Test Adapter hekr wisen elro App v0.0.x
Ich hab seit neuestem folgende Debugmeldungen vom Adapter.
2022-03-17 00:00:53.070 - debug: hekr.0 (24693) WS received:{"msgId":206152,"action":"devSend","params":{"devTid":"ESP_2M_8CCE4ED63F3B","appTid":[],"subDevTid":null,"ctrlKey":"3deccd8e236d40d6a8eab99174aa7084","data":{"cleaning":0,"B":0,"RGB_Sw":0,"sw":0,"G":0,"raw":"481101E701000000000000000000000042","light_Sw":0,"speed":0,"tm_Minutes":0,"R":0,"cmdId":1,"Statue":0,"fitter":0}}} 2022-03-17 00:00:53.071 - error: hekr.0 (24693) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). 2022-03-17 00:00:53.071 - error: hekr.0 (24693) unhandled promise rejection: Bad number 2022-03-17 00:00:53.071 - error: hekr.0 (24693) Bad number 2022-03-17 00:00:53.122 - info: hekr.0 (24693) terminating 2022-03-17 00:00:53.122 - debug: hekr.0 (24693) Plugin sentry destroyed 2022-03-17 00:00:53.123 - warn: hekr.0 (24693) Terminated (UNCAUGHT_EXCEPTION): Without reason 2022-03-17 00:00:53.645 - error: host.ioBroker Caught by controller[0]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason: 2022-03-17 00:00:53.647 - error: host.ioBroker Caught by controller[1]: { 2022-03-17 00:00:53.647 - error: host.ioBroker Caught by controller[1]: name: 'SyntaxError', 2022-03-17 00:00:53.648 - error: host.ioBroker Caught by controller[1]: message: 'Bad number', 2022-03-17 00:00:53.648 - error: host.ioBroker Caught by controller[1]: at: 35, 2022-03-17 00:00:53.648 - error: host.ioBroker Caught by controller[1]: text: '481101E701000000000000000000000042' 2022-03-17 00:00:53.648 - error: host.ioBroker Caught by controller[1]: } 2022-03-17 00:00:53.648 - error: host.ioBroker instance system.adapter.hekr.0 terminated with code 6 (UNCAUGHT_EXCEPTION) 2022-03-17 00:00:53.648 - info: host.ioBroker Restart adapter system.adapter.hekr.0 because enabled 2022-03-17 00:00:53.648 - warn: host.ioBroker Do not restart adapter system.adapter.hekr.0 because restart loop detectedPlatformBetriebssystem:linux
Architektur:x64
CPUs:2
Geschwindigkeit:3000 MHz
Modell:Intel(R) Core(TM) i3-8109U CPU @ 3.00GHz
RAM:7.4 GB
System-Betriebszeit:38 T. 18:43:31
Node.js:v14.19.0
time:1647542366613
timeOffset:-60
Adapter-Anzahl:401
NPM:6.14.16
Datenträgergröße:31.2 GB
freier Festplattenspeicher:27.9 GB
Betriebszeit:1 T. 23:32:51
Aktive Instanzen:13
Pfad:/opt/iobroker/Jemand eine Idee?
MfG Ralf
Irgenwoher kenne ich diesen Fehler und ich bin der Meinung, dass ich diesen bei mir behoben habe...Wenn du mal Zeit hast würde ich dir gerne meine Dateien geben. Kannst dich ja per Chat melden.
Wenn du den Fehler auch schon hattest, warum dann nicht einfach eine neue Version auf github.
Dann bin ich bestimmt nicht der einzigste den das betrifft.
Ich wollte ja auch schon länger mal weiter sniffen. Sorry @Lucky_ESA ich weis im Moment einfach nicht was ich zu erst machen soll.MfG Ralf
Werde tombox fragen ob er die Änderungen übernimmt. Es wäre dann ein neuer Datenpunkt vorhanden in dem man selber den Raw probieren kann.
Eine Frage noch...Welche Datenpunkte funktionieren überhaupt bei dir?
light_Sw
speed
sw
tm_MinutesGruß//Lucky
light_Sw
speed
sw
@lucky_esa
Das kann ich die Tage mal Durchtesten.
Bin bis Montag nicht Daheim. -
@lucky_esa
Bin bis Montag nicht Daheim.Habe gerade getestet. Es funktionieren folgende Datenpunkte:
sw = 1 und 0 funktioniert
speed = 0, 1, 2 ,3 funktioniert
lightSw = 1 und 0 funktioniert
tm_Minutes = 1 funktioniert, schaltet nach einer Minute ab.
RGB_Sw = 1 funktioniert nicht, wird aber beim Schalten über die App richtig gesetzt. Zusätzlich wird beim RGB_Sw auf 1 schalten mit der App noch der Datenpunkt Statue auf 2 gesetzt. Beim ausschalten der Hg-Beleuchtung über App, wird korrekt RGB_Sw wieder auf 0 gesetzt und Statue wieder auf 1.
Die Farbwerte R, G, B und rgb werden nicht richtig gesetzt und lassen sich auch nicht steuern.MfG Ralf
@lucky_esa
Ist bei euch die App seit heute auch tot? Keine Registrierung und Dunstabzugshaube auch aus WLAN herausgeworfen.
Wieso geht eigentlich die KKT Kolbe App nicht? -
bei mir hat alles soweit funktioniert, nur werden bei mir die Datenpunkte .SW etc. unter Status nicht angezeigt. Bei mir gibt es nur die Punkte status.raw_manually, status.time und status.rgb angezeigt.
Woran könnte das liegen? Habe eine Abzugshaube von KKT im einsatz und über die APP geht alles.Danke schon mal im Voraus.
Christian -
@lucky_esa
Wieso geht eigentlich die KKT Kolbe App nicht?Nö nichts Auffälliges. Alles so wie immer. Wisen App kann auch auf das Gerät zugreifen.
Hallo ihr drei,
hatte auch gerade Probleme mit der APP. Jetzt scheint es wieder zu funktionieren.
@Fam3xCE Wahrscheinlich hatte HEKR ein Problem mit dem Server. Einchfach den Adapter neu starten.
Der neu Datenpunkt raw_manually ist für euch zum testen, welcher RAW versendet werden muss. Genaue Anleitung poste ich hier zeitnah.
Gruß//Lucky
So, jetzt versuche ich mal mein Glück. Ihr gehört zu den glücklichen die die Strahler und das RGB Licht getrennt schalten könnt. Natürlich kenne ich meinen RAW aber ich kann leider nur alles zusammen einschalten. Folglich muss euer RAW ein anderer sein und nun müssen wir leider raten, wie dieser aussehen könnte (oder ihr sniffert).
Zu der Nummerierung aller Schalter:
sw: 2
light_Sw: 3
speed: 4
tm_Minutes: 5
cleaning: 6
R: 7
B: 7
G: 7
time: 8
RGB_Sw: 9 -> Das könnte auch 1 oder 10 seinNun zu meinen RAW für das ändern von Farben.
480902000700c3ff00
48 -> Vorgabe KKT Kolbe
09 -> Hex Länge
02 -> Einzelner Befehl könnte allerdings bei euch 03 sein
6c -> Fortlaufender Counter kann 00 bleiben
07 -> Schalter für RGB (siehe oben)
00c3ff -> RGB Hex
88 -> Fortlaufender Counter kann 00 bleibenLaut eurem Template wird das Einschalten in der APP so übergeben.
cmdTag: "set_Rgbw",
R: 255,
G: 255,
B: 255,
RGB_Sw: 1Bei mir so:
cmdTag: "set_Rgbw",
R: 255,
G: 255,
B: 255Folglich gehe ich davon aus, dass das 01 für ON hinter dem RGB HEX kommt. Nun gilt es zu klären, ob auch die Nummerierung mitgesendet werden muss.
Ihr könnt nun mal probieren.
481002000700c3ff0100 ->Piepst es dann?
Oder:
48100200070100c3ff00
Oder mit Nummer:
481102000700c3ff090100 ->Piepst es dann?
48110200070900c3ff0100 ->Piepst es dann?
4811020007090100c3ff00 ->Piepst es dann?
4811020009010700c3ff00 ->Piepst es dann?Oder statt der 09 eine 01 oder 0A...
Da zwei Befehle gesendet werden kann es auch so anfangen.
481003
481103 -> Mit NummerierungVersucht es mal...Viel Spaß beim testen:-)
Gruß//Lucky
Hallo ihr drei,
Gruß//Lucky
@lucky_esa Danke für deine Antwort,
leider hat das aber nichts geändert und die Datenpunkte werden mir weiterhin nicht angezeigt.Grüße
Christian -
Dann bitte bei dem Adapter den Debug Modus unter Instanzen aktivieren und das Resultat mir per Chat zusenden.
Gruß//Lucky
der Adapter läuft bei mir bisher echt gut.Was passiert denn aber, wenn hekr / wisen den online Service abschaltet? Läuft der Adapter komplett lokal?
Weil so eine Dunstabzugshaube kauft man ja auch nicht jeden Tag.Besten Dank für die tolle Arbeit!
Timo -
Hallo der_timo,
sollte der Service eingestellt werden kann man im Adapter die Abfragen deaktivieren. Aber dann kann man nur noch schalten und bekommt eine Infos mehr. Das der Service eingestellt wird kann ich mir nicht vorstellen. Es gibt ja noch die KKT Kolbe APP...
Gruß//Lucky
Hallo der_timo,
Gruß//Lucky
@lucky_esa said in Test Adapter hekr wisen elro App v0.0.x:
Leider wird unter der die Dunstabzugshaube nicht gefunden. Ich verstehe nicht das die mit der KKT Kolbe App nicht kompatibel ist.
sw: 2
light_Sw: 3
speed: 4
tm_Minutes: 5
cleaning: 6
R: 7
B: 7
G: 7
time: 8
480902000700c3ff00
09 -> Hex Länge
00c3ff -> RGB Hex
cmdTag: "set_Rgbw",
R: 255,
G: 255,
B: 255,
cmdTag: "set_Rgbw",
R: 255,
G: 255,
Oder:
Oder mit Nummer:
481003
Gruß//Lucky
Ich habe inzwischen auch eine Kolbe Abzugshaube und habe alles ausprobiert.
Mein RAW sieht erst einmal so aus
4811020007090000ff010000FF2A01001E ->piepst und RGB ist #0000ff also blau
48110200070900ff00010000FF2A01001E ->piepst und RGB ist #00ff00 also grün
481102000709ff0000010000FF2A01001E ->piepst und RGB ist #ff0000 also rot
481102000709000000010000FF2A01001E ->piepst und RGB ist #000000 RGB ausD.h., der raw sieht definitiv anders aus. Ich habe versucht nach Deiner Vorgabe das einzuordnen.
11 -> Hex Länge
02 -> ist bei mir immer 02
00 -> Fortlaufender Counter kann 00 bleiben
09-> keine Ahnung was das ist, wird aber benötigt
00c3ff -> RGB Hex
010000FF2A01001E->keine Ahnung was das ist, wird aber so benötigtJetzt muss ich den Templates das versuchen zu ändern, damit ich den Befehl ein/aus mit RGB Werten über den RGB_Sw steuern kann. Richtig?
