  4. (Gelöst) Fehlermeldung bei Backitup
    5.4k
67 Beiträge 5 Kommentatoren 5.3k Aufrufe 5 Beobachtet
  • Damrak2022D Damrak2022
    @thomas-braun Nach einer Anleitung von der Influx Seite glaube ich. Aber durch Dich lerne ich gerade das man anscheinend über sudo update usw. installiert, wenn alles stimmt
    Damrak2022D Offline
    Damrak2022D Offline
    Damrak2022
    @damrak2022 Das lief durch
    pi@homebridge:~ $ sudo apt update
    Hit:1 http://security.debian.org/debian-security bullseye-security InRelease
    Hit:2 http://deb.debian.org/debian bullseye InRelease
    Hit:3 http://deb.debian.org/debian bullseye-updates InRelease
    Hit:4 http://archive.raspberrypi.org/debian bullseye InRelease
    Get:5 https://repos.influxdata.com/debian bullseye InRelease [4,739 B]
    Hit:6 https://packages.grafana.com/oss/deb stable InRelease
    Hit:7 https://deb.nodesource.com/node_14.x bullseye InRelease
    Get:8 https://repos.influxdata.com/debian bullseye/stable arm64 Packages [1,268 B]
    Get:9 https://repos.influxdata.com/debian bullseye/stable armhf Packages [778 B]
    Fetched 6,785 B in 2s (3,467 B/s)
    Reading package lists... Done
    12 packages can be upgraded. Run 'apt list --upgradable' to see them.
    pi@homebridge:~ $ sudo apt install -y gnupg2 curl wget
    curl is already the newest version (7.74.0-1.3+deb11u1).
    wget is already the newest version (1.21-1+deb11u1).
    The following NEW packages will be installed:
      gnupg2
    0 upgraded, 1 newly installed, 0 to remove and 12 not upgraded.
    Need to get 434 kB of archives.
    After this operation, 453 kB of additional disk space will be used.
    Get:1 http://deb.debian.org/debian bullseye/main arm64 gnupg2 all 2.2.27-2+deb11u1 [434 kB]
    Fetched 434 kB in 0s (2,871 kB/s)
    Selecting previously unselected package gnupg2.
    (Reading database ... 55608 files and directories currently installed.)
    Preparing to unpack .../gnupg2_2.2.27-2+deb11u1_all.deb ...
    Unpacking gnupg2 (2.2.27-2+deb11u1) ...
    Setting up gnupg2 (2.2.27-2+deb11u1) ...
    Processing triggers for man-db (2.9.4-2) ...
    pi@homebridge:~ $ wget -qO- https://repos.influxdata.com/influxdb.key | sudo apt-key add -
    Warning: apt-key is deprecated. Manage keyring files in trusted.gpg.d instead (see apt-key(8)).
    OK
    pi@homebridge:~ $ echo 'deb https://repos.influxdata.com/debian $(lsb_release -cs) stable' | sudo tee /etc/apt/sources.list.d/influxdb.list
    pi@homebridge:~ $
    Mit besten Grüßen
    Andy
        gnupg2
      OK
      pi@homebridge:~ $
      @damrak2022 sagte in Fehlermeldung bei Backitup:
      War also doch schon drin...
      sudo apt update
      sudo apt full-upgrade
      sudo reboot
      apt policy influxdb2 influxdb2-cli
        sudo apt update
        sudo reboot
        Damrak2022D Offline
        Damrak2022D Offline
        Damrak2022
        @thomas-braun sagte in Fehlermeldung bei Backitup:
        sudo apt update
        1 Error nach dem ersten Befehl:
        Hit:5 https://packages.grafana.com/oss/deb stable InRelease
        Hit:6 https://deb.nodesource.com/node_14.x bullseye InRelease
        Ign:7 https://repos.influxdata.com/debian $(lsb_release InRelease
        Err:8 https://repos.influxdata.com/debian $(lsb_release Release
          404  Not Found [IP: 2600:9000:223f:2400:7:7790:e740:93a1 443]
        E: The repository 'https://repos.influxdata.com/debian $(lsb_release Release' does not have a Release file.
        N: Updating from such a repository can't be done securely, and is therefore disabled by default.
        N: See apt-secure(8) manpage for repository creation and user configuration details.
        pi@homebridge:~ $
        Mit besten Grüßen
        Andy
          sudo apt update
          pi@homebridge:~ $
          @damrak2022
          In der influxdb.list steht jetzt Quark drin.
          Mit
          cat /etc/apt/sources.list.d/influxdb.list
          schauen was da jetzt drin ist.
            @damrak2022
            Mit
            Damrak2022D Offline
            Damrak2022D Offline
            Damrak2022
            pi@homebridge:~ $ cat /etc/apt/sources.list.d/influxdb.list
            pi@homebridge:~ $
            Jetzt die restlichen 3 Befehle?
            Mit besten Grüßen
            Andy
              pi@homebridge:~ $
              @damrak2022
              Nein. Trag da statt $(lsb_release -cs) einfach nur bullseye ein.
                @damrak2022
                Damrak2022D Offline
                Damrak2022D Offline
                Damrak2022
                @thomas-braun wie komme ich da hin?
                Mit besten Grüßen
                Andy
                  @damrak2022 sudo nano /etc/apt/sources.list.d/influxdb.list
                    Damrak2022D Offline
                    Damrak2022D Offline
                    Damrak2022
                    @homoran sagte in Fehlermeldung bei Backitup:
                    Okay, gemacht:
                    deb https://repos.influxdata.com/debian $(bullseye) stable
                    Das $ Zeichen muss noch weg, richtig
                    Mit besten Grüßen
                    Andy
                      Okay, gemacht:
                      @damrak2022
                      So:
                      deb https://repos.influxdata.com/debian bullseye stable
                        @damrak2022
                        So:
                        Damrak2022D Offline
                        Damrak2022D Offline
                        Damrak2022
                        @thomas-braun Okay und jetzt mache ich nochmal update, upgrade usw.
                        Mit besten Grüßen
                        Andy
                          @damrak2022
                          Zeig mal
                          sudo apt update
                            @damrak2022
                            Zeig mal
                            sudo apt update
                            Damrak2022D Offline
                            Damrak2022D Offline
                            Damrak2022
                            sudo apt update
                            Hit:1 http://deb.debian.org/debian bullseye InRelease
                            Hit:2 http://deb.debian.org/debian bullseye-updates InRelease
                            Hit:3 http://security.debian.org/debian-security bullseye-security InRelease
                            Hit:5 https://deb.nodesource.com/node_14.x bullseye InRelease
                            Hit:7 https://repos.influxdata.com/debian bullseye InRelease
                            pi@homebridge:~ $
                            Mit besten Grüßen
                            Andy
                              sudo apt update
                              pi@homebridge:~ $
                              @damrak2022
                              Dann hau jetzt die 12 Updates rein.
                              iobroker stop
                              sudo reboot
                              Dann mal schauen, ob influxdb2 zur Verfügung stünde:
                                @damrak2022
                                iobroker stop
                                sudo reboot
                                Damrak2022D Offline
                                Damrak2022D Offline
                                Damrak2022
                                Nach dem sudo reboot musste ich den raspi vom Strom nehmen, da die grüne LED dauerhaft leuchtetet und im Terminal ein Timeout kam.
                                Danach dann so:
                                pi@homebridge:~ $ apt policy influxdb2 influxdb2-cli
                                influxdb2:
                                  Installed: 2.2.0
                                  Candidate: 2.2.0
                                  Version table:
                                 *** 2.2.0 500
                                        500 https://repos.influxdata.com/debian bullseye/stable arm64 Packages
                                influxdb2-cli:
                                  Installed: (none)
                                  Candidate: 2.3.0
                                  Version table:
                                     2.3.0 500
                                pi@homebridge:~ $
                                Mit besten Grüßen
                                Andy
                                  Danach dann so:
                                  influxdb2:
                                    Installed: 2.2.0
                                    Candidate: 2.2.0
                                    Version table:
                                   *** 2.2.0 500
                                  influxdb2-cli:
                                    Installed: (none)
                                    Candidate: 2.3.0
                                    Version table:
                                       2.3.0 500
                                  pi@homebridge:~ $
                                  Dann wundere dich nicht, wenn du ihn jetzt komplett neu aufsetzen musst
                                    Damrak2022D Offline
                                    Damrak2022D Offline
                                    Damrak2022
                                    @homoran Ich weiß, das man das nicht machen soll, aber es ging nichts voran. Warum das beim sudo reboot manchmal so ist weiß ich nicht
                                    Aber es ist ja zum Glück noch alles da.
                                    Mit besten Grüßen
                                    Andy
                                      @damrak2022
                                      Ähhhh... Mach das NIE NIE NIE NIEMALS!
                                      Jenachdem welches Update das ist dauert der Neustart ein wenig.
                                      Strom weg während solcher Operationen ist einer der sichersten Wege seinen Raspberry zu exekutieren.
                                        @damrak2022
                                        Damrak2022D Offline
                                        Damrak2022D Offline
                                        Damrak2022
                                        @thomas-braun okay, jetzt muss nur noch das cli drauf. So wie Du das oben beschrieben hast?
                                        Mit besten Grüßen
                                        Andy
                                          @damrak2022
                                          So wie man Software immer installiert:
                                          sudo apt install influxdb2-cli
                                          Damrak2022D liv-in-skyL 4 Antworten Letzte Antwort
