  4. Installation defekt?
    6.1k
51 Beiträge 6 Kommentatoren 6.5k Aufrufe 4 Beobachtet
    @qqolli
    Vielleicht aktivierst du mal die Option 'noserverino'.
    qqolliQ Offline
    qqolliQ Offline
    qqolli
    Auch mit aktiviertem "'noserverino'" wieder nichts:
    Started iobroker ...
    [DEBUG] [mount] - noserverino option: true
    [DEBUG] [mount] - cifs-mount command: "sudo mount -t cifs -o username=backup,password=****,noserverino,rw,file_mode=0777,dir_mode=0777,vers=3.1.1 //192.168.178.23/backup/ioBroker/ /opt/iobroker/backups"
    [DEBUG] [mount] - mount successfully completed
    [DEBUG] [mount] - done
    [DEBUG] [iobroker] - host.ioBroker 66335 states saved
    [DEBUG] [iobroker] - host.ioBroker 86194 objects saved
    [DEBUG] [iobroker] - done
    [DEBUG] [cifs] - done
    [DEBUG] [clean] - done
    [DEBUG] [pushover] - done
    [DEBUG] [historyHTML] - new history html values created
    [DEBUG] [historyHTML] - done
    [DEBUG] [historyJSON] - new history json values created
    [DEBUG] [historyJSON] - done
    [DEBUG] [umount] - mount activ, umount is started ...
    [DEBUG] [umount] - umount successfully completed
    [DEBUG] [umount] - done
    [EXIT] 0
    Verzeichnis nach unmount leer.
    Ich frag mich echt, wo der das hinschreibt, es aber nie auf der NAS auftaucht.
    PS: Vor nicht allzu langer Zeit wurde mir hier im Forum geraten, die "noserverino" abzuschalten :-) Wobei, wenn ich ehrlich bin, noch nicht mal weiss wozu die gut ist.
    • qqolliQ qqolli
      @thomas-braun @simatec
      Na, schau mal einer an:
      pi@ioBroker:~ $ iobroker backup
      host.ioBroker 67346 states saved
      host.ioBroker 87510 objects saved
      Backup created: /opt/iobroker/backups/2022_04_20-12_07_26_backupiobroker.tar.gz
      pi@ioBroker:~ $ ls -al /opt/iobroker/backups/
      insgesamt 38780
      drwxrwxr-x+  2 iobroker iobroker    12288 Apr 20 12:08 .
      drwxrwxr-x+ 10 iobroker iobroker     4096 Apr 20 11:50 ..
      -rw-rw-r--+  1 iobroker iobroker 39692317 Apr 20 12:08 2022_04_20-12_07_26_backupiobroker.tar.gz
      pi@ioBroker:~ $
      Und endlich auch:
      [DEBUG] [mount] - noserverino option: false
      [DEBUG] [mount] - cifs-mount command: "sudo mount -t cifs -o username=backup,password=****,rw,file_mode=0777,dir_mode=0777,vers=3.1.1 //192.168.178.23/backup/ioBroker /opt/iobroker/backups"
      [DEBUG] [iobroker] - host.ioBroker 67346 states saved
      [DEBUG] [iobroker] - host.ioBroker 87510 objects saved
      [DEBUG] [iobroker] - Backup created: /opt/iobroker/backups/iobroker_2022_04_20-12_10_45_backupiobroker.tar.gz
      [EXIT] 0
      ist das Backup wieder auf der NAS!!!
      Vielen lieben dank an euch beide für die Hilfe und eure Zeit! Ihr seid die Besten :-)
      qqolliQ Offline
      qqolliQ Offline
      qqolli
      @qqolli @simatec
      leider war die Freude nur von kurzer Dauer :-(
      Heute wieder wie zuvor:
      host.ioBroker 67642 states saved
      host.ioBroker 87958 objects saved
      /usr/bin/iobroker: Zeile 8: 23217 Getötet                sudo -H -u iobroker node /opt/iobroker/node_modules/iobroker.js-controller/iobroker.js "$@"
      insgesamt 16
      drwxrwxr-x+  2 iobroker iobroker 12288 Apr 20 13:07 .
      drwxrwxr-x+ 10 iobroker iobroker  4096 Apr 20 15:21 .
      • qqolliQ qqolli
        @qqolli @simatec
        insgesamt 16
        @qqolli sagte in Test Adapter Backitup v2.4.x:
        Kommt bei
        wirklich das raus?
        Oder lautet das richtig
        drwxrwxr-x+ 10 iobroker iobroker  4096 Apr 20 15:21 ..
        qqolliQ 1 Antwort Letzte Antwort
          Kommt bei
          wirklich das raus?
          qqolliQ Offline
          qqolliQ Offline
          qqolli
          Habe es nochmal durchgeführt, da waren jetzt keine Punkte:
          • qqolliQ qqolli
            @qqolli bitte als text in code-tags.
            ich glaube entziffern zu können, dass da Punkte sind
              qqolliQ Offline
              qqolliQ Offline
              qqolli
              @homoran @thomas-braun
              Komisch, im Terminal sehe ich keine Punkte, deswegen der Screenshot. Aber wenn ich es im Terminal markiere, sind die Punkte da:
              host.ioBroker 67714 states saved
              host.ioBroker 88054 objects saved
              /usr/bin/iobroker: Zeile 8: 10631 Getötet                sudo -H -u iobroker node /opt/iobroker/node_modules/iobroker.js-controller/iobroker.js "$@"
              insgesamt 16
              pi@ioBroker:~
              • qqolliQ qqolli
                insgesamt 16
                pi@ioBroker:~
                @qqolli
                Komisch.
                Hat aber wohl mit deinem Problem nix zu tun.
                Welches Terminal verwendest du denn?
                • qqolliQ qqolli
                  insgesamt 16
                  pi@ioBroker:~
                  aber sie dind da und wir können so einen kontrastarmen Screenshot auch nicht entziffern. Schon gar nicht auf dem Handy.
                    simatecS Offline
                    simatecS Offline
                    simatec
                    @homoran Kannst du eventuell zu dieser Diskussion hier ein neues Thema erstellen und die ganzen Beiträge dorthin verschieben?
                    Es hat nichts mit Backitup zu tun und der Thread ist schon extrem groß.
                    • Besuche meine Github Seite
                    • HowTo Restore ioBroker
                    HomoranH qqolliQ 2 Antworten Letzte Antwort
                    • simatecS simatec
                      @simatec mach ich, wenn ich am PC bin
                        simatecS Offline
                        simatecS Offline
                        simatec
                        @homoran Danke dir 👍
                          @qqolli
                          Komisch.
                          qqolliQ Offline
                          qqolliQ Offline
                          qqolli
                          Na ja, dafür hatte ich die Windows PowerShell benutzt :-( .
                          Bin jetzt aber auf Putty gegangen, da sieht man die Punkte ganz klar.
                          • qqolliQ qqolli
                            diwoma
                            @qqolli
                            Ab Windows 10 kannst Du dafür auch das "neue" Terminal benutzen, dass das alte cmd ersetzt. Mit dem kannst Du auch eine Shell zum Ubuntu-Subsystem öffnen (wenn es installiert ist)
                            -- diwoma
                            ioBroker in LX-Container in Proxmox
                            Zigbee-Coordinator: CC2652P2-TCP FW: 20230507
                            • simatecS simatec
                              @simatec sagte in Installation defekt?:
                              Hab da mal etwas abgespalten.
                              Habe aber selber nicht den Überblick, was noch in den BackitUp Thread passt.
                              Wenn noch mehr hierher muss, bitte Bescheid geben!
                              @qqolli
                              Bitte einen sinnvollen Titel einfallen lassen
                                @qqolli
                                qqolliQ Offline
                                qqolliQ Offline
                                qqolli
                                Ja, das mit dem Titel ist nicht so einfach, da wir ja noch in der Ursachenfindung sind.
                                Insofern würde ich Deinen Titel erstmal als "Arbeitstitel" stehen lassen, wenn das ok ist.
                                • simatecS simatec
                                  qqolliQ Offline
                                  qqolliQ Offline
                                  qqolli
                                  @simatec
                                  Wie kannst Du ausschliessen, das Backitup nichts damit zu tun hat?
                                  Nachdem ich den js-controller neu aufgesetzt hatte, ging es einmal (Sicherung direkt über den Adapter).
                                  Beim zweiten Mal schon nicht mehr, die Sicherung nicht über den Adapter, sondern über (weiss nicht wie man den nennt):
                                  Als ich dann auf dem Raspi nachgeschaut habe, war das Verzeichnis nicht dismounted. Danach wieder über den Adapter, und es wurde zwar dismounted, aber kein Backup auf der NAS angelegt (gleiche Fehlermeldung wie vor der Neuinstallation des js-controllers):
                                  Seitdem ging es nicht mehr. Wenn ich es verifizieren müsste, muss ich wieder alles neu installieren.
                                  Insofern würde ich nicht kategorisch ausschließen, das der Adapter nichts damit zu tun hat. Könnte es (rein theoretisch) einen Unterschied zwischen den beiden "Methoden" geben (Adapter direkt vs. Tab)?
                                  • qqolliQ qqolli
                                    @simatec
                                    simatecS Offline
                                    simatecS Offline
                                    simatec
                                    @qqolli Weil Backitup nichts an deinem System ändert, wenn du ein Backup erstellst und wenn nich ein mount gesetzt ist, sollte dies spätestens nach einem Neustart behoben sein.
                                    Aber auch nach einem Neustart kannst du kein Backup auf der CLI erstellen
                                    • simatecS simatec
                                      qqolliQ Offline
                                      qqolliQ Offline
                                      qqolli
                                      @simatec
                                      Ok, verstanden.
                                      Verwirrend für mich war (ist), das der Adapter trotzdem sagt (z. B. per Pushover), das eine Sicherung erfolgt und auf der NAS abgelegt wurde, obwohl das bei mir nicht der Fall ist. Daher habe ich das erst sehr spät bemerkt, da ich ja immer davon ausgegangen bin das alles ok ist und somit jede Menge iobroker-Sicherungen nicht angelegt wurden. Eventuell könnte man (falls möglich) noch im Adapter ändern.
                                      Alles in allem, hättet (@thomas-braun) ihr trotzdem noch irgendeine Idee, was ich noch machen könnte/sollte?
                                      • qqolliQ qqolli
                                        @simatec
                                        Ok, verstanden.
                                        simatecS Offline
                                        simatecS Offline
                                        simatec
                                        @qqolli
                                        Zeige mal bitte den Inhalt von "/var/log/syslog"
                                        So wie es ausschaut killt irgendwas das backup ...
                                        Könnte ein RAM Problem sein. Wie gross ist iobroker-data?
                                        Was gibt "free-m" bei erstellen des Backups aus?
                                        • simatecS simatec
                                          @qqolli
                                          qqolliQ Offline
                                          qqolliQ Offline
                                          qqolli
                                          @simatec
                                          Die syslog-Datei enthält 22559 Zeilen, ich denke die ist zu groß um sie hier anzuzeigen. Kann man da die Infos die diDich interessieren irgendwie "rausfiltern" und wenn ja, wie?
                                          Größe des iobroker-data:
                                          pi@ioBroker:~ $ du -sh iobroker-data
                                          96K	iobroker-data
                                          free -m vor dem Backup ergibt:
                                          pi@ioBroker:~ $ free -m
                                          Mem:           3837        3182         204         113         449         694
                                          Swap:            99          99           0
                                          Wobei ich echt nicht weiss, warum das swap immer voll läuft.
                                          pi@ioBroker:~ $ sudo service dphys-swapfile status
                                          ● dphys-swapfile.service - dphys-swapfile - set up, mount/unmount, and delete a swap file
                                             Loaded: loaded (/lib/systemd/system/dphys-swapfile.service; enabled; vendor preset: enabled)
                                             Active: active (exited) since Sat 2022-04-16 08:43:59 CEST; 6 days ago
                                               Docs: man:dphys-swapfile(8)
                                           Main PID: 500 (code=exited, status=0/SUCCESS)
                                              Tasks: 0 (limit: 4915)
                                             CGroup: /system.slice/dphys-swapfile.service
                                          Apr 16 08:43:58 ioBroker systemd[1]: Starting dphys-swapfile - set up, mount/unmount, and delete a swap file...
                                          Apr 16 08:43:59 ioBroker dphys-swapfile[360]: want /var/swap=100MByte, checking existing: keeping it
                                          Apr 16 08:43:59 ioBroker systemd[1]: Started dphys-swapfile - set up, mount/unmount, and delete a swap file.
                                          Ich lösche es ab und zu mit:
                                          sudo swapoff -a
                                          sudo swapon -a
                                          free -m während des Backups ergibt (aus zweitem Fenster ermittelt):
                                          Mem:           3837        3333          85         113         418         456
                                          Swap:            99          99           0
                                          Und danach wieder:
                                          Mem:           3837        3037         614         113         186         574
                                          Swap:            99          99           0
                                          Thomas BraunT simatecS 2 Antworten Letzte Antwort
