  4. Test Adapter homeconnect (BSH Home-Connect) v0.0.x
    6.4k
bshbsh home connecthome connecthomeconnect adapter
1.4k Beiträge 202 Kommentatoren 688.9k Aufrufe 153 Beobachtet
  • Merlin123M Merlin123
    Hab seit ein paar Tagen das Problem, dass der Adapter aussteigt und keine Werte mehr liefert.
    Hab den auch neu installiert, leider ohne Besserung (v0.0.37)
    Im Log steht dann
    homeconnect.0
    2022-02-20 16:16:24.362	info	BOSCH-WAYH2842-68A40E2AA61D: The rate limit "10 successive error calls in 10 minutes" was reached. Requests are blocked during the remaining period of 569 seconds.
    homeconnect.0
    2022-02-20 16:16:21.360	info	BOSCH-WAYH2842-68A40E2AA61D: The rate limit "10 successive error calls in 10 minutes" was reached. Requests are blocked during the remaining period of 572 seconds.
    homeconnect.0
    2022-02-20 16:16:16.888	info	BOSCH-WTYH7701-68A40E2F2657: The rate limit "10 successive error calls in 10 minutes" was reached. Requests are blocked during the remaining period of 577 seconds.
    homeconnect.0
    2022-02-20 16:16:13.860	info	BOSCH-WTYH7701-68A40E2F2657: The rate limit "10 successive error calls in 10 minutes" was reached. Requests are blocked during the remaining period of 580 seconds.
    homeconnect.0
    2022-02-20 16:16:10.566	info	BOSCH-WTYH7701-68A40E2F2657: The rate limit "10 successive error calls in 10 minutes" was reached. Requests are blocked during the remaining period of 583 seconds.
    homeconnect.0
    2022-02-20 16:16:09.059	info	BOSCH-WTYH7701-68A40E2F2657: The rate limit "10 successive error calls in 10 minutes" was reached. Requests are blocked during the remaining period of 585 seconds.
    homeconnect.0
    2022-02-20 16:16:07.575	info	BOSCH-WTYH7701-68A40E2F2657: Program currently not available
    homeconnect.0
    2022-02-20 16:16:06.070	info	BOSCH-WTYH7701-68A40E2F2657: Program currently not available
    homeconnect.0
    2022-02-20 16:16:04.577	info	BOSCH-WTYH7701-68A40E2F2657: Program currently not available
    homeconnect.0
    2022-02-20 16:16:03.068	info	BOSCH-WTYH7701-68A40E2F2657: Program currently not available
    homeconnect.0
    2022-02-20 16:16:01.569	info	BOSCH-WTYH7701-68A40E2F2657: Program currently not available
    homeconnect.0
    2022-02-20 16:16:00.064	info	BOSCH-WTYH7701-68A40E2F2657: Program currently not available
    homeconnect.0
    2022-02-20 16:15:58.564	info	BOSCH-WTYH7701-68A40E2F2657: Program currently not available
    homeconnect.0
    2022-02-20 16:15:57.053	info	BOSCH-WTYH7701-68A40E2F2657: Program currently not available
    homeconnect.0
    2022-02-20 16:15:55.552	info	BOSCH-WTYH7701-68A40E2F2657: Program currently not available
    homeconnect.0
    2022-02-20 16:15:54.067	info	BOSCH-WTYH7701-68A40E2F2657: Program currently not available
    Amokd0c
    #699
    @merlin123 sagte in Test Adapter homeconnect (BSH Home-Connect) v0.0.x:
    nicht gerade den Log, aber bei mir liefert die WM und der TR auch keine Daten mehr...
    • A Amokd0c
      tombox
      #700
      @amokd0c Bräuchte längere Logs oder logs im debug mode auch per mail tombox2020@gmail.com
      A 2 Antworten Letzte Antwort
      • T tombox
        Amokd0c
        #701
        @tombox
        Im Moment geht es wieder. Danke für dein Angebot!
        Habe die Geräte WM und TR angeschaltet und verbinden lassen. Dann den Adapter neu gestartet. Dann wurden adhoc die Datenpunkte wieder aktualisiert und laufen bis dato.
        • T tombox
          Amokd0c
          schrieb am zuletzt editiert von Amokd0c
          #702
          @tombox
          @Merlin123
          Guten Morgen!
          Also irgendwas stimmt hier doch nicht.
          Habe bis dato den Adapter gelöscht, neue ID erzeugt. Das ganze Setup eben neu gemacht.
          Aber der Adapter holt nicht IMMER die aktuellen Werte ab.
          Wenn ich den Adapter allerdings neu starte, dann holt er sie meistens ab.
          Gerade aktuell ist es so.
          In der Homeconnect APP sind die Datenpunkte aktuell.
          Hier mal der Log von heute morgen, nachdem ich den Adapter neu gestartet hab.
          Textdokument (neu).txt
          Aktuell läuft die Waschmaschine im extremly Kurzprogramm.
          Ich weiß jetzt aktuell nicht wie es besser beschreiben kann, bzw. mehr Logs anhänge. Der Adpater ist grün, und ist m.E. korrekt eingerichtet.
          Manchmal gehts, meistens aber nicht.
          Besten Dank!
          Amokd0c
          arteckA T 2 Antworten Letzte Antwort
          • A Amokd0c
            @tombox
            @Merlin123
            Guten Morgen!
            Besten Dank!
            Amokd0c
            arteckA Offline
            arteckA Offline
            arteck
            #703
            @amokd0c hab ich auch .. öffters mal seid neustem.. da sich bei uns nix geändert hat .. würde ich mal behaupten die gegenseite macht schmu.. zur not starte den adapter alle stunde neu
            A R 3 Antworten Letzte Antwort
            • arteckA arteck
              Amokd0c
              #704
              @arteck
              Dank dir fürs Feedback!
              • arteckA arteck
                Ritschy2000
                #705
                @arteck kann ich auch bestätigen. Allerdings ist bei mir nur bei einem Siemens Trockner.
                Spülmaschine und Backofen funktionieren.
                Der Siemens Trockner hat ja auch die Eigenart, dass er keinen richtigen Standby hat und
                komplett offline geht, wenn man ihn ausschaltet.
                Ist dies bei den Waschmaschinen auch so?
                Gibt es Erfahrungen, ob es bei einem stündlichen Adapter-Neustart zu Problemen mit
                zu vielen Zugriffen auf den Server kommt?
                I 1 Antwort Letzte Antwort
                • A Amokd0c
                  @tombox
                  @Merlin123
                  Guten Morgen!
                  Besten Dank!
                  Amokd0c
                  tombox
                  #706
                  @amokd0c
                  Am Adapter gab es keine Anpassung.
                  Es ist auch so das der Adapter sich subscribed und auf Events von der API wartet. Es gibt also keine Aktualisierungsrate.
                  Beim initialen subscriben gibt es dann natürlich die aktuelle Daten.
                  Warum die Daten nicht mehr so oft aktualisiert werden ist eine Frage an Homeconnect API
                  https://developer.home-connect.com/support/contact
                  • R Ritschy2000
                    I Offline
                    I Offline
                    IoBreaker
                    #707
                    @ritschy2000 sagte in Test Adapter homeconnect (BSH Home-Connect) v0.0.x:
                    Ja, ist zumindest bei meiner HC-fähigen Waschmaschine genauso. (Model BOSCH WAYH2891)
                    • T tombox
                      @amokd0c
                      Amokd0c
                      #708
                      @tombox
                      Ja, ich glaube auch nicht das es am Adapter liegt.
                      Hab über deinen Link den Support mal angeschrieben. Hoffe es hat geklappt, weil ich ständig nach dem absenden die Meldung bekommen hab
                      "The form has become outdated. Press the back button, copy any unsaved work in the form, and then reload the page"
                      Ggf. kann jemand anderes das nochmal versuchen über den Link ne Anfrage zu senden? Keine Ahnung ob meine jetzt durch ist.
                      Dear Support!
                      Since the last 3 weeks, I´ve got several problems to actualize the datapoints in IO Broker.
                      Has something changed in this process?
                      If I restart the Homeconnect Adapter it will fetch the actual status of my washer, dryer or coffeemachine, but after a while, the adapter will not get the actual status.
                      The HomeConnect App works properly.
                      Thanks for your reply.
                      Johannes
                      • H Online
                        H Online
                        holgerwolf
                        #709
                        Ich habe auch nur das Problem mit der Bosch Waschmaschine: BOSCH-WAV28G40. Da werden auch die Daten nicht immer alleine aktualisiert. Bei den Siemens Geräte (Spüler, Trockner) passiert das nicht.
                        • arteckA arteck
                          Ritschy2000
                          #710
                          @arteck den Adapter jede Stunde neu starten ist übrigens keine gute Idee :)
                          nach knapp 12 Stunden hatte ich die 1000 Daten, welche pro Tag maximal sind abgerufen und war 24 Stunden gesperrt. :(
                          • R Ritschy2000
                            arteckA Offline
                            arteckA Offline
                            arteck
                            #711
                            @ritschy2000 sollst ja auc nicht alle 5 min neu starten
                            ich hab alle 6 stunden bei mir
                            • arteckA arteck
                              joerg1979
                              #712
                              Habe auch seit paar Wochen das Problem, dass der Adapter keine Werte liefert.
                              Heute ist mir aufgefallen, wenn der Wäschetrockner aus ist, liefert der Adapter erst nach einem Neustart die Werte.
                              Danach läuft der Adapter ohne Probleme, bis der Wäschetrockner aus- und wieder eingeschaltet wird.
                              Ich habe parallel den Adapter von Openhab installiert und konfiguriert. Dort werden die Werte dauerhaft geliefert und richtig. Auch nachdem aus- und wieder einschalten.
                              Ansonsten finde ich den Adapter echt Klasse.
                              Was mir noch fehlt sind folgende Inhalte:
                              • wird der Wäschetrockner abgeschaltet, sollte der Powerstatus auf Off gehen
                              • Die Restdauer bleibt bei 60 Sekunden stehen. Bei Openhab geht diese tatsächlich auch auf 0 Sekunden
                              Viele Grüße
                              Jörg
                              • J joerg1979
                                Viele Grüße
                                Jörg
                                arteckA Offline
                                arteckA Offline
                                arteck
                                #713
                                @joerg1979 je mit den Problemen kämpfe ich seid anfang an..
                                • arteckA arteck
                                  joerg1979
                                  #714
                                  @arteck said in Test Adapter homeconnect (BSH Home-Connect) v0.0.x:
                                  Was halt auffällig ist, dass es in Openhab einfach läuft... Gerade nochmals getestet.
                                  Somit tippe ich auf den Adapter...
                                  • J joerg1979
                                    tombox
                                    #715
                                    @joerg1979 Ich schaue mir mal an was man bei der Verbindung verbesser kann
                                    nik82N 1 Antwort Letzte Antwort
                                    • T tombox
                                      nik82N Offline
                                      nik82N Offline
                                      nik82
                                      #716
                                      brauche auch einen neuen Trockner und bin gerade am hin und herüberlegen welche Adapteranbindung besser ist:
                                      Home Connect oder LG ThingQ?
                                      Habe diesen Trockner im Auge: Bosch WTX87KX0
                                      Hat den zufällig jemand am laufen? :-)
                                      • J joerg1979
                                        Viele Grüße
                                        Jörg
                                        tombox
                                        #717
                                        @joerg1979 @arteck
                                        Also ich kann das Problem nachvollziehen das nur der Trockner kein Connect und Disconnect event liefert obwohl er in der App als online angezeigt. Das hat vorher funktionier ich frage auch mal bei BSH nach.
                                        Es scheint so wenn sich der Adapter mit einem offline gerät verbindet dass er connect und disconnect nicht mitbekommt
                                        • IK79I Offline
                                          IK79I Offline
                                          IK79
                                          schrieb am zuletzt editiert von IK79
                                          #718
                                          ich bin seit einer Woche auch stolzer Besitzer einer Bosch Waschmaschine (WAV28K43/04) und habe das gleiche Problem mit der fehlenden Aktualisierung. Stelle mich gerne als Tester zur Verfügung.
                                          Danke für eure Arbeit am Adapter (coole Sache!) und den Hinweis besser nicht jede Stunde neuzustarten, das wäre mein erster Impuls gewesen, getreu dem Motto "Did you try turning it off and on again?" ;-)
                                          iobroker im docker auf OMV, HMIP, ZWave, deConz Zigbee, BSH Home Connect, Nuki, Netatmo, Meross
