  4. vedirect -> USB an Victron MP2
64 Beiträge 6 Kommentatoren 7.6k Aufrufe 2 Beobachtet
  • Ralla66R Ralla66
    @dutchman
    bin aber mit admin und update noch uralt
    Log ist von einem SmartSolar charge controller MPPT 100/20 BT
     2022-06-13 19:09:49.035 - debug: vedirect.0 (1717) Redis Objects: Use Redis connection: 127.0.0.1:9001
    2022-06-13 19:09:49.091 - debug: vedirect.0 (1717) Objects client ready ... initialize now
    2022-06-13 19:09:49.097 - debug: vedirect.0 (1717) Objects create System PubSub Client
    2022-06-13 19:09:49.100 - debug: vedirect.0 (1717) Objects create User PubSub Client
    2022-06-13 19:09:49.102 - debug: vedirect.0 (1717) Objects client initialize lua scripts
    2022-06-13 19:09:49.122 - debug: vedirect.0 (1717) Objects connected to redis: 127.0.0.1:9001
    2022-06-13 19:09:49.136 - debug: vedirect.0 (1717) objectDB connected
    2022-06-13 19:09:49.140 - debug: vedirect.0 (1717) Redis States: Use Redis connection: 127.0.0.1:9000
    2022-06-13 19:09:49.153 - debug: vedirect.0 (1717) States create User PubSub Client
    2022-06-13 19:09:49.159 - debug: vedirect.0 (1717) States create System PubSub Client
    2022-06-13 19:09:49.173 - debug: vedirect.0 (1717) States connected to redis: 127.0.0.1:9000
    2022-06-13 19:09:49.175 - debug: vedirect.0 (1717) statesDB connected
    2022-06-13 19:09:49.837 - debug: vedirect.0 (1717) Plugin sentry Initialize Plugin (enabled=true)
    2022-06-13 19:09:50.253 - info: vedirect.0 (1717) starting. Version 0.1.2 in /opt/iobroker/node_modules/iobroker.vedirect, node: v12.20.1, js-controller: 3.1.6
    2022-06-13 19:09:50.437 - debug: vedirect.0 (1717) Line : �
    2022-06-13 19:09:50.440 - debug: vedirect.0 (1717) Line : PID 0xA060
    2022-06-13 19:09:50.443 - debug: vedirect.0 (1717) [stateSetCreate]PID with value : SmartSolar MPPT 100|20 48V
    2022-06-13 19:09:50.444 - debug: vedirect.0 (1717) An attribute has changed for : PID
    2022-06-13 19:09:50.454 - debug: vedirect.0 (1717) Line : FW 159
    2022-06-13 19:09:50.455 - debug: vedirect.0 (1717) No case matched for FW
    2022-06-13 19:09:50.456 - debug: vedirect.0 (1717) [stateSetCreate]FW with value : 159
    2022-06-13 19:09:50.458 - debug: vedirect.0 (1717) An attribute has changed for : FW
    2022-06-13 19:09:50.461 - debug: vedirect.0 (1717) Line : SER# HQ2121KRGMY
    2022-06-13 19:09:50.462 - debug: vedirect.0 (1717) No case matched for SER#
    2022-06-13 19:09:50.463 - debug: vedirect.0 (1717) [stateSetCreate]SER# with value : HQ2121KRGMY
    2022-06-13 19:09:50.463 - debug: vedirect.0 (1717) An attribute has changed for : SER#
    2022-06-13 19:09:50.480 - debug: vedirect.0 (1717) Line : V 12830
    2022-06-13 19:09:50.481 - debug: vedirect.0 (1717) [stateSetCreate]V with value : 12.83
    2022-06-13 19:09:50.483 - debug: vedirect.0 (1717) An attribute has changed for : V
    2022-06-13 19:09:50.486 - debug: vedirect.0 (1717) Line : I 0
    2022-06-13 19:09:50.488 - debug: vedirect.0 (1717) [stateSetCreate]I with value : 0
    2022-06-13 19:09:50.489 - debug: vedirect.0 (1717) An attribute has changed for : I
    2022-06-13 19:09:50.492 - debug: vedirect.0 (1717) Line : VPV 14470
    2022-06-13 19:09:50.494 - debug: vedirect.0 (1717) [stateSetCreate]VPV with value : 14.47
    2022-06-13 19:09:50.495 - debug: vedirect.0 (1717) An attribute has changed for : VPV
    2022-06-13 19:09:50.499 - debug: vedirect.0 (1717) Line : PPV 0
    2022-06-13 19:09:50.500 - debug: vedirect.0 (1717) No case matched for PPV
    2022-06-13 19:09:50.502 - debug: vedirect.0 (1717) [stateSetCreate]PPV with value : 0
    2022-06-13 19:09:50.503 - debug: vedirect.0 (1717) An attribute has changed for : PPV
    2022-06-13 19:09:50.530 - debug: vedirect.0 (1717) Line : CS 3
    2022-06-13 19:09:50.533 - debug: vedirect.0 (1717) Line : MPPT 2
    2022-06-13 19:09:50.536 - debug: vedirect.0 (1717) Line : OR 0x00000000
    2022-06-13 19:09:50.538 - debug: vedirect.0 (1717) Line : ERR 0
    2022-06-13 19:09:50.541 - debug: vedirect.0 (1717) Line : LOAD ON
    2022-06-13 19:09:50.542 - debug: vedirect.0 (1717) No case matched for LOAD
    2022-06-13 19:09:50.544 - debug: vedirect.0 (1717) [stateSetCreate]LOAD with value : ON
    2022-06-13 19:09:50.545 - debug: vedirect.0 (1717) An attribute has changed for : LOAD
    2022-06-13 19:09:50.549 - debug: vedirect.0 (1717) Line : IL 0
    2022-06-13 19:09:50.550 - debug: vedirect.0 (1717) [stateSetCreate]IL with value : 0
    2022-06-13 19:09:50.552 - debug: vedirect.0 (1717) An attribute has changed for : IL
    2022-06-13 19:09:50.555 - debug: vedirect.0 (1717) Line : H19 0
    2022-06-13 19:09:50.556 - debug: vedirect.0 (1717) [stateSetCreate]H19 with value : 0
    2022-06-13 19:09:50.558 - debug: vedirect.0 (1717) An attribute has changed for : H19
    2022-06-13 19:09:50.561 - debug: vedirect.0 (1717) Line : H20 0
    2022-06-13 19:09:50.562 - debug: vedirect.0 (1717) [stateSetCreate]H20 with value : 0
    2022-06-13 19:09:50.563 - debug: vedirect.0 (1717) An attribute has changed for : H20
    2022-06-13 19:09:50.566 - debug: vedirect.0 (1717) [stateSetCreate]CS with value : Bulk
    2022-06-13 19:09:50.568 - debug: vedirect.0 (1717) An attribute has changed for : CS
    2022-06-13 19:09:50.570 - debug: vedirect.0 (1717) [stateSetCreate]MPPT with value : MPP Tracker active
    2022-06-13 19:09:50.571 - debug: vedirect.0 (1717) An attribute has changed for : MPPT
    2022-06-13 19:09:50.574 - debug: vedirect.0 (1717) [stateSetCreate]ERR with value : No Error
    2022-06-13 19:09:50.576 - debug: vedirect.0 (1717) An attribute has changed for : ERR
    2022-06-13 19:09:50.577 - debug: vedirect.0 (1717) [stateSetCreate]OR with value : Normal Operation
    2022-06-13 19:09:50.578 - debug: vedirect.0 (1717) An attribute has changed for : OR
    2022-06-13 19:09:50.609 - debug: vedirect.0 (1717) Line : H21 0
    2022-06-13 19:09:50.611 - debug: vedirect.0 (1717) No case matched for H21
    2022-06-13 19:09:50.612 - debug: vedirect.0 (1717) [stateSetCreate]H21 with value : 0
    2022-06-13 19:09:50.613 - debug: vedirect.0 (1717) An attribute has changed for : H21
    2022-06-13 19:09:50.615 - debug: vedirect.0 (1717) Line : H22 0
    2022-06-13 19:09:50.616 - debug: vedirect.0 (1717) [stateSetCreate]H22 with value : 0
    2022-06-13 19:09:50.618 - debug: vedirect.0 (1717) An attribute has changed for : H22
    2022-06-13 19:09:50.620 - debug: vedirect.0 (1717) Line : H23 0
    2022-06-13 19:09:50.621 - debug: vedirect.0 (1717) No case matched for H23
    2022-06-13 19:09:50.622 - debug: vedirect.0 (1717) [stateSetCreate]H23 with value : 0
    2022-06-13 19:09:50.623 - debug: vedirect.0 (1717) An attribute has changed for : H23
    2022-06-13 19:09:50.626 - debug: vedirect.0 (1717) Line : HSDS 0
    2022-06-13 19:09:50.627 - debug: vedirect.0 (1717) No case matched for HSDS
    2022-06-13 19:09:50.628 - debug: vedirect.0 (1717) [stateSetCreate]HSDS with value : 0
    2022-06-13 19:09:50.629 - debug: vedirect.0 (1717) An attribute has changed for : HSDS
    2022-06-13 19:09:51.445 - debug: vedirect.0 (1717) Line : Checksum ~
    2022-06-13 19:09:51.448 - debug: vedirect.0 (1717) Line : PID 0xA060
    2022-06-13 19:09:51.451 - debug: vedirect.0 (1717) Line : FW 159
    2022-06-13 19:09:51.452 - debug: vedirect.0 (1717) No case matched for FW
    2022-06-13 19:09:51.454 - debug: vedirect.0 (1717) [stateSetCreate]FW with value : 159
    2022-06-13 19:09:51.455 - debug: vedirect.0 (1717) No attribute changes for : FW, processing normallly
    2022-06-13 19:09:51.458 - debug: vedirect.0 (1717) [stateSetCreate]PID with value : SmartSolar MPPT 100|20 48V
    2022-06-13 19:09:51.460 - debug: vedirect.0 (1717) No attribute changes for : PID, processing normallly
    2022-06-13 19:09:51.480 - debug: vedirect.0 (1717) Line : SER# HQ2121KRGMY
    2022-06-13 19:09:51.483 - debug: vedirect.0 (1717) No case matched for SER#
    2022-06-13 19:09:51.484 - debug: vedirect.0 (1717) [stateSetCreate]SER# with value : HQ2121KRGMY
    2022-06-13 19:09:51.486 - debug: vedirect.0 (1717) No attribute changes for : SER#, processing normallly
    2022-06-13 19:09:51.491 - debug: vedirect.0 (1717) Line : V 13120
    2022-06-13 19:09:51.492 - debug: vedirect.0 (1717) [stateSetCreate]V with value : 13.12
    2022-06-13 19:09:51.493 - debug: vedirect.0 (1717) No attribute changes for : V, processing normallly
    2022-06-13 19:09:51.499 - debug: vedirect.0 (1717) Line : I 0
    2022-06-13 19:09:51.501 - debug: vedirect.0 (1717) [stateSetCreate]I with value : 0
    2022-06-13 19:09:51.502 - debug: vedirect.0 (1717) No attribute changes for : I, processing normallly
    2022-06-13 19:09:51.530 - debug: vedirect.0 (1717) Line : VPV 14470
    2022-06-13 19:09:51.531 - debug: vedirect.0 (1717) [stateSetCreate]VPV with value : 14.47
    2022-06-13 19:09:51.533 - debug: vedirect.0 (1717) No attribute changes for : VPV, processing normallly
    2022-06-13 19:09:51.536 - debug: vedirect.0 (1717) Line : PPV 0
    2022-06-13 19:09:51.537 - debug: vedirect.0 (1717) No case matched for PPV
    2022-06-13 19:09:51.538 - debug: vedirect.0 (1717) [stateSetCreate]PPV with value : 0
    2022-06-13 19:09:51.540 - debug: vedirect.0 (1717) No attribute changes for : PPV, processing normallly
    2022-06-13 19:09:51.543 - debug: vedirect.0 (1717) Line : CS 3
    2022-06-13 19:09:51.545 - debug: vedirect.0 (1717) Line : MPPT 2
    2022-06-13 19:09:51.547 - debug: vedirect.0 (1717) Line : OR 0x00000000
    2022-06-13 19:09:51.549 - debug: vedirect.0 (1717) Line : ERR 0
    2022-06-13 19:09:51.551 - debug: vedirect.0 (1717) Line : LOAD ON
    2022-06-13 19:09:51.553 - debug: vedirect.0 (1717) No case matched for LOAD
    2022-06-13 19:09:51.554 - debug: vedirect.0 (1717) [stateSetCreate]LOAD with value : ON
    2022-06-13 19:09:51.555 - debug: vedirect.0 (1717) No attribute changes for : LOAD, processing normallly
    2022-06-13 19:09:51.557 - debug: vedirect.0 (1717) [stateSetCreate]CS with value : Bulk
    2022-06-13 19:09:51.558 - debug: vedirect.0 (1717) No attribute changes for : CS, processing normallly
    2022-06-13 19:09:51.560 - debug: vedirect.0 (1717) [stateSetCreate]MPPT with value : MPP Tracker active
    2022-06-13 19:09:51.561 - debug: vedirect.0 (1717) No attribute changes for : MPPT, processing normallly
    2022-06-13 19:09:51.563 - debug: vedirect.0 (1717) [stateSetCreate]ERR with value : No Error
    2022-06-13 19:09:51.565 - debug: vedirect.0 (1717) No attribute changes for : ERR, processing normallly
    2022-06-13 19:09:51.566 - debug: vedirect.0 (1717) [stateSetCreate]OR with value : Normal Operation
    2022-06-13 19:09:51.567 - debug: vedirect.0 (1717) No attribute changes for : OR, processing normallly
    2022-06-13 19:09:51.601 - debug: vedirect.0 (1717) Line : IL 0
    2022-06-13 19:09:51.602 - debug: vedirect.0 (1717) [stateSetCreate]IL with value : 0
    2022-06-13 19:09:51.603 - debug: vedirect.0 (1717) No attribute changes for : IL, processing normallly
    2022-06-13 19:09:51.606 - debug: vedirect.0 (1717) Line : H19 0
    2022-06-13 19:09:51.607 - debug: vedirect.0 (1717) [stateSetCreate]H19 with value : 0
    2022-06-13 19:09:51.608 - debug: vedirect.0 (1717) No attribute changes for : H19, processing normallly
    2022-06-13 19:09:51.610 - debug: vedirect.0 (1717) Line : H20 0
    2022-06-13 19:09:51.611 - debug: vedirect.0 (1717) [stateSetCreate]H20 with value : 0
    2022-06-13 19:09:51.612 - debug: vedirect.0 (1717) No attribute changes for : H20, processing normallly
    2022-06-13 19:09:51.615 - debug: vedirect.0 (1717) Line : H21 0
    2022-06-13 19:09:51.616 - debug: vedirect.0 (1717) No case matched for H21
    2022-06-13 19:09:51.617 - debug: vedirect.0 (1717) [stateSetCreate]H21 with value : 0
    2022-06-13 19:09:51.618 - debug: vedirect.0 (1717) No attribute changes for : H21, processing normallly
    2022-06-13 19:09:51.620 - debug: vedirect.0 (1717) Line : H22 0
    2022-06-13 19:09:51.621 - debug: vedirect.0 (1717) [stateSetCreate]H22 with value : 0
    2022-06-13 19:09:51.622 - debug: vedirect.0 (1717) No attribute changes for : H22, processing normallly
    2022-06-13 19:09:51.624 - debug: vedirect.0 (1717) Line : H23 0
    2022-06-13 19:09:51.625 - debug: vedirect.0 (1717) No case matched for H23
    2022-06-13 19:09:51.626 - debug: vedirect.0 (1717) [stateSetCreate]H23 with value : 0
    2022-06-13 19:09:51.626 - debug: vedirect.0 (1717) No attribute changes for : H23, processing normallly
    2022-06-13 19:09:51.628 - debug: vedirect.0 (1717) Line : HSDS 0
    2022-06-13 19:09:51.630 - debug: vedirect.0 (1717) No case matched for HSDS
    2022-06-13 19:09:51.630 - debug: vedirect.0 (1717) [stateSetCreate]HSDS with value : 0
    2022-06-13 19:09:51.631 - debug: vedirect.0 (1717) No attribute changes for : HSDS, processing normallly
    2022-06-13 19:09:52.437 - debug: vedirect.0 (1717) Line : Checksum �
    2022-06-13 19:09:52.452 - debug: vedirect.0 (1717) Line : PID 0xA060
    2022-06-13 19:09:52.455 - debug: vedirect.0 (1717) Line : FW 159
    2022-06-13 19:09:52.457 - debug: vedirect.0 (1717) No case matched for FW
    2022-06-13 19:09:52.458 - debug: vedirect.0 (1717) [stateSetCreate]FW with value : 159
    2022-06-13 19:09:52.459 - debug: vedirect.0 (1717) No attribute changes for : FW, processing normallly
    2022-06-13 19:09:52.462 - debug: vedirect.0 (1717) Line : SER# HQ2121KRGMY
    2022-06-13 19:09:52.463 - debug: vedirect.0 (1717) No case matched for SER#
    2022-06-13 19:09:52.465 - debug: vedirect.0 (1717) [stateSetCreate]SER# with value : HQ2121KRGMY
    2022-06-13 19:09:52.466 - debug: vedirect.0 (1717) No attribute changes for : SER#, processing normallly
    2022-06-13 19:09:52.468 - debug: vedirect.0 (1717) [stateSetCreate]PID with value : SmartSolar MPPT 100|20 48V
    2022-06-13 19:09:52.470 - debug: vedirect.0 (1717) No attribute changes for : PID, processing normallly
    2022-06-13 19:09:52.484 - debug: vedirect.0 (1717) Line : V 12890
    2022-06-13 19:09:52.486 - debug: vedirect.0 (1717) [stateSetCreate]V with value : 12.89
    2022-06-13 19:09:52.488 - debug: vedirect.0 (1717) No attribute changes for : V, processing normallly
    2022-06-13 19:09:52.492 - debug: vedirect.0 (1717) Line : I 0
    2022-06-13 19:09:52.493 - debug: vedirect.0 (1717) [stateSetCreate]I with value : 0
    2022-06-13 19:09:52.495 - debug: vedirect.0 (1717) No attribute changes for : I, processing normallly
    2022-06-13 19:09:52.498 - debug: vedirect.0 (1717) Line : VPV 14470
    2022-06-13 19:09:52.500 - debug: vedirect.0 (1717) [stateSetCreate]VPV with value : 14.47
    2022-06-13 19:09:52.502 - debug: vedirect.0 (1717) No attribute changes for : VPV, processing normallly
    2022-06-13 19:09:52.523 - debug: vedirect.0 (1717) Line : PPV 0
    2022-06-13 19:09:52.525 - debug: vedirect.0 (1717) No case matched for PPV
    2022-06-13 19:09:52.527 - debug: vedirect.0 (1717) [stateSetCreate]PPV with value : 0
    2022-06-13 19:09:52.529 - debug: vedirect.0 (1717) No attribute changes for : PPV, processing normallly
    2022-06-13 19:09:52.531 - debug: vedirect.0 (1717) Line : CS 3
    2022-06-13 19:09:52.533 - debug: vedirect.0 (1717) Line : MPPT 2
    2022-06-13 19:09:52.535 - debug: vedirect.0 (1717) Line : OR 0x00000000
    2022-06-13 19:09:52.536 - debug: vedirect.0 (1717) Line : ERR 0
    2022-06-13 19:09:52.538 - debug: vedirect.0 (1717) Line : LOAD ON
    2022-06-13 19:09:52.539 - debug: vedirect.0 (1717) No case matched for LOAD
    2022-06-13 19:09:52.540 - debug: vedirect.0 (1717) [stateSetCreate]LOAD with value : ON
    2022-06-13 19:09:52.541 - debug: vedirect.0 (1717) No attribute changes for : LOAD, processing normallly
    2022-06-13 19:09:52.542 - debug: vedirect.0 (1717) Line : IL 0
    2022-06-13 19:09:52.543 - debug: vedirect.0 (1717) [stateSetCreate]IL with value : 0
    2022-06-13 19:09:52.544 - debug: vedirect.0 (1717) No attribute changes for : IL, processing normallly
    2022-06-13 19:09:52.545 - debug: vedirect.0 (1717) Line : H19 0
    2022-06-13 19:09:52.546 - debug: vedirect.0 (1717) [stateSetCreate]H19 with value : 0
    2022-06-13 19:09:52.547 - debug: vedirect.0 (1717) No attribute changes for : H19, processing normallly
    2022-06-13 19:09:52.549 - debug: vedirect.0 (1717) [stateSetCreate]CS with value : Bulk
    2022-06-13 19:09:52.549 - debug: vedirect.0 (1717) No attribute changes for : CS, processing normallly
    2022-06-13 19:09:52.551 - debug: vedirect.0 (1717) [stateSetCreate]MPPT with value : MPP Tracker active
    2022-06-13 19:09:52.551 - debug: vedirect.0 (1717) No attribute changes for : MPPT, processing normallly
    2022-06-13 19:09:52.553 - debug: vedirect.0 (1717) [stateSetCreate]ERR with value : No Error
    2022-06-13 19:09:52.554 - debug: vedirect.0 (1717) No attribute changes for : ERR, processing normallly
    2022-06-13 19:09:52.555 - debug: vedirect.0 (1717) [stateSetCreate]OR with value : Normal Operation
    2022-06-13 19:09:52.556 - debug: vedirect.0 (1717) No attribute changes for : OR, processing normallly
    2022-06-13 19:09:52.583 - debug: vedirect.0 (1717) Line : H20 0
    2022-06-13 19:09:52.584 - debug: vedirect.0 (1717) [stateSetCreate]H20 with value : 0
    2022-06-13 19:09:52.585 - debug: vedirect.0 (1717) No attribute changes for : H20, processing normallly
    2022-06-13 19:09:52.587 - debug: vedirect.0 (1717) Line : H21 0
    2022-06-13 19:09:52.589 - debug: vedirect.0 (1717) No case matched for H21
    2022-06-13 19:09:52.590 - debug: vedirect.0 (1717) [stateSetCreate]H21 with value : 0
    2022-06-13 19:09:52.590 - debug: vedirect.0 (1717) No attribute changes for : H21, processing normallly
    2022-06-13 19:09:52.593 - debug: vedirect.0 (1717) Line : H22 0
    2022-06-13 19:09:52.594 - debug: vedirect.0 (1717) [stateSetCreate]H22 with value : 0
    2022-06-13 19:09:52.595 - debug: vedirect.0 (1717) No attribute changes for : H22, processing normallly
    2022-06-13 19:09:52.597 - debug: vedirect.0 (1717) Line : H23 0
    2022-06-13 19:09:52.598 - debug: vedirect.0 (1717) No case matched for H23
    2022-06-13 19:09:52.599 - debug: vedirect.0 (1717) [stateSetCreate]H23 with value : 0
    2022-06-13 19:09:52.600 - debug: vedirect.0 (1717) No attribute changes for : H23, processing normallly
    2022-06-13 19:09:52.602 - debug: vedirect.0 (1717) Line : HSDS 0
    2022-06-13 19:09:52.603 - debug: vedirect.0 (1717) No case matched for HSDS
    2022-06-13 19:09:52.604 - debug: vedirect.0 (1717) [stateSetCreate]HSDS with value : 0
    2022-06-13 19:09:52.605 - debug: vedirect.0 (1717) No attribute changes for : HSDS, processing normallly
    2022-06-13 19:09:53.445 - debug: vedirect.0 (1717) Line : Checksum x
    2022-06-13 19:09:53.448 - debug: vedirect.0 (1717) Line : PID 0xA060
    2022-06-13 19:09:53.451 - debug: vedirect.0 (1717) Line : FW 159
    2022-06-13 19:09:53.452 - debug: vedirect.0 (1717) No case matched for FW
    2022-06-13 19:09:53.454 - debug: vedirect.0 (1717) [stateSetCreate]FW with value : 159
    2022-06-13 19:09:53.455 - debug: vedirect.0 (1717) No attribute changes for : FW, processing normallly
    2022-06-13 19:09:53.457 - debug: vedirect.0 (1717) [stateSetCreate]PID with value : SmartSolar MPPT 100|20 48V
    2022-06-13 19:09:53.459 - debug: vedirect.0 (1717) No attribute changes for : PID, processing normallly
    2022-06-13 19:09:53.474 - debug: vedirect.0 (1717) Line : SER# HQ2121KRGMY
    2022-06-13 19:09:53.476 - debug: vedirect.0 (1717) No case matched for SER#
    2022-06-13 19:09:53.478 - debug: vedirect.0 (1717) [stateSetCreate]SER# with value : HQ2121KRGMY
    2022-06-13 19:09:53.480 - debug: vedirect.0 (1717) No attribute changes for : SER#, processing normallly
    2022-06-13 19:09:53.483 - debug: vedirect.0 (1717) Line : V 12590
    2022-06-13 19:09:53.485 - debug: vedirect.0 (1717) [stateSetCreate]V with value : 12.59
    2022-06-13 19:09:53.486 - debug: vedirect.0 (1717) No attribute changes for : V, processing normallly
    2022-06-13 19:09:53.489 - debug: vedirect.0 (1717) Line : I 0
    2022-06-13 19:09:53.490 - debug: vedirect.0 (1717) [stateSetCreate]I with value : 0
    2022-06-13 19:09:53.491 - debug: vedirect.0 (1717) No attribute changes for : I, processing normallly
    2022-06-13 19:09:53.512 - debug: vedirect.0 (1717) Line : VPV 14470
    2022-06-13 19:09:53.514 - debug: vedirect.0 (1717) [stateSetCreate]VPV with value : 14.47
    2022-06-13 19:09:53.515 - debug: vedirect.0 (1717) No attribute changes for : VPV, processing normallly
    2022-06-13 19:09:53.519 - debug: vedirect.0 (1717) Line : PPV 0
    2022-06-13 19:09:53.520 - debug: vedirect.0 (1717) No case matched for PPV
    2022-06-13 19:09:53.522 - debug: vedirect.0 (1717) [stateSetCreate]PPV with value : 0
    2022-06-13 19:09:53.523 - debug: vedirect.0 (1717) No attribute changes for : PPV, processing normallly
    2022-06-13 19:09:53.526 - debug: vedirect.0 (1717) Line : CS 3
    2022-06-13 19:09:53.529 - debug: vedirect.0 (1717) Line : MPPT 2
    2022-06-13 19:09:53.531 - debug: vedirect.0 (1717) Line : OR 0x00000000
    2022-06-13 19:09:53.533 - debug: vedirect.0 (1717) Line : ERR 0
    2022-06-13 19:09:53.536 - debug: vedirect.0 (1717) [stateSetCreate]CS with value : Bulk
    2022-06-13 19:09:53.537 - debug: vedirect.0 (1717) No attribute changes for : CS, processing normallly
    2022-06-13 19:09:53.539 - debug: vedirect.0 (1717) [stateSetCreate]MPPT with value : MPP Tracker active
    2022-06-13 19:09:53.540 - debug: vedirect.0 (1717) No attribute changes for : MPPT, processing normallly
    2022-06-13 19:09:53.542 - debug: vedirect.0 (1717) [stateSetCreate]ERR with value : No Error
    2022-06-13 19:09:53.544 - debug: vedirect.0 (1717) No attribute changes for : ERR, processing normallly
    2022-06-13 19:09:53.546 - debug: vedirect.0 (1717) [stateSetCreate]OR with value : Normal Operation
    2022-06-13 19:09:53.547 - debug: vedirect.0 (1717) No attribute changes for : OR, processing normallly
    2022-06-13 19:09:53.578 - debug: vedirect.0 (1717) Line : LOAD ON
    2022-06-13 19:09:53.579 - debug: vedirect.0 (1717) No case matched for LOAD
    2022-06-13 19:09:53.580 - debug: vedirect.0 (1717) [stateSetCreate]LOAD with value : ON
    2022-06-13 19:09:53.581 - debug: vedirect.0 (1717) No attribute changes for : LOAD, processing normallly
    2022-06-13 19:09:53.583 - debug: vedirect.0 (1717) Line : IL 0
    2022-06-13 19:09:53.584 - debug: vedirect.0 (1717) [stateSetCreate]IL with value : 0
    2022-06-13 19:09:53.585 - debug: vedirect.0 (1717) No attribute changes for : IL, processing normallly
    2022-06-13 19:09:53.588 - debug: vedirect.0 (1717) Line : H19 0
    2022-06-13 19:09:53.589 - debug: vedirect.0 (1717) [stateSetCreate]H19 with value : 0
    2022-06-13 19:09:53.590 - debug: vedirect.0 (1717) No attribute changes for : H19, processing normallly
    2022-06-13 19:09:53.592 - debug: vedirect.0 (1717) Line : H20 0
    2022-06-13 19:09:53.593 - debug: vedirect.0 (1717) [stateSetCreate]H20 with value : 0
    2022-06-13 19:09:53.594 - debug: vedirect.0 (1717) No attribute changes for : H20, processing normallly
    2022-06-13 19:09:53.598 - debug: vedirect.0 (1717) Line : H21 0
    2022-06-13 19:09:53.600 - debug: vedirect.0 (1717) No case matched for H21
    2022-06-13 19:09:53.601 - debug: vedirect.0 (1717) [stateSetCreate]H21 with value : 0
    2022-06-13 19:09:53.602 - debug: vedirect.0 (1717) No attribute changes for : H21, processing normallly
    2022-06-13 19:09:53.604 - debug: vedirect.0 (1717) Line : H22 0
    2022-06-13 19:09:53.605 - debug: vedirect.0 (1717) [stateSetCreate]H22 with value : 0
    2022-06-13 19:09:53.605 - debug: vedirect.0 (1717) No attribute changes for : H22, processing normallly
    2022-06-13 19:09:53.607 - debug: vedirect.0 (1717) Line : H23 0
    2022-06-13 19:09:53.608 - debug: vedirect.0 (1717) No case matched for H23
    2022-06-13 19:09:53.609 - debug: vedirect.0 (1717) [stateSetCreate]H23 with value : 0
    2022-06-13 19:09:53.609 - debug: vedirect.0 (1717) No attribute changes for : H23, processing normallly
    2022-06-13 19:09:53.611 - debug: vedirect.0 (1717) Line : HSDS 0
    2022-06-13 19:09:53.612 - debug: vedirect.0 (1717) No case matched for HSDS
    2022-06-13 19:09:53.612 - debug: vedirect.0 (1717) [stateSetCreate]HSDS with value : 0
    2022-06-13 19:09:53.619 - debug: vedirect.0 (1717) No attribute changes for : HSDS, processing normallly
    2022-06-13 19:09:54.438 - debug: vedirect.0 (1717) Line : Checksum {
    2022-06-13 19:09:54.454 - debug: vedirect.0 (1717) Line : PID 0xA060
    2022-06-13 19:09:54.457 - debug: vedirect.0 (1717) Line : FW 159
    2022-06-13 19:09:54.458 - debug: vedirect.0 (1717) No case matched for FW
    2022-06-13 19:09:54.459 - debug: vedirect.0 (1717) [stateSetCreate]FW with value : 159
    2022-06-13 19:09:54.460 - debug: vedirect.0 (1717) No attribute changes for : FW, processing normallly
    2022-06-13 19:09:54.462 - debug: vedirect.0 (1717) [stateSetCreate]PID with value : SmartSolar MPPT 100|20 48V
    2022-06-13 19:09:54.463 - debug: vedirect.0 (1717) No attribute changes for : PID, processing normallly
    2022-06-13 19:09:54.478 - debug: vedirect.0 (1717) Line : SER# HQ2121KRGMY
    2022-06-13 19:09:54.480 - debug: vedirect.0 (1717) No case matched for SER#
    2022-06-13 19:09:54.481 - debug: vedirect.0 (1717) [stateSetCreate]SER# with value : HQ2121KRGMY
    2022-06-13 19:09:54.482 - debug: vedirect.0 (1717) No attribute changes for : SER#, processing normallly
    2022-06-13 19:09:54.486 - debug: vedirect.0 (1717) Line : V 12470
    2022-06-13 19:09:54.487 - debug: vedirect.0 (1717) [stateSetCreate]V with value : 12.47
    2022-06-13 19:09:54.488 - debug: vedirect.0 (1717) No attribute changes for : V, processing normallly
    2022-06-13 19:09:54.490 - debug: vedirect.0 (1717) Line : I 0
    2022-06-13 19:09:54.491 - debug: vedirect.0 (1717) [stateSetCreate]I with value : 0
    2022-06-13 19:09:54.492 - debug: vedirect.0 (1717) No attribute changes for : I, processing normallly
    2022-06-13 19:09:54.493 - debug: vedirect.0 (1717) Line : VPV 14470
    2022-06-13 19:09:54.495 - debug: vedirect.0 (1717) [stateSetCreate]VPV with value : 14.47
    2022-06-13 19:09:54.495 - debug: vedirect.0 (1717) No attribute changes for : VPV, processing normallly
    2022-06-13 19:09:54.507 - debug: vedirect.0 (1717) Line : PPV 0
    2022-06-13 19:09:54.508 - debug: vedirect.0 (1717) No case matched for PPV
    2022-06-13 19:09:54.510 - debug: vedirect.0 (1717) [stateSetCreate]PPV with value : 0
    2022-06-13 19:09:54.511 - debug: vedirect.0 (1717) No attribute changes for : PPV, processing normallly
    2022-06-13 19:09:54.514 - debug: vedirect.0 (1717) Line : CS 3
    2022-06-13 19:09:54.516 - debug: vedirect.0 (1717) Line : MPPT 2
    2022-06-13 19:09:54.518 - debug: vedirect.0 (1717) [stateSetCreate]CS with value : Bulk
    2022-06-13 19:09:54.519 - debug: vedirect.0 (1717) No attribute changes for : CS, processing normallly
    2022-06-13 19:09:54.521 - debug: vedirect.0 (1717) [stateSetCreate]MPPT with value : MPP Tracker active
    2022-06-13 19:09:54.522 - debug: vedirect.0 (1717) No attribute changes for : MPPT, processing normallly
    2022-06-13 19:09:54.540 - debug: vedirect.0 (1717) Line : OR 0x00000000
    2022-06-13 19:09:54.543 - debug: vedirect.0 (1717) Line : ERR 0
    2022-06-13 19:09:54.545 - debug: vedirect.0 (1717) Line : LOAD ON
    2022-06-13 19:09:54.546 - debug: vedirect.0 (1717) No case matched for LOAD
    2022-06-13 19:09:54.547 - debug: vedirect.0 (1717) [stateSetCreate]LOAD with value : ON
    2022-06-13 19:09:54.549 - debug: vedirect.0 (1717) No attribute changes for : LOAD, processing normallly
    2022-06-13 19:09:54.551 - debug: vedirect.0 (1717) Line : IL 0
    2022-06-13 19:09:54.552 - debug: vedirect.0 (1717) [stateSetCreate]IL with value : 0
    2022-06-13 19:09:54.556 - debug: vedirect.0 (1717) No attribute changes for : IL, processing normallly
    2022-06-13 19:09:54.559 - debug: vedirect.0 (1717) Line : H19 0
    2022-06-13 19:09:54.560 - debug: vedirect.0 (1717) [stateSetCreate]H19 with value : 0
    2022-06-13 19:09:54.561 - debug: vedirect.0 (1717) No attribute changes for : H19, processing normallly
    2022-06-13 19:09:54.563 - debug: vedirect.0 (1717) Line : H20 0
    2022-06-13 19:09:54.565 - debug: vedirect.0 (1717) [stateSetCreate]H20 with value : 0
    2022-06-13 19:09:54.566 - debug: vedirect.0 (1717) No attribute changes for : H20, processing normallly
    2022-06-13 19:09:54.568 - debug: vedirect.0 (1717) Line : H21 0
    2022-06-13 19:09:54.569 - debug: vedirect.0 (1717) No case matched for H21
    2022-06-13 19:09:54.569 - debug: vedirect.0 (1717) [stateSetCreate]H21 with value : 0
    2022-06-13 19:09:54.570 - debug: vedirect.0 (1717) No attribute changes for : H21, processing normallly
    2022-06-13 19:09:54.572 - debug: vedirect.0 (1717) Line : H22 0
    2022-06-13 19:09:54.573 - debug: vedirect.0 (1717) [stateSetCreate]H22 with value : 0
    2022-06-13 19:09:54.574 - debug: vedirect.0 (1717) No attribute changes for : H22, processing normallly
    2022-06-13 19:09:54.576 - debug: vedirect.0 (1717) Line : H23 0
    2022-06-13 19:09:54.577 - debug: vedirect.0 (1717) No case matched for H23
    2022-06-13 19:09:54.578 - debug: vedirect.0 (1717) [stateSetCreate]H23 with value : 0
    2022-06-13 19:09:54.578 - debug: vedirect.0 (1717) No attribute changes for : H23, processing normallly
    2022-06-13 19:09:54.581 - debug: vedirect.0 (1717) [stateSetCreate]ERR with value : No Error
    2022-06-13 19:09:54.582 - debug: vedirect.0 (1717) No attribute changes for : ERR, processing normallly
    2022-06-13 19:09:54.583 - debug: vedirect.0 (1717) [stateSetCreate]OR with value : Normal Operation
    2022-06-13 19:09:54.584 - debug: vedirect.0 (1717) No attribute changes for : OR, processing normallly
    2022-06-13 19:09:54.611 - debug: vedirect.0 (1717) Line : HSDS 0
    2022-06-13 19:09:54.612 - debug: vedirect.0 (1717) No case matched for HSDS
    2022-06-13 19:09:54.613 - debug: vedirect.0 (1717) [stateSetCreate]HSDS with value : 0
    2022-06-13 19:09:54.614 - debug: vedirect.0 (1717) No attribute changes for : HSDS, processing normallly
    2022-06-13 19:09:55.446 - debug: vedirect.0 (1717) Line : Checksum ~
    2022-06-13 19:09:55.448 - debug: vedirect.0 (1717) Line : PID 0xA060
    2022-06-13 19:09:55.451 - debug: vedirect.0 (1717) [stateSetCreate]PID with value : SmartSolar MPPT 100|20 48V
    2022-06-13 19:09:55.452 - debug: vedirect.0 (1717) No attribute changes for : PID, processing normallly
    2022-06-13 19:09:55.462 - debug: vedirect.0 (1717) Line : FW 159
    2022-06-13 19:09:55.464 - debug: vedirect.0 (1717) No case matched for FW
    2022-06-13 19:09:55.465 - debug: vedirect.0 (1717) [stateSetCreate]FW with value : 159
    2022-06-13 19:09:55.467 - debug: vedirect.0 (1717) No attribute changes for : FW, processing normallly
    2022-06-13 19:09:55.472 - debug: vedirect.0 (1717) Line : SER# HQ2121KRGMY
    2022-06-13 19:09:55.473 - debug: vedirect.0 (1717) No case matched for SER#
    2022-06-13 19:09:55.474 - debug: vedirect.0 (1717) [stateSetCreate]SER# with value : HQ2121KRGMY
    2022-06-13 19:09:55.475 - debug: vedirect.0 (1717) No attribute changes for : SER#, processing normallly
    2022-06-13 19:09:55.480 - debug: vedirect.0 (1717) Line : V 12530
    2022-06-13 19:09:55.482 - debug: vedirect.0 (1717) [stateSetCreate]V with value : 12.53
    2022-06-13 19:09:55.483 - debug: vedirect.0 (1717) No attribute changes for : V, processing normallly
    2022-06-13 19:09:55.509 - debug: vedirect.0 (1717) Line : I 0
    2022-06-13 19:09:55.510 - debug: vedirect.0 (1717) [stateSetCreate]I with value : 0
    2022-06-13 19:09:55.511 - debug: vedirect.0 (1717) No attribute changes for : I, processing normallly
    2022-06-13 19:09:55.514 - debug: vedirect.0 (1717) Line : VPV 14470
    2022-06-13 19:09:55.515 - debug: vedirect.0 (1717) [stateSetCreate]VPV with value : 14.47
    2022-06-13 19:09:55.516 - debug: vedirect.0 (1717) No attribute changes for : VPV, processing normallly
    2022-06-13 19:09:55.518 - debug: vedirect.0 (1717) Line : PPV 0
    2022-06-13 19:09:55.519 - debug: vedirect.0 (1717) No case matched for PPV
    2022-06-13 19:09:55.520 - debug: vedirect.0 (1717) [stateSetCreate]PPV with value : 0
    2022-06-13 19:09:55.520 - debug: vedirect.0 (1717) No attribute changes for : PPV, processing normallly
    2022-06-13 19:09:55.522 - debug: vedirect.0 (1717) Line : CS 3
    2022-06-13 19:09:55.524 - debug: vedirect.0 (1717) [stateSetCreate]CS with value : Bulk
    2022-06-13 19:09:55.525 - debug: vedirect.0 (1717) No attribute changes for : CS, processing normallly
    2022-06-13 19:09:55.550 - debug: vedirect.0 (1717) Line : MPPT 2
    2022-06-13 19:09:55.552 - debug: vedirect.0 (1717) Line : OR 0x00000000
    2022-06-13 19:09:55.554 - debug: vedirect.0 (1717) Line : ERR 0
    2022-06-13 19:09:55.556 - debug: vedirect.0 (1717) Line : LOAD ON
    2022-06-13 19:09:55.557 - debug: vedirect.0 (1717) No case matched for LOAD
    2022-06-13 19:09:55.558 - debug: vedirect.0 (1717) [stateSetCreate]LOAD with value : ON
    2022-06-13 19:09:55.559 - debug: vedirect.0 (1717) No attribute changes for : LOAD, processing normallly
    2022-06-13 19:09:55.561 - debug: vedirect.0 (1717) Line : IL 0
    2022-06-13 19:09:55.562 - debug: vedirect.0 (1717) [stateSetCreate]IL with value : 0
    2022-06-13 19:09:55.563 - debug: vedirect.0 (1717) No attribute changes for : IL, processing normallly
    2022-06-13 19:09:55.565 - debug: vedirect.0 (1717) Line : H19 0
    2022-06-13 19:09:55.567 - debug: vedirect.0 (1717) [stateSetCreate]H19 with value : 0
    2022-06-13 19:09:55.567 - debug: vedirect.0 (1717) No attribute changes for : H19, processing normallly
    2022-06-13 19:09:55.570 - debug: vedirect.0 (1717) Line : H20 0
    2022-06-13 19:09:55.571 - debug: vedirect.0 (1717) [stateSetCreate]H20 with value : 0
    2022-06-13 19:09:55.571 - debug: vedirect.0 (1717) No attribute changes for : H20, processing normallly
    2022-06-13 19:09:55.573 - debug: vedirect.0 (1717) Line : H21 0
    2022-06-13 19:09:55.574 - debug: vedirect.0 (1717) No case matched for H21
    2022-06-13 19:09:55.575 - debug: vedirect.0 (1717) [stateSetCreate]H21 with value : 0
    2022-06-13 19:09:55.575 - debug: vedirect.0 (1717) No attribute changes for : H21, processing normallly
    2022-06-13 19:09:55.577 - debug: vedirect.0 (1717) Line : H22 0
    2022-06-13 19:09:55.578 - debug: vedirect.0 (1717) [stateSetCreate]H22 with value : 0
    2022-06-13 19:09:55.579 - debug: vedirect.0 (1717) No attribute changes for : H22, processing normallly
    2022-06-13 19:09:55.581 - debug: vedirect.0 (1717) Line : H23 0
    2022-06-13 19:09:55.582 - debug: vedirect.0 (1717) No case matched for H23
    2022-06-13 19:09:55.582 - debug: vedirect.0 (1717) [stateSetCreate]H23 with value : 0
    2022-06-13 19:09:55.583 - debug: vedirect.0 (1717) No attribute changes for : H23, processing normallly
    2022-06-13 19:09:55.584 - debug: vedirect.0 (1717) Line : HSDS 0
    2022-06-13 19:09:55.585 - debug: vedirect.0 (1717) No case matched for HSDS
    2022-06-13 19:09:55.586 - debug: vedirect.0 (1717) [stateSetCreate]HSDS with value : 0
    2022-06-13 19:09:55.587 - debug: vedirect.0 (1717) No attribute changes for : HSDS, processing normallly
    2022-06-13 19:09:55.589 - debug: vedirect.0 (1717) [stateSetCreate]MPPT with value : MPP Tracker active
    2022-06-13 19:09:55.589 - debug: vedirect.0 (1717) No attribute changes for : MPPT, processing normallly
    2022-06-13 19:09:55.591 - debug: vedirect.0 (1717) [stateSetCreate]ERR with value : No Error
    2022-06-13 19:09:55.592 - debug: vedirect.0 (1717) No attribute changes for : ERR, processing normallly
    2022-06-13 19:09:55.593 - debug: vedirect.0 (1717) [stateSetCreate]OR with value : Normal Operation
    2022-06-13 19:09:55.594 - debug: vedirect.0 (1717) No attribute changes for : OR, processing normallly
    2022-06-13 19:09:56.455 - debug: vedirect.0 (1717) Line : Checksum �
    2022-06-13 19:09:56.458 - debug: vedirect.0 (1717) Line : PID 0xA060
    2022-06-13 19:09:56.460 - debug: vedirect.0 (1717) Line : FW 159
    2022-06-13 19:09:56.461 - debug: vedirect.0 (1717) No case matched for FW
    2022-06-13 19:09:56.461 - debug: vedirect.0 (1717) [stateSetCreate]FW with value : 159
    2022-06-13 19:09:56.462 - debug: vedirect.0 (1717) No attribute changes for : FW, processing normallly
    2022-06-13 19:09:56.464 - debug: vedirect.0 (1717) [stateSetCreate]PID with value : SmartSolar MPPT 100|20 48V
    2022-06-13 19:09:56.466 - debug: vedirect.0 (1717) No attribute changes for : PID, processing normallly
    2022-06-13 19:09:56.487 - debug: vedirect.0 (1717) Line : SER# HQ2121KRGMY
    2022-06-13 19:09:56.489 - debug: vedirect.0 (1717) No case matched for SER#
    2022-06-13 19:09:56.490 - debug: vedirect.0 (1717) [stateSetCreate]SER# with value : HQ2121KRGMY
    2022-06-13 19:09:56.492 - debug: vedirect.0 (1717) No attribute changes for : SER#, processing normallly
    2022-06-13 19:09:56.496 - debug: vedirect.0 (1717) Line : V 12610
    2022-06-13 19:09:56.499 - debug: vedirect.0 (1717) [stateSetCreate]V with value : 12.61
    2022-06-13 19:09:56.500 - debug: vedirect.0 (1717) No attribute changes for : V, processing normallly
    2022-06-13 19:09:56.503 - debug: vedirect.0 (1717) Line : I 0
    2022-06-13 19:09:56.505 - debug: vedirect.0 (1717) [stateSetCreate]I with value : 0
    2022-06-13 19:09:56.506 - debug: vedirect.0 (1717) No attribute changes for : I, processing normallly
    2022-06-13 19:09:56.508 - debug: vedirect.0 (1717) Line : VPV 14470
    2022-06-13 19:09:56.510 - debug: vedirect.0 (1717) [stateSetCreate]VPV with value : 14.47
    2022-06-13 19:09:56.511 - debug: vedirect.0 (1717) No attribute changes for : VPV, processing normallly
    2022-06-13 19:09:56.513 - debug: vedirect.0 (1717) Line : PPV 0
    2022-06-13 19:09:56.515 - debug: vedirect.0 (1717) No case matched for PPV
    2022-06-13 19:09:56.516 - debug: vedirect.0 (1717) [stateSetCreate]PPV with value : 0
    2022-06-13 19:09:56.516 - debug: vedirect.0 (1717) No attribute changes for : PPV, processing normallly
    2022-06-13 19:09:56.519 - debug: vedirect.0 (1717) Line : CS 3
    2022-06-13 19:09:56.522 - debug: vedirect.0 (1717) Line : MPPT 2
    2022-06-13 19:09:56.524 - debug: vedirect.0 (1717) [stateSetCreate]CS with value : Bulk
    2022-06-13 19:09:56.525 - debug: vedirect.0 (1717) No attribute changes for : CS, processing normallly
    2022-06-13 19:09:56.528 - debug: vedirect.0 (1717) [stateSetCreate]MPPT with value : MPP Tracker active
    2022-06-13 19:09:56.529 - debug: vedirect.0 (1717) No attribute changes for : MPPT, processing normallly
    2022-06-13 19:09:56.543 - debug: vedirect.0 (1717) Line : OR 0x00000000
    2022-06-13 19:09:56.545 - debug: vedirect.0 (1717) Line : ERR 0
    2022-06-13 19:09:56.547 - debug: vedirect.0 (1717) Line : LOAD ON
    2022-06-13 19:09:56.548 - debug: vedirect.0 (1717) No case matched for LOAD
    2022-06-13 19:09:56.549 - debug: vedirect.0 (1717) [stateSetCreate]LOAD with value : ON
    2022-06-13 19:09:56.551 - debug: vedirect.0 (1717) No attribute changes for : LOAD, processing normallly
    2022-06-13 19:09:56.553 - debug: vedirect.0 (1717) Line : IL 0
    2022-06-13 19:09:56.554 - debug: vedirect.0 (1717) [stateSetCreate]IL with value : 0
    2022-06-13 19:09:56.555 - debug: vedirect.0 (1717) No attribute changes for : IL, processing normallly
    2022-06-13 19:09:56.558 - debug: vedirect.0 (1717) Line : H19 0
    2022-06-13 19:09:56.559 - debug: vedirect.0 (1717) [stateSetCreate]H19 with value : 0
    2022-06-13 19:09:56.560 - debug: vedirect.0 (1717) No attribute changes for : H19, processing normallly
    2022-06-13 19:09:56.561 - debug: vedirect.0 (1717) Line : H20 0
    2022-06-13 19:09:56.562 - debug: vedirect.0 (1717) [stateSetCreate]H20 with value : 0
    2022-06-13 19:09:56.563 - debug: vedirect.0 (1717) No attribute changes for : H20, processing normallly
    2022-06-13 19:09:56.564 - debug: vedirect.0 (1717) Line : H21 0
    2022-06-13 19:09:56.565 - debug: vedirect.0 (1717) No case matched for H21
    2022-06-13 19:09:56.566 - debug: vedirect.0 (1717) [stateSetCreate]H21 with value : 0
    2022-06-13 19:09:56.566 - debug: vedirect.0 (1717) No attribute changes for : H21, processing normallly
    2022-06-13 19:09:56.568 - debug: vedirect.0 (1717) Line : H22 0
    2022-06-13 19:09:56.569 - debug: vedirect.0 (1717) [stateSetCreate]H22 with value : 0
    2022-06-13 19:09:56.569 - debug: vedirect.0 (1717) No attribute changes for : H22, processing normallly
    2022-06-13 19:09:56.571 - debug: vedirect.0 (1717) [stateSetCreate]ERR with value : No Error
    2022-06-13 19:09:56.572 - debug: vedirect.0 (1717) No attribute changes for : ERR, processing normallly
    2022-06-13 19:09:56.573 - debug: vedirect.0 (1717) [stateSetCreate]OR with value : Normal Operation
    2022-06-13 19:09:56.574 - debug: vedirect.0 (1717) No attribute changes for : OR, processing normallly
    2022-06-13 19:09:56.593 - debug: vedirect.0 (1717) Line : H23 0
    2022-06-13 19:09:56.594 - debug: vedirect.0 (1717) No case matched for H23
    2022-06-13 19:09:56.595 - debug: vedirect.0 (1717) [stateSetCreate]H23 with value : 0
    2022-06-13 19:09:56.596 - debug: vedirect.0 (1717) No attribute changes for : H23, processing normallly
    2022-06-13 19:09:56.597 - debug: vedirect.0 (1717) Line : HSDS 0
    2022-06-13 19:09:56.598 - debug: vedirect.0 (1717) No case matched for HSDS
    2022-06-13 19:09:56.600 - debug: vedirect.0 (1717) [stateSetCreate]HSDS with value : 0
    2022-06-13 19:09:56.601 - debug: vedirect.0 (1717) No attribute changes for : HSDS, processing normallly
    2022-06-13 19:09:57.448 - debug: vedirect.0 (1717) Line : Checksum �
    2022-06-13 19:09:57.450 - debug: vedirect.0 (1717) Line : PID 0xA060
    2022-06-13 19:09:57.453 - debug: vedirect.0 (1717) [stateSetCreate]PID with value : SmartSolar MPPT 100|20 48V
    2022-06-13 19:09:57.454 - debug: vedirect.0 (1717) No attribute changes for : PID, processing normallly
    2022-06-13 19:09:57.467 - debug: vedirect.0 (1717) Line : FW 159
    2022-06-13 19:09:57.469 - debug: vedirect.0 (1717) No case matched for FW
    2022-06-13 19:09:57.471 - debug: vedirect.0 (1717) [stateSetCreate]FW with value : 159
    2022-06-13 19:09:57.472 - debug: vedirect.0 (1717) No attribute changes for : FW, processing normallly
    2022-06-13 19:09:57.475 - debug: vedirect.0 (1717) Line : SER# HQ2121KRGMY
    2022-06-13 19:09:57.476 - debug: vedirect.0 (1717) No case matched for SER#
    2022-06-13 19:09:57.477 - debug: vedirect.0 (1717) [stateSetCreate]SER# with value : HQ2121KRGMY
    2022-06-13 19:09:57.478 - debug: vedirect.0 (1717) No attribute changes for : SER#, processing normallly
    2022-06-13 19:09:57.486 - debug: vedirect.0 (1717) Line : V 12700
    2022-06-13 19:09:57.488 - debug: vedirect.0 (1717) [stateSetCreate]V with value : 12.7
    2022-06-13 19:09:57.491 - debug: vedirect.0 (1717) No attribute changes for : V, processing normallly
    2022-06-13 19:09:57.494 - debug: vedirect.0 (1717) Line : I 0
    2022-06-13 19:09:57.496 - debug: vedirect.0 (1717) [stateSetCreate]I with value : 0
    2022-06-13 19:09:57.497 - debug: vedirect.0 (1717) No attribute changes for : I, processing normallly
    2022-06-13 19:09:57.500 - debug: vedirect.0 (1717) Line : VPV 14470
    2022-06-13 19:09:57.501 - debug: vedirect.0 (1717) [stateSetCreate]VPV with value : 14.47
    2022-06-13 19:09:57.502 - debug: vedirect.0 (1717) No attribute changes for : VPV, processing normallly
    2022-06-13 19:09:57.505 - debug: vedirect.0 (1717) Line : PPV 0
    2022-06-13 19:09:57.506 - debug: vedirect.0 (1717) No case matched for PPV
    2022-06-13 19:09:57.507 - debug: vedirect.0 (1717) [stateSetCreate]PPV with value : 0
    2022-06-13 19:09:57.508 - debug: vedirect.0 (1717) No attribute changes for : PPV, processing normallly
    2022-06-13 19:09:57.526 - debug: vedirect.0 (1717) Line : CS 3
    2022-06-13 19:09:57.528 - debug: vedirect.0 (1717) Line : MPPT 2
    2022-06-13 19:09:57.530 - debug: vedirect.0 (1717) Line : OR 0x00000000
    2022-06-13 19:09:57.533 - debug: vedirect.0 (1717) [stateSetCreate]CS with value : Bulk
    2022-06-13 19:09:57.534 - debug: vedirect.0 (1717) No attribute changes for : CS, processing normallly
    2022-06-13 19:09:57.538 - debug: vedirect.0 (1717) [stateSetCreate]MPPT with value : MPP Tracker active
    2022-06-13 19:09:57.540 - debug: vedirect.0 (1717) No attribute changes for : MPPT, processing normallly
    2022-06-13 19:09:57.544 - debug: vedirect.0 (1717) [stateSetCreate]OR with value : Normal Operation
    2022-06-13 19:09:57.545 - debug: vedirect.0 (1717) No attribute changes for : OR, processing normallly
    2022-06-13 19:09:57.564 - debug: vedirect.0 (1717) Line : ERR 0
    2022-06-13 19:09:57.567 - debug: vedirect.0 (1717) Line : LOAD ON
    2022-06-13 19:09:57.568 - debug: vedirect.0 (1717) No case matched for LOAD
    2022-06-13 19:09:57.570 - debug: vedirect.0 (1717) [stateSetCreate]LOAD with value : ON
    2022-06-13 19:09:57.572 - debug: vedirect.0 (1717) No attribute changes for : LOAD, processing normallly
    2022-06-13 19:09:57.574 - debug: vedirect.0 (1717) Line : IL 0
    2022-06-13 19:09:57.575 - debug: vedirect.0 (1717) [stateSetCreate]IL with value : 0
    2022-06-13 19:09:57.576 - debug: vedirect.0 (1717) No attribute changes for : IL, processing normallly
    2022-06-13 19:09:57.578 - debug: vedirect.0 (1717) Line : H19 0
    2022-06-13 19:09:57.579 - debug: vedirect.0 (1717) [stateSetCreate]H19 with value : 0
    2022-06-13 19:09:57.579 - debug: vedirect.0 (1717) No attribute changes for : H19, processing normallly
    2022-06-13 19:09:57.581 - debug: vedirect.0 (1717) Line : H20 0
    2022-06-13 19:09:57.582 - debug: vedirect.0 (1717) [stateSetCreate]H20 with value : 0
    2022-06-13 19:09:57.582 - debug: vedirect.0 (1717) No attribute changes for : H20, processing normallly
    2022-06-13 19:09:57.584 - debug: vedirect.0 (1717) Line : H21 0
    2022-06-13 19:09:57.585 - debug: vedirect.0 (1717) No case matched for H21
    2022-06-13 19:09:57.585 - debug: vedirect.0 (1717) [stateSetCreate]H21 with value : 0
    2022-06-13 19:09:57.585 - debug: vedirect.0 (1717) No attribute changes for : H21, processing normallly
    2022-06-13 19:09:57.587 - debug: vedirect.0 (1717) Line : H22 0
    2022-06-13 19:09:57.588 - debug: vedirect.0 (1717) [stateSetCreate]H22 with value : 0
    2022-06-13 19:09:57.588 - debug: vedirect.0 (1717) No attribute changes for : H22, processing normallly
    2022-06-13 19:09:57.590 - debug: vedirect.0 (1717) Line : H23 0
    2022-06-13 19:09:57.591 - debug: vedirect.0 (1717) No case matched for H23
    2022-06-13 19:09:57.591 - debug: vedirect.0 (1717) [stateSetCreate]H23 with value : 0
    2022-06-13 19:09:57.592 - debug: vedirect.0 (1717) No attribute changes for : H23, processing normallly
    2022-06-13 19:09:57.593 - debug: vedirect.0 (1717) Line : HSDS 0
    2022-06-13 19:09:57.594 - debug: vedirect.0 (1717) No case matched for HSDS
    2022-06-13 19:09:57.595 - debug: vedirect.0 (1717) [stateSetCreate]HSDS with value : 0
    2022-06-13 19:09:57.595 - debug: vedirect.0 (1717) No attribute changes for : HSDS, processing normallly
    2022-06-13 19:09:57.596 - debug: vedirect.0 (1717) [stateSetCreate]ERR with value : No Error
    2022-06-13 19:09:57.597 - debug: vedirect.0 (1717) No attribute changes for : ERR, processing normallly
    2022-06-13 19:09:58.455 - debug: vedirect.0 (1717) Line : Checksum �
    2022-06-13 19:09:58.458 - debug: vedirect.0 (1717) Line : PID 0xA060
    2022-06-13 19:09:58.459 - debug: vedirect.0 (1717) Line : FW 159
    2022-06-13 19:09:58.461 - debug: vedirect.0 (1717) No case matched for FW
    2022-06-13 19:09:58.461 - debug: vedirect.0 (1717) [stateSetCreate]FW with value : 159
    2022-06-13 19:09:58.462 - debug: vedirect.0 (1717) No attribute changes for : FW, processing normallly
    2022-06-13 19:09:58.464 - debug: vedirect.0 (1717) [stateSetCreate]PID with value : SmartSolar MPPT 100|20 48V
    2022-06-13 19:09:58.465 - debug: vedirect.0 (1717) No attribute changes for : PID, processing normallly
    2022-06-13 19:09:58.474 - debug: vedirect.0 (1717) Line : SER# HQ2121KRGMY
    2022-06-13 19:09:58.478 - debug: vedirect.0 (1717) No case matched for SER#
    2022-06-13 19:09:58.480 - debug: vedirect.0 (1717) [stateSetCreate]SER# with value : HQ2121KRGMY
    2022-06-13 19:09:58.481 - debug: vedirect.0 (1717) No attribute changes for : SER#, processing normallly
    2022-06-13 19:09:58.484 - debug: vedirect.0 (1717) Line : V 12760
    2022-06-13 19:09:58.485 - debug: vedirect.0 (1717) [stateSetCreate]V with value : 12.76
    2022-06-13 19:09:58.486 - debug: vedirect.0 (1717) No attribute changes for : V, processing normallly
    2022-06-13 19:09:58.488 - debug: vedirect.0 (1717) Line : I 0
    2022-06-13 19:09:58.489 - debug: vedirect.0 (1717) [stateSetCreate]I with value : 0
    2022-06-13 19:09:58.490 - debug: vedirect.0 (1717) No attribute changes for : I, processing normallly
    2022-06-13 19:09:58.495 - debug: vedirect.0 (1717) Line : VPV 14470
    2022-06-13 19:09:58.496 - debug: vedirect.0 (1717) [stateSetCreate]VPV with value : 14.47
    2022-06-13 19:09:58.496 - debug: vedirect.0 (1717) No attribute changes for : VPV, processing normallly
    2022-06-13 19:09:58.498 - debug: vedirect.0 (1717) Line : PPV 0
    2022-06-13 19:09:58.499 - debug: vedirect.0 (1717) No case matched for PPV
    2022-06-13 19:09:58.501 - debug: vedirect.0 (1717) [stateSetCreate]PPV with value : 0
    2022-06-13 19:09:58.501 - debug: vedirect.0 (1717) No attribute changes for : PPV, processing normallly
    2022-06-13 19:09:58.503 - debug: vedirect.0 (1717) Line : CS 3
    2022-06-13 19:09:58.505 - debug: vedirect.0 (1717) Line : MPPT 2
    2022-06-13 19:09:58.507 - debug: vedirect.0 (1717) [stateSetCreate]CS with value : Bulk
    2022-06-13 19:09:58.508 - debug: vedirect.0 (1717) No attribute changes for : CS, processing normallly
    2022-06-13 19:09:58.509 - debug: vedirect.0 (1717) [stateSetCreate]MPPT with value : MPP Tracker active
    2022-06-13 19:09:58.510 - debug: vedirect.0 (1717) No attribute changes for : MPPT, processing normallly
    2022-06-13 19:09:58.526 - debug: vedirect.0 (1717) Line : OR 0x00000000
    2022-06-13 19:09:58.528 - debug: vedirect.0 (1717) Line : ERR 0
    2022-06-13 19:09:58.529 - debug: vedirect.0 (1717) Line : LOAD ON
    2022-06-13 19:09:58.530 - debug: vedirect.0 (1717) No case matched for LOAD
    2022-06-13 19:09:58.531 - debug: vedirect.0 (1717) [stateSetCreate]LOAD with value : ON
    2022-06-13 19:09:58.532 - debug: vedirect.0 (1717) No attribute changes for : LOAD, processing normallly
    2022-06-13 19:09:58.534 - debug: vedirect.0 (1717) [stateSetCreate]ERR with value : No Error
    2022-06-13 19:09:58.535 - debug: vedirect.0 (1717) No attribute changes for : ERR, processing normallly
    2022-06-13 19:09:58.536 - debug: vedirect.0 (1717) [stateSetCreate]OR with value : Normal Operation
    2022-06-13 19:09:58.537 - debug: vedirect.0 (1717) No attribute changes for : OR, processing normallly
    2022-06-13 19:09:58.546 - debug: vedirect.0 (1717) Line : IL 0
    2022-06-13 19:09:58.547 - debug: vedirect.0 (1717) [stateSetCreate]IL with value : 0
    2022-06-13 19:09:58.548 - debug: vedirect.0 (1717) No attribute changes for : IL, processing normallly
    2022-06-13 19:09:58.551 - debug: vedirect.0 (1717) Line : H19 0
    2022-06-13 19:09:58.552 - debug: vedirect.0 (1717) [stateSetCreate]H19 with value : 0
    2022-06-13 19:09:58.553 - debug: vedirect.0 (1717) No attribute changes for : H19, processing normallly
    2022-06-13 19:09:58.556 - debug: vedirect.0 (1717) Line : H20 0
    2022-06-13 19:09:58.556 - debug: vedirect.0 (1717) [stateSetCreate]H20 with value : 0
    2022-06-13 19:09:58.560 - debug: vedirect.0 (1717) No attribute changes for : H20, processing normallly
    2022-06-13 19:09:58.563 - debug: vedirect.0 (1717) Line : H21 0
    2022-06-13 19:09:58.564 - debug: vedirect.0 (1717) No case matched for H21
    2022-06-13 19:09:58.565 - debug: vedirect.0 (1717) [stateSetCreate]H21 with value : 0
    2022-06-13 19:09:58.566 - debug: vedirect.0 (1717) No attribute changes for : H21, processing normallly
    2022-06-13 19:09:58.569 - debug: vedirect.0 (1717) Line : H22 0
    2022-06-13 19:09:58.570 - debug: vedirect.0 (1717) [stateSetCreate]H22 with value : 0
    2022-06-13 19:09:58.571 - debug: vedirect.0 (1717) No attribute changes for : H22, processing normallly
    2022-06-13 19:09:58.575 - debug: vedirect.0 (1717) Line : H23 0
    2022-06-13 19:09:58.576 - debug: vedirect.0 (1717) No case matched for H23
    2022-06-13 19:09:58.576 - debug: vedirect.0 (1717) [stateSetCreate]H23 with value : 0
    2022-06-13 19:09:58.577 - debug: vedirect.0 (1717) No attribute changes for : H23, processing normallly
    2022-06-13 19:09:58.578 - debug: vedirect.0 (1717) Line : HSDS 0
    2022-06-13 19:09:58.579 - debug: vedirect.0 (1717) No case matched for HSDS
    2022-06-13 19:09:58.580 - debug: vedirect.0 (1717) [stateSetCreate]HSDS with value : 0
    2022-06-13 19:09:58.580 - debug: vedirect.0 (1717) No attribute changes for : HSDS, processing normallly
    2022-06-13 19:09:59.448 - debug: vedirect.0 (1717) Line : Checksum |
    2022-06-13 19:09:59.466 - debug: vedirect.0 (1717) Line : PID 0xA060
    2022-06-13 19:09:59.468 - debug: vedirect.0 (1717) Line : FW 159
    2022-06-13 19:09:59.470 - debug: vedirect.0 (1717) No case matched for FW
    2022-06-13 19:09:59.471 - debug: vedirect.0 (1717) [stateSetCreate]FW with value : 159
    2022-06-13 19:09:59.472 - debug: vedirect.0 (1717) No attribute changes for : FW, processing normallly
    2022-06-13 19:09:59.474 - debug: vedirect.0 (1717) Line : SER# HQ2121KRGMY
    2022-06-13 19:09:59.476 - debug: vedirect.0 (1717) No case matched for SER#
    2022-06-13 19:09:59.477 - debug: vedirect.0 (1717) [stateSetCreate]SER# with value : HQ2121KRGMY
    2022-06-13 19:09:59.478 - debug: vedirect.0 (1717) No attribute changes for : SER#, processing normallly
    2022-06-13 19:09:59.481 - debug: vedirect.0 (1717) [stateSetCreate]PID with value : SmartSolar MPPT 100|20 48V
    2022-06-13 19:09:59.482 - debug: vedirect.0 (1717) No attribute changes for : PID, processing normallly
    2022-06-13 19:09:59.492 - debug: vedirect.0 (1717) Line : V 12800
    2022-06-13 19:09:59.494 - debug: vedirect.0 (1717) [stateSetCreate]V with value : 12.8
    2022-06-13 19:09:59.496 - debug: vedirect.0 (1717) No attribute changes for : V, processing normallly
    2022-06-13 19:09:59.500 - debug: vedirect.0 (1717) Line : I 0
    2022-06-13 19:09:59.502 - debug: vedirect.0 (1717) [stateSetCreate]I with value : 0
    2022-06-13 19:09:59.504 - debug: vedirect.0 (1717) No attribute changes for : I, processing normallly
    2022-06-13 19:09:59.507 - debug: vedirect.0 (1717) Line : VPV 14470
    2022-06-13 19:09:59.508 - debug: vedirect.0 (1717) [stateSetCreate]VPV with value : 14.47
    2022-06-13 19:09:59.509 - debug: vedirect.0 (1717) No attribute changes for : VPV, processing normallly
    2022-06-13 19:09:59.522 - debug: vedirect.0 (1717) Line : PPV 0
    2022-06-13 19:09:59.523 - debug: vedirect.0 (1717) No case matched for PPV
    2022-06-13 19:09:59.526 - debug: vedirect.0 (1717) [stateSetCreate]PPV with value : 0
    2022-06-13 19:09:59.527 - debug: vedirect.0 (1717) No attribute changes for : PPV, processing normallly
    2022-06-13 19:09:59.529 - debug: vedirect.0 (1717) Line : CS 3
    2022-06-13 19:09:59.531 - debug: vedirect.0 (1717) Line : MPPT 2
    2022-06-13 19:09:59.532 - debug: vedirect.0 (1717) Line : OR 0x00000000
    2022-06-13 19:09:59.534 - debug: vedirect.0 (1717) Line : ERR 0
    2022-06-13 19:09:59.536 - debug: vedirect.0 (1717) Line : LOAD ON
    2022-06-13 19:09:59.536 - debug: vedirect.0 (1717) No case matched for LOAD
    2022-06-13 19:09:59.537 - debug: vedirect.0 (1717) [stateSetCreate]LOAD with value : ON
    2022-06-13 19:09:59.538 - debug: vedirect.0 (1717) No attribute changes for : LOAD, processing normallly
    2022-06-13 19:09:59.539 - debug: vedirect.0 (1717) Line : IL 0
    2022-06-13 19:09:59.540 - debug: vedirect.0 (1717) [stateSetCreate]IL with value : 0
    2022-06-13 19:09:59.540 - debug: vedirect.0 (1717) No attribute changes for : IL, processing normallly
    2022-06-13 19:09:59.542 - debug: vedirect.0 (1717) Line : H19 0
    2022-06-13 19:09:59.542 - debug: vedirect.0 (1717) [stateSetCreate]H19 with value : 0
    2022-06-13 19:09:59.543 - debug: vedirect.0 (1717) No attribute changes for : H19, processing normallly
    2022-06-13 19:09:59.544 - debug: vedirect.0 (1717) [stateSetCreate]CS with value : Bulk
    2022-06-13 19:09:59.545 - debug: vedirect.0 (1717) No attribute changes for : CS, processing normallly
    2022-06-13 19:09:59.546 - debug: vedirect.0 (1717) [stateSetCreate]MPPT with value : MPP Tracker active
    2022-06-13 19:09:59.547 - debug: vedirect.0 (1717) No attribute changes for : MPPT, processing normallly
    2022-06-13 19:09:59.552 - debug: vedirect.0 (1717) [stateSetCreate]ERR with value : No Error
    2022-06-13 19:09:59.553 - debug: vedirect.0 (1717) No attribute changes for : ERR, processing normallly
    2022-06-13 19:09:59.555 - debug: vedirect.0 (1717) [stateSetCreate]OR with value : Normal Operation
    2022-06-13 19:09:59.556 - debug: vedirect.0 (1717) No attribute changes for : OR, processing normallly
    2022-06-13 19:09:59.576 - debug: vedirect.0 (1717) Line : H20 0
    2022-06-13 19:09:59.578 - debug: vedirect.0 (1717) [stateSetCreate]H20 with value : 0
    2022-06-13 19:09:59.579 - debug: vedirect.0 (1717) No attribute changes for : H20, processing normallly
    2022-06-13 19:09:59.580 - debug: vedirect.0 (1717) Line : H21 0
    2022-06-13 19:09:59.581 - debug: vedirect.0 (1717) No case matched for H21
    2022-06-13 19:09:59.582 - debug: vedirect.0 (1717) [stateSetCreate]H21 with value : 0
    2022-06-13 19:09:59.583 - debug: vedirect.0 (1717) No attribute changes for : H21, processing normallly
    2022-06-13 19:09:59.585 - debug: vedirect.0 (1717) Line : H22 0
    2022-06-13 19:09:59.587 - debug: vedirect.0 (1717) [stateSetCreate]H22 with value : 0
    2022-06-13 19:09:59.588 - debug: vedirect.0 (1717) No attribute changes for : H22, processing normallly
    2022-06-13 19:09:59.592 - debug: vedirect.0 (1717) Line : H23 0
    2022-06-13 19:09:59.593 - debug: vedirect.0 (1717) No case matched for H23
    2022-06-13 19:09:59.594 - debug: vedirect.0 (1717) [stateSetCreate]H23 with value : 0
    2022-06-13 19:09:59.595 - debug: vedirect.0 (1717) No attribute changes for : H23, processing normallly
    2022-06-13 19:09:59.598 - debug: vedirect.0 (1717) Line : HSDS 0
    2022-06-13 19:09:59.599 - debug: vedirect.0 (1717) No case matched for HSDS
    2022-06-13 19:09:59.600 - debug: vedirect.0 (1717) [stateSetCreate]HSDS with value : 0
    2022-06-13 19:09:59.601 - debug: vedirect.0 (1717) No attribute changes for : HSDS, processing normallly
    2022-06-13 19:10:00.458 - debug: vedirect.0 (1717) Line : Checksum �
    2022-06-13 19:10:00.460 - debug: vedirect.0 (1717) Line : PID 0xA060
    2022-06-13 19:10:00.462 - debug: vedirect.0 (1717) Line : FW 159
    2022-06-13 19:10:00.463 - debug: vedirect.0 (1717) No case matched for FW
    2022-06-13 19:10:00.464 - debug: vedirect.0 (1717) [stateSetCreate]FW with value : 159
    2022-06-13 19:10:00.465 - debug: vedirect.0 (1717) No attribute changes for : FW, processing normallly
    2022-06-13 19:10:00.468 - debug: vedirect.0 (1717) [stateSetCreate]PID with value : SmartSolar MPPT 100|20 48V
    2022-06-13 19:10:00.469 - debug: vedirect.0 (1717) No attribute changes for : PID, processing normallly
    2022-06-13 19:10:00.480 - debug: vedirect.0 (1717) Line : SER# HQ2121KRGMY
    2022-06-13 19:10:00.482 - debug: vedirect.0 (1717) No case matched for SER#
    2022-06-13 19:10:00.483 - debug: vedirect.0 (1717) [stateSetCreate]SER# with value : HQ2121KRGMY
    2022-06-13 19:10:00.484 - debug: vedirect.0 (1717) No attribute changes for : SER#, processing normallly
    2022-06-13 19:10:00.487 - debug: vedirect.0 (1717) Line : V 12850
    2022-06-13 19:10:00.489 - debug: vedirect.0 (1717) [stateSetCreate]V with value : 12.85
    2022-06-13 19:10:00.490 - debug: vedirect.0 (1717) No attribute changes for : V, processing normallly
    2022-06-13 19:10:00.498 - debug: vedirect.0 (1717) Line : I 0
    2022-06-13 19:10:00.499 - debug: vedirect.0 (1717) [stateSetCreate]I with value : 0
    2022-06-13 19:10:00.501 - debug: vedirect.0 (1717) No attribute changes for : I, processing normallly
    2022-06-13 19:10:00.504 - debug: vedirect.0 (1717) Line : VPV 14470
    2022-06-13 19:10:00.505 - debug: vedirect.0 (1717) [stateSetCreate]VPV with value : 14.47
    2022-06-13 19:10:00.507 - debug: vedirect.0 (1717) No attribute changes for : VPV, processing normallly
    2022-06-13 19:10:00.509 - debug: vedirect.0 (1717) Line : PPV 0
    2022-06-13 19:10:00.511 - debug: vedirect.0 (1717) No case matched for PPV
    2022-06-13 19:10:00.512 - debug: vedirect.0 (1717) [stateSetCreate]PPV with value : 0
    2022-06-13 19:10:00.513 - debug: vedirect.0 (1717) No attribute changes for : PPV, processing normallly
    2022-06-13 19:10:00.516 - debug: vedirect.0 (1717) Line : CS 3
    2022-06-13 19:10:00.518 - debug: vedirect.0 (1717) [stateSetCreate]CS with value : Bulk
    2022-06-13 19:10:00.520 - debug: vedirect.0 (1717) No attribute changes for : CS, processing normallly
    2022-06-13 19:10:00.531 - debug: vedirect.0 (1717) Line : MPPT 2
    2022-06-13 19:10:00.533 - debug: vedirect.0 (1717) Line : OR 0x00000000
    2022-06-13 19:10:00.538 - debug: vedirect.0 (1717) Line : ERR 0
    2022-06-13 19:10:00.543 - debug: vedirect.0 (1717) Line : LOAD ON
    2022-06-13 19:10:00.544 - debug: vedirect.0 (1717) No case matched for LOAD
    2022-06-13 19:10:00.545 - debug: vedirect.0 (1717) [stateSetCreate]LOAD with value : ON
    2022-06-13 19:10:00.547 - debug: vedirect.0 (1717) No attribute changes for : LOAD, processing normallly
    2022-06-13 19:10:00.550 - debug: vedirect.0 (1717) Line : IL 0
    2022-06-13 19:10:00.551 - debug: vedirect.0 (1717) [stateSetCreate]IL with value : 0
    2022-06-13 19:10:00.552 - debug: vedirect.0 (1717) No attribute changes for : IL, processing normallly
    2022-06-13 19:10:00.554 - debug: vedirect.0 (1717) Line : H19 0
    2022-06-13 19:10:00.555 - debug: vedirect.0 (1717) [stateSetCreate]H19 with value : 0
    2022-06-13 19:10:00.556 - debug: vedirect.0 (1717) No attribute changes for : H19, processing normallly
    2022-06-13 19:10:00.558 - debug: vedirect.0 (1717) Line : H20 0
    2022-06-13 19:10:00.559 - debug: vedirect.0 (1717) [stateSetCreate]H20 with value : 0
    2022-06-13 19:10:00.560 - debug: vedirect.0 (1717) No attribute changes for : H20, processing normallly
    2022-06-13 19:10:00.562 - debug: vedirect.0 (1717) Line : H21 0
    2022-06-13 19:10:00.563 - debug: vedirect.0 (1717) No case matched for H21
    2022-06-13 19:10:00.564 - debug: vedirect.0 (1717) [stateSetCreate]H21 with value : 0
    2022-06-13 19:10:00.565 - debug: vedirect.0 (1717) No attribute changes for : H21, processing normallly
    2022-06-13 19:10:00.567 - debug: vedirect.0 (1717) [stateSetCreate]MPPT with value : MPP Tracker active
    2022-06-13 19:10:00.568 - debug: vedirect.0 (1717) No attribute changes for : MPPT, processing normallly
    2022-06-13 19:10:00.570 - debug: vedirect.0 (1717) [stateSetCreate]ERR with value : No Error
    2022-06-13 19:10:00.571 - debug: vedirect.0 (1717) No attribute changes for : ERR, processing normallly
    2022-06-13 19:10:00.573 - debug: vedirect.0 (1717) [stateSetCreate]OR with value : Normal Operation
    2022-06-13 19:10:00.573 - debug: vedirect.0 (1717) No attribute changes for : OR, processing normallly
    2022-06-13 19:10:00.593 - debug: vedirect.0 (1717) Line : H22 0
    2022-06-13 19:10:00.594 - debug: vedirect.0 (1717) [stateSetCreate]H22 with value : 0
    2022-06-13 19:10:00.595 - debug: vedirect.0 (1717) No attribute changes for : H22, processing normallly
    2022-06-13 19:10:00.596 - debug: vedirect.0 (1717) Line : H23 0
    2022-06-13 19:10:00.598 - debug: vedirect.0 (1717) No case matched for H23
    2022-06-13 19:10:00.599 - debug: vedirect.0 (1717) [stateSetCreate]H23 with value : 0
    2022-06-13 19:10:00.601 - debug: vedirect.0 (1717) No attribute changes for : H23, processing normallly
    2022-06-13 19:10:00.606 - debug: vedirect.0 (1717) Line : HSDS 0
    2022-06-13 19:10:00.609 - debug: vedirect.0 (1717) No case matched for HSDS
    2022-06-13 19:10:00.610 - debug: vedirect.0 (1717) [stateSetCreate]HSDS with value : 0
    2022-06-13 19:10:00.611 - debug: vedirect.0 (1717) No attribute changes for : HSDS, processing normallly
    2022-06-13 19:10:01.449 - debug: vedirect.0 (1717) Line : Checksum |
    2022-06-13 19:10:01.465 - debug: vedirect.0 (1717) Line : PID 0xA060
    wie war das noch mit update und upgrade in der Console ? wo ihr schon einmal hier seid
    @ralla66
    Wie bist du denn da sonst so unterwegs?
    uname -m && which nodejs node npm && nodejs -v && node -v && npm -v && whoami && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
    Ralla66R 1 Antwort Letzte Antwort
      @ralla66
      Ralla66R Offline
      Ralla66R Offline
      Ralla66
      alter Eisenbahn Spiele Raspi zum testen. Halt für Modellbauprojekte im Winter und so RS485 Spiele
      mit Wechselrichtern.
      • Ralla66R Ralla66
        @ralla66 hast du backup?
        dann würde ich komplett neu aufsetzen
          Ralla66R Offline
          Ralla66R Offline
          Ralla66
          habe noch ein in Reserve, wenn die Solarmodule dann da sind Bau ich eh noch einmal komplett um.
          Prima das der Adapter rennt, wird dann mit eingepflegt.
          Tolle Arbeit von allen
          pi@raspberrypi:~ $ uname -m && which nodejs node npm && nodejs -v && node -v && npm -v && whoami && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
          armv7l
          /usr/bin/nodejs
          /usr/bin/node
          /usr/bin/npm
          v12.20.1
          v12.20.1
          6.14.10
          pi
          /home/pi
          pi@raspberrypi:~ $
          pi@raspberrypi:~ $ sudo ln -s /usr/bin/node /usr/bin/nodejs
          ln: die symbolische Verknüpfung '/usr/bin/nodejs' konnte nicht angelegt werden: Die Datei existiert bereits
          pi@raspberrypi:~ $
          • Ralla66R Ralla66
            armv7l
            /usr/bin/nodejs
            /usr/bin/node
            /usr/bin/npm
            v12.20.1
            v12.20.1
            6.14.10
            pi
            /home/pi
            pi@raspberrypi:~ $
            pi@raspberrypi:~ $
            @ralla66
            Dann ist da ewig kein Update mehr gefahren worden.
            sudo apt update
            sudo apt full-upgrade
            sudo reboot
              @ralla66
              sudo apt update
              sudo reboot
              Ralla66R Offline
              Ralla66R Offline
              Ralla66
              ist durchgelaufen ohne Warnung, jetzt die Adapter aktuallisieren ?
              • Ralla66R Ralla66
                @ralla66
                Zeig nochmal
                  @ralla66
                  Zeig nochmal
                  Ralla66R Offline
                  Ralla66R Offline
                  Ralla66
                  armv7l
                  /usr/bin/nodejs
                  /usr/bin/node
                  /usr/bin/npm
                  v12.22.12
                  v12.22.12
                  6.14.16
                  pi
                  /home/pi
                  Thomas BraunT Ralla66R 2 Antworten Letzte Antwort
                  • Ralla66R Ralla66
                    armv7l
                    /usr/bin/nodejs
                    /usr/bin/node
                    /usr/bin/npm
                    v12.22.12
                    v12.22.12
                    6.14.16
                    pi
                    /home/pi
                    @ralla66 sagte in vedirect -> USB an Victron MP2:
                    sudo apt update
                    sagt?
                      sudo apt update
                      sagt?
                      Ralla66R Offline
                      Ralla66R Offline
                      Ralla66
                      pi@raspberrypi:~ $ sudo apt update
                      OK:1 http://raspbian.raspberrypi.org/raspbian buster InRelease
                      OK:2 http://archive.raspberrypi.org/debian buster InRelease
                      OK:3 https://deb.nodesource.com/node_12.x buster InRelease
                      Alle Pakete sind aktuell.
                      pi@raspberrypi:~ $
                      • Ralla66R Ralla66
                        pi@raspberrypi:~ $
                        @ralla66
                        Dann stell jetzt auf node14 um. Siehe meine Signatur.
                          @ralla66
                          Ralla66R Offline
                          Ralla66R Offline
                          Ralla66
                          ok Danke,
                          mache erst einmal ein Backup. Wenn noch Probleme entstehen mache ich ein Fred auf.
                          Zu weit weg vom Thema.
                          • Ralla66R Ralla66
                            @dutchman
                            bin aber mit admin und update noch uralt
                            Log ist von einem SmartSolar charge controller MPPT 100/20 BT
                             2022-06-13 19:09:49.035 - debug: vedirect.0 (1717) Redis Objects: Use Redis connection: 127.0.0.1:9001
                            2022-06-13 19:09:49.091 - debug: vedirect.0 (1717) Objects client ready ... initialize now
                            2022-06-13 19:09:49.097 - debug: vedirect.0 (1717) Objects create System PubSub Client
                            2022-06-13 19:09:49.100 - debug: vedirect.0 (1717) Objects create User PubSub Client
                            2022-06-13 19:09:49.102 - debug: vedirect.0 (1717) Objects client initialize lua scripts
                            2022-06-13 19:09:49.122 - debug: vedirect.0 (1717) Objects connected to redis: 127.0.0.1:9001
                            2022-06-13 19:09:49.136 - debug: vedirect.0 (1717) objectDB connected
                            2022-06-13 19:09:49.140 - debug: vedirect.0 (1717) Redis States: Use Redis connection: 127.0.0.1:9000
                            2022-06-13 19:09:49.153 - debug: vedirect.0 (1717) States create User PubSub Client
                            2022-06-13 19:09:49.159 - debug: vedirect.0 (1717) States create System PubSub Client
                            2022-06-13 19:09:49.173 - debug: vedirect.0 (1717) States connected to redis: 127.0.0.1:9000
                            2022-06-13 19:09:49.175 - debug: vedirect.0 (1717) statesDB connected
                            2022-06-13 19:09:49.837 - debug: vedirect.0 (1717) Plugin sentry Initialize Plugin (enabled=true)
                            2022-06-13 19:09:50.253 - info: vedirect.0 (1717) starting. Version 0.1.2 in /opt/iobroker/node_modules/iobroker.vedirect, node: v12.20.1, js-controller: 3.1.6
                            2022-06-13 19:09:50.437 - debug: vedirect.0 (1717) Line : �
                            2022-06-13 19:09:50.440 - debug: vedirect.0 (1717) Line : PID 0xA060
                            2022-06-13 19:09:50.443 - debug: vedirect.0 (1717) [stateSetCreate]PID with value : SmartSolar MPPT 100|20 48V
                            2022-06-13 19:09:50.444 - debug: vedirect.0 (1717) An attribute has changed for : PID
                            2022-06-13 19:09:50.454 - debug: vedirect.0 (1717) Line : FW 159
                            2022-06-13 19:09:50.455 - debug: vedirect.0 (1717) No case matched for FW
                            2022-06-13 19:09:50.456 - debug: vedirect.0 (1717) [stateSetCreate]FW with value : 159
                            2022-06-13 19:09:50.458 - debug: vedirect.0 (1717) An attribute has changed for : FW
                            2022-06-13 19:09:50.461 - debug: vedirect.0 (1717) Line : SER# HQ2121KRGMY
                            2022-06-13 19:09:50.462 - debug: vedirect.0 (1717) No case matched for SER#
                            2022-06-13 19:09:50.463 - debug: vedirect.0 (1717) [stateSetCreate]SER# with value : HQ2121KRGMY
                            2022-06-13 19:09:50.463 - debug: vedirect.0 (1717) An attribute has changed for : SER#
                            2022-06-13 19:09:50.480 - debug: vedirect.0 (1717) Line : V 12830
                            2022-06-13 19:09:50.481 - debug: vedirect.0 (1717) [stateSetCreate]V with value : 12.83
                            2022-06-13 19:09:50.483 - debug: vedirect.0 (1717) An attribute has changed for : V
                            2022-06-13 19:09:50.486 - debug: vedirect.0 (1717) Line : I 0
                            2022-06-13 19:09:50.488 - debug: vedirect.0 (1717) [stateSetCreate]I with value : 0
                            2022-06-13 19:09:50.489 - debug: vedirect.0 (1717) An attribute has changed for : I
                            2022-06-13 19:09:50.492 - debug: vedirect.0 (1717) Line : VPV 14470
                            2022-06-13 19:09:50.494 - debug: vedirect.0 (1717) [stateSetCreate]VPV with value : 14.47
                            2022-06-13 19:09:50.495 - debug: vedirect.0 (1717) An attribute has changed for : VPV
                            2022-06-13 19:09:50.499 - debug: vedirect.0 (1717) Line : PPV 0
                            2022-06-13 19:09:50.500 - debug: vedirect.0 (1717) No case matched for PPV
                            2022-06-13 19:09:50.502 - debug: vedirect.0 (1717) [stateSetCreate]PPV with value : 0
                            2022-06-13 19:09:50.503 - debug: vedirect.0 (1717) An attribute has changed for : PPV
                            2022-06-13 19:09:50.530 - debug: vedirect.0 (1717) Line : CS 3
                            2022-06-13 19:09:50.533 - debug: vedirect.0 (1717) Line : MPPT 2
                            2022-06-13 19:09:50.536 - debug: vedirect.0 (1717) Line : OR 0x00000000
                            2022-06-13 19:09:50.538 - debug: vedirect.0 (1717) Line : ERR 0
                            2022-06-13 19:09:50.541 - debug: vedirect.0 (1717) Line : LOAD ON
                            2022-06-13 19:09:50.542 - debug: vedirect.0 (1717) No case matched for LOAD
                            2022-06-13 19:09:50.544 - debug: vedirect.0 (1717) [stateSetCreate]LOAD with value : ON
                            2022-06-13 19:09:50.545 - debug: vedirect.0 (1717) An attribute has changed for : LOAD
                            2022-06-13 19:09:50.549 - debug: vedirect.0 (1717) Line : IL 0
                            2022-06-13 19:09:50.550 - debug: vedirect.0 (1717) [stateSetCreate]IL with value : 0
                            2022-06-13 19:09:50.552 - debug: vedirect.0 (1717) An attribute has changed for : IL
                            2022-06-13 19:09:50.555 - debug: vedirect.0 (1717) Line : H19 0
                            2022-06-13 19:09:50.556 - debug: vedirect.0 (1717) [stateSetCreate]H19 with value : 0
                            2022-06-13 19:09:50.558 - debug: vedirect.0 (1717) An attribute has changed for : H19
                            2022-06-13 19:09:50.561 - debug: vedirect.0 (1717) Line : H20 0
                            2022-06-13 19:09:50.562 - debug: vedirect.0 (1717) [stateSetCreate]H20 with value : 0
                            2022-06-13 19:09:50.563 - debug: vedirect.0 (1717) An attribute has changed for : H20
                            2022-06-13 19:09:50.566 - debug: vedirect.0 (1717) [stateSetCreate]CS with value : Bulk
                            2022-06-13 19:09:50.568 - debug: vedirect.0 (1717) An attribute has changed for : CS
                            2022-06-13 19:09:50.570 - debug: vedirect.0 (1717) [stateSetCreate]MPPT with value : MPP Tracker active
                            2022-06-13 19:09:50.571 - debug: vedirect.0 (1717) An attribute has changed for : MPPT
                            2022-06-13 19:09:50.574 - debug: vedirect.0 (1717) [stateSetCreate]ERR with value : No Error
                            2022-06-13 19:09:50.576 - debug: vedirect.0 (1717) An attribute has changed for : ERR
                            2022-06-13 19:09:50.577 - debug: vedirect.0 (1717) [stateSetCreate]OR with value : Normal Operation
                            2022-06-13 19:09:50.578 - debug: vedirect.0 (1717) An attribute has changed for : OR
                            2022-06-13 19:09:50.609 - debug: vedirect.0 (1717) Line : H21 0
                            2022-06-13 19:09:50.611 - debug: vedirect.0 (1717) No case matched for H21
                            2022-06-13 19:09:50.612 - debug: vedirect.0 (1717) [stateSetCreate]H21 with value : 0
                            2022-06-13 19:09:50.613 - debug: vedirect.0 (1717) An attribute has changed for : H21
                            2022-06-13 19:09:50.615 - debug: vedirect.0 (1717) Line : H22 0
                            2022-06-13 19:09:50.616 - debug: vedirect.0 (1717) [stateSetCreate]H22 with value : 0
                            2022-06-13 19:09:50.618 - debug: vedirect.0 (1717) An attribute has changed for : H22
                            2022-06-13 19:09:50.620 - debug: vedirect.0 (1717) Line : H23 0
                            2022-06-13 19:09:50.621 - debug: vedirect.0 (1717) No case matched for H23
                            2022-06-13 19:09:50.622 - debug: vedirect.0 (1717) [stateSetCreate]H23 with value : 0
                            2022-06-13 19:09:50.623 - debug: vedirect.0 (1717) An attribute has changed for : H23
                            2022-06-13 19:09:50.626 - debug: vedirect.0 (1717) Line : HSDS 0
                            2022-06-13 19:09:50.627 - debug: vedirect.0 (1717) No case matched for HSDS
                            2022-06-13 19:09:50.628 - debug: vedirect.0 (1717) [stateSetCreate]HSDS with value : 0
                            2022-06-13 19:09:50.629 - debug: vedirect.0 (1717) An attribute has changed for : HSDS
                            2022-06-13 19:09:51.445 - debug: vedirect.0 (1717) Line : Checksum ~
                            2022-06-13 19:09:51.448 - debug: vedirect.0 (1717) Line : PID 0xA060
                            2022-06-13 19:09:51.451 - debug: vedirect.0 (1717) Line : FW 159
                            2022-06-13 19:09:51.452 - debug: vedirect.0 (1717) No case matched for FW
                            2022-06-13 19:09:51.454 - debug: vedirect.0 (1717) [stateSetCreate]FW with value : 159
                            2022-06-13 19:09:51.455 - debug: vedirect.0 (1717) No attribute changes for : FW, processing normallly
                            2022-06-13 19:09:51.458 - debug: vedirect.0 (1717) [stateSetCreate]PID with value : SmartSolar MPPT 100|20 48V
                            2022-06-13 19:09:51.460 - debug: vedirect.0 (1717) No attribute changes for : PID, processing normallly
                            2022-06-13 19:09:51.480 - debug: vedirect.0 (1717) Line : SER# HQ2121KRGMY
                            2022-06-13 19:09:51.483 - debug: vedirect.0 (1717) No case matched for SER#
                            2022-06-13 19:09:51.484 - debug: vedirect.0 (1717) [stateSetCreate]SER# with value : HQ2121KRGMY
                            2022-06-13 19:09:51.486 - debug: vedirect.0 (1717) No attribute changes for : SER#, processing normallly
                            2022-06-13 19:09:51.491 - debug: vedirect.0 (1717) Line : V 13120
                            2022-06-13 19:09:51.492 - debug: vedirect.0 (1717) [stateSetCreate]V with value : 13.12
                            2022-06-13 19:09:51.493 - debug: vedirect.0 (1717) No attribute changes for : V, processing normallly
                            2022-06-13 19:09:51.499 - debug: vedirect.0 (1717) Line : I 0
                            2022-06-13 19:09:51.501 - debug: vedirect.0 (1717) [stateSetCreate]I with value : 0
                            2022-06-13 19:09:51.502 - debug: vedirect.0 (1717) No attribute changes for : I, processing normallly
                            2022-06-13 19:09:51.530 - debug: vedirect.0 (1717) Line : VPV 14470
                            2022-06-13 19:09:51.531 - debug: vedirect.0 (1717) [stateSetCreate]VPV with value : 14.47
                            2022-06-13 19:09:51.533 - debug: vedirect.0 (1717) No attribute changes for : VPV, processing normallly
                            2022-06-13 19:09:51.536 - debug: vedirect.0 (1717) Line : PPV 0
                            2022-06-13 19:09:51.537 - debug: vedirect.0 (1717) No case matched for PPV
                            2022-06-13 19:09:51.538 - debug: vedirect.0 (1717) [stateSetCreate]PPV with value : 0
                            2022-06-13 19:09:51.540 - debug: vedirect.0 (1717) No attribute changes for : PPV, processing normallly
                            2022-06-13 19:09:51.543 - debug: vedirect.0 (1717) Line : CS 3
                            2022-06-13 19:09:51.545 - debug: vedirect.0 (1717) Line : MPPT 2
                            2022-06-13 19:09:51.547 - debug: vedirect.0 (1717) Line : OR 0x00000000
                            2022-06-13 19:09:51.549 - debug: vedirect.0 (1717) Line : ERR 0
                            2022-06-13 19:09:51.551 - debug: vedirect.0 (1717) Line : LOAD ON
                            2022-06-13 19:09:51.553 - debug: vedirect.0 (1717) No case matched for LOAD
                            2022-06-13 19:09:51.554 - debug: vedirect.0 (1717) [stateSetCreate]LOAD with value : ON
                            2022-06-13 19:09:51.555 - debug: vedirect.0 (1717) No attribute changes for : LOAD, processing normallly
                            2022-06-13 19:09:51.557 - debug: vedirect.0 (1717) [stateSetCreate]CS with value : Bulk
                            2022-06-13 19:09:51.558 - debug: vedirect.0 (1717) No attribute changes for : CS, processing normallly
                            2022-06-13 19:09:51.560 - debug: vedirect.0 (1717) [stateSetCreate]MPPT with value : MPP Tracker active
                            2022-06-13 19:09:51.561 - debug: vedirect.0 (1717) No attribute changes for : MPPT, processing normallly
                            2022-06-13 19:09:51.563 - debug: vedirect.0 (1717) [stateSetCreate]ERR with value : No Error
                            2022-06-13 19:09:51.565 - debug: vedirect.0 (1717) No attribute changes for : ERR, processing normallly
                            2022-06-13 19:09:51.566 - debug: vedirect.0 (1717) [stateSetCreate]OR with value : Normal Operation
                            2022-06-13 19:09:51.567 - debug: vedirect.0 (1717) No attribute changes for : OR, processing normallly
                            2022-06-13 19:09:51.601 - debug: vedirect.0 (1717) Line : IL 0
                            2022-06-13 19:09:51.602 - debug: vedirect.0 (1717) [stateSetCreate]IL with value : 0
                            2022-06-13 19:09:51.603 - debug: vedirect.0 (1717) No attribute changes for : IL, processing normallly
                            2022-06-13 19:09:51.606 - debug: vedirect.0 (1717) Line : H19 0
                            2022-06-13 19:09:51.607 - debug: vedirect.0 (1717) [stateSetCreate]H19 with value : 0
                            2022-06-13 19:09:51.608 - debug: vedirect.0 (1717) No attribute changes for : H19, processing normallly
                            2022-06-13 19:09:51.610 - debug: vedirect.0 (1717) Line : H20 0
                            2022-06-13 19:09:51.611 - debug: vedirect.0 (1717) [stateSetCreate]H20 with value : 0
                            2022-06-13 19:09:51.612 - debug: vedirect.0 (1717) No attribute changes for : H20, processing normallly
                            2022-06-13 19:09:51.615 - debug: vedirect.0 (1717) Line : H21 0
                            2022-06-13 19:09:51.616 - debug: vedirect.0 (1717) No case matched for H21
                            2022-06-13 19:09:51.617 - debug: vedirect.0 (1717) [stateSetCreate]H21 with value : 0
                            2022-06-13 19:09:51.618 - debug: vedirect.0 (1717) No attribute changes for : H21, processing normallly
                            2022-06-13 19:09:51.620 - debug: vedirect.0 (1717) Line : H22 0
                            2022-06-13 19:09:51.621 - debug: vedirect.0 (1717) [stateSetCreate]H22 with value : 0
                            2022-06-13 19:09:51.622 - debug: vedirect.0 (1717) No attribute changes for : H22, processing normallly
                            2022-06-13 19:09:51.624 - debug: vedirect.0 (1717) Line : H23 0
                            2022-06-13 19:09:51.625 - debug: vedirect.0 (1717) No case matched for H23
                            2022-06-13 19:09:51.626 - debug: vedirect.0 (1717) [stateSetCreate]H23 with value : 0
                            2022-06-13 19:09:51.626 - debug: vedirect.0 (1717) No attribute changes for : H23, processing normallly
                            2022-06-13 19:09:51.628 - debug: vedirect.0 (1717) Line : HSDS 0
                            2022-06-13 19:09:51.630 - debug: vedirect.0 (1717) No case matched for HSDS
                            2022-06-13 19:09:51.630 - debug: vedirect.0 (1717) [stateSetCreate]HSDS with value : 0
                            2022-06-13 19:09:51.631 - debug: vedirect.0 (1717) No attribute changes for : HSDS, processing normallly
                            2022-06-13 19:09:52.437 - debug: vedirect.0 (1717) Line : Checksum �
                            2022-06-13 19:09:52.452 - debug: vedirect.0 (1717) Line : PID 0xA060
                            2022-06-13 19:09:52.455 - debug: vedirect.0 (1717) Line : FW 159
                            2022-06-13 19:09:52.457 - debug: vedirect.0 (1717) No case matched for FW
                            2022-06-13 19:09:52.458 - debug: vedirect.0 (1717) [stateSetCreate]FW with value : 159
                            2022-06-13 19:09:52.459 - debug: vedirect.0 (1717) No attribute changes for : FW, processing normallly
                            2022-06-13 19:09:52.462 - debug: vedirect.0 (1717) Line : SER# HQ2121KRGMY
                            2022-06-13 19:09:52.463 - debug: vedirect.0 (1717) No case matched for SER#
                            2022-06-13 19:09:52.465 - debug: vedirect.0 (1717) [stateSetCreate]SER# with value : HQ2121KRGMY
                            2022-06-13 19:09:52.466 - debug: vedirect.0 (1717) No attribute changes for : SER#, processing normallly
                            2022-06-13 19:09:52.468 - debug: vedirect.0 (1717) [stateSetCreate]PID with value : SmartSolar MPPT 100|20 48V
                            2022-06-13 19:09:52.470 - debug: vedirect.0 (1717) No attribute changes for : PID, processing normallly
                            2022-06-13 19:09:52.484 - debug: vedirect.0 (1717) Line : V 12890
                            2022-06-13 19:09:52.486 - debug: vedirect.0 (1717) [stateSetCreate]V with value : 12.89
                            2022-06-13 19:09:52.488 - debug: vedirect.0 (1717) No attribute changes for : V, processing normallly
                            2022-06-13 19:09:52.492 - debug: vedirect.0 (1717) Line : I 0
                            2022-06-13 19:09:52.493 - debug: vedirect.0 (1717) [stateSetCreate]I with value : 0
                            2022-06-13 19:09:52.495 - debug: vedirect.0 (1717) No attribute changes for : I, processing normallly
                            2022-06-13 19:09:52.498 - debug: vedirect.0 (1717) Line : VPV 14470
                            2022-06-13 19:09:52.500 - debug: vedirect.0 (1717) [stateSetCreate]VPV with value : 14.47
                            2022-06-13 19:09:52.502 - debug: vedirect.0 (1717) No attribute changes for : VPV, processing normallly
                            2022-06-13 19:09:52.523 - debug: vedirect.0 (1717) Line : PPV 0
                            2022-06-13 19:09:52.525 - debug: vedirect.0 (1717) No case matched for PPV
                            2022-06-13 19:09:52.527 - debug: vedirect.0 (1717) [stateSetCreate]PPV with value : 0
                            2022-06-13 19:09:52.529 - debug: vedirect.0 (1717) No attribute changes for : PPV, processing normallly
                            2022-06-13 19:09:52.531 - debug: vedirect.0 (1717) Line : CS 3
                            2022-06-13 19:09:52.533 - debug: vedirect.0 (1717) Line : MPPT 2
                            2022-06-13 19:09:52.535 - debug: vedirect.0 (1717) Line : OR 0x00000000
                            2022-06-13 19:09:52.536 - debug: vedirect.0 (1717) Line : ERR 0
                            2022-06-13 19:09:52.538 - debug: vedirect.0 (1717) Line : LOAD ON
                            2022-06-13 19:09:52.539 - debug: vedirect.0 (1717) No case matched for LOAD
                            2022-06-13 19:09:52.540 - debug: vedirect.0 (1717) [stateSetCreate]LOAD with value : ON
                            2022-06-13 19:09:52.541 - debug: vedirect.0 (1717) No attribute changes for : LOAD, processing normallly
                            2022-06-13 19:09:52.542 - debug: vedirect.0 (1717) Line : IL 0
                            2022-06-13 19:09:52.543 - debug: vedirect.0 (1717) [stateSetCreate]IL with value : 0
                            2022-06-13 19:09:52.544 - debug: vedirect.0 (1717) No attribute changes for : IL, processing normallly
                            2022-06-13 19:09:52.545 - debug: vedirect.0 (1717) Line : H19 0
                            2022-06-13 19:09:52.546 - debug: vedirect.0 (1717) [stateSetCreate]H19 with value : 0
                            2022-06-13 19:09:52.547 - debug: vedirect.0 (1717) No attribute changes for : H19, processing normallly
                            2022-06-13 19:09:52.549 - debug: vedirect.0 (1717) [stateSetCreate]CS with value : Bulk
                            2022-06-13 19:09:52.549 - debug: vedirect.0 (1717) No attribute changes for : CS, processing normallly
                            2022-06-13 19:09:52.551 - debug: vedirect.0 (1717) [stateSetCreate]MPPT with value : MPP Tracker active
                            2022-06-13 19:09:52.551 - debug: vedirect.0 (1717) No attribute changes for : MPPT, processing normallly
                            2022-06-13 19:09:52.553 - debug: vedirect.0 (1717) [stateSetCreate]ERR with value : No Error
                            2022-06-13 19:09:52.554 - debug: vedirect.0 (1717) No attribute changes for : ERR, processing normallly
                            2022-06-13 19:09:52.555 - debug: vedirect.0 (1717) [stateSetCreate]OR with value : Normal Operation
                            2022-06-13 19:09:52.556 - debug: vedirect.0 (1717) No attribute changes for : OR, processing normallly
                            2022-06-13 19:09:52.583 - debug: vedirect.0 (1717) Line : H20 0
                            2022-06-13 19:09:52.584 - debug: vedirect.0 (1717) [stateSetCreate]H20 with value : 0
                            2022-06-13 19:09:52.585 - debug: vedirect.0 (1717) No attribute changes for : H20, processing normallly
                            2022-06-13 19:09:52.587 - debug: vedirect.0 (1717) Line : H21 0
                            2022-06-13 19:09:52.589 - debug: vedirect.0 (1717) No case matched for H21
                            2022-06-13 19:09:52.590 - debug: vedirect.0 (1717) [stateSetCreate]H21 with value : 0
                            2022-06-13 19:09:52.590 - debug: vedirect.0 (1717) No attribute changes for : H21, processing normallly
                            2022-06-13 19:09:52.593 - debug: vedirect.0 (1717) Line : H22 0
                            2022-06-13 19:09:52.594 - debug: vedirect.0 (1717) [stateSetCreate]H22 with value : 0
                            2022-06-13 19:09:52.595 - debug: vedirect.0 (1717) No attribute changes for : H22, processing normallly
                            2022-06-13 19:09:52.597 - debug: vedirect.0 (1717) Line : H23 0
                            2022-06-13 19:09:52.598 - debug: vedirect.0 (1717) No case matched for H23
                            2022-06-13 19:09:52.599 - debug: vedirect.0 (1717) [stateSetCreate]H23 with value : 0
                            2022-06-13 19:09:52.600 - debug: vedirect.0 (1717) No attribute changes for : H23, processing normallly
                            2022-06-13 19:09:52.602 - debug: vedirect.0 (1717) Line : HSDS 0
                            2022-06-13 19:09:52.603 - debug: vedirect.0 (1717) No case matched for HSDS
                            2022-06-13 19:09:52.604 - debug: vedirect.0 (1717) [stateSetCreate]HSDS with value : 0
                            2022-06-13 19:09:52.605 - debug: vedirect.0 (1717) No attribute changes for : HSDS, processing normallly
                            2022-06-13 19:09:53.445 - debug: vedirect.0 (1717) Line : Checksum x
                            2022-06-13 19:09:53.448 - debug: vedirect.0 (1717) Line : PID 0xA060
                            2022-06-13 19:09:53.451 - debug: vedirect.0 (1717) Line : FW 159
                            2022-06-13 19:09:53.452 - debug: vedirect.0 (1717) No case matched for FW
                            2022-06-13 19:09:53.454 - debug: vedirect.0 (1717) [stateSetCreate]FW with value : 159
                            2022-06-13 19:09:53.455 - debug: vedirect.0 (1717) No attribute changes for : FW, processing normallly
                            2022-06-13 19:09:53.457 - debug: vedirect.0 (1717) [stateSetCreate]PID with value : SmartSolar MPPT 100|20 48V
                            2022-06-13 19:09:53.459 - debug: vedirect.0 (1717) No attribute changes for : PID, processing normallly
                            2022-06-13 19:09:53.474 - debug: vedirect.0 (1717) Line : SER# HQ2121KRGMY
                            2022-06-13 19:09:53.476 - debug: vedirect.0 (1717) No case matched for SER#
                            2022-06-13 19:09:53.478 - debug: vedirect.0 (1717) [stateSetCreate]SER# with value : HQ2121KRGMY
                            2022-06-13 19:09:53.480 - debug: vedirect.0 (1717) No attribute changes for : SER#, processing normallly
                            2022-06-13 19:09:53.483 - debug: vedirect.0 (1717) Line : V 12590
                            2022-06-13 19:09:53.485 - debug: vedirect.0 (1717) [stateSetCreate]V with value : 12.59
                            2022-06-13 19:09:53.486 - debug: vedirect.0 (1717) No attribute changes for : V, processing normallly
                            2022-06-13 19:09:53.489 - debug: vedirect.0 (1717) Line : I 0
                            2022-06-13 19:09:53.490 - debug: vedirect.0 (1717) [stateSetCreate]I with value : 0
                            2022-06-13 19:09:53.491 - debug: vedirect.0 (1717) No attribute changes for : I, processing normallly
                            2022-06-13 19:09:53.512 - debug: vedirect.0 (1717) Line : VPV 14470
                            2022-06-13 19:09:53.514 - debug: vedirect.0 (1717) [stateSetCreate]VPV with value : 14.47
                            2022-06-13 19:09:53.515 - debug: vedirect.0 (1717) No attribute changes for : VPV, processing normallly
                            2022-06-13 19:09:53.519 - debug: vedirect.0 (1717) Line : PPV 0
                            2022-06-13 19:09:53.520 - debug: vedirect.0 (1717) No case matched for PPV
                            2022-06-13 19:09:53.522 - debug: vedirect.0 (1717) [stateSetCreate]PPV with value : 0
                            2022-06-13 19:09:53.523 - debug: vedirect.0 (1717) No attribute changes for : PPV, processing normallly
                            2022-06-13 19:09:53.526 - debug: vedirect.0 (1717) Line : CS 3
                            2022-06-13 19:09:53.529 - debug: vedirect.0 (1717) Line : MPPT 2
                            2022-06-13 19:09:53.531 - debug: vedirect.0 (1717) Line : OR 0x00000000
                            2022-06-13 19:09:53.533 - debug: vedirect.0 (1717) Line : ERR 0
                            2022-06-13 19:09:53.536 - debug: vedirect.0 (1717) [stateSetCreate]CS with value : Bulk
                            2022-06-13 19:09:53.537 - debug: vedirect.0 (1717) No attribute changes for : CS, processing normallly
                            2022-06-13 19:09:53.539 - debug: vedirect.0 (1717) [stateSetCreate]MPPT with value : MPP Tracker active
                            2022-06-13 19:09:53.540 - debug: vedirect.0 (1717) No attribute changes for : MPPT, processing normallly
                            2022-06-13 19:09:53.542 - debug: vedirect.0 (1717) [stateSetCreate]ERR with value : No Error
                            2022-06-13 19:09:53.544 - debug: vedirect.0 (1717) No attribute changes for : ERR, processing normallly
                            2022-06-13 19:09:53.546 - debug: vedirect.0 (1717) [stateSetCreate]OR with value : Normal Operation
                            2022-06-13 19:09:53.547 - debug: vedirect.0 (1717) No attribute changes for : OR, processing normallly
                            2022-06-13 19:09:53.578 - debug: vedirect.0 (1717) Line : LOAD ON
                            2022-06-13 19:09:53.579 - debug: vedirect.0 (1717) No case matched for LOAD
                            2022-06-13 19:09:53.580 - debug: vedirect.0 (1717) [stateSetCreate]LOAD with value : ON
                            2022-06-13 19:09:53.581 - debug: vedirect.0 (1717) No attribute changes for : LOAD, processing normallly
                            2022-06-13 19:09:53.583 - debug: vedirect.0 (1717) Line : IL 0
                            2022-06-13 19:09:53.584 - debug: vedirect.0 (1717) [stateSetCreate]IL with value : 0
                            2022-06-13 19:09:53.585 - debug: vedirect.0 (1717) No attribute changes for : IL, processing normallly
                            2022-06-13 19:09:53.588 - debug: vedirect.0 (1717) Line : H19 0
                            2022-06-13 19:09:53.589 - debug: vedirect.0 (1717) [stateSetCreate]H19 with value : 0
                            2022-06-13 19:09:53.590 - debug: vedirect.0 (1717) No attribute changes for : H19, processing normallly
                            2022-06-13 19:09:53.592 - debug: vedirect.0 (1717) Line : H20 0
                            2022-06-13 19:09:53.593 - debug: vedirect.0 (1717) [stateSetCreate]H20 with value : 0
                            2022-06-13 19:09:53.594 - debug: vedirect.0 (1717) No attribute changes for : H20, processing normallly
                            2022-06-13 19:09:53.598 - debug: vedirect.0 (1717) Line : H21 0
                            2022-06-13 19:09:53.600 - debug: vedirect.0 (1717) No case matched for H21
                            2022-06-13 19:09:53.601 - debug: vedirect.0 (1717) [stateSetCreate]H21 with value : 0
                            2022-06-13 19:09:53.602 - debug: vedirect.0 (1717) No attribute changes for : H21, processing normallly
                            2022-06-13 19:09:53.604 - debug: vedirect.0 (1717) Line : H22 0
                            2022-06-13 19:09:53.605 - debug: vedirect.0 (1717) [stateSetCreate]H22 with value : 0
                            2022-06-13 19:09:53.605 - debug: vedirect.0 (1717) No attribute changes for : H22, processing normallly
                            2022-06-13 19:09:53.607 - debug: vedirect.0 (1717) Line : H23 0
                            2022-06-13 19:09:53.608 - debug: vedirect.0 (1717) No case matched for H23
                            2022-06-13 19:09:53.609 - debug: vedirect.0 (1717) [stateSetCreate]H23 with value : 0
                            2022-06-13 19:09:53.609 - debug: vedirect.0 (1717) No attribute changes for : H23, processing normallly
                            2022-06-13 19:09:53.611 - debug: vedirect.0 (1717) Line : HSDS 0
                            2022-06-13 19:09:53.612 - debug: vedirect.0 (1717) No case matched for HSDS
                            2022-06-13 19:09:53.612 - debug: vedirect.0 (1717) [stateSetCreate]HSDS with value : 0
                            2022-06-13 19:09:53.619 - debug: vedirect.0 (1717) No attribute changes for : HSDS, processing normallly
                            2022-06-13 19:09:54.438 - debug: vedirect.0 (1717) Line : Checksum {
                            2022-06-13 19:09:54.454 - debug: vedirect.0 (1717) Line : PID 0xA060
                            2022-06-13 19:09:54.457 - debug: vedirect.0 (1717) Line : FW 159
                            2022-06-13 19:09:54.458 - debug: vedirect.0 (1717) No case matched for FW
                            2022-06-13 19:09:54.459 - debug: vedirect.0 (1717) [stateSetCreate]FW with value : 159
                            2022-06-13 19:09:54.460 - debug: vedirect.0 (1717) No attribute changes for : FW, processing normallly
                            2022-06-13 19:09:54.462 - debug: vedirect.0 (1717) [stateSetCreate]PID with value : SmartSolar MPPT 100|20 48V
                            2022-06-13 19:09:54.463 - debug: vedirect.0 (1717) No attribute changes for : PID, processing normallly
                            2022-06-13 19:09:54.478 - debug: vedirect.0 (1717) Line : SER# HQ2121KRGMY
                            2022-06-13 19:09:54.480 - debug: vedirect.0 (1717) No case matched for SER#
                            2022-06-13 19:09:54.481 - debug: vedirect.0 (1717) [stateSetCreate]SER# with value : HQ2121KRGMY
                            2022-06-13 19:09:54.482 - debug: vedirect.0 (1717) No attribute changes for : SER#, processing normallly
                            2022-06-13 19:09:54.486 - debug: vedirect.0 (1717) Line : V 12470
                            2022-06-13 19:09:54.487 - debug: vedirect.0 (1717) [stateSetCreate]V with value : 12.47
                            2022-06-13 19:09:54.488 - debug: vedirect.0 (1717) No attribute changes for : V, processing normallly
                            2022-06-13 19:09:54.490 - debug: vedirect.0 (1717) Line : I 0
                            2022-06-13 19:09:54.491 - debug: vedirect.0 (1717) [stateSetCreate]I with value : 0
                            2022-06-13 19:09:54.492 - debug: vedirect.0 (1717) No attribute changes for : I, processing normallly
                            2022-06-13 19:09:54.493 - debug: vedirect.0 (1717) Line : VPV 14470
                            2022-06-13 19:09:54.495 - debug: vedirect.0 (1717) [stateSetCreate]VPV with value : 14.47
                            2022-06-13 19:09:54.495 - debug: vedirect.0 (1717) No attribute changes for : VPV, processing normallly
                            2022-06-13 19:09:54.507 - debug: vedirect.0 (1717) Line : PPV 0
                            2022-06-13 19:09:54.508 - debug: vedirect.0 (1717) No case matched for PPV
                            2022-06-13 19:09:54.510 - debug: vedirect.0 (1717) [stateSetCreate]PPV with value : 0
                            2022-06-13 19:09:54.511 - debug: vedirect.0 (1717) No attribute changes for : PPV, processing normallly
                            2022-06-13 19:09:54.514 - debug: vedirect.0 (1717) Line : CS 3
                            2022-06-13 19:09:54.516 - debug: vedirect.0 (1717) Line : MPPT 2
                            2022-06-13 19:09:54.518 - debug: vedirect.0 (1717) [stateSetCreate]CS with value : Bulk
                            2022-06-13 19:09:54.519 - debug: vedirect.0 (1717) No attribute changes for : CS, processing normallly
                            2022-06-13 19:09:54.521 - debug: vedirect.0 (1717) [stateSetCreate]MPPT with value : MPP Tracker active
                            2022-06-13 19:09:54.522 - debug: vedirect.0 (1717) No attribute changes for : MPPT, processing normallly
                            2022-06-13 19:09:54.540 - debug: vedirect.0 (1717) Line : OR 0x00000000
                            2022-06-13 19:09:54.543 - debug: vedirect.0 (1717) Line : ERR 0
                            2022-06-13 19:09:54.545 - debug: vedirect.0 (1717) Line : LOAD ON
                            2022-06-13 19:09:54.546 - debug: vedirect.0 (1717) No case matched for LOAD
                            2022-06-13 19:09:54.547 - debug: vedirect.0 (1717) [stateSetCreate]LOAD with value : ON
                            2022-06-13 19:09:54.549 - debug: vedirect.0 (1717) No attribute changes for : LOAD, processing normallly
                            2022-06-13 19:09:54.551 - debug: vedirect.0 (1717) Line : IL 0
                            2022-06-13 19:09:54.552 - debug: vedirect.0 (1717) [stateSetCreate]IL with value : 0
                            2022-06-13 19:09:54.556 - debug: vedirect.0 (1717) No attribute changes for : IL, processing normallly
                            2022-06-13 19:09:54.559 - debug: vedirect.0 (1717) Line : H19 0
                            2022-06-13 19:09:54.560 - debug: vedirect.0 (1717) [stateSetCreate]H19 with value : 0
                            2022-06-13 19:09:54.561 - debug: vedirect.0 (1717) No attribute changes for : H19, processing normallly
                            2022-06-13 19:09:54.563 - debug: vedirect.0 (1717) Line : H20 0
                            2022-06-13 19:09:54.565 - debug: vedirect.0 (1717) [stateSetCreate]H20 with value : 0
                            2022-06-13 19:09:54.566 - debug: vedirect.0 (1717) No attribute changes for : H20, processing normallly
                            2022-06-13 19:09:54.568 - debug: vedirect.0 (1717) Line : H21 0
                            2022-06-13 19:09:54.569 - debug: vedirect.0 (1717) No case matched for H21
                            2022-06-13 19:09:54.569 - debug: vedirect.0 (1717) [stateSetCreate]H21 with value : 0
                            2022-06-13 19:09:54.570 - debug: vedirect.0 (1717) No attribute changes for : H21, processing normallly
                            2022-06-13 19:09:54.572 - debug: vedirect.0 (1717) Line : H22 0
                            2022-06-13 19:09:54.573 - debug: vedirect.0 (1717) [stateSetCreate]H22 with value : 0
                            2022-06-13 19:09:54.574 - debug: vedirect.0 (1717) No attribute changes for : H22, processing normallly
                            2022-06-13 19:09:54.576 - debug: vedirect.0 (1717) Line : H23 0
                            2022-06-13 19:09:54.577 - debug: vedirect.0 (1717) No case matched for H23
                            2022-06-13 19:09:54.578 - debug: vedirect.0 (1717) [stateSetCreate]H23 with value : 0
                            2022-06-13 19:09:54.578 - debug: vedirect.0 (1717) No attribute changes for : H23, processing normallly
                            2022-06-13 19:09:54.581 - debug: vedirect.0 (1717) [stateSetCreate]ERR with value : No Error
                            2022-06-13 19:09:54.582 - debug: vedirect.0 (1717) No attribute changes for : ERR, processing normallly
                            2022-06-13 19:09:54.583 - debug: vedirect.0 (1717) [stateSetCreate]OR with value : Normal Operation
                            2022-06-13 19:09:54.584 - debug: vedirect.0 (1717) No attribute changes for : OR, processing normallly
                            2022-06-13 19:09:54.611 - debug: vedirect.0 (1717) Line : HSDS 0
                            2022-06-13 19:09:54.612 - debug: vedirect.0 (1717) No case matched for HSDS
                            2022-06-13 19:09:54.613 - debug: vedirect.0 (1717) [stateSetCreate]HSDS with value : 0
                            2022-06-13 19:09:54.614 - debug: vedirect.0 (1717) No attribute changes for : HSDS, processing normallly
                            2022-06-13 19:09:55.446 - debug: vedirect.0 (1717) Line : Checksum ~
                            2022-06-13 19:09:55.448 - debug: vedirect.0 (1717) Line : PID 0xA060
                            2022-06-13 19:09:55.451 - debug: vedirect.0 (1717) [stateSetCreate]PID with value : SmartSolar MPPT 100|20 48V
                            2022-06-13 19:09:55.452 - debug: vedirect.0 (1717) No attribute changes for : PID, processing normallly
                            2022-06-13 19:09:55.462 - debug: vedirect.0 (1717) Line : FW 159
                            2022-06-13 19:09:55.464 - debug: vedirect.0 (1717) No case matched for FW
                            2022-06-13 19:09:55.465 - debug: vedirect.0 (1717) [stateSetCreate]FW with value : 159
                            2022-06-13 19:09:55.467 - debug: vedirect.0 (1717) No attribute changes for : FW, processing normallly
                            2022-06-13 19:09:55.472 - debug: vedirect.0 (1717) Line : SER# HQ2121KRGMY
                            2022-06-13 19:09:55.473 - debug: vedirect.0 (1717) No case matched for SER#
                            2022-06-13 19:09:55.474 - debug: vedirect.0 (1717) [stateSetCreate]SER# with value : HQ2121KRGMY
                            2022-06-13 19:09:55.475 - debug: vedirect.0 (1717) No attribute changes for : SER#, processing normallly
                            2022-06-13 19:09:55.480 - debug: vedirect.0 (1717) Line : V 12530
                            2022-06-13 19:09:55.482 - debug: vedirect.0 (1717) [stateSetCreate]V with value : 12.53
                            2022-06-13 19:09:55.483 - debug: vedirect.0 (1717) No attribute changes for : V, processing normallly
                            2022-06-13 19:09:55.509 - debug: vedirect.0 (1717) Line : I 0
                            2022-06-13 19:09:55.510 - debug: vedirect.0 (1717) [stateSetCreate]I with value : 0
                            2022-06-13 19:09:55.511 - debug: vedirect.0 (1717) No attribute changes for : I, processing normallly
                            2022-06-13 19:09:55.514 - debug: vedirect.0 (1717) Line : VPV 14470
                            2022-06-13 19:09:55.515 - debug: vedirect.0 (1717) [stateSetCreate]VPV with value : 14.47
                            2022-06-13 19:09:55.516 - debug: vedirect.0 (1717) No attribute changes for : VPV, processing normallly
                            2022-06-13 19:09:55.518 - debug: vedirect.0 (1717) Line : PPV 0
                            2022-06-13 19:09:55.519 - debug: vedirect.0 (1717) No case matched for PPV
                            2022-06-13 19:09:55.520 - debug: vedirect.0 (1717) [stateSetCreate]PPV with value : 0
                            2022-06-13 19:09:55.520 - debug: vedirect.0 (1717) No attribute changes for : PPV, processing normallly
                            2022-06-13 19:09:55.522 - debug: vedirect.0 (1717) Line : CS 3
                            2022-06-13 19:09:55.524 - debug: vedirect.0 (1717) [stateSetCreate]CS with value : Bulk
                            2022-06-13 19:09:55.525 - debug: vedirect.0 (1717) No attribute changes for : CS, processing normallly
                            2022-06-13 19:09:55.550 - debug: vedirect.0 (1717) Line : MPPT 2
                            2022-06-13 19:09:55.552 - debug: vedirect.0 (1717) Line : OR 0x00000000
                            2022-06-13 19:09:55.554 - debug: vedirect.0 (1717) Line : ERR 0
                            2022-06-13 19:09:55.556 - debug: vedirect.0 (1717) Line : LOAD ON
                            2022-06-13 19:09:55.557 - debug: vedirect.0 (1717) No case matched for LOAD
                            2022-06-13 19:09:55.558 - debug: vedirect.0 (1717) [stateSetCreate]LOAD with value : ON
                            2022-06-13 19:09:55.559 - debug: vedirect.0 (1717) No attribute changes for : LOAD, processing normallly
                            2022-06-13 19:09:55.561 - debug: vedirect.0 (1717) Line : IL 0
                            2022-06-13 19:09:55.562 - debug: vedirect.0 (1717) [stateSetCreate]IL with value : 0
                            2022-06-13 19:09:55.563 - debug: vedirect.0 (1717) No attribute changes for : IL, processing normallly
                            2022-06-13 19:09:55.565 - debug: vedirect.0 (1717) Line : H19 0
                            2022-06-13 19:09:55.567 - debug: vedirect.0 (1717) [stateSetCreate]H19 with value : 0
                            2022-06-13 19:09:55.567 - debug: vedirect.0 (1717) No attribute changes for : H19, processing normallly
                            2022-06-13 19:09:55.570 - debug: vedirect.0 (1717) Line : H20 0
                            2022-06-13 19:09:55.571 - debug: vedirect.0 (1717) [stateSetCreate]H20 with value : 0
                            2022-06-13 19:09:55.571 - debug: vedirect.0 (1717) No attribute changes for : H20, processing normallly
                            2022-06-13 19:09:55.573 - debug: vedirect.0 (1717) Line : H21 0
                            2022-06-13 19:09:55.574 - debug: vedirect.0 (1717) No case matched for H21
                            2022-06-13 19:09:55.575 - debug: vedirect.0 (1717) [stateSetCreate]H21 with value : 0
                            2022-06-13 19:09:55.575 - debug: vedirect.0 (1717) No attribute changes for : H21, processing normallly
                            2022-06-13 19:09:55.577 - debug: vedirect.0 (1717) Line : H22 0
                            2022-06-13 19:09:55.578 - debug: vedirect.0 (1717) [stateSetCreate]H22 with value : 0
                            2022-06-13 19:09:55.579 - debug: vedirect.0 (1717) No attribute changes for : H22, processing normallly
                            2022-06-13 19:09:55.581 - debug: vedirect.0 (1717) Line : H23 0
                            2022-06-13 19:09:55.582 - debug: vedirect.0 (1717) No case matched for H23
                            2022-06-13 19:09:55.582 - debug: vedirect.0 (1717) [stateSetCreate]H23 with value : 0
                            2022-06-13 19:09:55.583 - debug: vedirect.0 (1717) No attribute changes for : H23, processing normallly
                            2022-06-13 19:09:55.584 - debug: vedirect.0 (1717) Line : HSDS 0
                            2022-06-13 19:09:55.585 - debug: vedirect.0 (1717) No case matched for HSDS
                            2022-06-13 19:09:55.586 - debug: vedirect.0 (1717) [stateSetCreate]HSDS with value : 0
                            2022-06-13 19:09:55.587 - debug: vedirect.0 (1717) No attribute changes for : HSDS, processing normallly
                            2022-06-13 19:09:55.589 - debug: vedirect.0 (1717) [stateSetCreate]MPPT with value : MPP Tracker active
                            2022-06-13 19:09:55.589 - debug: vedirect.0 (1717) No attribute changes for : MPPT, processing normallly
                            2022-06-13 19:09:55.591 - debug: vedirect.0 (1717) [stateSetCreate]ERR with value : No Error
                            2022-06-13 19:09:55.592 - debug: vedirect.0 (1717) No attribute changes for : ERR, processing normallly
                            2022-06-13 19:09:55.593 - debug: vedirect.0 (1717) [stateSetCreate]OR with value : Normal Operation
                            2022-06-13 19:09:55.594 - debug: vedirect.0 (1717) No attribute changes for : OR, processing normallly
                            2022-06-13 19:09:56.455 - debug: vedirect.0 (1717) Line : Checksum �
                            2022-06-13 19:09:56.458 - debug: vedirect.0 (1717) Line : PID 0xA060
                            2022-06-13 19:09:56.460 - debug: vedirect.0 (1717) Line : FW 159
                            2022-06-13 19:09:56.461 - debug: vedirect.0 (1717) No case matched for FW
                            2022-06-13 19:09:56.461 - debug: vedirect.0 (1717) [stateSetCreate]FW with value : 159
                            2022-06-13 19:09:56.462 - debug: vedirect.0 (1717) No attribute changes for : FW, processing normallly
                            2022-06-13 19:09:56.464 - debug: vedirect.0 (1717) [stateSetCreate]PID with value : SmartSolar MPPT 100|20 48V
                            2022-06-13 19:09:56.466 - debug: vedirect.0 (1717) No attribute changes for : PID, processing normallly
                            2022-06-13 19:09:56.487 - debug: vedirect.0 (1717) Line : SER# HQ2121KRGMY
                            2022-06-13 19:09:56.489 - debug: vedirect.0 (1717) No case matched for SER#
                            2022-06-13 19:09:56.490 - debug: vedirect.0 (1717) [stateSetCreate]SER# with value : HQ2121KRGMY
                            2022-06-13 19:09:56.492 - debug: vedirect.0 (1717) No attribute changes for : SER#, processing normallly
                            2022-06-13 19:09:56.496 - debug: vedirect.0 (1717) Line : V 12610
                            2022-06-13 19:09:56.499 - debug: vedirect.0 (1717) [stateSetCreate]V with value : 12.61
                            2022-06-13 19:09:56.500 - debug: vedirect.0 (1717) No attribute changes for : V, processing normallly
                            2022-06-13 19:09:56.503 - debug: vedirect.0 (1717) Line : I 0
                            2022-06-13 19:09:56.505 - debug: vedirect.0 (1717) [stateSetCreate]I with value : 0
                            2022-06-13 19:09:56.506 - debug: vedirect.0 (1717) No attribute changes for : I, processing normallly
                            2022-06-13 19:09:56.508 - debug: vedirect.0 (1717) Line : VPV 14470
                            2022-06-13 19:09:56.510 - debug: vedirect.0 (1717) [stateSetCreate]VPV with value : 14.47
                            2022-06-13 19:09:56.511 - debug: vedirect.0 (1717) No attribute changes for : VPV, processing normallly
                            2022-06-13 19:09:56.513 - debug: vedirect.0 (1717) Line : PPV 0
                            2022-06-13 19:09:56.515 - debug: vedirect.0 (1717) No case matched for PPV
                            2022-06-13 19:09:56.516 - debug: vedirect.0 (1717) [stateSetCreate]PPV with value : 0
                            2022-06-13 19:09:56.516 - debug: vedirect.0 (1717) No attribute changes for : PPV, processing normallly
                            2022-06-13 19:09:56.519 - debug: vedirect.0 (1717) Line : CS 3
                            2022-06-13 19:09:56.522 - debug: vedirect.0 (1717) Line : MPPT 2
                            2022-06-13 19:09:56.524 - debug: vedirect.0 (1717) [stateSetCreate]CS with value : Bulk
                            2022-06-13 19:09:56.525 - debug: vedirect.0 (1717) No attribute changes for : CS, processing normallly
                            2022-06-13 19:09:56.528 - debug: vedirect.0 (1717) [stateSetCreate]MPPT with value : MPP Tracker active
                            2022-06-13 19:09:56.529 - debug: vedirect.0 (1717) No attribute changes for : MPPT, processing normallly
                            2022-06-13 19:09:56.543 - debug: vedirect.0 (1717) Line : OR 0x00000000
                            2022-06-13 19:09:56.545 - debug: vedirect.0 (1717) Line : ERR 0
                            2022-06-13 19:09:56.547 - debug: vedirect.0 (1717) Line : LOAD ON
                            2022-06-13 19:09:56.548 - debug: vedirect.0 (1717) No case matched for LOAD
                            2022-06-13 19:09:56.549 - debug: vedirect.0 (1717) [stateSetCreate]LOAD with value : ON
                            2022-06-13 19:09:56.551 - debug: vedirect.0 (1717) No attribute changes for : LOAD, processing normallly
                            2022-06-13 19:09:56.553 - debug: vedirect.0 (1717) Line : IL 0
                            2022-06-13 19:09:56.554 - debug: vedirect.0 (1717) [stateSetCreate]IL with value : 0
                            2022-06-13 19:09:56.555 - debug: vedirect.0 (1717) No attribute changes for : IL, processing normallly
                            2022-06-13 19:09:56.558 - debug: vedirect.0 (1717) Line : H19 0
                            2022-06-13 19:09:56.559 - debug: vedirect.0 (1717) [stateSetCreate]H19 with value : 0
                            2022-06-13 19:09:56.560 - debug: vedirect.0 (1717) No attribute changes for : H19, processing normallly
                            2022-06-13 19:09:56.561 - debug: vedirect.0 (1717) Line : H20 0
                            2022-06-13 19:09:56.562 - debug: vedirect.0 (1717) [stateSetCreate]H20 with value : 0
                            2022-06-13 19:09:56.563 - debug: vedirect.0 (1717) No attribute changes for : H20, processing normallly
                            2022-06-13 19:09:56.564 - debug: vedirect.0 (1717) Line : H21 0
                            2022-06-13 19:09:56.565 - debug: vedirect.0 (1717) No case matched for H21
                            2022-06-13 19:09:56.566 - debug: vedirect.0 (1717) [stateSetCreate]H21 with value : 0
                            2022-06-13 19:09:56.566 - debug: vedirect.0 (1717) No attribute changes for : H21, processing normallly
                            2022-06-13 19:09:56.568 - debug: vedirect.0 (1717) Line : H22 0
                            2022-06-13 19:09:56.569 - debug: vedirect.0 (1717) [stateSetCreate]H22 with value : 0
                            2022-06-13 19:09:56.569 - debug: vedirect.0 (1717) No attribute changes for : H22, processing normallly
                            2022-06-13 19:09:56.571 - debug: vedirect.0 (1717) [stateSetCreate]ERR with value : No Error
                            2022-06-13 19:09:56.572 - debug: vedirect.0 (1717) No attribute changes for : ERR, processing normallly
                            2022-06-13 19:09:56.573 - debug: vedirect.0 (1717) [stateSetCreate]OR with value : Normal Operation
                            2022-06-13 19:09:56.574 - debug: vedirect.0 (1717) No attribute changes for : OR, processing normallly
                            2022-06-13 19:09:56.593 - debug: vedirect.0 (1717) Line : H23 0
                            2022-06-13 19:09:56.594 - debug: vedirect.0 (1717) No case matched for H23
                            2022-06-13 19:09:56.595 - debug: vedirect.0 (1717) [stateSetCreate]H23 with value : 0
                            2022-06-13 19:09:56.596 - debug: vedirect.0 (1717) No attribute changes for : H23, processing normallly
                            2022-06-13 19:09:56.597 - debug: vedirect.0 (1717) Line : HSDS 0
                            2022-06-13 19:09:56.598 - debug: vedirect.0 (1717) No case matched for HSDS
                            2022-06-13 19:09:56.600 - debug: vedirect.0 (1717) [stateSetCreate]HSDS with value : 0
                            2022-06-13 19:09:56.601 - debug: vedirect.0 (1717) No attribute changes for : HSDS, processing normallly
                            2022-06-13 19:09:57.448 - debug: vedirect.0 (1717) Line : Checksum �
                            2022-06-13 19:09:57.450 - debug: vedirect.0 (1717) Line : PID 0xA060
                            2022-06-13 19:09:57.453 - debug: vedirect.0 (1717) [stateSetCreate]PID with value : SmartSolar MPPT 100|20 48V
                            2022-06-13 19:09:57.454 - debug: vedirect.0 (1717) No attribute changes for : PID, processing normallly
                            2022-06-13 19:09:57.467 - debug: vedirect.0 (1717) Line : FW 159
                            2022-06-13 19:09:57.469 - debug: vedirect.0 (1717) No case matched for FW
                            2022-06-13 19:09:57.471 - debug: vedirect.0 (1717) [stateSetCreate]FW with value : 159
                            2022-06-13 19:09:57.472 - debug: vedirect.0 (1717) No attribute changes for : FW, processing normallly
                            2022-06-13 19:09:57.475 - debug: vedirect.0 (1717) Line : SER# HQ2121KRGMY
                            2022-06-13 19:09:57.476 - debug: vedirect.0 (1717) No case matched for SER#
                            2022-06-13 19:09:57.477 - debug: vedirect.0 (1717) [stateSetCreate]SER# with value : HQ2121KRGMY
                            2022-06-13 19:09:57.478 - debug: vedirect.0 (1717) No attribute changes for : SER#, processing normallly
                            2022-06-13 19:09:57.486 - debug: vedirect.0 (1717) Line : V 12700
                            2022-06-13 19:09:57.488 - debug: vedirect.0 (1717) [stateSetCreate]V with value : 12.7
                            2022-06-13 19:09:57.491 - debug: vedirect.0 (1717) No attribute changes for : V, processing normallly
                            2022-06-13 19:09:57.494 - debug: vedirect.0 (1717) Line : I 0
                            2022-06-13 19:09:57.496 - debug: vedirect.0 (1717) [stateSetCreate]I with value : 0
                            2022-06-13 19:09:57.497 - debug: vedirect.0 (1717) No attribute changes for : I, processing normallly
                            2022-06-13 19:09:57.500 - debug: vedirect.0 (1717) Line : VPV 14470
                            2022-06-13 19:09:57.501 - debug: vedirect.0 (1717) [stateSetCreate]VPV with value : 14.47
                            2022-06-13 19:09:57.502 - debug: vedirect.0 (1717) No attribute changes for : VPV, processing normallly
                            2022-06-13 19:09:57.505 - debug: vedirect.0 (1717) Line : PPV 0
                            2022-06-13 19:09:57.506 - debug: vedirect.0 (1717) No case matched for PPV
                            2022-06-13 19:09:57.507 - debug: vedirect.0 (1717) [stateSetCreate]PPV with value : 0
                            2022-06-13 19:09:57.508 - debug: vedirect.0 (1717) No attribute changes for : PPV, processing normallly
                            2022-06-13 19:09:57.526 - debug: vedirect.0 (1717) Line : CS 3
                            2022-06-13 19:09:57.528 - debug: vedirect.0 (1717) Line : MPPT 2
                            2022-06-13 19:09:57.530 - debug: vedirect.0 (1717) Line : OR 0x00000000
                            2022-06-13 19:09:57.533 - debug: vedirect.0 (1717) [stateSetCreate]CS with value : Bulk
                            2022-06-13 19:09:57.534 - debug: vedirect.0 (1717) No attribute changes for : CS, processing normallly
                            2022-06-13 19:09:57.538 - debug: vedirect.0 (1717) [stateSetCreate]MPPT with value : MPP Tracker active
                            2022-06-13 19:09:57.540 - debug: vedirect.0 (1717) No attribute changes for : MPPT, processing normallly
                            2022-06-13 19:09:57.544 - debug: vedirect.0 (1717) [stateSetCreate]OR with value : Normal Operation
                            2022-06-13 19:09:57.545 - debug: vedirect.0 (1717) No attribute changes for : OR, processing normallly
                            2022-06-13 19:09:57.564 - debug: vedirect.0 (1717) Line : ERR 0
                            2022-06-13 19:09:57.567 - debug: vedirect.0 (1717) Line : LOAD ON
                            2022-06-13 19:09:57.568 - debug: vedirect.0 (1717) No case matched for LOAD
                            2022-06-13 19:09:57.570 - debug: vedirect.0 (1717) [stateSetCreate]LOAD with value : ON
                            2022-06-13 19:09:57.572 - debug: vedirect.0 (1717) No attribute changes for : LOAD, processing normallly
                            2022-06-13 19:09:57.574 - debug: vedirect.0 (1717) Line : IL 0
                            2022-06-13 19:09:57.575 - debug: vedirect.0 (1717) [stateSetCreate]IL with value : 0
                            2022-06-13 19:09:57.576 - debug: vedirect.0 (1717) No attribute changes for : IL, processing normallly
                            2022-06-13 19:09:57.578 - debug: vedirect.0 (1717) Line : H19 0
                            2022-06-13 19:09:57.579 - debug: vedirect.0 (1717) [stateSetCreate]H19 with value : 0
                            2022-06-13 19:09:57.579 - debug: vedirect.0 (1717) No attribute changes for : H19, processing normallly
                            2022-06-13 19:09:57.581 - debug: vedirect.0 (1717) Line : H20 0
                            2022-06-13 19:09:57.582 - debug: vedirect.0 (1717) [stateSetCreate]H20 with value : 0
                            2022-06-13 19:09:57.582 - debug: vedirect.0 (1717) No attribute changes for : H20, processing normallly
                            2022-06-13 19:09:57.584 - debug: vedirect.0 (1717) Line : H21 0
                            2022-06-13 19:09:57.585 - debug: vedirect.0 (1717) No case matched for H21
                            2022-06-13 19:09:57.585 - debug: vedirect.0 (1717) [stateSetCreate]H21 with value : 0
                            2022-06-13 19:09:57.585 - debug: vedirect.0 (1717) No attribute changes for : H21, processing normallly
                            2022-06-13 19:09:57.587 - debug: vedirect.0 (1717) Line : H22 0
                            2022-06-13 19:09:57.588 - debug: vedirect.0 (1717) [stateSetCreate]H22 with value : 0
                            2022-06-13 19:09:57.588 - debug: vedirect.0 (1717) No attribute changes for : H22, processing normallly
                            2022-06-13 19:09:57.590 - debug: vedirect.0 (1717) Line : H23 0
                            2022-06-13 19:09:57.591 - debug: vedirect.0 (1717) No case matched for H23
                            2022-06-13 19:09:57.591 - debug: vedirect.0 (1717) [stateSetCreate]H23 with value : 0
                            2022-06-13 19:09:57.592 - debug: vedirect.0 (1717) No attribute changes for : H23, processing normallly
                            2022-06-13 19:09:57.593 - debug: vedirect.0 (1717) Line : HSDS 0
                            2022-06-13 19:09:57.594 - debug: vedirect.0 (1717) No case matched for HSDS
                            2022-06-13 19:09:57.595 - debug: vedirect.0 (1717) [stateSetCreate]HSDS with value : 0
                            2022-06-13 19:09:57.595 - debug: vedirect.0 (1717) No attribute changes for : HSDS, processing normallly
                            2022-06-13 19:09:57.596 - debug: vedirect.0 (1717) [stateSetCreate]ERR with value : No Error
                            2022-06-13 19:09:57.597 - debug: vedirect.0 (1717) No attribute changes for : ERR, processing normallly
                            2022-06-13 19:09:58.455 - debug: vedirect.0 (1717) Line : Checksum �
                            2022-06-13 19:09:58.458 - debug: vedirect.0 (1717) Line : PID 0xA060
                            2022-06-13 19:09:58.459 - debug: vedirect.0 (1717) Line : FW 159
                            2022-06-13 19:09:58.461 - debug: vedirect.0 (1717) No case matched for FW
                            2022-06-13 19:09:58.461 - debug: vedirect.0 (1717) [stateSetCreate]FW with value : 159
                            2022-06-13 19:09:58.462 - debug: vedirect.0 (1717) No attribute changes for : FW, processing normallly
                            2022-06-13 19:09:58.464 - debug: vedirect.0 (1717) [stateSetCreate]PID with value : SmartSolar MPPT 100|20 48V
                            2022-06-13 19:09:58.465 - debug: vedirect.0 (1717) No attribute changes for : PID, processing normallly
                            2022-06-13 19:09:58.474 - debug: vedirect.0 (1717) Line : SER# HQ2121KRGMY
                            2022-06-13 19:09:58.478 - debug: vedirect.0 (1717) No case matched for SER#
                            2022-06-13 19:09:58.480 - debug: vedirect.0 (1717) [stateSetCreate]SER# with value : HQ2121KRGMY
                            2022-06-13 19:09:58.481 - debug: vedirect.0 (1717) No attribute changes for : SER#, processing normallly
                            2022-06-13 19:09:58.484 - debug: vedirect.0 (1717) Line : V 12760
                            2022-06-13 19:09:58.485 - debug: vedirect.0 (1717) [stateSetCreate]V with value : 12.76
                            2022-06-13 19:09:58.486 - debug: vedirect.0 (1717) No attribute changes for : V, processing normallly
                            2022-06-13 19:09:58.488 - debug: vedirect.0 (1717) Line : I 0
                            2022-06-13 19:09:58.489 - debug: vedirect.0 (1717) [stateSetCreate]I with value : 0
                            2022-06-13 19:09:58.490 - debug: vedirect.0 (1717) No attribute changes for : I, processing normallly
                            2022-06-13 19:09:58.495 - debug: vedirect.0 (1717) Line : VPV 14470
                            2022-06-13 19:09:58.496 - debug: vedirect.0 (1717) [stateSetCreate]VPV with value : 14.47
                            2022-06-13 19:09:58.496 - debug: vedirect.0 (1717) No attribute changes for : VPV, processing normallly
                            2022-06-13 19:09:58.498 - debug: vedirect.0 (1717) Line : PPV 0
                            2022-06-13 19:09:58.499 - debug: vedirect.0 (1717) No case matched for PPV
                            2022-06-13 19:09:58.501 - debug: vedirect.0 (1717) [stateSetCreate]PPV with value : 0
                            2022-06-13 19:09:58.501 - debug: vedirect.0 (1717) No attribute changes for : PPV, processing normallly
                            2022-06-13 19:09:58.503 - debug: vedirect.0 (1717) Line : CS 3
                            2022-06-13 19:09:58.505 - debug: vedirect.0 (1717) Line : MPPT 2
                            2022-06-13 19:09:58.507 - debug: vedirect.0 (1717) [stateSetCreate]CS with value : Bulk
                            2022-06-13 19:09:58.508 - debug: vedirect.0 (1717) No attribute changes for : CS, processing normallly
                            2022-06-13 19:09:58.509 - debug: vedirect.0 (1717) [stateSetCreate]MPPT with value : MPP Tracker active
                            2022-06-13 19:09:58.510 - debug: vedirect.0 (1717) No attribute changes for : MPPT, processing normallly
                            2022-06-13 19:09:58.526 - debug: vedirect.0 (1717) Line : OR 0x00000000
                            2022-06-13 19:09:58.528 - debug: vedirect.0 (1717) Line : ERR 0
                            2022-06-13 19:09:58.529 - debug: vedirect.0 (1717) Line : LOAD ON
                            2022-06-13 19:09:58.530 - debug: vedirect.0 (1717) No case matched for LOAD
                            2022-06-13 19:09:58.531 - debug: vedirect.0 (1717) [stateSetCreate]LOAD with value : ON
                            2022-06-13 19:09:58.532 - debug: vedirect.0 (1717) No attribute changes for : LOAD, processing normallly
                            2022-06-13 19:09:58.534 - debug: vedirect.0 (1717) [stateSetCreate]ERR with value : No Error
                            2022-06-13 19:09:58.535 - debug: vedirect.0 (1717) No attribute changes for : ERR, processing normallly
                            2022-06-13 19:09:58.536 - debug: vedirect.0 (1717) [stateSetCreate]OR with value : Normal Operation
                            2022-06-13 19:09:58.537 - debug: vedirect.0 (1717) No attribute changes for : OR, processing normallly
                            2022-06-13 19:09:58.546 - debug: vedirect.0 (1717) Line : IL 0
                            2022-06-13 19:09:58.547 - debug: vedirect.0 (1717) [stateSetCreate]IL with value : 0
                            2022-06-13 19:09:58.548 - debug: vedirect.0 (1717) No attribute changes for : IL, processing normallly
                            2022-06-13 19:09:58.551 - debug: vedirect.0 (1717) Line : H19 0
                            2022-06-13 19:09:58.552 - debug: vedirect.0 (1717) [stateSetCreate]H19 with value : 0
                            2022-06-13 19:09:58.553 - debug: vedirect.0 (1717) No attribute changes for : H19, processing normallly
                            2022-06-13 19:09:58.556 - debug: vedirect.0 (1717) Line : H20 0
                            2022-06-13 19:09:58.556 - debug: vedirect.0 (1717) [stateSetCreate]H20 with value : 0
                            2022-06-13 19:09:58.560 - debug: vedirect.0 (1717) No attribute changes for : H20, processing normallly
                            2022-06-13 19:09:58.563 - debug: vedirect.0 (1717) Line : H21 0
                            2022-06-13 19:09:58.564 - debug: vedirect.0 (1717) No case matched for H21
                            2022-06-13 19:09:58.565 - debug: vedirect.0 (1717) [stateSetCreate]H21 with value : 0
                            2022-06-13 19:09:58.566 - debug: vedirect.0 (1717) No attribute changes for : H21, processing normallly
                            2022-06-13 19:09:58.569 - debug: vedirect.0 (1717) Line : H22 0
                            2022-06-13 19:09:58.570 - debug: vedirect.0 (1717) [stateSetCreate]H22 with value : 0
                            2022-06-13 19:09:58.571 - debug: vedirect.0 (1717) No attribute changes for : H22, processing normallly
                            2022-06-13 19:09:58.575 - debug: vedirect.0 (1717) Line : H23 0
                            2022-06-13 19:09:58.576 - debug: vedirect.0 (1717) No case matched for H23
                            2022-06-13 19:09:58.576 - debug: vedirect.0 (1717) [stateSetCreate]H23 with value : 0
                            2022-06-13 19:09:58.577 - debug: vedirect.0 (1717) No attribute changes for : H23, processing normallly
                            2022-06-13 19:09:58.578 - debug: vedirect.0 (1717) Line : HSDS 0
                            2022-06-13 19:09:58.579 - debug: vedirect.0 (1717) No case matched for HSDS
                            2022-06-13 19:09:58.580 - debug: vedirect.0 (1717) [stateSetCreate]HSDS with value : 0
                            2022-06-13 19:09:58.580 - debug: vedirect.0 (1717) No attribute changes for : HSDS, processing normallly
                            2022-06-13 19:09:59.448 - debug: vedirect.0 (1717) Line : Checksum |
                            2022-06-13 19:09:59.466 - debug: vedirect.0 (1717) Line : PID 0xA060
                            2022-06-13 19:09:59.468 - debug: vedirect.0 (1717) Line : FW 159
                            2022-06-13 19:09:59.470 - debug: vedirect.0 (1717) No case matched for FW
                            2022-06-13 19:09:59.471 - debug: vedirect.0 (1717) [stateSetCreate]FW with value : 159
                            2022-06-13 19:09:59.472 - debug: vedirect.0 (1717) No attribute changes for : FW, processing normallly
                            2022-06-13 19:09:59.474 - debug: vedirect.0 (1717) Line : SER# HQ2121KRGMY
                            2022-06-13 19:09:59.476 - debug: vedirect.0 (1717) No case matched for SER#
                            2022-06-13 19:09:59.477 - debug: vedirect.0 (1717) [stateSetCreate]SER# with value : HQ2121KRGMY
                            2022-06-13 19:09:59.478 - debug: vedirect.0 (1717) No attribute changes for : SER#, processing normallly
                            2022-06-13 19:09:59.481 - debug: vedirect.0 (1717) [stateSetCreate]PID with value : SmartSolar MPPT 100|20 48V
                            2022-06-13 19:09:59.482 - debug: vedirect.0 (1717) No attribute changes for : PID, processing normallly
                            2022-06-13 19:09:59.492 - debug: vedirect.0 (1717) Line : V 12800
                            2022-06-13 19:09:59.494 - debug: vedirect.0 (1717) [stateSetCreate]V with value : 12.8
                            2022-06-13 19:09:59.496 - debug: vedirect.0 (1717) No attribute changes for : V, processing normallly
                            2022-06-13 19:09:59.500 - debug: vedirect.0 (1717) Line : I 0
                            2022-06-13 19:09:59.502 - debug: vedirect.0 (1717) [stateSetCreate]I with value : 0
                            2022-06-13 19:09:59.504 - debug: vedirect.0 (1717) No attribute changes for : I, processing normallly
                            2022-06-13 19:09:59.507 - debug: vedirect.0 (1717) Line : VPV 14470
                            2022-06-13 19:09:59.508 - debug: vedirect.0 (1717) [stateSetCreate]VPV with value : 14.47
                            2022-06-13 19:09:59.509 - debug: vedirect.0 (1717) No attribute changes for : VPV, processing normallly
                            2022-06-13 19:09:59.522 - debug: vedirect.0 (1717) Line : PPV 0
                            2022-06-13 19:09:59.523 - debug: vedirect.0 (1717) No case matched for PPV
                            2022-06-13 19:09:59.526 - debug: vedirect.0 (1717) [stateSetCreate]PPV with value : 0
                            2022-06-13 19:09:59.527 - debug: vedirect.0 (1717) No attribute changes for : PPV, processing normallly
                            2022-06-13 19:09:59.529 - debug: vedirect.0 (1717) Line : CS 3
                            2022-06-13 19:09:59.531 - debug: vedirect.0 (1717) Line : MPPT 2
                            2022-06-13 19:09:59.532 - debug: vedirect.0 (1717) Line : OR 0x00000000
                            2022-06-13 19:09:59.534 - debug: vedirect.0 (1717) Line : ERR 0
                            2022-06-13 19:09:59.536 - debug: vedirect.0 (1717) Line : LOAD ON
                            2022-06-13 19:09:59.536 - debug: vedirect.0 (1717) No case matched for LOAD
                            2022-06-13 19:09:59.537 - debug: vedirect.0 (1717) [stateSetCreate]LOAD with value : ON
                            2022-06-13 19:09:59.538 - debug: vedirect.0 (1717) No attribute changes for : LOAD, processing normallly
                            2022-06-13 19:09:59.539 - debug: vedirect.0 (1717) Line : IL 0
                            2022-06-13 19:09:59.540 - debug: vedirect.0 (1717) [stateSetCreate]IL with value : 0
                            2022-06-13 19:09:59.540 - debug: vedirect.0 (1717) No attribute changes for : IL, processing normallly
                            2022-06-13 19:09:59.542 - debug: vedirect.0 (1717) Line : H19 0
                            2022-06-13 19:09:59.542 - debug: vedirect.0 (1717) [stateSetCreate]H19 with value : 0
                            2022-06-13 19:09:59.543 - debug: vedirect.0 (1717) No attribute changes for : H19, processing normallly
                            2022-06-13 19:09:59.544 - debug: vedirect.0 (1717) [stateSetCreate]CS with value : Bulk
                            2022-06-13 19:09:59.545 - debug: vedirect.0 (1717) No attribute changes for : CS, processing normallly
                            2022-06-13 19:09:59.546 - debug: vedirect.0 (1717) [stateSetCreate]MPPT with value : MPP Tracker active
                            2022-06-13 19:09:59.547 - debug: vedirect.0 (1717) No attribute changes for : MPPT, processing normallly
                            2022-06-13 19:09:59.552 - debug: vedirect.0 (1717) [stateSetCreate]ERR with value : No Error
                            2022-06-13 19:09:59.553 - debug: vedirect.0 (1717) No attribute changes for : ERR, processing normallly
                            2022-06-13 19:09:59.555 - debug: vedirect.0 (1717) [stateSetCreate]OR with value : Normal Operation
                            2022-06-13 19:09:59.556 - debug: vedirect.0 (1717) No attribute changes for : OR, processing normallly
                            2022-06-13 19:09:59.576 - debug: vedirect.0 (1717) Line : H20 0
                            2022-06-13 19:09:59.578 - debug: vedirect.0 (1717) [stateSetCreate]H20 with value : 0
                            2022-06-13 19:09:59.579 - debug: vedirect.0 (1717) No attribute changes for : H20, processing normallly
                            2022-06-13 19:09:59.580 - debug: vedirect.0 (1717) Line : H21 0
                            2022-06-13 19:09:59.581 - debug: vedirect.0 (1717) No case matched for H21
                            2022-06-13 19:09:59.582 - debug: vedirect.0 (1717) [stateSetCreate]H21 with value : 0
                            2022-06-13 19:09:59.583 - debug: vedirect.0 (1717) No attribute changes for : H21, processing normallly
                            2022-06-13 19:09:59.585 - debug: vedirect.0 (1717) Line : H22 0
                            2022-06-13 19:09:59.587 - debug: vedirect.0 (1717) [stateSetCreate]H22 with value : 0
                            2022-06-13 19:09:59.588 - debug: vedirect.0 (1717) No attribute changes for : H22, processing normallly
                            2022-06-13 19:09:59.592 - debug: vedirect.0 (1717) Line : H23 0
                            2022-06-13 19:09:59.593 - debug: vedirect.0 (1717) No case matched for H23
                            2022-06-13 19:09:59.594 - debug: vedirect.0 (1717) [stateSetCreate]H23 with value : 0
                            2022-06-13 19:09:59.595 - debug: vedirect.0 (1717) No attribute changes for : H23, processing normallly
                            2022-06-13 19:09:59.598 - debug: vedirect.0 (1717) Line : HSDS 0
                            2022-06-13 19:09:59.599 - debug: vedirect.0 (1717) No case matched for HSDS
                            2022-06-13 19:09:59.600 - debug: vedirect.0 (1717) [stateSetCreate]HSDS with value : 0
                            2022-06-13 19:09:59.601 - debug: vedirect.0 (1717) No attribute changes for : HSDS, processing normallly
                            2022-06-13 19:10:00.458 - debug: vedirect.0 (1717) Line : Checksum �
                            2022-06-13 19:10:00.460 - debug: vedirect.0 (1717) Line : PID 0xA060
                            2022-06-13 19:10:00.462 - debug: vedirect.0 (1717) Line : FW 159
                            2022-06-13 19:10:00.463 - debug: vedirect.0 (1717) No case matched for FW
                            2022-06-13 19:10:00.464 - debug: vedirect.0 (1717) [stateSetCreate]FW with value : 159
                            2022-06-13 19:10:00.465 - debug: vedirect.0 (1717) No attribute changes for : FW, processing normallly
                            2022-06-13 19:10:00.468 - debug: vedirect.0 (1717) [stateSetCreate]PID with value : SmartSolar MPPT 100|20 48V
                            2022-06-13 19:10:00.469 - debug: vedirect.0 (1717) No attribute changes for : PID, processing normallly
                            2022-06-13 19:10:00.480 - debug: vedirect.0 (1717) Line : SER# HQ2121KRGMY
                            2022-06-13 19:10:00.482 - debug: vedirect.0 (1717) No case matched for SER#
                            2022-06-13 19:10:00.483 - debug: vedirect.0 (1717) [stateSetCreate]SER# with value : HQ2121KRGMY
                            2022-06-13 19:10:00.484 - debug: vedirect.0 (1717) No attribute changes for : SER#, processing normallly
                            2022-06-13 19:10:00.487 - debug: vedirect.0 (1717) Line : V 12850
                            2022-06-13 19:10:00.489 - debug: vedirect.0 (1717) [stateSetCreate]V with value : 12.85
                            2022-06-13 19:10:00.490 - debug: vedirect.0 (1717) No attribute changes for : V, processing normallly
                            2022-06-13 19:10:00.498 - debug: vedirect.0 (1717) Line : I 0
                            2022-06-13 19:10:00.499 - debug: vedirect.0 (1717) [stateSetCreate]I with value : 0
                            2022-06-13 19:10:00.501 - debug: vedirect.0 (1717) No attribute changes for : I, processing normallly
                            2022-06-13 19:10:00.504 - debug: vedirect.0 (1717) Line : VPV 14470
                            2022-06-13 19:10:00.505 - debug: vedirect.0 (1717) [stateSetCreate]VPV with value : 14.47
                            2022-06-13 19:10:00.507 - debug: vedirect.0 (1717) No attribute changes for : VPV, processing normallly
                            2022-06-13 19:10:00.509 - debug: vedirect.0 (1717) Line : PPV 0
                            2022-06-13 19:10:00.511 - debug: vedirect.0 (1717) No case matched for PPV
                            2022-06-13 19:10:00.512 - debug: vedirect.0 (1717) [stateSetCreate]PPV with value : 0
                            2022-06-13 19:10:00.513 - debug: vedirect.0 (1717) No attribute changes for : PPV, processing normallly
                            2022-06-13 19:10:00.516 - debug: vedirect.0 (1717) Line : CS 3
                            2022-06-13 19:10:00.518 - debug: vedirect.0 (1717) [stateSetCreate]CS with value : Bulk
                            2022-06-13 19:10:00.520 - debug: vedirect.0 (1717) No attribute changes for : CS, processing normallly
                            2022-06-13 19:10:00.531 - debug: vedirect.0 (1717) Line : MPPT 2
                            2022-06-13 19:10:00.533 - debug: vedirect.0 (1717) Line : OR 0x00000000
                            2022-06-13 19:10:00.538 - debug: vedirect.0 (1717) Line : ERR 0
                            2022-06-13 19:10:00.543 - debug: vedirect.0 (1717) Line : LOAD ON
                            2022-06-13 19:10:00.544 - debug: vedirect.0 (1717) No case matched for LOAD
                            2022-06-13 19:10:00.545 - debug: vedirect.0 (1717) [stateSetCreate]LOAD with value : ON
                            2022-06-13 19:10:00.547 - debug: vedirect.0 (1717) No attribute changes for : LOAD, processing normallly
                            2022-06-13 19:10:00.550 - debug: vedirect.0 (1717) Line : IL 0
                            2022-06-13 19:10:00.551 - debug: vedirect.0 (1717) [stateSetCreate]IL with value : 0
                            2022-06-13 19:10:00.552 - debug: vedirect.0 (1717) No attribute changes for : IL, processing normallly
                            2022-06-13 19:10:00.554 - debug: vedirect.0 (1717) Line : H19 0
                            2022-06-13 19:10:00.555 - debug: vedirect.0 (1717) [stateSetCreate]H19 with value : 0
                            2022-06-13 19:10:00.556 - debug: vedirect.0 (1717) No attribute changes for : H19, processing normallly
                            2022-06-13 19:10:00.558 - debug: vedirect.0 (1717) Line : H20 0
                            2022-06-13 19:10:00.559 - debug: vedirect.0 (1717) [stateSetCreate]H20 with value : 0
                            2022-06-13 19:10:00.560 - debug: vedirect.0 (1717) No attribute changes for : H20, processing normallly
                            2022-06-13 19:10:00.562 - debug: vedirect.0 (1717) Line : H21 0
                            2022-06-13 19:10:00.563 - debug: vedirect.0 (1717) No case matched for H21
                            2022-06-13 19:10:00.564 - debug: vedirect.0 (1717) [stateSetCreate]H21 with value : 0
                            2022-06-13 19:10:00.565 - debug: vedirect.0 (1717) No attribute changes for : H21, processing normallly
                            2022-06-13 19:10:00.567 - debug: vedirect.0 (1717) [stateSetCreate]MPPT with value : MPP Tracker active
                            2022-06-13 19:10:00.568 - debug: vedirect.0 (1717) No attribute changes for : MPPT, processing normallly
                            2022-06-13 19:10:00.570 - debug: vedirect.0 (1717) [stateSetCreate]ERR with value : No Error
                            2022-06-13 19:10:00.571 - debug: vedirect.0 (1717) No attribute changes for : ERR, processing normallly
                            2022-06-13 19:10:00.573 - debug: vedirect.0 (1717) [stateSetCreate]OR with value : Normal Operation
                            2022-06-13 19:10:00.573 - debug: vedirect.0 (1717) No attribute changes for : OR, processing normallly
                            2022-06-13 19:10:00.593 - debug: vedirect.0 (1717) Line : H22 0
                            2022-06-13 19:10:00.594 - debug: vedirect.0 (1717) [stateSetCreate]H22 with value : 0
                            2022-06-13 19:10:00.595 - debug: vedirect.0 (1717) No attribute changes for : H22, processing normallly
                            2022-06-13 19:10:00.596 - debug: vedirect.0 (1717) Line : H23 0
                            2022-06-13 19:10:00.598 - debug: vedirect.0 (1717) No case matched for H23
                            2022-06-13 19:10:00.599 - debug: vedirect.0 (1717) [stateSetCreate]H23 with value : 0
                            2022-06-13 19:10:00.601 - debug: vedirect.0 (1717) No attribute changes for : H23, processing normallly
                            2022-06-13 19:10:00.606 - debug: vedirect.0 (1717) Line : HSDS 0
                            2022-06-13 19:10:00.609 - debug: vedirect.0 (1717) No case matched for HSDS
                            2022-06-13 19:10:00.610 - debug: vedirect.0 (1717) [stateSetCreate]HSDS with value : 0
                            2022-06-13 19:10:00.611 - debug: vedirect.0 (1717) No attribute changes for : HSDS, processing normallly
                            2022-06-13 19:10:01.449 - debug: vedirect.0 (1717) Line : Checksum |
                            2022-06-13 19:10:01.465 - debug: vedirect.0 (1717) Line : PID 0xA060
                            wie war das noch mit update und upgrade in der Console ? wo ihr schon einmal hier seid
                            DutchmanD Offline
                            DutchmanD Offline
                            Dutchman
                            @ralla66
                            Super danke dir! Hmm log wie erwartet ich schau mal weiter im Code
                            Ralla66R 1 Antwort Letzte Antwort
                            • DutchmanD Dutchman
                              @ralla66
                              Ralla66R Offline
                              Ralla66R Offline
                              Ralla66
                              @dutchman
                              vermutlich ist das noch der js-controller". Installed "3.1.6 bei mir
                              • Ralla66R Ralla66
                                @dutchman
                                DutchmanD Offline
                                DutchmanD Offline
                                Dutchman
                                schrieb am zuletzt editiert von Dutchman
                                @ralla66 sagte in vedirect -> USB an Victron MP2:
                                @dutchman
                                Ich meinte die info's vom Debug 😉, aber Jup stimmt würdest du Controller 4 haben kämen dieselben Fehler
                                • Ralla66R Ralla66
                                  pi@raspberrypi:~ $ uname -m && which nodejs node npm && nodejs -v && node -v && npm -v && whoami && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
                                  armv7l
                                  /usr/bin/nodejs
                                  /usr/bin/node
                                  /usr/bin/npm
                                  v12.22.12
                                  v12.22.12
                                  6.14.16
                                  pi
                                  /home/pi
                                  Ralla66R Offline
                                  Ralla66R Offline
                                  Ralla66
                                  @ralla66
                                  Bild vom Kabel innen, links der Optokoppler
                                    usb-VictronEnergy_BV_VE_Direct_cable_VE5OE42L-if00-port0
                                    Ich würde das so einstellen:
                                    /dev/serial/by-id/usb-VictronEnergy_BV_VE_Direct_cable_VE5OE42L-if00-port0
                                    Das passt immer, auch wenn sich die Reihenfolge der Ports mal ändern sollte.
                                    Marco 3
                                    @thomas-braun said in vedirect -> USB an Victron MP2:
                                    Moin, Kabel ist gekommen und ich kann über windows auch auf dem 150/45 zugreifen.
                                    Leider kann ich unter ioBroker nicht den USB Anschluss ausfindig machen.
                                    Bei mir läuft der ioBroker unter Debian in einer VM Ware.
                                    mit
                                    dmesg -wT
                                    kommt einiges, aber ich weiß nicht wie ich hoch oder runter scollen soll, oder aus dem Zustand heraus komme.
                                      @ralla66
                                      In
                                      ls -l /dev/serial/by-id
                                      schauen oder
                                      dmesg -wT
                                      beobachten während das Kabel/das Gerät eingesteckt wird.
                                      @Marco-3
                                      @thomas-braun sagte in vedirect -> USB an Victron MP2:
                                      • M Marco 3
                                        mit
                                        dmesg -wT
                                        @marco-3 sagte in vedirect -> USB an Victron MP2:
                                        Musst du ja auch nicht. Dazu dient der Link
                                        ja.
                                        In
                                        dmesg -wT
                                        kann man nicht blättern.
                                        Aber bei
                                        dmesg -T | less
                                        geht es. (Bild Rauf/Runter)
                                        Verlassen mit Strg-C (bzw. aus 'less' mit q)
                                          ja.
                                          In
                                          dmesg -wT
                                          Aber bei
                                          dmesg -T | less
                                          Marco 3
                                          schrieb am zuletzt editiert von Marco 3
                                          nur der link scheint es niccht bei mir zu bringen.
                                          1. Fehler USB wurde nicht in die VM durchgeschliffen, jetzt ja.
                                          Das bekomme ich das zu sehen. Der VE Adapter ist dann an Port 2 : DEV 5 angeschlossen sein.
                                          das kommt, wenn ich den USB nicht durch leite.
                                          Und nun meine Frage, was muss ich für eine Bezeichung eintragen?
                                          ttyUSB2-2-5 ??-->
