  4. Test Adapter Husqvarna Automower v0.3.x
    apollon77A
husqvarnaautomower
439 Beiträge 73 Kommentatoren 168.9k Aufrufe 62 Beobachtet
  • BoronsbruderB
    BoronsbruderB
    Boronsbruder
    schrieb am zuletzt editiert von Boronsbruder
    #214
    @greyhound
    Hilfe!
    Gestern gab der Automower-Adapter mit folgender Meldung den Geist auf!
    2022-03-28 09:27:18.814 - error: husq-automower.0 (30998) updateStatus geo_response.statusCode: 404
    2022-03-28 09:28:19.540 - warn: husq-automower.0 (30998) updateStatus typeof response or result === undefined
    2022-03-28 09:29:20.584 - warn: husq-automower.0 (30998) updateStatus typeof response or result === undefined
    Nach einem Neustart der Instanz kam nur noch
    2022-03-28 19:23:51.635 - info: host.zerobroker stopInstance system.adapter.husq-automower.0 (force=false, process=true)
    2022-03-28 19:23:51.637 - info: host.zerobroker stopInstance system.adapter.husq-automower.0 send kill signal
    2022-03-28 19:23:51.639 - info: husq-automower.0 (30998) Got terminate signal TERMINATE_YOURSELF
    2022-03-28 19:23:51.640 - info: husq-automower.0 (30998) Logged off.
    2022-03-28 19:23:51.641 - info: husq-automower.0 (30998) cleaned everything up...
    2022-03-28 19:23:51.641 - info: husq-automower.0 (30998) terminating
    2022-03-28 19:23:51.642 - info: husq-automower.0 (30998) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    2022-03-28 19:23:52.205 - info: host.zerobroker instance system.adapter.husq-automower.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2022-03-28 19:23:54.662 - info: host.zerobroker instance system.adapter.husq-automower.0 started with pid 28334
    2022-03-28 19:23:55.191 - info: husq-automower.0 (28334) starting. Version 1.1.2 (non-npm: truegreyhound/ioBroker.husq-automower#7a8ed7031d6e945544c0adbb05d82cc0f322f954) in /opt/iobroker/node_modules/iobroker.husq-automower, node: v14.19.1, js-controller: 4.0.21
    2022-03-28 19:23:55.217 - info: husq-automower.0 (28334) State value to set for "husq-automower.0.mower.homeLocation.maxDistance" has to be type "number" but received type "string"
    2022-03-28 19:23:55.217 - info: husq-automower.0 (28334) State value to set for "husq-automower.0.mower.waitAfterRain" has to be type "number" but received type "string"
    2022-03-28 19:23:57.208 - info: husq-automower.0 (28334) Logged off.
    2022-03-28 19:23:57.233 - info: husq-automower.0 (28334) updateStatus mower object is NULL
    dann im Sekundentakt der "updateStatus mower object is NULL"
    Ich habe schon die Instanz, den Adapter, gelöscht und neuinstalliert...
    Das folgende Log ist nach der Neuinstallation
    2022-03-29 19:37:40.663 - info: host.zerobroker instance system.adapter.husq-automower.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2022-03-29 19:37:43.121 - info: host.zerobroker instance system.adapter.husq-automower.0 started with pid 25064
    2022-03-29 19:37:43.403 - debug: husq-automower.0 (25064) Redis Objects: Use Redis connection: 127.0.0.1:9001
    2022-03-29 19:37:43.515 - debug: husq-automower.0 (25064) Objects client ready ... initialize now
    2022-03-29 19:37:43.516 - debug: husq-automower.0 (25064) Objects create System PubSub Client
    2022-03-29 19:37:43.517 - debug: husq-automower.0 (25064) Objects create User PubSub Client
    2022-03-29 19:37:43.545 - debug: husq-automower.0 (25064) Objects client initialize lua scripts
    2022-03-29 19:37:43.548 - debug: husq-automower.0 (25064) Objects connected to redis: 127.0.0.1:9001
    2022-03-29 19:37:43.565 - debug: husq-automower.0 (25064) Redis States: Use Redis connection: 127.0.0.1:6379
    2022-03-29 19:37:43.568 - debug: husq-automower.0 (25064) States create System PubSub Client
    2022-03-29 19:37:43.568 - debug: husq-automower.0 (25064) States create User PubSub Client
    2022-03-29 19:37:43.571 - debug: husq-automower.0 (25064) States connected to redis: 127.0.0.1:6379
    2022-03-29 19:37:43.641 - info: husq-automower.0 (25064) starting. Version 1.1.2 (non-npm: truegreyhound/ioBroker.husq-automower#7a8ed7031d6e945544c0adbb05d82cc0f322f954) in /opt/iobroker/node_modules/iobroker.husq-automower, node: v14.19.1, js-controller: 4.0.21
    2022-03-29 19:37:43.654 - debug: husq-automower.0 (25064) createDataStructure started
    2022-03-29 19:37:43.654 - debug: husq-automower.0 (25064) createChannels started
    2022-03-29 19:37:43.655 - debug: husq-automower.0 (25064) createChannels finished
    2022-03-29 19:37:43.655 - debug: husq-automower.0 (25064) createDataStructure finished
    2022-03-29 19:37:43.656 - debug: husq-automower.0 (25064) Mail address: ************
    2022-03-29 19:37:43.656 - debug: husq-automower.0 (25064) waitAfterRain:
    2022-03-29 19:37:43.657 - debug: husq-automower.0 (25064) syncConfigAsync started
    2022-03-29 19:37:43.658 - debug: husq-automower.0 (25064) createDataStructure, createChannels() finished; result: {"msg":"Success","data":true}
    2022-03-29 19:37:43.658 - debug: husq-automower.0 (25064) createDPs started
    2022-03-29 19:37:43.659 - debug: husq-automower.0 (25064) createDPs finished
    2022-03-29 19:37:43.666 - debug: husq-automower.0 (25064) syncConfigAsync, mJsonLastLocations:[]
    2022-03-29 19:37:43.667 - debug: husq-automower.0 (25064) syncConfigAsync finished
    2022-03-29 19:37:43.669 - info: husq-automower.0 (25064) State value to set for "husq-automower.0.mower.homeLocation.maxDistance" has to be type "number" but received type "string"
    2022-03-29 19:37:43.669 - info: husq-automower.0 (25064) State value to set for "husq-automower.0.mower.waitAfterRain" has to be type "number" but received type "string"
    2022-03-29 19:37:43.718 - debug: husq-automower.0 (25064) syncConfigAsync, processing state: "mower.homeLocation.name" with value ""
    2022-03-29 19:37:43.719 - debug: husq-automower.0 (25064) syncConfigAsync, processing state: "mower.homeLocation.longitude" with value "0"
    2022-03-29 19:37:43.719 - debug: husq-automower.0 (25064) syncConfigAsync, processing state: "mower.homeLocation.latitude" with value "0"
    2022-03-29 19:37:43.719 - debug: husq-automower.0 (25064) syncConfigAsync, processing state: "mower.homeLocation.longitudeCP" with value "0"
    2022-03-29 19:37:43.719 - debug: husq-automower.0 (25064) syncConfigAsync, processing state: "mower.homeLocation.latitudeCP" with value "0"
    2022-03-29 19:37:43.719 - debug: husq-automower.0 (25064) syncConfigAsync, processing state: "mower.homeLocation.longitudeOffset" with value "0"
    2022-03-29 19:37:43.720 - debug: husq-automower.0 (25064) syncConfigAsync, processing state: "mower.homeLocation.latitudeOffset" with value "0"
    2022-03-29 19:37:43.720 - debug: husq-automower.0 (25064) syncConfigAsync, processing state: "mower.homeLocation.currentDistance" with value "0"
    2022-03-29 19:37:43.720 - debug: husq-automower.0 (25064) syncConfigAsync, processing state: "mower.homeLocation.maxDistance" with value "500"
    2022-03-29 19:37:43.720 - debug: husq-automower.0 (25064) syncConfigAsync, processing state: "mower.homeLocation.sensitivityLevel" with value "3"
    2022-03-29 19:37:43.720 - debug: husq-automower.0 (25064) syncConfigAsync, processing state: "mower.homeLocation.sensitivityRadius" with value "1000"
    2022-03-29 19:37:43.721 - debug: husq-automower.0 (25064) syncConfigAsync, processing state: "mower.lastLocation.latitude" with value "0"
    2022-03-29 19:37:43.721 - debug: husq-automower.0 (25064) syncConfigAsync, processing state: "mower.lastLocation.longitude" with value "0"
    2022-03-29 19:37:43.721 - debug: husq-automower.0 (25064) syncConfigAsync, processing state: "mower.lastLocation.timestamp" with value "0"
    2022-03-29 19:37:43.721 - debug: husq-automower.0 (25064) syncConfigAsync, processing state: "mower.statistics.mowingTime" with value "0"
    2022-03-29 19:37:43.722 - debug: husq-automower.0 (25064) syncConfigAsync, processing state: "mower.statistics.mowingTimeDaily" with value "0"
    2022-03-29 19:37:43.722 - debug: husq-automower.0 (25064) syncConfigAsync, processing state: "mower.statistics.mowingTimeBatteryNew" with value "0"
    2022-03-29 19:37:43.722 - debug: husq-automower.0 (25064) syncConfigAsync, processing state: "mower.statistics.batteryChargeCycleDaily" with value "0"
    2022-03-29 19:37:43.722 - debug: husq-automower.0 (25064) syncConfigAsync, processing state: "mower.statistics.batteryEfficiencyFactor" with value "0"
    2022-03-29 19:37:43.722 - debug: husq-automower.0 (25064) syncConfigAsync, processing state: "mower.statistics.chargingBatteryStarttime" with value "0"
    2022-03-29 19:37:43.722 - debug: husq-automower.0 (25064) syncConfigAsync, processing state: "mower.statistics.chargingTimeBatteryCurrent" with value "0"
    2022-03-29 19:37:43.723 - debug: husq-automower.0 (25064) syncConfigAsync, processing state: "mower.statistics.chargingTimeBatteryDaily" with value "0"
    2022-03-29 19:37:43.723 - debug: husq-automower.0 (25064) syncConfigAsync, processing state: "mower.statistics.chargingTimeBatteryNew" with value "0"
    2022-03-29 19:37:43.723 - debug: husq-automower.0 (25064) syncConfigAsync, processing state: "mower.statistics.lastChargingTimeBattery" with value "0"
    2022-03-29 19:37:43.723 - debug: husq-automower.0 (25064) syncConfigAsync, processing state: "mower.statistics.currentCoveredDistance" with value "0"
    2022-03-29 19:37:43.723 - debug: husq-automower.0 (25064) syncConfigAsync, processing state: "mower.statistics.coveredDistanceDaily" with value "0"
    2022-03-29 19:37:43.723 - debug: husq-automower.0 (25064) syncConfigAsync, processing state: "mower.statistics.lastMowingTime" with value "0"
    2022-03-29 19:37:43.724 - debug: husq-automower.0 (25064) syncConfigAsync, processing state: "mower.statistics.lastCoveredDistance" with value "0"
    2022-03-29 19:37:43.724 - debug: husq-automower.0 (25064) syncConfigAsync, processing state: "mower.statistics.lastStationReturnTime" with value "0"
    2022-03-29 19:37:43.724 - debug: husq-automower.0 (25064) syncConfigAsync, processing state: "mower.statistics.overallBatteryChargeCycle" with value "0"
    2022-03-29 19:37:43.724 - debug: husq-automower.0 (25064) syncConfigAsync, processing state: "mower.statistics.overallMowingTime" with value "0"
    2022-03-29 19:37:43.724 - debug: husq-automower.0 (25064) syncConfigAsync, processing state: "mower.statistics.overallCoveredDistance" with value "0"
    2022-03-29 19:37:43.724 - debug: husq-automower.0 (25064) syncConfigAsync, processing state: "mower.action" with value "0"
    2022-03-29 19:37:43.725 - debug: husq-automower.0 (25064) syncConfigAsync, processing state: "mower.batteryPercent" with value "0"
    2022-03-29 19:37:43.725 - debug: husq-automower.0 (25064) syncConfigAsync, processing state: "mower.currentErrorCode" with value "0"
    2022-03-29 19:37:43.725 - debug: husq-automower.0 (25064) syncConfigAsync, processing state: "mower.currentErrorMsg" with value ""
    2022-03-29 19:37:43.725 - debug: husq-automower.0 (25064) syncConfigAsync, processing state: "mower.currentErrorCodeTimestamp" with value "0"
    2022-03-29 19:37:43.725 - debug: husq-automower.0 (25064) syncConfigAsync, processing state: "mower.lastAction" with value "unkonwn"
    2022-03-29 19:37:43.725 - debug: husq-automower.0 (25064) syncConfigAsync, processing state: "mower.lastDockingTime" with value "0"
    2022-03-29 19:37:43.726 - debug: husq-automower.0 (25064) syncConfigAsync, processing state: "mower.lastErrorCode" with value "0"
    2022-03-29 19:37:43.726 - debug: husq-automower.0 (25064) syncConfigAsync, processing state: "mower.lastErrorMsg" with value ""
    2022-03-29 19:37:43.726 - debug: husq-automower.0 (25064) syncConfigAsync, processing state: "mower.lastErrorCodeTimestamp" with value "0"
    2022-03-29 19:37:43.726 - debug: husq-automower.0 (25064) syncConfigAsync, processing state: "mower.lastHttpStatus" with value "0"
    2022-03-29 19:37:43.726 - debug: husq-automower.0 (25064) syncConfigAsync, processing state: "mower.lastLocations" with value "[]"
    2022-03-29 19:37:43.726 - debug: husq-automower.0 (25064) syncConfigAsync, processing state: "mower.lastStatus" with value "unkonwn"
    2022-03-29 19:37:43.726 - debug: husq-automower.0 (25064) syncConfigAsync, processing state: "mower.lastStatusTime" with value "0"
    2022-03-29 19:37:43.726 - debug: husq-automower.0 (25064) syncConfigAsync, processing state: "mower.lastStatusChangeTime" with value "0"
    2022-03-29 19:37:43.727 - debug: husq-automower.0 (25064) syncConfigAsync, processing state: "mower.lastdayLocations" with value "[]"
    2022-03-29 19:37:43.727 - debug: husq-automower.0 (25064) syncConfigAsync, processing state: "mower.nextStartSource" with value ""
    2022-03-29 19:37:43.727 - debug: husq-automower.0 (25064) syncConfigAsync, processing state: "mower.nextStartTime" with value "0"
    2022-03-29 19:37:43.727 - debug: husq-automower.0 (25064) syncConfigAsync, processing state: "mower.nextStartWatching" with value "0"
    2022-03-29 19:37:43.727 - debug: husq-automower.0 (25064) syncConfigAsync, processing state: "mower.operatingMode" with value "unkonwn"
    2022-03-29 19:37:43.727 - debug: husq-automower.0 (25064) syncConfigAsync, processing state: "mower.stopOnRainEnabled" with value "false"
    2022-03-29 19:37:43.727 - debug: husq-automower.0 (25064) syncConfigAsync, processing state: "mower.stoppedDueRain" with value "false"
    2022-03-29 19:37:43.728 - debug: husq-automower.0 (25064) syncConfigAsync, processing state: "mower.timerAfterRainStartAt" with value "0"
    2022-03-29 19:37:43.728 - debug: husq-automower.0 (25064) syncConfigAsync, processing state: "mower.waitAfterRain" with value ""
    2022-03-29 19:37:43.728 - debug: husq-automower.0 (25064) syncConfigAsync, processing state: "mower.sendMessage" with value ""
    2022-03-29 19:37:43.728 - debug: husq-automower.0 (25064) syncConfigAsync, processing state: "mower.scheduleTime" with value "1"
    2022-03-29 19:37:43.728 - debug: husq-automower.0 (25064) syncConfigAsync, processing state: "mower.http_request_count_day" with value "0"
    2022-03-29 19:37:43.728 - debug: husq-automower.0 (25064) syncConfigAsync, processing state: "mower.http_request_count_day" with value "0", set in mnWebRequestCountDay
    2022-03-29 19:37:43.728 - debug: husq-automower.0 (25064) syncConfigAsync, processing state: "mower.http_request_count_day_success" with value "0"
    2022-03-29 19:37:43.728 - debug: husq-automower.0 (25064) syncConfigAsync, processing state: "mower.http_request_count_day_error" with value "0"
    2022-03-29 19:37:43.729 - debug: husq-automower.0 (25064) syncConfigAsync, processing state: "mower.http_request_count_month" with value "0"
    2022-03-29 19:37:43.729 - debug: husq-automower.0 (25064) syncConfigAsync, processing state: "mower.http_request_count_month_success" with value "0"
    2022-03-29 19:37:43.729 - debug: husq-automower.0 (25064) syncConfigAsync, processing state: "mower.http_request_count_month_error" with value "0"
    2022-03-29 19:37:43.729 - debug: husq-automower.0 (25064) syncConfigAsync, processing state: "mower.statistics.mowingStartTime" with value "0"
    2022-03-29 19:37:43.729 - debug: husq-automower.0 (25064) syncConfigAsync, processing state: "mower.rawSend" with value ""
    2022-03-29 19:37:43.729 - debug: husq-automower.0 (25064) syncConfigAsync, processing state: "mower.rawResponse" with value ""
    2022-03-29 19:37:43.729 - debug: husq-automower.0 (25064) syncConfigAsync, processing state: "mower.rawResponse_geo" with value ""
    2022-03-29 19:37:43.730 - debug: husq-automower.0 (25064) syncConfigAsync, processing state: "mower.rawResponse_mowers" with value ""
    2022-03-29 19:37:43.730 - debug: husq-automower.0 (25064) syncConfigAsync, idnLastStatus: unkonwn, idnNextStartTime: 0, mStartMowingTime: 0, idnStoppedDueRain: false, idnCurrentErrorCode: 0, idnCurrentErrorCodeTS: 0
    2022-03-29 19:37:43.730 - debug: husq-automower.0 (25064) syncConfigAsync, idnCurrentCoveredDistance: 0, idnLastLocationLongitude: 0, idnLastLocationLatitude: 0, idnHomeLocationLongitude: 0, idnHomeLocationLatitude: 0
    2022-03-29 19:37:43.730 - debug: husq-automower.0 (25064) syncConfigAsync, idnBatteryPercent: 0, idnBatteryChargeCycleDaily: 0, idnMowingTime: 0, idnMowingTimeDaily: 0
    2022-03-29 19:37:44.658 - debug: husq-automower.0 (25064) dailyAccumulation started
    2022-03-29 19:37:44.658 - debug: husq-automower.0 (25064) dailyAccumulation, stop status timer
    2022-03-29 19:37:44.658 - debug: husq-automower.0 (25064) dailyAccumulation, add current covered distance to overall distance ...
    2022-03-29 19:37:44.659 - debug: husq-automower.0 (25064) dailyAccumulation, move lastlocations to lastday locations
    2022-03-29 19:37:44.659 - debug: husq-automower.0 (25064) dailyAccumulation, add daily mowing time to overall mowing time ...
    2022-03-29 19:37:44.660 - debug: husq-automower.0 (25064) dailyAccumulation, add daily battery charging cycle to overall charging cycle ...
    2022-03-29 19:37:44.660 - debug: husq-automower.0 (25064) dailyAccumulation, add daily http request counter to month ...
    2022-03-29 19:37:44.661 - debug: husq-automower.0 (25064) createStatusScheduler started
    2022-03-29 19:37:44.661 - debug: husq-automower.0 (25064) createStatusScheduler scheduler created, start every 1 secands
    2022-03-29 19:37:44.662 - debug: husq-automower.0 (25064) createStatusScheduler finished
    2022-03-29 19:37:44.662 - debug: husq-automower.0 (25064) dailyAccumulation finished
    2022-03-29 19:37:44.666 - debug: husq-automower.0 (25064) dailyAccumulation, add current covered distance; bCheck: true; stateCDD.ts: 1648575391687; new Date(00): 1648504800000; stateCDD.val: 0
    2022-03-29 19:37:44.666 - debug: husq-automower.0 (25064) dailyAccumulation, stateRCM.ts: 1648575391687; Date: Tue Mar 29 2022 19:36:31 GMT+0200 (Mitteleuropäische Sommerzeit)
    2022-03-29 19:37:44.666 - debug: husq-automower.0 (25064) dailyAccumulation, nDateMonth: 2; nDateRCM_Month_TS: 2
    2022-03-29 19:37:44.668 - debug: husq-automower.0 (25064) dailyAccumulation, stateRCD.ts: 1648575391687; Date: Tue Mar 29 2022 19:36:31 GMT+0200 (Mitteleuropäische Sommerzeit)
    2022-03-29 19:37:44.668 - debug: husq-automower.0 (25064) dailyAccumulation, nDateMonth: 2; nDateRCD_Month_TS: 2; nDateRCD_Day_TS: 2
    2022-03-29 19:37:45.657 - info: husq-automower.0 (25064) Logged off.
    2022-03-29 19:37:45.682 - info: husq-automower.0 (25064) updateStatus mower object is NULL
    2022-03-29 19:37:46.088 - info: husq-automower.0 (25064) Logged on. Checking for mowers.
    2022-03-29 19:37:46.658 - debug: husq-automower.0 (25064) createSubscriberAsync started
    2022-03-29 19:37:46.658 - debug: husq-automower.0 (25064) checkIfItsRaining started
    2022-03-29 19:37:46.659 - debug: husq-automower.0 (25064) checkIfItsRaining finished
    2022-03-29 19:37:46.659 - info: husq-automower.0 (25064) createSubscriberAsync, idRainSensor; stop due rain not enabled.
    2022-03-29 19:37:46.660 - debug: husq-automower.0 (25064) createSubscriberAsync, scheduler for dailyAccumulation created
    2022-03-29 19:37:46.668 - debug: husq-automower.0 (25064) createSubscriberAsync finished
    2022-03-29 19:37:46.683 - info: husq-automower.0 (25064) updateStatus mower object is NULL
    2022-03-29 19:37:47.683 - info: husq-automower.0 (25064) updateStatus mower object is NULL
    2022-03-29 19:37:48.683 - info: husq-automower.0 (25064) updateStatus mower object is NULL
    2022-03-29 19:37:49.684 - info: husq-automower.0 (25064) updateStatus mower object is NULL
    2022-03-29 19:37:50.685 - info: husq-automower.0 (25064) updateStatus mower object is NULL
    2022-03-29 19:37:51.685 - info: husq-automower.0 (25064) updateStatus mower object is NULL
    2022-03-29 19:37:52.686 - info: husq-automower.0 (25064) updateStatus mower object is NULL
    2022-03-29 19:37:53.685 - info: husq-automower.0 (25064) updateStatus mower object is NULL
    2022-03-29 19:37:54.686 - info: husq-automower.0 (25064) updateStatus mower object is NULL
    2022-03-29 19:37:55.686 - info: husq-automower.0 (25064) updateStatus mower object is NULL
    2022-03-29 19:37:56.687 - info: husq-automower.0 (25064) updateStatus mower object is NULL
    2022-03-29 19:37:57.687 - info: husq-automower.0 (25064) updateStatus mower object is NULL
    2022-03-29 19:37:58.688 - info: husq-automower.0 (25064) updateStatus mower object is NULL
    2022-03-29 19:37:59.688 - info: husq-automower.0 (25064) updateStatus mower object is NULL
    2022-03-29 19:38:00.689 - info: husq-automower.0 (25064) updateStatus mower object is NULL
    2022-03-29 19:38:01.689 - info: husq-automower.0 (25064) updateStatus mower object is NULL
    2022-03-29 19:38:02.689 - info: husq-automower.0 (25064) updateStatus mower object is NULL
    2022-03-29 19:38:03.690 - info: husq-automower.0 (25064) updateStatus mower object is NULL
    2022-03-29 19:38:04.690 - info: husq-automower.0 (25064) updateStatus mower object is NULL
    2022-03-29 19:38:05.690 - info: husq-automower.0 (25064) updateStatus mower object is NULL
    2022-03-29 19:38:06.690 - info: husq-automower.0 (25064) updateStatus mower object is NULL
    2022-03-29 19:38:07.691 - info: husq-automower.0 (25064) updateStatus mower object is NULL
    2022-03-29 19:38:08.692 - info: husq-automower.0 (25064) updateStatus mower object is NULL
    2022-03-29 19:38:09.691 - info: husq-automower.0 (25064) updateStatus mower object is NULL
    2022-03-29 19:38:10.691 - info: husq-automower.0 (25064) updateStatus mower object is NULL
    2022-03-29 19:38:11.691 - info: husq-automower.0 (25064) updateStatus mower object is NULL
    2022-03-29 19:38:12.692 - info: husq-automower.0 (25064) updateStatus mower object is NULL
    2022-03-29 19:38:13.691 - info: husq-automower.0 (25064) updateStatus mower object is NULL
    2022-03-29 19:38:14.691 - info: husq-automower.0 (25064) updateStatus mower object is NULL
    2022-03-29 19:38:15.692 - info: husq-automower.0 (25064) updateStatus mower object is NULL
    2022-03-29 19:38:16.245 - info: host.zerobroker "system.adapter.husq-automower.0" disabled
    2022-03-29 19:38:16.246 - info: host.zerobroker stopInstance system.adapter.husq-automower.0 (force=false, process=true)
    2022-03-29 19:38:16.248 - info: host.zerobroker stopInstance system.adapter.husq-automower.0 send kill signal
    2022-03-29 19:38:16.249 - info: husq-automower.0 (25064) Got terminate signal TERMINATE_YOURSELF
    2022-03-29 19:38:16.250 - info: husq-automower.0 (25064) Logged off.
    2022-03-29 19:38:16.251 - info: husq-automower.0 (25064) cleaned everything up...
    2022-03-29 19:38:16.252 - info: husq-automower.0 (25064) terminating
    2022-03-29 19:38:16.253 - info: husq-automower.0 (25064) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    Woher kommts? Wo muss ich suchen? Was kann ich tun?
    Der Mähroboter lief nach der Aus-Winterung ca. 1 Woche ohne Probleme...
    Schon mal Danke für die Hilfe im Vorraus
    R 1 Antwort Letzte Antwort
    • BoronsbruderB Boronsbruder
      @greyhound
      Hilfe!
      R
      R
      romestylez
      schrieb am zuletzt editiert von romestylez
      #215
      @boronsbruder ich habe das gleiche Problem und es auch bei GitHub gemeldet. Leider scheint @greyhound aber nicht mehr aktiv zu sein hier.
      Ich würde vermuten das Husqvarna etwas an der API geändert hat (Authentifizierung oder URL). Ich habe schon etwas im Sourcecode geschaut und versucht mit Postman die HTTP Requests vom Adapter nachzubauen aber keine Chance bzw. ich hatte auch nicht wirklich Zeit.
      Wir müssen hier also beten das sich jemand hinsetzt und das Ding irgendwie fixxt.
      • R romestylez
        R
        R
        reutli
        #216
        @romestylez Habe greyhound per mail kontaktiert, bisher ohne Antwort. War absehbar, dass die alte API von Husqvarna stirbt... Die neue liefert aber nur deutlich weniger (hatte mal begonnen stümperhaft einen Adapter anzufangen).
        Wenn die alte also nicht nur geändert wurde, sondern tot ist, dass muss ein neuer Adapter her. Schade.
        Vielleicht meldet sich @greyhound aber ja noch...
        iobroker in Debian-VM auf Proxmox Server (Ryzen 7 / 32GB / 1TB NVMe SSD) als Master - mehrere Raspberry Pis (3+4) als Slaves. InfluxDB V2 und Grafana auf LXC.
        *Wer freundlich ist, dem wird freundlich geholfen *
        • R reutli
          R
          R
          romestylez
          #217
          @reutli ich schaue mal ob ich nicht was aus der normalen Husqvarna App etwas sniffen kann was man benutzten könnte.
          Wäre auf jeden Fall schade. Verstehe es auch nicht wieso man eine API hat diese abschaltet und dann eine weniger umfangreiche rausbringt. Aber gut so ist das halt manchmal.
          BoronsbruderB 1 Antwort Letzte Antwort
          • R romestylez
            BoronsbruderB
            BoronsbruderB
            Boronsbruder
            #218
            Was soll eigentlich in der neuen API fehlen?
            Ich finde jetzt nichts, was nicht mindest den Umfang des alten Adapters abdecken könnte. (siehe hier -> Husqvarna Rest Api Doku)
            Man könnte sogar die Einsatzzeiten, Lichter und Mähhöhe verstellen.
            Wenn ich das (mit meinem Laien-Wissen) richtig sehe läuft "nur" die Authentifizierung anders.
            Es werden nun Anfragen, per App-Key limitiert, was heissen würde, dass jeder Adapternutzer einen Account anlegen müsste und einen App-Key holen.
            Oder sehe ich das falsch?
            Im Moment kann leider keinen App-Key beantragen, da anscheinend "Maintenance" ist.
              R
              R
              reutli
              schrieb am zuletzt editiert von reutli
              #219
              @boronsbruder : Da fehlen (zumindest war es letztes Jahr noch so) z.B. Geo-Daten. Ansonsten habe ich auch reingeschaut und war erstaunt, dass es einiges mehr gibt als 2021.
              Edit: Geo-Daten sind jetzt auch da... hab' gelogen 🤥
              Hatte übrigens Kontakt zu @greyhound ... er hat einiges um die Ohren und will sich gegen Ostern um die Thematik kümmern, weil er auch sein mower an den Start bringen will/muss.
              Ich habe meine Adapterversuche seinerzeit eingestellt, genau wegen der Authentifizierungsthematik und möchte mich (ebenfalls als JavaScript-Anfänger) hier nicht auf's Glatteis begeben, zumal es ja bereits diesen Adapter hier gibt.
              Soweit ich weiss hat @greyhound ohnehin schon an der neuen API gearbeitet, so dass es vielleicht Ostern was werden könnte.
              Wenn alle Stricke reissen, hole ich meinen Code nochmals hoch...
              • R reutli
                BoronsbruderB
                BoronsbruderB
                Boronsbruder
                #220
                @reutli Das hört sich ja mal positiv an!
                @greyhound: Ich stehe auf jeden Fall als Tester egal, ob Alpha oder Beta zur Verfügung!
                • A
                  A
                  andrebu
                  #221
                  Ich hoffe auch das sich jemand findet der den Adapter weiter entwickelt oder @greyhound weiter macht. Sitze gerade an einem Blockly damit der Mower die Beregnung steuern kann.
                  Intel NUC
                  Proxmox
                  Raspberry Pi 4
                  Conbee 2 Stick
                  Adapter: deConz Zigbee
                  H 1 Antwort Letzte Antwort
                  • A andrebu
                    H
                    H
                    h4m4
                    schrieb am zuletzt editiert von h4m4
                    #222
                    Hat jemand diese Adapter mal ausprobiert?
                    https://github.com/ice987987/ioBroker.husqvarna-automower
                    R BoronsbruderB M 4 Antworten Letzte Antwort
                    • H h4m4
                      R
                      R
                      reutli
                      #223
                      @h4m4 Nein, aber Code sieht ähnlich dem aus aus, den ich gerade bearbeite 🤠
                      Holt die Daten dann über Web-Socket...das mach ich nicht so. Wenn der funktioniert, stelle ich meine Arbeit ein - warte ohnehin auf @greyhound , der an Ostern die Mower in Betrieb nehmen wollte und sich dann den Adapter anschaut.
                      Ich spiele auch nur rum... 😧
                      • H h4m4
                        BoronsbruderB
                        BoronsbruderB
                        Boronsbruder
                        #224
                        @reutli
                        der Vorteil am Websocket ist, dass man nicht pullen muss, sondern Änderungen gepusht werden und die Aktualisierungen nicht begrenzt sind.
                        Die 10000 APi-Anfragen pro Monat sind dann frei für Kommandos.
                          @reutli
                          R
                          R
                          reutli
                          #225
                          @boronsbruder Wieder was gelernt - danke.
                          Will am WE auch Mäher in Betrieb nehmen (wenn dann die Kabel repariert sind).
                          Dann schaue ich mir den Adapter im Testsystem mal an.
                          • H h4m4
                            M
                            M
                            MatthiasUlrich
                            schrieb am zuletzt editiert von MatthiasUlrich
                            #226
                            @h4m4 Die Verbindung ist bei mir scheinbar da, aber die Objekte werden nicht geladen.
                            Aber laut GitHub wird daran gearbeitet. Ich lass ihn mal laufen, vielleicht passiert ja noch was.
                            • M MatthiasUlrich
                              BoronsbruderB
                              BoronsbruderB
                              Boronsbruder
                              #227
                              @matthiasulrich
                              Was sagt das log?
                              Edit:
                              du hast ja noch den Original...
                              Da wird nix kommen, da die Adresse der Alten-API die Anfrage nach Daten ablehnt...
                                @matthiasulrich
                                Was sagt das log?
                                Edit:
                                M
                                M
                                MatthiasUlrich
                                #228
                                @boronsbruder Ein Issue ist erstellt inkl. log. Ich bin mit ice987 in Kontakt dazu.
                                I BoronsbruderB 2 Antworten Letzte Antwort
                                • M MatthiasUlrich
                                  I
                                  I
                                  intruder7
                                  #229
                                  @matthiasulrich war doof dass du den Issue zu gemacht hast.... hatte noch kommentiert
                                  • I intruder7
                                    M
                                    M
                                    MatthiasUlrich
                                    #230
                                    @intruder7 Ich musste schnell reagieren, da ich versehentlich im Log pers. Daten hatte.
                                    I 1 Antwort Letzte Antwort
                                    • M MatthiasUlrich
                                      I
                                      I
                                      intruder7
                                      #231
                                      @matthiasulrich hatte ich gesehen ;-)
                                      • M MatthiasUlrich
                                        BoronsbruderB
                                        BoronsbruderB
                                        Boronsbruder
                                        #232
                                        @matthiasulrich
                                        Aber die Verbindung zwischen deiner App / Appkey zu den APIs hast du aber schon im Developerportal angelegt?
                                        Hatte ich nämlich bei meinen eigenen Skript-Versuchen auch vergessen...
                                          @matthiasulrich
                                          M
                                          M
                                          MatthiasUlrich
                                          #233
                                          @boronsbruder genau da lag der Fehler. Ich hab dort zwar die Application angelegt aber diese nicht mit der API connected. Danach ging es.
                                          Danke für die Unterstützung und natürlich für die Entwicklung des neuen Adapters.
                                          84.0k
