  4. Test eCharts Adapter
    apollon77A
echarts
666 Beiträge 109 Kommentatoren 290.5k Aufrufe 84 Beobachtet
  • W WernerS
    @sigi234
    Seltsam. Ich hatte die echarts instanz auf einem slave. Ich habe sie deinstalliert und eine auf dem master versucht zu erzeugen. Da kam dann das
    $ iobroker add echarts --host iobroker
    NPM version: 7.4.3
    npm install iobroker.echarts@1.0.3 --loglevel error --prefix "/opt/iobroker" (System call)
    npm ERR! code ENOTEMPTY
    npm ERR! syscall renamenpm ERR! path /opt/iobroker/node_modules/node-fetchnpm ERR! dest /opt/iobroker/node_modules/.node-fetch-blvKKu2bnpm ERR! errno -39
    npm ERR! ENOTEMPTY: directory not empty, rename '/opt/iobroker/node_modules/node-fetch' -> '/opt/iobroker/node_modules/.node-fetch-blvKKu2b'
    npm ERR! A complete log of this run can be found in:npm ERR! /home/iobroker/.npm/_logs/2022-02-13T15_27_26_679Z-debug.log
    host.iobroker Cannot install iobroker.echarts@1.0.3: 217
    ERROR: Process exited with code 25
    MOD-Edit: Code in code-tags gesetzt!
    Gruss
    Werner
    #254
    @werners sagte in Test eCharts Adapter:
    NPM version: 7.4.3
    iobroker update -i
    node -v
    nodejs -v
    W 1 Antwort Letzte Antwort
      NPM version: 7.4.3
      iobroker update -i
      node -v
      nodejs -v
      W
      W
      WernerS
      #255
      hier das Ergebnis
      :~ $ iobroker -i
      iobroker [command]
      Commands:
        iobroker setup                                               Setup ioBroker
        iobroker start                                               Starts the js-controller
        iobroker stop                                                stops the js-controller
        iobroker restart                                             Restarts js-controller
        iobroker debug <adapter>[.<instance>]                        Starts a Node.js debugging session for the adapter instance
        iobroker info                                                Shows the host info
        iobroker logs [<adapter>]                                    Monitor log
        iobroker add <adapter> [desiredNumber]                       Add instance of adapter
        iobroker install <adapter>                                   Installs a specified adapter
        iobroker rebuild <adapter>|self                              Rebuilds a specified adapter
        iobroker url <url> [<name>]                                  Install adapter from specified url, e.g. GitHub
        iobroker del <adapter>                                       Remove adapter from system
        iobroker del <adapter>.<instance>                            Remove adapter instance
        iobroker update [<repositoryUrl>]                            Update repository and list adapters
        iobroker upgrade                                             Upgrade management
        iobroker upload                                              Upload management
        iobroker object                                              Object management
        iobroker state                                               State management
        iobroker message <adapter>[.instance] <command> [<message>]  Send message to adapter instance/s
        iobroker list <type> [<filter>]                              List all entries, like objects
        iobroker chmod <mode> <file>                                 Change file rights
        iobroker chown <user> <group> <file>                         Change file ownership
        iobroker touch <file>                                        Touch file
        iobroker rm <file>                                           Remove file
        iobroker file                                                File management
        iobroker user                                                User commands
        iobroker group                                               group management
        iobroker host <hostname>                                     Set host to given hostname
        iobroker set <adapter>.<instance>                            Change settings of adapter config
        iobroker license <license.file or license.text>              Update license by given file
        iobroker cert                                                Certificate management
        iobroker clean <yes>                                         Clears all objects and states
        iobroker backup                                              Create backup
        iobroker restore <backup name or path>                       Restore a specified backup
        iobroker validate <backup name or path>                      Validate a specified backup
        iobroker status [all|<adapter>.<instance>]                   Status of ioBroker or adapter instance
        iobroker repo [<name>]                                       Show repo information
        iobroker uuid                                                Show uuid of the installation
        iobroker unsetup                                             Reset license, installation secret and language
        iobroker fix                                                 Execute the installation fixer script, this updates your ioBroker installation
        iobroker multihost                                           Multihost management
        iobroker compact                                             compact group management
        iobroker plugin                                              Plugin management
        iobroker version [<adapter>]                                 Show version of js-controller or specified adapter
      Options:
            --help     Show help  [boolean]
        -v, --version  Show version  [boolean]
      :~ $ node -v
      v15.7.0
      :~ $ nodejs -v
      v15.7.0
      • W WernerS
        hier das Ergebnis
        :~ $ iobroker -i
        iobroker [command]
        Commands:
        Options:
        :~ $ node -v
        v15.7.0
        :~ $ nodejs -v
        v15.7.0
        #256
        hier das Ergebnis
        nö!
        iobroker -i
        ist nicht
        @homoran sagte in Test eCharts Adapter:
        iobroker update -i
        aber das Grundübel ist deine grausame node/npm Basis.
        node -v v15.7.0
        ist eine Entwicklerversion (weil ungerade) und zusammen mit
        NPM version: 7.4.3
        nicht für ioBroker geeignet
          hier das Ergebnis
          nö!
          iobroker -i
          ist nicht
          iobroker update -i
          node -v v15.7.0
          NPM version: 7.4.3
          W
          W
          WernerS
          #257
          iobroker -i
          sorry für das iobroker -i
          was kann ich da jetzt tun? downgraden?
          Werner
          HomoranH W 2 Antworten Letzte Antwort
          • W WernerS
            iobroker -i
            Werner
            #258
            downgraden?
            solltest du unbedingt machen.
            jede weitere Fehlersuche ergibt vorher keinen Sinn
            • W WernerS
              iobroker -i
              Werner
              W
              W
              WernerS
              #259
              @werners
              habe gerade gesehen es gibt eine 16.
              ich schau mal wie das update geht und melde mich dann wieder.
              Werner
              • W WernerS
                @werners
                Werner
                #260
                Du hast aber schon gelesen, was ich geschrieben habe?
                Was steht denn bei dir im Info-Adapter zu deinem System?
                  W
                  W
                  WernerS
                  #261
                  Den Info adapter sehe ich zwar kann aber keine Instanz anlegen. Ist der dann nicht auf meinem master?
                  Werner
                  • W WernerS
                    Werner
                    #262
                    wo? ich sehe nichts ;-)
                    ganz links in der Menüspalte sollte ein Eintrag (i) Info stehen
                    Das wählst du aus
                      Das wählst du aus
                      W
                      W
                      WernerS
                      #263
                      ist wohl heute nicht so mein Tag. Ich hoffe jetzt ist es richtig :-)
                      iobroker-slave01
                      Plattform
                          linux
                      Betriebssystem
                          linux
                      Architektur
                          arm
                      CPUs
                      Geschwindigkeit
                          600 MHz
                      Modell
                          ARMv7 Processor rev 4 (v7l)
                      RAM
                          924.21 MB
                      System-Betriebszeit
                          01:18:00
                      Node.js
                          v15.14.0 (Die Version v15.x von Node.js wird derzeit nicht vollständig unterstützt. - Empfohlene Version v14.19.0)
                      NPM
                          7.7.6
                      Datenträgergröße
                          14.33 GB
                      freier Festplattenspeicher
                          10.81 GB
                      Anzahl der Adapter
                          390
                      Betriebszeit
                          16:09:32
                      Aktive Instanzen
                      location
                          /opt/iobroker/
                      Hostname
                          iobroker-slave01
                      iobroker
                      Plattform
                          linux
                      Betriebssystem
                          linux
                      Architektur
                          arm
                      CPUs
                      Geschwindigkeit
                          1200 MHz
                      Modell
                      RAM
                          924.84 MB
                      System-Betriebszeit
                          01:48:38
                      Node.js
                          v15.7.0 (Es gibt eine neuere Version: v15.14.0 Die Version v15.x von Node.js wird derzeit nicht vollständig unterstützt. - Empfohlene Version v14.19.0)
                      NPM
                          7.4.3
                      Datenträgergröße
                          14.33 GB
                          7.37 GB
                      Anzahl der Adapter
                          390
                      Betriebszeit
                          16:27:04
                      Aktive Instanzen
                          19
                      location
                          /opt/iobroker/
                      Hostname
                          iobroker
                      iobroker-slave02
                      Plattform
                          linux
                      Betriebssystem
                          linux
                      Architektur
                          arm64
                      CPUs
                      Geschwindigkeit
                          600 MHz
                      Modell
                          unknown
                      RAM
                          3.71 GB
                      System-Betriebszeit
                          01:15:05
                      Node.js
                          v16.13.2 (Es gibt eine neuere Version: v16.14.0 Die Version v16.x von Node.js wird derzeit nicht vollständig unterstützt. - Empfohlene Version v14.19.0)
                      NPM
                          8.4.1
                      Datenträgergröße
                          14.33 GB
                          11.03 GB
                      Anzahl der Adapter
                          390
                      Betriebszeit
                          03:04:26
                      Aktive Instanzen
                      location
                          /opt/iobroker/
                      Hostname
                          iobroker-slave02
                      • W WernerS
                        iobroker-slave01
                        Plattform
                            linux
                        Betriebssystem
                            linux
                        Architektur
                            arm
                        CPUs
                        Geschwindigkeit
                            600 MHz
                        Modell
                        RAM
                            924.21 MB
                        System-Betriebszeit
                            01:18:00
                        Node.js
                        NPM
                            7.7.6
                        Datenträgergröße
                            14.33 GB
                            10.81 GB
                        Anzahl der Adapter
                            390
                        Betriebszeit
                            16:09:32
                        Aktive Instanzen
                        location
                            /opt/iobroker/
                        Hostname
                            iobroker-slave01
                        iobroker
                        Plattform
                            linux
                        Betriebssystem
                            linux
                        Architektur
                            arm
                        CPUs
                        Geschwindigkeit
                            1200 MHz
                        Modell
                        RAM
                            924.84 MB
                        System-Betriebszeit
                            01:48:38
                        Node.js
                        NPM
                            7.4.3
                        Datenträgergröße
                            14.33 GB
                            7.37 GB
                        Anzahl der Adapter
                            390
                        Betriebszeit
                            16:27:04
                        Aktive Instanzen
                            19
                        location
                            /opt/iobroker/
                        Hostname
                            iobroker
                        iobroker-slave02
                        Plattform
                            linux
                        Betriebssystem
                            linux
                        Architektur
                            arm64
                        CPUs
                        Geschwindigkeit
                            600 MHz
                        Modell
                            unknown
                        RAM
                            3.71 GB
                        System-Betriebszeit
                            01:15:05
                        Node.js
                        NPM
                            8.4.1
                        Datenträgergröße
                            14.33 GB
                            11.03 GB
                        Anzahl der Adapter
                            390
                        Betriebszeit
                            03:04:26
                        Aktive Instanzen
                        location
                            /opt/iobroker/
                        Hostname
                            iobroker-slave02
                        #264
                        Node.js v15.14.0 (Die Version v15.x von Node.js wird derzeit nicht vollständig unterstützt. - Empfohlene Version v14.19.0)
                        und warum willst du dann auf v16?
                        nicht ganz.
                        Hat aber geklappt
                        • W WernerS
                          iobroker-slave01
                          Plattform
                              linux
                          Betriebssystem
                              linux
                          Architektur
                              arm
                          CPUs
                          Geschwindigkeit
                              600 MHz
                          Modell
                          RAM
                              924.21 MB
                          System-Betriebszeit
                              01:18:00
                          Node.js
                          NPM
                              7.7.6
                          Datenträgergröße
                              14.33 GB
                              10.81 GB
                          Anzahl der Adapter
                              390
                          Betriebszeit
                              16:09:32
                          Aktive Instanzen
                          location
                              /opt/iobroker/
                          Hostname
                              iobroker-slave01
                          iobroker
                          Plattform
                              linux
                          Betriebssystem
                              linux
                          Architektur
                              arm
                          CPUs
                          Geschwindigkeit
                              1200 MHz
                          Modell
                          RAM
                              924.84 MB
                          System-Betriebszeit
                              01:48:38
                          Node.js
                          NPM
                              7.4.3
                          Datenträgergröße
                              14.33 GB
                              7.37 GB
                          Anzahl der Adapter
                              390
                          Betriebszeit
                              16:27:04
                          Aktive Instanzen
                              19
                          location
                              /opt/iobroker/
                          Hostname
                              iobroker
                          iobroker-slave02
                          Plattform
                              linux
                          Betriebssystem
                              linux
                          Architektur
                              arm64
                          CPUs
                          Geschwindigkeit
                              600 MHz
                          Modell
                              unknown
                          RAM
                              3.71 GB
                          System-Betriebszeit
                              01:15:05
                          Node.js
                          NPM
                              8.4.1
                          Datenträgergröße
                              14.33 GB
                              11.03 GB
                          Anzahl der Adapter
                              390
                          Betriebszeit
                              03:04:26
                          Aktive Instanzen
                          location
                              /opt/iobroker/
                          Hostname
                              iobroker-slave02
                          Thomas BraunT
                          Thomas BraunT
                          #265
                          Nein. Ungerade nodeJS-Versionen willst du nicht.
                          Ich würde einheitlich auf allen Systemen die nodeJS@14 einsetzen.
                            W
                            W
                            WernerS
                            #266
                            ok das wusste ich nicht, werds mir aber merken.
                            Wie kann ich die up- bzw downgraden?
                            Hoffe dass klappt dann Problemlos, werde aber vorher von allen ein Image machen.
                            Werner
                            • W WernerS
                              Werner
                              Thomas BraunT
                              Thomas BraunT
                              #267
                              @werners
                              In meiner Signatur steht drin wie man durch die Versionen turnen kann.
                                @werners
                                W
                                W
                                WernerS
                                #268
                                Wer lesen kann ist im vorteil :-) Da habe ich natürlich nicht geschaut.
                                Werde es morgen früh gleich mal angehen und mich wieder melden.
                                Danke für den schnellen super guten Support
                                Werner
                                • W WernerS
                                  Hallo
                                  also der Adapter macht wirklich einen guten Eindruck ich habe aber 2 Fragen.
                                  1.) Wie bekomme ich einen Bargraph hin?
                                  2.) Ich habe 2 getrennte x Achsen. Er schreibt mir die Werte nicht nebeneinander sondern übereinander oder legt einen Wert über den anderen.
                                  Werner
                                  S
                                  S
                                  smartias
                                  #269
                                  @werners Hallo werners,
                                  kannst du mir bitte sagen, wo und wie du die zwei x-Achsen eingestellt hast?
                                  Für die erste Linie kann ich unten/oben/nichts einstellen, für die 2. Linie sehe ich dazu keine Option (E-Charts in der Version 1.0.3, Node.js
                                  v14.19.0)
                                  Matthias
                                  • S smartias
                                    v14.19.0)
                                    Matthias
                                    #270
                                    @smartias sagte in Test eCharts Adapter:
                                    hat er doch gar nicht
                                      @werners
                                      W
                                      W
                                      WernerS
                                      #271
                                      @Homoran
                                      Hallo
                                      jetzt sieht das so aus
                                      iobroker
                                      Plattform
                                          linux
                                      Betriebssystem
                                          linux
                                      Architektur
                                          arm
                                      CPUs
                                      Geschwindigkeit
                                          1200 MHz
                                      Modell
                                      RAM
                                          923.21 MB
                                      System-Betriebszeit
                                          02:47:40
                                      Node.js
                                          v14.19.0
                                      NPM
                                          6.14.16
                                      Datenträgergröße
                                          14.33 GB
                                          6.99 GB
                                      Anzahl der Adapter
                                          390
                                      Betriebszeit
                                          02:47:41
                                      Aktive Instanzen
                                      location
                                          /opt/iobroker/
                                      Hostname
                                          iobroker
                                      iobroker-slave02
                                      Plattform
                                          linux
                                      Betriebssystem
                                          linux
                                      Architektur
                                          arm64
                                      CPUs
                                      Geschwindigkeit
                                          800 MHz
                                      Modell
                                          unknown
                                      RAM
                                          3.71 GB
                                      System-Betriebszeit
                                          02:30:02
                                      Node.js
                                          v14.19.0
                                      NPM
                                          6.14.16
                                      Datenträgergröße
                                          14.33 GB
                                          11 GB
                                      Anzahl der Adapter
                                          390
                                      Betriebszeit
                                          02:32:21
                                      Aktive Instanzen
                                      location
                                          /opt/iobroker/
                                      Hostname
                                          iobroker-slave02
                                      iobroker-slave01
                                      Plattform
                                          linux
                                      Betriebssystem
                                          linux
                                      Architektur
                                          arm
                                      CPUs
                                      Geschwindigkeit
                                          1400 MHz
                                      Modell
                                      RAM
                                          924.21 MB
                                      System-Betriebszeit
                                          02:13:45
                                      Node.js
                                          v14.19.0
                                      NPM
                                          6.14.16
                                      Datenträgergröße
                                          14.33 GB
                                          10.03 GB
                                      Anzahl der Adapter
                                          390
                                      Betriebszeit
                                          00:01:55
                                      Aktive Instanzen
                                      location
                                          /opt/iobroker/
                                      Hostname
                                          iobroker-slave01
                                      Ich habe dann echarts installiert und vis neu gestartet. Und siehe da das widget ist da.
                                      Danke für eure Hilfe
                                      Werner
                                      • W WernerS
                                        @Homoran
                                        Hallo
                                        iobroker
                                        Plattform
                                            linux
                                        Betriebssystem
                                            linux
                                        Architektur
                                            arm
                                        CPUs
                                        Geschwindigkeit
                                            1200 MHz
                                        Modell
                                        RAM
                                            923.21 MB
                                        System-Betriebszeit
                                            02:47:40
                                        Node.js
                                            v14.19.0
                                        NPM
                                            6.14.16
                                        Datenträgergröße
                                            14.33 GB
                                            6.99 GB
                                        Anzahl der Adapter
                                            390
                                        Betriebszeit
                                            02:47:41
                                        Aktive Instanzen
                                        location
                                            /opt/iobroker/
                                        Hostname
                                            iobroker
                                        iobroker-slave02
                                        Plattform
                                            linux
                                        Betriebssystem
                                            linux
                                        Architektur
                                            arm64
                                        CPUs
                                        Geschwindigkeit
                                            800 MHz
                                        Modell
                                            unknown
                                        RAM
                                            3.71 GB
                                        System-Betriebszeit
                                            02:30:02
                                        Node.js
                                            v14.19.0
                                        NPM
                                            6.14.16
                                        Datenträgergröße
                                            14.33 GB
                                            11 GB
                                        Anzahl der Adapter
                                            390
                                        Betriebszeit
                                            02:32:21
                                        Aktive Instanzen
                                        location
                                            /opt/iobroker/
                                        Hostname
                                            iobroker-slave02
                                        iobroker-slave01
                                        Plattform
                                            linux
                                        Betriebssystem
                                            linux
                                        Architektur
                                            arm
                                        CPUs
                                        Geschwindigkeit
                                            1400 MHz
                                        Modell
                                        RAM
                                            924.21 MB
                                        System-Betriebszeit
                                            02:13:45
                                        Node.js
                                            v14.19.0
                                        NPM
                                            6.14.16
                                        Datenträgergröße
                                            14.33 GB
                                            10.03 GB
                                        Anzahl der Adapter
                                            390
                                        Betriebszeit
                                            00:01:55
                                        Aktive Instanzen
                                        location
                                            /opt/iobroker/
                                        Hostname
                                            iobroker-slave01
                                        Werner
                                        #272
                                        Node.js v14.19.0
                                        NPM 6.14.16
                                        so muss es sein!
                                          S
                                          S
                                          smartias
                                          #273
                                          ok, dann hatte ich den Post falsch verstanden:
                                          @werners said in Test eCharts Adapter:
                                          Wie kann ich denn die Daten von gestern mit denen von heute vergleichen? Hatte gehofft, zwei X-Achsen und eine davon mit Offset könnten das leisten. Ohne die zweite Achse plottet mir der Offset den gestrigen Tag neben/vor die heutigen Daten.
                                          83.9k
