  4. Error 25 bei Adapterupdates nach Node.JS 16.15.1 Update
errormeldungnodejs 16.15.1
169 Beiträge 15 Kommentatoren 41.5k Aufrufe 12 Beobachtet
  • P paul.honka
    gemacht
     mv /opt/iobroker/node_modules/node-telegram-bot-api /opt/iobroker/node_modules/.node-telegram-bot-api-1etpN2K2
    /opt/iobroker $  iob upgrade email --debug
    This upgrade of "email" will introduce the following changes:
    -> 1.1.3:
    Make sure the STARTTLS configuration field is displayed
    -> 1.1.2:
    Fix mail.ee settings
    -> 1.1.1:
    Allow to use connections to port 25 unencrypted
    -> 1.1.0:
    Adjust default settings for web.de and 1und1 and add ionos
    Add "Always use STARTTLS" option for custom SMTP settings
    Would you like to upgrade email from @1.0.10 to @1.1.3 now? [(y)es, (n)o]: y
    Update email from @1.0.10 to @1.1.3
    NPM version: 8.11.0
    Installing iobroker.email@1.1.3... (System call)
    npm WARN old lockfile
    npm WARN old lockfile The package-lock.json file was created with an old version of npm,
    npm WARN old lockfile so supplemental metadata must be fetched from the registry.
    npm WARN old lockfile This is a one-time fix-up, please be patient...
    npm ERR! code ENOTEMPTY
    npm ERR! syscall rename
    npm ERR! path /opt/iobroker/node_modules/regexp.prototype.flags
    npm ERR! dest /opt/iobroker/node_modules/.regexp.prototype.flags-omxNhUlX
    npm ERR! errno -39
    npm ERR! ENOTEMPTY: directory not empty, rename '/opt/iobroker/node_modules/regexp.prototype.flags' -> '/opt/iobroker/node_modules/.regexp.prototype.flags-omxNhUlX'
    npm ERR!     /home/iobroker/.npm/_logs/2022-06-28T08_35_21_368Z-debug-0.log
    host.IOBroker-Sted1 Cannot install iobroker.email@1.1.3: 217
    Drehen wir uns im Kreis ?
    Steht wieder ein rename drin? Immer weiter umbenennen?
    Gruss paul
    Thomas BraunT
    Thomas BraunT
    Most Active Developer
    #126
    @paul-honka sagte in Error 25 bei Adapterupdates nach Node.JS 16.15.1 Update:
    Ja.
    • P paul.honka
      gemacht
      -> 1.1.3:
      -> 1.1.2:
      -> 1.1.1:
      -> 1.1.0:
      NPM version: 8.11.0
      npm ERR! errno -39
      Gruss paul
      Thomas BraunT
      Thomas BraunT
      #127
      Deutet auf verfummelte Rechte hin. Mal als root oder per sudo unterwegs gewesen?
      P 4 Antworten Letzte Antwort
      • P paul.honka
        gemacht
        -> 1.1.3:
        -> 1.1.2:
        -> 1.1.1:
        -> 1.1.0:
        NPM version: 8.11.0
        npm ERR! errno -39
        Gruss paul
        GlasfaserG
        GlasfaserG
        #128
        gesehen .... die mal löschen/verschieben !?
          P
          P
          paul.honka
          #129
          nein, nur das update auf node 16 vor einiger Zeit mit sudo, um die Einträge in der
          etc/apt/sources.list.d zu ändern.
          Gruss paul
            P
            P
            paul.honka
            #130
            Noch drei Runden verschieben dreht, dann war der E Mail Adapter uogedatet.
            -> 1.1.3:
            -> 1.1.2:
            -> 1.1.1:
            -> 1.1.0:
            NPM version: 8.11.0
            added 32 packages, removed 45 packages, and changed 8 packages in 1m
            94 packages are looking for funding
              run `npm fund` for details
            Update "system.adapter.email.0"
            upload [4] email.admin /opt/iobroker/node_modules/iobroker.email/admin/blockly.js blockly.js application/javascript
            upload [3] email.admin /opt/iobroker/node_modules/iobroker.email/admin/email.png email.png image/png
            upload [2] email.admin /opt/iobroker/node_modules/iobroker.email/admin/index.html index.html text/html
            upload [1] email.admin /opt/iobroker/node_modules/iobroker.email/admin/index_m.html index_m.html text/html
            upload [0] email.admin /opt/iobroker/node_modules/iobroker.email/admin/words.js words.js application/javascript
            Dann wollte ich flot updaten, das gleiche Spiel nochmal.
            iob upgrade flot --debug
            This upgrade of "flot" will introduce the following changes:
            -> 1.11.0:
            Trust GetHistory results to contain ms resolution timestamps
            Would you like to upgrade flot from @1.10.7 to @1.11.0 now? [(y)es, (n)o]: y
            Update flot from @1.10.7 to @1.11.0
            NPM version: 8.11.0
            Installing iobroker.flot@1.11.0... (System call)
            npm ERR! path /opt/iobroker/node_modules/iobroker.javascript/node_modules/acorn-walk
            npm ERR! dest /opt/iobroker/node_modules/iobroker.javascript/node_modules/.acorn-walk-xHkEOJL1
            npm ERR! errno -39
            npm ERR! ENOTEMPTY: directory not empty, rename '/opt/iobroker/node_modules/iobroker.javascript/node_modules/acorn-walk' -> '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.acorn-walk-xHkEOJL1'
            npm ERR!     /home/iobroker/.npm/_logs/2022-06-28T08_57_13_800Z-debug-0.log
            host.IOBroker-Sted1 Cannot install iobroker.flot@1.11.0: 217
            Gruss paul
              P
              P
              paul.honka
              #131
              wo finde ich die package-lock.json, im /opt/obroker/log nicht.
              Gruss paul
                P
                P
                paul.honka
                #132
                Jetzt fängt er an, das ich alle Dateien in /opt/iobroker/node_modules/iobroker.javascript/node_modules/
                umbennen soll. Natürlich nur eine pro Update Aufruf. Kommt dann das nächste Verzeichnis drann?
                Da wird es wohl Weihnachten. Das kann nicht die Lösung sein?
                Gruss paul
                • apollon77A
                  apollon77A
                  #133
                  Ich bin imme rnoch der Meinung das das nicht richtig ist was wir hier tun ... npm will das umbenennen, wohl weil es da Module gibt mit denen er was tun will ... und er kann es nicht umbenennen. So interpretiere ich diese Meldung. Die Frage ist also jetzt ob das Zielverzeichnis denn schon da ist oder warum er das anmeckert? Dann müsste man eher das aus dem Weg räumen.
                  EDIT: je mehr ich google umso mehr vermute ich das es das Zielverzeichnis ist was man löschen muss - warum auch immer esd da geblieben ist Und dann nochmal versuchen.
                  Das Rename zu machen macht ggf mehr Issues als alles andere
                  P 2 Antworten Letzte Antwort
                  • Thomas BraunT
                    Thomas BraunT
                    #134
                    In /opt/iobroker/
                    • apollon77A apollon77
                      P
                      P
                      paul.honka
                      #135
                      @apollon77
                      Wenn ich nachher zu Hause bin, dann schaue ich mal nach der Verzeichnisstruktur.
                      Gruss paul
                      • T taba_luga
                        jetzt geht der Spaß mit den Ordnern wieder los...
                        xx@iobroker-prod:/opt/iobroker$ sudo -H -u iobroker npm install iobroker.js-controller
                        npm ERR! path /opt/iobroker/node_modules/alexa-cookie2
                        npm ERR! dest /opt/iobroker/node_modules/.alexa-cookie2-yH4YGJkw
                        npm ERR! errno -39
                        npm ERR! ENOTEMPTY: directory not empty, rename '/opt/iobroker/node_modules/alexa-cookie2' -> '/opt/iobroker/node_modules/.alexa-cookie2-yH4YGJkw'
                        npm ERR!     /home/iobroker/.npm/_logs/2022-06-24T11_45_06_568Z-debug-0.log
                        Die benenne ich dann erst mal wieder um und melde mich dann wieder bei euch. Vielen DANK schon mal zwischendurch für euren super Support!!!
                        T
                        T
                        taba_luga
                        #136
                        @thomas-braun nach drei Tagen umbenennen der Verzeichnisse und immer noch kein Ende in Sicht, habe ich das System jetzt auf den Snapshot mit Debian 10 zurückgerollt. Hier scheint noch alles zu ordentlich zu laufen. Ich werde jetzt erstmal auf diesem Stand bleiben und dort alle Adapter updaten. Wenn das alles ordentlich funktioniert hat, versuche ich nochmal ein Update auf Debian 11 mit NPM 8.
                        • T taba_luga
                          Thomas BraunT
                          Thomas BraunT
                          #137
                          @taba_luga sagte in Error 25 bei Adapterupdates nach Node.JS 16.15.1 Update:
                          Das Debian-Release hat nichts mit npm8 zu tun.
                          Schau dir vor einem Upgrade auf node16/npm8 den npm tree an. Der muss möglichst sauber sein.
                          cd /opt/iobroker
                          npm ls | grep -E 'ERR|github'
                          sollte im Altsystem schon ohne Rückmeldung durchlaufen.
                            cd /opt/iobroker
                            T
                            T
                            taba_luga
                            #138
                            Das war unglücklich formuliert von mir. Der Snapshot mit Debian 10 geht einher mit dem Stand Node14/npm6.
                            xx@iobroker-prod:~$ which nodejs && nodejs -v && which node && node -v && which npm && npm -v && apt policy nodejs
                            /usr/bin/nodejs
                            v14.19.3
                            /usr/bin/node
                            v14.19.3
                            /usr/bin/npm
                            6.14.17
                            nodejs:
                              Installiert:           14.19.3-1nodesource1
                              Installationskandidat: 14.19.3-1nodesource1
                              Versionstabelle:
                             *** 14.19.3-1nodesource1 500
                                    500 https://deb.nodesource.com/node_14.x stretch/main amd64 Packages
                                 10.24.0~dfsg-1~deb10u1 500
                                    500 http://ftp.de.debian.org/debian buster/main amd64 Packages
                                    500 http://security.debian.org/debian-security buster/updates/main amd64 Packages
                            xx@iobroker-prod:~$
                            Leider läuft das nicht ohne Rückmeldung durch...
                             xx@iobroker-prod:~$ cd /opt/iobroker
                            xx@iobroker-prod:/opt/iobroker$ npm ls | grep -E 'ERR|github'
                            [sudo] Passwort für xx:
                            │ │ │ ├── github-from-package@0.0.0
                            npm ERR! extraneous: @abandonware/noble@1.9.2-1 /opt/iobroker/node_modules/@abandonware/noble
                            npm ERR! extraneous: @apollon/frankjoke-myadapter@1.2.5 /opt/iobroker/node_modules/@apollon/frankjoke-myadapter
                            npm ERR! extraneous: @frankjoke/myadapter@1.2.4 /opt/iobroker/node_modules/@frankjoke/myadapter
                            npm ERR! extraneous: @serialport/bindings@2.0.8 /opt/iobroker/node_modules/@serialport/bindings
                            npm ERR! extraneous: @serialport/parser-byte-length@1.0.5 /opt/iobroker/node_modules/@serialport/parser-byte-length
                            npm ERR! extraneous: @serialport/parser-cctalk@1.0.5 /opt/iobroker/node_modules/@serialport/parser-cctalk
                            npm ERR! extraneous: @serialport/parser-readline@1.0.5 /opt/iobroker/node_modules/@serialport/parser-readline
                            npm ERR! extraneous: @serialport/parser-ready@1.0.5 /opt/iobroker/node_modules/@serialport/parser-ready
                            npm ERR! extraneous: @serialport/parser-regex@1.0.5 /opt/iobroker/node_modules/@serialport/parser-regex
                            npm ERR! extraneous: @serialport/stream@2.0.5 /opt/iobroker/node_modules/@serialport/stream
                            npm ERR! extraneous: iobroker.rflink /opt/iobroker/node_modules/iobroker.rflink
                            npm ERR! error in /opt/iobroker/node_modules/iobroker.rflink: ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.rflink/package.json'
                            npm ERR! extraneous: alexa-remote2@1.0.0 /opt/iobroker/node_modules/alexa-remote2
                            npm ERR! extraneous: axios@0.18.0 /opt/iobroker/node_modules/axios
                            npm ERR! extraneous: dropbox-v2-api@2.4.0 /opt/iobroker/node_modules/dropbox-v2-api
                            npm ERR! extraneous: express-fileupload@0.1.4 /opt/iobroker/node_modules/express-fileupload
                            npm ERR! extraneous: fs-extra@0.22.1 /opt/iobroker/node_modules/fs-extra
                            npm ERR! extraneous: googleapis@40.0.1 /opt/iobroker/node_modules/googleapis
                            npm ERR! extraneous: iobroker@1.0.2 /opt/iobroker/node_modules/iobroker
                            npm ERR! extraneous: iobroker.icons-material-png@0.1.0 /opt/iobroker/node_modules/iobroker.icons-material-png
                            npm ERR! extraneous: iobroker.milight@0.3.6 /opt/iobroker/node_modules/iobroker.milight
                            npm ERR! extraneous: iobroker.vis-timeandweather@1.1.7 /opt/iobroker/node_modules/iobroker.vis-timeandweather
                            npm ERR! extraneous: joi@6.10.1 /opt/iobroker/node_modules/joi
                            npm ERR! extraneous: js2xmlparser@3.0.0 /opt/iobroker/node_modules/js2xmlparser
                            npm ERR! extraneous: jsonwebtoken@8.1.0 /opt/iobroker/node_modules/jsonwebtoken
                            npm ERR! extraneous: md5@2.2.1 /opt/iobroker/node_modules/md5
                            npm ERR! extraneous: mongodb@3.3.2 /opt/iobroker/node_modules/mongodb
                            npm ERR! extraneous: mqtt-connection@3.2.0 /opt/iobroker/node_modules/mqtt-connection
                            npm ERR! extraneous: nearest-color@0.4.2 /opt/iobroker/node_modules/nearest-color
                            npm ERR! extraneous: net-ping@1.2.3 /opt/iobroker/node_modules/net-ping
                            npm ERR! extraneous: noble@1.9.1 /opt/iobroker/node_modules/noble
                            npm ERR! extraneous: node-arp@1.0.6 /opt/iobroker/node_modules/node-arp
                            npm ERR! extraneous: node-bluetooth@1.2.6 /opt/iobroker/node_modules/node-bluetooth
                            npm ERR! extraneous: node-red@0.20.8 /opt/iobroker/node_modules/node-red
                            npm ERR! extraneous: node-red-contrib-aggregator@1.5.0 /opt/iobroker/node_modules/node-red-contrib-aggregator
                            npm ERR! extraneous: node-red-contrib-os@0.1.7 /opt/iobroker/node_modules/node-red-contrib-os
                            npm ERR! extraneous: node-red-contrib-polymer@0.0.21 /opt/iobroker/node_modules/node-red-contrib-polymer
                            npm ERR! extraneous: node-red-dashboard@2.16.2 /opt/iobroker/node_modules/node-red-dashboard
                            npm ERR! extraneous: node-ssdp@3.2.5 /opt/iobroker/node_modules/node-ssdp
                            npm ERR! extraneous: node-telegram-bot-api@0.30.0 /opt/iobroker/node_modules/node-telegram-bot-api
                            npm ERR! extraneous: openzwave-shared@1.4.0 /opt/iobroker/node_modules/openzwave-shared
                            npm ERR! extraneous: picocolors@1.0.0 /opt/iobroker/node_modules/picocolors
                            npm ERR! extraneous: ping@0.2.2 /opt/iobroker/node_modules/ping
                            npm ERR! extraneous: prebuild-install@4.0.0 /opt/iobroker/node_modules/prebuild-install
                            npm ERR! extraneous: promirepl@1.0.1 /opt/iobroker/node_modules/promirepl
                            npm ERR! extraneous: prompt-list@3.2.0 /opt/iobroker/node_modules/prompt-list
                            npm ERR! extraneous: pushover-notifications@0.2.4 /opt/iobroker/node_modules/pushover-notifications
                            npm ERR! extraneous: suncalc@1.8.0 /opt/iobroker/node_modules/suncalc
                            npm ERR! extraneous: systeminformation@4.5.1 /opt/iobroker/node_modules/systeminformation
                            npm ERR! extraneous: typescript@2.6.2 /opt/iobroker/node_modules/typescript
                            npm ERR! extraneous: virtual-device-sdk@1.5.1 /opt/iobroker/node_modules/virtual-device-sdk
                            npm ERR! extraneous: virtual-tsc@0.3.4 /opt/iobroker/node_modules/virtual-tsc
                            npm ERR! extraneous: zwave-js@5.4.0 /opt/iobroker/node_modules/zwave-js
                            npm ERR! peer dep missing: @zwave-js/core@>=9.0.4, required by @zwave-js/log-transport-json@2.0.1
                            npm ERR! peer dep missing: @zwave-js/shared@>=9.0.4, required by @zwave-js/log-transport-json@2.0.1
                            • T taba_luga
                              /usr/bin/nodejs
                              v14.19.3
                              /usr/bin/node
                              v14.19.3
                              /usr/bin/npm
                              6.14.17
                              nodejs:
                                Versionstabelle:
                              xx@iobroker-prod:~$
                              Thomas BraunT
                              Thomas BraunT
                              #139
                              Da vermute ich den Troublemaker:
                                P
                                P
                                paul.honka
                                schrieb am zuletzt editiert von paul.honka
                                #140
                                @apollon77 Noch mal ein Versuch
                                -> 1.11.0:
                                NPM version: 8.11.0
                                npm ERR! path /opt/iobroker/node_modules/iobroker.javascript/node_modules/@types/caseless
                                npm ERR! dest /opt/iobroker/node_modules/iobroker.javascript/node_modules/@types/.caseless-E7EBKTiW
                                npm ERR! errno -39
                                npm ERR! ENOTEMPTY: directory not empty, rename '/opt/iobroker/node_modules/iobroker.javascript/node_modules/@types/caseless' -> '/opt/iobroker/node_modules/iobroker.javascript/node_modules/@types/.caseless-E7EBKTiW'
                                npm ERR!     /home/iobroker/.npm/_logs/2022-06-28T16_56_44_129Z-debug-0.log
                                und jetzt das Verzeichnis /opt/iobroker/node_modules/iobroker.javascript/node_modules
                                659370 40 drwxrwxr-x+  91 iobroker iobroker 36864 Jun 28 18:56 .
                                 658280  4 drwxrwxr-x+   8 iobroker iobroker  4096 Jun  2 00:18 ..
                                1708173  4 drwxrwxr-x+  12 iobroker iobroker  4096 Jun 28 10:55 @alcalzone
                                1708174  4 drwxrwxr-x+   5 iobroker iobroker  4096 Jun 28 10:55 @babel
                                 794382  4 drwxrwxr-x+   2 iobroker iobroker  4096 Jun 28 18:45 .bin
                                1313831  4 drwxrwxr-x+   4 iobroker iobroker  4096 Jun 28 10:55 coffee-script
                                1313856  4 drwxrwxr-x+   3 iobroker iobroker  4096 Jun 28 10:55 combined-stream
                                1313868  4 drwxrwxr-x+   3 iobroker iobroker  4096 Jun 28 10:55 core-util-is
                                1313873  4 drwxrwxr-x+   5 iobroker iobroker  4096 Jun 28 10:55 cron-parser
                                1313884  4 drwxrwxr-x+   4 iobroker iobroker  4096 Jun 28 10:55 dashdash
                                1313887  4 drwxrwxr-x+   3 iobroker iobroker  4096 Jun 28 10:55 debug
                                1313900  4 drwxrwxr-x+   3 iobroker iobroker  4096 Jun 28 10:55 define-properties
                                1313908  4 drwxrwxr-x+   3 iobroker iobroker  4096 Jun 28 10:55 delayed-stream
                                2232767  4 drwxrwxr-x+   2 iobroker iobroker  4096 Jun 28 10:55 dewpoint
                                1313924  4 drwxrwxr-x+   3 iobroker iobroker  4096 Jun 28 10:55 ecc-jsbn
                                1708178  4 drwxrwxr-x+   3 iobroker iobroker  4096 Jun 28 10:55 @eslint
                                1577393  4 drwxrwxr-x+   2 iobroker iobroker  4096 Jun 28 10:55 extend
                                1577772  4 drwxrwxr-x+   3 iobroker iobroker  4096 Jun 28 10:55 extsprintf
                                1577808  4 drwxrwxr-x+   3 iobroker iobroker  4096 Jun 28 10:55 fast-deep-equal
                                1577828  4 drwxrwxr-x+   6 iobroker iobroker  4096 Jun 28 10:55 fast-json-stable-stringify
                                2109566  4 drwxrwxr-x+   2 iobroker iobroker  4096 Jun 28 10:55 forever-agent
                                2109567  4 drwxrwxr-x+   3 iobroker iobroker  4096 Jun 28 10:55 form-data
                                2109573  4 drwxrwxr-x+   3 iobroker iobroker  4096 Jun 28 10:55 function-bind
                                2109577  4 drwxrwxr-x+   4 iobroker iobroker  4096 Jun 28 10:55 get-intrinsic
                                2109580  4 drwxrwxr-x+   3 iobroker iobroker  4096 Jun 28 10:55 getpass
                                2109594  4 drwxrwxr-x+   3 iobroker iobroker  4096 Jun 28 10:55 har-schema
                                2109595  4 drwxrwxr-x+   3 iobroker iobroker  4096 Jun 28 10:55 har-validator
                                2109596  4 drwxrwxr-x+   4 iobroker iobroker  4096 Jun 28 10:55 has
                                2109598  4 drwxrwxr-x+   4 iobroker iobroker  4096 Jun 28 10:55 has-property-descriptors
                                2109599  4 drwxrwxr-x+   4 iobroker iobroker  4096 Jun 28 10:55 has-symbols
                                2109604  4 drwxrwxr-x+   3 iobroker iobroker  4096 Jun 28 10:55 http-signature
                                1708175  4 drwxrwxr-x+   4 iobroker iobroker  4096 Jun 28 10:55 @humanwhocodes
                                2109607  4 drwxrwxr-x+   4 iobroker iobroker  4096 Jun 28 10:55 immediate
                                2109612  4 drwxrwxr-x+   2 iobroker iobroker  4096 Jun 28 10:55 inherits
                                 659375  4 drwxrwxr-x+   3 iobroker iobroker  4096 Jun 28 18:56 @iobroker
                                2109640  4 drwxrwxr-x+   2 iobroker iobroker  4096 Jun 28 10:55 isarray
                                2109626  4 drwxrwxr-x+   4 iobroker iobroker  4096 Jun 28 10:55 is-nan
                                2109643  4 drwxrwxr-x+   2 iobroker iobroker  4096 Jun 28 10:55 isstream
                                2109634  4 drwxrwxr-x+   2 iobroker iobroker  4096 Jun 28 10:55 is-typedarray
                                2109647  4 drwxrwxr-x+   2 iobroker iobroker  4096 Jun 28 10:55 jsbn
                                2109652  4 drwxrwxr-x+   2 iobroker iobroker  4096 Jun 28 10:55 jsonata
                                2109648  4 drwxrwxr-x+   3 iobroker iobroker  4096 Jun 28 10:55 json-schema
                                2109649  4 drwxrwxr-x+   3 iobroker iobroker  4096 Jun 28 10:55 json-schema-traverse
                                2109651  4 drwxrwxr-x+   3 iobroker iobroker  4096 Jun 28 10:55 json-stringify-safe
                                2109654  4 drwxrwxr-x+   3 iobroker iobroker  4096 Jun 28 10:55 jsprim
                                2109655  4 drwxrwxr-x+   6 iobroker iobroker  4096 Jun 28 10:55 jszip
                                2109663  4 drwxrwxr-x+   4 iobroker iobroker  4096 Jun 28 10:55 lie
                                2232582  4 drwxrwxr-x+   2 iobroker iobroker  4096 Jun 28 10:55 long-timeout
                                2232584  4 drwxrwxr-x+   2 iobroker iobroker  4096 Jun 28 10:55 lru-cache
                                2232585  4 drwxrwxr-x+   4 iobroker iobroker  4096 Jun 28 10:55 luxon
                                2232590  4 drwxrwxr-x+   2 iobroker iobroker  4096 Jun 28 10:55 mime-db
                                2232591  4 drwxrwxr-x+   2 iobroker iobroker  4096 Jun 28 10:55 mime-types
                                2232594  4 drwxrwxr-x+   4 iobroker iobroker  4096 Jun 28 10:55 minimist
                                2232595  4 drwxrwxr-x+   2 iobroker iobroker  4096 Jun 28 10:55 ms
                                2232601  4 drwxrwxr-x+   3 iobroker iobroker  4096 Jun 28 10:55 node-inspect
                                1708176  4 drwxrwxr-x+   5 iobroker iobroker  4096 Jun 28 10:55 @nodelib
                                2232602  4 drwxrwxr-x+   3 iobroker iobroker  4096 Jun 28 10:55 node-schedule
                                2232607  4 drwxrwxr-x+   2 iobroker iobroker  4096 Jun 28 10:55 oauth-sign
                                2232609  4 drwxrwxr-x+   3 iobroker iobroker  4096 Jun 28 10:55 object-keys
                                2232624  4 drwxrwxr-x+   4 iobroker iobroker  4096 Jun 28 10:55 pako
                                2232640  4 drwxrwxr-x+   5 iobroker iobroker  4096 Jun 28 10:55 performance-now
                                2232641  4 drwxrwxr-x+   2 iobroker iobroker  4096 Jun 28 10:55 picocolors
                                2232649  4 drwxrwxr-x+   2 iobroker iobroker  4096 Jun 28 10:55 process-nextick-args
                                2232651  4 drwxrwxr-x+   4 iobroker iobroker  4096 Jun 28 10:55 psl
                                2232654  4 drwxrwxr-x+   2 iobroker iobroker  4096 Jun 28 10:55 punycode
                                2232655  4 drwxrwxr-x+   6 iobroker iobroker  4096 Jun 28 10:55 qs
                                2232658  4 drwxrwxr-x+   4 iobroker iobroker  4096 Jun 28 10:55 readable-stream
                                2232843  4 drwxrwxr-x+   4 iobroker iobroker  4096 Jun 28 10:55 request
                                 794224 24 drwxrwxr-x+ 478 pi       pi       24576 Jun 28 18:43 res
                                2232680  4 drwxrwxr-x+   2 iobroker iobroker  4096 Jun 28 10:55 safe-buffer
                                2232682  4 drwxrwxr-x+   2 iobroker iobroker  4096 Jun 28 10:55 safer-buffer
                                 658277  4 drwxrwxr-x+   7 iobroker iobroker  4096 Jun  2 00:18 semver
                                2232686  4 drwxrwxr-x+   2 iobroker iobroker  4096 Jun 28 10:55 setimmediate
                                2232692  4 drwxrwxr-x+   2 iobroker iobroker  4096 Jun 28 10:55 sorted-array-functions
                                2232702  4 drwxrwxr-x+   5 iobroker iobroker  4096 Jun 28 10:55 sshpk
                                2232707  4 drwxrwxr-x+   3 iobroker iobroker  4096 Jun 28 10:55 string_decoder
                                2232713  4 drwxrwxr-x+   2 iobroker iobroker  4096 Jun 28 10:55 suncalc2
                                2232727  4 drwxrwxr-x+   3 iobroker iobroker  4096 Jun 28 10:55 tough-cookie
                                2232728  4 drwxrwxr-x+   2 iobroker iobroker  4096 Jun 28 10:55 tunnel-agent
                                2232729  4 drwxrwxr-x+   2 iobroker iobroker  4096 Jun 28 10:55 tweetnacl
                                 659374  4 drwxrwxr-x+  13 iobroker iobroker  4096 Jun 28 18:56 @types
                                 658278  4 drwxrwxr-x+   5 iobroker iobroker  4096 Jun  2 00:18 typescript
                                1708182  4 drwxrwxr-x+   3 iobroker iobroker  4096 Jun 28 10:55 @ungap
                                2232741  4 drwxrwxr-x+   3 iobroker iobroker  4096 Jun 28 10:55 uri-js
                                2232744  4 drwxrwxr-x+   2 iobroker iobroker  4096 Jun 28 10:55 util-deprecate
                                2232745  4 drwxrwxr-x+   4 iobroker iobroker  4096 Jun 28 10:55 uuid
                                2232858  4 drwxrwxr-x+   4 iobroker iobroker  4096 Jun 28 10:55 verror
                                2232752  4 drwxrwxr-x+   4 iobroker iobroker  4096 Jun 28 10:55 virtual-tsc
                                2232857  4 drwxrwxr-x+   5 iobroker iobroker  4096 Jun 28 10:55 vm2
                                2232753  4 drwxrwxr-x+   2 iobroker iobroker  4096 Jun 28 10:55 wake_on_lan
                                2232762  4 drwxrwxr-x+   2 iobroker iobroker  4096 Jun 28 10:55 yallist
                                Wenig . Verzeichnisse dabei, sonst war zu jedem Verzeichnis auch ein .Verzeichnis vorhanden-
                                zB. coffee-script und .coffee-script
                                Vielleicht hat jemand ne Idee.
                                Gruss paul
                                • P paul.honka
                                  -> 1.11.0:
                                  NPM version: 8.11.0
                                  npm ERR! errno -39
                                  Gruss paul
                                  Thomas BraunT
                                  Thomas BraunT
                                  #141
                                  /opt/iobroker/node_modules/iobroker.javascript/node_modules/.core-util-is-eZ4fUaee
                                  Lösch das Verzeichnis mal
                                  sudo -u iobroker rm -rf /opt/iobroker/node_modules/iobroker.javascript/node_modules/.core-util-is-eZ4fUaee
                                  P 1 Antwort Letzte Antwort
                                    P
                                    P
                                    paul.honka
                                    #142
                                    pi@IOBroker-Sted1:/opt/iobroker $ iob upgrade flot --debug
                                    -> 1.11.0:
                                    NPM version: 8.11.0
                                    npm ERR! errno -39
                                    npm ERR!     /home/iobroker/.npm/_logs/2022-06-28T17_07_00_023Z-debug-0.log
                                    Endlosschleife?
                                    Gruss paul
                                    • P paul.honka
                                      -> 1.11.0:
                                      NPM version: 8.11.0
                                      npm ERR! errno -39
                                      Endlosschleife?
                                      Gruss paul
                                      Thomas BraunT
                                      Thomas BraunT
                                      #143
                                      Endlosschleife?
                                      Nee, irgendwann ist Ende.
                                        Endlosschleife?
                                        P
                                        P
                                        paul.honka
                                        #144
                                        So bei flot und Simply-api habe ich zwölf Löschungen gemacht, bei telegram 38 Löschungen.
                                        Ist das jetzt bei jedem Update so?
                                        Gruss paul
                                        • P paul.honka
                                          Gruss paul
                                          Thomas BraunT
                                          Thomas BraunT
                                          #145
                                          Hier ist das nicht so.
                                          84.2k
