  4. (Gelöst) Fehlermeldung bei Backitup
    5.4k
67 Beiträge 5 Kommentatoren 5.3k Aufrufe 5 Beobachtet
  • Damrak2022D Damrak2022
    @damrak2022 Das lief durch
    pi@homebridge:~ $ sudo apt update
    Hit:1 http://security.debian.org/debian-security bullseye-security InRelease
    Hit:2 http://deb.debian.org/debian bullseye InRelease
    Hit:3 http://deb.debian.org/debian bullseye-updates InRelease
    Hit:4 http://archive.raspberrypi.org/debian bullseye InRelease
    Get:5 https://repos.influxdata.com/debian bullseye InRelease [4,739 B]
    Hit:6 https://packages.grafana.com/oss/deb stable InRelease
    Hit:7 https://deb.nodesource.com/node_14.x bullseye InRelease
    Get:8 https://repos.influxdata.com/debian bullseye/stable arm64 Packages [1,268 B]
    Get:9 https://repos.influxdata.com/debian bullseye/stable armhf Packages [778 B]
    Fetched 6,785 B in 2s (3,467 B/s)
    Reading package lists... Done
    12 packages can be upgraded. Run 'apt list --upgradable' to see them.
    pi@homebridge:~ $ sudo apt install -y gnupg2 curl wget
    curl is already the newest version (7.74.0-1.3+deb11u1).
    wget is already the newest version (1.21-1+deb11u1).
    The following NEW packages will be installed:
      gnupg2
    0 upgraded, 1 newly installed, 0 to remove and 12 not upgraded.
    Need to get 434 kB of archives.
    After this operation, 453 kB of additional disk space will be used.
    Get:1 http://deb.debian.org/debian bullseye/main arm64 gnupg2 all 2.2.27-2+deb11u1 [434 kB]
    Fetched 434 kB in 0s (2,871 kB/s)
    Selecting previously unselected package gnupg2.
    (Reading database ... 55608 files and directories currently installed.)
    Preparing to unpack .../gnupg2_2.2.27-2+deb11u1_all.deb ...
    Unpacking gnupg2 (2.2.27-2+deb11u1) ...
    Setting up gnupg2 (2.2.27-2+deb11u1) ...
    Processing triggers for man-db (2.9.4-2) ...
    pi@homebridge:~ $ wget -qO- https://repos.influxdata.com/influxdb.key | sudo apt-key add -
    Warning: apt-key is deprecated. Manage keyring files in trusted.gpg.d instead (see apt-key(8)).
    OK
    pi@homebridge:~ $ echo 'deb https://repos.influxdata.com/debian $(lsb_release -cs) stable' | sudo tee /etc/apt/sources.list.d/influxdb.list
    pi@homebridge:~ $
    @damrak2022 sagte in Fehlermeldung bei Backitup:
    War also doch schon drin...
    sudo apt update
    sudo apt full-upgrade
    sudo reboot
    apt policy influxdb2 influxdb2-cli
      sudo apt update
      sudo reboot
      Damrak2022D Offline
      Damrak2022D Offline
      Damrak2022
      @thomas-braun sagte in Fehlermeldung bei Backitup:
      sudo apt update
      1 Error nach dem ersten Befehl:
      Hit:5 https://packages.grafana.com/oss/deb stable InRelease
      Hit:6 https://deb.nodesource.com/node_14.x bullseye InRelease
      Ign:7 https://repos.influxdata.com/debian $(lsb_release InRelease
      Err:8 https://repos.influxdata.com/debian $(lsb_release Release
        404  Not Found [IP: 2600:9000:223f:2400:7:7790:e740:93a1 443]
      E: The repository 'https://repos.influxdata.com/debian $(lsb_release Release' does not have a Release file.
      N: Updating from such a repository can't be done securely, and is therefore disabled by default.
      N: See apt-secure(8) manpage for repository creation and user configuration details.
      pi@homebridge:~ $
      Mit besten Grüßen
      Andy
        sudo apt update
        pi@homebridge:~ $
        @damrak2022
        In der influxdb.list steht jetzt Quark drin.
        Mit
        cat /etc/apt/sources.list.d/influxdb.list
        schauen was da jetzt drin ist.
          @damrak2022
          Mit
          Damrak2022D Offline
          Damrak2022D Offline
          Damrak2022
          pi@homebridge:~ $ cat /etc/apt/sources.list.d/influxdb.list
          pi@homebridge:~ $
          Jetzt die restlichen 3 Befehle?
          Mit besten Grüßen
          Andy
            pi@homebridge:~ $
            @damrak2022
            Nein. Trag da statt $(lsb_release -cs) einfach nur bullseye ein.
              @damrak2022
              Damrak2022D Offline
              Damrak2022D Offline
              Damrak2022
              @thomas-braun wie komme ich da hin?
              Mit besten Grüßen
              Andy
                @damrak2022 sudo nano /etc/apt/sources.list.d/influxdb.list
                  Damrak2022D Offline
                  Damrak2022D Offline
                  Damrak2022
                  @homoran sagte in Fehlermeldung bei Backitup:
                  Okay, gemacht:
                  deb https://repos.influxdata.com/debian $(bullseye) stable
                  Das $ Zeichen muss noch weg, richtig
                  Mit besten Grüßen
                  Andy
                    Okay, gemacht:
                    @damrak2022
                    So:
                    deb https://repos.influxdata.com/debian bullseye stable
                      @damrak2022
                      So:
                      Damrak2022D Offline
                      Damrak2022D Offline
                      Damrak2022
                      @thomas-braun Okay und jetzt mache ich nochmal update, upgrade usw.
                      Mit besten Grüßen
                      Andy
                        @damrak2022
                        Zeig mal
                        sudo apt update
                          @damrak2022
                          Zeig mal
                          sudo apt update
                          Damrak2022D Offline
                          Damrak2022D Offline
                          Damrak2022
                          sudo apt update
                          Hit:1 http://deb.debian.org/debian bullseye InRelease
                          Hit:2 http://deb.debian.org/debian bullseye-updates InRelease
                          Hit:3 http://security.debian.org/debian-security bullseye-security InRelease
                          Hit:5 https://deb.nodesource.com/node_14.x bullseye InRelease
                          Hit:7 https://repos.influxdata.com/debian bullseye InRelease
                          pi@homebridge:~ $
                          Mit besten Grüßen
                          Andy
                            sudo apt update
                            pi@homebridge:~ $
                            @damrak2022
                            Dann hau jetzt die 12 Updates rein.
                            iobroker stop
                            sudo reboot
                            Dann mal schauen, ob influxdb2 zur Verfügung stünde:
                              @damrak2022
                              iobroker stop
                              sudo reboot
                              Damrak2022D Offline
                              Damrak2022D Offline
                              Damrak2022
                              Nach dem sudo reboot musste ich den raspi vom Strom nehmen, da die grüne LED dauerhaft leuchtetet und im Terminal ein Timeout kam.
                              Danach dann so:
                              pi@homebridge:~ $ apt policy influxdb2 influxdb2-cli
                              influxdb2:
                                Installed: 2.2.0
                                Candidate: 2.2.0
                                Version table:
                               *** 2.2.0 500
                                      500 https://repos.influxdata.com/debian bullseye/stable arm64 Packages
                              influxdb2-cli:
                                Installed: (none)
                                Candidate: 2.3.0
                                Version table:
                                   2.3.0 500
                              pi@homebridge:~ $
                              Mit besten Grüßen
                              Andy
                                Danach dann so:
                                influxdb2:
                                  Installed: 2.2.0
                                  Candidate: 2.2.0
                                  Version table:
                                 *** 2.2.0 500
                                influxdb2-cli:
                                  Installed: (none)
                                  Candidate: 2.3.0
                                  Version table:
                                     2.3.0 500
                                pi@homebridge:~ $
                                Dann wundere dich nicht, wenn du ihn jetzt komplett neu aufsetzen musst
                                  Damrak2022D Offline
                                  Damrak2022D Offline
                                  Damrak2022
                                  @homoran Ich weiß, das man das nicht machen soll, aber es ging nichts voran. Warum das beim sudo reboot manchmal so ist weiß ich nicht
                                  Aber es ist ja zum Glück noch alles da.
                                  Mit besten Grüßen
                                  Andy
                                    @damrak2022
                                    Ähhhh... Mach das NIE NIE NIE NIEMALS!
                                    Jenachdem welches Update das ist dauert der Neustart ein wenig.
                                    Strom weg während solcher Operationen ist einer der sichersten Wege seinen Raspberry zu exekutieren.
                                      @damrak2022
                                      Damrak2022D Offline
                                      Damrak2022D Offline
                                      Damrak2022
                                      @thomas-braun okay, jetzt muss nur noch das cli drauf. So wie Du das oben beschrieben hast?
                                      Mit besten Grüßen
                                      Andy
                                        @damrak2022
                                        So wie man Software immer installiert:
                                        sudo apt install influxdb2-cli
                                        Damrak2022D liv-in-skyL 4 Antworten Letzte Antwort
                                          woher willst du das wissen?
                                          Dei RasPi kann jetzt in einem undefinierten Zustandsein, was sich erst irgendwann äußert.
