  4. ZigBee neue Version 1.6.x
    6.3k
509 Beiträge 61 Kommentatoren 150.3k Aufrufe 62 Beobachtet
    Schmetterfliege
    schrieb am zuletzt editiert von Schmetterfliege
    #343
    Ich hänge mich hier mal mit rein...
    Ich habe seit dem Update auf 1.6.11 ebenfalls ab und zu den Absturz vom Zigbee Adapter wegen "Offset out of boundaries"...
    zigbee.0
    2022-02-08 21:09:02.634	info	Currently 47 devices are joined:
    zigbee.0
    2022-02-08 21:09:02.627	info	Unable to set transmit power, unsupported function.
    zigbee.0
    2022-02-08 21:09:02.461	info	--> transmitPower : normal
    zigbee.0
    2022-02-08 21:09:02.451	info	Unable to disable LED, unsupported function.
    zigbee.0
    2022-02-08 21:09:02.431	info	Coordinator firmware version: {"type":"ConBee2/RaspBee2","meta":{"transportrev":0,"product":0,"majorrel":38,"minorrel":88,"maintrel":0,"revision":"0x26580700"}}
    zigbee.0
    2022-02-08 21:09:02.403	info	Installed Version: ioBroker/ioBroker.zigbee
    zigbee.0
    2022-02-08 21:09:01.860	warn	extension DelayedAction
    zigbee.0
    2022-02-08 21:09:01.859	warn	extension DeviceEvent
    zigbee.0
    2022-02-08 21:09:01.858	warn	extension DeviceConfigure
    zigbee.0
    2022-02-08 21:09:01.857	warn	extension DeviceAvailability
    zigbee.0
    2022-02-08 21:09:01.856	warn	4 extensions initialized
    zigbee.0
    2022-02-08 21:09:01.854	info	Starting Zigbee npm ...
    zigbee.0
    2022-02-08 21:09:01.709	info	starting. Version 1.6.11 in /opt/iobroker/node_modules/iobroker.zigbee, node: v12.20.0, js-controller: 3.3.22
    host.raspberrypi
    2022-02-08 21:08:57.664	info	instance system.adapter.zigbee.0 started with pid 21968
    host.raspberrypi
    2022-02-08 21:08:27.623	info	Restart adapter system.adapter.zigbee.0 because enabled
    host.raspberrypi
    2022-02-08 21:08:27.622	error	instance system.adapter.zigbee.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
    host.raspberrypi
    2022-02-08 21:08:27.622	error	Caught by controller[1]: at Parser.EventEmitter.emit (domain.js:483:12)
    host.raspberrypi
    2022-02-08 21:08:27.621	error	Caught by controller[1]: at Parser.emit (events.js:314:20)
    host.raspberrypi
    2022-02-08 21:08:27.621	error	Caught by controller[1]: at Driver.onParsed (/opt/iobroker/node_modules/zigbee-herdsman/src/adapter/deconz/driver/driver.ts:784:14)
    host.raspberrypi
    2022-02-08 21:08:27.621	error	Caught by controller[1]: at Driver.EventEmitter.emit (domain.js:483:12)
    host.raspberrypi
    2022-02-08 21:08:27.621	error	Caught by controller[1]: at Driver.emit (events.js:314:20)
    host.raspberrypi
    2022-02-08 21:08:27.620	error	Caught by controller[1]: at Driver.<anonymous> (/opt/iobroker/node_modules/zigbee-herdsman/src/adapter/deconz/adapter/deconzAdapter.ts:63:59)
    host.raspberrypi
    2022-02-08 21:08:27.620	error	Caught by controller[1]: at processFrame (/opt/iobroker/node_modules/zigbee-herdsman/src/adapter/deconz/driver/frameParser.ts:405:59)
    host.raspberrypi
    2022-02-08 21:08:27.620	error	Caught by controller[1]: at parseFrame (/opt/iobroker/node_modules/zigbee-herdsman/src/adapter/deconz/driver/frameParser.ts:458:32)
    host.raspberrypi
    2022-02-08 21:08:27.620	error	Caught by controller[1]: at parseGreenPowerDataIndication (/opt/iobroker/node_modules/zigbee-herdsman/src/adapter/deconz/driver/frameParser.ts:313:33)
    host.raspberrypi
    2022-02-08 21:08:27.619	error	Caught by controller[1]: at DataView.getUint32 (<anonymous>)
    host.raspberrypi
    2022-02-08 21:08:27.619	error	Caught by controller[1]: RangeError: Offset is outside the bounds of the DataView
    host.raspberrypi
    2022-02-08 21:08:27.614	error	Caught by controller[0]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
    zigbee.0
    2022-02-08 21:08:26.984	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
    zigbee.0
    2022-02-08 21:08:26.981	info	terminating
    zigbee.0
    2022-02-08 21:08:26.811	info	Zigbee: disabling joining new devices.
    zigbee.0
    2022-02-08 21:08:26.676	info	cleaned everything up...
    zigbee.0
    2022-02-08 21:08:26.615	error	Offset is outside the bounds of the DataView
    zigbee.0
    2022-02-08 21:08:26.614	error	RangeError: Offset is outside the bounds of the DataView at DataView.getUint32 (<anonymous>) at parseGreenPowerDataIndication (/opt/iobroker/node_modules/zigbee-herdsman/src/adapter/deconz/driver/frameParser.ts:313:33) at parseFrame (/opt/iobroker/node_modules/zigbee-herdsman/src/adapter/deconz/driver/frameParser.ts:458:32) at processFrame (/opt/iobroker/node_modules/zigbee-herdsman/src/adapter/deconz/driver/frameParser.ts:405:59) at Driver.<anonymous> (/opt/iobroker/node_modules/zigbee-herdsman/src/adapter/deconz/adapter/deconzAdapter.ts:63:59) at Driver.emit (events.js:314:20) at Driver.EventEmitter.emit (domain.js:483:12) at Driver.onParsed (/opt/iobroker/node_modules/zigbee-herdsman/src/adapter/deconz/driver/driver.ts:784:14) at Parser.emit (events.js:314:20) at Parser.EventEmitter.emit (domain.js:483:12)
    zigbee.0
    2022-02-08 21:08:26.438	error	unhandled promise rejection: Offset is outside the bounds of the DataView
    zigbee.0
    2022-02-08 21:08:26.428	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    Hab mir fast alle Beiträge hier durchgelesen, glaube aber nicht eine klare Antwort darauf gefunden zu haben.
    Falls es die doch gab - sorry!
    Falls nicht, stelle ich einfach mal die Frage:
    Ist aus der Fehlermeldung ersichtlich, was genau bei mir das Problem ist?
    Soweit ich das sagen kann, passiert das erst seit dem Update.
    Was ich in dem Zeitraum hinzugefügt habe sind die neuen BW-SHP15 und diese Ikea Styrbar Remotes.
    Letztere werfen nach dem Neustart von Zigbee immer wieder Warnungen á la:
    DeviceConfigure:DeviceConfigure failed 0x842e14fffe285173 Remote Control N2, attempt 1 (Error: Bind 0x842e14fffe285173/1 genPowerCfg from '0x00212effff065d89/1' failed (waiting for response TIMEOUT) at DeconzAdapter.bind (/opt/iobroker/node_modules/zigbee-herdsman/src/adapter/deconz/adapter/deconzAdapter.ts:753:19))
    Ansonsten wüsste ich jetzt nicht, was sich geändert haben sollte das ansonsten zu dem Absturz führen könnte.
    EDIT:
    @Asgothian
    In Topic 50313 hatte ich das ja schonmal im Zuge der Integration der BW-SHP15 angesprochen und meinte ich aktiviere Debug im herdsman falls ich ein Muster erkenne.
    Aber ich behaupte mal ganz vorsichtig, dass es da kein Muster gibt^^
    mickymM AsgothianA 2 Antworten Letzte Antwort
    • S Schmetterfliege
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      host.raspberrypi
      host.raspberrypi
      host.raspberrypi
      host.raspberrypi
      host.raspberrypi
      host.raspberrypi
      host.raspberrypi
      host.raspberrypi
      host.raspberrypi
      host.raspberrypi
      host.raspberrypi
      host.raspberrypi
      host.raspberrypi
      host.raspberrypi
      host.raspberrypi
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      EDIT:
      @Asgothian
      mickymM Offline
      mickymM Offline
      mickym
      #344
      @schmetterfliege Na dann hoffe ich mal, dass Du mehr Glück hast.
      • mickymM mickym
        Schmetterfliege
        #345
        @mickym
        danke :D
        Noch ist wegen dem Crash nichts abgefackelt, daher verzichte ich mal noch darauf alles neu einzurichten.
        In ca 3 Monaten ziehe ich hier eh aus, dann gibts sowieso den großen Reset
        • 1Topf1 1Topf
          @Asgothian
          @arteck sagte in ZigBee neue Version 1.6.x:
          @1topf sach an
          Naja, ich trau mich ja kaum, hab hier schon mal danach gefragt ... HEIMAN hs2wdsr-e ... 🙄 😉
          Mir würde es schon reichen, wenn ich den Taster und die Lampe nur nutzen könnte. Farbsteuerung ist (erstmal) nebensächlich. Wenn es absolut nicht möglich ist, habe ich halt Pech gehabt, ich bin da nicht böse. ✌
          Installiert habe ich die 1.6.12, da ja mit der 14 mein anderer Taster nicht mehr funzt.
          Viele Grüße
          AsgothianA Offline
          AsgothianA Offline
          Asgothian
          #346
          @1topf Ich fürchte das wird nicht "mal eben so" werden. Ist eine Nichtstandard Fernbedienung.
          A.
          1Topf1 1 Antwort Letzte Antwort
          • arteckA Offline
            arteckA Offline
            arteck
            #347
            ich wiederholle es nochml FÜR ALLE DIE EINEN CONBEE haben
            das DING ist nur als BETA Hardware (Probeweise) angebunden.. und wird nicht RICHTIG supported..wenns läuft ist gut..wenn nicht suchen wir uns einen doofen..
            wobei ich nicht bereit bin da Zeit zu investieren da ich s nicht nutze.
            @1topf sagte in ZigBee neue Version 1.6.x:
            das ding ist doch schon längs drin..hab es auch geschrieben
            • S Schmetterfliege
              zigbee.0
              zigbee.0
              zigbee.0
              zigbee.0
              zigbee.0
              zigbee.0
              zigbee.0
              zigbee.0
              zigbee.0
              zigbee.0
              zigbee.0
              zigbee.0
              zigbee.0
              host.raspberrypi
              host.raspberrypi
              host.raspberrypi
              host.raspberrypi
              host.raspberrypi
              host.raspberrypi
              host.raspberrypi
              host.raspberrypi
              host.raspberrypi
              host.raspberrypi
              host.raspberrypi
              host.raspberrypi
              host.raspberrypi
              host.raspberrypi
              host.raspberrypi
              zigbee.0
              zigbee.0
              zigbee.0
              zigbee.0
              zigbee.0
              zigbee.0
              zigbee.0
              zigbee.0
              EDIT:
              @Asgothian
              AsgothianA Offline
              AsgothianA Offline
              Asgothian
              #348
              @schmetterfliege sagte in ZigBee neue Version 1.6.x:
              EDIT:
              @Asgothian
              Zum Absturz: Der wird dadurch ausgelöst das ein über den Conbee herein kommendes Kommunikationspaket nicht in dem von der Conbee Implementierung erwarteten Format entspricht. Ich gehe im Moment davon aus das dieses weniger an der Adapter Version und eher an der Firmware-Version des Conbee liegt. An dieser Stelle bin ich im gleichen Boot wie @arteck. Ich kann mich da nicht auch noch im Detail hinein arbeiten. Dieses Problem muss auf zigbee-herdsman Seite gelöst werden.
              Zu den Warnmeldungen - diese werden dadurch ausgelöst das inzwischen vermehrt batteriebetriebene Geräte eine Konfiguration bei Start benötigen. Diese können sie nur durchführen wenn die Geräte zu dem Zeitpunkt wach sind. Die Meldungen wirst Du los in dem Du das Gerät weckst und dann Über die Kachel eine Konfiguration auslöst.
              A.
              • arteckA arteck
                1Topf1 Offline
                1Topf1 Offline
                1Topf
                #349
                Nee, haste nich 😛 . Asgothian meinte nur Das sollte sich mit dem Anpassungen der letzten Tage behoben haben. Bitte testen. und ich schrieb dann, daß ich es gestestet habe und es nicht geht. Ich werde es nochmal probieren. 🙏
                • AsgothianA Asgothian
                  A.
                  1Topf1 Offline
                  1Topf1 Offline
                  1Topf
                  #350
                  @asgothian sagte in ZigBee neue Version 1.6.x:
                  A.
                  Ja, dachte ich mir schon. Kann man die Config der HS2SS irgendwie umfummeln, daß deren Funktionen bei meiner verfügbar wären?
                  • 1Topf1 1Topf
                    1Topf1 Offline
                    1Topf1 Offline
                    1Topf
                    #351
                    So, hab es mit der 1.6.15 probiert, geht nicht. Ich hab ja keine Ahnung, welche Dateien dafür "zuständig" sind. Die osram.js, die configureKey.js und die shepherd.db sind bei 1.6.12 und 1.6.15 identisch abgesehen von "defaultSendRequestWhen":"immediate", aber das fehlt ja jetzt bei allen Geräten. Verstecken sich irgendwo noch mehr Dateien, in denen die Geräte hinterlegt sind?
                    Hier, mal optisch dargestellt. 1.6.12
                    vs. 1.6.14 / 15
                    • DerStalleD DerStalle
                      @asgothian Gerne.
                      AsgothianA Offline
                      AsgothianA Offline
                      Asgothian
                      #352
                      @derstalle
                      Es hat etwas länger gedauert da ich mich um was kümmern musste. Hier nun der Versuch einer Einbindung:
                      Du musst die folgenden Schritte tun:
                      • Zigbee Adapter anhalten
                      • die Datei "Paulmann.js" in den Zigbee-herdsman-converters finden. Diese sollte unter /opt/iobroker/node_modules/zigbee-herdsman-converters/devices liegen.
                      • In diese Datei fügst du ab Zeile 7 den folgenden Code ein:
                              zigbeeModel: ['50134'],
                              model: '501.34',
                              vendor: 'Paulmann',
                              description: 'Dual wall switch/dimmer',
                              extend: extend.light_onoff_brightness(),
                              meta: {multiEndpoint: true},
                      • Zigbee adapter starten. Wenn alles passt müsste das Gerät sauber erkannt werden.
                      A.
                        @derstalle
                                model: '501.34',
                                vendor: 'Paulmann',
                        A.
                        #353
                        @asgothian ah, da faellt mir ein, ich hab mir die Paulman.js auch gepatcht, hab da n LED Panel, das funktioniert so:
                                zigbeeModel: ['371232040'],
                                model: '371232040',
                                vendor: 'Paulmann',
                                description: 'LED panels',
                                extend: extend.light_onoff_brightness_colortemp_color(),
                        Kannst du das auch adden?
                        Ich editiere nach jedem Update das file manuell.. :-)
                                  model: '371232040',
                                  vendor: 'Paulmann',
                          arteckA Offline
                          arteckA Offline
                          arteck
                          #354
                          @ilovegym habs mit aufgenommen
                          Chris76eC 1 Antwort Letzte Antwort
                          • arteckA arteck
                            Chris76eC Offline
                            Chris76eC Offline
                            Chris76e
                            #355
                            Hi, seit der Version 1.6.15 wird beim Paulmann 500.45 kein Bild mehr angezeigt und ich kann den nicht mehr über "Switch state" ein/aus schalten, geht nur noch über "Brightness".
                            Mit der Version 1.6.16 geht es jetzt auch bei den Tint LED bulb nicht mehr.
                            Mit der Version 1.6.14 funktioniert das alles.
                            Tint LED bulb GU10/E14/E27 350/470/806 lumen, dimmable, color, opal white
                            Paulmann 500.45 SmartHome Zigbee Pendulum Light Aptare
                            • Chris76eC Chris76e
                              arteckA Offline
                              arteckA Offline
                              arteck
                              #356
                              @chris76e sagte in ZigBee neue Version 1.6.x:
                              die 2 Geräte sind nicht verbunden wie ich es sehe.. schaltest du die am Schalter aus so dass die ohne Strom sind ?
                              • ? Offline
                                #357
                                @arteck Guten Morgen, ich habe seit der Version 16 auch das Problem, dass verschiedene 220V Zigbee's offline sind und toggeln .. ( hab ein Script laufen, das den online Datenpunkt triggert und mir ne Message schickt, seit V16 sind im 5min-Takt messages ... das war vorher nie..)..
                                Bei mir sind es Lampen, Mi-Power, die HS2WD-E, auch mal Blitzwolf SHP.. die waren alle noch nie offline..
                                Dass mal ein Sensor offline ist.. ist eigentlich normal.. ich hab 195 Zigbee devices connected..
                                Kann ich das irgenwie besser loggen?
                                Komisch ist, dass es ausgerechnet die 220V Devices sind..
                                  arteckA Offline
                                  arteckA Offline
                                  arteck
                                  #358
                                  @ilovegym ich hab die probleme mit Osram Dosen..aber das ist bekannt das die muken
                                  was hst du als coordinator ?
                                  • arteckA arteck
                                    #359
                                    @arteck Das Zigbee Netzwerk ist jetzt seit einem Jahr stabil ausgebaut, ich hatte monatelang keine Probleme, aber seit der letzten Version sind die 220V devices offline und toggeln.. dann gehts mal wieder.. dann sind se wieder offline..
                                    Ich hab n CC26X2R1
                                      Ich hab n CC26X2R1
                                      AsgothianA Offline
                                      AsgothianA Offline
                                      Asgothian
                                      #360
                                      @ilovegym sagte in ZigBee neue Version 1.6.x:
                                      Kannst du in dem Moment wo die Devices offline gehen bitte an dem jeweiligen Device den "device query" state mit wahr aktualisieren, und schauen ob dadurch
                                      • das Device sofort wieder auf available wechselt ?
                                      • in der Folge der message_from_zigbee state aktualisiert wird ?
                                      Ich gehe davon aus das du dafür ein Skript - da müsste zusätzlich zur Nachricht halt noch der State angepasst werden.
                                      Letztendlich steht dahinter die Frage ob wir durch Anpassungen am Herdsman unsere "Ping" Funktion überarbeiten müssen weil sie nicht die gewünschten Ergebnisse liefert oder ob es da wirklich Probleme mit dem Netzwerk gibt.
                                      A.
                                      • ? Offline
                                        #361
                                        @asgothian
                                        mir ist gerade aufgefallen, dass meine Netzwerkkarte zur Zeit so aussieht..:
                                        ja, genau das passiert.. ich trigger, und dann ist das Device online...
                                        arteckA AsgothianA 2 Antworten Letzte Antwort
                                          @asgothian
                                          arteckA Offline
                                          arteckA Offline
                                          arteck
                                          #362
                                          @ilovegym warte mal so 5 min.. bei so vielen Geäten dauert der aufbau..also nicht ungeduldig werden
