  4. Test Adapter Mihome-vacuum v3.1.6 Next Generarition
    6.6k
1.2k Beiträge 100 Kommentatoren 503.6k Aufrufe 82 Beobachtet
  • D dirkhe
    @wendy2702 mach mal das bestätigt weg, aber das man gar nichts im log sieht...
    wendy2702W Online
    wendy2702W Online
    #784
    @dirkhe Danke, ohne bestätigt hat er jetzt los gelegt.
    2022-03-02 21:00:55.744  - debug: mihome-vacuum.0 (11182) command: roomClean parent: 217001039930
    2022-03-02 21:00:55.747  - debug: mihome-vacuum.0 (11182) We are in onMessage:{"command":"cleanSegments","message":{"segments":[19],"channels":["mihome-vacuum.0.rooms.217001039930"]},"from":"system.adapter.mihome-vacuum.0","_id":96779554}
    2022-03-02 21:00:55.748  - debug: mihome-vacuum.0 (11182) start Cleaning: 18 MObj: {"command":"cleanSegments","message":"19","from":"system.adapter.mihome-vacuum.0","_id":96779554,"segments":[19],"channels":["mihome-vacuum.0.rooms.217001039930"]}
    2022-03-02 21:00:55.748  - info: mihome-vacuum.0 (11182) trigger cleaning segment 19
    2022-03-02 21:00:55.748  - debug: mihome-vacuum.0 (11182) Message= {"id":1317,"method":"app_segment_clean","params":[19]}
    2022-03-02 21:00:55.753  - debug: mihome-vacuum.0 (11182) command: fan_power parent: control
    2022-03-02 21:00:55.754  - debug: mihome-vacuum.0 (11182) Message= {"id":1318,"method":"set_custom_mode","params":[103]}
    2022-03-02 21:00:55.755  - debug: mihome-vacuum.0 (11182) command: water_box_mode parent: control
    2022-03-02 21:00:55.756  - debug: mihome-vacuum.0 (11182) Message= {"id":1319,"method":"set_water_box_custom_mode","params":[203]}
    2022-03-02 21:00:55.933  - debug: mihome-vacuum.0 (11182) MIIO RECIVE: {"id":1317,"result":["ok"],"exe_time":101}
    2022-03-02 21:00:56.034  - debug: mihome-vacuum.0 (11182) MIIO RECIVE: {"id":1318,"result":["ok"],"exe_time":101}
    2022-03-02 21:00:56.135  - debug: mihome-vacuum.0 (11182) MIIO RECIVE: {"id":1319,"result":["ok"],"exe_time":101}
    2022-03-02 21:01:00.261  - debug: mihome-vacuum.0 (11182) Receive <<< Helo <<< 21310020000000001e28ace40000f390ffffffffffffffffffffffffffffffff
    Ist es richtig das der DP auf "true" bleibt auch wenn der Sauger schon lange wieder in der Station steht ?
    • wendy2702W wendy2702
      @saeft_2003 Sorry, war gerade mit den Hunden.
      Hier mal ein Raum bei dem ich den roomclean auf "true" gesetzt hatte. Da ist nichts passiert.
      Jetzt gerade mal einen anderen auf "true" gesetzt:
      Im Log kommt davon nichts an:
      2022-03-02 20:32:24.081  - debug: mihome-vacuum.0 (11182) setGetStatus {"msg_ver":2,"msg_seq":493,"state":8,"battery":100,"clean_time":3090,"clean_area":40680000,"error_code":0,"map_present":true,"in_cleaning":false,"in_returning":0,"in_fresh_state":1,"lab_status":1,"water_box_status":1,"fan_power":103,"dnd_enabled":false,"map_status":3,"is_locating":0,"lock_status":0,"water_box_mode":203,"water_box_carriage_status":1,"mop_forbidden_enable":1,"adbumper_status":[0,0,0],"water_shortage_status":0,"dock_type":1,"dust_collection_status":0,"auto_dust_collection":1,"mop_mode":300,"debug_mode":0,"dock_error_status":0,"error_text":"No error"}
      2022-03-02 20:32:24.082  - debug: mihome-vacuum.0 (11182) Message= {"id":982,"method":"get_network_info"}
      2022-03-02 20:32:24.282  - debug: mihome-vacuum.0 (11182) MIIO RECIVE: {"id":982,"result":{"ssid":"WANXXXXXX","ip":"192.168.178.73","mac":"b0:4a:39:38:3e:72","bssid":"76:83:c2:9c:1c:91","rssi":-67},"exe_time":100}
      2022-03-02 20:32:24.288  - debug: mihome-vacuum.0 (11182) Message= {"id":983,"method":"get_sound_volume"}
      2022-03-02 20:32:24.584  - debug: mihome-vacuum.0 (11182) MIIO RECIVE: {"id":983,"result":[90],"exe_time":101}
      2022-03-02 20:32:24.584  - debug: mihome-vacuum.0 (11182) Message= {"id":984,"method":"get_carpet_mode"}
      2022-03-02 20:32:24.886  - debug: mihome-vacuum.0 (11182) MIIO RECIVE: {"id":984,"result":[{"enable":1,"current_integral":450,"current_high":500,"current_low":400,"stall_time":10}],"exe_time":101}
      2022-03-02 20:32:28.839  - debug: mihome-vacuum.0 (11182) Receive <<< Helo <<< 21310020000000001e28ace40000ece1ffffffffffffffffffffffffffffffff
      2022-03-02 20:32:28.839  - debug: mihome-vacuum.0 (11182) Time difference between Mihome Vacuum and ioBroker: -1646188907 sec
      2022-03-02 20:32:38.842  - debug: mihome-vacuum.0 (11182) Receive <<< Helo <<< 21310020000000001e28ace40000ecebffffffffffffffffffffffffffffffff
      2022-03-02 20:32:38.842  - debug: mihome-vacuum.0 (11182) Time difference between Mihome Vacuum and ioBroker: -1646188907 sec
      2022-03-02 20:32:44.892  - debug: mihome-vacuum.0 (11182) get params for stock Vacuum
      2022-03-02 20:32:44.892  - debug: mihome-vacuum.0 (11182) Message= {"id":985,"method":"get_status"}
      2022-03-02 20:32:45.119  - debug: mihome-vacuum.0 (11182) MIIO RECIVE: {"id":985,"result":[{"msg_ver":2,"msg_seq":494,"state":8,"battery":100,"clean_time":3090,"clean_area":40680000,"error_code":0,"map_present":1,"in_cleaning":0,"in_returning":0,"in_fresh_state":1,"lab_status":1,"water_box_status":1,"fan_power":103,"dnd_enabled":0,"map_status":3,"is_locating":0,"lock_status":0,"water_box_mode":203,"water_box_carriage_status":1,"mop_forbidden_enable":1,"adbumper_status":[0,0,0],"water_shortage_status":0,"dock_type":1,"dust_collection_status":0,"auto_dust_collection":1,"mop_mode":300,"debug_mode":0,"dock_error_status":0}],"exe_time":101}
      2022-03-02 20:32:45.119  - debug: mihome-vacuum.0 (11182) setGetStatus {"msg_ver":2,"msg_seq":494,"state":8,"battery":100,"clean_time":3090,"clean_area":40680000,"error_code":0,"map_present":true,"in_cleaning":false,"in_returning":0,"in_fresh_state":1,"lab_status":1,"water_box_status":1,"fan_power":103,"dnd_enabled":false,"map_status":3,"is_locating":0,"lock_status":0,"water_box_mode":203,"water_box_carriage_status":1,"mop_forbidden_enable":1,"adbumper_status":[0,0,0],"water_shortage_status":0,"dock_type":1,"dust_collection_status":0,"auto_dust_collection":1,"mop_mode":300,"debug_mode":0,"dock_error_status":0,"error_text":"No error"}
      2022-03-02 20:32:45.119  - debug: mihome-vacuum.0 (11182) Message= {"id":986,"method":"get_network_info"}
      2022-03-02 20:32:45.324  - debug: mihome-vacuum.0 (11182) MIIO RECIVE: {"id":986,"result":{"ssid":"WAXXXXXX","ip":"192.168.178.73","mac":"b0:4a:39:38:3e:72","bssid":"76:83:c2:9c:1c:91","rssi":-67},"exe_time":100}
      2022-03-02 20:32:45.347  - debug: mihome-vacuum.0 (11182) Message= {"id":987,"method":"get_sound_volume"}
      2022-03-02 20:32:45.621  - debug: mihome-vacuum.0 (11182) MIIO RECIVE: {"id":987,"result":[90],"exe_time":101}
      2022-03-02 20:32:45.621  - debug: mihome-vacuum.0 (11182) Message= {"id":988,"method":"get_carpet_mode"}
      2022-03-02 20:32:45.923  - debug: mihome-vacuum.0 (11182) MIIO RECIVE: {"id":988,"result":[{"enable":1,"current_integral":450,"current_high":500,"current_low":400,"stall_time":10}],"exe_time":101}
      2022-03-02 20:32:48.845  - debug: mihome-vacuum.0 (11182) Receive <<< Helo <<< 21310020000000001e28ace40000ecf5ffffffffffffffffffffffffffffffff
      2022-03-02 20:32:48.845  - debug: mihome-vacuum.0 (11182) Time difference between Mihome Vacuum and ioBroker: -1646188907 sec
      2022-03-02 20:32:58.848  - debug: mihome-vacuum.0 (11182) Receive <<< Helo <<< 21310020000000001e28ace40000ecffffffffffffffffffffffffffffffffff
      2022-03-02 20:32:58.848  - debug: mihome-vacuum.0 (11182) Time difference between Mihome Vacuum and ioBroker: -1646188907 sec
      Habt ihr diesen Time difference Eintrag auch?
      Wo könnte sonst noch das Problem liegen?
      saeft_2003
      schrieb am zuletzt editiert von saeft_2003
      #785
      @wendy2702
      Super das es geht. Ja das ist normal meine DP bleiben auch alle auf true.
        blackeagle998
        schrieb am zuletzt editiert von blackeagle998
        #786
        @Meistertr @dirkhe
        ich habe von Version 3.1.1. auf Version 3.3.3 geupdatet und bekomme seit dem diverse Fehlermeldungen.
        js-controller: 4.0.15
        Admin: 5.3.1
        node: 14.19.0
        nodejs: 14.19.0
        npm: 8.3.1
        Auszüge:
        2022-03-03 00:52:50.638  - error: mihome-vacuum.0 (5038) Error when receiving map url: hX@!{\|%$?XV *1<b)Qal)n9fs+5N1R)P,%X2Fl68	%e`aI$	Pwmm'`)<XT\_,%
        ;!lT%%
        \2DHB"\B
        (]>ch!&&$3{
        M6elBXS)"6.&usJO!JW<5R\(Ec1UB5koJ3 7o7Jy*6`	_PaF7iu|T<HD.3
        ZA3E[] .:u}uad%U8$]o:Byd!4YneLH^`(p4@H.f!$RJ
        Fb.]75FWJ@+#}
        2022-03-03 00:52:50.641  - warn: mihome-vacuum.0 (5038) map error:SyntaxError: Unexpected token h in JSON at position 0
        2022-03-03 01:18:00.668  - error: host.raspi-master Caught by controller[0]: #
        2022-03-03 01:18:00.676  - error: host.raspi-master Caught by controller[0]: # Fatal error in , line 0
        2022-03-03 01:18:00.677  - error: host.raspi-master Caught by controller[0]: # Check failed: map_object.IsMap().
        2022-03-03 01:18:00.678  - error: host.raspi-master Caught by controller[0]: #
        2022-03-03 01:18:00.679  - error: host.raspi-master Caught by controller[0]: #
        2022-03-03 01:18:00.679  - error: host.raspi-master Caught by controller[0]: #FailureMessage Object: 0xf54fb9d8
        2022-03-03 01:18:00.680  - warn: host.raspi-master instance system.adapter.mihome-vacuum.0 terminated due to SIGILL
        2022-03-03 01:18:00.681  - info: host.raspi-master instance system.adapter.mihome-vacuum.0 terminated with code NaN ()
        2022-03-03 01:18:00.681  - info: host.raspi-master Restart adapter system.adapter.mihome-vacuum.0 because enabled
        2022-03-03 04:32:19.535  - error: host.raspi-master Caught by controller[0]: #
        2022-03-03 04:32:19.542  - error: host.raspi-master Caught by controller[0]: # Fatal error in , line 0
        2022-03-03 04:32:19.542  - error: host.raspi-master Caught by controller[0]: # Check failed: len > 0.
        2022-03-03 04:32:19.543  - error: host.raspi-master Caught by controller[0]: #
        2022-03-03 04:32:19.544  - error: host.raspi-master Caught by controller[0]: #FailureMessage Object: 0xff8a6fc0
        2022-03-03 04:32:19.544  - warn: host.raspi-master instance system.adapter.mihome-vacuum.0 terminated due to SIGILL
        2022-03-03 04:32:19.545  - info: host.raspi-master instance system.adapter.mihome-vacuum.0 terminated with code NaN ()
        2022-03-03 04:32:19.545  - info: host.raspi-master Restart adapter system.adapter.mihome-vacuum.0 because enabled
        2022-03-04 08:12:44.295  - debug: mihome-vacuum.0 (1947) Mappointer_updated
        2022-03-04 08:12:44.295  - debug: mihome-vacuum.0 (1947) update_Map Mimap enabled
        2022-03-04 08:12:44.296  - debug: mihome-vacuum.0 (1947) update_Map use old mapurl
        2022-03-04 08:12:44.296  - debug: mihome-vacuum.0 (1947) Message= {"id":775,"method":"get_carpet_mode"}
        2022-03-04 08:12:44.316  - debug: mihome-vacuum.0 (1947) MIIO RECIVE: {"result":[{"enable":1,"current_integral":0,"current_high":0,"current_low":0,"stall_time":0}],"id":775}
        2022-03-04 08:12:44.823  - debug: mihome-vacuum.0 (1947) 25563
        2022-03-04 08:12:45.596  - debug: host.raspi-master-Server States 127.0.0.1:60286 Redis Socket error: Error: read ECONNRESET
        2022-03-04 08:12:45.603  - debug: host.raspi-master-Server Objects 127.0.0.1:48364 Redis Socket error: Error: read ECONNRESET
        2022-03-04 08:12:45.966  - error: host.raspi-master Caught by controller[0]: corrupted double-linked list
        2022-03-04 08:12:45.971  - warn: host.raspi-master instance system.adapter.mihome-vacuum.0 terminated due to SIGABRT
        2022-03-04 08:12:45.972  - info: host.raspi-master instance system.adapter.mihome-vacuum.0 terminated with code NaN ()
        2022-03-04 08:12:45.973  - debug: host.raspi-master Reset crash count of system.adapter.mihome-vacuum.0, because non-crash exit
        2022-03-04 08:12:45.973  - info: host.raspi-master Restart adapter system.adapter.mihome-vacuum.0 because enabled
        2022-03-04 08:13:16.345  - debug: host.raspi-master added notifications configuration of system.adapter.mihome-vacuum.0
        2022-03-04 08:13:16.350  - debug: host.raspi-master startInstance mihome-vacuum.0 loglevel=debug, compact=false
        2022-03-04 08:13:16.440  - info: host.raspi-master instance system.adapter.mihome-vacuum.0 started with pid 6962
        2022-03-04 08:13:18.479  - debug: mihome-vacuum.0 (6962) Redis Objects: Use Redis connection: 0.0.0.0:9001
        2022-03-04 08:13:18.547  - debug: mihome-vacuum.0 (6962) Objects client ready ... initialize now
        2022-03-04 08:13:18.549  - debug: mihome-vacuum.0 (6962) Objects create System PubSub Client
        2022-03-04 08:13:18.551  - debug: mihome-vacuum.0 (6962) Objects create User PubSub Client
        2022-03-04 08:13:18.707  - debug: mihome-vacuum.0 (6962) Objects client initialize lua scripts
        2022-03-04 08:13:18.735  - debug: mihome-vacuum.0 (6962) Objects connected to redis: 0.0.0.0:9001
        2022-03-04 08:13:18.787  - debug: mihome-vacuum.0 (6962) Redis States: Use Redis connection: 0.0.0.0:9000
        2022-03-04 08:13:18.826  - debug: mihome-vacuum.0 (6962) States create System PubSub Client
        2022-03-04 08:13:18.827  - debug: mihome-vacuum.0 (6962) States create User PubSub Client
        2022-03-04 08:13:18.895  - debug: mihome-vacuum.0 (6962) States connected to redis: 0.0.0.0:9000
        2022-03-04 08:13:19.203  - debug: mihome-vacuum.0 (6962) Plugin sentry Initialize Plugin (enabled=true)
        2022-03-04 08:13:19.211  - info: mihome-vacuum.0 (6962) Plugin sentry Sentry Plugin disabled for this process because sending of statistic data is disabled for the system
        2022-03-04 08:13:19.489  - info: mihome-vacuum.0 (6962) starting. Version 3.3.3 in /opt/iobroker/node_modules/iobroker.mihome-vacuum, node: v14.19.0, js-controller: 4.0.15
        2022-03-04 08:13:19.580  - debug: mihome-vacuum.0 (6962) load Map creator... true
        2022-03-04 08:13:19.642  - debug: mihome-vacuum.0 (6962) Create State for deviceInfo
        2022-03-04 08:13:19.643  - debug: mihome-vacuum.0 (6962) Create State for deviceInfomac
        2022-03-04 08:13:19.645  - debug: mihome-vacuum.0 (6962) Create State for deviceInfomodel
        2022-03-04 08:13:19.646  - debug: mihome-vacuum.0 (6962) Create State for deviceInfofw_ver
        2022-03-04 08:13:19.647  - debug: mihome-vacuum.0 (6962) Create State for deviceInfowifi_signal
        2022-03-04 10:23:11.755  - debug: mihome-vacuum.0 (4214) Message= {"id":958,"method":"get_carpet_mode"}
        2022-03-04 10:23:11.792  - debug: mihome-vacuum.0 (4214) MIIO RECIVE: {"result":[{"enable":1,"current_integral":0,"current_high":0,"current_low":0,"stall_time":0}],"id":958}
        2022-03-04 10:23:11.865  - debug: mihome-vacuum.0 (4214) update_Map got new url:https://awsde0.fds.api.xiaomi.com/robomap/robomap/74488275/0?Expires=1646387591000&GalaxyAccessKeyId=xxx
        2022-03-04 10:23:11.866  - debug: mihome-vacuum.0 (4214) update_Map got new expires:1646387591
        2022-03-04 10:23:11.866  - debug: mihome-vacuum.0 (4214) update_Map got new time:1646385791
        2022-03-04 10:23:12.384  - debug: mihome-vacuum.0 (4214) 25563
        2022-03-04 10:23:13.553  - error: host.raspi-master Caught by controller[0]: munmap_chunk(): invalid pointer
        2022-03-04 10:23:13.561  - warn: host.raspi-master instance system.adapter.mihome-vacuum.0 terminated due to SIGABRT
        2022-03-04 10:23:13.562  - info: host.raspi-master instance system.adapter.mihome-vacuum.0 terminated with code NaN ()
        2022-03-04 10:23:13.563  - debug: host.raspi-master Reset crash count of system.adapter.mihome-vacuum.0, because non-crash exit
        2022-03-04 10:23:13.564  - info: host.raspi-master Restart adapter system.adapter.mihome-vacuum.0 because enabled
        2022-03-04 10:23:43.933  - debug: host.raspi-master added notifications configuration of system.adapter.mihome-vacuum.0
        2022-03-04 10:23:43.935  - debug: host.raspi-master startInstance mihome-vacuum.0 loglevel=debug, compact=false
        2022-03-04 10:23:43.995  - info: host.raspi-master instance system.adapter.mihome-vacuum.0 started with pid 18519
        2022-03-04 10:23:45.987  - debug: mihome-vacuum.0 (18519) Redis Objects: Use Redis connection: 0.0.0.0:9001
        2022-03-04 10:23:46.055  - debug: mihome-vacuum.0 (18519) Objects client ready ... initialize now
        2022-03-04 10:23:46.058  - debug: mihome-vacuum.0 (18519) Objects create System PubSub Client
        2022-03-04 10:23:46.059  - debug: mihome-vacuum.0 (18519) Objects create User PubSub Client
        2022-03-04 10:23:46.184  - debug: mihome-vacuum.0 (18519) Objects client initialize lua scripts
        2022-03-04 10:23:46.212  - debug: mihome-vacuum.0 (18519) Objects connected to redis: 0.0.0.0:9001
        2022-03-04 10:23:46.295  - debug: mihome-vacuum.0 (18519) Redis States: Use Redis connection: 0.0.0.0:9000
        2022-03-04 10:23:46.361  - debug: mihome-vacuum.0 (18519) States create System PubSub Client
        2022-03-04 10:23:46.363  - debug: mihome-vacuum.0 (18519) States create User PubSub Client
        2022-03-04 10:23:46.517  - debug: mihome-vacuum.0 (18519) States connected to redis: 0.0.0.0:9000
        2022-03-04 10:23:46.744  - debug: mihome-vacuum.0 (18519) Plugin sentry Initialize Plugin (enabled=true)
        2022-03-04 10:23:46.751  - info: mihome-vacuum.0 (18519) Plugin sentry Sentry Plugin disabled for this process because sending of statistic data is disabled for the system
        2022-03-04 10:23:47.074  - info: mihome-vacuum.0 (18519) starting. Version 3.3.3 in /opt/iobroker/node_modules/iobroker.mihome-vacuum, node: v14.19.0, js-controller: 4.0.15
        2022-03-04 10:23:47.160  - debug: mihome-vacuum.0 (18519) load Map creator... true
        2022-03-04 10:23:47.218  - debug: mihome-vacuum.0 (18519) Create State for deviceInfo
        2022-03-04 10:23:47.219  - debug: mihome-vacuum.0 (18519) Create State for deviceInfomac
        2022-03-04 10:23:47.220  - debug: mihome-vacuum.0 (18519) Create State for deviceInfomodel
        2022-03-04 10:23:47.221  - debug: mihome-vacuum.0 (18519) Create State for deviceInfofw_ver
        2022-03-04 10:23:47.223  - debug: mihome-vacuum.0 (18519) Create State for deviceInfowifi_signal
        Sobald ich den Staubsauger (Roborock S5) starte verliert der Adapter die Verbindung und geht auf rot.
        Ausprobiert habe ich bereits folgendes:
        • neue Adapter-Instanz
        • Server von Germany auf China gewechselt und zurück
        • Adapater komplett neu installiert
        • downgrade auf Version 3.1.1
        Nichts davon hat geholfen und ich komme nicht mehr weiter.
        Könnt ihr mal bitte einen Blick drauf werfen, ob ihr was erkennen könnt?
        Thomas BraunT K D 3 Antworten Letzte Antwort
        • B blackeagle998
          @Meistertr @dirkhe
          Admin: 5.3.1
          node: 14.19.0
          nodejs: 14.19.0
          npm: 8.3.1
          Auszüge:
          ;!lT%%
          \2DHB"\B
          (]>ch!&&$3{
          Fb.]75FWJ@+#}
          #787
          @blackeagle998 sagte in Test Adapter Mihome-vacuum v3.1.6 Next Generarition:
          nodejs: 14.19.0
          npm: 8.3.1
          Ich erkenne hier, das die npm Version nicht die 'von Haus aus' mitgelieferte ist. Schau dir deine nodejs-Installation mal an.
          • B blackeagle998
            @Meistertr @dirkhe
            Admin: 5.3.1
            node: 14.19.0
            nodejs: 14.19.0
            npm: 8.3.1
            Auszüge:
            ;!lT%%
            \2DHB"\B
            (]>ch!&&$3{
            Fb.]75FWJ@+#}
            Krys
            #788
            @blackeagle998 siehe meine Posts vorher. Ich hatte dasselbe Problem. Das Update auf Debian Bullseye hat das Problem gelöst.
              nodejs: 14.19.0
              npm: 8.3.1
              blackeagle998
              #789
              Die Versionen hatte ich gestern auf den neuesten Stand gebracht, die Probleme existierten aber schon davor.
              Mein System ist ein Raspberry PI 4 mit Raspbian.
              ich bin bei weitem kein LINUX Experte, kannst du mir kurz erklären, wie ich die NodeJS Installation prüfen soll bzw. was genau?
              Danke vorab!
              • K Krys
                blackeagle998
                #790
                @krys
                Danke für die Info, habe ich tatsächlich nicht gesehen.
                Ich habe mein System, Raspberry PI 4 mit Raspbian, gestern Abend auf den neuesten Stand gebracht und danach kamen trotzdem Fehler. Daran liegt es aus meiner Sicht nicht.
                • B blackeagle998
                  Danke vorab!
                  #791
                  Schau in meiner Signatur nach. Da steht ein Link zum entsprechenden HowTo.
                    blackeagle998
                    #792
                    Vermutlich bin ich zu doof dafür...
                    Ich habe Node + NodeJS entfernt, Reboot durchgeführt und nach deiner Anleitung NodeJS V.14 neu installiert.
                    Jetzt habe ich wieder V. 14.19.0 drauf und NPM ist immer noch auf 8.3.1
                    Wie bekomme ich denn NPM auf Version 6 zurück?
                    • B blackeagle998
                      #793
                      Könnte ich dir vielleicht sagen, wenn ich den Status 'IST' aus deinem System kennen würde.
                        blackeagle998
                        #794
                        So, NPM ist wieder auf 6.14.16, da war wohl was krum, folgender Befehl hat es gelöst:
                        sudo rm /usr/local/bin/npm
                        Trotzdem bleiben die Fehler des Adapters.
                          Krys
                          #795
                          @blackeagle998 mach mal nen Screenshot von putty, nachdem du dich eingeloggt hast.
                          Thomas BraunT B 2 Antworten Letzte Antwort
                          • K Krys
                            #796
                            @krys sagte in Test Adapter Mihome-vacuum v3.1.6 Next Generarition:
                            Nein, bitte keine Screenshots aus einem Terminal.
                            Den Text von dort auch als Text (in CodeTags eingebettet) hier rein kopieren.
                            • K Krys
                              blackeagle998
                              #797
                              @krys
                              Using username "pi".
                              Linux RasPImaster 5.10.63-v8+ #1496 SMP PREEMPT Wed Dec 1 15:59:46 GMT 2021 aarc                           h64
                              permitted by applicable law.
                              Last login: Fri Mar  4 18:28:57 2022 from xxx.xxx.xxx.xxx
                              pi@RasPImaster:~ $
                              • B blackeagle998
                                @krys
                                pi@RasPImaster:~ $
                                #798
                                @blackeagle998
                                System aktuell halten. Das ist ein z. B. ein alter Kernel. Aktuell dürfte da ein 5.10.92-v8+ zur Verfügung stehen.
                                  @blackeagle998
                                  blackeagle998
                                  #799
                                  Gibt es noch was anderes als "apt-get update und upgrade" was ich noch nicht kenne?
                                  pi@RasPImaster:~ $ sudo apt-get update
                                  OK:1 http://phoscon.de/apt/deconz buster InRelease
                                  OK:2 http://raspbian.raspberrypi.org/raspbian buster InRelease
                                  OK:3 http://archive.raspberrypi.org/debian buster InRelease
                                  OK:4 https://deb.nodesource.com/node_14.x buster InRelease
                                  OK:5 https://download.docker.com/linux/raspbian buster InRelease
                                  pi@RasPImaster:~ $ sudo apt-get upgrade
                                  Paketaktualisierung (Upgrade) wird berechnet... Fertig
                                  0 aktualisiert, 0 neu installiert, 0 zu entfernen und 0 nicht aktualisiert.
                                  pi@RasPImaster:~ $
                                  • B blackeagle998
                                    pi@RasPImaster:~ $
                                    #800
                                    @blackeagle998
                                    Okay, Buster. Ich dachte du seist auf Bullseye mit 64bit unterwegs.
                                    • B blackeagle998
                                      @Meistertr @dirkhe
                                      Admin: 5.3.1
                                      node: 14.19.0
                                      nodejs: 14.19.0
                                      npm: 8.3.1
                                      Auszüge:
                                      ;!lT%%
                                      \2DHB"\B
                                      (]>ch!&&$3{
                                      Fb.]75FWJ@+#}
                                      D Nicht stören
                                      D Nicht stören
                                      dirkhe
                                      #801
                                      @blackeagle998 stell mal die map aus, ob er dann auch noch crascht.
                                      Wenn du mal ein paar Beiträge zurück genst, gab es da auch schon mal Probleme, wenn die falsche canvas Bibliothek installiert war. Ich glaube das Problem tritt bei 32bit pi's auf
                                        Krys
                                        #802
                                        @blackeagle998
                                        so sah es bei mir vorher auch aus (Debian Buster). Nach dem Update auf Debian Bullseye lief alles Absturz-/Fehlerfrei auf nem Rpi4 4GB.
                                        B B 2 Antworten Letzte Antwort
                                        • K Krys
                                          @blackeagle998
                                          bob der 1.
                                          schrieb am zuletzt editiert von bob der 1.
                                          #803
                                          Schade das niemand Antworten mag .
