannot find module)
    host.KNXbroker 2017-06-02 15:39:35.760 info instance system.adapter.knx.0 started with pid 13387
    host.KNXbroker 2017-06-02 15:39:32.250 info Restart adapter system.adapter.knx.0 because enabled
    host.KNXbroker 2017-06-02 15:39:32.250 error instance system.adapter.knx.0 terminated with code 8 (node.js: Cannot find module)
    host.KNXbroker 2017-06-02 15:39:31.999 info instance system.adapter.knx.0 started with pid 13385
    host.KNXbroker 2017-06-02 15:39:17.869 info Restart adapter system.adapter.knx.0 because enabled
    host.KNXbroker 2017-06-02 15:39:17.869 error instance system.adapter.knx.0 terminated with code 8 (node.js: Cannot find module)
    host.KNXbroker 2017-06-02 15:39:17.637 info instance system.adapter.knx.0 started with pid 13383
    host.KNXbroker 2017-06-02 15:39:06.259 info Restart adapter system.adapter.knx.0 because enabled
    host.KNXbroker 2017-06-02 15:39:06.258 error instance system.adapter.knx.0 terminated with code 8 (node.js: Cannot find module)
    host.KNXbroker 2017-06-02 15:39:06.047 info instance system.adapter.knx.0 started with pid 13381
    host.KNXbroker 2017-06-02 15:39:05.738 info Restart adapter system.adapter.knx.0 because enabled
    host.KNXbroker 2017-06-02 15:39:05.737 error instance system.adapter.knx.0 terminated with code 8 (node.js: Cannot find module)
    Jemand eine Idee?
    Besten Dank
    • M
      M
      my-knx-shop
      #266
      Mal ne andere Frage. Ließt du auch was hier geschrieben wird ? Ich habe 2 Beiträge über deinem doch geschrieben, dass es aktuell nicht mit der Version die zur Zeit online ist, funktioniert !
      Also bitte abwarten bis dieses wieder korrigiert ist. Dann wird Chefkoch009 uns sicher kurz informieren.
      • A
        A
        Applefrank
        #267
        Hallo
        Ich habe die Kommunikation über Meinen Gira knx Router hin bekommen.
        Kann über den Iobroker schalten, dimmen etc. aber das mit den Status bekomme ich nicht hin.
        Vielleicht hat ja jemand einen Tipp.
        • M
          M
          my-knx-shop
          #268
          @Applefrank:
          Hallo
          Vielleicht hat ja jemand einen Tipp. `
          Wann hast du den KNX Adapter denn installiert gehabt ?
          • A
            A
            Applefrank
            #269
            Habe den vor ca eine Woche installiert
            • M
              M
              Max2106
              #270
              @Max2106:
              Im LOG file steht:
              Jemand eine Idee?
              Besten Dank `
              • M
                M
                Max2106
                #271
                vielleicht ist es sinnvoll, bei den Adptern den link fuer den KNX Adapter 0.8.3 zu hinterlegen, bis die neue Version ohne Probleme laueft.
                • HomoranH
                  #272
                  Hallo Max,
                  Was bitte soll das jetzt?
                  Vollzitat von deinem eigenen Post, auf den bereits geantwortet wurde?
                  • M
                    M
                    Max2106
                    #273
                    Sorry, ist versehentlich passiert.
                    Soll nicht wieder vorkommen.
                    Herrscht ein rauher Ton hier.
                    Gruss, Max
                    • HomoranH
                      #274
                      @Max2106:
                      Herrscht ein rauher Ton hier. `
                      Nö, nur wenn außer dem eigenen Post nur noch ein weiteres mal der selbe ohne Zusatzinformationen gepostet wird, wird man doch wohl mal fragen dürfen.
                      Deswegen musst du mir nicht gleich zweimal meinen Post als Vollzitat ohne weitere Informationen als PN schicken.
                      Und zu deiner letzten Frage:
                      Hast du hier mal gelesen
                      http://www.iobroker.net/docu/?page_id=5 … stallieren
                      Punkt 4
                      • S
                        S
                        Stupidman
                        #275
                        UPDATE zu meinem Raspi Schnittstellenproblem.
                        ES LÄUFT !!!
                        Kurz bevor ich den Raspi in den Teich werfen wollte habe ich mal den KNX Adapter Version 0.8.3 installiert. (Vorgängerversion)
                        Damit klappt es jetzt ENDLICH und die erste Testlampe gehorcht auf´s Wort.
                        IK FREU MIR !!
                        • D
                          D
                          dalmabrain
                          #276
                          @chefkoch009:
                          @fuchs1978: normaler Weise hat das wert dimmen den dpt 5.001. Du verwendest den dpt 3, welcher für das schrittdimmen ist, also dimmen z.b. über einen Taster. Weiterhin sehe ich bei dir keine Antwortadressen. Beim dimmen lege ich üblicher Weise 5 mittelgruppen an:
                          schalten,
                          Schalten Status,
                          Dimmen,
                          Dimmen wert und
                          dimmen wert Status.
                          Wenn in den Gruppenadressen alles verknüpft ist und die Datenpunkttypen richtig zugeordnet sind, dann wird es funktionieren. Bei Fragen stehe ich zur Verfügung `
                          … Welches Objekt verwendest Du dann im IoBroker? Ich möchte meine Lampe dimmen und im ETS ist DPT5.001 eingestellt. Weiterhin habe ich genau wie von Dir besprechen alle Mittelgruppen erstellt:
                          schalten,
                          Schalten Status,
                          Dimmen,
                          Dimmen wert und
                          dimmen wert Status
                          Aber irgendwie funktioniert es null.
                          • cvidalC
                            cvidalC
                            cvidal
                            Forum Testing
                            #277
                            @chefkoch009:
                            Ich hoffe deine Fragen damit beantwortet zu haben. Solltest du nicht weiterkommen, würde ich mir dein Projekt gern Mal anschauen.
                            chefkoch009 `
                            Hi Zusammen bei mir läuft Zustand anzeigen meiner Jalousienen jetzt auch, ich habe in der ETS Zustand als Objekt Programmiert mir ist nachher erst aufgefallen das der Aktor auch Position anzeigen hat… Also alles gut.
                            So für mich ist es soweit erstmal komplett fertig mit KNX, ich habe keinerlei Probleme mehr mit dem Adapter 0.8.3
                            Danke für eure Hilfe und Geduld.
                            • cvidalC
                              cvidalC
                              cvidal
                              Forum Testing
                              #278
                              Hallo Dalmabrain,
                              bekommst du den Adapter überhaupt ans laufen, grüne Anzeige unter Instanzen? Es läuft nichts ist schwer ein zuordnen.
                              Gruß Christian
                              • chefkoch009C
                                chefkoch009C
                                chefkoch009
                                #279
                                Hallo cvidal,
                                es gibt in der 0.8.4er Version einen Fehler. Ich arbeite daran, diesen zu beheben. Bitte benutze solange die Version 0.8.3.
                                Vielen Dank für die Geduld und das Verständniss bis zum Erscheinen der neuen Version.
                                chefkoch009
                                • cvidalC
                                  cvidalC
                                  cvidal
                                  Forum Testing
                                  #280
                                  @ Chefkoch009
                                  Ja das ist mir bewusst ich habe es ja am laufen mit 8.3 die frage hatte ich eigentlich an Dalmabrain gestellt, sollte keine Fehlermeldung an KNX 8.4 sein.
                                  @Dalmabrain
                                  Versuch es mal mit Version 8.3 dann sollte es laufen.
                                  Gruß Christian
                                  • D
                                    D
                                    dalmabrain
                                    #281
                                    @cvidal
                                    Ja der Adapter 0.8.3 läuft und ich kann auch einfache Schaltvorgänge machen..Licht ein und aus ist kein Problem. Komplizierter wird es wenn ich Dimmen möchte…Da habe ich mal die Dimmer der HQwidgets genommen. Aber irgendwie kann ich dort den Dimmwert nicht übertragen. Im ETS ist alles vorhanden...Ich habe für die enstprechende Lampe eine GA für Schalten, eine für Dimmen, eine für dne Dimmwert und eine für die Rückmeldung des Dimmwerts.
                                    Egal was ich mache, ich bekomme das Dimmen über IoBroker nicht hin :(
                                    Wie machst Du das?
                                    • cvidalC
                                      cvidalC
                                      cvidal
                                      Forum Testing
                                      #282
                                      @ dalmabrain
                                      Hallo, da kann ich leider nicht weiterhelfen ich habe keinen Dimmaktor verbaut.
                                      Ich habe als einzige Dimmbare leuchte von Milight das dazugehörige Widget genommen.
                                      Eventuell mal testen?
                                      Gruß Christian
                                      • D
                                        D
                                        dalmabrain
                                        #283
                                        @Cvidal: Dann eine andere Frage :-) Bezüglich Rolladen…Wie ahst Du das mit der Position geregelt? Kannst Du mal Screenshots reinstellen, wo man die Konfiguraiton rauslesen kann?
                                        @Chefkoch: Hast Du dimmbare Lampen, die über den Datentyp DPT5 gesteuert werden? Wenn ja, wie machst Du das?
                                        Danke im Voraus
                                        • chefkoch009C
                                          chefkoch009C
                                          chefkoch009
                                          #284
                                          habe soeben die Version 0.8.5 online gestellt. Dabei ein riesengrosses Dankeschön an Bluefox.
                                          Es wurden fundamentale Veränderungen am Loader durchgeführt. Somit sollten nun auch grössere Projektfiles geladen werden können.
                                          Viel Spass beim Testen
                                          chefkoch009
                                          84.3k
