[Frage] Xiaomi Vacuum cleaner
Auf meinem Mac (Python 3.6.0 :: Anaconda 4.3.1 (x86_64)) bekomme ich die Fehlermeldung
msg = {u'data': {u'value': cmd}, u'header': {u'value': header}, u'checksum': 0} ! m = Message.build(msg) ! Traceback (most recent call last): ! File "<ipython-input-18-f0bb71292b90>", line 3, in <module> m = Message.build(msg) ! File "/anaconda/lib/python3.6/site-packages/construct/core.py", line 193, in build self.build_stream(obj, stream, context, **kw) ! File "/anaconda/lib/python3.6/site-packages/construct/core.py", line 205, in build_stream self._build(obj, stream, context, "building") ! File "/anaconda/lib/python3.6/site-packages/construct/core.py", line 872, in _build buildret = sc._build(subobj, stream, context, path) ! File "/anaconda/lib/python3.6/site-packages/construct/core.py", line 2713, in _build return self.subcon._build(obj, stream, context, path) ! File "/anaconda/lib/python3.6/site-packages/construct/core.py", line 1656, in _build buildret = self.subcon._build(obj, stream, context, path) ! File "/anaconda/lib/python3.6/site-packages/construct/core.py", line 2143, in _build value = self.subcon._build(value, stream, context, path) ! File "/anaconda/lib/python3.6/site-packages/construct/core.py", line 306, in _build return self.subcon._build(self._encode(obj, context), stream, context, path) ! File "/anaconda/lib/python3.6/site-packages/mirobo/protocol.py", line 114, in _encode return Utils.encrypt(json.dumps(obj).encode('utf-8') + b'\x00') ! File "/anaconda/lib/python3.6/site-packages/mirobo/protocol.py", line 45, in encrypt key, iv = Utils.key_iv() ! File "/anaconda/lib/python3.6/site-packages/mirobo/protocol.py", line 39, in key_iv key = Utils.md5(Utils.token) ! File "/anaconda/lib/python3.6/site-packages/mirobo/protocol.py", line 34, in md5 checksum.update(data) ! TypeError: Unicode-objects must be encoded before hashing</module></ipython-input-18-f0bb71292b90>`Das sind mindestens mit Python 3.4 entweder "bytes" oder "bytearray" Objekten statt Unicode. Leider weiß ich gerade nicht wie man damit umgehen könnte. Könntest du bitte ein Issue darüber ins github repo hinzufügen?
Auf meinem Raspberry Pi steigt er mit beim install aus mit der Fehlermeldung
AttributeError: 'Distribution' object has no attribute '_egg_fetcher'
Hat jemand das Paket https://github.com/rytilahti/python-mirobo
auf seinem Mac oder Raspberry Pi erfolgreich laufen? `
Ich habe es erneut mit Raspberry PI getestet, für eine erfolgreiche Installation benötigt man eine neuere Version als Pis 1.5.6 von setuptools. Hier ist wie ich es gerade getestet habe:
virtualenv -p python3 testenv source testenv/bin/activate pip install -U setuptools pip install -e git+https://github.com/rytilahti/python-mirobo#egg=python-mirobo # für git version, pip install python-mirobo für release. -
so, nun auch mal eine Zwischenmeldung von mir:
<u>1) neue Vers. vom Adapter</u>
Die 0.3.1 habe ich installiert; funktioniert.
Allerdings konnte ich nicht installieren mit:
https://github.com/ioBroker/ioBroker.mi … arball/dev
Dabei kam Fehlermeldung "404".
Über das + bei adapter konnte ich dann die Instanz installieren.
Die Werte bei Objekte "filter, main_brush, side_brush" stimmen bei mir auch nicht.
Also wollte ich auf github mal schauen ob es was neue gibt. Hab mir dann die Datei "main.js" die nur 3 Tage alt ist runter geladen und ins Verzeichnis kopiert.
Dann wurde der Adapter nicht mehr grün.
Fazit:
Installation hat über + bei Adapter geklappt.
o.g. Objekte stimmen noch nicht.
die neue Main.js bei github wird nicht grün.
<u>2) Sprachpakete</u>
Habe die xiaomi app laufen auf android handy.
Englisch konnte ich einstellen. Danach wieder das deutsche drauf.
und voila.
Fazit:
app läuft auf android in deutsch.
Die Sprachausgabe des robo habe ich nun auf Englisch.
mfg
Dieter
Über das + bei adapter konnte ich dann die Instanz installieren. `
Über den link kannst du es nicht installieren, hatte ich weiter oben schon einmal erläutert, der Link war zu dem Pullrequest von gst666 sämtlichge Änderungen sind in den Master eingeflossen
https://github.com/ioBroker/ioBroker.mihome-vacuum
über den Link installieren,
mit dem "+" hast du lediglich eine instanz mit der nicht aktuellen Version hinzugefügt.
Deine Kopierte main kann nicht grün werden, da bluefox auch noch andere Dateien geändert hat z.b das Verzeichnis der Mihome-paket.
wenn du über die admin seite und dem oben genannten link den adapter installeirt, hast du die neue Version. Die geänderten Werte der Bürsten, hat Bluefox wie du richtig gesehen hast vor 3 Tagen in die Main übernommen
mit freundlichen Grüßen Tobi
> wenn du über die admin seite und dem oben genannten link den adapter installeirt, hast du die neue Version. Die geänderten Werte der Bürsten, hat Bluefox wie du richtig gesehen hast vor 3 Tagen in die Main übernommenMeistertr,
Ich bin lost! Was meinst Du mit Admin Seite?
Ich bin lost! Was meinst Du mit Admin Seite? `
1768_unbenannt.jpg -
Bei mir hat die Installation geklappt.
Nun wollte ich ein Script basteln um mit den neuen Variablen etwas zu basteln.
Aber nur bei:
on({id: "mihome-vacuum.0.info.consumable.filter", change: "ne"}, function(){ // Restlaufzeit geändert });und dann Änderung der Variablen bekomme ich im log folgende Fehlermeldung:
filename="bild1.jpg" index="0">~~Jemand eine Idee?
was ist "unknown state" ???
mfg
Dieter
Nachtrag:
ich kann den State mit getstate abfragen und dann auch rechnen.
Aber o.g. Fehlermeldung bleibt.
noch ein Fehler gefunden (zumindest bei mir)
Wenn man ein widget "basic number " nimmt und bei objekt id einträgt "side_brush" wird der Text darunter nicht geändert.
Bei object id ausgewählt: ….side_brush
darunter steht aber main_brush
Komisch
-----> Gefunden:
Es steht als name jeweils "main_brush" <--------- sollte man mal ändern.
was ist "unknown state" ??? `
Dabei brauchst du dir keine Sorgen machen, Die Soll eigentlich nur kommen, wenn er die Aktion nicht zuordnen kann, aber in diesem fall gibt es ja keine Aktion (start,stop oder sonstiges) werde ich mir anschauen,Zu dem Main Brush, das habe ich auch gerade gesehen, da hat sich ein Schreibfehler eingeschlichen.
mfg Tobi
Hallo Tobi,
danke für die schnelle Antwort.
Fehlermeldungen sollten aber doch nur kommen wenn auch ein Fehler vorliegt.
Gibt es denn schon neue Erkenntnisse bzgl. der map ?
mfg
MoiN!
Auf Grund des Adapters habe ich mir jetzt auch so ein Teil gekauft…
Läuft alles bestens.
Ergänzung:
State 7 ist manueller Modus
Vielleicht kann man das in den Adapter mit aufnehmen.
ggf. Bug:
Seit ich den mihome-vacuum.0.control.fan_power im Adapter eingestellt habe (0-2?) zeigt er die Modi nicht mehr in der Applikation an?!
Kann das jemand reproduzieren?
bis denne
Mr.Lee
MoiN!
Kann das jemand reproduzieren? `
0-100
Die App kennt nur die drei voreingestellten Werte und kann auch nur diese anzeigen.
Hatte das schon einer?
Bei mir ist der Adapter grün, im Log erscheint connected. Datenpunkte werden angelegt und "connected" taucht auf aber ich kann ihn mit den Button "start, home…" nicht steuern und die restlichen Datenpunkte werden auch nicht ausgefüllt (siehe Screenshot).
Version 0.3.1 mit Ubuntu.
2548_bildschirmfoto_2017-04-22_um_02.01.32.png -
Du scheinst den falschen token zu haben, der Adapter kann nicht erkennen ob dieser richtig ist. Also Am besten noch einmal reseten und den Token erneut über packetsender abgreifen.
@tpr:Ich habe es erneut mit Raspberry PI getestet, für eine erfolgreiche Installation benötigt man eine neuere Version als Pis 1.5.6 von setuptools. Hier ist wie ich es gerade getestet habe:
virtualenv -p python3 testenv source testenv/bin/activate pip install -U setuptools pip install -e git+https://github.com/rytilahti/python-mirobo#egg=python-mirobo # für git version, pip install python-mirobo für release. ```` `It works.
(testenv) pi@raspberrypi: ~ $ mirobo find
But how to start from
pi@raspberrypi:
upd
So works
/home/pi/testenv/bin/mirobo find
0-2? Die Power ist von 0-100% also empfehlenswert ist min 30 %, werde es nachher mal ausprobieren. Danke für die Rückmeldung `
Ok, das war doof von mir mit 100% schafft er auch mehr weg… :lol:
nichts desto trotz zeigt die OrginalApp nicht mehr die saugstufen an...?
Ist auch schon das manuelle Steuern entschlüsselt? Es wäre super wenn man Roberto automatisiert an Stellen fahren könnte um dort Spot zu starten...
bis denne
Mr.Lee
P.S.: Genialer Adapter!!!
Danke Tobi für die schnelle Antwort
Du scheinst den falschen token zu haben, der Adapter kann nicht erkennen ob dieser richtig ist. Also Am besten noch einmal reseten und den Token erneut über packetsender abgreifen. `
Habe es jetzt noch 3 mal versucht und es haut leider immer noch nicht hin, siehe Bild.
Die letzten 16 Zeichen sind doch der Token oder? Also (letzte Uhrzeit im PacketSenderist momentan aktuell) müsste es doch 6E 48 51 32 6E 37 69 33 sein oder stehe ich schon wieder am Schlauch?
Und so habe ich es in den Adapter eingetragen
(siehe 2. Bild, habe es mit und ohne Leerzeichen probiert)
2548_bildschirmfoto_2017-04-22_um_15.33.24.png -
