  4. Test eCharts Adapter
    apollon77A
echarts
666 Beiträge 109 Kommentatoren 291.2k Aufrufe 84 Beobachtet
  • W WernerS
    hier das Ergebnis
    :~ $ iobroker -i
    iobroker [command]
    Commands:
      iobroker setup                                               Setup ioBroker
      iobroker start                                               Starts the js-controller
      iobroker stop                                                stops the js-controller
      iobroker restart                                             Restarts js-controller
      iobroker debug <adapter>[.<instance>]                        Starts a Node.js debugging session for the adapter instance
      iobroker info                                                Shows the host info
      iobroker logs [<adapter>]                                    Monitor log
      iobroker add <adapter> [desiredNumber]                       Add instance of adapter
      iobroker install <adapter>                                   Installs a specified adapter
      iobroker rebuild <adapter>|self                              Rebuilds a specified adapter
      iobroker url <url> [<name>]                                  Install adapter from specified url, e.g. GitHub
      iobroker del <adapter>                                       Remove adapter from system
      iobroker del <adapter>.<instance>                            Remove adapter instance
      iobroker update [<repositoryUrl>]                            Update repository and list adapters
      iobroker upgrade                                             Upgrade management
      iobroker upload                                              Upload management
      iobroker object                                              Object management
      iobroker state                                               State management
      iobroker message <adapter>[.instance] <command> [<message>]  Send message to adapter instance/s
      iobroker list <type> [<filter>]                              List all entries, like objects
      iobroker chmod <mode> <file>                                 Change file rights
      iobroker chown <user> <group> <file>                         Change file ownership
      iobroker touch <file>                                        Touch file
      iobroker rm <file>                                           Remove file
      iobroker file                                                File management
      iobroker user                                                User commands
      iobroker group                                               group management
      iobroker host <hostname>                                     Set host to given hostname
      iobroker set <adapter>.<instance>                            Change settings of adapter config
      iobroker license <license.file or license.text>              Update license by given file
      iobroker cert                                                Certificate management
      iobroker clean <yes>                                         Clears all objects and states
      iobroker backup                                              Create backup
      iobroker restore <backup name or path>                       Restore a specified backup
      iobroker validate <backup name or path>                      Validate a specified backup
      iobroker status [all|<adapter>.<instance>]                   Status of ioBroker or adapter instance
      iobroker repo [<name>]                                       Show repo information
      iobroker uuid                                                Show uuid of the installation
      iobroker unsetup                                             Reset license, installation secret and language
      iobroker fix                                                 Execute the installation fixer script, this updates your ioBroker installation
      iobroker multihost                                           Multihost management
      iobroker compact                                             compact group management
      iobroker plugin                                              Plugin management
      iobroker version [<adapter>]                                 Show version of js-controller or specified adapter
    Options:
          --help     Show help  [boolean]
      -v, --version  Show version  [boolean]
    :~ $ node -v
    v15.7.0
    :~ $ nodejs -v
    v15.7.0
    #256
    @werners sagte in Test eCharts Adapter:
    hier das Ergebnis
    nö!
    iobroker -i
    ist nicht
    @homoran sagte in Test eCharts Adapter:
    iobroker update -i
    aber das Grundübel ist deine grausame node/npm Basis.
    node -v v15.7.0
    ist eine Entwicklerversion (weil ungerade) und zusammen mit
    NPM version: 7.4.3
    nicht für ioBroker geeignet
    W 1 Antwort Letzte Antwort
      hier das Ergebnis
      nö!
      iobroker -i
      ist nicht
      iobroker update -i
      node -v v15.7.0
      NPM version: 7.4.3
      W
      W
      WernerS
      #257
      iobroker -i
      sorry für das iobroker -i
      was kann ich da jetzt tun? downgraden?
      Werner
      HomoranH W 2 Antworten Letzte Antwort
      • W WernerS
        iobroker -i
        Werner
        #258
        downgraden?
        solltest du unbedingt machen.
        jede weitere Fehlersuche ergibt vorher keinen Sinn
        • W WernerS
          iobroker -i
          Werner
          W
          W
          WernerS
          #259
          @werners
          habe gerade gesehen es gibt eine 16.
          ich schau mal wie das update geht und melde mich dann wieder.
          Werner
          • W WernerS
            @werners
            Werner
            #260
            Du hast aber schon gelesen, was ich geschrieben habe?
            Was steht denn bei dir im Info-Adapter zu deinem System?
              W
              W
              WernerS
              #261
              Den Info adapter sehe ich zwar kann aber keine Instanz anlegen. Ist der dann nicht auf meinem master?
              Werner
              • W WernerS
                Werner
                #262
                wo? ich sehe nichts ;-)
                ganz links in der Menüspalte sollte ein Eintrag (i) Info stehen
                Das wählst du aus
                  Das wählst du aus
                  W
                  W
                  WernerS
                  #263
                  ist wohl heute nicht so mein Tag. Ich hoffe jetzt ist es richtig :-)
                  iobroker-slave01
                  Plattform
                      linux
                  Betriebssystem
                      linux
                  Architektur
                      arm
                  CPUs
                  Geschwindigkeit
                      600 MHz
                  Modell
                      ARMv7 Processor rev 4 (v7l)
                  RAM
                      924.21 MB
                  System-Betriebszeit
                      01:18:00
                  Node.js
                      v15.14.0 (Die Version v15.x von Node.js wird derzeit nicht vollständig unterstützt. - Empfohlene Version v14.19.0)
                  NPM
                      7.7.6
                  Datenträgergröße
                      14.33 GB
                  freier Festplattenspeicher
                      10.81 GB
                  Anzahl der Adapter
                      390
                  Betriebszeit
                      16:09:32
                  Aktive Instanzen
                  location
                      /opt/iobroker/
                  Hostname
                      iobroker-slave01
                  iobroker
                  Plattform
                      linux
                  Betriebssystem
                      linux
                  Architektur
                      arm
                  CPUs
                  Geschwindigkeit
                      1200 MHz
                  Modell
                  RAM
                      924.84 MB
                  System-Betriebszeit
                      01:48:38
                  Node.js
                      v15.7.0 (Es gibt eine neuere Version: v15.14.0 Die Version v15.x von Node.js wird derzeit nicht vollständig unterstützt. - Empfohlene Version v14.19.0)
                  NPM
                      7.4.3
                  Datenträgergröße
                      14.33 GB
                      7.37 GB
                  Anzahl der Adapter
                      390
                  Betriebszeit
                      16:27:04
                  Aktive Instanzen
                      19
                  location
                      /opt/iobroker/
                  Hostname
                      iobroker
                  iobroker-slave02
                  Plattform
                      linux
                  Betriebssystem
                      linux
                  Architektur
                      arm64
                  CPUs
                  Geschwindigkeit
                      600 MHz
                  Modell
                      unknown
                  RAM
                      3.71 GB
                  System-Betriebszeit
                      01:15:05
                  Node.js
                      v16.13.2 (Es gibt eine neuere Version: v16.14.0 Die Version v16.x von Node.js wird derzeit nicht vollständig unterstützt. - Empfohlene Version v14.19.0)
                  NPM
                      8.4.1
                  Datenträgergröße
                      14.33 GB
                      11.03 GB
                  Anzahl der Adapter
                      390
                  Betriebszeit
                      03:04:26
                  Aktive Instanzen
                  location
                      /opt/iobroker/
                  Hostname
                      iobroker-slave02
                  • W WernerS
                    iobroker-slave01
                    Plattform
                        linux
                    Betriebssystem
                        linux
                    Architektur
                        arm
                    CPUs
                    Geschwindigkeit
                        600 MHz
                    Modell
                    RAM
                        924.21 MB
                    System-Betriebszeit
                        01:18:00
                    Node.js
                    NPM
                        7.7.6
                    Datenträgergröße
                        14.33 GB
                        10.81 GB
                    Anzahl der Adapter
                        390
                    Betriebszeit
                        16:09:32
                    Aktive Instanzen
                    location
                        /opt/iobroker/
                    Hostname
                        iobroker-slave01
                    iobroker
                    Plattform
                        linux
                    Betriebssystem
                        linux
                    Architektur
                        arm
                    CPUs
                    Geschwindigkeit
                        1200 MHz
                    Modell
                    RAM
                        924.84 MB
                    System-Betriebszeit
                        01:48:38
                    Node.js
                    NPM
                        7.4.3
                    Datenträgergröße
                        14.33 GB
                        7.37 GB
                    Anzahl der Adapter
                        390
                    Betriebszeit
                        16:27:04
                    Aktive Instanzen
                        19
                    location
                        /opt/iobroker/
                    Hostname
                        iobroker
                    iobroker-slave02
                    Plattform
                        linux
                    Betriebssystem
                        linux
                    Architektur
                        arm64
                    CPUs
                    Geschwindigkeit
                        600 MHz
                    Modell
                        unknown
                    RAM
                        3.71 GB
                    System-Betriebszeit
                        01:15:05
                    Node.js
                    NPM
                        8.4.1
                    Datenträgergröße
                        14.33 GB
                        11.03 GB
                    Anzahl der Adapter
                        390
                    Betriebszeit
                        03:04:26
                    Aktive Instanzen
                    location
                        /opt/iobroker/
                    Hostname
                        iobroker-slave02
                    #264
                    Node.js v15.14.0 (Die Version v15.x von Node.js wird derzeit nicht vollständig unterstützt. - Empfohlene Version v14.19.0)
                    und warum willst du dann auf v16?
                    nicht ganz.
                    Hat aber geklappt
                    • W WernerS
                      iobroker-slave01
                      Plattform
                          linux
                      Betriebssystem
                          linux
                      Architektur
                          arm
                      CPUs
                      Geschwindigkeit
                          600 MHz
                      Modell
                      RAM
                          924.21 MB
                      System-Betriebszeit
                          01:18:00
                      Node.js
                      NPM
                          7.7.6
                      Datenträgergröße
                          14.33 GB
                          10.81 GB
                      Anzahl der Adapter
                          390
                      Betriebszeit
                          16:09:32
                      Aktive Instanzen
                      location
                          /opt/iobroker/
                      Hostname
                          iobroker-slave01
                      iobroker
                      Plattform
                          linux
                      Betriebssystem
                          linux
                      Architektur
                          arm
                      CPUs
                      Geschwindigkeit
                          1200 MHz
                      Modell
                      RAM
                          924.84 MB
                      System-Betriebszeit
                          01:48:38
                      Node.js
                      NPM
                          7.4.3
                      Datenträgergröße
                          14.33 GB
                          7.37 GB
                      Anzahl der Adapter
                          390
                      Betriebszeit
                          16:27:04
                      Aktive Instanzen
                          19
                      location
                          /opt/iobroker/
                      Hostname
                          iobroker
                      iobroker-slave02
                      Plattform
                          linux
                      Betriebssystem
                          linux
                      Architektur
                          arm64
                      CPUs
                      Geschwindigkeit
                          600 MHz
                      Modell
                          unknown
                      RAM
                          3.71 GB
                      System-Betriebszeit
                          01:15:05
                      Node.js
                      NPM
                          8.4.1
                      Datenträgergröße
                          14.33 GB
                          11.03 GB
                      Anzahl der Adapter
                          390
                      Betriebszeit
                          03:04:26
                      Aktive Instanzen
                      location
                          /opt/iobroker/
                      Hostname
                          iobroker-slave02
                      Thomas BraunT
                      Thomas BraunT
                      #265
                      Nein. Ungerade nodeJS-Versionen willst du nicht.
                      Ich würde einheitlich auf allen Systemen die nodeJS@14 einsetzen.
                        W
                        W
                        WernerS
                        #266
                        ok das wusste ich nicht, werds mir aber merken.
                        Wie kann ich die up- bzw downgraden?
                        Hoffe dass klappt dann Problemlos, werde aber vorher von allen ein Image machen.
                        Werner
                        • W WernerS
                          Werner
                          Thomas BraunT
                          Thomas BraunT
                          #267
                          @werners
                          In meiner Signatur steht drin wie man durch die Versionen turnen kann.
                            @werners
                            W
                            W
                            WernerS
                            #268
                            Wer lesen kann ist im vorteil :-) Da habe ich natürlich nicht geschaut.
                            Werde es morgen früh gleich mal angehen und mich wieder melden.
                            Danke für den schnellen super guten Support
                            Werner
                            • W WernerS
                              Hallo
                              also der Adapter macht wirklich einen guten Eindruck ich habe aber 2 Fragen.
                              1.) Wie bekomme ich einen Bargraph hin?
                              2.) Ich habe 2 getrennte x Achsen. Er schreibt mir die Werte nicht nebeneinander sondern übereinander oder legt einen Wert über den anderen.
                              Werner
                              S
                              S
                              smartias
                              #269
                              @werners Hallo werners,
                              kannst du mir bitte sagen, wo und wie du die zwei x-Achsen eingestellt hast?
                              Für die erste Linie kann ich unten/oben/nichts einstellen, für die 2. Linie sehe ich dazu keine Option (E-Charts in der Version 1.0.3, Node.js
                              v14.19.0)
                              Matthias
                              • S smartias
                                v14.19.0)
                                Matthias
                                #270
                                @smartias sagte in Test eCharts Adapter:
                                hat er doch gar nicht
                                  @werners
                                  W
                                  W
                                  WernerS
                                  #271
                                  @Homoran
                                  Hallo
                                  jetzt sieht das so aus
                                  iobroker
                                  Plattform
                                      linux
                                  Betriebssystem
                                      linux
                                  Architektur
                                      arm
                                  CPUs
                                  Geschwindigkeit
                                      1200 MHz
                                  Modell
                                  RAM
                                      923.21 MB
                                  System-Betriebszeit
                                      02:47:40
                                  Node.js
                                      v14.19.0
                                  NPM
                                      6.14.16
                                  Datenträgergröße
                                      14.33 GB
                                      6.99 GB
                                  Anzahl der Adapter
                                      390
                                  Betriebszeit
                                      02:47:41
                                  Aktive Instanzen
                                  location
                                      /opt/iobroker/
                                  Hostname
                                      iobroker
                                  iobroker-slave02
                                  Plattform
                                      linux
                                  Betriebssystem
                                      linux
                                  Architektur
                                      arm64
                                  CPUs
                                  Geschwindigkeit
                                      800 MHz
                                  Modell
                                      unknown
                                  RAM
                                      3.71 GB
                                  System-Betriebszeit
                                      02:30:02
                                  Node.js
                                      v14.19.0
                                  NPM
                                      6.14.16
                                  Datenträgergröße
                                      14.33 GB
                                      11 GB
                                  Anzahl der Adapter
                                      390
                                  Betriebszeit
                                      02:32:21
                                  Aktive Instanzen
                                  location
                                      /opt/iobroker/
                                  Hostname
                                      iobroker-slave02
                                  iobroker-slave01
                                  Plattform
                                      linux
                                  Betriebssystem
                                      linux
                                  Architektur
                                      arm
                                  CPUs
                                  Geschwindigkeit
                                      1400 MHz
                                  Modell
                                  RAM
                                      924.21 MB
                                  System-Betriebszeit
                                      02:13:45
                                  Node.js
                                      v14.19.0
                                  NPM
                                      6.14.16
                                  Datenträgergröße
                                      14.33 GB
                                      10.03 GB
                                  Anzahl der Adapter
                                      390
                                  Betriebszeit
                                      00:01:55
                                  Aktive Instanzen
                                  location
                                      /opt/iobroker/
                                  Hostname
                                      iobroker-slave01
                                  Ich habe dann echarts installiert und vis neu gestartet. Und siehe da das widget ist da.
                                  Danke für eure Hilfe
                                  Werner
                                  • W WernerS
                                    @Homoran
                                    Hallo
                                    iobroker
                                    Plattform
                                        linux
                                    Betriebssystem
                                        linux
                                    Architektur
                                        arm
                                    CPUs
                                    Geschwindigkeit
                                        1200 MHz
                                    Modell
                                    RAM
                                        923.21 MB
                                    System-Betriebszeit
                                        02:47:40
                                    Node.js
                                        v14.19.0
                                    NPM
                                        6.14.16
                                    Datenträgergröße
                                        14.33 GB
                                        6.99 GB
                                    Anzahl der Adapter
                                        390
                                    Betriebszeit
                                        02:47:41
                                    Aktive Instanzen
                                    location
                                        /opt/iobroker/
                                    Hostname
                                        iobroker
                                    iobroker-slave02
                                    Plattform
                                        linux
                                    Betriebssystem
                                        linux
                                    Architektur
                                        arm64
                                    CPUs
                                    Geschwindigkeit
                                        800 MHz
                                    Modell
                                        unknown
                                    RAM
                                        3.71 GB
                                    System-Betriebszeit
                                        02:30:02
                                    Node.js
                                        v14.19.0
                                    NPM
                                        6.14.16
                                    Datenträgergröße
                                        14.33 GB
                                        11 GB
                                    Anzahl der Adapter
                                        390
                                    Betriebszeit
                                        02:32:21
                                    Aktive Instanzen
                                    location
                                        /opt/iobroker/
                                    Hostname
                                        iobroker-slave02
                                    iobroker-slave01
                                    Plattform
                                        linux
                                    Betriebssystem
                                        linux
                                    Architektur
                                        arm
                                    CPUs
                                    Geschwindigkeit
                                        1400 MHz
                                    Modell
                                    RAM
                                        924.21 MB
                                    System-Betriebszeit
                                        02:13:45
                                    Node.js
                                        v14.19.0
                                    NPM
                                        6.14.16
                                    Datenträgergröße
                                        14.33 GB
                                        10.03 GB
                                    Anzahl der Adapter
                                        390
                                    Betriebszeit
                                        00:01:55
                                    Aktive Instanzen
                                    location
                                        /opt/iobroker/
                                    Hostname
                                        iobroker-slave01
                                    Werner
                                    #272
                                    Node.js v14.19.0
                                    NPM 6.14.16
                                    so muss es sein!
                                      S
                                      S
                                      smartias
                                      #273
                                      ok, dann hatte ich den Post falsch verstanden:
                                      @werners said in Test eCharts Adapter:
                                      Wie kann ich denn die Daten von gestern mit denen von heute vergleichen? Hatte gehofft, zwei X-Achsen und eine davon mit Offset könnten das leisten. Ohne die zweite Achse plottet mir der Offset den gestrigen Tag neben/vor die heutigen Daten.
                                      • W WernerS
                                        Hallo homoran
                                        ich denke mal es wird ein Bargraph noch implementiert. Oder?
                                        Bis gefällt mir echarts sehr gut, vor allem die Bedienung ist gut und übersichtlich. Da hatte ich bei Flotcharts am Anfang erheblich Probleme mit.
                                        hier der gewünschte Screenshot
                                        Werner
                                        #274
                                        Nö! Da stand das schon so, aber in der Grafik war es nicht x sondern y
                                        • S
                                          S
                                          smartias
                                          #275
                                          Stimmt, ich wollte in dem Screenshot was sehen, was da gar nicht drin war :man-facepalming: .
                                          Hatte dort die Wochentage auf der X-Achse doppelt gesehen, weil es so schön zu meinem Problem passte, dass ich gerne eine zweite x-Achse nutzen würde.
                                          Da bleibt mir wohl nichts anderes übrig, als die Daten von gestern mit einem Offset von einem Tag zu speichern und dann diese zu nutzen.
                                          Oder ist es ein bug, so wie sich der Offset verhält? Ich hatte gehofft, dass die Daten von gestern (schwarze Linie, X-Offset = 1 Tag) heute um 00:00h anfangen.
                                          83.9k
