  4. massive CPU Auslastung
146 Beiträge 17 Kommentatoren 42.7k Aufrufe 11 Beobachtet
  • da_WoodyD da_Woody
    @apollon77 noch kein eigenes thema? ok.
    ich teste schon den ganzen tag herum. in der früh downgrade gemacht auf 3.3.22. ok nicht kontrolliert. alle scripte ausgeschalten, einige adapter gestoppt. danach teilweise normale werte bei CPU und RAM. mit ausreissern auf über 100%.
    js-controller update auf 4.0.9, aber, zeile 103, Update js-controller from @4.0.8 to @4.0.9?
    woody@ioBroker:~$ iob backup
    host.ioBroker 137495 states saved
    host.ioBroker 176283 objects saved
    Backup created: /opt/iobroker/backups/2022_02_15-12_24_08_backupiobroker.tar.gz
    woody@ioBroker:~$ iob stop
    woody@ioBroker:~$ iob update
    Used repository: Beta (latest)
    Adapter    "admin"        : 5.3.0    , installed 5.3.0
    Adapter    "alexa2"       : 3.12.0   , installed 3.12.0
    Adapter    "alias-manager": 1.2.4    , installed 1.2.4
    Adapter    "backitup"     : 2.3.2    , installed 2.3.2
    Adapter    "birthdays"    : 1.0.0    , installed 1.0.0
    Adapter    "bydbatt"      : 1.0.7    , installed 1.0.7
    Adapter    "daswetter"    : 3.0.9    , installed 3.0.9
    Adapter    "device-reminder": 1.2.9  , installed 1.2.9
    Adapter    "followthesun" : 0.3.8    , installed 0.3.8
    Adapter    "fronius"      : 1.1.3    , installed 1.1.3
    Adapter    "gruenbeck"    : 0.0.34   , installed 0.0.34
    Adapter    "ical"         : 1.11.6   , installed 1.11.6
    Adapter    "influxdb"     : 2.4.0    , installed 2.4.0
    Adapter    "info"         : 1.9.18   , installed 1.9.18
    Adapter    "iot"          : 1.9.5    , installed 1.9.5
    Adapter    "iqontrol"     : 2.0.0-rc2.1, installed 2.0.0-rc2.1
    Adapter    "javascript"   : 5.2.21   , installed 5.2.21
    Controller "js-controller": 4.0.9    , installed 4.0.8  [Updatable]
    Adapter    "linux-control": 1.1.4    , installed 1.1.4
    Adapter    "logparser"    : 1.1.0    , installed 1.1.0
    Adapter    "meteoalarm"   : 2.1.1    , installed 2.1.1
    Adapter    "mihome-vacuum": 3.3.3    , installed 3.3.3
    Adapter    "mqtt"         : 2.4.1    , installed 2.4.1
    Adapter    "octoprint"    : 3.0.1    , installed 3.0.1
    Adapter    "pi-hole"      : 1.3.4    , installed 1.3.4
    Adapter    "ping"         : 1.5.2    , installed 1.5.2
    Adapter    "proxmox"      : 1.3.4    , installed 1.3.4
    Adapter    "radar2"       : 2.0.3    , installed 2.0.3
    Adapter    "shelly"       : 5.1.3    , installed 5.1.3
    Adapter    "shuttercontrol": 1.4.11  , installed 1.4.11
    Adapter    "simple-api"   : 2.6.2    , installed 2.6.2
    Adapter    "smartcontrol" : 1.2.1    , installed 1.2.1
    Adapter    "snmp"         : 0.5.0    , installed 0.5.0
    Adapter    "socketio"     : 4.1.2    , installed 4.1.2
    Adapter    "sonoff"       : 2.4.7    , installed 2.4.7
    Adapter    "synology"     : 1.1.3    , installed 2.0.1
    Adapter    "trashschedule": 1.4.2    , installed 1.4.2
    Adapter    "vis"          : 1.4.12   , installed 1.4.12
    Adapter    "weatherunderground": 3.3.1, installed 3.3.1
    Adapter    "web"          : 4.1.4    , installed 4.1.4
    Adapter    "web-speedy"   : 0.2.0    , installed 0.2.0
    Adapter    "whatsapp-cmb" : 0.1.6    , installed 0.1.6
    Adapter    "wled"         : 0.6.3    , installed 0.6.3
    Adapter    "ws"           : 1.1.4    , installed 1.1.4
    woody@ioBroker:~$ iob fix
    library: loaded
    Library version=2022-02-10
        Welcome to the ioBroker installation fixer!
        Script version: 2022-02-13
        You might need to enter your password a couple of times.
        Installing prerequisites (1/3)
    [sudo] Passwort für woody:
    OK:1 http://security.debian.org/debian-security buster/updates InRelease
    OK:2 http://deb.debian.org/debian buster InRelease
    Holen:3 http://deb.debian.org/debian buster-updates InRelease [51,9 kB]
    OK:4 https://deb.nodesource.com/node_14.x buster InRelease
    Es wurden 51,9 kB in 1 s geholt (101 kB/s).
    Installed gcc-c++
        Checking ioBroker user and directory permissions (2/3)
        Checking autostart (3/3)
    Enabling autostart...
    Autostart enabled!
        Your installation was fixed successfully
        Run iobroker start to start ioBroker again!
    woody@ioBroker:~$ iob upgrade self
    Stopped Objects DB
    Stopped States DB
    NPM version: 6.14.16
    Installing iobroker.js-controller@4.0.9... (System call)
    > iobroker.js-controller@4.0.9 preinstall /opt/iobroker/node_modules/iobroker.js-controller
    > node lib/preinstallCheck.js
    > iobroker.js-controller@4.0.9 install /opt/iobroker/node_modules/iobroker.js-controller
    > node iobroker.js setup first
    Successfully migrated 179884 objects to Redis Sets
    object _design/system updated
    The following notifications happened during sync:
    - Ignoring Directory "fronius.admin" because officially not created as meta object. Please remove directory!
    - Ignoring Directory "proxmox" because officially not created as meta object. Please remove directory!
    - Ignoring Directory "proxmox.admin" because officially not created as meta object. Please remove directory!
    - Ignoring Directory "switchbot-hub.admin" because officially not created as meta object. Please remove directory!
      "defaultPrivate": "-----BEGIN RSA PRIVATE KEY-----\r\xxx\r\n-----END RSA PRIVATE KEY-----\r\n",
      "defaultPublic": "-----BEGIN CERTIFICATE-----\r\xxx\r\n-----END CERTIFICATE-----\r\n"
    Update certificate defaultPrivate
    The object "system.certificates" was updated successfully.
    Update certificate defaultPublic
    + iobroker.js-controller@4.0.9
    added 1 package from 2 contributors, removed 1 package and updated 26 packages in 91.61s
    74 packages are looking for funding
      run `npm fund` for details
    woody@ioBroker:~$ iob start
    woody@ioBroker:~$ iob status
     Cannot determine Lua scripts strategy: Connection is closed. ["cfg.o.system.host.ioBroker"]
    Server Cannot start inMem-objects on port 9001: Failed to lock DB file "/opt/iobroker/iobroker-data/objects.jsonl"!
    woody@ioBroker:~$
    verwirrung wird nicht weniger...
    alles auf latest gezogen, neuen downgrad gemacht.
    woody@ioBroker:~$ npm install iobroker.js-controller@3.3.22
    > iobroker.js-controller@3.3.22 preinstall /home/woody/node_modules/iobroker.js-controller
    > iobroker.js-controller@3.3.22 install /home/woody/node_modules/iobroker.js-controller
    object _design/custom updated
    ATTENTION: Error reporting via Sentry will be activated on next start of ioBroker
    ioBroker wants to make sure to deliver the most stable smart home system.
    To allow this we decided to implement an automatic error and crash reporting solution into the js-controller and also into adapters.
    THIS REPORTING WILL BE ENABLED WITH THE NEXT START OF YOUR IOBROKER!
    For any error that leads to the crash of the js-controller or one of the relevant adapters the error details are send to a server. For the js-controller and core adapters this server is located and operated in germany. For community adapters please check the Github Readme of the affected adapter for details which Sentry server is used.
    If you want to disable the error reporting you can use the command
    'iobroker plugin disable sentry'
    This command will also make sure that no adapter that runs on this host will send crash reporting data to sentry.
    npm WARN saveError ENOENT: no such file or directory, open '/home/woody/package.json'
    npm WARN enoent ENOENT: no such file or directory, open '/home/woody/package.json'
    npm WARN woody No description
    npm WARN woody No repository field.
    npm WARN woody No README data
    npm WARN woody No license field.
    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@2.3.2 (node_modules/fsevents):
    npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.3.2: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"x64"})
    + iobroker.js-controller@3.3.22
    updated 1 package and audited 485 packages in 9.215s
    12 packages are looking for funding
    found 21 vulnerabilities (13 low, 5 moderate, 3 high)
      run `npm audit fix` to fix them, or `npm audit` for details
       │      New major version of npm available! 6.14.16 → 8.5.0      │
       │   Changelog: https://github.com/npm/cli/releases/tag/v8.5.0   │
       │               Run npm install -g npm to update!               │
    woody@ioBroker:~$
    No connection to databases possible ...
    woody@ioBroker:~$
    admin neu gestartet, den ganzen rechner neu gestartet:
    top zickt immer noch rum.
    top - 15:50:41 up 29 min,  1 user,  load average: 2,10, 2,15, 1,91
    Tasks: 114 total,   3 running, 111 sleeping,   0 stopped,   0 zombie
    %Cpu(s): 67,9 us,  3,6 sy,  0,0 ni, 25,0 id,  0,2 wa,  0,0 hi,  0,7 si,  2,6 st
    MiB Mem :   5962,7 total,   1450,6 free,   4010,7 used,    501,5 buff/cache
    MiB Swap:    975,0 total,    974,7 free,      0,3 used.   1719,4 avail Mem
      PID USER      PR  NI    VIRT    RES    SHR S  %CPU  %MEM     TIME+ COMMAND
      351 iobroker  20   0 1890260   1,0g  35556 R 125,5  17,8  25:26.79 iobroker.js-con
      509 iobroker  20   0 1086652 237768  30856 S  11,3   3,9   3:28.99 io.mqtt.0
      785 iobroker  20   0  950776 351280  31000 S   5,3   5,8   0:37.79 io.simple-api.0
      536 iobroker  20   0  726040 134820  31164 S   2,3   2,2   1:16.09 io.shelly.0
      416 iobroker  20   0 1132504 423056  30760 S   0,7   6,9   1:39.00 io.javascript.0
      629 iobroker  20   0  676236  82032  30828 S   0,7   1,3   0:33.52 io.sonoff.0
       10 root      20   0       0      0      0 R   0,3   0,0   0:01.00 rcu_sched
      730 iobroker  20   0   10,6g  73164  32436 S   0,3   1,2   0:03.34 io.linux-contro
      763 iobroker  20   0  672868  76884  31208 S   0,3   1,3   0:13.60 io.octoprint.0
      845 iobroker  20   0  962872 108392  31388 S   0,3   1,8   0:10.23 io.web.0
      860 iobroker  20   0  671248  71196  30932 S   0,3   1,2   0:02.64 io.meldungslist
        1 root      20   0   21920   9760   7656 S   0,0   0,2   0:01.22 systemd
        2 root      20   0       0      0      0 S   0,0   0,0   0:00.00 kthreadd
        3 root       0 -20       0      0      0 I   0,0   0,0   0:00.00 rcu_gp
        4 root       0 -20       0      0      0 I   0,0   0,0   0:00.00 rcu_par_gp
        6 root       0 -20       0      0      0 I   0,0   0,0   0:00.00 kworker/0:0H-kblockd
        8 root       0 -20       0      0      0 I   0,0   0,0   0:00.00 mm_percpu_wq
        9 root      20   0       0      0      0 S   0,0   0,0   0:00.09 ksoftirqd/0
       11 root      20   0       0      0      0 I   0,0   0,0   0:00.00 rcu_bh
       12 root      rt   0       0      0      0 S   0,0   0,0   0:00.00 migration/0
       14 root      20   0       0      0      0 S   0,0   0,0   0:00.00 cpuhp/0
       15 root      20   0       0      0      0 S   0,0   0,0   0:00.00 cpuhp/1
       16 root      rt   0       0      0      0 S   0,0   0,0   0:00.36 migration/1
       17 root      20   0       0      0      0 S   0,0   0,0   0:00.44 ksoftirqd/1
       19 root       0 -20       0      0      0 I   0,0   0,0   0:00.00 kworker/1:0H-kblockd
       20 root      20   0       0      0      0 S   0,0   0,0   0:00.00 kdevtmpfs
       21 root       0 -20       0      0      0 I   0,0   0,0   0:00.00 netns
       22 root      20   0       0      0      0 S   0,0   0,0   0:00.00 kauditd
       23 root      20   0       0      0      0 S   0,0   0,0   0:00.00 khungtaskd
       24 root      20   0       0      0      0 S   0,0   0,0   0:00.00 oom_reaper
       25 root       0 -20       0      0      0 I   0,0   0,0   0:00.00 writeback
       26 root      20   0       0      0      0 S   0,0   0,0   0:00.00 kcompactd0
       27 root      25   5       0      0      0 S   0,0   0,0   0:00.00 ksmd
       28 root      39  19       0      0      0 S   0,0   0,0   0:00.34 khugepaged
       29 root       0 -20       0      0      0 I   0,0   0,0   0:00.00 crypto
       30 root       0 -20       0      0      0 I   0,0   0,0   0:00.00 kintegrityd
       31 root       0 -20       0      0      0 I   0,0   0,0   0:00.00 kblockd
       32 root       0 -20       0      0      0 I   0,0   0,0   0:00.00 edac-poller
       33 root       0 -20       0      0      0 I   0,0   0,0   0:00.00 devfreq_wq
       34 root      rt   0       0      0      0 S   0,0   0,0   0:00.00 watchdogd
       36 root      20   0       0      0      0 S   0,0   0,0   0:00.08 kswapd0
       54 root       0 -20       0      0      0 I   0,0   0,0   0:00.00 kthrotld
       55 root       0 -20       0      0      0 I   0,0   0,0   0:00.00 ipv6_addrconf
       65 root       0 -20       0      0      0 I   0,0   0,0   0:00.00 kstrp
    inder proxmox GUI sind teilweise "normale" werte, bis zu extrem.
    Thomas BraunT
    Thomas BraunT
    Most Active Developer
    @da_woody sagte in js-controller 4.0 jetzt im BETA/LATEST!:
    Da stehst du im falschen Verzeichnis.
    Vorher in /opt/iobroker wechseln.
      da_WoodyD
      da_WoodyD
      @thomas-braun wurde vor paar tagen erklärt, daß das automatisch passiert.
      soll heißen, das ich jetzt 2 js-controller im system habe?
      würde die last erklären, oder?
        Thomas BraunT
        Thomas BraunT
        Nicht, wenn du direkt mit npm hantierst. Das installiert immer in das Verzeichnis, in welchem es aufgerufen wurde.
        Wenn der wrapper
        iobroker add MODULNAME
        verwendet wird ist es egal, der setzt das richtige Verzeichnis.
        Möglich.
        Ebenfalls möglich.
          Wenn der wrapper
          Möglich.
          Ebenfalls möglich.
          da_WoodyD
          da_WoodyD
          @thomas-braun dann kann ich nur verweisen:
          Eine alte 3.3.x-Version des js-controller kann im Notfall einfach wieder per npm install iobroker.js-controller@version ("version" durch die gewünschte Versionsnummer ersetzen) installiert werden und sollte alles wieder herstellen.
            Thomas BraunT
            Thomas BraunT
            @da_woody
            Stimmt ja auch. Der Befehl muss aber halt im richtige Verzeichnis ausgeführt werden. Der Hinweis fehlt an der Stelle. Aber als Beta-Tester sollte man das eh wissen und selbstständig daran denken. Ist halt 'Handwerkzeug' für einen Beta-Testling.
              @da_woody
              da_WoodyD
              da_WoodyD
              @thomas-braun ok, passt. für dich ist beta tester gleich linux guru...
                Thomas BraunT
                Thomas BraunT
                @da_woody
                Nö.
                Aber 'Handwerkzeug' ist 'Handwerkzeug'. Ich vermute, npm tickt auf Windows auch nicht anders, hat also mit dem Betriebssystem nix zu tun.
                  @da_woody
                  Nö.
                  da_WoodyD
                  da_WoodyD
                  #66
                  @thomas-braun was kommst du mir jetzt mit windows???
                  du liest irgenwo root, springst sofort an.
                  du liest windows, springst sofort an.
                  manchmal versteh ich dich nicht...
                    Thomas BraunT
                    Thomas BraunT
                    #67
                    @da_woody
                    Was denn?
                    Nein, für Beta-Testing braucht man kein Linux-Guru sein, weil npm / nodejs als plattformunabhänigige Laufzeitumgebung überall mehr oder weniger gleich tickt.
                    Dann kannst du auch genauso behaupten, man müsse ein 'Windows-Guru' sein.
                    Muss man halt auch nicht. Aber man muss seine verwendeten Werkzeuge kennen. Nicht mehr und nicht weniger habe ich gesagt.
                      @da_woody
                      Was denn?
                      da_WoodyD
                      da_WoodyD
                      #68
                      @thomas-braun ich bezeichne mich sicher nicht als 'Windows-Guru", aber dort hab ich noch nie npm gebraucht.
                      werkzeuge kann man nur verwenden, wenn man sich damit auskennt. wie ich schon oft geschrieben habe, der pinguin ist nicht meins. bin aber lernfähig. du bist offensichtlich mit linux "aufgewachsen", kennst die regeln dort auswendig. ich bin halt mit dos "aufgewachsen" und kenn mich mit windoof besser aus.
                      sinn und zweck eines forums ist, einem unbedarfteren zu helfen und nicht ihn mit wertfreien ansagen runter zu machen...
                        Thomas BraunT
                        Thomas BraunT
                        #69
                        @da_woody
                        Wenn du die 'Eier hast' als root oder Beta-Tester oder was weiß ich hier aufzutreten, dann musst du auch damit rechnen, wenn da mehr oder weniger dezente Hinweise kommen, wenn die Schuhe offenbar eine Nummer zu groß sind.
                        Ist allerdings jetzt schwer OffTopic hier im Thread.
                        • apollon77A apollon77
                          @da_woody nur lass uns bitte extra thread machen.
                          @Homoran s hiebst du bitte die Performance Posts in was eigenes. Aber ja ist mit Controller 4 verhandelt. Danke
                          NegaleinN
                          NegaleinN
                          Negalein
                          #70
                          @apollon77 sagte in massive CPU Auslastung:
                          hab ich gerade erledigt
                          ° Fixer ---> iob fix
                            Thomas BraunT
                            Thomas BraunT
                            #71
                            @da_woody
                            BTT: Deine Beobachtung mit der hohen Last wäre eigentlich nicht uninterressant. Eine saubere Installation vorausgesetzt.
                            So würde ich behaupten: Irgendwie krumm und schief und doppelt und 'irgendwie' installiert; kann man so gar nichts draus ableiten.
                            • AlCalzoneA
                              AlCalzoneA
                              AlCalzone
                              #72
                              @da_Woody @thomas-braun bitte diskutiert das woanders, z.B. im Chat
                              laut letztem top ist ja beim Skript-Adapter jetzt Ruhe. MQTT ist noch ein bisschen busy:
                              Ich kann mich aber immer noch nicht erinnern, die INPUT/OUTPUT-Werte gesehen zu haben. Ist doch nicht so schwer, da mal nen Screenshot zu machen, etwa so?
                                @da_woody
                                da_WoodyD
                                da_WoodyD
                                #73
                                @thomas-braun bitte hör endlich damit auf. wenn du meine logs lesen würdets, wirst du sehn, daß ich als woody unterwegs bin. lass dein root geschreibsel.
                                  Thomas BraunT
                                  Thomas BraunT
                                  #74
                                  @da_woody
                                  Tu ich.
                                  Wo hab ich denn was von root geschrieben?
                                  Ich hab nur geschrieben, dass du im falschen Vezeichnis stehst, nämlich im home von woody. Hab ich deinem Log entnommen.
                                    @da_woody
                                    Tu ich.
                                    da_WoodyD
                                    da_WoodyD
                                    #75
                                    @thomas-braun immer wieder schreibst du "root hampeln" in diverse postings.
                                    endlich hast du mich aufgeklärt wo ein problem sein könnte! war das so schwer, das gleich im text zu schreiben?
                                    eine einfache erklärung, "du hast das vllt im falschen verzeichniss gemacht" mit einer lösungserklärung wie man das gerade biegen kann, fällt dir nicht ein.
                                    kann es jetzt sein, daß ich im system einen js-controller und in meinem woody, oder wo anders einen am laufen habe?
                                    keine ahnung ob man sowas in top sehen würde. für mich ist die ordnerstruktur unter linux noch immer ein "spanisches dorf"
                                    vllt wäre es ein lösung alle js-controller, wenn zu finden, zu deinsten und dann eine neue am richtigen platz reintackern?
                                    HomoranH Thomas BraunT 3 Antworten Letzte Antwort
                                      #76
                                      @da_woody sagte in massive CPU Auslastung:
                                      aber hier diesmal nicht!
                                      und was ist das?:
                                      @thomas-braun sagte in massive CPU Auslastung:
                                      dazu fehlen Informationen was genau bereits alles auf deinem System krumm ist.
                                        Thomas BraunT
                                        Thomas BraunT
                                        #77
                                        Wenn es angebracht ist tue ich das. Stimmt.
                                        Tun nämlich meist genau die Kandidaten, die es besser nicht tun würden. Ist nämlich oft nicht anderes als 'rumgehampel'.
                                        Wovon sprichst du konkret?
                                        Doch. Aber ich geb dir die Chance dein Handwerkszeug zu erlernen.
                                        Wie man in Verzeichnisse wechselt muss ich hoffentlich nicht erklären?
                                        Das ist nämlich dann die Frage 'wo fängst du an, wo hörst du auf?'
                                        Man würde einen Prozess js-controller (oder ähnlich) sehen, der unter dem user woody läuft. Ich würde das aber anders nachschauen. Mit htop geht es aber z. B. auch. Einfach nach dem user sortieren.
                                        Was willst denn wissen? User-Dateien liegen in /home/USERNAME, im login prompt als ~ abgekürzt. Das habe ich deinem log (ja, ich lese das!) entnehmen können.
                                        Andere Verzeichnisse als das home-Verzeichnis stehen immer mit absolutem Pfad im login prompt. Weil das ganze u. U. so wichtig ist hätten deine Helfer auch ganz gerne vollständige Ein- wie Ausgaben aus der Konsole, wenn um Hilfe gerufen wird.
                                          und was ist das?:
                                          da_WoodyD
                                          da_WoodyD
                                          #78
                                          @homoran sagte in massive CPU Auslastung:
                                          dazu fehlen infos wie ich das rausfinden könnte... ich bin ja gewillt zu lernen. mach auch gerne beta-tests. (i know, masochist am produktiv system) bis jetzt konnte ich mir fast immer selbst helfen. jetzt steh ich an. ist halt so.
                                          33.2k
                                          84.4k
