  4. Error 25 bei Adapterupdates nach Node.JS 16.15.1 Update
errormeldungnodejs 16.15.1
169 Beiträge 15 Kommentatoren 41.8k Aufrufe 12 Beobachtet
    @paul-honka sagte in Error 25 bei Adapterupdates nach Node.JS 16.15.1 Update:
    Cannot install iobroker.email@1.1.3: 217
    Deutet auf verfummelte Rechte hin. Mal als root oder per sudo unterwegs gewesen?
    P
    P
    paul.honka
    #129
    nein, nur das update auf node 16 vor einiger Zeit mit sudo, um die Einträge in der
    etc/apt/sources.list.d zu ändern.
    Gruss paul
      P
      P
      paul.honka
      #130
      Noch drei Runden verschieben dreht, dann war der E Mail Adapter uogedatet.
      iob upgrade email --debug
      This upgrade of "email" will introduce the following changes:
      -> 1.1.3:
      Make sure the STARTTLS configuration field is displayed
      -> 1.1.2:
      Fix mail.ee settings
      -> 1.1.1:
      Allow to use connections to port 25 unencrypted
      -> 1.1.0:
      Adjust default settings for web.de and 1und1 and add ionos
      Add "Always use STARTTLS" option for custom SMTP settings
      Would you like to upgrade email from @1.0.10 to @1.1.3 now? [(y)es, (n)o]: y
      Update email from @1.0.10 to @1.1.3
      NPM version: 8.11.0
      Installing iobroker.email@1.1.3... (System call)
      npm WARN old lockfile
      npm WARN old lockfile The package-lock.json file was created with an old version of npm,
      npm WARN old lockfile so supplemental metadata must be fetched from the registry.
      npm WARN old lockfile This is a one-time fix-up, please be patient...
      added 32 packages, removed 45 packages, and changed 8 packages in 1m
      94 packages are looking for funding
        run `npm fund` for details
      Update "system.adapter.email.0"
      upload [4] email.admin /opt/iobroker/node_modules/iobroker.email/admin/blockly.js blockly.js application/javascript
      upload [3] email.admin /opt/iobroker/node_modules/iobroker.email/admin/email.png email.png image/png
      upload [2] email.admin /opt/iobroker/node_modules/iobroker.email/admin/index.html index.html text/html
      upload [1] email.admin /opt/iobroker/node_modules/iobroker.email/admin/index_m.html index_m.html text/html
      upload [0] email.admin /opt/iobroker/node_modules/iobroker.email/admin/words.js words.js application/javascript
      Dann wollte ich flot updaten, das gleiche Spiel nochmal.
      iob upgrade flot --debug
      This upgrade of "flot" will introduce the following changes:
      -> 1.11.0:
      Trust GetHistory results to contain ms resolution timestamps
      Would you like to upgrade flot from @1.10.7 to @1.11.0 now? [(y)es, (n)o]: y
      Update flot from @1.10.7 to @1.11.0
      NPM version: 8.11.0
      Installing iobroker.flot@1.11.0... (System call)
      npm ERR! code ENOTEMPTY
      npm ERR! syscall rename
      npm ERR! path /opt/iobroker/node_modules/iobroker.javascript/node_modules/acorn-walk
      npm ERR! dest /opt/iobroker/node_modules/iobroker.javascript/node_modules/.acorn-walk-xHkEOJL1
      npm ERR! errno -39
      npm ERR! ENOTEMPTY: directory not empty, rename '/opt/iobroker/node_modules/iobroker.javascript/node_modules/acorn-walk' -> '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.acorn-walk-xHkEOJL1'
      npm ERR!     /home/iobroker/.npm/_logs/2022-06-28T08_57_13_800Z-debug-0.log
      host.IOBroker-Sted1 Cannot install iobroker.flot@1.11.0: 217
      Gruss paul
        P
        P
        paul.honka
        #131
        wo finde ich die package-lock.json, im /opt/obroker/log nicht.
        Gruss paul
          P
          P
          paul.honka
          #132
          Jetzt fängt er an, das ich alle Dateien in /opt/iobroker/node_modules/iobroker.javascript/node_modules/
          umbennen soll. Natürlich nur eine pro Update Aufruf. Kommt dann das nächste Verzeichnis drann?
          Da wird es wohl Weihnachten. Das kann nicht die Lösung sein?
          Gruss paul
          • apollon77A
            apollon77A
            #133
            Ich bin imme rnoch der Meinung das das nicht richtig ist was wir hier tun ... npm will das umbenennen, wohl weil es da Module gibt mit denen er was tun will ... und er kann es nicht umbenennen. So interpretiere ich diese Meldung. Die Frage ist also jetzt ob das Zielverzeichnis denn schon da ist oder warum er das anmeckert? Dann müsste man eher das aus dem Weg räumen.
            EDIT: je mehr ich google umso mehr vermute ich das es das Zielverzeichnis ist was man löschen muss - warum auch immer esd da geblieben ist Und dann nochmal versuchen.
            Das Rename zu machen macht ggf mehr Issues als alles andere
            P 2 Antworten Letzte Antwort
            • Thomas BraunT
              Thomas BraunT
              Most Active Developer
              #134
              In /opt/iobroker/
              • apollon77A apollon77
                P
                P
                paul.honka
                #135
                @apollon77
                Wenn ich nachher zu Hause bin, dann schaue ich mal nach der Verzeichnisstruktur.
                Gruss paul
                • T taba_luga
                  jetzt geht der Spaß mit den Ordnern wieder los...
                  xx@iobroker-prod:/opt/iobroker$ sudo -H -u iobroker npm install iobroker.js-controller
                  npm ERR! path /opt/iobroker/node_modules/alexa-cookie2
                  npm ERR! dest /opt/iobroker/node_modules/.alexa-cookie2-yH4YGJkw
                  npm ERR! errno -39
                  npm ERR! ENOTEMPTY: directory not empty, rename '/opt/iobroker/node_modules/alexa-cookie2' -> '/opt/iobroker/node_modules/.alexa-cookie2-yH4YGJkw'
                  npm ERR!     /home/iobroker/.npm/_logs/2022-06-24T11_45_06_568Z-debug-0.log
                  Die benenne ich dann erst mal wieder um und melde mich dann wieder bei euch. Vielen DANK schon mal zwischendurch für euren super Support!!!
                  T
                  T
                  taba_luga
                  #136
                  @thomas-braun nach drei Tagen umbenennen der Verzeichnisse und immer noch kein Ende in Sicht, habe ich das System jetzt auf den Snapshot mit Debian 10 zurückgerollt. Hier scheint noch alles zu ordentlich zu laufen. Ich werde jetzt erstmal auf diesem Stand bleiben und dort alle Adapter updaten. Wenn das alles ordentlich funktioniert hat, versuche ich nochmal ein Update auf Debian 11 mit NPM 8.
                  • T taba_luga
                    Thomas BraunT
                    Thomas BraunT
                    #137
                    @taba_luga sagte in Error 25 bei Adapterupdates nach Node.JS 16.15.1 Update:
                    Das Debian-Release hat nichts mit npm8 zu tun.
                    Schau dir vor einem Upgrade auf node16/npm8 den npm tree an. Der muss möglichst sauber sein.
                    cd /opt/iobroker
                    npm ls | grep -E 'ERR|github'
                    sollte im Altsystem schon ohne Rückmeldung durchlaufen.
                      cd /opt/iobroker
                      T
                      T
                      taba_luga
                      #138
                      Das war unglücklich formuliert von mir. Der Snapshot mit Debian 10 geht einher mit dem Stand Node14/npm6.
                      xx@iobroker-prod:~$ which nodejs && nodejs -v && which node && node -v && which npm && npm -v && apt policy nodejs
                      /usr/bin/nodejs
                      v14.19.3
                      /usr/bin/node
                      v14.19.3
                      /usr/bin/npm
                      6.14.17
                      nodejs:
                        Installiert:           14.19.3-1nodesource1
                        Installationskandidat: 14.19.3-1nodesource1
                        Versionstabelle:
                       *** 14.19.3-1nodesource1 500
                              500 https://deb.nodesource.com/node_14.x stretch/main amd64 Packages
                           10.24.0~dfsg-1~deb10u1 500
                              500 http://ftp.de.debian.org/debian buster/main amd64 Packages
                              500 http://security.debian.org/debian-security buster/updates/main amd64 Packages
                      xx@iobroker-prod:~$
                      Leider läuft das nicht ohne Rückmeldung durch...
                       xx@iobroker-prod:~$ cd /opt/iobroker
                      xx@iobroker-prod:/opt/iobroker$ npm ls | grep -E 'ERR|github'
                      [sudo] Passwort für xx:
                      │ │ │ ├── github-from-package@0.0.0
                      npm ERR! extraneous: @abandonware/noble@1.9.2-1 /opt/iobroker/node_modules/@abandonware/noble
                      npm ERR! extraneous: @apollon/frankjoke-myadapter@1.2.5 /opt/iobroker/node_modules/@apollon/frankjoke-myadapter
                      npm ERR! extraneous: @frankjoke/myadapter@1.2.4 /opt/iobroker/node_modules/@frankjoke/myadapter
                      npm ERR! extraneous: @serialport/bindings@2.0.8 /opt/iobroker/node_modules/@serialport/bindings
                      npm ERR! extraneous: @serialport/parser-byte-length@1.0.5 /opt/iobroker/node_modules/@serialport/parser-byte-length
                      npm ERR! extraneous: @serialport/parser-cctalk@1.0.5 /opt/iobroker/node_modules/@serialport/parser-cctalk
                      npm ERR! extraneous: @serialport/parser-readline@1.0.5 /opt/iobroker/node_modules/@serialport/parser-readline
                      npm ERR! extraneous: @serialport/parser-ready@1.0.5 /opt/iobroker/node_modules/@serialport/parser-ready
                      npm ERR! extraneous: @serialport/parser-regex@1.0.5 /opt/iobroker/node_modules/@serialport/parser-regex
                      npm ERR! extraneous: @serialport/stream@2.0.5 /opt/iobroker/node_modules/@serialport/stream
                      npm ERR! extraneous: iobroker.rflink /opt/iobroker/node_modules/iobroker.rflink
                      npm ERR! error in /opt/iobroker/node_modules/iobroker.rflink: ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.rflink/package.json'
                      npm ERR! extraneous: alexa-remote2@1.0.0 /opt/iobroker/node_modules/alexa-remote2
                      npm ERR! extraneous: axios@0.18.0 /opt/iobroker/node_modules/axios
                      npm ERR! extraneous: dropbox-v2-api@2.4.0 /opt/iobroker/node_modules/dropbox-v2-api
                      npm ERR! extraneous: express-fileupload@0.1.4 /opt/iobroker/node_modules/express-fileupload
                      npm ERR! extraneous: fs-extra@0.22.1 /opt/iobroker/node_modules/fs-extra
                      npm ERR! extraneous: googleapis@40.0.1 /opt/iobroker/node_modules/googleapis
                      npm ERR! extraneous: iobroker@1.0.2 /opt/iobroker/node_modules/iobroker
                      npm ERR! extraneous: iobroker.icons-material-png@0.1.0 /opt/iobroker/node_modules/iobroker.icons-material-png
                      npm ERR! extraneous: iobroker.milight@0.3.6 /opt/iobroker/node_modules/iobroker.milight
                      npm ERR! extraneous: iobroker.vis-timeandweather@1.1.7 /opt/iobroker/node_modules/iobroker.vis-timeandweather
                      npm ERR! extraneous: joi@6.10.1 /opt/iobroker/node_modules/joi
                      npm ERR! extraneous: js2xmlparser@3.0.0 /opt/iobroker/node_modules/js2xmlparser
                      npm ERR! extraneous: jsonwebtoken@8.1.0 /opt/iobroker/node_modules/jsonwebtoken
                      npm ERR! extraneous: md5@2.2.1 /opt/iobroker/node_modules/md5
                      npm ERR! extraneous: mongodb@3.3.2 /opt/iobroker/node_modules/mongodb
                      npm ERR! extraneous: mqtt-connection@3.2.0 /opt/iobroker/node_modules/mqtt-connection
                      npm ERR! extraneous: nearest-color@0.4.2 /opt/iobroker/node_modules/nearest-color
                      npm ERR! extraneous: net-ping@1.2.3 /opt/iobroker/node_modules/net-ping
                      npm ERR! extraneous: noble@1.9.1 /opt/iobroker/node_modules/noble
                      npm ERR! extraneous: node-arp@1.0.6 /opt/iobroker/node_modules/node-arp
                      npm ERR! extraneous: node-bluetooth@1.2.6 /opt/iobroker/node_modules/node-bluetooth
                      npm ERR! extraneous: node-red@0.20.8 /opt/iobroker/node_modules/node-red
                      npm ERR! extraneous: node-red-contrib-aggregator@1.5.0 /opt/iobroker/node_modules/node-red-contrib-aggregator
                      npm ERR! extraneous: node-red-contrib-os@0.1.7 /opt/iobroker/node_modules/node-red-contrib-os
                      npm ERR! extraneous: node-red-contrib-polymer@0.0.21 /opt/iobroker/node_modules/node-red-contrib-polymer
                      npm ERR! extraneous: node-red-dashboard@2.16.2 /opt/iobroker/node_modules/node-red-dashboard
                      npm ERR! extraneous: node-ssdp@3.2.5 /opt/iobroker/node_modules/node-ssdp
                      npm ERR! extraneous: node-telegram-bot-api@0.30.0 /opt/iobroker/node_modules/node-telegram-bot-api
                      npm ERR! extraneous: openzwave-shared@1.4.0 /opt/iobroker/node_modules/openzwave-shared
                      npm ERR! extraneous: picocolors@1.0.0 /opt/iobroker/node_modules/picocolors
                      npm ERR! extraneous: ping@0.2.2 /opt/iobroker/node_modules/ping
                      npm ERR! extraneous: prebuild-install@4.0.0 /opt/iobroker/node_modules/prebuild-install
                      npm ERR! extraneous: promirepl@1.0.1 /opt/iobroker/node_modules/promirepl
                      npm ERR! extraneous: prompt-list@3.2.0 /opt/iobroker/node_modules/prompt-list
                      npm ERR! extraneous: pushover-notifications@0.2.4 /opt/iobroker/node_modules/pushover-notifications
                      npm ERR! extraneous: suncalc@1.8.0 /opt/iobroker/node_modules/suncalc
                      npm ERR! extraneous: systeminformation@4.5.1 /opt/iobroker/node_modules/systeminformation
                      npm ERR! extraneous: typescript@2.6.2 /opt/iobroker/node_modules/typescript
                      npm ERR! extraneous: virtual-device-sdk@1.5.1 /opt/iobroker/node_modules/virtual-device-sdk
                      npm ERR! extraneous: virtual-tsc@0.3.4 /opt/iobroker/node_modules/virtual-tsc
                      npm ERR! extraneous: zwave-js@5.4.0 /opt/iobroker/node_modules/zwave-js
                      npm ERR! peer dep missing: @zwave-js/core@>=9.0.4, required by @zwave-js/log-transport-json@2.0.1
                      npm ERR! peer dep missing: @zwave-js/shared@>=9.0.4, required by @zwave-js/log-transport-json@2.0.1
                      • T taba_luga
                        /usr/bin/nodejs
                        v14.19.3
                        /usr/bin/node
                        v14.19.3
                        /usr/bin/npm
                        6.14.17
                        nodejs:
                          Versionstabelle:
                        xx@iobroker-prod:~$
                        Thomas BraunT
                        Thomas BraunT
                        #139
                        Da vermute ich den Troublemaker:
                          P
                          P
                          paul.honka
                          schrieb am zuletzt editiert von paul.honka
                          #140
                          @apollon77 Noch mal ein Versuch
                          -> 1.11.0:
                          NPM version: 8.11.0
                          npm ERR! path /opt/iobroker/node_modules/iobroker.javascript/node_modules/@types/caseless
                          npm ERR! dest /opt/iobroker/node_modules/iobroker.javascript/node_modules/@types/.caseless-E7EBKTiW
                          npm ERR! errno -39
                          npm ERR! ENOTEMPTY: directory not empty, rename '/opt/iobroker/node_modules/iobroker.javascript/node_modules/@types/caseless' -> '/opt/iobroker/node_modules/iobroker.javascript/node_modules/@types/.caseless-E7EBKTiW'
                          npm ERR!     /home/iobroker/.npm/_logs/2022-06-28T16_56_44_129Z-debug-0.log
                          und jetzt das Verzeichnis /opt/iobroker/node_modules/iobroker.javascript/node_modules
                          659370 40 drwxrwxr-x+  91 iobroker iobroker 36864 Jun 28 18:56 .
                           658280  4 drwxrwxr-x+   8 iobroker iobroker  4096 Jun  2 00:18 ..
                          1708173  4 drwxrwxr-x+  12 iobroker iobroker  4096 Jun 28 10:55 @alcalzone
                          1708174  4 drwxrwxr-x+   5 iobroker iobroker  4096 Jun 28 10:55 @babel
                           794382  4 drwxrwxr-x+   2 iobroker iobroker  4096 Jun 28 18:45 .bin
                          1313831  4 drwxrwxr-x+   4 iobroker iobroker  4096 Jun 28 10:55 coffee-script
                          1313856  4 drwxrwxr-x+   3 iobroker iobroker  4096 Jun 28 10:55 combined-stream
                          1313868  4 drwxrwxr-x+   3 iobroker iobroker  4096 Jun 28 10:55 core-util-is
                          1313873  4 drwxrwxr-x+   5 iobroker iobroker  4096 Jun 28 10:55 cron-parser
                          1313884  4 drwxrwxr-x+   4 iobroker iobroker  4096 Jun 28 10:55 dashdash
                          1313887  4 drwxrwxr-x+   3 iobroker iobroker  4096 Jun 28 10:55 debug
                          1313900  4 drwxrwxr-x+   3 iobroker iobroker  4096 Jun 28 10:55 define-properties
                          1313908  4 drwxrwxr-x+   3 iobroker iobroker  4096 Jun 28 10:55 delayed-stream
                          2232767  4 drwxrwxr-x+   2 iobroker iobroker  4096 Jun 28 10:55 dewpoint
                          1313924  4 drwxrwxr-x+   3 iobroker iobroker  4096 Jun 28 10:55 ecc-jsbn
                          1708178  4 drwxrwxr-x+   3 iobroker iobroker  4096 Jun 28 10:55 @eslint
                          1577393  4 drwxrwxr-x+   2 iobroker iobroker  4096 Jun 28 10:55 extend
                          1577772  4 drwxrwxr-x+   3 iobroker iobroker  4096 Jun 28 10:55 extsprintf
                          1577808  4 drwxrwxr-x+   3 iobroker iobroker  4096 Jun 28 10:55 fast-deep-equal
                          1577828  4 drwxrwxr-x+   6 iobroker iobroker  4096 Jun 28 10:55 fast-json-stable-stringify
                          2109566  4 drwxrwxr-x+   2 iobroker iobroker  4096 Jun 28 10:55 forever-agent
                          2109567  4 drwxrwxr-x+   3 iobroker iobroker  4096 Jun 28 10:55 form-data
                          2109573  4 drwxrwxr-x+   3 iobroker iobroker  4096 Jun 28 10:55 function-bind
                          2109577  4 drwxrwxr-x+   4 iobroker iobroker  4096 Jun 28 10:55 get-intrinsic
                          2109580  4 drwxrwxr-x+   3 iobroker iobroker  4096 Jun 28 10:55 getpass
                          2109594  4 drwxrwxr-x+   3 iobroker iobroker  4096 Jun 28 10:55 har-schema
                          2109595  4 drwxrwxr-x+   3 iobroker iobroker  4096 Jun 28 10:55 har-validator
                          2109596  4 drwxrwxr-x+   4 iobroker iobroker  4096 Jun 28 10:55 has
                          2109598  4 drwxrwxr-x+   4 iobroker iobroker  4096 Jun 28 10:55 has-property-descriptors
                          2109599  4 drwxrwxr-x+   4 iobroker iobroker  4096 Jun 28 10:55 has-symbols
                          2109604  4 drwxrwxr-x+   3 iobroker iobroker  4096 Jun 28 10:55 http-signature
                          1708175  4 drwxrwxr-x+   4 iobroker iobroker  4096 Jun 28 10:55 @humanwhocodes
                          2109607  4 drwxrwxr-x+   4 iobroker iobroker  4096 Jun 28 10:55 immediate
                          2109612  4 drwxrwxr-x+   2 iobroker iobroker  4096 Jun 28 10:55 inherits
                           659375  4 drwxrwxr-x+   3 iobroker iobroker  4096 Jun 28 18:56 @iobroker
                          2109640  4 drwxrwxr-x+   2 iobroker iobroker  4096 Jun 28 10:55 isarray
                          2109626  4 drwxrwxr-x+   4 iobroker iobroker  4096 Jun 28 10:55 is-nan
                          2109643  4 drwxrwxr-x+   2 iobroker iobroker  4096 Jun 28 10:55 isstream
                          2109634  4 drwxrwxr-x+   2 iobroker iobroker  4096 Jun 28 10:55 is-typedarray
                          2109647  4 drwxrwxr-x+   2 iobroker iobroker  4096 Jun 28 10:55 jsbn
                          2109652  4 drwxrwxr-x+   2 iobroker iobroker  4096 Jun 28 10:55 jsonata
                          2109648  4 drwxrwxr-x+   3 iobroker iobroker  4096 Jun 28 10:55 json-schema
                          2109649  4 drwxrwxr-x+   3 iobroker iobroker  4096 Jun 28 10:55 json-schema-traverse
                          2109651  4 drwxrwxr-x+   3 iobroker iobroker  4096 Jun 28 10:55 json-stringify-safe
                          2109654  4 drwxrwxr-x+   3 iobroker iobroker  4096 Jun 28 10:55 jsprim
                          2109655  4 drwxrwxr-x+   6 iobroker iobroker  4096 Jun 28 10:55 jszip
                          2109663  4 drwxrwxr-x+   4 iobroker iobroker  4096 Jun 28 10:55 lie
                          2232582  4 drwxrwxr-x+   2 iobroker iobroker  4096 Jun 28 10:55 long-timeout
                          2232584  4 drwxrwxr-x+   2 iobroker iobroker  4096 Jun 28 10:55 lru-cache
                          2232585  4 drwxrwxr-x+   4 iobroker iobroker  4096 Jun 28 10:55 luxon
                          2232590  4 drwxrwxr-x+   2 iobroker iobroker  4096 Jun 28 10:55 mime-db
                          2232591  4 drwxrwxr-x+   2 iobroker iobroker  4096 Jun 28 10:55 mime-types
                          2232594  4 drwxrwxr-x+   4 iobroker iobroker  4096 Jun 28 10:55 minimist
                          2232595  4 drwxrwxr-x+   2 iobroker iobroker  4096 Jun 28 10:55 ms
                          2232601  4 drwxrwxr-x+   3 iobroker iobroker  4096 Jun 28 10:55 node-inspect
                          1708176  4 drwxrwxr-x+   5 iobroker iobroker  4096 Jun 28 10:55 @nodelib
                          2232602  4 drwxrwxr-x+   3 iobroker iobroker  4096 Jun 28 10:55 node-schedule
                          2232607  4 drwxrwxr-x+   2 iobroker iobroker  4096 Jun 28 10:55 oauth-sign
                          2232609  4 drwxrwxr-x+   3 iobroker iobroker  4096 Jun 28 10:55 object-keys
                          2232624  4 drwxrwxr-x+   4 iobroker iobroker  4096 Jun 28 10:55 pako
                          2232640  4 drwxrwxr-x+   5 iobroker iobroker  4096 Jun 28 10:55 performance-now
                          2232641  4 drwxrwxr-x+   2 iobroker iobroker  4096 Jun 28 10:55 picocolors
                          2232649  4 drwxrwxr-x+   2 iobroker iobroker  4096 Jun 28 10:55 process-nextick-args
                          2232651  4 drwxrwxr-x+   4 iobroker iobroker  4096 Jun 28 10:55 psl
                          2232654  4 drwxrwxr-x+   2 iobroker iobroker  4096 Jun 28 10:55 punycode
                          2232655  4 drwxrwxr-x+   6 iobroker iobroker  4096 Jun 28 10:55 qs
                          2232658  4 drwxrwxr-x+   4 iobroker iobroker  4096 Jun 28 10:55 readable-stream
                          2232843  4 drwxrwxr-x+   4 iobroker iobroker  4096 Jun 28 10:55 request
                           794224 24 drwxrwxr-x+ 478 pi       pi       24576 Jun 28 18:43 res
                          2232680  4 drwxrwxr-x+   2 iobroker iobroker  4096 Jun 28 10:55 safe-buffer
                          2232682  4 drwxrwxr-x+   2 iobroker iobroker  4096 Jun 28 10:55 safer-buffer
                           658277  4 drwxrwxr-x+   7 iobroker iobroker  4096 Jun  2 00:18 semver
                          2232686  4 drwxrwxr-x+   2 iobroker iobroker  4096 Jun 28 10:55 setimmediate
                          2232692  4 drwxrwxr-x+   2 iobroker iobroker  4096 Jun 28 10:55 sorted-array-functions
                          2232702  4 drwxrwxr-x+   5 iobroker iobroker  4096 Jun 28 10:55 sshpk
                          2232707  4 drwxrwxr-x+   3 iobroker iobroker  4096 Jun 28 10:55 string_decoder
                          2232713  4 drwxrwxr-x+   2 iobroker iobroker  4096 Jun 28 10:55 suncalc2
                          2232727  4 drwxrwxr-x+   3 iobroker iobroker  4096 Jun 28 10:55 tough-cookie
                          2232728  4 drwxrwxr-x+   2 iobroker iobroker  4096 Jun 28 10:55 tunnel-agent
                          2232729  4 drwxrwxr-x+   2 iobroker iobroker  4096 Jun 28 10:55 tweetnacl
                           659374  4 drwxrwxr-x+  13 iobroker iobroker  4096 Jun 28 18:56 @types
                           658278  4 drwxrwxr-x+   5 iobroker iobroker  4096 Jun  2 00:18 typescript
                          1708182  4 drwxrwxr-x+   3 iobroker iobroker  4096 Jun 28 10:55 @ungap
                          2232741  4 drwxrwxr-x+   3 iobroker iobroker  4096 Jun 28 10:55 uri-js
                          2232744  4 drwxrwxr-x+   2 iobroker iobroker  4096 Jun 28 10:55 util-deprecate
                          2232745  4 drwxrwxr-x+   4 iobroker iobroker  4096 Jun 28 10:55 uuid
                          2232858  4 drwxrwxr-x+   4 iobroker iobroker  4096 Jun 28 10:55 verror
                          2232752  4 drwxrwxr-x+   4 iobroker iobroker  4096 Jun 28 10:55 virtual-tsc
                          2232857  4 drwxrwxr-x+   5 iobroker iobroker  4096 Jun 28 10:55 vm2
                          2232753  4 drwxrwxr-x+   2 iobroker iobroker  4096 Jun 28 10:55 wake_on_lan
                          2232762  4 drwxrwxr-x+   2 iobroker iobroker  4096 Jun 28 10:55 yallist
                          Wenig . Verzeichnisse dabei, sonst war zu jedem Verzeichnis auch ein .Verzeichnis vorhanden-
                          zB. coffee-script und .coffee-script
                          Vielleicht hat jemand ne Idee.
                          Gruss paul
                          • P paul.honka
                            -> 1.11.0:
                            NPM version: 8.11.0
                            npm ERR! errno -39
                            Gruss paul
                            Thomas BraunT
                            Thomas BraunT
                            #141
                            /opt/iobroker/node_modules/iobroker.javascript/node_modules/.core-util-is-eZ4fUaee
                            Lösch das Verzeichnis mal
                            sudo -u iobroker rm -rf /opt/iobroker/node_modules/iobroker.javascript/node_modules/.core-util-is-eZ4fUaee
                            P 1 Antwort Letzte Antwort
                              P
                              P
                              paul.honka
                              #142
                              pi@IOBroker-Sted1:/opt/iobroker $ iob upgrade flot --debug
                              -> 1.11.0:
                              NPM version: 8.11.0
                              npm ERR! errno -39
                              npm ERR!     /home/iobroker/.npm/_logs/2022-06-28T17_07_00_023Z-debug-0.log
                              Endlosschleife?
                              Gruss paul
                              • P paul.honka
                                -> 1.11.0:
                                NPM version: 8.11.0
                                npm ERR! errno -39
                                Endlosschleife?
                                Gruss paul
                                Thomas BraunT
                                Thomas BraunT
                                #143
                                Endlosschleife?
                                Nee, irgendwann ist Ende.
                                  Endlosschleife?
                                  P
                                  P
                                  paul.honka
                                  #144
                                  So bei flot und Simply-api habe ich zwölf Löschungen gemacht, bei telegram 38 Löschungen.
                                  Ist das jetzt bei jedem Update so?
                                  Gruss paul
                                  • P paul.honka
                                    Gruss paul
                                    Thomas BraunT
                                    Thomas BraunT
                                    #145
                                    Hier ist das nicht so.
                                      P
                                      P
                                      paul.honka
                                      #146
                                      @thomas-braun und
                                      habe mal von stable auf beta ungestell.
                                      Die Adapter ble und texttocommand2 konnte aus dem Admin updaten.
                                      Besten Dank an tb, apollon77 und dem super Forum
                                      Gruss paul
                                      • P paul.honka
                                        @thomas-braun und
                                        Gruss paul
                                        Thomas BraunT
                                        Thomas BraunT
                                        #147
                                        @paul-honka
                                        Wie schaut denn das nun aus?
                                        uname -m && which nodejs node npm && nodejs -v && node -v && npm -v && whoami && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
                                        iobroker update -i
                                          T
                                          T
                                          taba_luga
                                          schrieb am zuletzt editiert von taba_luga
                                          #148
                                          Die Datei
                                          ist nicht vorhanden. Das Verzeichnis existiert.
                                          Nachtrag: Den Adapter RFLink habe ich gar nicht mehr installiert. Kann ich das gesamte Verzeichnis
                                          iobroker.rflink
                                          mit Unterverzeichnissen einfach löschen?
                                          84.2k
