  4. Test Adapter homeconnect (BSH Home-Connect) v0.0.x
    6.4k
bshbsh home connecthome connecthomeconnect adapter
1.4k Beiträge 202 Kommentatoren 688.9k Aufrufe 153 Beobachtet
  • B biker1602
    @sigi234
    Gibt es schon eine Lösung für die Fehlermeldung die bei mir stündlich kommt?
    Oder liegt das am Home Connect selber?
    tombox
    #697
    @biker1602 Home connect aber einfach neu installieren via github sollte es erstmal weg sein
    • Merlin123M Offline
      Merlin123M Offline
      Merlin123
      #698
      Hab seit ein paar Tagen das Problem, dass der Adapter aussteigt und keine Werte mehr liefert.
      Hab den auch neu installiert, leider ohne Besserung (v0.0.37)
      Im Log steht dann
      homeconnect.0
      2022-02-20 16:16:24.362	info	BOSCH-WAYH2842-68A40E2AA61D: The rate limit "10 successive error calls in 10 minutes" was reached. Requests are blocked during the remaining period of 569 seconds.
      homeconnect.0
      2022-02-20 16:16:21.360	info	BOSCH-WAYH2842-68A40E2AA61D: The rate limit "10 successive error calls in 10 minutes" was reached. Requests are blocked during the remaining period of 572 seconds.
      homeconnect.0
      2022-02-20 16:16:16.888	info	BOSCH-WTYH7701-68A40E2F2657: The rate limit "10 successive error calls in 10 minutes" was reached. Requests are blocked during the remaining period of 577 seconds.
      homeconnect.0
      2022-02-20 16:16:13.860	info	BOSCH-WTYH7701-68A40E2F2657: The rate limit "10 successive error calls in 10 minutes" was reached. Requests are blocked during the remaining period of 580 seconds.
      homeconnect.0
      2022-02-20 16:16:10.566	info	BOSCH-WTYH7701-68A40E2F2657: The rate limit "10 successive error calls in 10 minutes" was reached. Requests are blocked during the remaining period of 583 seconds.
      homeconnect.0
      2022-02-20 16:16:09.059	info	BOSCH-WTYH7701-68A40E2F2657: The rate limit "10 successive error calls in 10 minutes" was reached. Requests are blocked during the remaining period of 585 seconds.
      homeconnect.0
      2022-02-20 16:16:07.575	info	BOSCH-WTYH7701-68A40E2F2657: Program currently not available
      homeconnect.0
      2022-02-20 16:16:06.070	info	BOSCH-WTYH7701-68A40E2F2657: Program currently not available
      homeconnect.0
      2022-02-20 16:16:04.577	info	BOSCH-WTYH7701-68A40E2F2657: Program currently not available
      homeconnect.0
      2022-02-20 16:16:03.068	info	BOSCH-WTYH7701-68A40E2F2657: Program currently not available
      homeconnect.0
      2022-02-20 16:16:01.569	info	BOSCH-WTYH7701-68A40E2F2657: Program currently not available
      homeconnect.0
      2022-02-20 16:16:00.064	info	BOSCH-WTYH7701-68A40E2F2657: Program currently not available
      homeconnect.0
      2022-02-20 16:15:58.564	info	BOSCH-WTYH7701-68A40E2F2657: Program currently not available
      homeconnect.0
      2022-02-20 16:15:57.053	info	BOSCH-WTYH7701-68A40E2F2657: Program currently not available
      homeconnect.0
      2022-02-20 16:15:55.552	info	BOSCH-WTYH7701-68A40E2F2657: Program currently not available
      homeconnect.0
      2022-02-20 16:15:54.067	info	BOSCH-WTYH7701-68A40E2F2657: Program currently not available
      Beta-Tester
      • Merlin123M Merlin123
        Im Log steht dann
        homeconnect.0
        homeconnect.0
        homeconnect.0
        homeconnect.0
        homeconnect.0
        homeconnect.0
        homeconnect.0
        homeconnect.0
        homeconnect.0
        homeconnect.0
        homeconnect.0
        homeconnect.0
        homeconnect.0
        homeconnect.0
        homeconnect.0
        homeconnect.0
        Amokd0c
        #699
        @merlin123 sagte in Test Adapter homeconnect (BSH Home-Connect) v0.0.x:
        nicht gerade den Log, aber bei mir liefert die WM und der TR auch keine Daten mehr...
        • A Amokd0c
          tombox
          #700
          @amokd0c Bräuchte längere Logs oder logs im debug mode auch per mail tombox2020@gmail.com
          A 2 Antworten Letzte Antwort
          • T tombox
            Amokd0c
            #701
            @tombox
            Im Moment geht es wieder. Danke für dein Angebot!
            Habe die Geräte WM und TR angeschaltet und verbinden lassen. Dann den Adapter neu gestartet. Dann wurden adhoc die Datenpunkte wieder aktualisiert und laufen bis dato.
            • T tombox
              Amokd0c
              schrieb am zuletzt editiert von Amokd0c
              #702
              @tombox
              @Merlin123
              Guten Morgen!
              Also irgendwas stimmt hier doch nicht.
              Habe bis dato den Adapter gelöscht, neue ID erzeugt. Das ganze Setup eben neu gemacht.
              Aber der Adapter holt nicht IMMER die aktuellen Werte ab.
              Wenn ich den Adapter allerdings neu starte, dann holt er sie meistens ab.
              Gerade aktuell ist es so.
              In der Homeconnect APP sind die Datenpunkte aktuell.
              Hier mal der Log von heute morgen, nachdem ich den Adapter neu gestartet hab.
              Textdokument (neu).txt
              Aktuell läuft die Waschmaschine im extremly Kurzprogramm.
              Ich weiß jetzt aktuell nicht wie es besser beschreiben kann, bzw. mehr Logs anhänge. Der Adpater ist grün, und ist m.E. korrekt eingerichtet.
              Manchmal gehts, meistens aber nicht.
              Besten Dank!
              Amokd0c
              arteckA T 2 Antworten Letzte Antwort
              • A Amokd0c
                @tombox
                @Merlin123
                Guten Morgen!
                Besten Dank!
                Amokd0c
                arteckA Offline
                arteckA Offline
                arteck
                #703
                @amokd0c hab ich auch .. öffters mal seid neustem.. da sich bei uns nix geändert hat .. würde ich mal behaupten die gegenseite macht schmu.. zur not starte den adapter alle stunde neu
                A R 3 Antworten Letzte Antwort
                • arteckA arteck
                  Amokd0c
                  #704
                  @arteck
                  Dank dir fürs Feedback!
                  • arteckA arteck
                    Ritschy2000
                    #705
                    @arteck kann ich auch bestätigen. Allerdings ist bei mir nur bei einem Siemens Trockner.
                    Spülmaschine und Backofen funktionieren.
                    Der Siemens Trockner hat ja auch die Eigenart, dass er keinen richtigen Standby hat und
                    komplett offline geht, wenn man ihn ausschaltet.
                    Ist dies bei den Waschmaschinen auch so?
                    Gibt es Erfahrungen, ob es bei einem stündlichen Adapter-Neustart zu Problemen mit
                    zu vielen Zugriffen auf den Server kommt?
                    I 1 Antwort Letzte Antwort
                    • A Amokd0c
                      @tombox
                      @Merlin123
                      Guten Morgen!
                      Besten Dank!
                      Amokd0c
                      tombox
                      #706
                      @amokd0c
                      Am Adapter gab es keine Anpassung.
                      Es ist auch so das der Adapter sich subscribed und auf Events von der API wartet. Es gibt also keine Aktualisierungsrate.
                      Beim initialen subscriben gibt es dann natürlich die aktuelle Daten.
                      Warum die Daten nicht mehr so oft aktualisiert werden ist eine Frage an Homeconnect API
                      https://developer.home-connect.com/support/contact
                      • R Ritschy2000
                        I Offline
                        I Offline
                        IoBreaker
                        #707
                        @ritschy2000 sagte in Test Adapter homeconnect (BSH Home-Connect) v0.0.x:
                        Ja, ist zumindest bei meiner HC-fähigen Waschmaschine genauso. (Model BOSCH WAYH2891)
                        • T tombox
                          @amokd0c
                          Amokd0c
                          #708
                          @tombox
                          Ja, ich glaube auch nicht das es am Adapter liegt.
                          Hab über deinen Link den Support mal angeschrieben. Hoffe es hat geklappt, weil ich ständig nach dem absenden die Meldung bekommen hab
                          "The form has become outdated. Press the back button, copy any unsaved work in the form, and then reload the page"
                          Ggf. kann jemand anderes das nochmal versuchen über den Link ne Anfrage zu senden? Keine Ahnung ob meine jetzt durch ist.
                          Dear Support!
                          Since the last 3 weeks, I´ve got several problems to actualize the datapoints in IO Broker.
                          Has something changed in this process?
                          If I restart the Homeconnect Adapter it will fetch the actual status of my washer, dryer or coffeemachine, but after a while, the adapter will not get the actual status.
                          The HomeConnect App works properly.
                          Thanks for your reply.
                          Johannes
                          • H Online
                            H Online
                            holgerwolf
                            #709
                            Ich habe auch nur das Problem mit der Bosch Waschmaschine: BOSCH-WAV28G40. Da werden auch die Daten nicht immer alleine aktualisiert. Bei den Siemens Geräte (Spüler, Trockner) passiert das nicht.
                            • arteckA arteck
                              Ritschy2000
                              #710
                              @arteck den Adapter jede Stunde neu starten ist übrigens keine gute Idee :)
                              nach knapp 12 Stunden hatte ich die 1000 Daten, welche pro Tag maximal sind abgerufen und war 24 Stunden gesperrt. :(
                              • R Ritschy2000
                                arteckA Offline
                                arteckA Offline
                                arteck
                                #711
                                @ritschy2000 sollst ja auc nicht alle 5 min neu starten
                                ich hab alle 6 stunden bei mir
                                • arteckA arteck
                                  joerg1979
                                  #712
                                  Habe auch seit paar Wochen das Problem, dass der Adapter keine Werte liefert.
                                  Heute ist mir aufgefallen, wenn der Wäschetrockner aus ist, liefert der Adapter erst nach einem Neustart die Werte.
                                  Danach läuft der Adapter ohne Probleme, bis der Wäschetrockner aus- und wieder eingeschaltet wird.
                                  Ich habe parallel den Adapter von Openhab installiert und konfiguriert. Dort werden die Werte dauerhaft geliefert und richtig. Auch nachdem aus- und wieder einschalten.
                                  Ansonsten finde ich den Adapter echt Klasse.
                                  Was mir noch fehlt sind folgende Inhalte:
                                  • wird der Wäschetrockner abgeschaltet, sollte der Powerstatus auf Off gehen
                                  • Die Restdauer bleibt bei 60 Sekunden stehen. Bei Openhab geht diese tatsächlich auch auf 0 Sekunden
                                  Viele Grüße
                                  Jörg
                                  • J joerg1979
                                    Viele Grüße
                                    Jörg
                                    arteckA Offline
                                    arteckA Offline
                                    arteck
                                    #713
                                    @joerg1979 je mit den Problemen kämpfe ich seid anfang an..
                                    • arteckA arteck
                                      joerg1979
                                      #714
                                      @arteck said in Test Adapter homeconnect (BSH Home-Connect) v0.0.x:
                                      Was halt auffällig ist, dass es in Openhab einfach läuft... Gerade nochmals getestet.
                                      Somit tippe ich auf den Adapter...
                                      • J joerg1979
                                        tombox
                                        #715
                                        @joerg1979 Ich schaue mir mal an was man bei der Verbindung verbesser kann
                                        nik82N 1 Antwort Letzte Antwort
                                        • T tombox
                                          nik82N Offline
                                          nik82N Offline
                                          nik82
                                          #716
                                          brauche auch einen neuen Trockner und bin gerade am hin und herüberlegen welche Adapteranbindung besser ist:
                                          Home Connect oder LG ThingQ?
                                          Habe diesen Trockner im Auge: Bosch WTX87KX0
                                          Hat den zufällig jemand am laufen? :-)
