  3. Einsteigerfragen
  4. Zigbee Adapter stürzt ständig ab
61 Beiträge 4 Kommentatoren 10.5k Aufrufe 4 Beobachtet
  • K
    K
    klaris
    Mein ziigbee Adapter in Verbindung mit meinen Conbee Stick Stürzt jeden Tag ab..
    Leider kann ich den Fehler nicht finden , hier meine Log Datei vielleicht kann mir einer helfen…
    Danke im Voraus
    zigbee.0
    2022-06-02 02:46:55.750 error Error while opening serialport 'Error: Error: No such file or directory, cannot open /dev/ttyACM0'
    zigbee.0
    2022-06-02 02:46:55.748 error Error: Error while opening serialport 'Error: Error: No such file or directory, cannot open /dev/ttyACM0' at SerialPort.<anonymous> (/opt/iobroker/node_modules/zigbee-herdsman/src/adapter/deconz/driver/driver.ts:182:28) at SerialPort._error (/opt/iobroker/node_modules/@serialport/stream/lib/index.js:198:14) at /opt/iobroker/node_modules/@serialport/stream/lib/index.js:242:12
    zigbee.0
    2022-06-02 02:46:55.744 error unhandled promise rejection: Error while opening serialport 'Error: Error: No such file or directory, cannot open /dev/ttyACM0'
    zigbee.0
    2022-06-02 02:46:55.741 error Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    zigbee.0
    2022-06-02 02:46:36.256 error Error herdsman start
    zigbee.0
    2022-06-02 02:46:36.255 error Failed to start Zigbee
    zigbee.0
    2022-06-02 02:46:36.253 error Starting zigbee-herdsman problem : "Error while opening serialport 'Error: Error: No such file or directory, cannot open /dev/ttyACM0'"
    zigbee.0
    2022-06-02 02:46:25.986 error Error herdsman start
    zigbee.0
    2022-06-02 02:46:25.985 error Failed to start Zigbee
    zigbee.0
    2022-06-02 02:46:25.983 error Starting zigbee-herdsman problem : "Error while opening serialport 'Error: Error: No such file or directory, cannot open /dev/ttyACM0'"
    • K klaris
      Danke im Voraus
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      arteckA
      arteckA
      arteck
      @klaris im ernst.. dein Fehler ist schon mindestens 10000 besprochen worden.. hast du schon mal nach gesucht?
      einfach mal
      https://forum.iobroker.net/search?term=Error while opening serialport 'Error%3A&in=titlesposts
      • arteckA arteck
        einfach mal
        K
        K
        klaris
        @arteck erstmal danke fur die schnelle Antwort !!
        Ich habe auch die Suchfunktion benutzt und diese Artikel gelesen aber so richtig eine Lösung für mein Problem kann ich da jetzt nicht erkennen und in Verbindung bringen …
        • arteckA
          arteckA
          arteck
          @klaris
          welche zigbee Version ?? wo läuft der iobroker ?
          • arteckA arteck
            @klaris
            K
            K
            klaris
            schrieb am zuletzt editiert von klaris
            @arteck zigbee Adapter 1.16.18 läuft auf raspberry 3
            NPM 6.14.15 Node.js v14.18.3
            JavaScript v5.2.21
            • K klaris
              JavaScript v5.2.21
              Thomas BraunT
              Thomas BraunT
              Most Active Developer
              @klaris
              Zunächst mal die Kiste durchpatchen.
              Dann unter
              ls -l /dev/serial/by-id/
              den Geräte-Link raussuchen. Den im Adapter hinterlegen.
              K 2 Antworten Letzte Antwort
                @klaris
                Dann unter
                K
                K
                klaris
                @thomas-braun … ich bin gerade im Dienst habe Zugriff auf Iobroker aber die Befehle kann ich erst zuhause am pc Eingeben …
                Ps.was meinst (Anfänger)mit zuerst durchpatchen alle Adaptern Updaten ?
                Thomas BraunT K 2 Antworten Letzte Antwort
                • K klaris
                  Thomas BraunT
                  Thomas BraunT
                  @klaris sagte in Zigbee Adapter stürzt ständig ab:
                  Noch tiefer ansetzen. Zuerst das Betriebssystem, dann die Adapter, dann den js-controller und dann schaut man sich das Problem an. Wenn es denn dann überhaupt noch besteht.
                  • K klaris
                    K
                    K
                    klaris
                    @klaris ok danke !! Werde ich mal machen und mich melden …
                      @klaris
                      Dann unter
                      K
                      K
                      klaris
                      @thomas-braun pi@raspberrypi:/opt/iobroker $ ls -l /dev/serial/by-id/
                      total 0
                      lrwxrwxrwx 1 root root 13 Jun 2 16:17 usb-dresden_elektronik_ingenieurtechnik_G mbH_ConBee_II_DE2486562-if00 -> ../../ttyACM0
                      das sieht aber ok aus oder ?
                      unter zigbee com anschluss ist der eintrag /dev/ttyACM0
                      • K klaris
                        total 0
                        Thomas BraunT
                        Thomas BraunT
                        @klaris
                        Dann trag schon mal
                        /dev/serial/usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE2486562-if00
                        in der Instanz als COM-Port ein.
                        (Hast du das abgetippselt oder wo kommt das Leerzeichen in _G mbH_ her?)
                          @klaris
                          Dann trag schon mal
                          K
                          K
                          klaris
                          @thomas-braun das G mbH habe ich nicht selber eingetippt ruckmeldung von PuTTY ...wenn ich es so eintrage im zigbee adapter dann bleibt der adapter rot mit eintrag eintrag /dev/ttyACM0 wird er grün
                          • K klaris
                            Thomas BraunT
                            Thomas BraunT
                            @klaris
                            Muss auch mit dem Link funktionieren. Keinen Dreher drin? Aus der Konsole kopiert? Das Leerzeichen kann da eigentlich nicht drin sein.
                            Dann ist die ID auf dem Stick falsch eingebrannt worden. Da gehört kein Leerzeichen rein. Das dürfte auch der Grund sein warum das in dem Fall nicht funktioniert. Leerzeichen in Dateinamen sind immer doof.
                            Dann nimm /dev/ttyACM0 , wenn das funktioniert.
                              @klaris
                              K
                              K
                              klaris
                              komisch
                              • K klaris
                                komisch
                                Thomas BraunT
                                Thomas BraunT
                                @klaris
                                Putz mal deine Brille. Das ist wie erwartet kein Leerzeichen.
                                  @klaris
                                  K
                                  K
                                  klaris
                                  @thomas-braun stimmt das sind punkte 👍
                                  • K klaris
                                    Thomas BraunT
                                    Thomas BraunT
                                    @klaris
                                    Hast du den ganzen Sums mit Punkten usw. eingetragen?
                                    Es gehört NUR
                                    in den COM Port eingetragen.
                                      @klaris
                                      Es gehört NUR
                                      K
                                      K
                                      klaris
                                      Der zigbee adapter läuft nur mit den eintrag /dev/ttyACM0
                                      könnte da der Fehler sein ?
                                      Startstufe für zigbee festlegen war auf 2:Datenprovider Adapter eingestellt ?
                                      Habe jetzt auf 1:Logikadapter ..DC394A4F-C03A-4B0E-A173-6BD1EB340213.jpeg
                                      • K klaris
                                        Thomas BraunT
                                        Thomas BraunT
                                        Das ist auch richtig. Fummel da nicht dran rum und stell es wieder auf 2.
                                        Wo ist denn jetzt dein Problem? Instanz wird grün, alles gut.
                                          K
                                          K
                                          klaris
                                          @thomas-braun ok ! es gibt ein update fur den zigbee adapter vom instalierten 1.6.18 auf 1.7.5 das hatte ich auch mal gemacht und danach ging nichts..
                                          habe das system mit einen backup wieder hergestellt keine ahnung warum ...
                                          84.1k
