  4. Adapter WM-Bus / Kampstrup Multical 21
153 Beiträge 12 Kommentatoren 38.3k Aufrufe 13 Beobachtet
  • M matze-dev
    @wolfgangfb Hallo Wolfgang, was sagt <journalctl -ar> ? Sind dort Auffälligkeiten zu sehen?
    W
    W
    WolfgangFB
    #111
    @matze-dev
    Hallo Matze, es freut mich sehr, dass Du geantwortet hast. Die Wasseruhr ist mir sehr wichtig.
    Ich sehe in dem Journal aber überhaupt nichts vom wmbusmeter.
    pi@raspberrypi:~ $ journalctl -ar
    -- Journal begins at Fri 2022-01-28 02:30:20 CET, ends at Wed 2022-04-06 19:46:38 CEST. --
    Apr 06 19:46:38 raspberrypi influxd[630]: [httpd] 127.0.0.1 - user_iobroker [06/Apr/2022:19:46:38 +0200] "POST /write?d>
    Apr 06 19:46:35 raspberrypi influxd[630]: [httpd] 127.0.0.1 - user_iobroker [06/Apr/2022:19:46:35 +0200] "POST /write?d>
    Apr 06 19:46:34 raspberrypi influxd[630]: [httpd] 127.0.0.1 - user_iobroker [06/Apr/2022:19:46:34 +0200] "POST /write?d>
    Apr 06 19:46:33 raspberrypi influxd[630]: [httpd] 127.0.0.1 - user_iobroker [06/Apr/2022:19:46:33 +0200] "POST /write?d>
    Apr 06 19:46:32 raspberrypi influxd[630]: [httpd] 127.0.0.1 - user_iobroker [06/Apr/2022:19:46:32 +0200] "POST /write?d>
    Apr 06 19:46:31 raspberrypi influxd[630]: [httpd] 127.0.0.1 - user_iobroker [06/Apr/2022:19:46:31 +0200] "POST /write?d>
    Apr 06 19:46:30 raspberrypi influxd[630]: [httpd] 127.0.0.1 - user_iobroker [06/Apr/2022:19:46:30 +0200] "POST /write?d>
    Apr 06 19:46:28 raspberrypi influxd[630]: [httpd] 127.0.0.1 - user_iobroker [06/Apr/2022:19:46:28 +0200] "POST /write?d>
    Apr 06 19:46:26 raspberrypi influxd[630]: [httpd] 127.0.0.1 - user_iobroker [06/Apr/2022:19:46:26 +0200] "POST /write?d>
    Apr 06 19:46:24 raspberrypi influxd[630]: [httpd] 127.0.0.1 - user_iobroker [06/Apr/2022:19:46:24 +0200] "POST /write?d>
    Apr 06 19:46:22 raspberrypi systemd[1]: Started Session 29 of user pi.
    Apr 06 19:46:22 raspberrypi systemd-logind[537]: New session 29 of user pi.
    Apr 06 19:46:22 raspberrypi sshd[30739]: pam_unix(sshd:session): session opened for user pi(uid=1000) by (uid=0)
    Apr 06 19:46:22 raspberrypi sshd[30739]: Accepted password for pi from 192.168.1.24 port 58669 ssh2
    Apr 06 19:46:22 raspberrypi influxd[630]: [httpd] 127.0.0.1 - user_iobroker [06/Apr/2022:19:46:22 +0200] "POST /write?d>
    Apr 06 19:46:20 raspberrypi influxd[630]: [httpd] 127.0.0.1 - user_iobroker [06/Apr/2022:19:46:20 +0200] "POST /write?d>
    Apr 06 19:46:19 raspberrypi influxd[630]: [httpd] 127.0.0.1 - user_iobroker [06/Apr/2022:19:46:19 +0200] "POST /write?d>
    Apr 06 19:46:15 raspberrypi influxd[630]: [httpd] 127.0.0.1 - user_iobroker [06/Apr/2022:19:46:15 +0200] "POST /write?d>
    Apr 06 19:46:14 raspberrypi influxd[630]: [httpd] 127.0.0.1 - user_iobroker [06/Apr/2022:19:46:14 +0200] "POST /write?d>
    Apr 06 19:46:08 raspberrypi influxd[630]: [httpd] 127.0.0.1 - user_iobroker [06/Apr/2022:19:46:08 +0200] "POST /write?d>
    lines 1-29
    • W WolfgangFB
      @matze-dev
      lines 1-29
      M
      M
      matze-dev
      #112
      @wolfgangfb Hallo Wolfgang, das sind zu wenige Zeilen, einfach mal Leertaste drücken und weiter scrollen, da kommt noch mehr!
      • W
        W
        WolfgangFB
        schrieb am zuletzt editiert von WolfgangFB
        #113
        @matze-dev
        OK, ich habe jetzt nur den relevanten Teil rauskopiert (sonst wird das ja riesengroß)
        Ich schätze mal das die Zeile
        Not a valid device "/dev/ttyUSB0:im871a:c1
        der Knackpunkt ist. Das "C1" habe ich aus der letzten Sicherung der Konfigurationsdatei genommen. Mit T1 kommt es aber zum gleichen Fehler.
        Apr 07 18:02:55 raspberrypi systemd[1]: Failed to start "wmbusmeters service".
        Apr 07 18:02:55 raspberrypi systemd[1]: wmbusmeters.service: Failed with result 'exit-code'.
        Apr 07 18:02:55 raspberrypi systemd[1]: wmbusmeters.service: Start request repeated too quickly.
        Apr 07 18:02:55 raspberrypi systemd[1]: Stopped "wmbusmeters service".
        Apr 07 18:02:55 raspberrypi systemd[1]: wmbusmeters.service: Scheduled restart job, restart counter is at 3.
        Apr 07 18:02:55 raspberrypi systemd[1]: systemd-rfkill.service: Succeeded.
        Apr 07 18:02:55 raspberrypi influxd[595]: ts=2022-04-07T16:02:55.110331Z lvl=info msg="Opened shard" log_id=0_iC4DO0000 service=store trace_id=0_iC4D_W000 op_name=tsdb_open index_version=inmem path=/var/lib/influxdb/data/iobroker/autogen/2 duration=507.572ms
        Apr 07 18:02:55 raspberrypi influxd[595]: ts=2022-04-07T16:02:55.022397Z lvl=info msg="Opened shard" log_id=0_iC4DO0000 service=store trace_id=0_iC4D_W000 op_name=tsdb_open index_version=inmem path=/var/lib/influxdb/data/_internal/monitor/7 duration=469.798ms
        Apr 07 18:02:54 raspberrypi systemd[1]: wmbusmeters.service: Failed with result 'exit-code'.
        Apr 07 18:02:54 raspberrypi wmbusmetersd[715]: Not a valid device "/dev/ttyUSB0:im871a:c1
        Apr 07 18:02:54 raspberrypi systemd[1]: wmbusmeters.service: Main process exited, code=exited, status=1/FAILURE
        Apr 07 18:02:54 raspberrypi wmbusmetersd[715]: No such log level: "normal
        Apr 07 18:02:54 raspberrypi systemd[1]: Started "wmbusmeters service".
        Apr 07 18:02:54 raspberrypi wmbusmetersd[714]: (wmbusmeters) started /run/wmbusmeters/wmbusmeters.pid
        Apr 07 18:02:54 raspberrypi influxd[595]: ts=2022-04-07T16:02:54.790425Z lvl=info msg="Reading file" log_id=0_iC4DO0000 engine=tsm1 service=cacheloader path=/var/lib/influxdb/wal/iobroker/autogen/9/_00007.wal size=9370326
        Apr 07 18:02:54 raspberrypi influxd[595]: ts=2022-04-07T16:02:54.789687Z lvl=info msg="Opened file" log_id=0_iC4DO0000 engine=tsm1 service=filestore path=/var/lib/influxdb/data/iobroker/autogen/9/000000005-000000002.tsm id=0 duration=76.631ms
        Apr 07 18:02:54 raspberrypi influxd[595]: ts=2022-04-07T16:02:54.770085Z lvl=info msg="Reading file" log_id=0_iC4DO0000 engine=tsm1 service=cacheloader path=/var/lib/influxdb/wal/iobroker/autogen/2/_00058.wal size=3423
        Apr 07 18:02:54 raspberrypi influxd[595]: ts=2022-04-07T16:02:54.768337Z lvl=info msg="Opened file" log_id=0_iC4DO0000 engine=tsm1 service=filestore path=/var/lib/influxdb/data/iobroker/autogen/2/000000064-000000002.tsm id=0 duration=51.973ms
        Apr 07 18:02:54 raspberrypi systemd[1]: Starting "wmbusmeters service"...
        Apr 07 18:02:54 raspberrypi systemd[1]: Stopped "wmbusmeters service".
        Apr 07 18:02:54 raspberrypi systemd[1]: wmbusmeters.service: Scheduled restart job, restart counter is at 2.
        Apr 07 18:02:54 raspberrypi influxd[595]: ts=2022-04-07T16:02:54.679796Z lvl=info msg="Opened file" log_id=0_iC4DO0000 engine=tsm1 service=filestore path=/var/lib/influxdb/data/_internal/monitor/7/000000003-000000002.tsm id=0 duration=68.534ms
        Apr 07 18:02:54 raspberrypi influxd[595]: ts=2022-04-07T16:02:54.601933Z lvl=info msg="Opened shard" log_id=0_iC4DO0000 service=store trace_id=0_iC4D_W000 op_name=tsdb_open index_version=inmem path=/var/lib/influxdb/data/_internal/monitor/10 duration=380.589ms
        Apr 07 18:02:54 raspberrypi influxd[595]: ts=2022-04-07T16:02:54.601835Z lvl=info msg="Opened shard" log_id=0_iC4DO0000 service=store trace_id=0_iC4D_W000 op_name=tsdb_open index_version=inmem path=/var/lib/influxdb/data/_internal/monitor/6 duration=379.910ms
        Apr 07 18:02:54 raspberrypi influxd[595]: ts=2022-04-07T16:02:54.552453Z lvl=info msg="Opened shard" log_id=0_iC4DO0000 service=store trace_id=0_iC4D_W000 op_name=tsdb_open index_version=inmem path=/var/lib/influxdb/data/_internal/monitor/4 duration=331.197ms
        Apr 07 18:02:54 raspberrypi influxd[595]: ts=2022-04-07T16:02:54.312764Z lvl=info msg="Opened file" log_id=0_iC4DO0000 engine=tsm1 service=filestore path=/var/lib/influxdb/data/_internal/monitor/10/000000004-000000002.tsm id=0 duration=57.986ms
        Apr 07 18:02:54 raspberrypi influxd[595]: ts=2022-04-07T16:02:54.307802Z lvl=info msg="Opened file" log_id=0_iC4DO0000 engine=tsm1 service=filestore path=/var/lib/influxdb/data/_internal/monitor/6/000000004-000000002.tsm id=0 duration=53.843ms
        Apr 07 18:02:54 raspberrypi influxd[595]: ts=2022-04-07T16:02:54.297802Z lvl=info msg="Opened file" log_id=0_iC4DO0000 engine=tsm1 service=filestore path=/var/lib/influxdb/data/_internal/monitor/4/000000002-000000002.tsm id=0 duration=44.174ms
        Apr 07 18:02:54 raspberrypi influxd[595]: ts=2022-04-07T16:02:54.221814Z lvl=info msg="Opened shard" log_id=0_iC4DO0000 service=store trace_id=0_iC4D_W000 op_name=tsdb_open index_version=inmem path=/var/lib/influxdb/data/_internal/monitor/11 duration=525.544ms
        Apr 07 18:02:54 raspberrypi influxd[595]: ts=2022-04-07T16:02:54.221273Z lvl=info msg="Opened shard" log_id=0_iC4DO0000 service=store trace_id=0_iC4D_W000 op_name=tsdb_open index_version=inmem path=/var/lib/influxdb/data/_internal/monitor/5 duration=524.231ms
        Apr 07 18:02:54 raspberrypi influxd[595]: ts=2022-04-07T16:02:54.221132Z lvl=info msg="Opened shard" log_id=0_iC4DO0000 service=store trace_id=0_iC4D_W000 op_name=tsdb_open index_version=inmem path=/var/lib/influxdb/data/_internal/monitor/8 duration=524.008ms
        Apr 07 18:02:54 raspberrypi influxd[595]: ts=2022-04-07T16:02:54.024886Z lvl=info msg="Reading file" log_id=0_iC4DO0000 engine=tsm1 service=cacheloader path=/var/lib/influxdb/wal/_internal/monitor/12/_00009.wal size=4266060
        Apr 07 18:02:54 raspberrypi influxd[595]: ts=2022-04-07T16:02:54.020344Z lvl=info msg="Opened file" log_id=0_iC4DO0000 engine=tsm1 service=filestore path=/var/lib/influxdb/data/_internal/monitor/5/000000002-000000002.tsm id=0 duration=74.935ms
        Apr 07 18:02:53 raspberrypi influxd[595]: ts=2022-04-07T16:02:53.960818Z lvl=info msg="Opened file" log_id=0_iC4DO0000 engine=tsm1 service=filestore path=/var/lib/influxdb/data/_internal/monitor/8/000000003-000000002.tsm id=0 duration=118.199ms
        Apr 07 18:02:53 raspberrypi influxd[595]: ts=2022-04-07T16:02:53.952673Z lvl=info msg="Opened file" log_id=0_iC4DO0000 engine=tsm1 service=filestore path=/var/lib/influxdb/data/_internal/monitor/12/000000002-000000001.tsm id=1 duration=119.343ms
        Apr 07 18:02:53 raspberrypi influxd[595]: ts=2022-04-07T16:02:53.949263Z lvl=info msg="Opened file" log_id=0_iC4DO0000 engine=tsm1 service=filestore path=/var/lib/influxdb/data/_internal/monitor/11/000000004-000000002.tsm id=0 duration=115.660ms
        Apr 07 18:02:53 raspberrypi influxd[595]: ts=2022-04-07T16:02:53.945197Z lvl=info msg="Opened file" log_id=0_iC4DO0000 engine=tsm1 service=filestore path=/var/lib/influxdb/data/_internal/monitor/12/000000001-000000001.tsm id=0 duration=111.829ms
        Apr 07 18:02:53 raspberrypi vncserver-x11[631]: ConsoleDisplay: Found running X server (pid=654, binary=/usr/lib/xorg/Xorg)
        Apr 07 18:02:53 raspberrypi vncserver-x11[631]: ConsoleDisplay: Cannot find a running X server on vt1
        Apr 07 18:02:53 raspberrypi systemd[1]: wmbusmeters.service: Failed with result 'exit-code'.
        Apr 07 18:02:53 raspberrypi systemd[1]: wmbusmeters.service: Main process exited, code=exited, status=1/FAILURE
        Apr 07 18:02:53 raspberrypi wmbusmetersd[689]: Not a valid device "/dev/ttyUSB0:im871a:c1
        Apr 07 18:02:53 raspberrypi systemd[1]: Started "wmbusmeters service".
        Apr 07 18:02:53 raspberrypi wmbusmetersd[689]: No such log level: "normal
        Apr 07 18:02:53 raspberrypi wmbusmetersd[688]: (wmbusmeters) started /run/wmbusmeters/wmbusmeters.pid
        Apr 07 18:02:53 raspberrypi influxd[595]: ts=2022-04-07T16:02:53.458269Z lvl=info msg="Open store (start)" log_id=0_iC4DO0000 service=store trace_id=0_iC4D_W000 op_name=tsdb_open op_event=start
        Apr 07 18:02:53 raspberrypi influxd[595]: ts=2022-04-07T16:02:53.458216Z lvl=info msg="Compaction settings" log_id=0_iC4DO0000 service=store max_concurrent_compactions=2 throughput_bytes_per_second=50331648 throughput_burst_bytes=50331648
        Apr 07 18:02:53 raspberrypi influxd[595]: ts=2022-04-07T16:02:53.458065Z lvl=info msg="Using data dir" log_id=0_iC4DO0000 service=store path=/var/lib/influxdb/data
        Apr 07 18:02:53 raspberrypi systemd[1]: Starting "wmbusmeters service"...
        Apr 07 18:02:53 raspberrypi systemd[1]: Stopped "wmbusmeters service".
        Apr 07 18:02:53 raspberrypi systemd[1]: wmbusmeters.service: Scheduled restart job, restart counter is at 1.
        Apr 07 18:02:53 raspberrypi influxd[595]: ts=2022-04-07T16:02:53.408254Z lvl=info msg="Go runtime" log_id=0_iC4DO0000 version=go1.15.6 maxprocs=4
        Apr 07 18:02:53 raspberrypi influxd[595]: ts=2022-04-07T16:02:53.408159Z lvl=info msg="InfluxDB starting" log_id=0_iC4DO0000 version=1.6.7~rc0 branch=unknown commit=unknown
        Apr 07 18:02:53 raspberrypi vncserver-x11[631]: ServerManager: Server started
        Apr 07 18:02:53 raspberrypi vncserver-x11[631]: LogDestMem: Finished replaying stored messages
        Apr 07 18:02:53 raspberrypi vncserver-x11[631]: VendorConfig: Error in Certificate "CN=GlobalSign,O=GlobalSign,OU=GlobalSign Root CA - R2": X.509 Error: Certificate expired
        Apr 07 18:02:53 raspberrypi vncserver-x11[631]: LogDestMem: Start replaying stored messages
        Apr 07 18:02:52 raspberrypi kernel: bcmgenet fd580000.ethernet eth0: Link is Down
        Apr 07 18:02:52 raspberrypi kernel: bcmgenet fd580000.ethernet: configuring instance for external RGMII (RX delay)
        Apr 07 18:02:52 raspberrypi dhcpcd[625]: wlan0: waiting for carrier
        Apr 07 18:02:52 raspberrypi dhcpcd[625]: dhcpcd_prestartinterface: wlan0: Operation not possible due to RF-kill
        Apr 07 18:02:52 raspberrypi dhcpcd[625]: eth0: waiting for carrier
        Apr 07 18:02:52 raspberrypi dhcpcd[625]: wlan0: connected to Access Point `'
        Apr 07 18:02:52 raspberrypi dhcpcd-run-hooks[667]: wlan0: starting wpa_supplicant
        Apr 07 18:02:52 raspberrypi udisksd[501]: Acquired the name org.freedesktop.UDisks2 on the system message bus
        Apr 07 18:02:52 raspberrypi systemd[1]: Started Disk Manager.
        Apr 07 18:02:52 raspberrypi systemd[1]: Started Make remote CUPS printers available locally.
        Apr 07 18:02:52 raspberrypi systemd[1]: Started CUPS Scheduler.
        Apr 07 18:02:52 raspberrypi systemd[1]: Reached target Login Prompts.
        Apr 07 18:02:52 raspberrypi systemd[1]: Started Getty on tty1.
        Apr 07 18:02:52 raspberrypi systemd[1]: Started Light Display Manager.
        Apr 07 18:02:52 raspberrypi systemd[1]: Received SIGRTMIN+21 from PID 179 (n/a).
        Apr 07 18:02:52 raspberrypi systemd[1]: Started OpenBSD Secure Shell server.
        Apr 07 18:02:52 raspberrypi sshd[643]: Server listening on :: port 22.
        Apr 07 18:02:52 raspberrypi sshd[643]: Server listening on 0.0.0.0 port 22.
        Apr 07 18:02:52 raspberrypi systemd[1]: Finished Hold until boot process finishes up.
        Apr 07 18:02:52 raspberrypi systemd[1]: Started LSB: Switch to ondemand cpu governor (unless shift key is pressed).
        Apr 07 18:02:52 raspberrypi systemd[1]: wmbusmeters.service: Failed with result 'exit-code'.
        Apr 07 18:02:52 raspberrypi raspi-config[444]: Checking if shift key is held down: No. Switching to ondemand scaling governor.
        Apr 07 18:02:52 raspberrypi systemd[1]: wmbusmeters.service: Main process exited, code=exited, status=1/FAILURE
        Apr 07 18:02:52 raspberrypi systemd[1]: Started "wmbusmeters service".
        Apr 07 18:02:52 raspberrypi wmbusmetersd[649]: Not a valid device "/dev/ttyUSB0:im871a:c1
        Apr 07 18:02:52 raspberrypi wmbusmetersd[649]: No such log level: "normal
        Apr 07 18:02:52 raspberrypi wmbusmetersd[623]: (wmbusmeters) started /run/wmbusmeters/wmbusmeters.pid
        Apr 07 18:02:52 raspberrypi lightdm[617]: Error getting user list from org.freedesktop.Accounts: GDBus.Error:org.freedesktop.DBus.Error.ServiceUnknown: The name org.freedesktop.Accounts was not provided by any .service files
        Apr 07 18:02:52 raspberrypi systemd[1]: Starting Hold until boot process finishes up...
        Apr 07 18:02:52 raspberrypi systemd[1]: Started /etc/rc.local Compatibility.
        Apr 07 18:02:52 raspberrypi systemd[1]: Finished Check for Raspberry Pi EEPROM updates.
        Apr 07 18:02:52 raspberrypi rpi-eeprom-update[453]:     LATEST: 000138a1
        Apr 07 18:02:52 raspberrypi rpi-eeprom-update[453]:    CURRENT: 000138a1
        Apr 07 18:02:52 raspberrypi rpi-eeprom-update[453]:      VL805: up to date
        Apr 07 18:02:52 raspberrypi systemd[1]: Starting /etc/rc.local Compatibility...
        Apr 07 18:02:52 raspberrypi rpi-eeprom-update[453]:   VL805_FW: Dedicated VL805 EEPROM
        Apr 07 18:02:52 raspberrypi rpi-eeprom-update[453]:             Use raspi-config to change the release.
        Apr 07 18:02:52 raspberrypi rpi-eeprom-update[453]:    RELEASE: default (/lib/firmware/raspberrypi/bootloader/default)
        Apr 07 18:02:52 raspberrypi rpi-eeprom-update[453]:     LATEST: Di 25. Jan 14:30:41 UTC 2022 (1643121041)
        Apr 07 18:02:52 raspberrypi systemd[1]: Starting Samba NMB Daemon...
        Apr 07 18:02:52 raspberrypi rpi-eeprom-update[453]:    CURRENT: Do 3. Sep 12:11:43 UTC 2020 (1599135103)
        Apr 07 18:02:52 raspberrypi systemd[1]: Started Grafana instance.
        Apr 07 18:02:52 raspberrypi rpi-eeprom-update[453]: BOOTLOADER: up to date
        Apr 07 18:02:52 raspberrypi systemd[1]: Reached target Network is Online.
        Apr 07 18:02:51 raspberrypi systemd[1]: Started DHCP Client Daemon.
        Apr 07 18:02:51 raspberrypi dhcpcd[604]: forked to background, child pid 625
        Apr 07 18:02:51 raspberrypi kernel: 8021q: 802.1Q VLAN Support v1.8
        Apr 07 18:02:51 raspberrypi systemd[1]: Starting Light Display Manager...
        Apr 07 18:02:51 raspberrypi systemd[1]: Reached target Sound Card.
        Apr 07 18:02:51 raspberrypi systemd[1]: Started Authorization Manager.
        Apr 07 18:02:51 raspberrypi systemd[1]: Finished Permit User Sessions.
        Apr 07 18:02:51 raspberrypi systemd[1]: Finished Save/Restore Sound Card State.
        Apr 07 18:02:51 raspberrypi dhcpcd[604]: dev: loaded udev
        Apr 07 18:02:51 raspberrypi systemd[1]: Starting "wmbusmeters service"...
        Der Stick ist aber da:
        pi@raspberrypi:/opt/iobroker $ ls -l /dev/serial/by-id
        insgesamt 0
        lrwxrwxrwx 1 root root 13  7. Apr 18:31 usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_7aead84aacc9eb118e17914f1d69213e-if00-port0 -> ../../ttyUSB1
        lrwxrwxrwx 1 root root 13  7. Apr 18:31 usb-Silicon_Labs_WiMOD_iM871A-usb_00919907-if00-port0 -> ../../ttyUSB0
        p
        Das ist meine Uhr:
        • W WolfgangFB
          @matze-dev
          insgesamt 0
          p
          Das ist meine Uhr:
          M
          M
          matze-dev
          #114
          @wolfgangfb Hallo Wolfgang, was sagt das Kommando lsusb?
          Bei mir sieht das so aus; ich habe noch die UART-Bridge CP210x am laufen - siehe unten. Ist die bei Dir auch da?
          Scheint in der Tat den Stick nicht korrekt eingebunden zu haben. Einmal ziehen und dann stecken - was macht das dann? Lass auf alle Fälle vorher noch das Kommando laufen: tail -f /var/log/messages
          Was sagt das Kommando dmesg?
          Hier mein USB-Device:
          pi@raspi-mon:~ $ lsusb
          Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
          Bus 001 Device 003: ID 10c4:ea60 Silicon Labs CP210x UART Bridge
          Bus 001 Device 002: ID 2109:3431 VIA Labs, Inc. Hub
          W 1 Antwort Letzte Antwort
          • M matze-dev
            W
            W
            WolfgangFB
            #115
            @matze-dev
            pi@raspberrypi:~ $ lsusb
            Bus 001 Device 004: ID 10c4:ea60 Silicon Labs CP210x UART Bridge
            Apr  9 14:38:19 raspberrypi kernel: [79205.496907] usb 1-1.2: USB disconnect, device number 3
            Apr  9 14:38:19 raspberrypi kernel: [79205.497972] cp210x ttyUSB0: cp210x converter now disconnected from ttyUSB0
            Apr  9 14:38:19 raspberrypi kernel: [79205.498646] cp210x 1-1.2:1.0: device disconnected
            Apr  9 14:38:22 raspberrypi kernel: [79208.352123] usb 1-1.2: new full-speed USB device number 5 using xhci_hcd
            Apr  9 14:38:22 raspberrypi kernel: [79208.489965] usb 1-1.2: New USB device found, idVendor=10c4, idProduct=ea60, bcdDevice= 1.00
            Apr  9 14:38:22 raspberrypi kernel: [79208.489996] usb 1-1.2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
            Apr  9 14:38:22 raspberrypi kernel: [79208.490018] usb 1-1.2: Product: WiMOD iM871A-usb
            Apr  9 14:38:22 raspberrypi kernel: [79208.490036] usb 1-1.2: Manufacturer: Silicon Labs
            Apr  9 14:38:22 raspberrypi kernel: [79208.490054] usb 1-1.2: SerialNumber: 00919907
            Apr  9 14:38:22 raspberrypi kernel: [79208.496479] cp210x 1-1.2:1.0: cp210x converter detected
            Apr  9 14:38:22 raspberrypi kernel: [79208.504516] usb 1-1.2: cp210x converter now attached to ttyUSB0
            Apr  9 14:38:22 raspberrypi mtp-probe: checking bus 1, device 5: "/sys/devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.2"
            Apr  9 14:38:22 raspberrypi mtp-probe: bus: 1, device: 5 was not an MTP device
            [   18.562885] Bluetooth: RFCOMM TTY layer initialized
            [   18.562907] Bluetooth: RFCOMM socket layer initialized
            [   18.562927] Bluetooth: RFCOMM ver 1.11
            [   31.842667] cam-dummy-reg: disabling
            [   87.912851] bcmgenet fd580000.ethernet eth0: Link is Up - 1Gbps/Full - flow control off
            [   87.912896] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
            pi@raspberrypi:~ $
            • M
              M
              matze-dev
              #116
              @wolfgangfb das sieht gut aus, bis auf 2xdie Meldung der UART-Bridge. Meldet er immer noch, dass er den Stick nicht erkennt? Sollte noch ein zweiter Stick stecken, würde ich ihn abziehen und nur mit dem IMST hochfahren.
              • M matze-dev
                W
                W
                WolfgangFB
                #117
                @matze-dev
                Ich habe den Zigbee Stick entfernt und neu gebootet. Ergebnis leider immer noch negativ :-(
                pi@raspberrypi:~ $  systemctl status wmbusmeters
                * wmbusmeters.service - "wmbusmeters service"
                     Loaded: loaded (/lib/systemd/system/wmbusmeters.service; enabled; vendor preset: enabled)
                     Active: failed (Result: protocol) since Mon 2022-04-11 11:06:10 CEST; 1min 30s ago
                       Docs: https://github.com/weetmuts/wmbusmeters
                             man:wmbusmeters(1)
                    Process: 679 ExecStartPre=/bin/mkdir -p /var/log/wmbusmeters/meter_readings (code=exited, status=0/SUCCESS)
                    Process: 680 ExecStartPre=/bin/chown -R wmbusmeters:wmbusmeters /var/log/wmbusmeters (code=exited, status=0/SUCCESS)
                    Process: 681 ExecStartPre=/bin/mkdir -p /run/wmbusmeters (code=exited, status=0/SUCCESS)
                    Process: 682 ExecStartPre=/bin/chown -R wmbusmeters:wmbusmeters /run/wmbusmeters (code=exited, status=0/SUCCESS)
                    Process: 684 ExecStart=/usr/sbin/wmbusmetersd /run/wmbusmeters/wmbusmeters.pid (code=exited, status=0/SUCCESS)
                        CPU: 102ms
                Apr 11 11:06:08 raspberrypi systemd[1]: Failed to start "wmbusmeters service".
                Apr 11 11:06:10 raspberrypi systemd[1]: wmbusmeters.service: Scheduled restart job, restart counter is at 3.
                Apr 11 11:06:10 raspberrypi systemd[1]: Stopped "wmbusmeters service".
                Apr 11 11:06:10 raspberrypi systemd[1]: wmbusmeters.service: Start request repeated too quickly.
                Apr 11 11:06:10 raspberrypi systemd[1]: wmbusmeters.service: Failed with result 'protocol'.
                Apr 11 11:06:10 raspberrypi systemd[1]: Failed to start "wmbusmeters service".
                pi@raspberrypi:~ $ ls -l /dev/serial/by-id
                insgesamt 0
                lrwxrwxrwx 1 root root 13 11. Apr 11:06 usb-Silicon_Labs_WiMOD_iM871A-usb_00919907-if00-port0 -> ../../ttyUSB0
                pi@raspberrypi:~ $
                journalctl -ar > test.txt
                Apr 11 11:06:09 raspberrypi influxd[558]: ts=2022-04-11T09:06:09.658471Z lvl=info msg="Opened shard" log_id=0_myoi7l000 service=store trace_id=0_myoiNl000 op_name=tsdb_open index_version=inmem path=/var/lib/influxdb/data/iobroker/autogen/17 duration=1251.478ms
                Apr 11 11:06:09 raspberrypi influxd[558]: ts=2022-04-11T09:06:09.370313Z lvl=info msg="Opened shard" log_id=0_myoi7l000 service=store trace_id=0_myoiNl000 op_name=tsdb_open index_version=inmem path=/var/lib/influxdb/data/iobroker/autogen/2 duration=829.564ms
                Apr 11 11:06:09 raspberrypi influxd[558]: ts=2022-04-11T09:06:09.297692Z lvl=info msg="Opened shard" log_id=0_myoi7l000 service=store trace_id=0_myoiNl000 op_name=tsdb_open index_version=inmem path=/var/lib/influxdb/data/iobroker/autogen/9 duration=840.539ms
                Apr 11 11:06:09 raspberrypi systemd[1]: systemd-rfkill.service: Succeeded.
                Apr 11 11:06:08 raspberrypi wmbusmetersd[685]: Not a valid device "/dev/ttyUSB0:im871a:t1
                Apr 11 11:06:08 raspberrypi systemd[1]: wmbusmeters.service: Failed with result 'protocol'.
                Apr 11 11:06:08 raspberrypi wmbusmetersd[685]: No such log level: "normal
                Apr 11 11:06:08 raspberrypi systemd[1]: wmbusmeters.service: New main PID 685 does not exist or is a zombie.
                Apr 11 11:06:08 raspberrypi wmbusmetersd[684]: (wmbusmeters) started /run/wmbusmeters/wmbusmeters.pid
                Apr 11 11:06:08 raspberrypi influxd[558]: ts=2022-04-11T09:06:08.733727Z lvl=info msg="Reading file" log_id=0_myoi7l000 engine=tsm1 service=cacheloader path=/var/lib/influxdb/wal/iobroker/autogen/2/_00058.wal size=3423
                Apr 11 11:06:08 raspberrypi influxd[558]: ts=2022-04-11T09:06:08.724693Z lvl=info msg="Opened file" log_id=0_myoi7l000 engine=tsm1 service=filestore path=/var/lib/influxdb/data/iobroker/autogen/2/000000072-000000002.tsm id=0 duration=108.980ms
                Apr 11 11:06:08 raspberrypi systemd[1]: Starting "wmbusmeters service"...
                Apr 11 11:06:08 raspberrypi influxd[558]: ts=2022-04-11T09:06:08.624515Z lvl=info msg="Reading file" log_id=0_myoi7l000 engine=tsm1 service=cacheloader path=/var/lib/influxdb/wal/iobroker/autogen/9/_00020.wal size=7779
                Apr 11 11:06:08 raspberrypi influxd[558]: ts=2022-04-11T09:06:08.623602Z lvl=info msg="Opened file" log_id=0_myoi7l000 engine=tsm1 service=filestore path=/var/lib/influxdb/data/iobroker/autogen/9/000000010-000000002.tsm id=0 duration=67.973ms
                Apr 11 11:06:08 raspberrypi systemd[1]: Stopped "wmbusmeters service".
                Apr 11 11:06:08 raspberrypi systemd[1]: wmbusmeters.service: Scheduled restart job, restart counter is at 2.
                Apr 11 11:06:08 raspberrypi influxd[558]: ts=2022-04-11T09:06:08.607366Z lvl=info msg="Opened file" log_id=0_myoi7l000 engine=tsm1 service=filestore path=/var/lib/influxdb/data/iobroker/autogen/9/000000018-000000002.tsm id=1 duration=51.737ms
                Apr 11 11:06:08 raspberrypi influxd[558]: ts=2022-04-11T09:06:08.539989Z lvl=info msg="Opened shard" log_id=0_myoi7l000 service=store trace_id=0_myoiNl000 op_name=tsdb_open index_version=inmem path=/var/lib/influxdb/data/_internal/monitor/15 duration=466.457ms
                Apr 11 11:06:08 raspberrypi influxd[558]: ts=2022-04-11T09:06:08.537811Z lvl=info msg="Reading file" log_id=0_myoi7l000 engine=tsm1 service=cacheloader path=/var/lib/influxdb/wal/iobroker/autogen/17/_00002.wal size=3776034
                Apr 11 11:06:08 raspberrypi influxd[558]: ts=2022-04-11T09:06:08.537400Z lvl=info msg="Opened file" log_id=0_myoi7l000 engine=tsm1 service=filestore path=/var/lib/influxdb/data/iobroker/autogen/17/000000001-000000001.tsm id=0 duration=48.552ms
                Apr 11 11:06:08 raspberrypi influxd[558]: ts=2022-04-11T09:06:08.457005Z lvl=info msg="Opened shard" log_id=0_myoi7l000 service=store trace_id=0_myoiNl000 op_name=tsdb_open index_version=inmem path=/var/lib/influxdb/data/_internal/monitor/13 duration=383.418ms
                Apr 11 11:06:08 raspberrypi influxd[558]: ts=2022-04-11T09:06:08.406846Z lvl=info msg="Opened shard" log_id=0_myoi7l000 service=store trace_id=0_myoiNl000 op_name=tsdb_open index_version=inmem path=/var/lib/influxdb/data/_internal/monitor/8 duration=381.264ms
                Apr 11 11:06:08 raspberrypi influxd[558]: ts=2022-04-11T09:06:08.225964Z lvl=info msg="Reading file" log_id=0_myoi7l000 engine=tsm1 service=cacheloader path=/var/lib/influxdb/wal/_internal/monitor/16/_00005.wal size=10485929
                Apr 11 11:06:08 raspberrypi influxd[558]: ts=2022-04-11T09:06:08.225570Z lvl=info msg="Opened file" log_id=0_myoi7l000 engine=tsm1 service=filestore path=/var/lib/influxdb/data/_internal/monitor/16/000000001-000000001.tsm id=0 duration=93.320ms
                Apr 11 11:06:08 raspberrypi influxd[558]: ts=2022-04-11T09:06:08.223643Z lvl=info msg="Opened file" log_id=0_myoi7l000 engine=tsm1 service=filestore path=/var/lib/influxdb/data/_internal/monitor/15/000000004-000000002.tsm id=0 duration=94.742ms
                Apr 11 11:06:08 raspberrypi influxd[558]: ts=2022-04-11T09:06:08.203369Z lvl=info msg="Opened file" log_id=0_myoi7l000 engine=tsm1 service=filestore path=/var/lib/influxdb/data/_internal/monitor/13/000000005-000000002.tsm id=0 duration=84.057ms
                Apr 11 11:06:08 raspberrypi influxd[558]: ts=2022-04-11T09:06:08.132601Z lvl=info msg="Opened file" log_id=0_myoi7l000 engine=tsm1 service=filestore path=/var/lib/influxdb/data/_internal/monitor/8/000000003-000000002.tsm id=0 duration=60.324ms
                Apr 11 11:06:08 raspberrypi influxd[558]: ts=2022-04-11T09:06:08.073507Z lvl=info msg="Opened shard" log_id=0_myoi7l000 service=store trace_id=0_myoiNl000 op_name=tsdb_open index_version=inmem path=/var/lib/influxdb/data/_internal/monitor/14 duration=537.661ms
                Apr 11 11:06:08 raspberrypi influxd[558]: ts=2022-04-11T09:06:08.073504Z lvl=info msg="Opened shard" log_id=0_myoi7l000 service=store trace_id=0_myoiNl000 op_name=tsdb_open index_version=inmem path=/var/lib/influxdb/data/_internal/monitor/11 duration=538.137ms
                Apr 11 11:06:08 raspberrypi influxd[558]: ts=2022-04-11T09:06:08.073426Z lvl=info msg="Opened shard" log_id=0_myoi7l000 service=store trace_id=0_myoiNl000 op_name=tsdb_open index_version=inmem path=/var/lib/influxdb/data/_internal/monitor/12 duration=537.637ms
                Apr 11 11:06:08 raspberrypi influxd[558]: ts=2022-04-11T09:06:08.025434Z lvl=info msg="Opened shard" log_id=0_myoi7l000 service=store trace_id=0_myoiNl000 op_name=tsdb_open index_version=inmem path=/var/lib/influxdb/data/_internal/monitor/10 duration=490.196ms
                Apr 11 11:06:07 raspberrypi influxd[558]: ts=2022-04-11T09:06:07.803976Z lvl=info msg="Opened file" log_id=0_myoi7l000 engine=tsm1 service=filestore path=/var/lib/influxdb/data/_internal/monitor/11/000000004-000000002.tsm id=0 duration=135.351ms
                Apr 11 11:06:07 raspberrypi influxd[558]: ts=2022-04-11T09:06:07.779437Z lvl=info msg="Opened file" log_id=0_myoi7l000 engine=tsm1 service=filestore path=/var/lib/influxdb/data/_internal/monitor/12/000000004-000000002.tsm id=0 duration=111.405ms
                Apr 11 11:06:07 raspberrypi influxd[558]: ts=2022-04-11T09:06:07.768733Z lvl=info msg="Opened file" log_id=0_myoi7l000 engine=tsm1 service=filestore path=/var/lib/influxdb/data/_internal/monitor/10/000000004-000000002.tsm id=0 duration=84.845ms
                Apr 11 11:06:07 raspberrypi influxd[558]: ts=2022-04-11T09:06:07.765225Z lvl=info msg="Opened file" log_id=0_myoi7l000 engine=tsm1 service=filestore path=/var/lib/influxdb/data/_internal/monitor/14/000000004-000000002.tsm id=0 duration=97.434ms
                Apr 11 11:06:07 raspberrypi systemd[1]: wmbusmeters.service: Failed with result 'exit-code'.
                Apr 11 11:06:07 raspberrypi systemd[1]: wmbusmeters.service: Main process exited, code=exited, status=1/FAILURE
                Apr 11 11:06:07 raspberrypi systemd[1]: Started "wmbusmeters service".
                Apr 11 11:06:07 raspberrypi wmbusmetersd[672]: Not a valid device "/dev/ttyUSB0:im871a:t1
                Apr 11 11:06:07 raspberrypi wmbusmetersd[672]: No such log level: "normal
                Apr 11 11:06:07 raspberrypi wmbusmetersd[671]: (wmbusmeters) started /run/wmbusmeters/wmbusmeters.pid
                Apr 11 11:06:07 raspberrypi vncserver-x11[594]: ConsoleDisplay: Found running X server (pid=623, binary=/usr/lib/xorg/Xorg)
                Apr 11 11:06:07 raspberrypi vncserver-x11[594]: ConsoleDisplay: Cannot find a running X server on vt1
                Apr 11 11:06:07 raspberrypi systemd[1]: Starting "wmbusmeters service"...
                Apr 11 11:06:07 raspberrypi systemd[1]: Stopped "wmbusmeters service".
                Apr 11 11:06:07 raspberrypi systemd[1]: wmbusmeters.service: Scheduled restart job, restart counter is at 1.
                Apr 11 11:06:07 raspberrypi influxd[558]: ts=2022-04-11T09:06:07.327749Z lvl=info msg="Open store (start)" log_id=0_myoi7l000 service=store trace_id=0_myoiNl000 op_name=tsdb_open op_event=start
                Apr 11 11:06:07 raspberrypi influxd[558]: ts=2022-04-11T09:06:07.327711Z lvl=info msg="Compaction settings" log_id=0_myoi7l000 service=store max_concurrent_compactions=2 throughput_bytes_per_second=50331648 throughput_burst_bytes=50331648
                Apr 11 11:06:07 raspberrypi influxd[558]: ts=2022-04-11T09:06:07.327575Z lvl=info msg="Using data dir" log_id=0_myoi7l000 service=store path=/var/lib/influxdb/data
                Apr 11 11:06:07 raspberrypi influxd[558]: ts=2022-04-11T09:06:07.264013Z lvl=info msg="Go runtime" log_id=0_myoi7l000 version=go1.15.6 maxprocs=4
                Apr 11 11:06:07 raspberrypi influxd[558]: ts=2022-04-11T09:06:07.263961Z lvl=info msg="InfluxDB starting" log_id=0_myoi7l000 version=1.6.7~rc0 branch=unknown commit=unknown
                Apr 11 11:06:07 raspberrypi vncserver-x11[594]: ServerManager: Server started
                Apr 11 11:06:07 raspberrypi vncserver-x11[594]: LogDestMem: Finished replaying stored messages
                Apr 11 11:06:07 raspberrypi vncserver-x11[594]: VendorConfig: Error in Certificate "CN=GlobalSign,O=GlobalSign,OU=GlobalSign Root CA - R2": X.509 Error: Certificate expired
                Apr 11 11:06:07 raspberrypi vncserver-x11[594]: LogDestMem: Start replaying stored messages
                Apr 11 11:06:06 raspberrypi systemd[1]: Finished Check for Raspberry Pi EEPROM updates.
                Apr 11 11:06:06 raspberrypi rpi-eeprom-update[465]:     LATEST: 000138a1
                Apr 11 11:06:06 raspberrypi rpi-eeprom-update[465]:    CURRENT: 000138a1
                Apr 11 11:06:06 raspberrypi rpi-eeprom-update[465]:      VL805: up to date
                Apr 11 11:06:06 raspberrypi rpi-eeprom-update[465]:   VL805_FW: Dedicated VL805 EEPROM
                Apr 11 11:06:06 raspberrypi rpi-eeprom-update[465]:             Use raspi-config to change the release.
                Apr 11 11:06:06 raspberrypi rpi-eeprom-update[465]:    RELEASE: default (/lib/firmware/raspberrypi/bootloader/default)
                Apr 11 11:06:06 raspberrypi rpi-eeprom-update[465]:     LATEST: Di 25. Jan 14:30:41 UTC 2022 (1643121041)
                Apr 11 11:06:06 raspberrypi rpi-eeprom-update[465]:    CURRENT: Do 3. Sep 12:11:43 UTC 2020 (1599135103)
                Apr 11 11:06:06 raspberrypi rpi-eeprom-update[465]: BOOTLOADER: up to date
                Apr 11 11:06:06 raspberrypi kernel: bcmgenet fd580000.ethernet eth0: Link is Down
                Apr 11 11:06:06 raspberrypi kernel: bcmgenet fd580000.ethernet: configuring instance for external RGMII (RX delay)
                Apr 11 11:06:06 raspberrypi dhcpcd[586]: wlan0: waiting for carrier
                Apr 11 11:06:06 raspberrypi dhcpcd[586]: dhcpcd_prestartinterface: wlan0: Operation not possible due to RF-kill
                Apr 11 11:06:06 raspberrypi dhcpcd[586]: eth0: waiting for carrier
                Apr 11 11:06:06 raspberrypi systemd[1]: Started Make remote CUPS printers available locally.
                Apr 11 11:06:06 raspberrypi systemd[1]: Started CUPS Scheduler.
                Apr 11 11:06:06 raspberrypi udisksd[490]: Acquired the name org.freedesktop.UDisks2 on the system message bus
                Apr 11 11:06:06 raspberrypi dhcpcd[586]: wlan0: connected to Access Point `'
                Apr 11 11:06:06 raspberrypi systemd[1]: Started Disk Manager.
                Apr 11 11:06:06 raspberrypi systemd[1]: Failed to start "wmbusmeters service".
                Apr 11 11:06:06 raspberrypi systemd[1]: wmbusmeters.service: Failed with result 'protocol'.
                Apr 11 11:06:06 raspberrypi systemd[1]: wmbusmeters.service: New main PID 625 does not exist or is a zombie.
                Apr 11 11:06:06 raspberrypi wmbusmetersd[625]: Not a valid device "/dev/ttyUSB0:im871a:t1
                Apr 11 11:06:06 raspberrypi wmbusmetersd[625]: No such log level: "normal
                Apr 11 11:06:06 raspberrypi systemd[1]: Started LSB: Switch to ondemand cpu governor (unless shift key is pressed).
                Apr 11 11:06:06 raspberrypi raspi-config[437]: Checking if shift key is held down: No. Switching to ondemand scaling governor.
                Apr 11 11:06:06 raspberrypi wmbusmetersd[600]: (wmbusmeters) started /run/wmbusmeters/wmbusmeters.pid
                • W WolfgangFB
                  @matze-dev
                               man:wmbusmeters(1)
                          CPU: 102ms
                  insgesamt 0
                  pi@raspberrypi:~ $
                  M
                  M
                  matze-dev
                  #118
                  @wolfgangfb paste mal Deine wmbusmeters.conf
                  cat /etc/wmbusmeters.conf
                  • M matze-dev
                    W
                    W
                    WolfgangFB
                    #119
                    @matze-dev
                    pi@raspberrypi:/opt/iobroker $ cat /etc/wmbusmeters.conf
                    loglevel=normal
                    device=/dev/ttyUSB0:im871a:c1
                    # But do not probe this serial tty.
                    donotprobe=/dev/ttyACM2
                    logtelegrams=true
                    format=json
                    meterfiles=/var/log/wmbusmeters/meter_readings
                    meterfilesaction=overwrite
                    meterfilesnaming=name
                    meterfilestimestamp=day
                    logfile=/var/log/wmbusmeters/wmbusmeters.log
                    shell=/usr/local/bin/mosquitto_pub -h localhost -t wmbusmeters/$METER_ID -m "$METER_JSON"
                    alarmshell=/usr/local/bin/mosquitto_pub -h localhost -t wmbusmeters_alarm -m "$ALARM_TYPE $ALARM_MESSAGE"
                    alarmtimeout=1h
                    alarmexpectedactivity=mon-sun(00-23)
                    ignoreduplicates=true
                    • SBorgS
                      SBorgS
                      SBorg
                      #120
                      Ich habe zwar (noch) keinen und lese nur mit, aber mich macht
                      @wolfgangfb sagte in Adapter WM-Bus / Kampstrup Multical 21:
                      stutzig. Ist so gar nicht "Linux like". Du warst nicht mal (zB. unter Windows) in der conf und hast darin editiert (oder ist was beim C&P schief gelaufen?) ?
                      LG SBorg ( SBorg auf GitHub)
                      • SBorgS SBorg
                        W
                        W
                        WolfgangFB
                        #121
                        @sborg
                        Hi
                        Das hat mich auch stutzig gemacht (fehlendes Hochkomma am End der Fehlermeldung). Aber durch Deinen Beitrag habe ich mal weiter experimentiert. Also Datei nochmal von Hand eingegeben, mit absichtlich falschen Einträgen um zu sehen, ob die Datei überhaupt gelesen wird. Tatsächlich scheint da etwas schief gegangen zu sein. Ich habe alle Zeilenenden von Hand gelöscht und neu eingegeben und neu erzeugt und habe jetzt scheinbar tatsächlich den service am laufen.
                        Aber die "MyTapWater" macht Probleme. Die habe ich auch von Hand und per Copy&Paste und 100 mal eingegeben. Es kommt immer die Meldung:
                             Active: active (running) since Tue 2022-04-12 12:54:56 CEST; 1min 44s ago
                                     man:wmbusmeters(1)
                            Process: 575 ExecStartPre=/bin/mkdir -p /var/log/wmbusmeters/meter_readings (code=exited, status=0/SUCCESS)
                            Process: 594 ExecStartPre=/bin/chown -R wmbusmeters:wmbusmeters /var/log/wmbusmeters (code=exited, status=0/SUCCESS)
                            Process: 597 ExecStartPre=/bin/mkdir -p /run/wmbusmeters (code=exited, status=0/SUCCESS)
                            Process: 602 ExecStartPre=/bin/chown -R wmbusmeters:wmbusmeters /run/wmbusmeters (code=exited, status=0/SUCCESS)
                            Process: 609 ExecStart=/usr/sbin/wmbusmetersd /run/wmbusmeters/wmbusmeters.pid (code=exited, status=0/SUCCESS)
                           Main PID: 617 (wmbusmetersd)
                              Tasks: 3 (limit: 4915)
                                CPU: 298ms
                             CGroup: /system.slice/wmbusmeters.service
                                     `-617 /usr/sbin/wmbusmetersd /run/wmbusmeters/wmbusmeters.pid
                        Apr 12 12:54:55 raspberrypi systemd[1]: Starting "wmbusmeters service"...
                        Apr 12 12:54:56 raspberrypi wmbusmetersd[609]: (wmbusmeters) started /run/wmbusmeters/wmbusmeters.pid
                        Apr 12 12:54:56 raspberrypi systemd[1]: Started "wmbusmeters service".
                        Apr 12 12:54:56 raspberrypi wmbusmetersd[617]: Not a valid meter id nor a valid meter match expression ""
                        Apr 12 12:54:56 raspberrypi polkitd[606]: started daemon version 0.105 using authority implementation `local' version `0.105'
                        pi@raspberrypi:/opt/iobroker $ cat /etc/wmbusmeters.d/MyTapWater
                        name=MyTapWater
                        #type=multical21
                        id=57813696
                        key=E4E7EAF6FD17EAFB9587BC2996783C63
                        Die ID und der Key stimmen, da bin ich mir sicher. Im Journal fehlen bei den Fehlermeldungen auch wieder die Hochkommas am Ende. Aber ich habe das definitiv
                        SBorgS M 2 Antworten Letzte Antwort
                        • W WolfgangFB
                          @sborg
                          Hi
                                       man:wmbusmeters(1)
                                  CPU: 298ms
                          name=MyTapWater
                          #type=multical21
                          id=57813696
                          SBorgS
                          SBorgS
                          SBorg
                          #122
                          @wolfgangfb Na, geht ja voran :)
                          Ist der Key Original? Dann ersetze lieber mal bisserl was mit X ;)
                          Ich weiß nicht ob da eine Kommentarzeile erlaubt ist, aber nimm die Zeile #3 mal raus...
                          #type=multical21
                          • W WolfgangFB
                            @sborg
                            Hi
                                         man:wmbusmeters(1)
                                    CPU: 298ms
                            name=MyTapWater
                            #type=multical21
                            id=57813696
                            M
                            M
                            matze-dev
                            schrieb am zuletzt editiert von matze-dev
                            #123
                            @wolfgangfb Hallo,
                            ich würde auch SBorg zustimmen - die Fehlermeldung mit den Anführungszeichen ist ungewöhnlich, das Loglevel habe ich auf Debug gesetzt - sieht man mehr.
                            loglevel=debug
                            Gemaess Doku sollte das so aussehen (habe hier auch am Schluss eine Leerzeile) https://github.com/weetmuts/wmbusmeters
                            loglevel=normal
                            # Search for a wmbus device and set it to c1.
                            device=auto:c1
                            logtelegrams=false
                            format=json
                            shell=/usr/bin/mosquitto_pub -h localhost -t wmbusmeters/$METER_ID -m "$METER_JSON"
                            alarmshell=/usr/bin/mosquitto_pub -h localhost -t wmbusmeters_alarm -m "$ALARM_TYPE $ALARM_MESSAGE"
                            alarmtimeout=1h
                            Die MyTapWater sieht so aus - keine Kommentarzeile und eine letzte Leerzeile. Viel Glück
                            name=MyTapWater
                            type=multical21
                            id=XXXXXX
                            key=XXXXXXXXXXXXXXXXXXXXXXXXXXX
                            • SBorgS SBorg
                              #type=multical21
                              W
                              W
                              WolfgangFB
                              #124
                              @sborg sagte in Adapter WM-Bus / Kampstrup Multical 21:
                              Beim Key einer Wasseruhr habe ich keine Bedenken, dass da jemand etwas böses mit anfangen kann (zumal man die Uhr ja nur lesen und nicht schreiben kann). Du darfst Dich gerne mit dem Laptop vor meine Wohnung stellen und dich daran ergötzen, wie hoch mein Wasserverbrauch ist :-)
                              • M matze-dev
                                @wolfgangfb Hallo,
                                loglevel=debug
                                loglevel=normal
                                device=auto:c1
                                logtelegrams=false
                                format=json
                                alarmtimeout=1h
                                name=MyTapWater
                                type=multical21
                                id=XXXXXX
                                W
                                W
                                WolfgangFB
                                #125
                                @matze-dev
                                Die einzigen Änderungen die ich noch gesehen habe waren in MyTapWater die Kommentarzeile und in /etc/wmbusmeters.conf die Zeile "device=auto:c1" gegenüber "device=/dev/ttyUSB0:im871a:c1".
                                Nachdem ich das geändert habe konnte ich zu meine Freude sehen, dass die Uhr jetzt erkannt wird und auch die richtigen Werte liefert.
                                Neugierig woran es jetzt gelegen gelegen hat habe ich die Änderungen wieder rückgängig gemacht und erstaunlicherweise geht die Uhr immer noch. Einerseits bin ich froh, dass die Uhr wieder geht, andererseits bin ich nicht so glücklich darüber, dass ich keine Ahnung habe, woran es gelegen hat (irgendwann ist bestimmt wieder eine Neuinstallation notwendig).
                                Trotzdem vielen Dank an Matze und SBorg.
                                • W WolfgangFB
                                  @matze-dev
                                  SBorgS
                                  SBorgS
                                  SBorg
                                  #126
                                  @wolfgangfb Hauptsache geht :)
                                  ...und ich habe gestern endlich einen lieferbaren IM871a zum vernünftigen Preis gefunden. Also gleich bei meinem Versorger den AES-Key angefragt. Ok, Ostern... bis ich jetzt (hoffentlich überhaupt) den Key bekomme, ist bestimmt der Stick wieder ausverkauft :(
                                  • SBorgS SBorg
                                    W
                                    W
                                    WolfgangFB
                                    #127
                                    Ich bin kein große Freund von "neuaufsetzen" oder "hauptsache geht" denn es gibt bestimmt ein nächstes mal und ich wüsste gerne, auf was ich achten muss.
                                    Wo hast Du den Stick jetzt her? Ich finde es übrigens erstaunlich, wie weit der Stick von der Wasseruhr entfernt sein kann um sie trotzdem zuverlässig auszulesen. Mein Sonoff Zigbee 3 Stick kommt jedenfalls nicht so weit.
                                    SBorgS W 2 Antworten Letzte Antwort
                                    • W WolfgangFB
                                      SBorgS
                                      SBorgS
                                      SBorg
                                      #128
                                      Bin ich bei dir, nur wenn du es jetzt nicht mehr "einfach kaputt" kriegst, kannst du auch die gewonnene Zeit ggf. später bei einer Neuinstallation reinvestieren (sollte aber nicht nötig werden wenn du die beiden Dateien sicherst).
                                      bzgl. Stick: kann ich gerne kundtun, allerdings
                                      • bin ich da auch derzeit etwas egoistisch. Erstmal warten ob ich meinen Key bekomme, dann ordern... (sonst sind ev. wieder alle weg ;) )
                                      • ist der Preis nicht so ganz ausschlaggebend bei mir, sondern die Lieferfähigkeit, wobei ich natürlich bei einem Preis < 30,- € auch nicht unbedingt zu tiefst traurig bin.
                                      • muss ich erst testen ob es damit wirklich geht. Dann habe nur ich die Knete versemmelt.
                                      • W WolfgangFB
                                        W
                                        W
                                        WolfgangFB
                                        #129
                                        @wolfgangfb
                                        Es gibt noch ein Problem: Der Stick wird nur erkannt bzw. ausgelesen, wenn kein anderer Stick im Raspi steckt. Wenn ich den Sonoff Zigbee 3 Stick zusätzlich beim Booten im Raspi habe geht das ganze nicht:
                                             Active: active (running) since Sun 2022-04-17 17:57:50 CEST; 2h 34min ago
                                                     man:wmbusmeters(1)
                                            Process: 640 ExecStartPre=/bin/mkdir -p /var/log/wmbusmeters/meter_readings (code=exited, status=0/SUCCESS)
                                            Process: 652 ExecStartPre=/bin/chown -R wmbusmeters:wmbusmeters /var/log/wmbusmeters (code=exited, status=0/SUCCESS)
                                            Process: 656 ExecStartPre=/bin/mkdir -p /run/wmbusmeters (code=exited, status=0/SUCCESS)
                                            Process: 657 ExecStartPre=/bin/chown -R wmbusmeters:wmbusmeters /run/wmbusmeters (code=exited, status=0/SUCCESS)
                                            Process: 662 ExecStart=/usr/sbin/wmbusmetersd /run/wmbusmeters/wmbusmeters.pid (code=exited, status=0/SUCCESS)
                                           Main PID: 668 (wmbusmetersd)
                                                CPU: 5.278s
                                                     `-668 /usr/sbin/wmbusmetersd /run/wmbusmeters/wmbusmeters.pid
                                        Apr 17 17:57:50 raspberrypi wmbusmetersd[668]: (config) "alarmtimeout" "1h"
                                        Apr 17 17:57:50 raspberrypi wmbusmetersd[668]: (config) "alarmexpectedactivity" "mon-sun(00-23)"
                                        Apr 17 17:57:50 raspberrypi wmbusmetersd[668]: (config) "ignoreduplicates" "true"
                                        Apr 17 17:57:50 raspberrypi wmbusmetersd[668]: (config) "" ""
                                        Apr 17 17:57:50 raspberrypi systemd[1]: Started "wmbusmeters service".
                                        Apr 17 17:57:50 raspberrypi wmbusmetersd[668]: (config) loading meter file /etc/wmbusmeters.d/MyTapWater
                                        Apr 17 17:57:50 raspberrypi wmbusmetersd[668]: (config) name=MyTapWater
                                        Apr 17 17:57:50 raspberrypi wmbusmetersd[668]: (config) id=57813696
                                        Apr 17 17:57:50 raspberrypi wmbusmetersd[668]: (config) key=<notprinted>
                                        Apr 17 17:57:50 raspberrypi wmbusmetersd[668]: (wmbusmeters) using log file /var/log/wmbusmeters/wmbusmeters.log
                                        pi@raspberrypi:~ $ tail -f /var/log/wmbusmeters/wmbusmeters.log
                                        (shell) output: >>><<<
                                        (shell) return code 1
                                        (shell) 680 exited
                                        (serial) registered regular callback HOT_PLUG_DETECTOR(0) every 2 seconds
                                        (wmbusmeters) waiting for telegrams
                                        (serial) EVENT thread interrupted
                                        (serial) waiting for stop
                                        (serial) TIMER thread interrupted
                                        [2022-04-17_17:57:52] (memory) rss 3182592 peak 3.03 MiB
                                        Ziehe ich den Zigbee und den IM871a raus und stecke den IM871a wieder rein, dann läuft wieder alles.
                                        Wie bekomme ich beide Sticks sauber konfiguriert?
                                        • W WolfgangFB
                                          @wolfgangfb
                                                       man:wmbusmeters(1)
                                                  CPU: 5.278s
                                          (shell) 680 exited
                                          SBorgS
                                          SBorgS
                                          SBorg
                                          #130
                                          @wolfgangfb Das hängt damit zusammen in welcher Reihenfolge Linux die Geräte an den USB-Ports findet.
                                          Wenn du bspw. device=/dev/ttyUSB0:im871a:c1 nutzt, muss auch am "ttyUSB0" der IM-Stick erkannt worden sein. hat er da den ZigBee erkannt...
                                          Bei device=auto:c1 scannt er alle USB-Ports durch bis er den IM-Stick findet und nutzt dann auch den korrekten Eintrag.
                                          Oder man nutzt den Unique-Namen, der ist immer gleich egal an welchem USB-Port was steckt/erkannt wurde:
                                          ls -al /dev/serial/by-id/
                                          Hier mal ein Beispiel (ist allerdings ein ZigBee-Stick ;) ) :
                                          device=/dev/serial/by-id/usb-Texas_Instruments_XDS110__03.00.00.15__Embed_with_CMSIS-DAP_L1100G3W-if00:im871a:c1
                                          33.2k
                                          84.3k
