  4. Backup funktioniert nicht wirklich
    5.9k
49 Beiträge 7 Kommentatoren 2.0k Aufrufe 5 Beobachtet
    @dr-pie sagte in Backup funktioniert nicht wirklich:
    Synology Servern
    Nimm SMB/CIFS dafür. FTP ist aus der Steinzeit.
    Richtig eingerichtet funktioniert es aber.
    Hab es gerade mal auf meiner FritzBox aktiviert:
    [DEBUG] [iobroker] - host.chet 5254 states saved
    [DEBUG] [iobroker] - host.chet 6632 objects saved
    [DEBUG] [iobroker] - Backup created: /opt/iobroker/backups/iobroker_2022_05_29-18_59_07_backupiobroker.tar.gz
    [DEBUG] [iobroker] - done
    [DEBUG] [historyDB] - compress from historyDB started ...
    [DEBUG] [historyDB] - Backup created: /opt/iobroker/backups/historyDB_2022_05_29-18_59_18_backupiobroker.tar.gz
    [DEBUG] [historyDB] - done
    [DEBUG] [zigbee] - found zigbee database: zigbee.0
    [DEBUG] [zigbee] - done
    [DEBUG] [javascripts] - Created javascript_tmp directory: "/opt/iobroker/backups/tmpScripts"
    [DEBUG] [javascripts] - found Script: dwd_uwz_nina_warnungen
    [DEBUG] [javascripts] - found Script: nodemihome
    [DEBUG] [javascripts] - found Script: pakettruhe_offen
    [DEBUG] [javascripts] - found Script: ps4_waker
    [DEBUG] [javascripts] - found Script: sonnenaufgang
    [DEBUG] [javascripts] - found Script: sonnenuntergang
    [DEBUG] [javascripts] - found Script: speedtest
    [DEBUG] [javascripts] - found Script: telefon_klingelt
    [DEBUG] [javascripts] - found Script: tuerklingel_laeutet
    [DEBUG] [javascripts] - found Script: vorhaenge-sonnenschutz
    [DEBUG] [javascripts] - found Script: wohnung_verlassen
    [DEBUG] [javascripts] - found Script: wohnungstuer_entriegelt
    [DEBUG] [javascripts] - found Script: paketlieferungen
    [DEBUG] [javascripts] - found Script: treppenhaus_licht_hub
    [DEBUG] [javascripts] - found Script: treppenhaus_licht_ble
    [DEBUG] [javascripts] - found Script: lautstaerke_bad
    [DEBUG] [javascripts] - Try deleting the Javascript tmp directory: "/opt/iobroker/backups/tmpScripts"
    [DEBUG] [javascripts] - Javascript tmp directory "/opt/iobroker/backups/tmpScripts" successfully deleted
    [DEBUG] [javascripts] - Backup created: /opt/iobroker/backups/javascripts_2022_05_29-18_59_19_backupiobroker.tar.gz
    [DEBUG] [javascripts] - done
    [DEBUG] [ftp] - FTP connected.
    [DEBUG] [ftp] - Send iobroker_2022_05_29-18_59_07_backupiobroker.tar.gz
    [DEBUG] [ftp] - Send historyDB_2022_05_29-18_59_18_backupiobroker.tar.gz
    [DEBUG] [ftp] - Send zigbee.0_2022_05_29-18_59_19_backupiobroker.tar.gz
    [DEBUG] [ftp] - Send javascripts_2022_05_29-18_59_19_backupiobroker.tar.gz
    [DEBUG] [ftp] - done
    [DEBUG] [clean] - done
    [DEBUG] [whatsapp] - done
    [DEBUG] [historyHTML] - new history html values created
    [DEBUG] [historyHTML] - done
    [DEBUG] [historyJSON] - new history json values created
    [DEBUG] [historyJSON] - done
    [EXIT] 0
    Dr.PieD Offline
    Dr.PieD Offline
    Dr.Pie
    Ich habe nun mal einiges probiert ...keine Chance
    Die Zugangsdaten für den Server sind richtig ... aber das Backup will nicht anlaufen ... grrrr.
    Was ist denn wenn ich einen USB Stick in den Raspberry einstecke ... das sollte doch auch funktionieren ...
    • Dr.PieD Dr.Pie
      @crunchip ich will das Backup auf einen meiner Synology Servern speichern.
      Der Ordner Daten/ wird nämlich täglich gesichert.
      Der Ordner Daten/
      und das ist eine Freigabe?
      Ich würde es dann auch mit cifs versuchen.
      • Dr.PieD Dr.Pie
        Meldungen?
        Dr.PieD 1 Antwort Letzte Antwort
          Meldungen?
          Dr.PieD Offline
          Dr.PieD Offline
          Dr.Pie
          Started iobroker ...
          [DEBUG] [mount] - noserverino option: false
          [DEBUG] [mount] - cifs-mount command: "mount -t cifs -o username=jens,password=,rw,file_mode=0777,dir_mode=0777,vers=2.0 //192.168.178.202/daten/iobroker_raspberry /opt/iobroker/backups"
          [DEBUG] [mount] - first mount attempt with smb option failed. try next mount attempt without smb option ...
          ,rw,file_mode=0777,dir_mode=0777 //192.168.178.202/daten/iobroker_raspberry /opt/iobroker/backups"
          [ERROR] [mount] - [undefined Error: Command failed: mount -t cifs -o username=jens,password=****,rw,file_mode=0777,dir_mode=0777 //192.168.178.202/daten/iobroker_raspberry /opt/iobroker/backups
          mount.cifs: permission denied: no match for /opt/iobroker/backups found in /etc/fstab
          [ERROR] [mount] - Error: Command failed: mount -t cifs -o username=jens,password=****,rw,file_mode=0777,dir_mode=0777 //192.168.178.202/daten/iobroker_raspberry /opt/iobroker/backups
          Das ist die Meldung.
          Der User der unter Instanzen/backitup.0 eingetragen ist hat die entsprechenden Rechte den Ordner zu beschreiben.
          • Dr.PieD Dr.Pie
            @dr-pie
            Jetzt doch per CIFS?
            Was willst du denn jetzt? FTP? CIFS? NFS?
            Und bitte den Text in CodeTags setzen.
              @dr-pie
              Dr.PieD Offline
              Dr.PieD Offline
              Dr.Pie
              @thomas-braun imgrunde ist mir das wurscht ... Hautsache es funktioniert.
              In der Einstellung habe ich mal CISF eingestellt ... aber das scheint auch nicht zu funktionieren.
              • Dr.PieD Dr.Pie
                @dr-pie
                Hier meine Einstellungen:
                Die Option 'noserverino' ist für FritzBoxen wichtig, bei anderen Systemen deaktivieren.
                Pfade und IPs bei dir halt anpassen.
                  @dr-pie
                  Dr.PieD Offline
                  Dr.PieD Offline
                  Dr.Pie
                  @thomas-braun diese Funktion ist auch bei mir deaktiviert.
                  • Dr.PieD Dr.Pie
                    @dr-pie
                    Das habe ich gesehen. Ich wollte nur nicht das du die wegen des Screenshots aktivierst.
                      Der Ordner Daten/
                      @homoran sagte in Backup funktioniert nicht wirklich:
                      Der Ordner Daten/
                      da fehlt noch die Antwort
                        Der Ordner Daten/
                        Dr.PieD Offline
                        Dr.PieD Offline
                        Dr.Pie
                        @homoran auf der Synology ist ein Ordner "Daten" der den Ordner "iobroker_raspberry" enthält.
                        In diesen Ordner hat der entsprechende User das Recht zu schreiben.
                        HomoranH simatecS 2 Antworten Letzte Antwort
                        • Dr.PieD Dr.Pie
                          ein Ordner "Daten"
                          ist das auch ein freigegebener Ordner?
                            ein Ordner "Daten"
                            Dr.PieD Offline
                            Dr.PieD Offline
                            Dr.Pie
                            @homoran ja
                            • Dr.PieD Dr.Pie
                              simatecS Offline
                              simatecS Offline
                              simatec
                              @dr-pie Sind auf deinem PI die cifs-utils installierst?
                              sudo apt update
                              sudo apt install cifs-utils
                              • Besuche meine Github Seite
                              • HowTo Restore ioBroker
                              • simatecS simatec
                                sudo apt update
                                Dr.PieD Offline
                                Dr.PieD Offline
                                Dr.Pie
                                @simatec ich gebe auf ... hab das nun so eingestellt das Backup's lokal gespeichert werden.
                                Das ist zwar nicht optimal ... aber anders scheint es bei mir nicht zu funktionieren
                                Thomas BraunT simatecS HomoranH 3 Antworten Letzte Antwort
                                • Dr.PieD Dr.Pie
                                  Vermutlich nur eine Frage der Einstellungen auf der Server.
                                  Ich würde ja für den Zweck des Backups einen eigenen User dort anlegen. Bei mir heißt der praktischerweise 'iobroker'.
                                    Dr.PieD Offline
                                    Dr.PieD Offline
                                    Dr.Pie
                                    @thomas-braun Wie ich ja schon schrieb hat der User, der in den Einstellungen steht, Lese und Schreibrechte.
                                    • Dr.PieD Dr.Pie
                                      @dr-pie
                                      Leg doch mal einen zweckgebundenen user an.
                                      • Dr.PieD Dr.Pie
                                        simatecS Offline
                                        simatecS Offline
                                        simatec
                                        @dr-pie doch das geht auch auf deinem System.
                                        Sehr viele User nutzen das selbe Setup, wie du es hast.
                                        Ist alles nur ne Sache der Config.
                                        Liefere hier doch mal genaue Details.
                                        Zeige die Config von Backitup und deinem NAS.
                                        Sind die cifs-utils installiert.
                                        Hier kann dir nur geholfen werden, wenn du auch die Fragen beantwortest und Input lieferst.
                                        • Dr.PieD Dr.Pie
                                          ich gebe auf
                                          warum?
                                          Die Sache systematisch angehen, dann klappte es auch.
                                          Fragen wie:
                                          @simatec sagte in Backup funktioniert nicht wirklich:
                                          sind ja nicht um dich zu ärgern! Eine Antwort würde die möglichen Ursachen zumindest eingrenzen.
                                          wie auch:
                                          • ist cifs/samba auf der Syno aktiv?
                                            • welche Version?
                                          • welche Version ist in der Backitup config ausgewählt?
                                            • wue sehen überhaupt deine Einstellungen aus?
