    1.0k
    @raspiuser bitte als Text in code-tags posten
    RaspiUserR Online
    RaspiUserR Online
    RaspiUser
    #4460
    Sorry ...
    shuttercontrol.0
    	2022-04-13 19:40:00.011	debug	Sun Azimut: 278.8°
    shuttercontrol.0
    	2022-04-13 19:40:00.010	debug	calculate astrodata ...
    shuttercontrol.0
    	2022-04-13 19:39:50.576	debug	outsidetemperature changed: hm-rpc.0.OEQ0672049.4.TEMPERATURE Value: -1.7
    shuttercontrol.0
    	2022-04-13 19:38:26.792	debug	Lightsensor changed: hm-rpc.1.000D58A9A5AE9A.1.AVERAGE_ILLUMINATION Value: 1698
    shuttercontrol.0
    	2022-04-13 19:37:23.085	debug	outsidetemperature changed: hm-rpc.0.OEQ0672049.4.TEMPERATURE Value: -1.3
    shuttercontrol.0
    	2022-04-13 19:36:11.174	debug	Lightsensor changed: hm-rpc.1.000D58A9A5AE9A.1.AVERAGE_ILLUMINATION Value: 1976
    shuttercontrol.0
    	2022-04-13 19:35:00.012	debug	Sun Elevation: 5.2°
    shuttercontrol.0
    	2022-04-13 19:35:00.011	debug	Sun Azimut: 277.9°
    shuttercontrol.0
    	2022-04-13 19:35:00.010	debug	calculate astrodata ...
    shuttercontrol.0
    	2022-04-13 19:34:41.061	debug	outsidetemperature changed: hm-rpc.0.OEQ0672049.4.TEMPERATURE Value: -0.9
    shuttercontrol.0
    	2022-04-13 19:33:41.780	debug	Lightsensor changed: hm-rpc.1.000D58A9A5AE9A.1.AVERAGE_ILLUMINATION Value: 2387
    shuttercontrol.0
    	2022-04-13 19:31:44.583	debug	outsidetemperature changed: hm-rpc.0.OEQ0672049.4.TEMPERATURE Value: -0.4
    shuttercontrol.0
    	2022-04-13 19:30:58.558	debug	Lightsensor changed: hm-rpc.1.000D58A9A5AE9A.1.AVERAGE_ILLUMINATION Value: 2961
    • RaspiUserR RaspiUser
      Sorry ...
      shuttercontrol.0
      shuttercontrol.0
      shuttercontrol.0
      shuttercontrol.0
      shuttercontrol.0
      shuttercontrol.0
      shuttercontrol.0
      shuttercontrol.0
      shuttercontrol.0
      shuttercontrol.0
      shuttercontrol.0
      shuttercontrol.0
      shuttercontrol.0
      HomoranH Offline
      HomoranH Offline
      #4461
      @raspiuser sagte in Test Adapter shuttercontrol v1.4.x:
      Sun Azimut: 278.8°
      Nein. nach deinen Daten erst bei 290°
      245 +/-45 entspricht 200-290°
      RaspiUserR 1 Antwort Letzte Antwort
        Sun Azimut: 278.8°
        RaspiUserR Online
        RaspiUserR Online
        RaspiUser
        #4462
        ... ich hatte das in der Anleitung anders verstanden .... und mit meinen Worten so formuliert:
        "Im Azimutbereich von / bis gilt, dass bei Unterschreiting von Wert 1 UND Wert 2 der Rollo hoch fährt"
        OK, dann verkleinere ich jetzt mal den Azimutbereich ....
        Aber: Was passiert, wenn der Azimutbereich verlassen wird, aber die Werte zu Licht und Temperatur noch nicht unter den Grenzwerten sind?
          HomoranH Offline
          HomoranH Offline
          #4463
          dann muss ich mir das nochmal genau durchlesen.
          ich nutze den Azimut, damit genau dann
          der Rolladen hochfährt, weil die Sonne dann "ums Haus" ist und nicht mehr direkt in die betreffenden Zimmer scheint.
          EDIT:
          Ja, es ist eine UND Verknüpfung.
          Die Sonne muss im Azimut-Bereich sein UND die Temperatur über dem Schwellwert, damit beschattet wird.
          RaspiUserR 2 Antworten Letzte Antwort
            EDIT:
            RaspiUserR Online
            RaspiUserR Online
            RaspiUser
            #4464
            ... beim 2ten Screen ist der Azimut 270° überschritten ... und der ist jetzt auch noch unten.
            Nach deiner Argumentation, die ich prinzipiell teile, müßte der aber oben sein .... komisch.
              EDIT:
              RaspiUserR Online
              RaspiUserR Online
              RaspiUser
              #4465
              @homoran said in Test Adapter shuttercontrol v1.4.x:
              ... dann wäre meine Formulierung richtig und es stimmt tatsächlich irgend etwas nicht, oder ?
                HomoranH Offline
                HomoranH Offline
                #4466
                Nicht unbedingt.
                Morgen kannst du es sehen. Da der Entscheidungspunkt jetzt nicht mehr überschritten wird (sondern bereits ist)
                  Nicht unbedingt.
                  RaspiUserR Online
                  RaspiUserR Online
                  RaspiUser
                  #4467
                  ... schaun*mer mal, soweit Danke.
                    HomoranH Offline
                    HomoranH Offline
                    #4468
                    ich habe nur einen Diff-Sensor und den Azimut.
                    Nicht noch zusätzlich die Helligkeit.
                    Bei mir ist heute der Rollladen mehrfach rauf und runtergefahren, wenn die Sonne im Azimutbereich von Wolken verdeckt wurde und der Hitzesensor die Temperatur unterschritt.
                    Dann führ der Rollladen bei "Hitze" hoch, als die Sonne den Azimutbereich verließ
                    Sieh mal im Datenpunkt Auto State nach, ob der vielleicht auf Manu_mode steht
                      RaspiUserR Online
                      RaspiUserR Online
                      RaspiUser
                      #4469
                      ja, steht auf manu_mode ...
                        HomoranH Offline
                        HomoranH Offline
                        #4470
                        dann tut sich nix :-)
                        beobachte mal, wann der auf manu springt.
                        ggf. musst du für den Rollostatus eine Verzögerung einstellen
                          RaspiUserR Online
                          RaspiUserR Online
                          RaspiUser
                          schrieb am zuletzt editiert von RaspiUser
                          #4471
                          ... während Du geantwortet hast, ist ein Screen auf "up" gegangen, der 2te ist noch "manu".
                          .... muss ich da jetzt immer drauf starren oder steht das im Log !? 😊
                          ... jetzt wirds immer komplizierter ... Wo und wieviel warum ?! 😕
                          EDIT:
                          Habe jetzt manuell hochgefahren, demnächst gehen die Rollos runter ... Morgen gehts weiter.
                            EDIT:
                            HomoranH Offline
                            HomoranH Offline
                            #4472
                            ja 🔭
                            Nur im debug-mode
                            Aber kleiner Hinweis:
                            sieh mal 20-40 Sekunden nach dem runterfahren drauf ;-)
                            ich fang mal hinten an:
                            Womit steuerst (fährst) du deine Rollos?
                            geben diese während der Fahrt eine Leveländerung bekannt?
                            Die erste Änderung wird registriert, kommt eine weitere hinzu gilt das als manuell gesteuert und stellt auf manu_mode um.
                            Bis zum nächsten Morgen passiert dann nichts mehr.
                            Deswegen darf in so einem Fall die Feststellung der Position erst verzögert geprüft werden, wenn der Rollo definitiv an der Endposition ist.
                            Wo?? - DA!!
                              ja 🔭
                              Nur im debug-mode
                              Wo?? - DA!!
                              RaspiUserR Online
                              RaspiUserR Online
                              RaspiUser
                              #4473
                              ... dann stelle ich das mal so ein .... schaden kann es ja eigentlich nicht ... Danke
                              (Der ist schon arg mächtig dieser Adapter .... Puh ... 😕 )
                                ja 🔭
                                Nur im debug-mode
                                Wo?? - DA!!
                                RaspiUserR Online
                                RaspiUserR Online
                                RaspiUser
                                #4474
                                Also ich bin immer noch der Meinung, dass etwas nicht richtig läuft. Die Sonne stand eben noch im gewählen Bereich, Licht und Temperatur waren oberhalb der Grenzwert und trotzdem ging der Screen rauf ... oder habe ich im Log etwas falsch interpretiert ?
                                Aber der Hinweis bzgl. der "Extraeinstellung" war wichtig, die Screens sind zumindest oben ! 😊
                                shuttercontrol.0
                                	2022-04-16 18:45:00.010	debug	Sun Elevation: 14°
                                shuttercontrol.0
                                	2022-04-16 18:45:00.010	debug	Sun Azimut: 269.3°
                                shuttercontrol.0
                                	2022-04-16 18:45:00.009	debug	calculate astrodata ...
                                shuttercontrol.0
                                	2022-04-16 18:44:10.196	debug	outsidetemperature changed: hm-rpc.0.OEQ0672049.4.TEMPERATURE Value: 9.6
                                shuttercontrol.0
                                	2022-04-16 18:44:10.145	debug	Lightsensor changed: hm-rpc.1.000D58A9A5AE9A.1.AVERAGE_ILLUMINATION Value: 43130
                                shuttercontrol.0
                                	2022-04-16 18:42:47.810	debug	Textilscreen Süd.LEVEL Old value = 0. New value = 100. automatic is active
                                shuttercontrol.0
                                	2022-04-16 18:42:47.810	debug	Shutter state changed: Textilscreen Süd.LEVEL old value = 0 new value = 100
                                shuttercontrol.0
                                	2022-04-16 18:42:18.681	debug	Textilscreen Süd.LEVEL Old value = 0. New value = 100. automatic is active
                                shuttercontrol.0
                                	2022-04-16 18:42:18.681	debug	Shutter state changed: Textilscreen Süd.LEVEL old value = 0 new value = 100
                                shuttercontrol.0
                                	2022-04-16 18:42:18.504	debug	Textilscreen Süd.LEVEL Old value = 0. New value = 100. automatic is active
                                shuttercontrol.0
                                	2022-04-16 18:42:18.503	debug	Shutter state changed: Textilscreen Süd.LEVEL old value = 0 new value = 100
                                shuttercontrol.0
                                	2022-04-16 18:41:55.935	debug	outsidetemperature changed: hm-rpc.0.OEQ0672049.4.TEMPERATURE Value: 11.2
                                shuttercontrol.0
                                	2022-04-16 18:41:32.033	debug	Textilscreen West.LEVEL Old value = 0. New value = 100. automatic is active
                                shuttercontrol.0
                                	2022-04-16 18:41:32.032	debug	Shutter state changed: Textilscreen West.LEVEL old value = 0 new value = 100
                                shuttercontrol.0
                                	2022-04-16 18:41:18.520	debug	save current height: 100% from Textilscreen Süd.LEVEL
                                shuttercontrol.0
                                	2022-04-16 18:41:18.520	debug	last automatic Action for Textilscreen Süd.LEVEL: up_Sunprotect_end
                                shuttercontrol.0
                                	2022-04-16 18:41:18.520	debug	Sunprotect for Textilscreen Süd.LEVEL is completed
                                shuttercontrol.0
                                	2022-04-16 18:41:18.482	info	Sunprotect #422 Set ID: Textilscreen Süd.LEVEL value: 100%
                                shuttercontrol.0
                                	2022-04-16 18:41:18.441	debug	Textilscreen Süd.LEVEL level conversion is disabled ...
                                shuttercontrol.0
                                	2022-04-16 18:41:16.439	debug	Lightsensor changed: hm-rpc.1.000D58A9A5AE9A.1.AVERAGE_ILLUMINATION Value: 42640
                                shuttercontrol.0
                                	2022-04-16 18:41:02.218	debug	Textilscreen West.LEVEL Old value = 0. New value = 100. automatic is active
                                shuttercontrol.0
                                	2022-04-16 18:41:02.218	debug	Shutter state changed: Textilscreen West.LEVEL old value = 0 new value = 100
                                shuttercontrol.0
                                	2022-04-16 18:41:02.040	debug	Textilscreen West.LEVEL Old value = 0. New value = 100. automatic is active
                                shuttercontrol.0
                                	2022-04-16 18:41:02.039	debug	Shutter state changed: Textilscreen West.LEVEL old value = 0 new value = 100
                                shuttercontrol.0
                                	2022-04-16 18:40:02.049	debug	save current height: 100% from Textilscreen West.LEVEL
                                shuttercontrol.0
                                	2022-04-16 18:40:02.049	debug	last automatic Action for Textilscreen West.LEVEL: up_Sunprotect_end
                                shuttercontrol.0
                                	2022-04-16 18:40:02.049	debug	Sunprotect for Textilscreen West.LEVEL is completed
                                shuttercontrol.0
                                	2022-04-16 18:40:02.032	info	Sunprotect #422 Set ID: Textilscreen West.LEVEL value: 100%
                                shuttercontrol.0
                                	2022-04-16 18:40:02.030	debug	Textilscreen West.LEVEL level conversion is disabled ...
                                shuttercontrol.0
                                	2022-04-16 18:40:00.011	debug	Sun Elevation: 14.9°
                                shuttercontrol.0
                                	2022-04-16 18:40:00.010	debug	Sun Azimut: 268.4°
                                shuttercontrol.0
                                	2022-04-16 18:40:00.009	debug	calculate astrodata ...
                                shuttercontrol.0
                                	2022-04-16 18:39:27.433	debug	outsidetemperature changed: hm-rpc.0.OEQ0672049.4.TEMPERATURE Value: 13.9
                                shuttercontrol.0
                                	2022-04-16 18:39:10.677	debug	Lightsensor changed: hm-rpc.1.000D58A9A5AE9A.1.AVERAGE_ILLUMINATION Value: 44420
                                shuttercontrol.0
                                	2022-04-16 18:36:50.934	debug	Lightsensor changed: hm-rpc.1.000D58A9A5AE9A.1.AVERAGE_ILLUMINATION Value: 47400
                                shuttercontrol.0
                                	2022-04-16 18:36:44.451	debug	outsidetemperature changed: hm-rpc.0.OEQ0672049.4.TEMPERATURE Value: 14.2
                                shuttercontrol.0
                                  shuttercontrol.0
                                  shuttercontrol.0
                                  shuttercontrol.0
                                  shuttercontrol.0
                                  shuttercontrol.0
                                  shuttercontrol.0
                                  shuttercontrol.0
                                  shuttercontrol.0
                                  shuttercontrol.0
                                  shuttercontrol.0
                                  shuttercontrol.0
                                  shuttercontrol.0
                                  shuttercontrol.0
                                  shuttercontrol.0
                                  shuttercontrol.0
                                  shuttercontrol.0
                                  shuttercontrol.0
                                  shuttercontrol.0
                                  shuttercontrol.0
                                  shuttercontrol.0
                                  shuttercontrol.0
                                  shuttercontrol.0
                                  shuttercontrol.0
                                  shuttercontrol.0
                                  shuttercontrol.0
                                  shuttercontrol.0
                                  shuttercontrol.0
                                  shuttercontrol.0
                                  shuttercontrol.0
                                  shuttercontrol.0
                                  shuttercontrol.0
                                  shuttercontrol.0
                                  shuttercontrol.0
                                  shuttercontrol.0
                                  shuttercontrol.0
                                  shuttercontrol.0
                                  shuttercontrol.0
                                  HomoranH Offline
                                  HomoranH Offline
                                  #4475
                                  Sun Azimut: 269.3°
                                  das dürfte das Ende des Azimutbereiches sein, und damit Ende der Beschattung
                                    Sun Azimut: 269.3°
                                    RaspiUserR Online
                                    RaspiUserR Online
                                    RaspiUser
                                    #4476
                                    ... eigentlich nicht, der obere Wert steht zwischenzeitlich auf 275° ...
                                      HomoranH Offline
                                      HomoranH Offline
                                      #4477
                                      das weiß ich doch nicht :-(
                                      weiß es denn shuttercontrol?
                                      sieh mal in den Datenpunkten nach?
                                      Wann hast du es denn geändert?
                                      EDIT:
                                      Bei dem Azimut ist mir noch was eingefallen
                                      Was hast du denn hier stehen
                                        EDIT:
                                        RaspiUserR Online
                                        RaspiUserR Online
                                        RaspiUser
                                        #4478
                                        ... in der ursprünglichen Frage unter 4446 war er noch bei 290°, jetzt zum probieren bei 275°.
                                        Welchen Datenpunkt meinst Du ? In INFO finde ich den aktuellen Sonnenstand ...
                                        ... da steht bei mir 15 .... das erklärt das hochfahren.
                                        Vielen Dank für diesen Hinweis !!!!!! 👍 👍 😊
                                        Wäre dieser Parameter direkt unter den jeweiligen Rolloeinstellungen zu finden, wäre der Zusammenhang klar gewesen. Ihn unter den übergeordneten Einstellungen zu platzieren ist, meiner Meinung nach, etwas unglücklich.
                                        Ich denke mal, dass mit deinem letzten Hinweis meine Frage beantwortet ist.
                                        Ich ändere meine Werte entsprechend und beobachte ....
                                        EDIT:
                                        Alles funktioniert wie gewünscht, Danke nochmal.
                                          EDIT:
                                          StefanW
                                          schrieb am zuletzt editiert von StefanW
                                          #4479
                                          Hallo Zusammen,
                                          ich nutze Shuttercontrol schon bei meinen Rollläden, da funktioniert es auch super.
                                          Jetzt bin ich dran meine Markise vom Wintergarten einzubinden und habe ein Verständnisfrage.
                                          Ich wollte einfach angefangen und dann weitere Parameter dazu nehmen.
                                          Also erst mal nur Innentemperatur, funktioniert auch wie erwartet.
                                          Jetzt sollte noch der Windalarm dazukommen, bei meinen Einstellungen fährt sie zwar bei Wind aber sie bleibt da stehen auch wenn sich Wind / Temperatur ändert.
                                          Der Datenpunkt gibt True / False je nach Wind zurück (das funktioniert auch),
                                          die 50 habe ich nur eingestellt damit ich sehe ob der Windalarm aktiv war oder die Temperatur.
                                          Ich verstehe jetzt nicht warum die Markise bei 50% bleibt, Temperatur ist drunter und Wind auch.
                                          Eigentlich sollte sie hochfahren, zumindest hätte ich das gerne 🙄
                                          Vielen Dank schon mal falls mir jemand ein Tip hat.
                                          Stefan
