  4. Test Adapter renault v0.0.x für myRenault und myDacia
387 Beiträge 59 Kommentatoren 100.1k Aufrufe 56 Beobachtet
  • S Stephan74
    @tombox Habe jetzt nochmal den Adapter neu installiert und den vorhandenen Objektbaum gelöscht.
    Nach der Neuinstallation leider immer noch kein Zugriff auf den Batteriestatus (unwichige Dinge wie Fahrgestellnummer, Version des Navis etc. gehen)
    Hoffentlich liegts nicht daran das ich einen Dacia habe...
    im Fehlerprotokoll steht folgendes:
    renault.0
    2022-03-17 13:55:36.754 info {"error":"access_denied","error_description":"Unauthorized"}
    renault.0
    2022-03-17 13:55:36.753 info Error: Request failed with status code 403
    renault.0
    2022-03-17 13:55:36.753 info Feature not found. Ignore location for updates.
    renault.0
    2022-03-17 13:55:36.597 info {"error":"access_denied","error_description":"Unauthorized"}
    renault.0
    2022-03-17 13:55:36.596 info Error: Request failed with status code 403
    renault.0
    2022-03-17 13:55:36.593 info Feature not found. Ignore res-state for updates.
    renault.0
    2022-03-17 13:55:36.402 info {"error":"access_denied","error_description":"Unauthorized"}
    renault.0
    2022-03-17 13:55:36.401 info Error: Request failed with status code 403
    renault.0
    2022-03-17 13:55:36.400 info Feature not found. Ignore lock-status for updates.
    renault.0
    2022-03-17 13:55:36.141 info {"error":"access_denied","error_description":"Unauthorized"}
    renault.0
    2022-03-17 13:55:36.140 info Error: Request failed with status code 403
    renault.0
    2022-03-17 13:55:36.139 info Feature not found. Ignore charges for updates.
    renault.0
    2022-03-17 13:55:35.986 info {"error":"access_denied","error_description":"Unauthorized"}
    renault.0
    2022-03-17 13:55:35.985 info Error: Request failed with status code 403
    renault.0
    2022-03-17 13:55:35.984 info Feature not found. Ignore charge-history for updates.
    renault.0
    2022-03-17 13:55:35.801 info {"error":"access_denied","error_description":"Unauthorized"}
    renault.0
    2022-03-17 13:55:35.800 info Error: Request failed with status code 403
    renault.0
    2022-03-17 13:55:35.799 info Feature not found. Ignore charging-settings for updates.
    renault.0
    2022-03-17 13:55:35.618 info {"error":"access_denied","error_description":"Unauthorized"}
    renault.0
    2022-03-17 13:55:35.617 info Error: Request failed with status code 403
    renault.0
    2022-03-17 13:55:35.616 info Feature not found. Ignore hvac-settings for updates.
    renault.0
    2022-03-17 13:55:35.483 info {"error":"access_denied","error_description":"Unauthorized"}
    renault.0
    2022-03-17 13:55:35.482 info Error: Request failed with status code 403
    renault.0
    2022-03-17 13:55:35.480 info Feature not found. Ignore hvac-status for updates.
    renault.0
    2022-03-17 13:55:35.282 info {"error":"access_denied","error_description":"Unauthorized"}
    renault.0
    2022-03-17 13:55:35.281 info Error: Request failed with status code 403
    renault.0
    2022-03-17 13:55:35.280 info Feature not found. Ignore charge-mode for updates.
    renault.0
    2022-03-17 12:55:35.282 info {"error":"access_denied","error_description":"Unauthorized"}
    renault.0
    2022-03-17 12:55:35.281 info Error: Request failed with status code 403
    renault.0
    2022-03-17 12:55:35.280 info Feature not found. Ignore charge-mode for updates.
    renault.0
    2022-03-17 12:55:35.131 info {"error":"access_denied","error_description":"Unauthorized"}
    renault.0
    2022-03-17 12:55:35.130 info Error: Request failed with status code 403
    renault.0
    2022-03-17 12:55:35.129 info Feature not found. Ignore cockpitv2 for updates.
    renault.0
    2022-03-17 12:55:34.931 info {"error":"access_denied","error_description":"Unauthorized"}
    renault.0
    2022-03-17 12:55:34.930 info Error: Request failed with status code 403
    renault.0
    2022-03-17 12:55:34.930 info Feature not found. Ignore cockpit for updates.
    renault.0
    2022-03-17 12:55:34.748 info {"error":"access_denied","error_description":"Unauthorized"}
    renault.0
    2022-03-17 12:55:34.748 info Error: Request failed with status code 403
    renault.0
    2022-03-17 12:55:34.747 info Feature not found. Ignore battery-inhibition-status for updates.
    renault.0
    2022-03-17 12:55:34.541 info {"error":"access_denied","error_description":"Unauthorized"}
    renault.0
    2022-03-17 12:55:34.540 info Error: Request failed with status code 403
    renault.0
    2022-03-17 12:55:34.538 info Feature not found. Ignore battery-status for updates.
    renault.0
    2022-03-17 12:55:32.694 info starting. Version 0.0.9 in /opt/iobroker/node_modules/iobroker.renault, node: v14.18.2, js-controller: 3.3.22
    tombox
    #99
    @stephan74 Bräuchte den debug log via privat nachricht . Unter Instanzen in Experteneinstellung die log level von info auf debug setzen
    S 2 Antworten Letzte Antwort
    • T tombox
      Stephan74
      #100
      @tombox wird sofort erledigt...
      • T tombox
        @jey-cee Ein Update auf 0.0.9 reicht damit der Adapter wieder funktioniert
        Es muss kein API key oder ähnliches eingegeben werden
        Batterystatus is zu finden unter
        renault.0.VIN.battery-status
        Jey CeeJ Online
        Jey CeeJ Online
        Jey Cee
        #101
        @tombox sagte in Test Adapter renault v0.0.x für myRenault und myDacia:
        Das hab ich ja gemacht und hab trotzdem die Meldung bekommen. Ergo reicht ein Update alleine nicht.
        Hier auch mal noch das Log vom Start:
        renault.0
        2022-03-17 14:04:30.518	info	{"error":"access_denied","error_description":"Unauthorized"}
        renault.0
        2022-03-17 14:04:30.518	info	Error: Request failed with status code 403
        renault.0
        2022-03-17 14:04:30.518	info	Feature not found. Ignore battery-inhibition-status for updates.
        renault.0
        2022-03-17 14:04:30.445	warn	State "renault.0.VF1AGVYA050017538.general.vehicleDetails.URL.https://www.youtube.com/watch?v=5di-Asr2r90.url" has no existing object, this might lead to an error in future versions
        renault.0
        2022-03-17 14:04:30.395	info	{"error":"access_denied","error_description":"Unauthorized"}
        renault.0
        2022-03-17 14:04:30.395	info	Error: Request failed with status code 403
        renault.0
        2022-03-17 14:04:30.394	info	Feature not found. Ignore battery-status for updates.
        renault.0
        2022-03-17 14:04:30.356	error	Error: Invalid ID: renault.0.VF1AGVYA050017538.general.vehicleDetails.URL.https://www.youtube.com/watch?v=5di-Asr2r90.url
        renault.0
        2022-03-17 14:04:30.341	info	State value to set for "renault.0.VF1AGVYA050017538.general.vehicleDetails.gearbox.group" has to be type "number" but received type "string"
        renault.0
        2022-03-17 14:04:30.341	info	State value to set for "renault.0.VF1AGVYA050017538.general.vehicleDetails.model.group" has to be type "number" but received type "string"
        renault.0
        2022-03-17 14:04:30.340	info	State value to set for "renault.0.VF1AGVYA050017538.general.vehicleDetails.radioType.group" has to be type "number" but received type "string"
        renault.0
        2022-03-17 14:04:30.339	info	State value to set for "renault.0.VF1AGVYA050017538.general.vehicleDetails.battery.group" has to be type "number" but received type "string"
        renault.0
        2022-03-17 14:04:30.339	info	State value to set for "renault.0.VF1AGVYA050017538.general.vehicleDetails.navigationAssistanceLevel.group" has to be type "number" but received type "string"
        renault.0
        2022-03-17 14:04:30.338	info	State value to set for "renault.0.VF1AGVYA050017538.general.vehicleDetails.radioCode" has to be type "number" but received type "string"
        renault.0
        2022-03-17 14:04:30.337	error	Error: Invalid ID: renault.0.VF1AGVYA050017538.general.vehicleDetails.URL.https://www.youtube.com/watch?v=5di-Asr2r90
        renault.0
        2022-03-17 14:04:30.325	info	State value to set for "renault.0.VF1AGVYA050017538.general.vehicleDetails.engineRatio" has to be type "number" but received type "string"
        renault.0
        2022-03-17 14:04:28.349	info	starting. Version 0.0.9 (non-npm: TA2k/ioBroker.renault#dace9333463b5d5fbae8e62996bdde38a08c7d96) in /opt/iobroker/node_modules/iobroker.renault, node: v12.22.10, js-controller: 4.0.21
        Persönlicher Support
        Spenden -> paypal.me/J3YC33
        • T tombox
          Stephan74
          #102
          @tombox das debug protokoll habe ich dir im privaten Chat rübergeschickt.
          • S Stephan74
            tombox
            #103
            @stephan74 @Jey-Cee Habe noch was gefunden bitte nochmal via github installieren
            • T tombox
              guergen
              #104
              @tombox Hab hier die Version 0.0.9 laufen....:
              Grade nochmal von Git installiert, es kommen zwar immer noch jede Menge Fehler, aber die Daten scheint er sich zu holen:
              • G guergen
                tombox
                #105
                @guergen Ja am anfang probiert er alle schnittstellen durch die für das Fahrzeug daten liefern können
                G 1 Antwort Letzte Antwort
                • ? Offline
                  #106
                  ZOE Adapter bringt auch Error "403".
                  Ich glaube bei Renault klemmt es mal wieder.
                  HumidorH 1 Antwort Letzte Antwort
                    HumidorH Offline
                    HumidorH Offline
                    Humidor
                    #107
                    warum habt ihr 0.0.9 ? auf Github gibt es 0.2.x
                    WICHTIG!!! WENN SIE VON EINER VERSION VOR 0.2.2 AKTUALISIEREN, MÜSSEN SIE ...
                    BG
                    • HumidorH Humidor
                      Jey CeeJ Online
                      Jey CeeJ Online
                      Jey Cee
                      #108
                      @humidor Weil es hier um den Renault Adapter und nicht um den ZOE2 Adapter geht.
                      • Jey CeeJ Jey Cee
                        HumidorH Offline
                        HumidorH Offline
                        Humidor
                        #109
                        @jey-cee Ahh, ok, das sind dann 2 verschiedene für das Gleiche...
                        BG
                        • T tombox
                          guergen
                          #110
                          @tombox Hier klappt das update scheinbar nicht:
                          Anschliessend bleibt die Update-Info auf "update" und folgendes steht in der Instanz-Liste:
                          Auch über die console geht es nicht iob stop-iob update-iob upgrade-iob start
                          • G guergen
                            tombox
                            #111
                            @guergen Ja mein Fehler habe jetzt 0.0.13 veröffentlicht
                            • T tombox
                              HumidorH Offline
                              HumidorH Offline
                              Humidor
                              schrieb am zuletzt editiert von Humidor
                              #112
                              @tombox hab mir gerade deinen Adapter geladen (danke! 🙏 )
                              in den Meldungen ist was aufgetaucht
                              im Objektbaum wurde sehr viel angelegt und ist aktuell, dh. der Adapter fkt. und hat eine Verbindung
                              was ich spontan nicht finde ist die "chargingPower" vom Zoe2 Adapter ?
                              gibt es wo eine Beschreibung aller DP ?
                              Interessant ist ein schnellerer Updatezyklus während einer Ladung, sonst sind die 10min völlig ausreichend. Wäre ein kürzerer Intervall für dich denkbar einzuarbeiten, oder ev. ein Trigger von Außen?
                              BG
                              T N 2 Antworten Letzte Antwort
                              • HumidorH Humidor
                                tombox
                                #113
                                @humidor remote.refresh sollte ein trigger sein
                                • T tombox
                                  HumidorH Offline
                                  HumidorH Offline
                                  Humidor
                                  #114
                                  @tombox ok, werde ich probieren, was ist der min. Intervall?
                                  BG
                                  • HumidorH Humidor
                                    tombox
                                    #115
                                    @humidor Du kannst manuell ausführen so oft du willst bzw renault das blockiert
                                    • T tombox
                                      HumidorH Offline
                                      HumidorH Offline
                                      Humidor
                                      #116
                                      @tombox das frage ich ja, soweit ich weiß gibt es Tageslimits und Intervallimits, danns wirst blockiert....
                                      BG
                                      • HumidorH Humidor
                                        N Offline
                                        N Offline
                                        NoRitz
                                        #117
                                        @humidor said in Test Adapter renault v0.0.x für myRenault und myDacia:
                                        Tatsächlich werden diese Objekte erst während des Ladevorgangs angezeigt.
                                        Bin da auch drüber gestolpert und habe jetzt meine Zoe ans Kabel gehängt. Und siehe: Zwei neue Objekte erscheinen unter dem Ordner Batterie:
                                        F 1 Antwort Letzte Antwort
                                        • N NoRitz
                                          Farmer-cb
                                          #118
                                          Servus
                                          gibt es irgendwo eine beschreibung was bei dem
                                          • battery-status.plugStatus
                                          • battery-status.chargingStatus
                                          • battery-inhibition-status.batteryInhibitorStatus
                                          die Nummer für eine Bedeutung haben
                                          smartes Haus durch Digitalstrom, enocean, SPS S7-1215, Homematik, Shelly, Alexa, iobroker auf einem HP-mini mit Proxmox
                                          N 1 Antwort Letzte Antwort
