  4. Probleme mit Installation von ESP Home@0.2.4
109 Beiträge 6 Kommentatoren 12.9k Aufrufe 5 Beobachtet
    @tontechniker sagte in Probleme mit Installation von ESP Home@0.2.4:
    @homoran Über Admin.
    ok, dann bin ich erstmal mangels weiterer Ideen raus :-(
    Tontechniker
    @homoran Trotzdem: DANKE!!
    • T Tontechniker
      @tontechniker
      Also grundsätzlich installiert der Adapter:
      echad@chet:~ $ iobroker add esphome
      NPM version: 8.11.0
      Installing iobroker.esphome@0.2.4... (System call)
      added 98 packages, removed 192 packages, and changed 1 package in 2m
      81 packages are looking for funding
        run `npm fund` for details
      host.chet install adapter esphome
      upload [5] esphome.admin /opt/iobroker/node_modules/iobroker.esphome/admin/admin.d.ts admin.d.ts video/mp2t
      upload [4] esphome.admin /opt/iobroker/node_modules/iobroker.esphome/admin/esphome.png esphome.png image/png
      upload [3] esphome.admin /opt/iobroker/node_modules/iobroker.esphome/admin/img/dashboard.png img/dashboard.png image/png
      upload [2] esphome.admin /opt/iobroker/node_modules/iobroker.esphome/admin/index_m.html index_m.html text/html
      upload [1] esphome.admin /opt/iobroker/node_modules/iobroker.esphome/admin/style.css style.css text/css
      upload [0] esphome.admin /opt/iobroker/node_modules/iobroker.esphome/admin/words.js words.js application/javascript
      host.chet object system.adapter.esphome created/updated
      host.chet create instance esphome
      host.chet object system.adapter.esphome.0.alive created
      host.chet object system.adapter.esphome.0.connected created
      host.chet object system.adapter.esphome.0.compactMode created
      host.chet object system.adapter.esphome.0.cpu created
      host.chet object system.adapter.esphome.0.cputime created
      host.chet object system.adapter.esphome.0.memHeapUsed created
      host.chet object system.adapter.esphome.0.memHeapTotal created
      host.chet object system.adapter.esphome.0.memRss created
      host.chet object system.adapter.esphome.0.uptime created
      host.chet object system.adapter.esphome.0.inputCount created
      host.chet object system.adapter.esphome.0.outputCount created
      host.chet object system.adapter.esphome.0.eventLoopLag created
      host.chet object system.adapter.esphome.0.sigKill created
      host.chet object system.adapter.esphome.0.logLevel created
      host.chet object esphome.0.info created
      host.chet object esphome.0.info.connection created
      host.chet Set default value of esphome.0.info.connection: false
      host.chet object system.adapter.esphome.0 created
      echad@chet:~ $
      Wo es da jetzt auf deinem System klemmt? Keine Ahnung...
        @tontechniker
        NPM version: 8.11.0
        echad@chet:~ $
        Tontechniker
        @thomas-braun sagte in Probleme mit Installation von ESP Home@0.2.4:
        Habe es auch nochmal auf der Konsole versucht:
        pi@raspberrypi:~ $ iobroker add esphome
        NPM version: 6.14.17
        > iobroker.esphome@0.2.4 install /opt/iobroker/node_modules/iobroker.esphome
        > npip install
        No python_modules directory; installing pip locally if needed.
        Successfully completed pip check.
        Collecting esphome>=2021.8
        Was mich wundert, ist, dass das fehlende Directory "No python_modules directory" angemeckert wird. Wo muß das sein und wie lautet der Name?
        • T Tontechniker
          > npip install
          Jan1
          @tontechniker
          Das meckert er immer an und legt es dann auch selber an.
          Wenn Du im Admin installierst, dann von NPM oder GIT? Von GIT gehts bei mir auf alle Fälle.
          Welchen Pi hast Du denn? Nicht das dem einfach der RAM bei der Installation einfach aus geht.
          • J Jan1
            @tontechniker
            Tontechniker
            schrieb am zuletzt editiert von Tontechniker
            @jan1 Habe einen 4B mit 4GB Ram und SSD.
            • T Tontechniker
              Jan1
              @tontechniker
              Ok, daran liegts nicht.
              Dann die erste Frage. Von wo, GIT oder NPM?
              T 2 Antworten Letzte Antwort
              • J Jan1
                @tontechniker
                Tontechniker
                @jan1 Ganz normal aus der Oberfläche "Adapter".
                • J Jan1
                  @tontechniker
                  Tontechniker
                  @jan1 Habe es auch gerade nochmal von NPM versucht mit den gleichen Ergebnis. Was mich wundert ist, dass mein Log komplett anders aussieht als der Log von Thomas Braun.
                  • Thomas BraunT Online
                    @tontechniker
                    iobroker update -i
                    sagt?
                    apt policy python-is-python3 python3-pip python3-distutils
                    sagt?
                    • T Tontechniker
                      Jan1
                      Die Frage kommt daher, dass ich den da nicht angeboten bekomme und ihn nur unter GIT oder NPM finde.
                      • J Jan1
                        HomoranH Offline
                        HomoranH Offline
                        @jan1 sagte in Probleme mit Installation von ESP Home@0.2.4:
                        sollte aber im latest vorhanden sein
                        github:	0.2.4
                        latest:	0.2.4 for 9 months
                        stable:	-.-.-
                          github:	0.2.4
                          stable:	-.-.-
                          Jan1
                          und wenn er da ist eigentlich auch im Beta ;)
                          und da ist er nicht:
                          Edit:
                          wenn man unter ESP sucht nicht, unter "S" finde ich ihn nun auch.
                          • J Jan1
                            Edit:
                            HomoranH Offline
                            HomoranH Offline
                            was steht im log wenn du jetzt auf neuladen klickst?
                            (Beta (latest) sieht nicht aktuell aus, das sollte nur noch Beta heißen)
                            oder in der Konsole bei iobroker list adapters
                              Jan1
                              2022-06-10 20:05:30.636 - info: host.Beelink Updating repository "Beta (latest)" under "http://iobroker.live/repo/sources-dist-latest.json"
                              Ich habe ihn gefunden, nur dass das nicht mehr Beta heißt ist mir entgangen. Passt da der Link nicht?
                              • J Jan1
                                HomoranH Offline
                                HomoranH Offline
                                #66
                                doch, das wollte ich ja sehen. ich nehme aber an, dass du den manuell angepasst hast.
                                • T Tontechniker
                                  #67
                                  @tontechniker
                                  Mal den iobroker fix ausgeführt? Der zieht da ggf. auch noch python-Zeuch nach.
                                    Jan1
                                    #68
                                    den hatte ich mal vor langer Zeit geändert, als der alte nicht mehr lief.
                                    Was soll den offiziell rein?
                                      @tontechniker
                                      Jan1
                                      #69
                                      @tontechniker
                                      und macht mit hoher Wahrscheinlichkeit ein Downgrade auf 2 ;)
                                      • J Jan1
                                        #70
                                        @jan1
                                        echad@chet:/opt/iobroker $ iob repo list
                                        live-beta     : http://iobroker.live/repo/sources-dist-latest.json
                                        live-stable   : http://iobroker.live/repo/sources-dist.json
                                        Active repo(s): beta
                                        • J Jan1
                                          Edit:
                                          HomoranH Offline
                                          HomoranH Offline
                                          #71
                                          das sollte sich @dutchman mal ansehen.
                                          Auch in der Adapterlist kommt ein 404 wenn man auf den Namen klickt. Der dort hinterlegte link ist https://github.com/DrozmotiX/ioBroker.esphome/main/io-package.json
