  4. Error 25 bei Adapterupdates nach Node.JS 16.15.1 Update
errormeldungnodejs 16.15.1
169 Beiträge 15 Kommentatoren 42.1k Aufrufe 12 Beobachtet
    @paul-honka sagte in Error 25 bei Adapterupdates nach Node.JS 16.15.1 Update:
    Cannot install iobroker.email@1.1.3: 217
    Deutet auf verfummelte Rechte hin. Mal als root oder per sudo unterwegs gewesen?
    P
    P
    paul.honka
    #130
    Noch drei Runden verschieben dreht, dann war der E Mail Adapter uogedatet.
    iob upgrade email --debug
    This upgrade of "email" will introduce the following changes:
    -> 1.1.3:
    Make sure the STARTTLS configuration field is displayed
    -> 1.1.2:
    Fix mail.ee settings
    -> 1.1.1:
    Allow to use connections to port 25 unencrypted
    -> 1.1.0:
    Adjust default settings for web.de and 1und1 and add ionos
    Add "Always use STARTTLS" option for custom SMTP settings
    Would you like to upgrade email from @1.0.10 to @1.1.3 now? [(y)es, (n)o]: y
    Update email from @1.0.10 to @1.1.3
    NPM version: 8.11.0
    Installing iobroker.email@1.1.3... (System call)
    npm WARN old lockfile
    npm WARN old lockfile The package-lock.json file was created with an old version of npm,
    npm WARN old lockfile so supplemental metadata must be fetched from the registry.
    npm WARN old lockfile This is a one-time fix-up, please be patient...
    added 32 packages, removed 45 packages, and changed 8 packages in 1m
    94 packages are looking for funding
      run `npm fund` for details
    Update "system.adapter.email.0"
    upload [4] email.admin /opt/iobroker/node_modules/iobroker.email/admin/blockly.js blockly.js application/javascript
    upload [3] email.admin /opt/iobroker/node_modules/iobroker.email/admin/email.png email.png image/png
    upload [2] email.admin /opt/iobroker/node_modules/iobroker.email/admin/index.html index.html text/html
    upload [1] email.admin /opt/iobroker/node_modules/iobroker.email/admin/index_m.html index_m.html text/html
    upload [0] email.admin /opt/iobroker/node_modules/iobroker.email/admin/words.js words.js application/javascript
    Dann wollte ich flot updaten, das gleiche Spiel nochmal.
    iob upgrade flot --debug
    This upgrade of "flot" will introduce the following changes:
    -> 1.11.0:
    Trust GetHistory results to contain ms resolution timestamps
    Would you like to upgrade flot from @1.10.7 to @1.11.0 now? [(y)es, (n)o]: y
    Update flot from @1.10.7 to @1.11.0
    NPM version: 8.11.0
    Installing iobroker.flot@1.11.0... (System call)
    npm ERR! code ENOTEMPTY
    npm ERR! syscall rename
    npm ERR! path /opt/iobroker/node_modules/iobroker.javascript/node_modules/acorn-walk
    npm ERR! dest /opt/iobroker/node_modules/iobroker.javascript/node_modules/.acorn-walk-xHkEOJL1
    npm ERR! errno -39
    npm ERR! ENOTEMPTY: directory not empty, rename '/opt/iobroker/node_modules/iobroker.javascript/node_modules/acorn-walk' -> '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.acorn-walk-xHkEOJL1'
    npm ERR!     /home/iobroker/.npm/_logs/2022-06-28T08_57_13_800Z-debug-0.log
    host.IOBroker-Sted1 Cannot install iobroker.flot@1.11.0: 217
    Gruss paul
      P
      P
      paul.honka
      #131
      wo finde ich die package-lock.json, im /opt/obroker/log nicht.
      Gruss paul
        P
        P
        paul.honka
        #132
        Jetzt fängt er an, das ich alle Dateien in /opt/iobroker/node_modules/iobroker.javascript/node_modules/
        umbennen soll. Natürlich nur eine pro Update Aufruf. Kommt dann das nächste Verzeichnis drann?
        Da wird es wohl Weihnachten. Das kann nicht die Lösung sein?
        Gruss paul
        • apollon77A
          apollon77A
          #133
          Ich bin imme rnoch der Meinung das das nicht richtig ist was wir hier tun ... npm will das umbenennen, wohl weil es da Module gibt mit denen er was tun will ... und er kann es nicht umbenennen. So interpretiere ich diese Meldung. Die Frage ist also jetzt ob das Zielverzeichnis denn schon da ist oder warum er das anmeckert? Dann müsste man eher das aus dem Weg räumen.
          EDIT: je mehr ich google umso mehr vermute ich das es das Zielverzeichnis ist was man löschen muss - warum auch immer esd da geblieben ist Und dann nochmal versuchen.
          Das Rename zu machen macht ggf mehr Issues als alles andere
          P 2 Antworten Letzte Antwort
          • Thomas BraunT
            Thomas BraunT
            Most Active Developer
            #134
            In /opt/iobroker/
            • apollon77A apollon77
              P
              P
              paul.honka
              #135
              @apollon77
              Wenn ich nachher zu Hause bin, dann schaue ich mal nach der Verzeichnisstruktur.
              Gruss paul
              • T taba_luga
                jetzt geht der Spaß mit den Ordnern wieder los...
                xx@iobroker-prod:/opt/iobroker$ sudo -H -u iobroker npm install iobroker.js-controller
                npm ERR! path /opt/iobroker/node_modules/alexa-cookie2
                npm ERR! dest /opt/iobroker/node_modules/.alexa-cookie2-yH4YGJkw
                npm ERR! errno -39
                npm ERR! ENOTEMPTY: directory not empty, rename '/opt/iobroker/node_modules/alexa-cookie2' -> '/opt/iobroker/node_modules/.alexa-cookie2-yH4YGJkw'
                npm ERR!     /home/iobroker/.npm/_logs/2022-06-24T11_45_06_568Z-debug-0.log
                Die benenne ich dann erst mal wieder um und melde mich dann wieder bei euch. Vielen DANK schon mal zwischendurch für euren super Support!!!
                T
                T
                taba_luga
                #136
                @thomas-braun nach drei Tagen umbenennen der Verzeichnisse und immer noch kein Ende in Sicht, habe ich das System jetzt auf den Snapshot mit Debian 10 zurückgerollt. Hier scheint noch alles zu ordentlich zu laufen. Ich werde jetzt erstmal auf diesem Stand bleiben und dort alle Adapter updaten. Wenn das alles ordentlich funktioniert hat, versuche ich nochmal ein Update auf Debian 11 mit NPM 8.
                • T taba_luga
                  Thomas BraunT
                  Thomas BraunT
                  #137
                  @taba_luga sagte in Error 25 bei Adapterupdates nach Node.JS 16.15.1 Update:
                  Das Debian-Release hat nichts mit npm8 zu tun.
                  Schau dir vor einem Upgrade auf node16/npm8 den npm tree an. Der muss möglichst sauber sein.
                  cd /opt/iobroker
                  npm ls | grep -E 'ERR|github'
                  sollte im Altsystem schon ohne Rückmeldung durchlaufen.
                    cd /opt/iobroker
                    T
                    T
                    taba_luga
                    #138
                    Das war unglücklich formuliert von mir. Der Snapshot mit Debian 10 geht einher mit dem Stand Node14/npm6.
                    xx@iobroker-prod:~$ which nodejs && nodejs -v && which node && node -v && which npm && npm -v && apt policy nodejs
                    /usr/bin/nodejs
                    v14.19.3
                    /usr/bin/node
                    v14.19.3
                    /usr/bin/npm
                    6.14.17
                    nodejs:
                      Installiert:           14.19.3-1nodesource1
                      Installationskandidat: 14.19.3-1nodesource1
                      Versionstabelle:
                     *** 14.19.3-1nodesource1 500
                            500 https://deb.nodesource.com/node_14.x stretch/main amd64 Packages
                         10.24.0~dfsg-1~deb10u1 500
                            500 http://ftp.de.debian.org/debian buster/main amd64 Packages
                            500 http://security.debian.org/debian-security buster/updates/main amd64 Packages
                    xx@iobroker-prod:~$
                    Leider läuft das nicht ohne Rückmeldung durch...
                     xx@iobroker-prod:~$ cd /opt/iobroker
                    xx@iobroker-prod:/opt/iobroker$ npm ls | grep -E 'ERR|github'
                    [sudo] Passwort für xx:
                    │ │ │ ├── github-from-package@0.0.0
                    npm ERR! extraneous: @abandonware/noble@1.9.2-1 /opt/iobroker/node_modules/@abandonware/noble
                    npm ERR! extraneous: @apollon/frankjoke-myadapter@1.2.5 /opt/iobroker/node_modules/@apollon/frankjoke-myadapter
                    npm ERR! extraneous: @frankjoke/myadapter@1.2.4 /opt/iobroker/node_modules/@frankjoke/myadapter
                    npm ERR! extraneous: @serialport/bindings@2.0.8 /opt/iobroker/node_modules/@serialport/bindings
                    npm ERR! extraneous: @serialport/parser-byte-length@1.0.5 /opt/iobroker/node_modules/@serialport/parser-byte-length
                    npm ERR! extraneous: @serialport/parser-cctalk@1.0.5 /opt/iobroker/node_modules/@serialport/parser-cctalk
                    npm ERR! extraneous: @serialport/parser-readline@1.0.5 /opt/iobroker/node_modules/@serialport/parser-readline
                    npm ERR! extraneous: @serialport/parser-ready@1.0.5 /opt/iobroker/node_modules/@serialport/parser-ready
                    npm ERR! extraneous: @serialport/parser-regex@1.0.5 /opt/iobroker/node_modules/@serialport/parser-regex
                    npm ERR! extraneous: @serialport/stream@2.0.5 /opt/iobroker/node_modules/@serialport/stream
                    npm ERR! extraneous: iobroker.rflink /opt/iobroker/node_modules/iobroker.rflink
                    npm ERR! error in /opt/iobroker/node_modules/iobroker.rflink: ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.rflink/package.json'
                    npm ERR! extraneous: alexa-remote2@1.0.0 /opt/iobroker/node_modules/alexa-remote2
                    npm ERR! extraneous: axios@0.18.0 /opt/iobroker/node_modules/axios
                    npm ERR! extraneous: dropbox-v2-api@2.4.0 /opt/iobroker/node_modules/dropbox-v2-api
                    npm ERR! extraneous: express-fileupload@0.1.4 /opt/iobroker/node_modules/express-fileupload
                    npm ERR! extraneous: fs-extra@0.22.1 /opt/iobroker/node_modules/fs-extra
                    npm ERR! extraneous: googleapis@40.0.1 /opt/iobroker/node_modules/googleapis
                    npm ERR! extraneous: iobroker@1.0.2 /opt/iobroker/node_modules/iobroker
                    npm ERR! extraneous: iobroker.icons-material-png@0.1.0 /opt/iobroker/node_modules/iobroker.icons-material-png
                    npm ERR! extraneous: iobroker.milight@0.3.6 /opt/iobroker/node_modules/iobroker.milight
                    npm ERR! extraneous: iobroker.vis-timeandweather@1.1.7 /opt/iobroker/node_modules/iobroker.vis-timeandweather
                    npm ERR! extraneous: joi@6.10.1 /opt/iobroker/node_modules/joi
                    npm ERR! extraneous: js2xmlparser@3.0.0 /opt/iobroker/node_modules/js2xmlparser
                    npm ERR! extraneous: jsonwebtoken@8.1.0 /opt/iobroker/node_modules/jsonwebtoken
                    npm ERR! extraneous: md5@2.2.1 /opt/iobroker/node_modules/md5
                    npm ERR! extraneous: mongodb@3.3.2 /opt/iobroker/node_modules/mongodb
                    npm ERR! extraneous: mqtt-connection@3.2.0 /opt/iobroker/node_modules/mqtt-connection
                    npm ERR! extraneous: nearest-color@0.4.2 /opt/iobroker/node_modules/nearest-color
                    npm ERR! extraneous: net-ping@1.2.3 /opt/iobroker/node_modules/net-ping
                    npm ERR! extraneous: noble@1.9.1 /opt/iobroker/node_modules/noble
                    npm ERR! extraneous: node-arp@1.0.6 /opt/iobroker/node_modules/node-arp
                    npm ERR! extraneous: node-bluetooth@1.2.6 /opt/iobroker/node_modules/node-bluetooth
                    npm ERR! extraneous: node-red@0.20.8 /opt/iobroker/node_modules/node-red
                    npm ERR! extraneous: node-red-contrib-aggregator@1.5.0 /opt/iobroker/node_modules/node-red-contrib-aggregator
                    npm ERR! extraneous: node-red-contrib-os@0.1.7 /opt/iobroker/node_modules/node-red-contrib-os
                    npm ERR! extraneous: node-red-contrib-polymer@0.0.21 /opt/iobroker/node_modules/node-red-contrib-polymer
                    npm ERR! extraneous: node-red-dashboard@2.16.2 /opt/iobroker/node_modules/node-red-dashboard
                    npm ERR! extraneous: node-ssdp@3.2.5 /opt/iobroker/node_modules/node-ssdp
                    npm ERR! extraneous: node-telegram-bot-api@0.30.0 /opt/iobroker/node_modules/node-telegram-bot-api
                    npm ERR! extraneous: openzwave-shared@1.4.0 /opt/iobroker/node_modules/openzwave-shared
                    npm ERR! extraneous: picocolors@1.0.0 /opt/iobroker/node_modules/picocolors
                    npm ERR! extraneous: ping@0.2.2 /opt/iobroker/node_modules/ping
                    npm ERR! extraneous: prebuild-install@4.0.0 /opt/iobroker/node_modules/prebuild-install
                    npm ERR! extraneous: promirepl@1.0.1 /opt/iobroker/node_modules/promirepl
                    npm ERR! extraneous: prompt-list@3.2.0 /opt/iobroker/node_modules/prompt-list
                    npm ERR! extraneous: pushover-notifications@0.2.4 /opt/iobroker/node_modules/pushover-notifications
                    npm ERR! extraneous: suncalc@1.8.0 /opt/iobroker/node_modules/suncalc
                    npm ERR! extraneous: systeminformation@4.5.1 /opt/iobroker/node_modules/systeminformation
                    npm ERR! extraneous: typescript@2.6.2 /opt/iobroker/node_modules/typescript
                    npm ERR! extraneous: virtual-device-sdk@1.5.1 /opt/iobroker/node_modules/virtual-device-sdk
                    npm ERR! extraneous: virtual-tsc@0.3.4 /opt/iobroker/node_modules/virtual-tsc
                    npm ERR! extraneous: zwave-js@5.4.0 /opt/iobroker/node_modules/zwave-js
                    npm ERR! peer dep missing: @zwave-js/core@>=9.0.4, required by @zwave-js/log-transport-json@2.0.1
                    npm ERR! peer dep missing: @zwave-js/shared@>=9.0.4, required by @zwave-js/log-transport-json@2.0.1
                    • T taba_luga
                      /usr/bin/nodejs
                      v14.19.3
                      /usr/bin/node
                      v14.19.3
                      /usr/bin/npm
                      6.14.17
                      nodejs:
                        Versionstabelle:
                      xx@iobroker-prod:~$
                      Thomas BraunT
                      Thomas BraunT
                      #139
                      Da vermute ich den Troublemaker:
                        P
                        P
                        paul.honka
                        schrieb am zuletzt editiert von paul.honka
                        #140
                        @apollon77 Noch mal ein Versuch
                        -> 1.11.0:
                        NPM version: 8.11.0
                        npm ERR! path /opt/iobroker/node_modules/iobroker.javascript/node_modules/@types/caseless
                        npm ERR! dest /opt/iobroker/node_modules/iobroker.javascript/node_modules/@types/.caseless-E7EBKTiW
                        npm ERR! errno -39
                        npm ERR! ENOTEMPTY: directory not empty, rename '/opt/iobroker/node_modules/iobroker.javascript/node_modules/@types/caseless' -> '/opt/iobroker/node_modules/iobroker.javascript/node_modules/@types/.caseless-E7EBKTiW'
                        npm ERR!     /home/iobroker/.npm/_logs/2022-06-28T16_56_44_129Z-debug-0.log
                        und jetzt das Verzeichnis /opt/iobroker/node_modules/iobroker.javascript/node_modules
                        659370 40 drwxrwxr-x+  91 iobroker iobroker 36864 Jun 28 18:56 .
                         658280  4 drwxrwxr-x+   8 iobroker iobroker  4096 Jun  2 00:18 ..
                        1708173  4 drwxrwxr-x+  12 iobroker iobroker  4096 Jun 28 10:55 @alcalzone
                        1708174  4 drwxrwxr-x+   5 iobroker iobroker  4096 Jun 28 10:55 @babel
                         794382  4 drwxrwxr-x+   2 iobroker iobroker  4096 Jun 28 18:45 .bin
                        1313831  4 drwxrwxr-x+   4 iobroker iobroker  4096 Jun 28 10:55 coffee-script
                        1313856  4 drwxrwxr-x+   3 iobroker iobroker  4096 Jun 28 10:55 combined-stream
                        1313868  4 drwxrwxr-x+   3 iobroker iobroker  4096 Jun 28 10:55 core-util-is
                        1313873  4 drwxrwxr-x+   5 iobroker iobroker  4096 Jun 28 10:55 cron-parser
                        1313884  4 drwxrwxr-x+   4 iobroker iobroker  4096 Jun 28 10:55 dashdash
                        1313887  4 drwxrwxr-x+   3 iobroker iobroker  4096 Jun 28 10:55 debug
                        1313900  4 drwxrwxr-x+   3 iobroker iobroker  4096 Jun 28 10:55 define-properties
                        1313908  4 drwxrwxr-x+   3 iobroker iobroker  4096 Jun 28 10:55 delayed-stream
                        2232767  4 drwxrwxr-x+   2 iobroker iobroker  4096 Jun 28 10:55 dewpoint
                        1313924  4 drwxrwxr-x+   3 iobroker iobroker  4096 Jun 28 10:55 ecc-jsbn
                        1708178  4 drwxrwxr-x+   3 iobroker iobroker  4096 Jun 28 10:55 @eslint
                        1577393  4 drwxrwxr-x+   2 iobroker iobroker  4096 Jun 28 10:55 extend
                        1577772  4 drwxrwxr-x+   3 iobroker iobroker  4096 Jun 28 10:55 extsprintf
                        1577808  4 drwxrwxr-x+   3 iobroker iobroker  4096 Jun 28 10:55 fast-deep-equal
                        1577828  4 drwxrwxr-x+   6 iobroker iobroker  4096 Jun 28 10:55 fast-json-stable-stringify
                        2109566  4 drwxrwxr-x+   2 iobroker iobroker  4096 Jun 28 10:55 forever-agent
                        2109567  4 drwxrwxr-x+   3 iobroker iobroker  4096 Jun 28 10:55 form-data
                        2109573  4 drwxrwxr-x+   3 iobroker iobroker  4096 Jun 28 10:55 function-bind
                        2109577  4 drwxrwxr-x+   4 iobroker iobroker  4096 Jun 28 10:55 get-intrinsic
                        2109580  4 drwxrwxr-x+   3 iobroker iobroker  4096 Jun 28 10:55 getpass
                        2109594  4 drwxrwxr-x+   3 iobroker iobroker  4096 Jun 28 10:55 har-schema
                        2109595  4 drwxrwxr-x+   3 iobroker iobroker  4096 Jun 28 10:55 har-validator
                        2109596  4 drwxrwxr-x+   4 iobroker iobroker  4096 Jun 28 10:55 has
                        2109598  4 drwxrwxr-x+   4 iobroker iobroker  4096 Jun 28 10:55 has-property-descriptors
                        2109599  4 drwxrwxr-x+   4 iobroker iobroker  4096 Jun 28 10:55 has-symbols
                        2109604  4 drwxrwxr-x+   3 iobroker iobroker  4096 Jun 28 10:55 http-signature
                        1708175  4 drwxrwxr-x+   4 iobroker iobroker  4096 Jun 28 10:55 @humanwhocodes
                        2109607  4 drwxrwxr-x+   4 iobroker iobroker  4096 Jun 28 10:55 immediate
                        2109612  4 drwxrwxr-x+   2 iobroker iobroker  4096 Jun 28 10:55 inherits
                         659375  4 drwxrwxr-x+   3 iobroker iobroker  4096 Jun 28 18:56 @iobroker
                        2109640  4 drwxrwxr-x+   2 iobroker iobroker  4096 Jun 28 10:55 isarray
                        2109626  4 drwxrwxr-x+   4 iobroker iobroker  4096 Jun 28 10:55 is-nan
                        2109643  4 drwxrwxr-x+   2 iobroker iobroker  4096 Jun 28 10:55 isstream
                        2109634  4 drwxrwxr-x+   2 iobroker iobroker  4096 Jun 28 10:55 is-typedarray
                        2109647  4 drwxrwxr-x+   2 iobroker iobroker  4096 Jun 28 10:55 jsbn
                        2109652  4 drwxrwxr-x+   2 iobroker iobroker  4096 Jun 28 10:55 jsonata
                        2109648  4 drwxrwxr-x+   3 iobroker iobroker  4096 Jun 28 10:55 json-schema
                        2109649  4 drwxrwxr-x+   3 iobroker iobroker  4096 Jun 28 10:55 json-schema-traverse
                        2109651  4 drwxrwxr-x+   3 iobroker iobroker  4096 Jun 28 10:55 json-stringify-safe
                        2109654  4 drwxrwxr-x+   3 iobroker iobroker  4096 Jun 28 10:55 jsprim
                        2109655  4 drwxrwxr-x+   6 iobroker iobroker  4096 Jun 28 10:55 jszip
                        2109663  4 drwxrwxr-x+   4 iobroker iobroker  4096 Jun 28 10:55 lie
                        2232582  4 drwxrwxr-x+   2 iobroker iobroker  4096 Jun 28 10:55 long-timeout
                        2232584  4 drwxrwxr-x+   2 iobroker iobroker  4096 Jun 28 10:55 lru-cache
                        2232585  4 drwxrwxr-x+   4 iobroker iobroker  4096 Jun 28 10:55 luxon
                        2232590  4 drwxrwxr-x+   2 iobroker iobroker  4096 Jun 28 10:55 mime-db
                        2232591  4 drwxrwxr-x+   2 iobroker iobroker  4096 Jun 28 10:55 mime-types
                        2232594  4 drwxrwxr-x+   4 iobroker iobroker  4096 Jun 28 10:55 minimist
                        2232595  4 drwxrwxr-x+   2 iobroker iobroker  4096 Jun 28 10:55 ms
                        2232601  4 drwxrwxr-x+   3 iobroker iobroker  4096 Jun 28 10:55 node-inspect
                        1708176  4 drwxrwxr-x+   5 iobroker iobroker  4096 Jun 28 10:55 @nodelib
                        2232602  4 drwxrwxr-x+   3 iobroker iobroker  4096 Jun 28 10:55 node-schedule
                        2232607  4 drwxrwxr-x+   2 iobroker iobroker  4096 Jun 28 10:55 oauth-sign
                        2232609  4 drwxrwxr-x+   3 iobroker iobroker  4096 Jun 28 10:55 object-keys
                        2232624  4 drwxrwxr-x+   4 iobroker iobroker  4096 Jun 28 10:55 pako
                        2232640  4 drwxrwxr-x+   5 iobroker iobroker  4096 Jun 28 10:55 performance-now
                        2232641  4 drwxrwxr-x+   2 iobroker iobroker  4096 Jun 28 10:55 picocolors
                        2232649  4 drwxrwxr-x+   2 iobroker iobroker  4096 Jun 28 10:55 process-nextick-args
                        2232651  4 drwxrwxr-x+   4 iobroker iobroker  4096 Jun 28 10:55 psl
                        2232654  4 drwxrwxr-x+   2 iobroker iobroker  4096 Jun 28 10:55 punycode
                        2232655  4 drwxrwxr-x+   6 iobroker iobroker  4096 Jun 28 10:55 qs
                        2232658  4 drwxrwxr-x+   4 iobroker iobroker  4096 Jun 28 10:55 readable-stream
                        2232843  4 drwxrwxr-x+   4 iobroker iobroker  4096 Jun 28 10:55 request
                         794224 24 drwxrwxr-x+ 478 pi       pi       24576 Jun 28 18:43 res
                        2232680  4 drwxrwxr-x+   2 iobroker iobroker  4096 Jun 28 10:55 safe-buffer
                        2232682  4 drwxrwxr-x+   2 iobroker iobroker  4096 Jun 28 10:55 safer-buffer
                         658277  4 drwxrwxr-x+   7 iobroker iobroker  4096 Jun  2 00:18 semver
                        2232686  4 drwxrwxr-x+   2 iobroker iobroker  4096 Jun 28 10:55 setimmediate
                        2232692  4 drwxrwxr-x+   2 iobroker iobroker  4096 Jun 28 10:55 sorted-array-functions
                        2232702  4 drwxrwxr-x+   5 iobroker iobroker  4096 Jun 28 10:55 sshpk
                        2232707  4 drwxrwxr-x+   3 iobroker iobroker  4096 Jun 28 10:55 string_decoder
                        2232713  4 drwxrwxr-x+   2 iobroker iobroker  4096 Jun 28 10:55 suncalc2
                        2232727  4 drwxrwxr-x+   3 iobroker iobroker  4096 Jun 28 10:55 tough-cookie
                        2232728  4 drwxrwxr-x+   2 iobroker iobroker  4096 Jun 28 10:55 tunnel-agent
                        2232729  4 drwxrwxr-x+   2 iobroker iobroker  4096 Jun 28 10:55 tweetnacl
                         659374  4 drwxrwxr-x+  13 iobroker iobroker  4096 Jun 28 18:56 @types
                         658278  4 drwxrwxr-x+   5 iobroker iobroker  4096 Jun  2 00:18 typescript
                        1708182  4 drwxrwxr-x+   3 iobroker iobroker  4096 Jun 28 10:55 @ungap
                        2232741  4 drwxrwxr-x+   3 iobroker iobroker  4096 Jun 28 10:55 uri-js
                        2232744  4 drwxrwxr-x+   2 iobroker iobroker  4096 Jun 28 10:55 util-deprecate
                        2232745  4 drwxrwxr-x+   4 iobroker iobroker  4096 Jun 28 10:55 uuid
                        2232858  4 drwxrwxr-x+   4 iobroker iobroker  4096 Jun 28 10:55 verror
                        2232752  4 drwxrwxr-x+   4 iobroker iobroker  4096 Jun 28 10:55 virtual-tsc
                        2232857  4 drwxrwxr-x+   5 iobroker iobroker  4096 Jun 28 10:55 vm2
                        2232753  4 drwxrwxr-x+   2 iobroker iobroker  4096 Jun 28 10:55 wake_on_lan
                        2232762  4 drwxrwxr-x+   2 iobroker iobroker  4096 Jun 28 10:55 yallist
                        Wenig . Verzeichnisse dabei, sonst war zu jedem Verzeichnis auch ein .Verzeichnis vorhanden-
                        zB. coffee-script und .coffee-script
                        Vielleicht hat jemand ne Idee.
                        Gruss paul
                        • P paul.honka
                          -> 1.11.0:
                          NPM version: 8.11.0
                          npm ERR! errno -39
                          Gruss paul
                          Thomas BraunT
                          Thomas BraunT
                          #141
                          /opt/iobroker/node_modules/iobroker.javascript/node_modules/.core-util-is-eZ4fUaee
                          Lösch das Verzeichnis mal
                          sudo -u iobroker rm -rf /opt/iobroker/node_modules/iobroker.javascript/node_modules/.core-util-is-eZ4fUaee
                          P 1 Antwort Letzte Antwort
                            P
                            P
                            paul.honka
                            #142
                            pi@IOBroker-Sted1:/opt/iobroker $ iob upgrade flot --debug
                            -> 1.11.0:
                            NPM version: 8.11.0
                            npm ERR! errno -39
                            npm ERR!     /home/iobroker/.npm/_logs/2022-06-28T17_07_00_023Z-debug-0.log
                            Endlosschleife?
                            Gruss paul
                            • P paul.honka
                              -> 1.11.0:
                              NPM version: 8.11.0
                              npm ERR! errno -39
                              Endlosschleife?
                              Gruss paul
                              Thomas BraunT
                              Thomas BraunT
                              #143
                              Endlosschleife?
                              Nee, irgendwann ist Ende.
                                Endlosschleife?
                                P
                                P
                                paul.honka
                                #144
                                So bei flot und Simply-api habe ich zwölf Löschungen gemacht, bei telegram 38 Löschungen.
                                Ist das jetzt bei jedem Update so?
                                Gruss paul
                                • P paul.honka
                                  Gruss paul
                                  Thomas BraunT
                                  Thomas BraunT
                                  #145
                                  Hier ist das nicht so.
                                    P
                                    P
                                    paul.honka
                                    #146
                                    @thomas-braun und
                                    habe mal von stable auf beta ungestell.
                                    Die Adapter ble und texttocommand2 konnte aus dem Admin updaten.
                                    Besten Dank an tb, apollon77 und dem super Forum
                                    Gruss paul
                                    • P paul.honka
                                      @thomas-braun und
                                      Gruss paul
                                      Thomas BraunT
                                      Thomas BraunT
                                      #147
                                      @paul-honka
                                      Wie schaut denn das nun aus?
                                      uname -m && which nodejs node npm && nodejs -v && node -v && npm -v && whoami && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
                                      iobroker update -i
                                        T
                                        T
                                        taba_luga
                                        schrieb am zuletzt editiert von taba_luga
                                        #148
                                        Die Datei
                                        ist nicht vorhanden. Das Verzeichnis existiert.
                                        Nachtrag: Den Adapter RFLink habe ich gar nicht mehr installiert. Kann ich das gesamte Verzeichnis
                                        iobroker.rflink
                                        mit Unterverzeichnissen einfach löschen?
                                        • T taba_luga
                                          Die Datei
                                          iobroker.rflink
                                          Thomas BraunT
                                          Thomas BraunT
                                          #149
                                          @taba_luga
                                          Ist rflink richtig installiert?
                                          84.2k
