  4. Test Adapter Mihome-vacuum v3.1.6 Next Generarition
    6.6k
1.2k Beiträge 100 Kommentatoren 503.6k Aufrufe 82 Beobachtet
  • B blackeagle998
    @Meistertr @dirkhe
    ich habe von Version 3.1.1. auf Version 3.3.3 geupdatet und bekomme seit dem diverse Fehlermeldungen.
    js-controller: 4.0.15
    Admin: 5.3.1
    node: 14.19.0
    nodejs: 14.19.0
    npm: 8.3.1
    Auszüge:
    2022-03-03 00:52:50.638  - error: mihome-vacuum.0 (5038) Error when receiving map url: hX@!{\|%$?XV *1<b)Qal)n9fs+5N1R)P,%X2Fl68	%e`aI$	Pwmm'`)<XT\_,%
    ;!lT%%
    \2DHB"\B
    (]>ch!&&$3{
    M6elBXS)"6.&usJO!JW<5R\(Ec1UB5koJ3 7o7Jy*6`	_PaF7iu|T<HD.3
    ZA3E[] .:u}uad%U8$]o:Byd!4YneLH^`(p4@H.f!$RJ
    Fb.]75FWJ@+#}
    2022-03-03 00:52:50.641  - warn: mihome-vacuum.0 (5038) map error:SyntaxError: Unexpected token h in JSON at position 0
    2022-03-03 01:18:00.668  - error: host.raspi-master Caught by controller[0]: #
    2022-03-03 01:18:00.676  - error: host.raspi-master Caught by controller[0]: # Fatal error in , line 0
    2022-03-03 01:18:00.677  - error: host.raspi-master Caught by controller[0]: # Check failed: map_object.IsMap().
    2022-03-03 01:18:00.678  - error: host.raspi-master Caught by controller[0]: #
    2022-03-03 01:18:00.679  - error: host.raspi-master Caught by controller[0]: #
    2022-03-03 01:18:00.679  - error: host.raspi-master Caught by controller[0]: #FailureMessage Object: 0xf54fb9d8
    2022-03-03 01:18:00.680  - warn: host.raspi-master instance system.adapter.mihome-vacuum.0 terminated due to SIGILL
    2022-03-03 01:18:00.681  - info: host.raspi-master instance system.adapter.mihome-vacuum.0 terminated with code NaN ()
    2022-03-03 01:18:00.681  - info: host.raspi-master Restart adapter system.adapter.mihome-vacuum.0 because enabled
    2022-03-03 04:32:19.535  - error: host.raspi-master Caught by controller[0]: #
    2022-03-03 04:32:19.542  - error: host.raspi-master Caught by controller[0]: # Fatal error in , line 0
    2022-03-03 04:32:19.542  - error: host.raspi-master Caught by controller[0]: # Check failed: len > 0.
    2022-03-03 04:32:19.543  - error: host.raspi-master Caught by controller[0]: #
    2022-03-03 04:32:19.544  - error: host.raspi-master Caught by controller[0]: #FailureMessage Object: 0xff8a6fc0
    2022-03-03 04:32:19.544  - warn: host.raspi-master instance system.adapter.mihome-vacuum.0 terminated due to SIGILL
    2022-03-03 04:32:19.545  - info: host.raspi-master instance system.adapter.mihome-vacuum.0 terminated with code NaN ()
    2022-03-03 04:32:19.545  - info: host.raspi-master Restart adapter system.adapter.mihome-vacuum.0 because enabled
    2022-03-04 08:12:44.295  - debug: mihome-vacuum.0 (1947) Mappointer_updated
    2022-03-04 08:12:44.295  - debug: mihome-vacuum.0 (1947) update_Map Mimap enabled
    2022-03-04 08:12:44.296  - debug: mihome-vacuum.0 (1947) update_Map use old mapurl
    2022-03-04 08:12:44.296  - debug: mihome-vacuum.0 (1947) Message= {"id":775,"method":"get_carpet_mode"}
    2022-03-04 08:12:44.316  - debug: mihome-vacuum.0 (1947) MIIO RECIVE: {"result":[{"enable":1,"current_integral":0,"current_high":0,"current_low":0,"stall_time":0}],"id":775}
    2022-03-04 08:12:44.823  - debug: mihome-vacuum.0 (1947) 25563
    2022-03-04 08:12:45.596  - debug: host.raspi-master-Server States 127.0.0.1:60286 Redis Socket error: Error: read ECONNRESET
    2022-03-04 08:12:45.603  - debug: host.raspi-master-Server Objects 127.0.0.1:48364 Redis Socket error: Error: read ECONNRESET
    2022-03-04 08:12:45.966  - error: host.raspi-master Caught by controller[0]: corrupted double-linked list
    2022-03-04 08:12:45.971  - warn: host.raspi-master instance system.adapter.mihome-vacuum.0 terminated due to SIGABRT
    2022-03-04 08:12:45.972  - info: host.raspi-master instance system.adapter.mihome-vacuum.0 terminated with code NaN ()
    2022-03-04 08:12:45.973  - debug: host.raspi-master Reset crash count of system.adapter.mihome-vacuum.0, because non-crash exit
    2022-03-04 08:12:45.973  - info: host.raspi-master Restart adapter system.adapter.mihome-vacuum.0 because enabled
    2022-03-04 08:13:16.345  - debug: host.raspi-master added notifications configuration of system.adapter.mihome-vacuum.0
    2022-03-04 08:13:16.350  - debug: host.raspi-master startInstance mihome-vacuum.0 loglevel=debug, compact=false
    2022-03-04 08:13:16.440  - info: host.raspi-master instance system.adapter.mihome-vacuum.0 started with pid 6962
    2022-03-04 08:13:18.479  - debug: mihome-vacuum.0 (6962) Redis Objects: Use Redis connection: 0.0.0.0:9001
    2022-03-04 08:13:18.547  - debug: mihome-vacuum.0 (6962) Objects client ready ... initialize now
    2022-03-04 08:13:18.549  - debug: mihome-vacuum.0 (6962) Objects create System PubSub Client
    2022-03-04 08:13:18.551  - debug: mihome-vacuum.0 (6962) Objects create User PubSub Client
    2022-03-04 08:13:18.707  - debug: mihome-vacuum.0 (6962) Objects client initialize lua scripts
    2022-03-04 08:13:18.735  - debug: mihome-vacuum.0 (6962) Objects connected to redis: 0.0.0.0:9001
    2022-03-04 08:13:18.787  - debug: mihome-vacuum.0 (6962) Redis States: Use Redis connection: 0.0.0.0:9000
    2022-03-04 08:13:18.826  - debug: mihome-vacuum.0 (6962) States create System PubSub Client
    2022-03-04 08:13:18.827  - debug: mihome-vacuum.0 (6962) States create User PubSub Client
    2022-03-04 08:13:18.895  - debug: mihome-vacuum.0 (6962) States connected to redis: 0.0.0.0:9000
    2022-03-04 08:13:19.203  - debug: mihome-vacuum.0 (6962) Plugin sentry Initialize Plugin (enabled=true)
    2022-03-04 08:13:19.211  - info: mihome-vacuum.0 (6962) Plugin sentry Sentry Plugin disabled for this process because sending of statistic data is disabled for the system
    2022-03-04 08:13:19.489  - info: mihome-vacuum.0 (6962) starting. Version 3.3.3 in /opt/iobroker/node_modules/iobroker.mihome-vacuum, node: v14.19.0, js-controller: 4.0.15
    2022-03-04 08:13:19.580  - debug: mihome-vacuum.0 (6962) load Map creator... true
    2022-03-04 08:13:19.642  - debug: mihome-vacuum.0 (6962) Create State for deviceInfo
    2022-03-04 08:13:19.643  - debug: mihome-vacuum.0 (6962) Create State for deviceInfomac
    2022-03-04 08:13:19.645  - debug: mihome-vacuum.0 (6962) Create State for deviceInfomodel
    2022-03-04 08:13:19.646  - debug: mihome-vacuum.0 (6962) Create State for deviceInfofw_ver
    2022-03-04 08:13:19.647  - debug: mihome-vacuum.0 (6962) Create State for deviceInfowifi_signal
    2022-03-04 10:23:11.755  - debug: mihome-vacuum.0 (4214) Message= {"id":958,"method":"get_carpet_mode"}
    2022-03-04 10:23:11.792  - debug: mihome-vacuum.0 (4214) MIIO RECIVE: {"result":[{"enable":1,"current_integral":0,"current_high":0,"current_low":0,"stall_time":0}],"id":958}
    2022-03-04 10:23:11.865  - debug: mihome-vacuum.0 (4214) update_Map got new url:https://awsde0.fds.api.xiaomi.com/robomap/robomap/74488275/0?Expires=1646387591000&GalaxyAccessKeyId=xxx
    2022-03-04 10:23:11.866  - debug: mihome-vacuum.0 (4214) update_Map got new expires:1646387591
    2022-03-04 10:23:11.866  - debug: mihome-vacuum.0 (4214) update_Map got new time:1646385791
    2022-03-04 10:23:12.384  - debug: mihome-vacuum.0 (4214) 25563
    2022-03-04 10:23:13.553  - error: host.raspi-master Caught by controller[0]: munmap_chunk(): invalid pointer
    2022-03-04 10:23:13.561  - warn: host.raspi-master instance system.adapter.mihome-vacuum.0 terminated due to SIGABRT
    2022-03-04 10:23:13.562  - info: host.raspi-master instance system.adapter.mihome-vacuum.0 terminated with code NaN ()
    2022-03-04 10:23:13.563  - debug: host.raspi-master Reset crash count of system.adapter.mihome-vacuum.0, because non-crash exit
    2022-03-04 10:23:13.564  - info: host.raspi-master Restart adapter system.adapter.mihome-vacuum.0 because enabled
    2022-03-04 10:23:43.933  - debug: host.raspi-master added notifications configuration of system.adapter.mihome-vacuum.0
    2022-03-04 10:23:43.935  - debug: host.raspi-master startInstance mihome-vacuum.0 loglevel=debug, compact=false
    2022-03-04 10:23:43.995  - info: host.raspi-master instance system.adapter.mihome-vacuum.0 started with pid 18519
    2022-03-04 10:23:45.987  - debug: mihome-vacuum.0 (18519) Redis Objects: Use Redis connection: 0.0.0.0:9001
    2022-03-04 10:23:46.055  - debug: mihome-vacuum.0 (18519) Objects client ready ... initialize now
    2022-03-04 10:23:46.058  - debug: mihome-vacuum.0 (18519) Objects create System PubSub Client
    2022-03-04 10:23:46.059  - debug: mihome-vacuum.0 (18519) Objects create User PubSub Client
    2022-03-04 10:23:46.184  - debug: mihome-vacuum.0 (18519) Objects client initialize lua scripts
    2022-03-04 10:23:46.212  - debug: mihome-vacuum.0 (18519) Objects connected to redis: 0.0.0.0:9001
    2022-03-04 10:23:46.295  - debug: mihome-vacuum.0 (18519) Redis States: Use Redis connection: 0.0.0.0:9000
    2022-03-04 10:23:46.361  - debug: mihome-vacuum.0 (18519) States create System PubSub Client
    2022-03-04 10:23:46.363  - debug: mihome-vacuum.0 (18519) States create User PubSub Client
    2022-03-04 10:23:46.517  - debug: mihome-vacuum.0 (18519) States connected to redis: 0.0.0.0:9000
    2022-03-04 10:23:46.744  - debug: mihome-vacuum.0 (18519) Plugin sentry Initialize Plugin (enabled=true)
    2022-03-04 10:23:46.751  - info: mihome-vacuum.0 (18519) Plugin sentry Sentry Plugin disabled for this process because sending of statistic data is disabled for the system
    2022-03-04 10:23:47.074  - info: mihome-vacuum.0 (18519) starting. Version 3.3.3 in /opt/iobroker/node_modules/iobroker.mihome-vacuum, node: v14.19.0, js-controller: 4.0.15
    2022-03-04 10:23:47.160  - debug: mihome-vacuum.0 (18519) load Map creator... true
    2022-03-04 10:23:47.218  - debug: mihome-vacuum.0 (18519) Create State for deviceInfo
    2022-03-04 10:23:47.219  - debug: mihome-vacuum.0 (18519) Create State for deviceInfomac
    2022-03-04 10:23:47.220  - debug: mihome-vacuum.0 (18519) Create State for deviceInfomodel
    2022-03-04 10:23:47.221  - debug: mihome-vacuum.0 (18519) Create State for deviceInfofw_ver
    2022-03-04 10:23:47.223  - debug: mihome-vacuum.0 (18519) Create State for deviceInfowifi_signal
    Sobald ich den Staubsauger (Roborock S5) starte verliert der Adapter die Verbindung und geht auf rot.
    Ausprobiert habe ich bereits folgendes:
    • neue Adapter-Instanz
    • Server von Germany auf China gewechselt und zurück
    • Adapater komplett neu installiert
    • downgrade auf Version 3.1.1
    Nichts davon hat geholfen und ich komme nicht mehr weiter.
    Könnt ihr mal bitte einen Blick drauf werfen, ob ihr was erkennen könnt?
    Krys
    #788
    @blackeagle998 siehe meine Posts vorher. Ich hatte dasselbe Problem. Das Update auf Debian Bullseye hat das Problem gelöst.
      @blackeagle998 sagte in Test Adapter Mihome-vacuum v3.1.6 Next Generarition:
      nodejs: 14.19.0
      npm: 8.3.1
      Ich erkenne hier, das die npm Version nicht die 'von Haus aus' mitgelieferte ist. Schau dir deine nodejs-Installation mal an.
      blackeagle998
      #789
      Die Versionen hatte ich gestern auf den neuesten Stand gebracht, die Probleme existierten aber schon davor.
      Mein System ist ein Raspberry PI 4 mit Raspbian.
      ich bin bei weitem kein LINUX Experte, kannst du mir kurz erklären, wie ich die NodeJS Installation prüfen soll bzw. was genau?
      Danke vorab!
      • K Krys
        blackeagle998
        #790
        @krys
        Danke für die Info, habe ich tatsächlich nicht gesehen.
        Ich habe mein System, Raspberry PI 4 mit Raspbian, gestern Abend auf den neuesten Stand gebracht und danach kamen trotzdem Fehler. Daran liegt es aus meiner Sicht nicht.
        • B blackeagle998
          Danke vorab!
          #791
          Schau in meiner Signatur nach. Da steht ein Link zum entsprechenden HowTo.
            blackeagle998
            #792
            Vermutlich bin ich zu doof dafür...
            Ich habe Node + NodeJS entfernt, Reboot durchgeführt und nach deiner Anleitung NodeJS V.14 neu installiert.
            Jetzt habe ich wieder V. 14.19.0 drauf und NPM ist immer noch auf 8.3.1
            Wie bekomme ich denn NPM auf Version 6 zurück?
            • B blackeagle998
              #793
              Könnte ich dir vielleicht sagen, wenn ich den Status 'IST' aus deinem System kennen würde.
                blackeagle998
                #794
                So, NPM ist wieder auf 6.14.16, da war wohl was krum, folgender Befehl hat es gelöst:
                sudo rm /usr/local/bin/npm
                Trotzdem bleiben die Fehler des Adapters.
                  Krys
                  #795
                  @blackeagle998 mach mal nen Screenshot von putty, nachdem du dich eingeloggt hast.
                  Thomas BraunT B 2 Antworten Letzte Antwort
                  • K Krys
                    #796
                    @krys sagte in Test Adapter Mihome-vacuum v3.1.6 Next Generarition:
                    Nein, bitte keine Screenshots aus einem Terminal.
                    Den Text von dort auch als Text (in CodeTags eingebettet) hier rein kopieren.
                    • K Krys
                      blackeagle998
                      #797
                      @krys
                      Using username "pi".
                      Linux RasPImaster 5.10.63-v8+ #1496 SMP PREEMPT Wed Dec 1 15:59:46 GMT 2021 aarc                           h64
                      permitted by applicable law.
                      Last login: Fri Mar  4 18:28:57 2022 from xxx.xxx.xxx.xxx
                      pi@RasPImaster:~ $
                      • B blackeagle998
                        @krys
                        pi@RasPImaster:~ $
                        #798
                        @blackeagle998
                        System aktuell halten. Das ist ein z. B. ein alter Kernel. Aktuell dürfte da ein 5.10.92-v8+ zur Verfügung stehen.
                          @blackeagle998
                          blackeagle998
                          #799
                          Gibt es noch was anderes als "apt-get update und upgrade" was ich noch nicht kenne?
                          pi@RasPImaster:~ $ sudo apt-get update
                          OK:1 http://phoscon.de/apt/deconz buster InRelease
                          OK:2 http://raspbian.raspberrypi.org/raspbian buster InRelease
                          OK:3 http://archive.raspberrypi.org/debian buster InRelease
                          OK:4 https://deb.nodesource.com/node_14.x buster InRelease
                          OK:5 https://download.docker.com/linux/raspbian buster InRelease
                          pi@RasPImaster:~ $ sudo apt-get upgrade
                          Paketaktualisierung (Upgrade) wird berechnet... Fertig
                          0 aktualisiert, 0 neu installiert, 0 zu entfernen und 0 nicht aktualisiert.
                          pi@RasPImaster:~ $
                          • B blackeagle998
                            pi@RasPImaster:~ $
                            #800
                            @blackeagle998
                            Okay, Buster. Ich dachte du seist auf Bullseye mit 64bit unterwegs.
                            • B blackeagle998
                              @Meistertr @dirkhe
                              Admin: 5.3.1
                              node: 14.19.0
                              nodejs: 14.19.0
                              npm: 8.3.1
                              Auszüge:
                              ;!lT%%
                              \2DHB"\B
                              (]>ch!&&$3{
                              Fb.]75FWJ@+#}
                              D Nicht stören
                              D Nicht stören
                              dirkhe
                              #801
                              @blackeagle998 stell mal die map aus, ob er dann auch noch crascht.
                              Wenn du mal ein paar Beiträge zurück genst, gab es da auch schon mal Probleme, wenn die falsche canvas Bibliothek installiert war. Ich glaube das Problem tritt bei 32bit pi's auf
                                Krys
                                #802
                                @blackeagle998
                                so sah es bei mir vorher auch aus (Debian Buster). Nach dem Update auf Debian Bullseye lief alles Absturz-/Fehlerfrei auf nem Rpi4 4GB.
                                B B 2 Antworten Letzte Antwort
                                • K Krys
                                  @blackeagle998
                                  bob der 1.
                                  schrieb am zuletzt editiert von bob der 1.
                                  #803
                                  Schade das niemand Antworten mag .
                                  • K Krys
                                    @blackeagle998
                                    blackeagle998
                                    #804
                                    @krys
                                    Danke für deine Rückmeldung!
                                    Wenn ich es richtig verstanden habe geht es darum, das OS auf 64-Bit umzustellen, richtig?
                                    Dafür fehlt mir momentan die Zeit, zumal der Rest sauber funktioniert.
                                    Soweit ich das sehen kann, arbeitet auch ein 64-Bit Kernel (aarch64):
                                    pi@RasPImaster:~ $ uname -a
                                    Linux RasPImaster 5.10.63-v8+ #1496 SMP PREEMPT Wed Dec 1 15:59:46 GMT 2021 aarch64 GNU/Linux
                                    • B blackeagle998
                                      @krys
                                      #805
                                      @blackeagle998
                                      Ja, der Kernel ist 64bit.
                                      Aber auch der Rest? Userland? Oder nur den 64bit-Kernel ins System gedübelt? Gibt dazu ein paar schwachsinnige Anleitungen im Netz.
                                        @blackeagle998
                                        blackeagle998
                                        #806
                                        Vermutlich nur der Kernel.
                                        Die Einstellung ist in der /boot/config.txt die folgende:
                                        arm_64bit=1
                                        • B blackeagle998
                                          arm_64bit=1
                                          haselchenH Offline
                                          haselchenH Offline
                                          haselchen
                                          #807
                                          So, nun habe ich anscheinend auch ein canvas Problem.
                                          Warum weiss der liebe Gott.
                                          canvas package not installed......
                                          erscheint sekündlich im log.
                                          Adapter Version 3.3.3
                                          Hab auch schon neu - und drüber installiert.
                                          Canvas ist installiert. (sorry für den Screenshot, aus dem Container kann man leider nix kopieren)
