Probleme mit Installation von ESP Home@0.2.4
@homoran Trotzdem: DANKE!!
Also grundsätzlich installiert der Adapter:
echad@chet:~ $ iobroker add esphome NPM version: 8.11.0 Installing iobroker.esphome@0.2.4... (System call) added 98 packages, removed 192 packages, and changed 1 package in 2m 81 packages are looking for funding run `npm fund` for details host.chet install adapter esphome upload [5] esphome.admin /opt/iobroker/node_modules/iobroker.esphome/admin/admin.d.ts admin.d.ts video/mp2t upload [4] esphome.admin /opt/iobroker/node_modules/iobroker.esphome/admin/esphome.png esphome.png image/png upload [3] esphome.admin /opt/iobroker/node_modules/iobroker.esphome/admin/img/dashboard.png img/dashboard.png image/png upload [2] esphome.admin /opt/iobroker/node_modules/iobroker.esphome/admin/index_m.html index_m.html text/html upload [1] esphome.admin /opt/iobroker/node_modules/iobroker.esphome/admin/style.css style.css text/css upload [0] esphome.admin /opt/iobroker/node_modules/iobroker.esphome/admin/words.js words.js application/javascript host.chet object system.adapter.esphome created/updated host.chet create instance esphome host.chet object system.adapter.esphome.0.alive created host.chet object system.adapter.esphome.0.connected created host.chet object system.adapter.esphome.0.compactMode created host.chet object system.adapter.esphome.0.cpu created host.chet object system.adapter.esphome.0.cputime created host.chet object system.adapter.esphome.0.memHeapUsed created host.chet object system.adapter.esphome.0.memHeapTotal created host.chet object system.adapter.esphome.0.memRss created host.chet object system.adapter.esphome.0.uptime created host.chet object system.adapter.esphome.0.inputCount created host.chet object system.adapter.esphome.0.outputCount created host.chet object system.adapter.esphome.0.eventLoopLag created host.chet object system.adapter.esphome.0.sigKill created host.chet object system.adapter.esphome.0.logLevel created host.chet object esphome.0.info created host.chet object esphome.0.info.connection created host.chet Set default value of esphome.0.info.connection: false host.chet object system.adapter.esphome.0 created echad@chet:~ $Wo es da jetzt auf deinem System klemmt? Keine Ahnung...
@thomas-braun sagte in Probleme mit Installation von ESP Home@0.2.4:
Habe es auch nochmal auf der Konsole versucht:pi@raspberrypi:~ $ iobroker add esphome NPM version: 6.14.17 Installing iobroker.esphome@0.2.4... (System call) > iobroker.esphome@0.2.4 install /opt/iobroker/node_modules/iobroker.esphome > npip install No python_modules directory; installing pip locally if needed. Successfully completed pip check. Collecting esphome>=2021.8Was mich wundert, ist, dass das fehlende Directory "No python_modules directory" angemeckert wird. Wo muß das sein und wie lautet der Name?
@tontechniker
Das meckert er immer an und legt es dann auch selber an.
Wenn Du im Admin installierst, dann von NPM oder GIT? Von GIT gehts bei mir auf alle Fälle.Welchen Pi hast Du denn? Nicht das dem einfach der RAM bei der Installation einfach aus geht.
@tontechniker
@jan1 Habe einen 4B mit 4GB Ram und SSD.
@tontechniker
Ok, daran liegts nicht.
Dann die erste Frage. Von wo, GIT oder NPM? -
@tontechniker
Dann die erste Frage. Von wo, GIT oder NPM?@jan1 Ganz normal aus der Oberfläche "Adapter".
@tontechniker
Dann die erste Frage. Von wo, GIT oder NPM?@jan1 Habe es auch gerade nochmal von NPM versucht mit den gleichen Ergebnis. Was mich wundert ist, dass mein Log komplett anders aussieht als der Log von Thomas Braun.
iobroker update -isagt?
apt policy python-is-python3 python3-pip python3-distutilssagt?
@tontechniker sagte in Probleme mit Installation von ESP Home@0.2.4:
Die Frage kommt daher, dass ich den da nicht angeboten bekomme und ihn nur unter GIT oder NPM finde.
@jan1 sagte in Probleme mit Installation von ESP Home@0.2.4:
sollte aber im latest vorhanden sein
github: 0.2.4 latest: 0.2.4 for 9 months stable: -.-.- -
und wenn er da ist eigentlich auch im Beta ;)
und da ist er nicht:
Edit:
wenn man unter ESP sucht nicht, unter "S" finde ich ihn nun auch.@jan1 sagte in Probleme mit Installation von ESP Home@0.2.4:
was steht im log wenn du jetzt auf neuladen klickst?
(Beta (latest) sieht nicht aktuell aus, das sollte nur noch Beta heißen)oder in der Konsole bei
iobroker list adapters -
iobroker list adapters2022-06-10 20:05:30.636 - info: host.Beelink Updating repository "Beta (latest)" under "http://iobroker.live/repo/sources-dist-latest.json"Ich habe ihn gefunden, nur dass das nicht mehr Beta heißt ist mir entgangen. Passt da der Link nicht?
Mal den
iobroker fixausgeführt? Der zieht da ggf. auch noch python-Zeuch nach. -
doch, das wollte ich ja sehen. ich nehme aber an, dass du den manuell angepasst hast.
Mal den
iobroker fixausgeführt? Der zieht da ggf. auch noch python-Zeuch nach.@thomas-braun sagte in Probleme mit Installation von ESP Home@0.2.4:
Mal den
iobroker fixausgeführt? Der zieht da ggf. auch noch python-Zeuch nach.und macht mit hoher Wahrscheinlichkeit ein Downgrade auf 2 ;)
den hatte ich mal vor langer Zeit geändert, als der alte nicht mehr lief.
Was soll den offiziell rein?echad@chet:/opt/iobroker $ iob repo list stable : http://download.iobroker.net/sources-dist.json beta : http://download.iobroker.net/sources-dist-latest.json live-beta : http://iobroker.live/repo/sources-dist-latest.json live-stable : http://iobroker.live/repo/sources-dist.json Active repo(s): beta -
Edit:
das sollte sich @dutchman mal ansehen.
Auch in der Adapterlist kommt ein 404 wenn man auf den Namen klickt. Der dort hinterlegte link ist https://github.com/DrozmotiX/ioBroker.esphome/main/io-package.json -
Mal den
Ja, tut er (auch).
Nach dem Fix dannsudo apt install python-is-python3
