  4. Test Adapter HeatingControl v3.xx
    apollon77A
heating
3.3k Beiträge 239 Kommentatoren 2.8m Aufrufe 201 Beobachtet
    #2677
    Hallo, mir ist heute aufgefallen das ich bei Adapterstart folgendes in den Logs habe:
    heatingcontrol.0
    2022-05-19 09:11:58.284	error	exception in UpdateDPs [TypeError: Cannot read property 'status' of undefined]
    Kann mir jemand sagen was ich da tun kann?
    Gruß David
    Rene_HMR 1 Antwort Letzte Antwort
      heatingcontrol.0
      Gruß David
      Rene_HMR
      Rene_HMR
      Rene_HM
      #2678
      @david83 kannst du mal auf debug-log umschalten und das log entsprechend posten?
        #2679
        Hier der Febug Log:
        heatingcontrol.0
        2022-05-20 07:59:57.062	debug	Sensor state true ?= false
        heatingcontrol.0
        2022-05-20 07:59:57.055	debug	result for CheckSensors4Room in Kueche is false since 1652955548612 = never
        heatingcontrol.0
        2022-05-20 07:59:57.055	debug	boolean: one window closed in Kueche alias.0.Küche.Fenster_rechts_rechts.ACTUAL
        heatingcontrol.0
        2022-05-20 07:59:57.055	debug	Sensor state false ?= false
        heatingcontrol.0
        2022-05-20 07:59:57.055	debug	boolean: one window closed in Kueche alias.0.Küche.Fenster_rechts_links.ACTUAL
        heatingcontrol.0
        2022-05-20 07:59:57.054	debug	Sensor state false ?= false
        heatingcontrol.0
        2022-05-20 07:59:57.054	debug	boolean: one window closed in Kueche alias.0.Küche.Fenster_links.ACTUAL
        heatingcontrol.0
        heatingcontrol.0
        2022-05-20 07:59:57.047	debug	result for CheckSensors4Room in Flur UG is false since 1653025370108 = never
        heatingcontrol.0
        2022-05-20 07:59:57.047	debug	boolean: one window closed in Flur UG alias.0.Flur_UG.Haustür.ACTUAL
        heatingcontrol.0
        2022-05-20 07:59:57.047	debug	Sensor state false ?= false
        heatingcontrol.0
        2022-05-20 07:59:57.047	debug	boolean: one window closed in Flur UG alias.0.Flur_UG.Fenster.ACTUAL
        heatingcontrol.0
        2022-05-20 07:59:57.046	debug	Sensor state false ?= false
        heatingcontrol.0
        2022-05-20 07:59:57.036	debug	result for CheckSensors4Room in Kinderzimmer Malea is false since 1653026114424 = never
        heatingcontrol.0
        2022-05-20 07:59:57.036	debug	boolean: one window closed in Kinderzimmer Malea alias.0.Malea.Fenster_rechts.ACTUAL
        heatingcontrol.0
        2022-05-20 07:59:57.036	debug	Sensor state false ?= false
        heatingcontrol.0
        2022-05-20 07:59:57.035	debug	boolean: one window closed in Kinderzimmer Malea alias.0.Malea.Fenster_links.ACTUAL
        heatingcontrol.0
        2022-05-20 07:59:57.035	debug	Sensor state false ?= false
        heatingcontrol.0
        2022-05-20 07:59:56.989	debug	UpdateDPs for Wohnzimmer starting
        heatingcontrol.0
        2022-05-20 07:59:56.989	debug	Wohnzimmer ### ChangeStatus HeatingPeriodActive to true in starting
        heatingcontrol.0
        2022-05-20 07:59:56.989	error	exception in UpdateDPs [TypeError: Cannot read property 'status' of undefined]
        heatingcontrol.0
        2022-05-20 07:59:56.984	debug	result for CheckSensors4Room in Kinderzimmer Lennox is true since 1652986048083 = never
        heatingcontrol.0
        2022-05-20 07:59:56.984	debug	boolean: one window open in Kinderzimmer Lennox alias.0.Lennox.Fenster_rechts.ACTUAL
        heatingcontrol.0
        2022-05-20 07:59:56.984	debug	Sensor state true ?= false
        heatingcontrol.0
        2022-05-20 07:59:56.984	debug	boolean: one window closed in Kinderzimmer Lennox alias.0.Lennox.Fenster_links.ACTUAL
        heatingcontrol.0
        2022-05-20 07:59:56.984	debug	Sensor state false ?= false
        heatingcontrol.0
        2022-05-20 07:59:56.979	debug	result for CheckSensors4Room in Schlafzimmer is true since 1653021448429 = never
        heatingcontrol.0
        2022-05-20 07:59:56.979	debug	boolean: one window open in Schlafzimmer alias.0.Schlafzimmer.Fenster_rechts.ACTUAL
        heatingcontrol.0
        2022-05-20 07:59:56.978	debug	Sensor state true ?= false
        heatingcontrol.0
        2022-05-20 07:59:56.978	debug	boolean: one window closed in Schlafzimmer alias.0.Schlafzimmer.Fenster_links.ACTUAL
        heatingcontrol.0
        2022-05-20 07:59:56.978	debug	Sensor state false ?= false
        heatingcontrol.0
        2022-05-20 07:59:56.973	debug	result for CheckSensors4Room in Bad OG is true since 1652969071557 = never
        heatingcontrol.0
        2022-05-20 07:59:56.973	debug	boolean: one window open in Bad OG alias.0.Bad_OG.Fenster_rechts.ACTUAL
        heatingcontrol.0
        2022-05-20 07:59:56.973	debug	Sensor state true ?= false
        heatingcontrol.0
        2022-05-20 07:59:56.972	debug	boolean: one window closed in Bad OG alias.0.Bad_OG.Fenster_links.ACTUAL
        heatingcontrol.0
        2022-05-20 07:59:56.972	debug	Sensor state false ?= false
        heatingcontrol.0
        2022-05-20 07:59:56.967	info	check all active sensors
        heatingcontrol.0
        2022-05-20 07:59:56.967	debug	reset temp offsets because not used
        heatingcontrol.0
        2022-05-20 07:59:56.824	debug	UpdateDPs for Bad UG starting
        heatingcontrol.0
        2022-05-20 07:59:56.824	debug	Bad UG ### ChangeStatus HeatingPeriodActive to true in starting
        heatingcontrol.0
        2022-05-20 07:59:56.814	debug	check all active thermostats
        heatingcontrol.0
        2022-05-20 07:59:56.813	debug	ChangeStatus called, while already changing, push to list Waschküche ProfilPoint -99 (19)
        heatingcontrol.0
        2022-05-20 07:59:56.813	debug	ChangeStatus called, while already changing, push to list Wohnzimmer ProfilPoint -99 (18)
        heatingcontrol.0
        2022-05-20 07:59:56.813	debug	ChangeStatus called, while already changing, push to list Bad UG ProfilPoint -99 (17)
        heatingcontrol.0
        2022-05-20 07:59:56.813	debug	ChangeStatus called, while already changing, push to list Kueche ProfilPoint -99 (16)
        heatingcontrol.0
        2022-05-20 07:59:56.813	debug	ChangeStatus called, while already changing, push to list Flur UG ProfilPoint -99 (15)
        heatingcontrol.0
        2022-05-20 07:59:56.813	debug	ChangeStatus called, while already changing, push to list Kinderzimmer Malea ProfilPoint -99 (14)
        heatingcontrol.0
        2022-05-20 07:59:56.813	debug	ChangeStatus called, while already changing, push to list Kinderzimmer Lennox ProfilPoint -99 (13)
        heatingcontrol.0
        2022-05-20 07:59:56.813	debug	ChangeStatus called, while already changing, push to list Schlafzimmer ProfilPoint -99 (12)
        heatingcontrol.0
        2022-05-20 07:59:56.813	debug	ChangeStatus called, while already changing, push to list Bad OG ProfilPoint -99 (11)
        heatingcontrol.0
        2022-05-20 07:59:56.812	info	start statemachine
        heatingcontrol.0
        2022-05-20 07:59:56.812	debug	SetVis done
        heatingcontrol.0
        2022-05-20 07:59:56.811	debug	### handle state change acked heatingcontrol.0.vis.isActive {"val":true,"ack":true,"ts":1653026396806,"q":0,"from":"system.adapter.heatingcontrol.0","user":"system.user.admin","lc":1637826593142}
        heatingcontrol.0
        2022-05-20 07:59:56.773	debug	### handle state change acked heatingcontrol.0.vis.RoomValues.TemperaturOverrideTime {"val":"00:00","ack":true,"ts":1653026396766,"q":0,"from":"system.adapter.heatingcontrol.0","user":"system.user.admin","lc":1621933761503}
        heatingcontrol.0
        2022-05-20 07:59:56.764	debug	HandleStateChanges CurrentTimePeriod -1
        heatingcontrol.0
        2022-05-20 07:59:56.764	debug	### handle state change acked heatingcontrol.0.vis.RoomValues.TemperaturOverride {"val":0,"ack":true,"ts":1653026396758,"q":0,"from":"system.adapter.heatingcontrol.0","user":"system.user.admin","lc":1621490316182}
        heatingcontrol.0
        2022-05-20 07:59:56.756	debug	### handle state change acked heatingcontrol.0.vis.RoomValues.MinimumTemperature {"val":8,"ack":true,"ts":1653026396751,"q":0,"from":"system.adapter.heatingcontrol.0","user":"system.user.admin","lc":1621496892917}
        heatingcontrol.0
        2022-05-20 07:59:56.749	debug	### handle state change acked heatingcontrol.0.vis.TempDecreaseValues.WindowOpenDecrease {"val":8,"ack":true,"ts":1653026396742,"q":0,"from":"system.adapter.heatingcontrol.0","user":"system.user.admin","lc":1621496890294}
        heatingcontrol.0
        2022-05-20 07:59:56.740	debug	UpdateDPs for Kueche starting
        heatingcontrol.0
        2022-05-20 07:59:56.740	debug	Kueche ### ChangeStatus HeatingPeriodActive to true in starting
        heatingcontrol.0
        2022-05-20 07:59:56.736	debug	### handle state change acked heatingcontrol.0.vis.TempDecreaseValues.VacationAbsentDecrease {"val":18,"ack":true,"ts":1653026396733,"q":0,"from":"system.adapter.heatingcontrol.0","user":"system.user.admin","lc":1621496887911}
        heatingcontrol.0
        2022-05-20 07:59:56.691	debug	### handle state change acked heatingcontrol.0.vis.TempDecreaseValues.PartyDecrease {"val":22,"ack":true,"ts":1653026396687,"q":0,"from":"system.adapter.heatingcontrol.0","user":"system.user.admin","lc":1621496880840}
        heatingcontrol.0
        2022-05-20 07:59:56.683	debug	### handle state change acked heatingcontrol.0.vis.TempDecreaseValues.GuestIncrease {"val":22,"ack":true,"ts":1653026396677,"q":0,"from":"system.adapter.heatingcontrol.0","user":"system.user.admin","lc":1621496878008}
        heatingcontrol.0
        2022-05-20 07:59:56.634	debug	### handle state change acked heatingcontrol.0.vis.TempDecreaseValues.AbsentDecrease {"val":18,"ack":true,"ts":1653026396628,"q":0,"from":"system.adapter.heatingcontrol.0","user":"system.user.admin","lc":1648661320914}
        heatingcontrol.0
        2022-05-20 07:59:56.626	debug	### handle state change acked heatingcontrol.0.vis.ProfileTypes.Mo-Su.Periods.5.time {"val":"21:00","ack":true,"ts":1653026396620,"q":0,"from":"system.adapter.heatingcontrol.0","user":"system.user.admin","lc":1651734640310}
        heatingcontrol.0
        2022-05-20 07:59:56.618	debug	### handle state change acked heatingcontrol.0.vis.ProfileTypes.Mo-Su.Periods.5.Temperature {"val":18,"ack":true,"ts":1653026396612,"q":0,"from":"system.adapter.heatingcontrol.0","user":"system.user.admin","lc":1648661352241}
        heatingcontrol.0
        2022-05-20 07:59:56.610	debug	### handle state change acked heatingcontrol.0.vis.ProfileTypes.Mo-Su.Periods.4.time {"val":"20:00","ack":true,"ts":1653026396604,"q":0,"from":"system.adapter.heatingcontrol.0","user":"system.user.admin","lc":1651734640291}
        heatingcontrol.0
        2022-05-20 07:59:56.602	debug	### handle state change acked heatingcontrol.0.vis.ProfileTypes.Mo-Su.Periods.4.Temperature {"val":18,"ack":true,"ts":1653026396597,"q":0,"from":"system.adapter.heatingcontrol.0","user":"system.user.admin","lc":1648661352234}
        heatingcontrol.0
        2022-05-20 07:59:56.595	debug	### handle state change acked heatingcontrol.0.vis.ProfileTypes.Mo-Su.Periods.3.time {"val":"19:00","ack":true,"ts":1653026396589,"q":0,"from":"system.adapter.heatingcontrol.0","user":"system.user.admin","lc":1651734640264}
        heatingcontrol.0
        2022-05-20 07:59:56.587	debug	UpdateDPs for Flur UG starting
        heatingcontrol.0
        2022-05-20 07:59:56.587	debug	Flur UG ### ChangeStatus HeatingPeriodActive to true in starting
        heatingcontrol.0
        2022-05-20 07:59:56.586	debug	### handle state change acked heatingcontrol.0.vis.ProfileTypes.Mo-Su.Periods.3.Temperature {"val":18,"ack":true,"ts":1653026396581,"q":0,"from":"system.adapter.heatingcontrol.0","user":"system.user.admin","lc":1648661352225}
        heatingcontrol.0
        2022-05-20 07:59:56.579	debug	### handle state change acked heatingcontrol.0.vis.ProfileTypes.Mo-Su.Periods.2.time {"val":"08:30","ack":true,"ts":1653026396573,"q":0,"from":"system.adapter.heatingcontrol.0","user":"system.user.admin","lc":1651734640201}
        heatingcontrol.0
        2022-05-20 07:59:56.571	debug	### handle state change acked heatingcontrol.0.vis.ProfileTypes.Mo-Su.Periods.2.Temperature {"val":20,"ack":true,"ts":1653026396566,"q":0,"from":"system.adapter.heatingcontrol.0","user":"system.user.admin","lc":1651734640194}
        heatingcontrol.0
        2022-05-20 07:59:56.561	debug	### handle state change acked heatingcontrol.0.vis.ProfileTypes.Mo-Su.Periods.1.time {"val":"05:30","ack":true,"ts":1653026396558,"q":0,"from":"system.adapter.heatingcontrol.0","user":"system.user.admin","lc":1651734640187}
        heatingcontrol.0
        2022-05-20 07:59:56.553	debug	### handle state change acked heatingcontrol.0.vis.ProfileTypes.Mo-Su.Periods.1.Temperature {"val":23,"ack":true,"ts":1653026396550,"q":0,"from":"system.adapter.heatingcontrol.0","user":"system.user.admin","lc":1651734640181}
        heatingcontrol.0
        2022-05-20 07:59:56.546	debug	SetVis called
        heatingcontrol.0
        2022-05-20 07:59:56.545	debug	Set trigger done
        heatingcontrol.0
        2022-05-20 07:59:56.543	debug	Set trigger
        heatingcontrol.0
        2022-05-20 07:59:56.543	debug	SetTempDecreaseModeValueLists done
        heatingcontrol.0
        2022-05-20 07:59:56.511	debug	UpdateDPs for Kinderzimmer Malea starting
        heatingcontrol.0
        2022-05-20 07:59:56.511	debug	Kinderzimmer Malea ### ChangeStatus HeatingPeriodActive to true in starting
        heatingcontrol.0
        2022-05-20 07:59:56.495	debug	SetTempDecreaseModeValueLists called
        heatingcontrol.0
        2022-05-20 07:59:56.495	debug	SetProfileValueList done
        heatingcontrol.0
        2022-05-20 07:59:56.479	debug	SetProfileValueList 1;2;3;4 1;CopyOfProfile1;3;4
        heatingcontrol.0
        2022-05-20 07:59:56.477	debug	SetProfileValueList called 4
        heatingcontrol.0
        2022-05-20 07:59:56.476	debug	InitRoom done, choosen room is Kueche
        heatingcontrol.0
        2022-05-20 07:59:56.473	debug	### handle state change acked heatingcontrol.0.vis.isActive {"val":true,"ack":true,"ts":1653026396470,"q":0,"from":"system.adapter.heatingcontrol.0","user":"system.user.admin","lc":1637826593142}
        heatingcontrol.0
        2022-05-20 07:59:56.425	debug	InitRoom called
        heatingcontrol.0
        2022-05-20 07:59:56.424	debug	UsedRooms "Bad OG;Schlafzimmer;Kinderzimmer Lennox;Kinderzimmer Malea;Flur UG;Kueche;Bad UG;Wohnzimmer;Waschküche"
        heatingcontrol.0
        2022-05-20 07:59:56.422	debug	ProfileType "Mo - Su"
        heatingcontrol.0
        2022-05-20 07:59:56.407	debug	TempDecreaseMode "absolute"
        heatingcontrol.0
        2022-05-20 07:59:56.403	info	20 cron job(s) created
        heatingcontrol.0
        2022-05-20 07:59:56.403	debug	cron status = true next event: 1 Jun 2022 23:55:00
        heatingcontrol.0
        2022-05-20 07:59:56.398	debug	cron status = true next event: 1 Oct 2022 00:05:00
        heatingcontrol.0
        2022-05-20 07:59:56.397	debug	cron status = true next event: 20 May 2022 09:00:00
        heatingcontrol.0
        2022-05-20 07:59:56.396	debug	cron status = true next event: 20 May 2022 23:00:00
        heatingcontrol.0
        2022-05-20 07:59:56.396	debug	cron status = true next event: 20 May 2022 16:00:00
        heatingcontrol.0
        2022-05-20 07:59:56.395	debug	cron status = true next event: 21 May 2022 06:20:00
        heatingcontrol.0
        2022-05-20 07:59:56.393	debug	cron status = true next event: 20 May 2022 19:00:00
        heatingcontrol.0
        2022-05-20 07:59:56.392	debug	cron status = true next event: 20 May 2022 08:30:00
        heatingcontrol.0
        2022-05-20 07:59:56.391	debug	cron status = true next event: 21 May 2022 05:30:00
        heatingcontrol.0
        2022-05-20 07:59:56.389	debug	cron status = true next event: 20 May 2022 21:00:00
        heatingcontrol.0
        2022-05-20 07:59:56.388	debug	cron status = true next event: 20 May 2022 10:00:00
        heatingcontrol.0
        2022-05-20 07:59:56.387	debug	cron status = true next event: 20 May 2022 20:00:00
        heatingcontrol.0
        2022-05-20 07:59:56.386	debug	cron status = true next event: 20 May 2022 12:00:00
        heatingcontrol.0
        2022-05-20 07:59:56.385	debug	cron status = true next event: 20 May 2022 11:44:00
        heatingcontrol.0
        2022-05-20 07:59:56.382	debug	cron status = true next event: 21 May 2022 00:00:00
        heatingcontrol.0
        2022-05-20 07:59:56.380	debug	cron status = true next event: 20 May 2022 22:00:00
        heatingcontrol.0
        2022-05-20 07:59:56.379	debug	cron status = true next event: 20 May 2022 18:00:00
        heatingcontrol.0
        2022-05-20 07:59:56.378	debug	cron status = true next event: 20 May 2022 15:00:00
        heatingcontrol.0
        2022-05-20 07:59:56.378	debug	cron status = true next event: 20 May 2022 08:00:00
        heatingcontrol.0
        2022-05-20 07:59:56.377	debug	cron status = true next event: 21 May 2022 06:00:00
        heatingcontrol.0
        2022-05-20 07:59:56.376	debug	CreateCronJobs done
        heatingcontrol.0
        2022-05-20 07:59:56.370	debug	HeatingPeriod: create cron job #19 at 31.06 string: 55 23 31 5 * Europe/Berlin
        heatingcontrol.0
        2022-05-20 07:59:56.368	debug	HeatingPeriod: create cron job #18 at 01.10 string: 5 0 01 9 * Europe/Berlin
        heatingcontrol.0
        2022-05-20 07:59:56.368	info	set cron for heating period check based on settings between 01.10. and 31.06.
        heatingcontrol.0
        2022-05-20 07:59:56.367	debug	create cron job #17 at 9:0 string: 0 0 9 * * * Europe/Berlin
        heatingcontrol.0
        2022-05-20 07:59:56.365	debug	create cron job #16 at 23:0 string: 0 0 23 * * * Europe/Berlin
        heatingcontrol.0
        2022-05-20 07:59:56.363	debug	create cron job #15 at 16:0 string: 0 0 16 * * * Europe/Berlin
        heatingcontrol.0
        2022-05-20 07:59:56.361	debug	create cron job #14 at 6:20 string: 0 20 6 * * * Europe/Berlin
        heatingcontrol.0
        2022-05-20 07:59:56.359	debug	create cron job #13 at 19:0 string: 0 0 19 * * * Europe/Berlin
        heatingcontrol.0
        2022-05-20 07:59:56.356	debug	create cron job #12 at 8:30 string: 0 30 8 * * * Europe/Berlin
        heatingcontrol.0
        2022-05-20 07:59:56.353	debug	create cron job #11 at 5:30 string: 0 30 5 * * * Europe/Berlin
        heatingcontrol.0
        2022-05-20 07:59:56.350	debug	create cron job #10 at 21:0 string: 0 0 21 * * * Europe/Berlin
        heatingcontrol.0
        2022-05-20 07:59:56.347	debug	create cron job #9 at 10:0 string: 0 0 10 * * * Europe/Berlin
        heatingcontrol.0
        2022-05-20 07:59:56.346	debug	create cron job #8 at 20:0 string: 0 0 20 * * * Europe/Berlin
        heatingcontrol.0
        2022-05-20 07:59:56.344	debug	create cron job #7 at 12:0 string: 0 0 12 * * * Europe/Berlin
        heatingcontrol.0
        2022-05-20 07:59:56.339	debug	create cron job #6 at 11:44 string: 0 44 11 * * * Europe/Berlin
        heatingcontrol.0
        2022-05-20 07:59:56.337	debug	create cron job #5 at 0:0 string: 0 0 0 * * * Europe/Berlin
        heatingcontrol.0
        2022-05-20 07:59:56.336	debug	create cron job #4 at 22:0 string: 0 0 22 * * * Europe/Berlin
        heatingcontrol.0
        2022-05-20 07:59:56.334	debug	create cron job #3 at 18:0 string: 0 0 18 * * * Europe/Berlin
        heatingcontrol.0
        2022-05-20 07:59:56.331	debug	create cron job #2 at 15:0 string: 0 0 15 * * * Europe/Berlin
        heatingcontrol.0
        2022-05-20 07:59:56.330	debug	create cron job #1 at 8:0 string: 0 0 8 * * * Europe/Berlin
        heatingcontrol.0
        2022-05-20 07:59:56.322	debug	create cron job #0 at 6:0 string: 0 0 6 * * * Europe/Berlin
        heatingcontrol.0
        2022-05-20 07:59:56.322	debug	cron jobs created [{"hour":6,"minute":0,"day":0,"Values2Set":[{"room":"Bad OG","target":22,"currentTimePeriod":1,"ActiveTimeSlot":1,"CurrentTimePeriodTime":"06:00","CurrentTimePeriodFull":"Period 1 06:00"},{"room":"Kinderzimmer Lennox","target":18,"currentTimePeriod":1,"ActiveTimeSlot":1,"CurrentTimePeriodTime":"06:00","CurrentTimePeriodFull":"Period 1 06:00"},{"room":"Kinderzimmer Malea","target":18,"currentTimePeriod":1,"ActiveTimeSlot":1,"CurrentTimePeriodTime":"06:00","CurrentTimePeriodFull":"Period 1 06:00"},{"room":"Flur UG","target":21,"currentTimePeriod":1,"ActiveTimeSlot":1,"CurrentTimePeriodTime":"06:00","CurrentTimePeriodFull":"Period 1 06:00"},{"room":"Waschküche","target":19,"currentTimePeriod":1,"ActiveTimeSlot":1,"CurrentTimePeriodTime":"06:00","CurrentTimePeriodFull":"Period 1 06:00"}]},{"hour":8,"minute":0,"day":0,"Values2Set":[{"room":"Bad OG","target":18,"currentTimePeriod":2,"ActiveTimeSlot":2,"CurrentTimePeriodTime":"08:00","CurrentTimePeriodFull":"Period 2 08:00"},{"room":"Flur UG","target":20,"currentTimePeriod":2,"ActiveTimeSlot":2,"CurrentTimePeriodTime":"08:00","CurrentTimePeriodFull":"Period 2 08:00"},{"room":"Bad UG","target":18,"currentTimePeriod":2,"ActiveTimeSlot":2,"CurrentTimePeriodTime":"08:00","CurrentTimePeriodFull":"Period 2 08:00"},{"room":"Bad UG","target":18,"currentTimePeriod":5,"ActiveTimeSlot":5,"CurrentTimePeriodTime":"08:00","CurrentTimePeriodFull":"Period 5 08:00"}]},{"hour":15,"minute":0,"day":0,"Values2Set":[{"room":"Bad OG","target":18,"currentTimePeriod":3,"ActiveTimeSlot":3,"CurrentTimePeriodTime":"15:00","CurrentTimePeriodFull":"Period 3 15:00"}]},{"hour":18,"minute":0,"day":0,"Values2Set":[{"room":"Bad OG","target":18,"currentTimePeriod":4,"ActiveTimeSlot":4,"CurrentTimePeriodTime":"18:00","CurrentTimePeriodFull":"Period 4 18:00"},{"room":"Waschküche","target":18,"currentTimePeriod":3,"ActiveTimeSlot":3,"CurrentTimePeriodTime":"18:00","CurrentTimePeriodFull":"Period 3 18:00"}]},{"hour":22,"minute":0,"day":0,"Values2Set":[{"room":"Bad OG","target":18,"currentTimePeriod":5,"ActiveTimeSlot":5,"CurrentTimePeriodTime":"22:00","CurrentTimePeriodFull":"Period 5 22:00"}]},{"hour":0,"minute":0,"day":0,"Values2Set":[{"room":"Schlafzimmer","target":10,"currentTimePeriod":1,"ActiveTimeSlot":1,"CurrentTimePeriodTime":"00:00","CurrentTimePeriodFull":"Period 1 00:00"},{"room":"Schlafzimmer","target":10,"currentTimePeriod":2,"ActiveTimeSlot":2,"CurrentTimePeriodTime":"00:00","CurrentTimePeriodFull":"Period 2 00:00"},{"room":"Schlafzimmer","target":10,"currentTimePeriod":3,"ActiveTimeSlot":3,"CurrentTimePeriodTime":"00:00","CurrentTimePeriodFull":"Period 3 00:00"},{"room":"Schlafzimmer","target":10,"currentTimePeriod":4,"ActiveTimeSlot":4,"CurrentTimePeriodTime":"00:00","CurrentTimePeriodFull":"Period 4 00:00"},{"room":"Kinderzimmer Lennox","target":18,"currentTimePeriod":4,"ActiveTimeSlot":4,"CurrentTimePeriodTime":"00:00","CurrentTimePeriodFull":"Period 4 00:00"},{"room":"Kinderzimmer Lennox","target":18,"currentTimePeriod":5,"ActiveTimeSlot":5,"CurrentTimePeriodTime":"00:00","CurrentTimePeriodFull":"Period 5 00:00"},{"room":"Kinderzimmer Malea","target":18,"currentTimePeriod":4,"ActiveTimeSlot":4,"CurrentTimePeriodTime":"00:00","CurrentTimePeriodFull":"Period 4 00:00"},{"room":"Kinderzimmer Malea","target":18,"currentTimePeriod":5,"ActiveTimeSlot":5,"CurrentTimePeriodTime":"00:00","CurrentTimePeriodFull":"Period 5 00:00"}]},{"hour":11,"minute":44,"day":0,"Values2Set":[{"room":"Schlafzimmer","target":11,"currentTimePeriod":5,"ActiveTimeSlot":5,"CurrentTimePeriodTime":"11:44","CurrentTimePeriodFull":"Period 5 11:44"}]},{"hour":12,"minute":0,"day":0,"Values2Set":[{"room":"Kinderzimmer Lennox","target":18,"currentTimePeriod":2,"ActiveTimeSlot":2,"CurrentTimePeriodTime":"12:00","CurrentTimePeriodFull":"Period 2 12:00"},{"room":"Kinderzimmer Malea","target":18,"currentTimePeriod":2,"ActiveTimeSlot":2,"CurrentTimePeriodTime":"12:00","CurrentTimePeriodFull":"Period 2 12:00"},{"room":"Bad UG","target":18,"currentTimePeriod":3,"ActiveTimeSlot":3,"CurrentTimePeriodTime":"12:00","CurrentTimePeriodFull":"Period 3 12:00"}]},{"hour":20,"minute":0,"day":0,"Values2Set":[{"room":"Kinderzimmer Lennox","target":18,"currentTimePeriod":3,"ActiveTimeSlot":3,"CurrentTimePeriodTime":"20:00","CurrentTimePeriodFull":"Period 3 20:00"},{"room":"Kinderzimmer Malea","target":18,"currentTimePeriod":3,"ActiveTimeSlot":3,"CurrentTimePeriodTime":"20:00","CurrentTimePeriodFull":"Period 3 20:00"},{"room":"Kueche","target":18,"currentTimePeriod":4,"ActiveTimeSlot":4,"CurrentTimePeriodTime":"20:00","CurrentTimePeriodFull":"Period 4 20:00"},{"room":"Waschküche","target":18,"currentTimePeriod":4,"ActiveTimeSlot":4,"CurrentTimePeriodTime":"20:00","CurrentTimePeriodFull":"Period 4 20:00"}]},{"hour":10,"minute":0,"day":0,"Values2Set":[{"room":"Flur UG","target":19,"currentTimePeriod":3,"ActiveTimeSlot":3,"CurrentTimePeriodTime":"10:00","CurrentTimePeriodFull":"Period 3 10:00"},{"room":"Flur UG","target":19,"currentTimePeriod":5,"ActiveTimeSlot":5,"CurrentTimePeriodTime":"10:00","CurrentTimePeriodFull":"Period 5 10:00"},{"room":"Wohnzimmer","target":20,"currentTimePeriod":1,"ActiveTimeSlot":1,"CurrentTimePeriodTime":"10:00","CurrentTimePeriodFull":"Period 1 10:00"}]},{"hour":21,"minute":0,"day":0,"Values2Set":[{"room":"Flur UG","target":19,"currentTimePeriod":4,"ActiveTimeSlot":4,"CurrentTimePeriodTime":"21:00","CurrentTimePeriodFull":"Period 4 21:00"},{"room":"Kueche","target":18,"currentTimePeriod":5,"ActiveTimeSlot":5,"CurrentTimePeriodTime":"21:00","CurrentTimePeriodFull":"Period 5 21:00"},{"room":"Bad UG","target":18,"currentTimePeriod":4,"ActiveTimeSlot":4,"CurrentTimePeriodTime":"21:00","CurrentTimePeriodFull":"Period 4 21:00"}]},{"hour":5,"minute":30,"day":0,"Values2Set":[{"room":"Kueche","target":23,"currentTimePeriod":1,"ActiveTimeSlot":1,"CurrentTimePeriodTime":"05:30","CurrentTimePeriodFull":"Period 1 05:30"}]},{"hour":8,"minute":30,"day":0,"Values2Set":[{"room":"Kueche","target":20,"currentTimePeriod":2,"ActiveTimeSlot":2,"CurrentTimePeriodTime":"08:30","CurrentTimePeriodFull":"Period 2 08:30"}]},{"hour":19,"minute":0,"day":0,"Values2Set":[{"room":"Kueche","target":18,"currentTimePeriod":3,"ActiveTimeSlot":3,"CurrentTimePeriodTime":"19:00","CurrentTimePeriodFull":"Period 3 19:00"},{"room":"Wohnzimmer","target":18,"currentTimePeriod":3,"ActiveTimeSlot":3,"CurrentTimePeriodTime":"19:00","CurrentTimePeriodFull":"Period 3 19:00"},{"room":"Wohnzimmer","target":18,"currentTimePeriod":5,"ActiveTimeSlot":5,"CurrentTimePeriodTime":"19:00","CurrentTimePeriodFull":"Period 5 19:00"}]},{"hour":6,"minute":20,"day":0,"Values2Set":[{"room":"Bad UG","target":21,"currentTimePeriod":1,"ActiveTimeSlot":1,"CurrentTimePeriodTime":"06:20","CurrentTimePeriodFull":"Period 1 06:20"}]},{"hour":16,"minute":0,"day":0,"Values2Set":[{"room":"Wohnzimmer","target":20,"currentTimePeriod":2,"ActiveTimeSlot":2,"CurrentTimePeriodTime":"16:00","CurrentTimePeriodFull":"Period 2 16:00"}]},{"hour":23,"minute":0,"day":0,"Values2Set":[{"room":"Wohnzimmer","target":18,"currentTimePeriod":4,"ActiveTimeSlot":4,"CurrentTimePeriodTime":"23:00","CurrentTimePeriodFull":"Period 4 23:00"},{"room":"Waschküche","target":18,"currentTimePeriod":5,"ActiveTimeSlot":5,"CurrentTimePeriodTime":"23:00","CurrentTimePeriodFull":"Period 5 23:00"}]},{"hour":9,"minute":0,"day":0,"Values2Set":[{"room":"Waschküche","target":18,"currentTimePeriod":2,"ActiveTimeSlot":2,"CurrentTimePeriodTime":"09:00","CurrentTimePeriodFull":"Period 2 09:00"}]}]
        heatingcontrol.0
        2022-05-20 07:59:56.310	debug	UpdateDPs for Kinderzimmer Lennox starting
        heatingcontrol.0
        2022-05-20 07:59:56.310	debug	Kinderzimmer Lennox ### ChangeStatus HeatingPeriodActive to true in starting
        heatingcontrol.0
        2022-05-20 07:59:56.202	debug	ChangeStatus called, while already changing, push to list Bad OG Thermostats_Target {"val":8,"ack":true,"ts":1653026396174,"q":0,"from":"system.adapter.fritzdect.0","user":"system.user.admin","lc":1652969101579} (10)
        heatingcontrol.0
        2022-05-20 07:59:56.202	debug	CheckStateChangeDevice alias.0.Bad_OG.Heizkoerper.SET
        heatingcontrol.0
        2022-05-20 07:59:56.202	debug	HandleStateChangeDevices alias.0.Bad_OG.Heizkoerper.SET
        heatingcontrol.0
        2022-05-20 07:59:56.202	debug	### handle state change acked alias.0.Bad_OG.Heizkoerper.SET {"val":8,"ack":true,"ts":1653026396174,"q":0,"from":"system.adapter.fritzdect.0","user":"system.user.admin","lc":1652969101579}
        heatingcontrol.0
        2022-05-20 07:59:56.201	debug	ChangeStatus called, while already changing, push to list Bad OG Thermostats_Current {"val":22.5,"ack":true,"ts":1653026396174,"q":0,"from":"system.adapter.fritzdect.0","user":"system.user.admin","lc":1653021715089} (9)
        heatingcontrol.0
        2022-05-20 07:59:56.201	debug	CheckStateChangeDevice alias.0.Bad_OG.Heizkoerper.ACTUAL
        heatingcontrol.0
        2022-05-20 07:59:56.200	debug	HandleStateChangeDevices alias.0.Bad_OG.Heizkoerper.ACTUAL
        heatingcontrol.0
        2022-05-20 07:59:56.200	debug	### handle state change acked alias.0.Bad_OG.Heizkoerper.ACTUAL {"val":22.5,"ack":true,"ts":1653026396174,"q":0,"from":"system.adapter.fritzdect.0","user":"system.user.admin","lc":1653021715089}
        heatingcontrol.0
        2022-05-20 07:59:56.073	debug	ChangeStatus called, while already changing, push to list Bad UG Thermostats_Target {"val":8,"ack":true,"ts":1653026396038,"q":0,"from":"system.adapter.fritzdect.0","user":"system.user.admin","lc":1652856284282} (8)
        heatingcontrol.0
        2022-05-20 07:59:56.073	debug	CheckStateChangeDevice alias.0.Bad_UG.Heizkörper.SET
        heatingcontrol.0
        2022-05-20 07:59:56.073	debug	HandleStateChangeDevices alias.0.Bad_UG.Heizkörper.SET
        heatingcontrol.0
        2022-05-20 07:59:56.073	debug	### handle state change acked alias.0.Bad_UG.Heizkörper.SET {"val":8,"ack":true,"ts":1653026396038,"q":0,"from":"system.adapter.fritzdect.0","user":"system.user.admin","lc":1652856284282}
        heatingcontrol.0
        2022-05-20 07:59:56.071	debug	ChangeStatus called, while already changing, push to list Bad UG Thermostats_Current {"val":19.5,"ack":true,"ts":1653026396038,"q":0,"from":"system.adapter.fritzdect.0","user":"system.user.admin","lc":1653014334742} (7)
        heatingcontrol.0
        2022-05-20 07:59:56.071	debug	CheckStateChangeDevice alias.0.Bad_UG.Heizkörper.ACTUAL
        heatingcontrol.0
        2022-05-20 07:59:56.071	debug	HandleStateChangeDevices alias.0.Bad_UG.Heizkörper.ACTUAL
        heatingcontrol.0
        2022-05-20 07:59:56.070	debug	### handle state change acked alias.0.Bad_UG.Heizkörper.ACTUAL {"val":19.5,"ack":true,"ts":1653026396038,"q":0,"from":"system.adapter.fritzdect.0","user":"system.user.admin","lc":1653014334742}
        heatingcontrol.0
        2022-05-20 07:59:55.955	debug	ChangeStatus called, while already changing, push to list Kueche Thermostats_Target {"val":23,"ack":true,"ts":1653026395914,"q":0,"from":"system.adapter.fritzdect.0","user":"system.user.admin","lc":1653017400079} (6)
        heatingcontrol.0
        2022-05-20 07:59:55.955	debug	CheckStateChangeDevice alias.0.Küche.Heizkörper.SET
        heatingcontrol.0
        2022-05-20 07:59:55.955	debug	HandleStateChangeDevices alias.0.Küche.Heizkörper.SET
        heatingcontrol.0
        2022-05-20 07:59:55.954	debug	### handle state change acked alias.0.Küche.Heizkörper.SET {"val":23,"ack":true,"ts":1653026395914,"q":0,"from":"system.adapter.fritzdect.0","user":"system.user.admin","lc":1653017400079}
        heatingcontrol.0
        2022-05-20 07:59:55.952	debug	ChangeStatus called, while already changing, push to list Kueche Thermostats_Current {"val":22.5,"ack":true,"ts":1653026395914,"q":0,"from":"system.adapter.fritzdect.0","user":"system.user.admin","lc":1653025794731} (5)
        heatingcontrol.0
        2022-05-20 07:59:55.952	debug	CheckStateChangeDevice alias.0.Küche.Heizkörper.ACTUAL
        heatingcontrol.0
        2022-05-20 07:59:55.952	debug	HandleStateChangeDevices alias.0.Küche.Heizkörper.ACTUAL
        heatingcontrol.0
        2022-05-20 07:59:55.952	debug	### handle state change acked alias.0.Küche.Heizkörper.ACTUAL {"val":22.5,"ack":true,"ts":1653026395914,"q":0,"from":"system.adapter.fritzdect.0","user":"system.user.admin","lc":1653025794731}
        heatingcontrol.0
        2022-05-20 07:59:55.894	debug	UpdateDPs for Schlafzimmer starting
        heatingcontrol.0
        2022-05-20 07:59:55.894	debug	Schlafzimmer ### ChangeStatus HeatingPeriodActive to true in starting
        heatingcontrol.0
        2022-05-20 07:59:55.829	debug	ChangeStatus called, while already changing, push to list Waschküche Thermostats_Target {"val":19,"ack":true,"ts":1653026395792,"q":0,"from":"system.adapter.fritzdect.0","user":"system.user.admin","lc":1653019200478} (4)
        heatingcontrol.0
        2022-05-20 07:59:55.829	debug	CheckStateChangeDevice alias.0.Hauswirtschaftsraum.Heizkörper.SET
        heatingcontrol.0
        2022-05-20 07:59:55.828	debug	HandleStateChangeDevices alias.0.Hauswirtschaftsraum.Heizkörper.SET
        heatingcontrol.0
        2022-05-20 07:59:55.828	debug	### handle state change acked alias.0.Hauswirtschaftsraum.Heizkörper.SET {"val":19,"ack":true,"ts":1653026395792,"q":0,"from":"system.adapter.fritzdect.0","user":"system.user.admin","lc":1653019200478}
        heatingcontrol.0
        2022-05-20 07:59:55.826	debug	ChangeStatus called, while already changing, push to list Waschküche Thermostats_Current {"val":19.5,"ack":true,"ts":1653026395792,"q":0,"from":"system.adapter.fritzdect.0","user":"system.user.admin","lc":1653025854594} (3)
        heatingcontrol.0
        2022-05-20 07:59:55.826	debug	CheckStateChangeDevice alias.0.Hauswirtschaftsraum.Heizkörper.ACTUAL
        heatingcontrol.0
        2022-05-20 07:59:55.825	debug	HandleStateChangeDevices alias.0.Hauswirtschaftsraum.Heizkörper.ACTUAL
        heatingcontrol.0
        2022-05-20 07:59:55.825	debug	### handle state change acked alias.0.Hauswirtschaftsraum.Heizkörper.ACTUAL {"val":19.5,"ack":true,"ts":1653026395792,"q":0,"from":"system.adapter.fritzdect.0","user":"system.user.admin","lc":1653025854594}
        heatingcontrol.0
        2022-05-20 07:59:55.698	debug	ChangeStatus called, while already changing, push to list Kinderzimmer Lennox Thermostats_Target {"val":8,"ack":true,"ts":1653026395656,"q":0,"from":"system.adapter.fritzdect.0","user":"system.user.admin","lc":1652986078097} (2)
        heatingcontrol.0
        2022-05-20 07:59:55.698	debug	CheckStateChangeDevice alias.0.Lennox.Heizkoerper.SET
        heatingcontrol.0
        2022-05-20 07:59:55.698	debug	HandleStateChangeDevices alias.0.Lennox.Heizkoerper.SET
        heatingcontrol.0
        2022-05-20 07:59:55.698	debug	### handle state change acked alias.0.Lennox.Heizkoerper.SET {"val":8,"ack":true,"ts":1653026395656,"q":0,"from":"system.adapter.fritzdect.0","user":"system.user.admin","lc":1652986078097}
        heatingcontrol.0
        2022-05-20 07:59:55.697	debug	ChangeStatus called, while already changing, push to list Kinderzimmer Lennox Thermostats_Current {"val":21,"ack":true,"ts":1653026395656,"q":0,"from":"system.adapter.fritzdect.0","user":"system.user.admin","lc":1653025854446} (1)
        heatingcontrol.0
        2022-05-20 07:59:55.697	debug	CheckStateChangeDevice alias.0.Lennox.Heizkoerper.ACTUAL
        heatingcontrol.0
        2022-05-20 07:59:55.696	debug	HandleStateChangeDevices alias.0.Lennox.Heizkoerper.ACTUAL
        heatingcontrol.0
        2022-05-20 07:59:55.695	debug	### handle state change acked alias.0.Lennox.Heizkoerper.ACTUAL {"val":21,"ack":true,"ts":1653026395656,"q":0,"from":"system.adapter.fritzdect.0","user":"system.user.admin","lc":1653025854446}
        heatingcontrol.0
        2022-05-20 07:59:55.218	info	start create cron jobs for profile type 1 (Mo - Su)
        heatingcontrol.0
        2022-05-20 07:59:55.218	debug	start CreateCronJobs
        heatingcontrol.0
        2022-05-20 07:59:55.217	debug	profile 1
        heatingcontrol.0
        2022-05-20 07:59:55.159	debug	get current profile
        heatingcontrol.0
        2022-05-20 07:59:55.108	debug	UpdateDPs for Bad OG starting
        heatingcontrol.0
        2022-05-20 07:59:55.108	debug	Bad OG ### ChangeStatus HeatingPeriodActive to true in starting
        heatingcontrol.0
        2022-05-20 07:59:55.106	debug	### handle state change !ack heatingcontrol.0.HeatingPeriodActive {"val":true,"ack":false,"ts":1653026394901,"q":0,"from":"system.adapter.heatingcontrol.0","user":"system.user.admin","lc":1640370557849}
        heatingcontrol.0
        2022-05-20 07:59:53.812	info	heating period is true
        heatingcontrol.0
        2022-05-20 07:59:53.812	debug	we are in period
        heatingcontrol.0
        2022-05-20 07:59:53.812	debug	corrected Start Fri Oct 01 2021
        heatingcontrol.0
        2022-05-20 07:59:53.812	debug	End Fri Jul 01 2022
        heatingcontrol.0
        2022-05-20 07:59:53.812	debug	Start Sat Oct 01 2022
        heatingcontrol.0
        2022-05-20 07:59:53.811	info	initial check for heating period based on settings between 01.10. and 31.06.
        heatingcontrol.0
        2022-05-20 07:59:53.810	info	subscribe devices done
        heatingcontrol.0
        2022-05-20 07:59:53.810	info	subscribe sensor ACTUAL alias.0.Hauswirtschaftsraum.Seitentür.ACTUAL
        heatingcontrol.0
        2022-05-20 07:59:53.810	info	subscribe sensor ACTUAL alias.0.Wohnzimmer.Fenster_rechts.ACTUAL
        heatingcontrol.0
        2022-05-20 07:59:53.810	info	subscribe sensor ACTUAL alias.0.Wohnzimmer.Fenster_links.ACTUAL
        heatingcontrol.0
        2022-05-20 07:59:53.810	info	subscribe sensor ACTUAL alias.0.Bad_UG.Fenster.ACTUAL
        heatingcontrol.0
        2022-05-20 07:59:53.810	info	subscribe sensor ACTUAL alias.0.Küche.Fenster_rechts_rechts.ACTUAL
        heatingcontrol.0
        2022-05-20 07:59:53.810	info	subscribe sensor ACTUAL alias.0.Küche.Fenster_rechts_links.ACTUAL
        heatingcontrol.0
        2022-05-20 07:59:53.809	info	subscribe sensor ACTUAL alias.0.Küche.Fenster_links.ACTUAL
        heatingcontrol.0
        2022-05-20 07:59:53.809	info	subscribe sensor ACTUAL alias.0.Flur_UG.Haustür.ACTUAL
        heatingcontrol.0
        2022-05-20 07:59:53.809	info	subscribe sensor ACTUAL alias.0.Flur_UG.Fenster.ACTUAL
        heatingcontrol.0
        2022-05-20 07:59:53.809	info	subscribe sensor ACTUAL alias.0.Malea.Fenster_rechts.ACTUAL
        heatingcontrol.0
        2022-05-20 07:59:53.809	info	subscribe sensor ACTUAL alias.0.Malea.Fenster_links.ACTUAL
        heatingcontrol.0
        2022-05-20 07:59:53.809	info	subscribe sensor ACTUAL alias.0.Lennox.Fenster_rechts.ACTUAL
        heatingcontrol.0
        2022-05-20 07:59:53.808	info	subscribe sensor ACTUAL alias.0.Lennox.Fenster_links.ACTUAL
        heatingcontrol.0
        2022-05-20 07:59:53.808	info	subscribe sensor ACTUAL alias.0.Schlafzimmer.Fenster_rechts.ACTUAL
        heatingcontrol.0
        2022-05-20 07:59:53.808	info	subscribe sensor ACTUAL alias.0.Schlafzimmer.Fenster_links.ACTUAL
        heatingcontrol.0
        2022-05-20 07:59:53.808	info	subscribe sensor ACTUAL alias.0.Bad_OG.Fenster_rechts.ACTUAL
        heatingcontrol.0
        2022-05-20 07:59:53.808	info	subscribe sensor ACTUAL alias.0.Bad_OG.Fenster_links.ACTUAL
        heatingcontrol.0
        2022-05-20 07:59:53.808	info	subscribe thermostat target SET alias.0.Hauswirtschaftsraum.Heizkörper.SET
        heatingcontrol.0
        2022-05-20 07:59:53.808	info	subscribe thermostat target SET alias.0.Wohnzimmer.Heizkoerper_rechts.SET
        heatingcontrol.0
        2022-05-20 07:59:53.807	info	subscribe thermostat target SET alias.0.Wohnzimmer.Heizkoerper_links.SET
        heatingcontrol.0
        2022-05-20 07:59:53.807	info	subscribe thermostat target SET alias.0.Bad_UG.Heizkörper.SET
        heatingcontrol.0
        2022-05-20 07:59:53.807	info	subscribe thermostat target SET alias.0.Küche.Heizkörper.SET
        heatingcontrol.0
        2022-05-20 07:59:53.807	info	subscribe thermostat target SET alias.0.Flur_UG.Heizkoerper.SET
        heatingcontrol.0
        2022-05-20 07:59:53.807	info	subscribe thermostat target SET alias.0.Malea.Heizkoerper.SET
        heatingcontrol.0
        2022-05-20 07:59:53.807	info	subscribe thermostat target SET alias.0.Lennox.Heizkoerper.SET
        heatingcontrol.0
        2022-05-20 07:59:53.806	info	subscribe thermostat target SET alias.0.Schlafzimmer.Heizkoerper.SET
        heatingcontrol.0
        2022-05-20 07:59:53.806	info	subscribe thermostat target SET alias.0.Bad_OG.Heizkoerper.SET
        heatingcontrol.0
        2022-05-20 07:59:53.806	info	subscribe thermostats target 10
        heatingcontrol.0
        2022-05-20 07:59:53.806	info	subscribe thermostat current SET alias.0.Hauswirtschaftsraum.Heizkörper.ACTUAL
        heatingcontrol.0
        2022-05-20 07:59:53.806	info	subscribe thermostat current SET alias.0.Wohnzimmer.Heizkoerper_rechts.ACTUAL
        heatingcontrol.0
        2022-05-20 07:59:53.806	info	subscribe thermostat current SET alias.0.Wohnzimmer.Heizkoerper_links.ACTUAL
        heatingcontrol.0
        2022-05-20 07:59:53.805	info	subscribe thermostat current SET alias.0.Bad_UG.Heizkörper.ACTUAL
        heatingcontrol.0
        2022-05-20 07:59:53.805	info	subscribe thermostat current SET alias.0.Küche.Heizkörper.ACTUAL
        heatingcontrol.0
        2022-05-20 07:59:53.805	info	subscribe thermostat current SET alias.0.Flur_UG.Heizkoerper.ACTUAL
        heatingcontrol.0
        2022-05-20 07:59:53.805	info	subscribe thermostat current SET alias.0.Malea.Heizkoerper.ACTUAL
        heatingcontrol.0
        2022-05-20 07:59:53.805	info	subscribe thermostat current SET alias.0.Lennox.Heizkoerper.ACTUAL
        heatingcontrol.0
        2022-05-20 07:59:53.804	info	subscribe thermostat current SET alias.0.Schlafzimmer.Heizkoerper.ACTUAL
        heatingcontrol.0
        2022-05-20 07:59:53.804	info	subscribe thermostat current SET alias.0.Bad_OG.Heizkoerper.ACTUAL
        heatingcontrol.0
        2022-05-20 07:59:53.804	info	subscribe thermostats current 10
        heatingcontrol.0
        2022-05-20 07:59:53.804	info	subscribe devices start
        heatingcontrol.0
        2022-05-20 07:59:53.803	debug	subscribe vis DP
        heatingcontrol.0
        2022-05-20 07:59:53.803	info	subscribe 0_userdata.0.Eigene_Datenpunkte.Heizung.HeatingControl.Party_jetzt
        heatingcontrol.0
        2022-05-20 07:59:53.803	info	subscribe 0_userdata.0.Eigene_Datenpunkte.Heizung.HeatingControl.Gaeste_anwesend
        heatingcontrol.0
        2022-05-20 07:59:53.802	info	subscribe 0_userdata.0.Eigene_Datenpunkte.Heizung.HeatingControl.Urlaub_anwesend
        heatingcontrol.0
        heatingcontrol.0
        2022-05-20 07:59:53.802	info	subscribe 0_userdata.0.Eigene_Datenpunkte.Heizung.HeatingControl.Anwesend
        heatingcontrol.0
        2022-05-20 07:59:53.802	info	subscribe 0_userdata.0.Eigene_Datenpunkte.Heizung.HeatingControl.Feiertag
        heatingcontrol.0
        2022-05-20 07:59:53.783	info	SetCurrent done
        heatingcontrol.0
        2022-05-20 07:59:53.703	debug	PublicHolidyToday set to false
        heatingcontrol.0
        2022-05-20 07:59:53.703	debug	PublicHolidyToday type ==1 ??? false
        heatingcontrol.0
        2022-05-20 07:59:53.695	debug	PartyNow set to false
        heatingcontrol.0
        2022-05-20 07:59:53.695	debug	PartyNow type ==1 ??? false
        heatingcontrol.0
        2022-05-20 07:59:53.691	debug	GuestsPresent set to false
        heatingcontrol.0
        2022-05-20 07:59:53.690	debug	GuestsPresent type ==1 ??? false
        heatingcontrol.0
        2022-05-20 07:59:53.644	debug	HolidayPresent set to false
        heatingcontrol.0
        2022-05-20 07:59:53.644	debug	HolidayPresent type ==1 ??? false
        heatingcontrol.0
        2022-05-20 07:59:53.639	debug	VacationAbsent set to false
        heatingcontrol.0
        2022-05-20 07:59:53.639	debug	VacationAbsent type ==1 ??? false
        heatingcontrol.0
        2022-05-20 07:59:53.586	debug	Present set to true
        heatingcontrol.0
        2022-05-20 07:59:53.586	debug	Present type ==1 ??? true
        heatingcontrol.0
        2022-05-20 07:59:53.585	info	start SetCurrent
        heatingcontrol.0
        2022-05-20 07:59:53.584	info	SetInfo done
        heatingcontrol.0
        2022-05-20 07:59:53.510	info	start SetInfo
        heatingcontrol.0
        2022-05-20 07:59:53.510	debug	SetDefaults done
        heatingcontrol.0
        2022-05-20 07:59:53.204	debug	start SetDefaults
        heatingcontrol.0
        2022-05-20 07:59:53.203	info	CreateDatapoints done
        heatingcontrol.0
        2022-05-20 07:59:52.500	info	start CreateDatapoints
        heatingcontrol.0
        2022-05-20 07:59:52.499	info	CreateDatabase done with 9 rooms
        heatingcontrol.0
        2022-05-20 07:59:52.499	debug	CreateDatabase: 0 active additional Temp sensors found []
        heatingcontrol.0
        2022-05-20 07:59:52.498	debug	CreateDatabase: 10 active thermostats found [{"name":"SET","room":"Bad OG","OID_Target":"alias.0.Bad_OG.Heizkoerper.SET","OID_Current":"alias.0.Bad_OG.Heizkoerper.ACTUAL","lastTarget":-99,"currentTarget":-99,"lastTargetFromDevice":-99,"lastChange":""},{"name":"SET","room":"Schlafzimmer","OID_Target":"alias.0.Schlafzimmer.Heizkoerper.SET","OID_Current":"alias.0.Schlafzimmer.Heizkoerper.ACTUAL","lastTarget":-99,"currentTarget":-99,"lastTargetFromDevice":-99,"lastChange":""},{"name":"SET","room":"Kinderzimmer Lennox","OID_Target":"alias.0.Lennox.Heizkoerper.SET","OID_Current":"alias.0.Lennox.Heizkoerper.ACTUAL","lastTarget":-99,"currentTarget":-99,"lastTargetFromDevice":-99,"lastChange":""},{"name":"SET","room":"Kinderzimmer Malea","OID_Target":"alias.0.Malea.Heizkoerper.SET","OID_Current":"alias.0.Malea.Heizkoerper.ACTUAL","lastTarget":-99,"currentTarget":-99,"lastTargetFromDevice":-99,"lastChange":""},{"name":"SET","room":"Flur UG","OID_Target":"alias.0.Flur_UG.Heizkoerper.SET","OID_Current":"alias.0.Flur_UG.Heizkoerper.ACTUAL","lastTarget":-99,"currentTarget":-99,"lastTargetFromDevice":-99,"lastChange":""},{"name":"SET","room":"Kueche","OID_Target":"alias.0.Küche.Heizkörper.SET","OID_Current":"alias.0.Küche.Heizkörper.ACTUAL","lastTarget":-99,"currentTarget":-99,"lastTargetFromDevice":-99,"lastChange":""},{"name":"SET","room":"Bad UG","OID_Target":"alias.0.Bad_UG.Heizkörper.SET","OID_Current":"alias.0.Bad_UG.Heizkörper.ACTUAL","lastTarget":-99,"currentTarget":-99,"lastTargetFromDevice":-99,"lastChange":""},{"name":"SET","room":"Wohnzimmer","OID_Target":"alias.0.Wohnzimmer.Heizkoerper_links.SET","OID_Current":"alias.0.Wohnzimmer.Heizkoerper_links.ACTUAL","lastTarget":-99,"currentTarget":-99,"lastTargetFromDevice":-99,"lastChange":""},{"name":"SET","room":"Wohnzimmer","OID_Target":"alias.0.Wohnzimmer.Heizkoerper_rechts.SET","OID_Current":"alias.0.Wohnzimmer.Heizkoerper_rechts.ACTUAL","lastTarget":-99,"currentTarget":-99,"lastTargetFromDevice":-99,"lastChange":""},{"name":"SET","room":"Waschküche","OID_Target":"alias.0.Hauswirtschaftsraum.Heizkörper.SET","OID_Current":"alias.0.Hauswirtschaftsraum.Heizkörper.ACTUAL","lastTarget":-99,"currentTarget":-99,"lastTargetFromDevice":-99,"lastChange":""}]
        heatingcontrol.0
        2022-05-20 07:59:52.498	debug	CreateDatabase: 0 active actors found []
        heatingcontrol.0
        2022-05-20 07:59:52.498	debug	CreateDatabase: 17 active sensors found [{"name":"ACTUAL","room":"Bad OG","OID":"alias.0.Bad_OG.Fenster_links.ACTUAL","lastState":false,"lastChange":"","DataType":"boolean","valueOpen":true,"valueClosed":false,"WindowCloseTimerId":null,"WindowOpenTimerId":null},{"name":"ACTUAL","room":"Bad OG","OID":"alias.0.Bad_OG.Fenster_rechts.ACTUAL","lastState":false,"lastChange":"","DataType":"boolean","valueOpen":true,"valueClosed":false,"WindowCloseTimerId":null,"WindowOpenTimerId":null},{"name":"ACTUAL","room":"Schlafzimmer","OID":"alias.0.Schlafzimmer.Fenster_links.ACTUAL","lastState":false,"lastChange":"","DataType":"boolean","valueOpen":true,"valueClosed":false,"WindowCloseTimerId":null,"WindowOpenTimerId":null},{"name":"ACTUAL","room":"Schlafzimmer","OID":"alias.0.Schlafzimmer.Fenster_rechts.ACTUAL","lastState":false,"lastChange":"","DataType":"boolean","valueOpen":true,"valueClosed":false,"WindowCloseTimerId":null,"WindowOpenTimerId":null},{"name":"ACTUAL","room":"Kinderzimmer Lennox","OID":"alias.0.Lennox.Fenster_links.ACTUAL","lastState":false,"lastChange":"","DataType":"boolean","valueOpen":true,"valueClosed":false,"WindowCloseTimerId":null,"WindowOpenTimerId":null},{"name":"ACTUAL","room":"Kinderzimmer Lennox","OID":"alias.0.Lennox.Fenster_rechts.ACTUAL","lastState":false,"lastChange":"","DataType":"boolean","valueOpen":true,"valueClosed":false,"WindowCloseTimerId":null,"WindowOpenTimerId":null},{"name":"ACTUAL","room":"Kinderzimmer Malea","OID":"alias.0.Malea.Fenster_links.ACTUAL","lastState":false,"lastChange":"","DataType":"boolean","valueOpen":true,"valueClosed":false,"WindowCloseTimerId":null,"WindowOpenTimerId":null},{"name":"ACTUAL","room":"Kinderzimmer Malea","OID":"alias.0.Malea.Fenster_rechts.ACTUAL","lastState":false,"lastChange":"","DataType":"boolean","valueOpen":true,"valueClosed":false,"WindowCloseTimerId":null,"WindowOpenTimerId":null},{"name":"ACTUAL","room":"Flur UG","OID":"alias.0.Flur_UG.Fenster.ACTUAL","lastState":false,"lastChange":"","DataType":"boolean","valueOpen":true,"valueClosed":false,"WindowCloseTimerId":null,"WindowOpenTimerId":null},{"name":"ACTUAL","room":"Flur UG","OID":"alias.0.Flur_UG.Haustür.ACTUAL","lastState":false,"lastChange":"","DataType":"boolean","valueOpen":true,"valueClosed":false,"WindowCloseTimerId":null,"WindowOpenTimerId":null},{"name":"ACTUAL","room":"Kueche","OID":"alias.0.Küche.Fenster_links.ACTUAL","lastState":false,"lastChange":"","DataType":"boolean","valueOpen":true,"valueClosed":false,"WindowCloseTimerId":null,"WindowOpenTimerId":null},{"name":"ACTUAL","room":"Kueche","OID":"alias.0.Küche.Fenster_rechts_links.ACTUAL","lastState":false,"lastChange":"","DataType":"boolean","valueOpen":true,"valueClosed":false,"WindowCloseTimerId":null,"WindowOpenTimerId":null},{"name":"ACTUAL","room":"Kueche","OID":"alias.0.Küche.Fenster_rechts_rechts.ACTUAL","lastState":false,"lastChange":"","DataType":"boolean","valueOpen":true,"valueClosed":false,"WindowCloseTimerId":null,"WindowOpenTimerId":null},{"name":"ACTUAL","room":"Bad UG","OID":"alias.0.Bad_UG.Fenster.ACTUAL","lastState":false,"lastChange":"","DataType":"boolean","valueOpen":true,"valueClosed":false,"WindowCloseTimerId":null,"WindowOpenTimerId":null},{"name":"ACTUAL","room":"Wohnzimmer","OID":"alias.0.Wohnzimmer.Fenster_links.ACTUAL","lastState":false,"lastChange":"","DataType":"boolean","valueOpen":true,"valueClosed":false,"WindowCloseTimerId":null,"WindowOpenTimerId":null},{"name":"ACTUAL","room":"Wohnzimmer","OID":"alias.0.Wohnzimmer.Fenster_rechts.ACTUAL","lastState":false,"lastChange":"","DataType":"boolean","valueOpen":true,"valueClosed":false,"WindowCloseTimerId":null,"WindowOpenTimerId":null},{"name":"ACTUAL","room":"Waschküche","OID":"alias.0.Hauswirtschaftsraum.Seitentür.ACTUAL","lastState":false,"lastChange":"","DataType":"number","valueOpen":1,"valueClosed":0,"WindowCloseTimerId":null,"WindowOpenTimerId":null}]
        heatingcontrol.0
        2022-05-20 07:59:52.497	debug	CreateDatabase: 9 active rooms found [{"ID":0,"Name":"Bad OG","isActive":true,"WindowIsOpen":false,"WindowIsOpenChanged":"never","TemperaturOverrideTime":"00:00","TemperaturOverride":0,"State":"starting","PreviousState":"none","CurrentTimePeriodTime":"00:00","CurrentTimePeriodFull":"","CurrentTimePeriod":-1,"CurrentTarget":-99,"CurrentReduced":0,"ActiveTimeSlot":-1,"MinimumTemperature":-99,"CurrentProfileTarget":-99,"LastAutoTarget":-99,"IsInOverride":false,"IsInReduced":false,"CurrentReducedMode":"none","IsInManual":false,"TemperatureManualMode":-99,"CurrentTemperature":-99,"CurrentTemperatureAddSensor":-99,"ReducedState":"","HasActorsWithoutThermostat":false,"Present":true,"VacationAbsent":false,"MaintenanceActive":false,"FireplaceModeActive":false,"HolidayPresent":false,"GuestsPresent":false,"PartyNow":false,"PublicHolidyToday":false,"OverrideTimerId":null,"HeatingPeriod":true,"StatusLog":[],"hasWindowSensors":true,"ActorState":false,"NextTemperaturFromThermostatIsWindowOpen":false,"WindowOpenUntilTemperaturTimerId":null,"sensors":[{"name":"ACTUAL","id":0,"OID":"alias.0.Bad_OG.Fenster_links.ACTUAL","DataType":"boolean","valueOpen":true,"valueClosed":false,"state":-1},{"name":"ACTUAL","id":1,"OID":"alias.0.Bad_OG.Fenster_rechts.ACTUAL","DataType":"boolean","valueOpen":true,"valueClosed":false,"state":-1}],"TempOffset":0,"hasAddTempSensors":false,"TempOffsetData":[],"RemainingOverrideTime":0,"RemainingOverrideTimerId":null},{"ID":1,"Name":"Schlafzimmer","isActive":true,"WindowIsOpen":false,"WindowIsOpenChanged":"never","TemperaturOverrideTime":"00:00","TemperaturOverride":0,"State":"starting","PreviousState":"none","CurrentTimePeriodTime":"00:00","CurrentTimePeriodFull":"","CurrentTimePeriod":-1,"CurrentTarget":-99,"CurrentReduced":0,"ActiveTimeSlot":-1,"MinimumTemperature":-99,"CurrentProfileTarget":-99,"LastAutoTarget":-99,"IsInOverride":false,"IsInReduced":false,"CurrentReducedMode":"none","IsInManual":false,"TemperatureManualMode":-99,"CurrentTemperature":-99,"CurrentTemperatureAddSensor":-99,"ReducedState":"","HasActorsWithoutThermostat":false,"Present":true,"VacationAbsent":false,"MaintenanceActive":false,"FireplaceModeActive":false,"HolidayPresent":false,"GuestsPresent":false,"PartyNow":false,"PublicHolidyToday":false,"OverrideTimerId":null,"HeatingPeriod":true,"StatusLog":[],"hasWindowSensors":true,"ActorState":false,"NextTemperaturFromThermostatIsWindowOpen":false,"WindowOpenUntilTemperaturTimerId":null,"sensors":[{"name":"ACTUAL","id":2,"OID":"alias.0.Schlafzimmer.Fenster_links.ACTUAL","DataType":"boolean","valueOpen":true,"valueClosed":false,"state":-1},{"name":"ACTUAL","id":3,"OID":"alias.0.Schlafzimmer.Fenster_rechts.ACTUAL","DataType":"boolean","valueOpen":true,"valueClosed":false,"state":-1}],"TempOffset":0,"hasAddTempSensors":false,"TempOffsetData":[],"RemainingOverrideTime":0,"RemainingOverrideTimerId":null},{"ID":2,"Name":"Kinderzimmer Lennox","isActive":true,"WindowIsOpen":false,"WindowIsOpenChanged":"never","TemperaturOverrideTime":"00:00","TemperaturOverride":0,"State":"starting","PreviousState":"none","CurrentTimePeriodTime":"00:00","CurrentTimePeriodFull":"","CurrentTimePeriod":-1,"CurrentTarget":-99,"CurrentReduced":0,"ActiveTimeSlot":-1,"MinimumTemperature":-99,"CurrentProfileTarget":-99,"LastAutoTarget":-99,"IsInOverride":false,"IsInReduced":false,"CurrentReducedMode":"none","IsInManual":false,"TemperatureManualMode":-99,"CurrentTemperature":-99,"CurrentTemperatureAddSensor":-99,"ReducedState":"","HasActorsWithoutThermostat":false,"Present":true,"VacationAbsent":false,"MaintenanceActive":false,"FireplaceModeActive":false,"HolidayPresent":false,"GuestsPresent":false,"PartyNow":false,"PublicHolidyToday":false,"OverrideTimerId":null,"HeatingPeriod":true,"StatusLog":[],"hasWindowSensors":true,"ActorState":false,"NextTemperaturFromThermostatIsWindowOpen":false,"WindowOpenUntilTemperaturTimerId":null,"sensors":[{"name":"ACTUAL","id":4,"OID":"alias.0.Lennox.Fenster_links.ACTUAL","DataType":"boolean","valueOpen":true,"valueClosed":false,"state":-1},{"name":"ACTUAL","id":5,"OID":"alias.0.Lennox.Fenster_rechts.ACTUAL","DataType":"boolean","valueOpen":true,"valueClosed":false,"state":-1}],"TempOffset":0,"hasAddTempSensors":false,"TempOffsetData":[],"RemainingOverrideTime":0,"RemainingOverrideTimerId":null},{"ID":3,"Name":"Kinderzimmer Malea","isActive":true,"WindowIsOpen":false,"WindowIsOpenChanged":"never","TemperaturOverrideTime":"00:00","TemperaturOverride":0,"State":"starting","PreviousState":"none","CurrentTimePeriodTime":"00:00","CurrentTimePeriodFull":"","CurrentTimePeriod":-1,"CurrentTarget":-99,"CurrentReduced":0,"ActiveTimeSlot":-1,"MinimumTemperature":-99,"CurrentProfileTarget":-99,"LastAutoTarget":-99,"IsInOverride":false,"IsInReduced":false,"CurrentReducedMode":"none","IsInManual":false,"TemperatureManualMode":-99,"CurrentTemperature":-99,"CurrentTemperatureAddSensor":-99,"ReducedState":"","HasActorsWithoutThermostat":false,"Present":true,"VacationAbsent":false,"MaintenanceActive":false,"FireplaceModeActive":false,"HolidayPresent":false,"GuestsPresent":false,"PartyNow":false,"PublicHolidyToday":false,"OverrideTimerId":null,"HeatingPeriod":true,"StatusLog":[],"hasWindowSensors":true,"ActorState":false,"NextTemperaturFromThermostatIsWindowOpen":false,"WindowOpenUntilTemperaturTimerId":null,"sensors":[{"name":"ACTUAL","id":6,"OID":"alias.0.Malea.Fenster_links.ACTUAL","DataType":"boolean","valueOpen":true,"valueClosed":false,"state":-1},{"name":"ACTUAL","id":7,"OID":"alias.0.Malea.Fenster_rechts.ACTUAL","DataType":"boolean","valueOpen":true,"valueClosed":false,"state":-1}],"TempOffset":0,"hasAddTempSensors":false,"TempOffsetData":[],"RemainingOverrideTime":0,"RemainingOverrideTimerId":null},{"ID":4,"Name":"Flur UG","isActive":true,"WindowIsOpen":false,"WindowIsOpenChanged":"never","TemperaturOverrideTime":"00:00","TemperaturOverride":0,"State":"starting","PreviousState":"none","CurrentTimePeriodTime":"00:00","CurrentTimePeriodFull":"","CurrentTimePeriod":-1,"CurrentTarget":-99,"CurrentReduced":0,"ActiveTimeSlot":-1,"MinimumTemperature":-99,"CurrentProfileTarget":-99,"LastAutoTarget":-99,"IsInOverride":false,"IsInReduced":false,"CurrentReducedMode":"none","IsInManual":false,"TemperatureManualMode":-99,"CurrentTemperature":-99,"CurrentTemperatureAddSensor":-99,"ReducedState":"","HasActorsWithoutThermostat":false,"Present":true,"VacationAbsent":false,"MaintenanceActive":false,"FireplaceModeActive":false,"HolidayPresent":false,"GuestsPresent":false,"PartyNow":false,"PublicHolidyToday":false,"OverrideTimerId":null,"HeatingPeriod":true,"StatusLog":[],"hasWindowSensors":true,"ActorState":false,"NextTemperaturFromThermostatIsWindowOpen":false,"WindowOpenUntilTemperaturTimerId":null,"sensors":[{"name":"ACTUAL","id":8,"OID":"alias.0.Flur_UG.Fenster.ACTUAL","DataType":"boolean","valueOpen":true,"valueClosed":false,"state":-1},{"name":"ACTUAL","id":9,"OID":"alias.0.Flur_UG.Haustür.ACTUAL","DataType":"boolean","valueOpen":true,"valueClosed":false,"state":-1}],"TempOffset":0,"hasAddTempSensors":false,"TempOffsetData":[],"RemainingOverrideTime":0,"RemainingOverrideTimerId":null},{"ID":5,"Name":"Kueche","isActive":true,"WindowIsOpen":false,"WindowIsOpenChanged":"never","TemperaturOverrideTime":"00:00","TemperaturOverride":0,"State":"starting","PreviousState":"none","CurrentTimePeriodTime":"00:00","CurrentTimePeriodFull":"","CurrentTimePeriod":-1,"CurrentTarget":-99,"CurrentReduced":0,"ActiveTimeSlot":-1,"MinimumTemperature":-99,"CurrentProfileTarget":-99,"LastAutoTarget":-99,"IsInOverride":false,"IsInReduced":false,"CurrentReducedMode":"none","IsInManual":false,"TemperatureManualMode":-99,"CurrentTemperature":-99,"CurrentTemperatureAddSensor":-99,"ReducedState":"","HasActorsWithoutThermostat":false,"Present":true,"VacationAbsent":false,"MaintenanceActive":false,"FireplaceModeActive":false,"HolidayPresent":false,"GuestsPresent":false,"PartyNow":false,"PublicHolidyToday":false,"OverrideTimerId":null,"HeatingPeriod":true,"StatusLog":[],"hasWindowSensors":true,"ActorState":false,"NextTemperaturFromThermostatIsWindowOpen":false,"WindowOpenUntilTemperaturTimerId":null,"sensors":[{"name":"ACTUAL","id":10,"OID":"alias.0.Küche.Fenster_links.ACTUAL","DataType":"boolean","valueOpen":true,"valueClosed":false,"state":-1},{"name":"ACTUAL","id":11,"OID":"alias.0.Küche.Fenster_rechts_links.ACTUAL","DataType":"boolean","valueOpen":true,"valueClosed":false,"state":-1},{"name":"ACTUAL","id":12,"OID":"alias.0.Küche.Fenster_rechts_rechts.ACTUAL","DataType":"boolean","valueOpen":true,"valueClosed":false,"state":-1}],"TempOffset":0,"hasAddTempSensors":false,"TempOffsetData":[],"RemainingOverrideTime":0,"RemainingOverrideTimerId":null},{"ID":6,"Name":"Bad UG","isActive":true,"WindowIsOpen":false,"WindowIsOpenChanged":"never","TemperaturOverrideTime":"00:00","TemperaturOverride":0,"State":"starting","PreviousState":"none","CurrentTimePeriodTime":"00:00","CurrentTimePeriodFull":"","CurrentTimePeriod":-1,"CurrentTarget":-99,"CurrentReduced":0,"ActiveTimeSlot":-1,"MinimumTemperature":-99,"CurrentProfileTarget":-99,"LastAutoTarget":-99,"IsInOverride":false,"IsInReduced":false,"CurrentReducedMode":"none","IsInManual":false,"TemperatureManualMode":-99,"CurrentTemperature":-99,"CurrentTemperatureAddSensor":-99,"ReducedState":"","HasActorsWithoutThermostat":false,"Present":true,"VacationAbsent":false,"MaintenanceActive":false,"FireplaceModeActive":false,"HolidayPresent":false,"GuestsPresent":false,"PartyNow":false,"PublicHolidyToday":false,"OverrideTimerId":null,"HeatingPeriod":true,"StatusLog":[],"hasWindowSensors":true,"ActorState":false,"NextTemperaturFromThermostatIsWindowOpen":false,"WindowOpenUntilTemperaturTimerId":null,"sensors":[{"name":"ACTUAL","id":13,"OID":"alias.0.Bad_UG.Fenster.ACTUAL","DataType":"boolean","valueOpen":true,"valueClosed":false,"state":-1}],"TempOffset":0,"hasAddTempSensors":false,"TempOffsetData":[],"RemainingOverrideTime":0,"RemainingOverrideTimerId":null},{"ID":7,"Name":"Wohnzimmer","isActive":true,"WindowIsOpen":false,"WindowIsOpenChanged":"never","TemperaturOverrideTime":"00:00","TemperaturOverride":0,"State":"starting","PreviousState":"none","CurrentTimePeriodTime":"00:00","CurrentTimePeriodFull":"","CurrentTimePeriod":-1,"CurrentTarget":-99,"CurrentReduced":0,"ActiveTimeSlot":-1,"MinimumTemperature":-99,"CurrentProfileTarget":-99,"LastAutoTarget":-99,"IsInOverride":false,"IsInReduced":false,"CurrentReducedMode":"none","IsInManual":false,"TemperatureManualMode":-99,"CurrentTemperature":-99,"CurrentTemperatureAddSensor":-99,"ReducedState":"","HasActorsWithoutThermostat":false,"Present":true,"VacationAbsent":false,"MaintenanceActive":false,"FireplaceModeActive":false,"HolidayPresent":false,"GuestsPresent":false,"PartyNow":false,"PublicHolidyToday":false,"OverrideTimerId":null,"HeatingPeriod":true,"StatusLog":[],"hasWindowSensors":true,"ActorState":false,"NextTemperaturFromThermostatIsWindowOpen":false,"WindowOpenUntilTemperaturTimerId":null,"sensors":[{"name":"ACTUAL","id":14,"OID":"alias.0.Wohnzimmer.Fenster_links.ACTUAL","DataType":"boolean","valueOpen":true,"valueClosed":false,"state":-1},{"name":"ACTUAL","id":15,"OID":"alias.0.Wohnzimmer.Fenster_rechts.ACTUAL","DataType":"boolean","valueOpen":true,"valueClosed":false,"state":-1}],"TempOffset":0,"hasAddTempSensors":false,"TempOffsetData":[],"RemainingOverrideTime":0,"RemainingOverrideTimerId":null},{"ID":8,"Name":"Waschküche","isActive":true,"WindowIsOpen":false,"WindowIsOpenChanged":"never","TemperaturOverrideTime":"00:00","TemperaturOverride":0,"State":"starting","PreviousState":"none","CurrentTimePeriodTime":"00:00","CurrentTimePeriodFull":"","CurrentTimePeriod":-1,"CurrentTarget":-99,"CurrentReduced":0,"ActiveTimeSlot":-1,"MinimumTemperature":-99,"CurrentProfileTarget":-99,"LastAutoTarget":-99,"IsInOverride":false,"IsInReduced":false,"CurrentReducedMode":"none","IsInManual":false,"TemperatureManualMode":-99,"CurrentTemperature":-99,"CurrentTemperatureAddSensor":-99,"ReducedState":"","HasActorsWithoutThermostat":false,"Present":true,"VacationAbsent":false,"MaintenanceActive":false,"FireplaceModeActive":false,"HolidayPresent":false,"GuestsPresent":false,"PartyNow":false,"PublicHolidyToday":false,"OverrideTimerId":null,"HeatingPeriod":true,"StatusLog":[],"hasWindowSensors":true,"ActorState":false,"NextTemperaturFromThermostatIsWindowOpen":false,"WindowOpenUntilTemperaturTimerId":null,"sensors":[{"name":"ACTUAL","id":16,"OID":"alias.0.Hauswirtschaftsraum.Seitentür.ACTUAL","DataType":"number","valueOpen":1,"valueClosed":0,"state":-1}],"TempOffset":0,"hasAddTempSensors":false,"TempOffsetData":[],"RemainingOverrideTime":0,"RemainingOverrideTimerId":null}]
        heatingcontrol.0
        2022-05-20 07:59:52.495	info	start CreateDatabase
        heatingcontrol.0
        2022-05-20 07:59:52.494	debug	got system language de
        heatingcontrol.0
        2022-05-20 07:59:52.466	debug	devices [{"id":1,"name":"SET","OID_Current":"alias.0.Schlafzimmer.Heizkoerper.ACTUAL","OID_Target":"alias.0.Schlafzimmer.Heizkoerper.SET","isActive":true,"type":1,"room":"Schlafzimmer"},{"id":2,"name":"ACTUAL","OID_Current":"alias.0.Schlafzimmer.Fenster_links.ACTUAL","isActive":true,"DataType":"boolean","valueOpen":true,"valueClosed":false,"type":3,"room":"Schlafzimmer"},{"id":3,"name":"ACTUAL","OID_Current":"alias.0.Schlafzimmer.Fenster_rechts.ACTUAL","isActive":true,"DataType":"boolean","valueOpen":true,"valueClosed":false,"type":3,"room":"Schlafzimmer"},{"id":4,"name":"SET","OID_Current":"alias.0.Bad_OG.Heizkoerper.ACTUAL","OID_Target":"alias.0.Bad_OG.Heizkoerper.SET","isActive":true,"type":1,"room":"Bad OG"},{"id":5,"name":"ACTUAL","OID_Current":"alias.0.Bad_OG.Fenster_links.ACTUAL","isActive":true,"DataType":"boolean","valueOpen":true,"valueClosed":false,"type":3,"room":"Bad OG"},{"id":6,"name":"ACTUAL","OID_Current":"alias.0.Bad_OG.Fenster_rechts.ACTUAL","isActive":true,"DataType":"boolean","valueOpen":true,"valueClosed":false,"type":3,"room":"Bad OG"},{"id":7,"name":"SET","OID_Current":"alias.0.Lennox.Heizkoerper.ACTUAL","OID_Target":"alias.0.Lennox.Heizkoerper.SET","isActive":true,"type":1,"room":"Kinderzimmer Lennox"},{"id":8,"name":"ACTUAL","OID_Current":"alias.0.Lennox.Fenster_links.ACTUAL","isActive":true,"DataType":"boolean","valueOpen":true,"valueClosed":false,"type":3,"room":"Kinderzimmer Lennox"},{"id":9,"name":"ACTUAL","OID_Current":"alias.0.Lennox.Fenster_rechts.ACTUAL","isActive":true,"DataType":"boolean","valueOpen":true,"valueClosed":false,"type":3,"room":"Kinderzimmer Lennox"},{"id":10,"name":"SET","OID_Current":"alias.0.Malea.Heizkoerper.ACTUAL","OID_Target":"alias.0.Malea.Heizkoerper.SET","isActive":true,"type":1,"room":"Kinderzimmer Malea"},{"id":11,"name":"ACTUAL","OID_Current":"alias.0.Malea.Fenster_links.ACTUAL","isActive":true,"DataType":"boolean","valueOpen":true,"valueClosed":false,"type":3,"room":"Kinderzimmer Malea"},{"id":12,"name":"ACTUAL","OID_Current":"alias.0.Malea.Fenster_rechts.ACTUAL","isActive":true,"DataType":"boolean","valueOpen":true,"valueClosed":false,"type":3,"room":"Kinderzimmer Malea"},{"id":13,"name":"SET","OID_Current":"alias.0.Flur_UG.Heizkoerper.ACTUAL","OID_Target":"alias.0.Flur_UG.Heizkoerper.SET","isActive":true,"type":1,"room":"Flur UG"},{"id":14,"name":"ACTUAL","OID_Current":"alias.0.Flur_UG.Fenster.ACTUAL","isActive":true,"DataType":"boolean","valueOpen":true,"valueClosed":false,"type":3,"room":"Flur UG"},{"id":15,"name":"ACTUAL","OID_Current":"alias.0.Flur_UG.Haustür.ACTUAL","isActive":true,"DataType":"boolean","valueOpen":true,"valueClosed":false,"type":3,"room":"Flur UG"},{"id":16,"name":"SET","OID_Current":"alias.0.Küche.Heizkörper.ACTUAL","OID_Target":"alias.0.Küche.Heizkörper.SET","isActive":true,"type":1,"room":"Kueche"},{"id":17,"name":"ACTUAL","OID_Current":"alias.0.Küche.Fenster_links.ACTUAL","isActive":true,"DataType":"boolean","valueOpen":true,"valueClosed":false,"type":3,"room":"Kueche"},{"id":18,"name":"ACTUAL","OID_Current":"alias.0.Küche.Fenster_rechts_links.ACTUAL","isActive":true,"DataType":"boolean","valueOpen":true,"valueClosed":false,"type":3,"room":"Kueche"},{"id":19,"name":"ACTUAL","OID_Current":"alias.0.Küche.Fenster_rechts_rechts.ACTUAL","isActive":true,"DataType":"boolean","valueOpen":true,"valueClosed":false,"type":3,"room":"Kueche"},{"id":20,"name":"SET","OID_Current":"alias.0.Bad_UG.Heizkörper.ACTUAL","OID_Target":"alias.0.Bad_UG.Heizkörper.SET","isActive":true,"type":1,"room":"Bad UG"},{"id":21,"name":"ACTUAL","OID_Current":"alias.0.Bad_UG.Fenster.ACTUAL","isActive":true,"DataType":"boolean","valueOpen":true,"valueClosed":false,"type":3,"room":"Bad UG"},{"id":22,"name":"SET","OID_Current":"alias.0.Wohnzimmer.Heizkoerper_links.ACTUAL","OID_Target":"alias.0.Wohnzimmer.Heizkoerper_links.SET","isActive":true,"type":1,"room":"Wohnzimmer"},{"id":23,"name":"SET","OID_Current":"alias.0.Wohnzimmer.Heizkoerper_rechts.ACTUAL","OID_Target":"alias.0.Wohnzimmer.Heizkoerper_rechts.SET","isActive":true,"type":1,"room":"Wohnzimmer"},{"id":24,"name":"ACTUAL","OID_Current":"alias.0.Wohnzimmer.Fenster_links.ACTUAL","isActive":true,"DataType":"boolean","valueOpen":true,"valueClosed":false,"type":3,"room":"Wohnzimmer"},{"id":25,"name":"ACTUAL","OID_Current":"alias.0.Wohnzimmer.Fenster_rechts.ACTUAL","isActive":true,"DataType":"boolean","valueOpen":true,"valueClosed":false,"type":3,"room":"Wohnzimmer"},{"id":26,"name":"SET","OID_Current":"alias.0.Hauswirtschaftsraum.Heizkörper.ACTUAL","OID_Target":"alias.0.Hauswirtschaftsraum.Heizkörper.SET","isActive":true,"type":1,"room":"Waschküche"},{"id":27,"name":"ACTUAL","OID_Current":"alias.0.Hauswirtschaftsraum.Seitentür.ACTUAL","isActive":true,"DataType":"number","valueOpen":1,"valueClosed":0,"type":3,"room":"Waschküche"}]
        heatingcontrol.0
        2022-05-20 07:59:52.449	info	starting. Version 2.8.6 in /opt/iobroker/node_modules/iobroker.heatingcontrol, node: v14.19.3, js-controller: 4.0.23
          #2680
          heatingcontrol.0
          2022-05-20 07:59:57.192	debug	ChangeStatus called, while already changing, push to list all HolidayPresent false (23)
          heatingcontrol.0
          2022-05-20 07:59:57.192	debug	ChangeStatus called, while already changing, push to list all VacationAbsent false (22)
          heatingcontrol.0
          2022-05-20 07:59:57.192	debug	ChangeStatus called, while already changing, push to list all Present true (21)
          heatingcontrol.0
          2022-05-20 07:59:57.191	debug	ChangeStatus called, while already changing, push to list all HeatingPeriodActive true (20)
          heatingcontrol.0
          2022-05-20 07:59:57.191	debug	MaintenanceActive false
          heatingcontrol.0
          2022-05-20 07:59:57.190	debug	PublicHolidyToday false
          heatingcontrol.0
          2022-05-20 07:59:57.186	debug	UpdateDPs for Waschküche starting
          heatingcontrol.0
          2022-05-20 07:59:57.186	debug	Waschküche ### ChangeStatus HeatingPeriodActive to true in starting
          heatingcontrol.0
          2022-05-20 07:59:57.185	error	exception in UpdateDPs [TypeError: Cannot read property 'status' of undefined]
          heatingcontrol.0
          2022-05-20 07:59:57.185	debug	PartyNow false
          heatingcontrol.0
          2022-05-20 07:59:57.181	debug	GuestsPresent false
          heatingcontrol.0
          2022-05-20 07:59:57.180	debug	HolidayPresent false
          heatingcontrol.0
          2022-05-20 07:59:57.176	debug	VacationAbsent false
          heatingcontrol.0
          2022-05-20 07:59:57.176	debug	Present true
          heatingcontrol.0
          2022-05-20 07:59:57.132	debug	HeatingPeriodActive true
          heatingcontrol.0
          2022-05-20 07:59:57.128	info	checking external states
          heatingcontrol.0
          2022-05-20 07:59:57.127	debug	result for CheckSensors4Room in Waschküche is false since 1653026059367 = never
          heatingcontrol.0
          2022-05-20 07:59:57.127	debug	number: one window closed in Waschküche alias.0.Hauswirtschaftsraum.Seitentür.ACTUAL
          Rene_HMR 1 Antwort Letzte Antwort
            heatingcontrol.0
            heatingcontrol.0
            heatingcontrol.0
            heatingcontrol.0
            heatingcontrol.0
            heatingcontrol.0
            heatingcontrol.0
            heatingcontrol.0
            heatingcontrol.0
            heatingcontrol.0
            heatingcontrol.0
            heatingcontrol.0
            heatingcontrol.0
            heatingcontrol.0
            heatingcontrol.0
            heatingcontrol.0
            heatingcontrol.0
            heatingcontrol.0
            Rene_HMR
            Rene_HMR
            Rene_HM
            #2681
            @david83 Ich sehe den Fehler im Log, verstehe aber die Ursache noch nicht. Es scheint aber funktionell keine Auswirkung zu haben, also können wir das erst mal ignorieren. In der V2.9 baue ich zusätzliche checks dafür ein, dann sehen wir hoffentlich die Ursache...
            • D
              D
              deta
              #2682
              Hallo Zusammen,
              ich habe da auch ein Anliegen.
              Meine Heizung über die CCU3 und Heating Controll , ist bereits im Sommermodus, also nicht Heizen. Sie bleibt also auf die definierte Temperatur.
              Jetzt gibts leider ein paar kalte Tage grummel. Nun wollte ich diese jetzt einfach wie gewohnt mit Alexa Wohnzimmer auf X Grad.
              Ja Sie stellt kurz auf X Grad und gleich wieder auf die Sommer nicht Heizungs Temperatur. Mh.
              Wenn ich diese Manuell am Heizkörper ändere, dann bleibt diese auch so.
              Vom Sinn her klar. Sommer kein Heizen. Aber in solchen Fällen, müste es doch Möglich sein, dennoch die Heizung einzuschalten. Vielleicht mit einer Sonderfunktion. Sommernotfall ..
              Cu Deta
              P mkshbM 2 Antworten Letzte Antwort
              • D deta
                Hallo Zusammen,
                Cu Deta
                P
                P
                Pittini
                schrieb am zuletzt editiert von Pittini
                #2683
                @deta Und warum schaltest nicht einfach die Heizperiode wieder an?
                • D deta
                  Hallo Zusammen,
                  Cu Deta
                  mkshbM
                  mkshbM
                  mkshb
                  schrieb am zuletzt editiert von mkshb
                  #2684
                  Moin @deta,
                  ist es wirklich sinnvoll in den warmen Monaten die Steuerung anzupassen?
                  Ob Ventile geöffnet werden oder nicht entscheidet die Raumtemperatur. Somit hättest Du Deinen Sommernotfall sobald es zu kalt wird.
                  AndreiosA 1 Antwort Letzte Antwort
                  • mkshbM mkshb
                    Moin @deta,
                    AndreiosA
                    AndreiosA
                    Andreios
                    Forum Testing
                    #2685
                    @mkshb sagte in Test Adapter HeatingControl v2.8.x:
                    Moin @deta,
                    Das steckt in den Leuten so drin, kommt wohl noch aus der Zeit, wo ein Heizungsventil wie ein Wasserhahn funktioniert hat. Selbst vor den elektronisch gesteuerten Ventilen habe ich schon die Einstellung im Sommer nicht verändert, weil, wenn das Ventil auf Stufe 3 20°C macht, öffnet es nur, wenn es kälter im Raum ist und dann will ich ja auch im Sommer, dass es warm bleibt.
                    Sparpotential ist da nur an der Heizung selber, wenn das noch eine nicht ganz so moderne Heizung ist. Da läuft dann evtl. auch im Sommer die Umwälzpumpe, auch wenn kein Heizbedarf ist und der Kessel wird evtl. auch auf Temperatur gehalten.
                    Ich vermute, moderne Heizungen steuern auch die Pumpe nach der Außentemperatur oder haben zumindest eine Sommereinstellung. (Meine Hzg. ist schon sehr alt, da wird nur die Vorlauftemperatur über den Außenfühler über die eingestellte Kurve geregelt.)
                    Schöne Grüße
                    Andreas
                    ioBroker auf Raspberry 4 mit SSD. Homematik IP mit CCU 3. Shelly. MySQL. Arduino. ...
                    Meine Posts sind subjektiv und manipulativ, erheben Anspruch auf Allwissenheit und können Spuren von Ironie oder Sarkasmus enthalten. ;-)
                    • Rene_HMR
                      Rene_HMR
                      Rene_HM
                      #2686
                      Im github und NPM liegt die 2.9.0 zum Testen bereit.
                      siehe auch github
                      Es gibt folgende Änderungen:
                      • Erweitertes Handling beim Setzen von Datenpunkten (Thermostat-Temperatur und Aktor-Status): Pro Gerät kann angegeben werden, ob das erfolgreiche Setzen geprüft werden soll und ob zusätzlich auch das Ack geprüft werden soll. siehe auch issue 306
                      • Benachrichtigung per email, telegram usw wurde hinzugefügt
                      Feedback ist wie immer willkommen...
                      Übrigens: ich suche support bei der Erstellung bzw. Update der Dokumentation. Bei Interesse bitte melden...
                      • Rene_HMR Rene_HM
                        siehe auch github
                        Dominik F.D
                        Dominik F.D
                        Dominik F.
                        #2687
                        @rene_hm
                        Bekomme seit dem Update folgende Fehlermeldung:
                        heatingcontrol.0
                        2022-06-11 14:14:49.024	error	exception in SetRoomTemperature [TypeError: Cannot read property 'log' of undefined]
                        heatingcontrol.0
                        2022-06-11 14:14:48.930	error	exception in SetRoomTemperature [TypeError: Cannot read property 'log' of undefined]
                        heatingcontrol.0
                        2022-06-11 14:14:48.859	error	exception in SetRoomTemperature [TypeError: Cannot read property 'log' of undefined]
                        heatingcontrol.0
                        2022-06-11 14:14:48.784	error	exception in SetRoomTemperature [TypeError: Cannot read property 'log' of undefined]
                        Hast du eine Idee?
                        • Dominik F.D Dominik F.
                          @rene_hm
                          heatingcontrol.0
                          heatingcontrol.0
                          heatingcontrol.0
                          heatingcontrol.0
                          Hast du eine Idee?
                          Rene_HMR
                          Rene_HMR
                          Rene_HM
                          schrieb am zuletzt editiert von Rene_HM
                          #2688
                          @dominik-f ja, habe eine Idee... liegt wahrscheinlich an den notifications, da habe ich etwas umgebaut.
                          edit:
                          sollte mit der 2.9.1 erledigt sein...
                          • Rene_HMR Rene_HM
                            edit:
                            Dominik F.D
                            Dominik F.D
                            Dominik F.
                            #2689
                            @rene_hm
                            Gerade die neue Version installiert, melde mich falls das Problem weiterhin besteht
                            P 1 Antwort Letzte Antwort
                              @rene_hm
                              P
                              P
                              Phinix
                              #2690
                              ich bin gerade dabei mich in den Adapter einzuarbeiten. Zwei Dinge welche ich nicht ganz verstehe.
                              • im Objektbaum heatingcontrol.0.currentprofile kann ich das aktuelle Profil aktivieren. Gilt dies für alle Thermostate oder kann ich für jedes Thermostat ein anderes Profil aktiv schalten?
                              • Wie kann ich einen manuellen Modus aktiv schalten? Heißt wenn ich nicht nach Profil meine Thermostate steuern möchte sondern auf meiner Visualisierung eine Direkteingabe der Temperatur habe?
                              Danke für eure Hilfe
                              • P Phinix
                                Dominik F.D
                                Dominik F.D
                                Dominik F.
                                #2691
                                @phinix
                                Diese Datenpunkte sind vorallem dafür da, wenn du die Vis von Pittini dazu nutzt. Ein Profil ist immer für alle Räume, diese kannst du allerdings individuell einstellen in jedem Profil. Die Einstellungsmöglichkeiten werden dir aber erst richtig klar wenn du die Vis nutzt.
                                Sobald du die Temperatur selbstständig irgendwo veränderst wird der manuelle Modus automatisch aktiviert.
                                  @phinix
                                  P
                                  P
                                  Phinix
                                  schrieb am zuletzt editiert von Phinix
                                  #2692
                                  @dominik-f
                                  Das mit den Profilen habe ich verstanden.
                                  Das mit dem manuellen Modus nicht, möchte ich die Temperatur manuell abändern, zb. über einen Slider auf meiner Visu, welchen Datenpunkt muss ich beschreiben damit die Temperatur übernommen wird?
                                  • P Phinix
                                    @dominik-f
                                    Dominik F.D
                                    Dominik F.D
                                    Dominik F.
                                    schrieb am zuletzt editiert von Dominik F.
                                    #2693
                                    @phinix
                                    Ich hoffe ich verstehe dich richtig....Du nimmst dafür keinen Datenpunkt vom Adapter, sondern musst einen Datenpunk von deinem Thermostat nehmen. Der Adapter erkennt dann, dass die Temperatur verändert wurde und dies nicht vom Adapter geschehen ist und schaltet sich dann in den Manu Modus
                                    Ich zeig dir mal ein Beispiel von meine Visualisierung:
                                    Im Wohnzimmer hat der Adapter alles selbstständig gemacht, in der Diele hab ich gerade die Temperatur manuel über den Slider verändert:
                                    In diesem Bild siehst du meine Einstellungen.
                                    Ganz rechts siehst du, dass in der Diele die 3. Periode aktiv ist. Wird die vierte erreicht, wird sich der Raum die wieder in den Automodus umstellen.
                                      @phinix
                                      P
                                      P
                                      Phinix
                                      #2694
                                      @dominik-f
                                      Mein Fehler war die fehlende Zeit bei "TemperaturOverrideTime", dadurch wurde meine eingegebene Temperatur nicht übernommen. Nachdem ich eine Zeit eingetragen hatte, wechselte der Status von auto in override. Soweit so gut.
                                      Was ich mir eigentlich gewünscht hätte, wäre ein reiner manueller Modus, so wie es zum Bsp. in der Homematic Zentrale ist. Dort kann ich zwischen Auto und Manu Modus umschalten und das Zeitprofil wird dann nicht mehr beachtet.
                                      • P Phinix
                                        @dominik-f
                                        Dominik F.D
                                        Dominik F.D
                                        Dominik F.
                                        #2695
                                        @phinix
                                        Dann musst du im Adapter unter Thermostateinstellung bei Verwendung von Änderungen beim Thermostat das entsprechende Einstellen oder den Raum gar nicht erst in Heatingcontrol einbinden
                                          @phinix
                                          P
                                          P
                                          Phinix
                                          #2696
                                          @dominik-f
                                          Wie meinst du das genau mit den Einstellungen im Thermostat?
                                          Wenn ich es richtig verstanden habe habe ich vier Möglichkeiten; Änderungen am Thermostat ignorieren, Änderung in Zeitplan übernehmen, Änderung für eine bestimmte Zeit übernehmen, Änderungen bis zum nächsten Zeitpunkt übernehmen ... oder habe ich da was falsch verstanden?
                                          Ich werde jetzt versuchen umzudenken, mir einen Zeitplan zu erstellen und diesen im Winter testen :D
                                          Eine weitere Frage habe ich aber noch; in den Raumeinstellungen kann ich ja noch weitere Sensoren hinterlegen. Fenstersensor ist mir klar. Fenster auf, Temperatur runter. Aber wie wird ein zusätzlicher Temperatursensor behandelt bzw. was bewirkt dieser im Adapter?
                                          84.0k
