  3. Einsteigerfragen
  4. Einbindung von Geräten
  5. [gelöst] web.0 läuft nicht
    5.2k
34 Beiträge 5 Kommentatoren 2.6k Aufrufe 3 Beobachtet
  • mickymM mickym
    @emi-0
    Achso das geht ja wahrscheinlich nich - weil der web Adapter nicht geht.
    Dann ggf. auf der Kommandozeile:
    iob logs
    eingeben und schauen, ob da was zum web.0 Adapter drin steht.
    Emi 0
    @mickym said in web.0 läuft nicht:
    iob logs
    micros02@smartmeter:~ $ iob logs
    2022-03-14 21:05:19.119  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:05:26.189  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:05:33.141  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:05:38.803  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:05:41.961  - info: host.smartmeter iobroker add flot --host smartmeter
    2022-03-14 21:05:44.988  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:05:51.288  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:05:57.392  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:06:03.280  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:06:04.494  - info: host.smartmeter iobroker host.smartmeter create instance flot
    2022-03-14 21:06:04.664  - info: host.smartmeter iobroker host.smartmeter object system.adapter.flot.upload created
    2022-03-14 21:06:05.011  - info: host.smartmeter iobroker host.smartmeter object system.adapter.flot.0 created
    2022-03-14 21:06:07.419  - info: host.smartmeter iobroker exit 0
    2022-03-14 21:06:08.079  - error: host.smartmeter startInstance system.adapter.flot.0 Adapter dependency not fulfilled on "smartmeter": required adapter "web" not found!
    2022-03-14 21:06:09.358  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:06:15.861  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:06:21.854  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:06:28.042  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:06:34.319  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:06:40.516  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:06:46.664  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:06:52.976  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:06:59.104  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:07:05.316  - info: smartmeter.0 (7330) Received 7 values, 2 updated
    2022-03-14 21:07:11.562  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:07:17.833  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:07:24.096  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:07:30.319  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:07:36.664  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:07:39.127  - info: host.smartmeter iobroker add vis --host smartmeter
    2022-03-14 21:07:42.890  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:07:49.309  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:07:55.399  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:08:01.424  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:08:01.454  - info: host.smartmeter iobroker host.smartmeter create instance vis
    2022-03-14 21:08:01.593  - info: host.smartmeter iobroker host.smartmeter object system.adapter.vis.upload created
    2022-03-14 21:08:01.665  - info: host.smartmeter iobroker host.smartmeter object vis.0 created
    2022-03-14 21:08:01.795  - info: host.smartmeter iobroker host.smartmeter object vis.0.control created
    2022-03-14 21:08:01.874  - info: host.smartmeter iobroker host.smartmeter object vis.0.control.instance created
    2022-03-14 21:08:01.954  - info: host.smartmeter iobroker host.smartmeter object vis.0.control.command created
    2022-03-14 21:08:02.043  - info: host.smartmeter iobroker host.smartmeter object vis.0.control.data created
    2022-03-14 21:08:02.214  - info: host.smartmeter iobroker host.smartmeter object system.adapter.vis.0 created
    2022-03-14 21:08:03.472  - info: host.smartmeter iobroker exit 0
    2022-03-14 21:08:05.426  - error: host.smartmeter startInstance system.adapter.vis.0 Adapter dependency not fulfilled on "smartmeter": required adapter "web" not found!
    2022-03-14 21:08:07.982  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:08:14.970  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:08:21.917  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:08:28.867  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:08:35.657  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:08:42.573  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:08:49.035  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:08:55.658  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:09:02.149  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:09:08.569  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:09:14.598  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:09:20.902  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:09:27.221  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:09:33.333  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:09:39.602  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:09:45.888  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:09:52.148  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:09:58.423  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:10:04.691  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:10:11.194  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:10:17.859  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:10:24.477  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:10:31.245  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:10:37.486  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:10:43.756  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:10:49.449  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:10:55.042  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:11:00.593  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:11:06.207  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:11:11.839  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:11:17.450  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:11:23.060  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:11:28.688  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:11:34.347  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:11:40.001  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:11:45.577  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:11:51.863  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:11:58.054  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:12:04.346  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:12:10.477  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:12:16.719  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:12:23.004  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:12:29.260  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:12:35.379  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:12:41.491  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:12:47.621  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:12:53.785  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:12:59.971  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:13:06.161  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:13:12.365  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:13:18.454  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:13:24.687  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:13:30.934  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:13:37.132  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:13:43.285  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:13:49.253  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:13:55.253  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:14:01.186  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:14:07.168  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:14:13.167  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:14:19.189  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:14:25.175  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:14:31.168  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:14:37.356  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:14:43.614  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:14:50.019  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:14:56.042  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:15:02.252  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:15:08.574  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:15:14.614  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:15:20.784  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:15:26.922  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:15:33.150  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:15:39.398  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:15:45.611  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:15:51.882  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:15:58.139  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:16:04.347  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:16:10.603  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:16:16.877  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:16:22.836  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:16:28.221  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:16:35.106  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:16:41.828  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:16:48.673  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:16:55.433  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:17:02.266  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:17:09.073  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:17:15.947  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:17:22.774  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:17:29.668  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:17:36.673  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:17:43.340  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:17:50.192  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:17:56.908  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:18:03.803  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:18:10.571  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:18:17.441  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:18:24.314  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:18:31.219  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:18:38.165  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:18:45.091  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:18:52.079  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:18:59.071  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:19:06.029  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:19:12.995  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:19:20.056  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:19:26.848  - info: smartmeter.0 (7330) Received 7 values, 2 updated
    2022-03-14 21:19:33.907  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:19:40.859  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:19:48.008  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:19:55.230  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:20:01.800  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:20:08.771  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:20:15.759  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:20:22.782  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:20:29.734  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:20:36.814  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:20:43.803  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:20:50.799  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:20:57.899  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:21:04.674  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:21:11.606  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:21:18.503  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:21:25.529  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:21:32.473  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:21:39.458  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:21:46.434  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:21:53.486  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:22:00.345  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:22:07.310  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:22:14.310  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:22:21.288  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:22:26.939  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:22:33.195  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:22:39.434  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:22:41.720  - info: host.smartmeter iobroker add web --host smartmeter
    2022-03-14 21:22:45.646  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:22:51.975  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:22:58.069  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:23:03.133  - info: host.smartmeter iobroker host.smartmeter create instance web
    2022-03-14 21:23:03.321  - info: host.smartmeter iobroker host.smartmeter object system.adapter.web.0.alive created
    2022-03-14 21:23:03.413  - info: host.smartmeter iobroker host.smartmeter object system.adapter.web.0.connected created
    2022-03-14 21:23:03.493  - info: host.smartmeter iobroker host.smartmeter object system.adapter.web.0.compactMode created
    2022-03-14 21:23:03.603  - info: host.smartmeter iobroker host.smartmeter object system.adapter.web.0.cpu created
    2022-03-14 21:23:03.951  - info: host.smartmeter iobroker host.smartmeter object system.adapter.web.0.cputime created
    2022-03-14 21:23:04.078  - info: host.smartmeter iobroker host.smartmeter object system.adapter.web.0.memHeapUsed created
    2022-03-14 21:23:04.175  - info: host.smartmeter iobroker host.smartmeter object system.adapter.web.0.memHeapTotal created
    2022-03-14 21:23:04.273  - info: host.smartmeter iobroker host.smartmeter object system.adapter.web.0.memRss created
    2022-03-14 21:23:04.364  - info: host.smartmeter iobroker host.smartmeter object system.adapter.web.0.uptime created
    2022-03-14 21:23:04.457  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:23:04.461  - info: host.smartmeter iobroker host.smartmeter object system.adapter.web.0.inputCount created
    2022-03-14 21:23:04.555  - info: host.smartmeter iobroker host.smartmeter object system.adapter.web.0.outputCount created
    2022-03-14 21:23:04.635  - info: host.smartmeter iobroker host.smartmeter object system.adapter.web.0.eventLoopLag created
    2022-03-14 21:23:04.724  - info: host.smartmeter iobroker host.smartmeter object system.adapter.web.0.sigKill created
    2022-03-14 21:23:04.797  - info: host.smartmeter iobroker host.smartmeter object system.adapter.web.0.logLevel created
    2022-03-14 21:23:04.986  - info: host.smartmeter iobroker host.smartmeter object system.adapter.web.upload created
    2022-03-14 21:23:05.053  - info: host.smartmeter iobroker host.smartmeter object web.0 created
    2022-03-14 21:23:05.122  - info: host.smartmeter iobroker host.smartmeter object web.0.info created
    2022-03-14 21:23:05.193  - info: host.smartmeter iobroker host.smartmeter object web.0.info.connection created
    2022-03-14 21:23:05.240  - info: host.smartmeter iobroker host.smartmeter Set default value of web.0.info.connection:
    2022-03-14 21:23:05.383  - info: host.smartmeter iobroker host.smartmeter object system.adapter.web.0 created
    2022-03-14 21:23:06.681  - info: host.smartmeter iobroker exit 0
    2022-03-14 21:23:08.952  - info: host.smartmeter instance system.adapter.web.0 started with pid 7726
    2022-03-14 21:23:10.357  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:23:16.517  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:23:22.759  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:23:28.780  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:23:34.468  - info: web.0 (7726) starting. Version 3.4.16 in /opt/iobroker/node_modules/iobroker.web, node: v12.22.5, js-controller: 4.0.21
    2022-03-14 21:23:35.369  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:23:36.914  - info: web.0 (7726) socket.io server listening on port 8082
    2022-03-14 21:23:36.991  - info: web.0 (7726) http server listening on port 8082
    2022-03-14 21:23:37.964  - warn: web.0 (7726) State "web.0.info.connected" has no existing object, this might lead to an error in future versions
    2022-03-14 21:23:41.179  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:23:47.479  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:23:53.736  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:23:59.985  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:24:06.282  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:24:12.429  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:24:18.796  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:24:24.951  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:24:31.219  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:24:37.419  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:24:40.517  - info: host.smartmeter stopInstance system.adapter.web.0 (force=false, process=true)
    2022-03-14 21:24:40.568  - info: web.0 (7726) Got terminate signal TERMINATE_YOURSELF
    2022-03-14 21:24:40.580  - info: host.smartmeter stopInstance system.adapter.web.0 send kill signal
    2022-03-14 21:24:40.627  - info: web.0 (7726) terminated http server on port 8082
    2022-03-14 21:24:40.646  - info: web.0 (7726) terminating
    2022-03-14 21:24:40.689  - info: web.0 (7726) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    2022-03-14 21:24:41.542  - info: host.smartmeter instance system.adapter.web.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2022-03-14 21:24:43.613  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:24:43.851  - info: host.smartmeter instance system.adapter.web.0 started with pid 7752
    2022-03-14 21:24:50.215  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:24:56.260  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:25:02.619  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:25:05.992  - info: web.0 (7752) starting. Version 3.4.16 in /opt/iobroker/node_modules/iobroker.web, node: v12.22.5, js-controller: 4.0.21
    2022-03-14 21:25:07.017  - error: web.0 (7752) Please specify the email address and domains to use Let's Encrypt certificates! We reuse old certificates
    2022-03-14 21:25:08.476  - info: web.0 (7752) Secure socket.io server listening on port 8082
    2022-03-14 21:25:08.687  - info: web.0 (7752) https server listening on port 8082
    2022-03-14 21:25:08.819  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:25:09.529  - warn: web.0 (7752) State "web.0.info.connected" has no existing object, this might lead to an error in future versions
    2022-03-14 21:25:15.095  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:25:21.439  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:25:27.689  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:25:33.998  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:25:40.288  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:25:46.504  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:25:52.858  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:25:59.004  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:26:05.278  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:26:11.499  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:26:17.628  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:26:23.881  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:26:30.159  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:26:36.465  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:26:42.458  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:26:48.496  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:26:54.591  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:27:00.613  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:27:06.811  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:27:13.031  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:27:18.974  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:27:24.979  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:27:31.166  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:27:37.169  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:27:43.309  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:27:49.398  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:27:55.523  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:28:01.584  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:28:07.665  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:28:13.694  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:28:19.747  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:28:25.824  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:28:31.859  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:28:37.779  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:28:43.685  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:28:49.708  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:28:56.899  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:29:02.639  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:29:08.496  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:29:14.177  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:29:20.145  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:29:25.917  - info: smartmeter.0 (7330) Received 7 values, 2 updated
    2022-03-14 21:29:31.815  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:29:37.312  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:29:42.919  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:29:48.207  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:29:53.702  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:29:59.151  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:30:04.508  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:30:09.934  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:30:15.437  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:30:20.888  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:30:28.041  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:30:35.164  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:30:40.993  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:30:46.873  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:30:52.806  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:30:58.853  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:31:05.115  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:31:10.997  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:31:16.976  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:31:23.009  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:31:29.087  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:31:35.188  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:31:41.237  - info: smartmeter.0 (7330) Received 7 values, 2 updated
    2022-03-14 21:31:47.319  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:31:53.500  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:31:59.449  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:32:05.514  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:32:11.625  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:32:17.655  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:32:23.697  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:32:29.741  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:32:35.824  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:32:41.917  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:32:47.947  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:32:54.035  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:33:00.134  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:33:06.339  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:33:12.355  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:33:18.559  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:33:24.810  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:33:31.095  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:33:37.347  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:33:43.489  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:33:49.689  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:33:55.935  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:34:02.162  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:34:08.501  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:34:14.631  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:34:20.855  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:34:27.274  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:34:33.370  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:34:39.133  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:34:44.765  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:34:50.423  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:34:55.986  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:35:01.554  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:35:07.073  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:35:12.883  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:35:18.414  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:35:24.019  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:35:29.692  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:35:35.349  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:35:40.924  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:35:46.684  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:35:52.643  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:35:59.128  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:36:05.537  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:36:11.897  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:36:18.351  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:36:24.759  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:36:31.069  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:36:37.459  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:36:43.780  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:36:50.220  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:36:56.681  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:37:03.076  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:37:09.453  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:37:15.693  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:37:22.076  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:37:28.504  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:37:35.345  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:37:41.669  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:37:48.211  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:37:54.777  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:37:57.099  - info: host.smartmeter stopInstance system.adapter.admin.0 (force=false, process=true)
    2022-03-14 21:37:57.431  - info: host.smartmeter stopInstance system.adapter.admin.0 send kill signal
    2022-03-14 21:37:57.313  - info: admin.0 (7316) Got terminate signal TERMINATE_YOURSELF
    2022-03-14 21:37:57.551  - info: admin.0 (7316) terminating http server on port 8081
    2022-03-14 21:37:57.571  - info: admin.0 (7316) terminating
    2022-03-14 21:37:57.620  - info: admin.0 (7316) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    2022-03-14 21:37:58.446  - info: host.smartmeter stopInstance system.adapter.admin.0 killing pid 7316
    2022-03-14 21:37:58.765  - info: host.smartmeter instance system.adapter.admin.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2022-03-14 21:37:59.397  - info: host.smartmeter stopInstance system.adapter.backitup.0 (force=false, process=true)
    2022-03-14 21:37:59.458  - info: host.smartmeter stopInstance system.adapter.backitup.0 send kill signal
    2022-03-14 21:37:59.438  - info: backitup.0 (7344) Got terminate signal TERMINATE_YOURSELF
    2022-03-14 21:37:59.505  - info: backitup.0 (7344) cleaned everything up...
    2022-03-14 21:37:59.522  - info: backitup.0 (7344) terminating
    2022-03-14 21:37:59.559  - info: backitup.0 (7344) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    2022-03-14 21:38:00.390  - info: host.smartmeter stopInstance system.adapter.discovery.0 (force=false, process=true)
    2022-03-14 21:38:00.480  - info: host.smartmeter stopInstance system.adapter.backitup.0 killing pid 7344
    2022-03-14 21:38:00.534  - info: discovery.0 (7337) Got terminate signal TERMINATE_YOURSELF
    2022-03-14 21:38:00.625  - info: discovery.0 (7337) terminating
    2022-03-14 21:38:00.652  - info: discovery.0 (7337) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    2022-03-14 21:38:00.722  - info: host.smartmeter stopInstance system.adapter.discovery.0 send kill signal
    2022-03-14 21:38:00.900  - info: host.smartmeter instance system.adapter.backitup.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2022-03-14 21:38:01.170  - info: host.smartmeter instance system.adapter.admin.0 started with pid 7800
    2022-03-14 21:38:01.753  - info: host.smartmeter stopInstance system.adapter.discovery.0 killing pid 7337
    2022-03-14 21:38:01.856  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:38:02.069  - info: host.smartmeter instance system.adapter.discovery.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2022-03-14 21:38:02.927  - info: host.smartmeter instance system.adapter.backitup.0 started with pid 7807
    2022-03-14 21:38:04.556  - info: host.smartmeter instance system.adapter.discovery.0 started with pid 7813
    2022-03-14 21:38:08.019  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:38:11.942  - info: host.smartmeter "system.adapter.vis.0" disabled
    2022-03-14 21:38:12.157  - info: host.smartmeter "system.adapter.vis.0" enabled
    2022-03-14 21:38:15.476  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:38:21.841  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:38:28.415  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:38:35.671  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:38:41.134  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:38:47.749  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:38:54.765  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:39:00.735  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:39:07.475  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:39:14.434  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:39:20.895  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:39:27.109  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:39:33.697  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:39:38.348  - info: vis.0 (7821) starting. Version 1.4.5 in /opt/iobroker/node_modules/iobroker.vis, node: v12.22.5, js-controller: 4.0.21
    2022-03-14 21:39:39.895  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:39:39.634  - error: vis.0 (7821) No license found for vis. Please get one on https://iobroker.net !
    2022-03-14 21:39:44.336  - info: vis.0 (7821) Terminated (NO_ERROR): Without reason
    2022-03-14 21:39:46.018  - info: host.smartmeter instance system.adapter.vis.0 terminated while should be started once
    2022-03-14 21:39:46.571  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:39:48.518  - info: discovery.0 (7813) starting. Version 2.7.5 in /opt/iobroker/node_modules/iobroker.discovery, node: v12.22.5, js-controller: 4.0.21
    2022-03-14 21:39:51.444  - info: admin.0 (7800) starting. Version 5.3.1 in /opt/iobroker/node_modules/iobroker.admin, node: v12.22.5, js-controller: 4.0.21
    2022-03-14 21:39:53.004  - info: admin.0 (7800) requesting all states
    2022-03-14 21:39:53.204  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:39:53.030  - info: admin.0 (7800) requesting all objects
    2022-03-14 21:39:53.704  - info: backitup.0 (7807) starting. Version 2.3.3 in /opt/iobroker/node_modules/iobroker.backitup, node: v12.22.5, js-controller: 4.0.21
    2022-03-14 21:39:55.825  - info: backitup.0 (7807) [iobroker] backup was activated at 02:40 every 1 day(s)
    2022-03-14 21:40:01.579  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:40:03.069  - info: admin.0 (7800) received all objects
    2022-03-14 21:40:07.252  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:40:11.862  - warn: admin.0 (7800) Cannot update rating: timeout of 15000ms exceeded
    2022-03-14 21:40:12.114  - info: admin.0 (7800) Request actual repository...
    2022-03-14 21:40:14.664  - info: admin.0 (7800) http server listening on port 8081
    2022-03-14 21:40:15.492  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:40:14.674  - info: admin.0 (7800) Use link "http://localhost:8081" to configure.
    2022-03-14 21:40:20.267  - info: host.smartmeter Updating repository "stable" under "http://download.iobroker.net/sources-dist.json"
    2022-03-14 21:40:32.545  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:40:33.227  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:40:33.355  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:40:37.007  - info: admin.0 (7800) Repository received successfully.
    2022-03-14 21:40:38.302  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:40:44.681  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:40:51.795  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:40:57.757  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:41:04.336  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:41:10.994  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:41:17.505  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:41:24.098  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:41:30.473  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:41:37.070  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:41:43.593  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:41:50.266  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:41:56.670  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:42:03.113  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:42:09.628  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:42:15.762  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:42:22.663  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:42:29.623  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:42:35.385  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:42:40.518  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:42:45.952  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:42:52.118  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:42:57.089  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:43:03.187  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:43:10.881  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:43:17.239  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:43:24.282  - info: smartmeter.0 (7330) Received 7 values, 2 updated
    2022-03-14 21:43:31.229  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:43:37.488  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:43:43.709  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:43:50.180  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:43:56.827  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:44:02.561  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:44:08.111  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:44:13.574  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:44:19.114  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:44:24.709  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:44:30.907  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:44:36.843  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:44:42.593  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:44:48.423  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:44:54.249  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:45:00.016  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:45:05.940  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:45:11.672  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:45:17.529  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:45:23.426  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:45:28.901  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:45:34.509  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:45:40.235  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:45:45.647  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:45:51.862  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:45:56.827  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:46:02.522  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:46:07.962  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:46:13.584  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:46:15.303  - info: host.smartmeter stopInstance system.adapter.web.0 (force=false, process=true)
    2022-03-14 21:46:15.539  - info: host.smartmeter stopInstance system.adapter.web.0 send kill signal
    2022-03-14 21:46:15.517  - info: web.0 (7752) Got terminate signal TERMINATE_YOURSELF
    2022-03-14 21:46:15.656  - info: web.0 (7752) terminated https server on port 8082
    2022-03-14 21:46:15.683  - info: web.0 (7752) terminating
    2022-03-14 21:46:15.719  - info: web.0 (7752) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    2022-03-14 21:46:16.671  - info: host.smartmeter instance system.adapter.web.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2022-03-14 21:46:19.477  - info: host.smartmeter instance system.adapter.web.0 started with pid 7876
    2022-03-14 21:46:19.552  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:46:24.819  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:46:30.429  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:46:36.248  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:46:41.729  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:46:45.147  - info: web.0 (7876) starting. Version 3.4.16 in /opt/iobroker/node_modules/iobroker.web, node: v12.22.5, js-controller: 4.0.21
    2022-03-14 21:46:46.099  - error: web.0 (7876) Please specify the email address and domains to use Let's Encrypt certificates! We reuse old certificates
    2022-03-14 21:46:47.446  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:46:47.967  - info: web.0 (7876) Secure socket.io server listening on port 8082
    2022-03-14 21:46:48.054  - info: web.0 (7876) https server listening on port 8082
    2022-03-14 21:46:49.007  - warn: web.0 (7876) State "web.0.info.connected" has no existing object, this might lead to an error in future versions
    2022-03-14 21:46:52.908  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:46:58.517  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:47:01.415  - info: host.smartmeter stopInstance system.adapter.web.0 (force=false, process=true)
    2022-03-14 21:47:01.503  - info: web.0 (7876) Got terminate signal TERMINATE_YOURSELF
    2022-03-14 21:47:01.565  - info: host.smartmeter stopInstance system.adapter.web.0 send kill signal
    2022-03-14 21:47:01.545  - info: web.0 (7876) terminated https server on port 8082
    2022-03-14 21:47:01.552  - info: web.0 (7876) terminating
    2022-03-14 21:47:01.611  - info: web.0 (7876) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    2022-03-14 21:47:02.441  - info: host.smartmeter instance system.adapter.web.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2022-03-14 21:47:04.384  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:47:04.708  - info: host.smartmeter instance system.adapter.web.0 started with pid 7893
    2022-03-14 21:47:10.470  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:47:16.099  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:47:22.189  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:47:28.078  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:47:33.607  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:47:34.857  - info: web.0 (7893) starting. Version 3.4.16 in /opt/iobroker/node_modules/iobroker.web, node: v12.22.5, js-controller: 4.0.21
    2022-03-14 21:47:35.972  - error: web.0 (7893) Please specify the email address and domains to use Let's Encrypt certificates! We reuse old certificates
    2022-03-14 21:47:37.683  - info: web.0 (7893) Secure socket.io server listening on port 8082
    2022-03-14 21:47:37.766  - info: web.0 (7893) https server listening on port 8082
    2022-03-14 21:47:38.728  - warn: web.0 (7893) State "web.0.info.connected" has no existing object, this might lead to an error in future versions
    2022-03-14 21:47:39.436  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:47:45.196  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:47:51.369  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:47:56.836  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:48:02.608  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:48:08.069  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:48:13.577  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:48:19.245  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:48:24.771  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:48:30.448  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:48:37.006  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:48:43.449  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:48:49.866  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:48:56.531  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:49:03.630  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:49:09.141  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:49:16.131  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:49:23.238  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:49:30.285  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:49:37.281  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:49:44.040  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:49:50.982  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:49:57.818  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:50:04.609  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:50:11.338  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:50:18.171  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:50:24.778  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:50:31.968  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:50:39.118  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:50:46.067  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:50:53.181  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:51:00.266  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:51:07.347  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:51:14.444  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:51:21.649  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:51:27.504  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:51:32.974  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:51:38.374  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:51:43.842  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:51:50.568  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:51:56.032  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:52:01.523  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:52:07.047  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:52:12.605  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:52:18.170  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:52:23.739  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:52:29.261  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:52:34.856  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:52:40.467  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:52:45.944  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:52:51.511  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:52:57.075  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:53:02.631  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:53:08.191  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:53:13.716  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:53:19.356  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:53:24.854  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:53:30.413  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:53:36.008  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:53:41.485  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:53:46.964  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:53:52.569  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:53:59.449  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:54:07.359  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:54:12.937  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:54:18.434  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:54:24.129  - info: smartmeter.0 (7330) Received 7 values, 2 updated
    2022-03-14 21:54:29.536  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:54:35.417  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:54:40.697  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:54:46.268  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:54:51.841  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:54:57.447  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:55:02.950  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:55:10.551  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:55:17.043  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:55:23.794  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:55:30.432  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:55:37.149  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:55:43.172  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:55:48.687  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:55:54.252  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:55:59.673  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:56:05.396  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:56:10.620  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:56:16.147  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:56:21.665  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:56:27.186  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:56:33.788  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:56:39.270  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:56:44.778  - info: smartmeter.0 (7330) Received 7 values, 2 updated
    2022-03-14 21:56:50.524  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:56:55.847  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:57:01.179  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:57:06.756  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:57:12.422  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:57:18.158  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:57:23.860  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:57:29.495  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:57:37.258  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:57:40.840  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:57:46.537  - info: host.smartmeter stopInstance system.adapter.web.0 (force=false, process=true)
    2022-03-14 21:57:46.616  - info: web.0 (7893) Got terminate signal TERMINATE_YOURSELF
    2022-03-14 21:57:46.734  - info: host.smartmeter stopInstance system.adapter.web.0 send kill signal
    2022-03-14 21:57:46.684  - info: web.0 (7893) terminated https server on port 8082
    2022-03-14 21:57:46.691  - info: web.0 (7893) terminating
    2022-03-14 21:57:46.740  - info: web.0 (7893) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    2022-03-14 21:57:46.868  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:57:47.575  - info: host.smartmeter instance system.adapter.web.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2022-03-14 21:57:49.946  - info: host.smartmeter instance system.adapter.web.0 started with pid 7925
    2022-03-14 21:57:52.137  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:57:58.100  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:58:03.589  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:58:09.437  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:58:15.227  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:58:15.339  - info: web.0 (7925) starting. Version 3.4.16 in /opt/iobroker/node_modules/iobroker.web, node: v12.22.5, js-controller: 4.0.21
    2022-03-14 21:58:17.156  - info: web.0 (7925) socket.io server listening on port 8082
    2022-03-14 21:58:17.238  - info: web.0 (7925) http server listening on port 8082
    2022-03-14 21:58:18.192  - warn: web.0 (7925) State "web.0.info.connected" has no existing object, this might lead to an error in future versions
    2022-03-14 21:58:20.885  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:58:26.501  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:58:32.213  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:58:37.838  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:58:43.588  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:58:49.456  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:58:54.783  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:59:00.582  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:59:06.096  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:59:11.711  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:59:17.382  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:59:22.991  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:59:28.710  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:59:34.337  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:59:39.952  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:59:45.813  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:59:51.401  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 21:59:57.057  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 22:00:02.580  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 22:00:09.407  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 22:00:14.758  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 22:00:22.784  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 22:00:29.397  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 22:00:34.806  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 22:00:40.359  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 22:00:46.921  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 22:00:53.696  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 22:00:59.063  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 22:01:04.505  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 22:01:10.152  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 22:01:15.776  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 22:01:21.408  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 22:01:27.052  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 22:01:32.781  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 22:01:38.382  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 22:01:46.301  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 22:01:51.648  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 22:01:58.318  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 22:02:06.242  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 22:02:08.296  - info: host.smartmeter stopInstance system.adapter.web.0 (force=false, process=true)
    2022-03-14 22:02:08.378  - info: web.0 (7925) Got terminate signal TERMINATE_YOURSELF
    2022-03-14 22:02:08.475  - info: host.smartmeter stopInstance system.adapter.web.0 send kill signal
    2022-03-14 22:02:08.439  - info: web.0 (7925) terminated http server on port 8082
    2022-03-14 22:02:08.459  - info: web.0 (7925) terminating
    2022-03-14 22:02:08.511  - info: web.0 (7925) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    2022-03-14 22:02:09.324  - info: host.smartmeter instance system.adapter.web.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2022-03-14 22:02:11.688  - info: host.smartmeter instance system.adapter.web.0 started with pid 7965
    2022-03-14 22:02:11.742  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 22:02:19.589  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 22:02:24.969  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 22:02:31.547  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 22:02:33.867  - info: web.0 (7965) starting. Version 3.4.16 in /opt/iobroker/node_modules/iobroker.web, node: v12.22.5, js-controller: 4.0.21
    2022-03-14 22:02:36.189  - info: web.0 (7965) socket.io server listening on port 8082
    2022-03-14 22:02:36.285  - info: web.0 (7965) http server listening on port 8082
    2022-03-14 22:02:37.228  - warn: web.0 (7965) State "web.0.info.connected" has no existing object, this might lead to an error in future versions
    2022-03-14 22:02:39.368  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 22:02:47.410  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 22:02:52.270  - info: host.smartmeter stopInstance system.adapter.web.0 (force=false, process=true)
    2022-03-14 22:02:52.358  - info: web.0 (7965) Got terminate signal TERMINATE_YOURSELF
    2022-03-14 22:02:52.371  - info: host.smartmeter stopInstance system.adapter.web.0 send kill signal
    2022-03-14 22:02:52.418  - info: web.0 (7965) terminated http server on port 8082
    2022-03-14 22:02:52.446  - info: web.0 (7965) terminating
    2022-03-14 22:02:52.487  - info: web.0 (7965) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    2022-03-14 22:02:53.117  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 22:02:53.392  - info: host.smartmeter stopInstance system.adapter.web.0 killing pid 7965
    2022-03-14 22:02:53.584  - info: host.smartmeter instance system.adapter.web.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2022-03-14 22:02:55.512  - info: host.smartmeter instance system.adapter.web.0 started with pid 7980
    2022-03-14 22:02:58.549  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 22:03:04.290  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 22:03:09.661  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 22:03:15.119  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 22:03:17.686  - info: web.0 (7980) starting. Version 3.4.16 in /opt/iobroker/node_modules/iobroker.web, node: v12.22.5, js-controller: 4.0.21
    2022-03-14 22:03:19.731  - info: web.0 (7980) socket.io server listening on port 8082
    2022-03-14 22:03:19.813  - info: web.0 (7980) http server listening on port 8082
    2022-03-14 22:03:20.854  - warn: web.0 (7980) State "web.0.info.connected" has no existing object, this might lead to an error in future versions
    2022-03-14 22:03:20.975  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 22:03:26.435  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 22:03:31.987  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 22:03:37.609  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 22:03:43.310  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 22:03:49.165  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 22:03:55.087  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 22:04:00.598  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 22:04:06.514  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 22:04:12.361  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 22:04:18.193  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 22:04:24.231  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 22:04:29.679  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 22:04:37.173  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 22:04:44.334  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 22:04:51.503  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 22:04:58.722  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 22:05:05.941  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 22:05:13.046  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 22:05:19.930  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 22:05:27.168  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 22:05:34.357  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 22:05:40.919  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 22:05:46.538  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 22:05:52.159  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 22:05:57.772  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 22:06:03.377  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 22:06:09.099  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 22:06:14.568  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 22:06:20.299  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 22:06:25.798  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 22:06:33.208  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 22:06:39.974  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 22:06:46.773  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 22:06:53.525  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 22:07:00.254  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 22:07:07.024  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 22:07:13.838  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 22:07:20.601  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 22:07:27.389  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 22:07:34.214  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 22:07:40.926  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 22:07:47.712  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 22:07:54.523  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 22:08:01.299  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 22:08:08.067  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 22:08:14.905  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 22:08:21.679  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 22:08:28.489  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 22:08:35.953  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 22:08:43.304  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 22:08:50.869  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 22:08:58.192  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 22:09:05.561  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 22:09:13.156  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 22:09:20.509  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 22:09:28.094  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 22:09:35.487  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 22:09:43.098  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 22:09:50.466  - info: smartmeter.0 (7330) Received 7 values, 2 updated
    2022-03-14 22:09:58.109  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 22:10:05.504  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 22:10:13.098  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 22:10:20.361  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 22:10:27.821  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 22:10:35.299  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 22:10:42.320  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 22:10:49.459  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 22:10:56.534  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 22:11:04.130  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 22:11:11.429  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 22:11:18.923  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 22:11:26.404  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 22:11:33.865  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 22:11:41.371  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 22:11:48.831  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 22:11:56.274  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 22:12:03.689  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 22:12:11.202  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 22:12:18.640  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 22:12:24.533  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 22:12:30.390  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 22:12:36.331  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 22:12:42.319  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 22:12:48.337  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 22:12:54.189  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 22:12:59.971  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 22:13:05.990  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 22:13:11.927  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 22:13:18.053  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 22:13:23.969  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 22:13:29.923  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 22:13:35.994  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 22:13:41.901  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 22:13:48.135  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 22:13:54.247  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 22:14:00.325  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 22:14:06.519  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 22:14:12.737  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 22:14:18.965  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 22:14:25.147  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 22:14:31.369  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 22:14:37.615  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 22:14:43.860  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 22:14:50.231  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 22:14:56.279  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 22:15:02.526  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 22:15:08.776  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 22:15:14.989  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 22:15:21.229  - info: smartmeter.0 (7330) Received 7 values, 3 updated
    2022-03-14 22:15:23.703  - info: host.smartmeter received SIGTERM
    2022-03-14 22:15:23.794  - info: backitup.0 (7807) cleaned everything up...
    2022-03-14 22:15:23.843  - info: web.0 (7980) terminated http server on port 8082
    2022-03-14 22:15:23.826  - info: host.smartmeter stopInstance system.adapter.admin.0 (force=false, process=true)
    2022-03-14 22:15:23.829  - info: host.smartmeter stopInstance system.adapter.history.0 (force=false, process=true)
    2022-03-14 22:15:23.885  - info: host.smartmeter stopInstance system.adapter.smartmeter.0 (force=false, process=true)
    2022-03-14 22:15:23.889  - info: host.smartmeter stopInstance system.adapter.discovery.0 (force=false, process=true)
    2022-03-14 22:15:23.892  - info: host.smartmeter stopInstance system.adapter.backitup.0 (force=false, process=true)
    2022-03-14 22:15:23.947  - info: host.smartmeter stopInstance system.adapter.flot.0 (force=false, process=false)
    2022-03-14 22:15:23.950  - info: host.smartmeter stopInstance system.adapter.vis.0 (force=false, process=false)
    2022-03-14 22:15:23.952  - info: host.smartmeter stopInstance system.adapter.web.0 (force=false, process=true)
    2022-03-14 22:15:23.874  - info: admin.0 (7800) terminating http server on port 8081
    2022-03-14 22:15:24.360  - info: admin.0 (7800) Got terminate signal TERMINATE_YOURSELF
    2022-03-14 22:15:24.382  - info: smartmeter.0 (7330) Got terminate signal TERMINATE_YOURSELF
    2022-03-14 22:15:24.407  - info: discovery.0 (7813) Got terminate signal TERMINATE_YOURSELF
    2022-03-14 22:15:24.434  - info: backitup.0 (7807) Got terminate signal TERMINATE_YOURSELF
    2022-03-14 22:15:24.431  - info: web.0 (7980) Got terminate signal TERMINATE_YOURSELF
    2022-03-14 22:15:24.610  - info: smartmeter.0 (7330) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
    2022-03-14 22:15:24.596  - info: backitup.0 (7807) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
    2022-03-14 22:15:24.625  - info: web.0 (7980) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
    2022-03-14 22:15:24.635  - info: discovery.0 (7813) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
    2022-03-14 22:15:24.739  - info: admin.0 (7800) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
    2022-03-14 22:15:24.975  - info: host.smartmeter stopInstance system.adapter.admin.0 send kill signal
    2022-03-14 22:15:24.984  - info: host.smartmeter stopInstance system.adapter.smartmeter.0 send kill signal
    2022-03-14 22:15:24.987  - info: host.smartmeter stopInstance system.adapter.discovery.0 send kill signal
    2022-03-14 22:15:24.989  - info: host.smartmeter stopInstance system.adapter.backitup.0 send kill signal
    2022-03-14 22:15:24.992  - info: host.smartmeter stopInstance system.adapter.web.0 send kill signal
    2022-03-14 22:15:26.037  - info: host.smartmeter stopInstance system.adapter.admin.0 killing pid 7800
    2022-03-14 22:15:26.063  - info: host.smartmeter stopInstance system.adapter.smartmeter.0 killing pid 7330
    2022-03-14 22:15:26.074  - info: host.smartmeter stopInstance system.adapter.discovery.0 killing pid 7813
    2022-03-14 22:15:26.093  - info: host.smartmeter stopInstance system.adapter.backitup.0 killing pid 7807
    2022-03-14 22:15:26.256  - info: host.smartmeter stopInstance system.adapter.web.0 killing pid 7980
    2022-03-14 22:15:27.487  - warn: host.smartmeter instance system.adapter.smartmeter.0 terminated due to SIGTERM
    2022-03-14 22:15:27.494  - info: host.smartmeter instance system.adapter.smartmeter.0 terminated with code null ()
    2022-03-14 22:15:27.639  - warn: host.smartmeter instance system.adapter.admin.0 terminated due to SIGTERM
    2022-03-14 22:15:27.642  - info: host.smartmeter instance system.adapter.admin.0 terminated with code null ()
    2022-03-14 22:15:27.657  - warn: host.smartmeter instance system.adapter.backitup.0 terminated due to SIGTERM
    2022-03-14 22:15:27.660  - info: host.smartmeter instance system.adapter.backitup.0 terminated with code null ()
    2022-03-14 22:15:27.673  - warn: host.smartmeter instance system.adapter.discovery.0 terminated due to SIGTERM
    2022-03-14 22:15:27.676  - info: host.smartmeter instance system.adapter.discovery.0 terminated with code null ()
    2022-03-14 22:15:27.679  - warn: host.smartmeter instance system.adapter.web.0 terminated due to SIGTERM
    2022-03-14 22:15:27.682  - info: host.smartmeter instance system.adapter.web.0 terminated with code null ()
    2022-03-14 22:15:28.643  - info: history.0 (7323) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
    2022-03-14 22:15:29.728  - info: host.smartmeter instance system.adapter.history.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
    2022-03-14 22:15:29.732  - info: host.smartmeter All instances are stopped.
    2022-03-14 22:15:29.962  - info: host.smartmeter terminated
    2022-03-14 22:15:44.610  - info: host.smartmeter iobroker.js-controller version 4.0.21 js-controller starting
    2022-03-14 22:15:44.709  - info: host.smartmeter Copyright (c) 2014-2022 bluefox, 2014 hobbyquaker
    2022-03-14 22:15:44.716  - info: host.smartmeter hostname: smartmeter, node: v12.22.5
    2022-03-14 22:15:44.723  - info: host.smartmeter ip addresses: 192.168.178.191 2001:16b8:220a:5a00:13a1:9f6c:3f10:875b fe80::3214:b3be:5fb:d542
    2022-03-14 22:15:55.235  - info: host.smartmeter connected to Objects and States
    2022-03-14 22:15:55.647  - info: host.smartmeter added notifications configuration of host
    2022-03-14 22:15:58.737  - info: host.smartmeter 8 instances found
    2022-03-14 22:15:58.942  - info: host.smartmeter starting 7 instances
    2022-03-14 22:15:59.542  - info: host.smartmeter instance system.adapter.admin.0 started with pid 8037
    2022-03-14 22:16:03.304  - info: host.smartmeter instance system.adapter.history.0 started with pid 8044
    2022-03-14 22:16:07.455  - info: host.smartmeter instance system.adapter.smartmeter.0 started with pid 8052
    2022-03-14 22:16:11.796  - info: host.smartmeter instance system.adapter.discovery.0 started with pid 8059
    2022-03-14 22:16:15.790  - info: host.smartmeter instance system.adapter.backitup.0 started with pid 8066
    2022-03-14 22:16:20.274  - info: host.smartmeter instance system.adapter.web.0 started with pid 8073
    2022-03-14 22:16:47.359  - info: host.smartmeter received SIGTERM
    2022-03-14 22:16:47.571  - info: host.smartmeter stopInstance system.adapter.admin.0 (force=false, process=true)
    2022-03-14 22:16:47.577  - info: host.smartmeter stopInstance system.adapter.history.0 (force=false, process=true)
    2022-03-14 22:16:47.591  - info: host.smartmeter stopInstance system.adapter.smartmeter.0 (force=false, process=true)
    2022-03-14 22:16:47.596  - info: host.smartmeter stopInstance system.adapter.discovery.0 (force=false, process=true)
    2022-03-14 22:16:47.602  - info: host.smartmeter stopInstance system.adapter.backitup.0 (force=false, process=true)
    2022-03-14 22:16:47.607  - info: host.smartmeter stopInstance system.adapter.web.0 (force=false, process=true)
    2022-03-14 22:16:47.612  - info: host.smartmeter stopInstance system.adapter.vis.0 (force=false, process=true)
    2022-03-14 22:16:49.094  - warn: host.smartmeter instance system.adapter.admin.0 terminated due to SIGTERM
    2022-03-14 22:16:49.106  - info: host.smartmeter instance system.adapter.admin.0 terminated with code null ()
    2022-03-14 22:16:49.124  - warn: host.smartmeter instance system.adapter.history.0 terminated due to SIGTERM
    2022-03-14 22:16:49.128  - info: host.smartmeter instance system.adapter.history.0 terminated with code null ()
    2022-03-14 22:16:49.146  - warn: host.smartmeter instance system.adapter.smartmeter.0 terminated due to SIGTERM
    2022-03-14 22:16:49.150  - info: host.smartmeter instance system.adapter.smartmeter.0 terminated with code null ()
    2022-03-14 22:16:49.167  - warn: host.smartmeter instance system.adapter.discovery.0 terminated due to SIGTERM
    2022-03-14 22:16:49.172  - info: host.smartmeter instance system.adapter.discovery.0 terminated with code null ()
    2022-03-14 22:16:49.188  - warn: host.smartmeter instance system.adapter.backitup.0 terminated due to SIGTERM
    2022-03-14 22:16:49.203  - info: host.smartmeter instance system.adapter.backitup.0 terminated with code null ()
    2022-03-14 22:16:49.209  - warn: host.smartmeter instance system.adapter.web.0 terminated due to SIGTERM
    2022-03-14 22:16:49.221  - info: host.smartmeter instance system.adapter.web.0 terminated with code null ()
    2022-03-14 22:16:49.228  - info: host.smartmeter instance system.adapter.vis.0 terminated while should be started once
    2022-03-14 22:16:49.305  - info: host.smartmeter stopInstance system.adapter.admin.0 send kill signal
    2022-03-14 22:16:49.309  - info: host.smartmeter stopInstance system.adapter.smartmeter.0 send kill signal
    2022-03-14 22:16:49.313  - info: host.smartmeter stopInstance system.adapter.discovery.0 send kill signal
    2022-03-14 22:16:49.317  - info: host.smartmeter stopInstance system.adapter.backitup.0 send kill signal
    2022-03-14 22:16:49.321  - info: host.smartmeter stopInstance system.adapter.web.0 send kill signal
    2022-03-14 22:17:03.022  - info: host.smartmeter force terminating
    2022-03-14 22:17:31.119  - info: host.smartmeter iobroker.js-controller version 4.0.21 js-controller starting
    2022-03-14 22:17:31.310  - info: host.smartmeter Copyright (c) 2014-2022 bluefox, 2014 hobbyquaker
    2022-03-14 22:17:31.327  - info: host.smartmeter hostname: smartmeter, node: v12.22.5
    2022-03-14 22:17:31.344  - info: host.smartmeter ip addresses: 192.168.178.191 2001:16b8:220a:5a00:13a1:9f6c:3f10:875b fe80::3214:b3be:5fb:d542
    2022-03-14 22:17:52.589  - info: host.smartmeter connected to Objects and States
    2022-03-14 22:17:53.573  - info: host.smartmeter added notifications configuration of host
    2022-03-14 22:17:57.297  - info: host.smartmeter 8 instances found
    2022-03-14 22:17:57.488  - info: host.smartmeter starting 7 instances
    2022-03-14 22:17:58.451  - info: host.smartmeter instance system.adapter.admin.0 started with pid 8144
    2022-03-14 22:18:02.544  - info: host.smartmeter instance system.adapter.history.0 started with pid 8151
    2022-03-14 22:18:05.986  - info: host.smartmeter instance system.adapter.smartmeter.0 started with pid 8158
    2022-03-14 22:18:10.146  - info: host.smartmeter instance system.adapter.discovery.0 started with pid 8165
    2022-03-14 22:18:14.425  - info: host.smartmeter instance system.adapter.backitup.0 started with pid 8172
    2022-03-14 22:18:18.647  - info: host.smartmeter instance system.adapter.web.0 started with pid 8179
    2022-03-14 22:20:00.094  - info: history.0 (8151) starting. Version 1.10.5 in /opt/iobroker/node_modules/iobroker.history, node: v12.22.5, js-controller: 4.0.21
    2022-03-14 22:20:03.502  - info: history.0 (8151) enabled logging of 0_userdata.0.example_state (Count=1), Alias=false
    2022-03-14 22:20:03.609  - info: history.0 (8151) enabled logging of smartmeter.0.1-0:16_7_0__255.value (Count=2), Alias=false
    2022-03-14 22:20:10.634  - info: admin.0 (8144) starting. Version 5.3.1 in /opt/iobroker/node_modules/iobroker.admin, node: v12.22.5, js-controller: 4.0.21
    2022-03-14 22:20:12.673  - info: admin.0 (8144) requesting all states
    2022-03-14 22:20:12.724  - info: admin.0 (8144) requesting all objects
    2022-03-14 22:20:24.026  - info: vis.0 (8186) starting. Version 1.4.5 in /opt/iobroker/node_modules/iobroker.vis, node: v12.22.5, js-controller: 4.0.21
    2022-03-14 22:20:24.712  - info: discovery.0 (8165) starting. Version 2.7.5 in /opt/iobroker/node_modules/iobroker.discovery, node: v12.22.5, js-controller: 4.0.21
    2022-03-14 22:20:24.919  - info: admin.0 (8144) received all objects
    2022-03-14 22:20:25.310  - error: vis.0 (8186) No license found for vis. Please get one on https://iobroker.net !
    2022-03-14 22:20:31.854  - info: vis.0 (8186) Terminated (NO_ERROR): Without reason
    2022-03-14 22:20:35.340  - info: host.smartmeter instance system.adapter.vis.0 terminated while should be started once
    2022-03-14 22:20:35.867  - warn: admin.0 (8144) Cannot update rating: timeout of 15000ms exceeded
    2022-03-14 22:20:36.088  - info: admin.0 (8144) Request actual repository...
    2022-03-14 22:20:36.757  - info: admin.0 (8144) http server listening on port 8081
    2022-03-14 22:20:37.041  - info: backitup.0 (8172) starting. Version 2.3.3 in /opt/iobroker/node_modules/iobroker.backitup, node: v12.22.5, js-controller: 4.0.21
    2022-03-14 22:20:36.778  - info: admin.0 (8144) Use link "http://localhost:8081" to configure.
    2022-03-14 22:20:38.703  - info: backitup.0 (8172) [iobroker] backup was activated at 02:40 every 1 day(s)
    2022-03-14 22:20:44.538  - info: host.smartmeter Updating repository "stable" under "http://download.iobroker.net/sources-dist.json"
    2022-03-14 22:20:46.934  - info: smartmeter.0 (8158) starting. Version 3.2.1 in /opt/iobroker/node_modules/iobroker.smartmeter, node: v12.22.5, js-controller: 4.0.21
    2022-03-14 22:20:57.091  - info: web.0 (8179) starting. Version 3.4.16 in /opt/iobroker/node_modules/iobroker.web, node: v12.22.5, js-controller: 4.0.21
    2022-03-14 22:20:59.132  - info: smartmeter.0 (8158) Received 7 values, 7 updated
    2022-03-14 22:20:59.202  - info: smartmeter.0 (8158) Received 7 values, 6 updated
    2022-03-14 22:21:01.009  - info: admin.0 (8144) Repository received successfully.
    2022-03-14 22:21:02.354  - info: web.0 (8179) socket.io server listening on port 8082
    2022-03-14 22:21:02.479  - info: web.0 (8179) http server listening on port 8082
    2022-03-14 22:21:03.457  - warn: web.0 (8179) State "web.0.info.connected" has no existing object, this might lead to an error in future versions
    2022-03-14 22:21:03.810  - info: smartmeter.0 (8158) Received 7 values, 3 updated
    2022-03-14 22:21:07.939  - error: admin.0 (8144) error
    2022-03-14 22:21:10.473  - info: smartmeter.0 (8158) Received 7 values, 3 updated
    2022-03-14 22:21:17.032  - info: smartmeter.0 (8158) Received 7 values, 3 updated
    2022-03-14 22:21:23.510  - info: smartmeter.0 (8158) Received 7 values, 3 updated
    2022-03-14 22:21:29.547  - info: smartmeter.0 (8158) Received 7 values, 3 updated
    2022-03-14 22:21:36.075  - info: smartmeter.0 (8158) Received 7 values, 3 updated
    2022-03-14 22:21:50.985  - info: smartmeter.0 (8158) Received 7 values, 3 updated
    2022-03-14 22:21:51.025  - info: smartmeter.0 (8158) Received 7 values, 3 updated
    2022-03-14 22:21:56.413  - info: smartmeter.0 (8158) Received 7 values, 3 updated
    2022-03-14 22:22:04.160  - info: smartmeter.0 (8158) Received 7 values, 3 updated
    2022-03-14 22:22:09.494  - info: smartmeter.0 (8158) Received 7 values, 3 updated
    2022-03-14 22:22:16.212  - info: smartmeter.0 (8158) Received 7 values, 3 updated
    2022-03-14 22:22:22.962  - info: smartmeter.0 (8158) Received 7 values, 3 updated
    2022-03-14 22:22:29.691  - info: smartmeter.0 (8158) Received 7 values, 3 updated
    2022-03-14 22:22:36.115  - info: smartmeter.0 (8158) Received 7 values, 3 updated
    2022-03-14 22:22:42.737  - info: smartmeter.0 (8158) Received 7 values, 3 updated
    2022-03-14 22:22:49.576  - info: smartmeter.0 (8158) Received 7 values, 3 updated
    2022-03-14 22:22:56.128  - info: smartmeter.0 (8158) Received 7 values, 3 updated
    2022-03-14 22:23:02.653  - info: smartmeter.0 (8158) Received 7 values, 3 updated
    2022-03-14 22:23:09.280  - info: smartmeter.0 (8158) Received 7 values, 3 updated
    2022-03-14 22:23:15.960  - info: smartmeter.0 (8158) Received 7 values, 3 updated
    2022-03-14 22:23:22.637  - info: smartmeter.0 (8158) Received 7 values, 3 updated
    2022-03-14 22:23:29.342  - info: smartmeter.0 (8158) Received 7 values, 3 updated
    2022-03-14 22:23:35.808  - info: smartmeter.0 (8158) Received 7 values, 3 updated
    2022-03-14 22:23:42.587  - info: smartmeter.0 (8158) Received 7 values, 3 updated
    2022-03-14 22:23:49.255  - info: smartmeter.0 (8158) Received 7 values, 3 updated
    2022-03-14 22:23:56.520  - info: smartmeter.0 (8158) Received 7 values, 3 updated
    2022-03-14 22:24:02.780  - info: smartmeter.0 (8158) Received 7 values, 3 updated
    2022-03-14 22:24:09.375  - info: smartmeter.0 (8158) Received 7 values, 3 updated
    2022-03-14 22:24:18.263  - info: smartmeter.0 (8158) Received 7 values, 3 updated
    2022-03-14 22:24:22.919  - info: smartmeter.0 (8158) Received 7 values, 3 updated
    micros02@smartmeter:~ $
    • E Emi 0
      @mickym
      ja, gibt es:
      mickymM Offline
      mickymM Offline
      mickym
      @emi-0 Ja das ist der Mist, mit dem HTTPS und den Zertifikaten - den Du angehakt hattest.
      Lösche doch einfach die Web Instanz und installiere diese neu und ändere nichts an den Einstellungen.
      Wenn Du noch auf den Admin kommst.
      Wenn nicht dann löschst Du die instanz:
      iob del web.0
      dann installierst Du die Instanz neu:
      iob add web: 0
      E 1 Antwort Letzte Antwort
      • wendy2702W Online
        wendy2702W Online
        Wie sehen deine Socket.io Einstellungen aus?
        • mickymM mickym
          iob del web.0
          iob add web: 0
          Emi 0
          @mickym said in web.0 läuft nicht:
          iob add web: 0
          Geht nicht, immer noch gelbes Dreieck aber nur 1 Warnung:
          2022-03-14 22:40:12.910  - info: web.0 (8379) http server listening on port 8082
          2022-03-14 22:40:13.655  - info: smartmeter.0 (8158) Received 7 values, 3 updated
          2022-03-14 22:40:13.908  - warn: web.0 (8379) State "web.0.info.connected" has no existing object, this might lead to an error in future versions
          2022-03-14 22:40:18.969  - info: smartmeter.0 (8158) Received 7 values, 3 updated
          • wendy2702W wendy2702
            Emi 0
            @wendy2702
            wo finde ich die?
            • E Emi 0
              @wendy2702
              wo finde ich die?
              wendy2702W Online
              wendy2702W Online
              @emi-0 Unter Instanzen den Socket.io auswählen und dann auf den Schraubenschlüssel
                Emi 0
                @wendy2702
                gibt es bei mir nicht:
                • E Emi 0
                  @wendy2702
                  @emi-0 sagte: gibt es bei mir nicht:
                  Muss es auch nicht. Der Web-Adapter hat seine eigene socket.io.
                    Emi 0
                    wie komme da ran?
                    • E Emi 0
                      wie komme da ran?
                      @emi-0 sagte: wie komme da ran?
                      Gar nicht, ist auch nicht nötig.
                        Emi 0
                        was kann ich jetzt tun?
                        • wendy2702W Online
                          wendy2702W Online
                          Du musst da nicht dran kommen. Wäre nur interessant gewesen wenn er installiert wäre.
                          Was kommt bei
                          iob list instances
                          und hast du schon ein
                          iob upload all
                          Probiert?
                          • mickymM Offline
                            mickymM Offline
                            mickym
                            Meines Erachtens liegt der ganze Mist an dem HTTPS anhaken und den Zertifikaten. Am Besten den Adapter nicht nur die Instanz komplett löschen - auch schauen, dass die Objekte weg sind und dann neu installieren.
                            • E Emi 0
                              @emi-0 sagte: was kann ich jetzt tun?
                              Bei so hartnäckiger Verweigerung würde ich
                              • Instanz web.0 löschen
                              • Adapter web löschen
                              • ioBroker neu starten
                              • Adapter web installieren oder Adapter flot installieren (web sollte automatisch mit installiert werden)
                              • wendy2702W Online
                                wendy2702W Online
                                Mal hier lesen:
                                https://github.com/ioBroker/ioBroker.web/issues/184
                                Wenn alles funktioniert ist das mehr oder weniger „kosmetisch“ und in 4.1.3 gelöst
                                  Was kommt bei
                                  iob list instances
                                  iob upload all
                                  Probiert?
                                  Emi 0
                                  @wendy2702
                                  micros02@smartmeter:~ $ iob list instances
                                  + system.adapter.admin.0                  : admin                 : smartmeter                               -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                                  + system.adapter.backitup.0               : backitup              : smartmeter                               -  enabled
                                  + system.adapter.discovery.0              : discovery             : smartmeter                               -  enabled
                                  + system.adapter.history.0                : history               : smartmeter                               -  enabled
                                  + system.adapter.smartmeter.0             : smartmeter            : smartmeter                               -  enabled
                                  + system.adapter.web.0                    : web                   : smartmeter                               -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
                                  + instance is alive
                                  paul53P wendy2702W 2 Antworten Letzte Antwort
                                  • E Emi 0
                                    @wendy2702
                                    + instance is alive
                                    @emi-0
                                    Sieht so aus, als ob web.0 läuft. Installiere mal den Adapter flot.
                                    • E Emi 0
                                      @wendy2702
                                      + instance is alive
                                      wendy2702W Online
                                      wendy2702W Online
                                      @emi-0 sagte in web.0 läuft nicht:
                                      @wendy2702
                                      + instance is alive
                                      Dann passt wohl der verlinkte GitHub Eintrag da du genau diese Version mit dem Fehler verwendest, kein VIS oder ähnliches installiert ist
                                      info: web.0 (7752) starting. Version 3.4.16
                                        Emi 0
                                        nein läuft nicht:
                                        Ich werde morgen Deine Vorschläge durchführen.
                                        Dank erstmal ...
                                        • E Emi 0
                                          nein läuft nicht:
                                          Dank erstmal ...
                                          @emi-0 sagte: nein läuft nicht:
                                          Er hat keinen Client (flot / vis).
