  3. Einsteigerfragen
  4. IoBroker lässt kein update zu
    2.8k
    2.9k
18 Beiträge 6 Kommentatoren 1.7k Aufrufe 5 Beobachtet
  • wierer-sigiW Offline
    wierer-sigi
    versuche Gerate die Adapter im iobroker zu aktualisieren.
    Erst über die Benutzerobfläche aber auch über SSH.
    Aktuelle Versionen:
    pi@raspberrypi4:/home/iobroker/.npm/_logs $ iob update
    Used repository: stable
    hash unchanged, use cached sources
    update done
    Adapter "admin" : 5.3.1 , installed 5.2.3 [Updateable]
    Adapter "backitup" : 2.3.3 , installed 2.2.3 [Updateable]
    Adapter "bmw" : 2.5.1 , installed 2.5.1
    Adapter "discovery" : 2.7.5 , installed 2.7.3 [Updateable]
    Adapter "go-e" : 1.0.18 , installed 1.0.18
    Adapter "javascript" : 5.2.21 , installed 5.2.13 [Updateable]
    Controller "js-controller" : 4.0.15 , installed 3.3.22 [Updateable]
    Adapter "parser" : 1.0.7 , installed 1.0.7
    Adapter "rpi2" : 1.3.1 , installed 1.3.1
    Adapter "shelly" : 4.0.7 , installed 4.1.2
    Adapter "telegram" : 1.11.1 , installed 1.10.0 [Updateable]
    Adapter "whatsapp-cmb" : 0.1.6 , installed 0.1.6
    Adapter "yahka" : 0.13.1 , installed 0.13.1
    beim ausführen des: iob upgrade self
    bekomme ich folgende Fehlermeldung:
    0 verbose cli [
    0 verbose cli   '/usr/local/bin/node',
    0 verbose cli   '/usr/local/bin/npm',
    0 verbose cli   'install',
    0 verbose cli   'iobroker.js-controller@4.0.15',
    0 verbose cli   '--loglevel',
    0 verbose cli   'error',
    0 verbose cli   '--unsafe-perm',
    0 verbose cli   '--prefix',
    0 verbose cli   '/opt/iobroker'
    0 verbose cli ]
    1 info using npm@8.1.2
    2 info using node@v16.13.2
    3 timing npm:load:whichnode Completed in 0ms
    4 timing config:load:defaults Completed in 4ms
    5 timing config:load:file:/usr/local/lib/node_modules/npm/npmrc Completed in 2ms
    6 timing config:load:builtin Completed in 2ms
    7 timing config:load:cli Completed in 6ms
    8 timing config:load:env Completed in 0ms
    9 timing config:load:file:/opt/iobroker/.npmrc Completed in 3ms
    10 timing config:load:project Completed in 3ms
    11 timing config:load:file:/home/iobroker/.npmrc Completed in 1ms
    12 timing config:load:user Completed in 1ms
    13 timing config:load:file:/opt/iobroker/etc/npmrc Completed in 1ms
    14 timing config:load:global Completed in 1ms
    15 timing config:load:validate Completed in 0ms
    16 timing config:load:credentials Completed in 3ms
    17 timing config:load:setEnvs Completed in 2ms
    18 timing config:load Completed in 23ms
    19 timing npm:load:configload Completed in 24ms
    20 timing npm:load:setTitle Completed in 0ms
    21 timing npm:load:setupLog Completed in 1ms
    22 timing config:load:flatten Completed in 7ms
    23 timing npm:load:cleanupLog Completed in 6ms
    24 timing npm:load:configScope Completed in 0ms
    25 timing npm:load:projectScope Completed in 1ms
    26 timing npm:load Completed in 42ms
    27 verbose stack Error: Cannot find module 'asap'
    27 verbose stack Require stack:
    27 verbose stack - /usr/local/lib/node_modules/npm/node_modules/dezalgo/dezalgo.js
    27 verbose stack - /usr/local/lib/node_modules/npm/node_modules/readdir-scoped-modules/readdir.js
    27 verbose stack - /usr/local/lib/node_modules/npm/node_modules/@npmcli/arborist/lib/arborist/build-ideal-tree.js
    27 verbose stack - /usr/local/lib/node_modules/npm/node_modules/@npmcli/arborist/lib/arborist/index.js
    27 verbose stack - /usr/local/lib/node_modules/npm/node_modules/@npmcli/arborist/lib/index.js
    27 verbose stack - /usr/local/lib/node_modules/npm/node_modules/libnpmfund/index.js
    27 verbose stack - /usr/local/lib/node_modules/npm/lib/utils/reify-output.js
    27 verbose stack - /usr/local/lib/node_modules/npm/lib/utils/reify-finish.js
    27 verbose stack - /usr/local/lib/node_modules/npm/lib/install.js
    27 verbose stack - /usr/local/lib/node_modules/npm/lib/npm.js
    27 verbose stack - /usr/local/lib/node_modules/npm/lib/cli.js
    27 verbose stack - /usr/local/lib/node_modules/npm/bin/npm-cli.js
    27 verbose stack     at Function.Module._resolveFilename (node:internal/modules/cjs/loader:933:15)
    27 verbose stack     at Function.Module._load (node:internal/modules/cjs/loader:778:27)
    27 verbose stack     at Module.require (node:internal/modules/cjs/loader:1005:19)
    27 verbose stack     at require (node:internal/modules/cjs/helpers:102:18)
    27 verbose stack     at Object.<anonymous> (/usr/local/lib/node_modules/npm/node_modules/dezalgo/dezalgo.js:4:12)
    27 verbose stack     at Module._compile (node:internal/modules/cjs/loader:1101:14)
    27 verbose stack     at Object.Module._extensions..js (node:internal/modules/cjs/loader:1153:10)
    27 verbose stack     at Module.load (node:internal/modules/cjs/loader:981:32)
    27 verbose stack     at Function.Module._load (node:internal/modules/cjs/loader:822:12)
    28 verbose cwd /opt/iobroker
    29 verbose Linux 5.10.92-v7l+
    30 verbose argv "/usr/local/bin/node" "/usr/local/bin/npm" "install" "iobroker.js-controller@4.0.15" "--loglevel" "error">
    31 verbose node v16.13.2
    32 verbose npm  v8.1.2
    33 error code MODULE_NOT_FOUND
    Kann bis auf die Meldung: 27 verbose stack Error: Cannot find module 'asap'
    nichts finden
    Habe natürlich auch schon einen:
    Sudo apt-update
    sudo apt-upgrade
    gefahren
    und auch nodejs / NBM de- / installiert.
    Hat jemand noch einen Tipp für mich?
    Danke vorab.
    Sigi
    • wierer-sigiW wierer-sigi
      Aktuelle Versionen:
      update done
      0 verbose cli [
      0 verbose cli ]
      nichts finden
      Sudo apt-update
      sudo apt-upgrade
      gefahren
      Danke vorab.
      Sigi
      @wierer-sigi
      NodeJS falsch installiert.
      Schau in meiner Signatur wie es richtig gemacht wird.
      wierer-sigiW 1 Antwort Letzte Antwort
        @wierer-sigi
        wierer-sigi
        @thomas-braun sagte in IoBroker lässt kein update zu:
        @wierer-sigi
        Danke für den Tipp, hat aber leider nicht direkt zum Erfolg geführt.
        Nach ein paar versuchen, habe ich mir nodejs heruntergeladen, entpackt und installiert.
        https://nodejs.org/en/download/
        Sigi
        crunchipC Thomas BraunT 2 Antworten Letzte Antwort
          @wierer-sigi
          Sigi
          crunchipC Abwesend
          crunchipC Abwesend
          @wierer-sigi sagte in IoBroker lässt kein update zu:
          weil?
          und jetzt doppelt vorhanden?
            @wierer-sigi
            Sigi
            Und GENAU SO macht man das NICHT unter Linux/Debian.
            Man nutzt seinen Paketmanager. Wie steht in dem HowTo aus meiner Signatur.
            Über die Tour haste dir auch den krummen Kram in
            eingehandelt.
            • W Offline
              W Offline
              worxweis
              @jan1 Hallo Leute!
              Ich habe folgendes Problem: Ich habe ein Multihost System mit einem Master und einem Slave. (Beides Raspery Pi's).
              Auf der Übersichtseite wird beim Master ein NODEJS mit V14.19.1 angezeigt, beim Slave V14.16.0. Alle Adapter aktuell! Beide iobroker laufen mit js-controller 4.0.21.
              PlatformBetriebssystem:linux
              Architektur:arm
              CPUs:4
              Geschwindigkeit:600 MHz
              Modell:ARMv7 Processor rev 4 (v7l)
              RAM:926 MB
              System-Betriebszeit:00:05:15
              Node.js:v14.16.0
              time:1651388230789
              timeOffset:-120
              Adapter-Anzahl:407
              NPM:v6.14.11
              Datenträgergröße:14.4 GB
              freier Festplattenspeicher:8.2 GB
              Betriebszeit:00:03:10
              Aktive Instanzen:1
              Pfad:/opt/iobroker/
              Wollte nun ein Update des js-controllers durchführen.
              Beim Backup kam dann der Fehler:
              pi@ioBroker-RasPi:~ $ iob backup
              host.ioBroker-RasPi 15639 states saved
              host.ioBroker-RasPi 17623 objects saved
              <--- Last few GCs --->
              [1006:0x3fa5e78]    91924 ms: Mark-sweep (reduce) 231.7 (233.4) -> 231.7 (233.9) MB, 142.2 / 0.0 ms  (average mu = 0.298, current mu = 0.001) last resort GC in old space requested
              [1006:0x3fa5e78]    92069 ms: Mark-sweep (reduce) 231.7 (233.4) -> 231.7 (233.9) MB, 144.5 / 0.1 ms  (average mu = 0.182, current mu = 0.001) last resort GC in old space requested
              <--- JS stacktrace --->
              FATAL ERROR: CALL_AND_RETRY_LAST Allocation failed - JavaScript heap out of memory
              /usr/bin/iob: Zeile 8:  1002 Abgebrochen             sudo -H -u iobroker node /opt/iobroker/node_modules/iobroker.js-controller/iobroker.js "$@"
              Bei der Versionsabfrage kommt folgende Meldung:
              pi@ioBroker-RasPi:~ $ nodejs -v
              -bash: nodejs: Kommando nicht gefunden.
              Neustart hat nichts gebracht!
              Kann mir hier jemand weiterhelfen?
              Danke schon mal!
              J crunchipC 2 Antworten Letzte Antwort
              • W worxweis
                @jan1 Hallo Leute!
                Architektur:arm
                CPUs:4
                RAM:926 MB
                Node.js:v14.16.0
                time:1651388230789
                timeOffset:-120
                Adapter-Anzahl:407
                NPM:v6.14.11
                Aktive Instanzen:1
                Pfad:/opt/iobroker/
                Danke schon mal!
                Jan1
                @worxweis sagte in IoBroker lässt kein update zu:
                nodejs -v
                Wolltest nicht mich direkt fragen, oder?
                Multi Host habe ich keinen und somit auch nicht wirklich Plan wie das zu handhaben ist, aber wenn Die Node Abfrage schon nicht funktioniert, dann dürfte das wohl schon schlecht sein und Du solltest hier das Problem suchen. Backup manuell geht, aber warum wenn man dafür ein Adapter hat?
                • J Jan1
                  nodejs -v
                  W Offline
                  W Offline
                  worxweis
                  @jan1 Sorry, wollte allgemein Fragen!
                  Backup manuell, weil es in der Updatebeschreibung des js-controllers so drinnensteht!
                  Aber was ich auch noch immer nicht verstehe: was ist der Unterschied zwischen Node.js und Nodejs? Oder ist das dass gleiche?
                  crunchipC J 2 Antworten Letzte Antwort
                  • W worxweis
                    crunchipC Abwesend
                    crunchipC Abwesend
                    die Schreibweise, es heisst node.js
                    https://nodejs.org/en/docs/
                    • W worxweis
                      Jan1
                      @worxweis
                      Auch so, das steht nur drin, damit die Kandidaten die Backups nur machen wenn sie sie benötigen auch endlich mal eins machen. Normal hat man eh jeden Tag ein aktuelles vom Backitup Adapter.
                      Node ist Node und wird so eben nur geprüft, ob die Installation richtig ist ;)
                      • W worxweis
                        @jan1 Hallo Leute!
                        Architektur:arm
                        CPUs:4
                        RAM:926 MB
                        Node.js:v14.16.0
                        time:1651388230789
                        timeOffset:-120
                        Adapter-Anzahl:407
                        NPM:v6.14.11
                        Aktive Instanzen:1
                        Pfad:/opt/iobroker/
                        Danke schon mal!
                        crunchipC Abwesend
                        crunchipC Abwesend
                        mal eine Erklärung
                        https://sebhastian.com/javascript-heap-out-of-memory/
                          mal eine Erklärung
                          W Offline
                          W Offline
                          worxweis
                          @crunchip Danke für die Info!
                          Aber wie hilft mir das weiter? Warum findet er den Befehl nodejs -v nicht?
                          J HomoranH 2 Antworten Letzte Antwort
                          • W worxweis
                            Jan1
                            @worxweis
                            zeig mal was er mit dem Befehle ausspuckt:
                            uname -m && which nodejs node npm && nodejs -v && node -v && npm -v && whoami && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
                            • W worxweis
                              weil neuere Installationen diesen symlink nicht mehr besitzen.
                              Wenn du ihn nich nach Anleitung erstellt hast, hast du ihn nicht
                              Aus der Doku:
                              In neueren Installationen kann es sein, dass der Befehl nodejs -v eine Fehlermeldung wie “nicht gefunden” erzeugt. Dies ist prinzipiell unbedenklich, da der Befehl nodejs schon länger nicht mehr verwendet wird, kann aber über einen Symlink mit dem Befehl sudo ln -s /usr/bin/node /usr/bin/nodejs "repariert" werden.
                              • J Jan1
                                @worxweis
                                W Offline
                                W Offline
                                worxweis
                                @jan1 Hallo Jan!
                                armv7l
                                /usr/local/bin/node
                                /usr/local/bin/npm
                                • W worxweis
                                  @jan1 Hallo Jan!
                                  armv7l
                                  /usr/local/bin/node
                                  /usr/local/bin/npm
                                  @worxweis
                                  nodeJS ist falsch installiert.
                                  Schau in meiner Signatur, da steht drin wie es richtig geht.
                                    @worxweis
                                    W Offline
                                    W Offline
                                    worxweis
                                    Deine Signatur ist Goldes Wert. Hab jetzt alles entfernt und nodejs neu installiert!
                                    Perfekt! Alles funktioniert jetzt wie es soll!
                                    Sehr schön beschrieben!
                                    Danke!
                                    • W worxweis
                                      Danke!
                                      @worxweis
                                      Kontrolle... :-)
                                      sagt jetzt?
