  4. Test Adapter ioBroker.sainlogic v0.6.X GitHub/Latest
    6.4k
sainlogicwetterstationadapterws980wififroggit wh4000sh
326 Beiträge 60 Kommentatoren 102.1k Aufrufe 51 Beobachtet
  • FabioF Fabio
    @fogg alles gut mach dir bitte keinen Stress.👍
    2021-10-11 16:02:03.588 - info: sainlogic.0 (30283) Scheduler pulling for new data
    2021-10-11 16:02:03.668 - debug: sainlogic.0 (30283) Scheduler connected to weather station run 255,255,80,3,83
    2021-10-11 16:02:03.673 - debug: sainlogic.0 (30283) FW Scheduler Received data string: ffff501511456173795765617468657256312e352e39
    2021-10-11 16:02:03.674 - debug: sainlogic.0 (30283) Data Command received: 80 subcommand 69
    2021-10-11 16:02:03.674 - debug: sainlogic.0 (30283) Data object: {"softwaretype":"EasyWeatherV1.5.9"}
    2021-10-11 16:02:03.675 - info: sainlogic.0 (30283) Scheduler updating IOBroker states
    2021-10-11 16:02:03.675 - debug: sainlogic.0 (30283) Setting value from data for info.softwaretype to EasyWeatherV1.5.9
    2021-10-11 16:02:03.675 - debug: sainlogic.0 (30283) Scheduler connected to weather station run 255,255,11,0,6,4,4,25
    2021-10-11 16:02:03.687 - debug: sainlogic.0 (30283) FW Scheduler Received data string: ffff0b0050040100e1020093030059040093050093063307440827e40927e40a00110b00000c00000e0000000010000000021100000002120000003d130000003d140000003d150001d19616005e17000e77
    2021-10-11 16:02:03.687 - debug: sainlogic.0 (30283) Data Command received: 11 subcommand 4
    2021-10-11 16:02:03.688 - debug: sainlogic.0 (30283) Data object: {"indoortemp":225,"outdoortemp":147,"dewpointtemp":89,"windchilltemp":147,"heatindex":147,"indoorhumidity":51,"outdoorhumidity":68,"pressureabs":10212,"pressurerel":10212,"winddir":17,"windspeed":0,"windgustspeed":0,"rain":0,"dailyrain":2,"weeklyrain":2,"monthlyrain":61,"yearlyrain":61,"raintotal":61,"solarradiation":119190,"UVraw":94,"uvi":0}
    2021-10-11 16:02:03.688 - info: sainlogic.0 (30283) Scheduler updating IOBroker states
    2021-10-11 16:02:03.689 - debug: sainlogic.0 (30283) Setting value from data for weather.current.UVraw to 94
    2021-10-11 16:02:03.690 - debug: sainlogic.0 (30283) Setting value from data for weather.current.dailyrain to 0.2
    2021-10-11 16:02:03.690 - debug: sainlogic.0 (30283) Target for dailyrain unit is set: mm, using conversion: null
    2021-10-11 16:02:03.690 - debug: sainlogic.0 (30283) Setting value from data for weather.current.dewpointtemp to 8.9
    2021-10-11 16:02:03.691 - debug: sainlogic.0 (30283) Target for dewpointtemp unit is set: °C, using conversion: null
    2021-10-11 16:02:03.691 - debug: sainlogic.0 (30283) Setting value from data for weather.current.indoorhumidity to 51
    2021-10-11 16:02:03.691 - debug: sainlogic.0 (30283) Setting value from data for weather.current.indoortemp to 22.5
    2021-10-11 16:02:03.691 - debug: sainlogic.0 (30283) Target for indoortemp unit is set: °C, using conversion: null
    2021-10-11 16:02:03.692 - debug: sainlogic.0 (30283) Setting value from data for weather.current.monthlyrain to 6.1
    2021-10-11 16:02:03.692 - debug: sainlogic.0 (30283) Target for monthlyrain unit is set: mm, using conversion: null
    2021-10-11 16:02:03.692 - debug: sainlogic.0 (30283) Setting value from data for weather.current.outdoorhumidity to 68
    2021-10-11 16:02:03.692 - debug: sainlogic.0 (30283) Setting value from data for weather.current.outdoortemp to 14.7
    2021-10-11 16:02:03.693 - debug: sainlogic.0 (30283) Target for outdoortemp unit is set: °C, using conversion: null
    2021-10-11 16:02:03.693 - debug: sainlogic.0 (30283) Setting value from data for weather.current.pressureabs to 1021.2
    2021-10-11 16:02:03.693 - debug: sainlogic.0 (30283) Target for pressureabs unit is set: hPa, using conversion: null
    2021-10-11 16:02:03.694 - debug: sainlogic.0 (30283) Setting value from data for weather.current.pressurerel to 1021.2
    2021-10-11 16:02:03.695 - debug: sainlogic.0 (30283) Target for pressurerel unit is set: hPa, using conversion: null
    2021-10-11 16:02:03.695 - debug: sainlogic.0 (30283) Setting value from data for weather.current.solarradiation to 11919
    2021-10-11 16:02:03.695 - debug: sainlogic.0 (30283) Target for solarradiation unit is set: lx, using conversion: null
    2021-10-11 16:02:03.696 - debug: sainlogic.0 (30283) Setting value from data for weather.current.weeklyrain to 0.2
    2021-10-11 16:02:03.696 - debug: sainlogic.0 (30283) Target for weeklyrain unit is set: mm, using conversion: null
    2021-10-11 16:02:03.696 - debug: sainlogic.0 (30283) Setting value from data for weather.current.windchilltemp to 14.7
    2021-10-11 16:02:03.696 - debug: sainlogic.0 (30283) Target for windchilltemp unit is set: °C, using conversion: null
    2021-10-11 16:02:03.697 - debug: sainlogic.0 (30283) Setting value from data for weather.current.winddir to 17
    2021-10-11 16:02:03.697 - debug: sainlogic.0 (30283) Setting value from data for weather.current.yearlyrain to 6.1
    2021-10-11 16:02:03.697 - debug: sainlogic.0 (30283) Target for yearlyrain unit is set: mm, using conversion: null
    2021-10-11 16:02:03.698 - debug: sainlogic.0 (30283) Scheduler connected to weather station run 255,255,11,0,6,5,5,27
    2021-10-11 16:02:03.709 - debug: sainlogic.0 (30283) FW Scheduler Received data string: ffff0b00450501011a0200ec0300a30500ec0641076308281d09281d0b00290c005c0e0000005a1000000021110000003b120000003d130000003d15000d1b8216ffff17060254
    2021-10-11 16:02:03.709 - debug: sainlogic.0 (30283) Data Command received: 11 subcommand 5
    2021-10-11 16:02:03.709 - debug: sainlogic.0 (30283) Data object: {"indoortemp":282,"outdoortemp":236,"dewpointtemp":163,"heatindex":236,"indoorhumidity":65,"outdoorhumidity":99,"pressureabs":10269,"pressurerel":10269,"windspeed":41,"windgustspeed":92,"rain":90,"dailyrain":33,"weeklyrain":59,"monthlyrain":61,"yearlyrain":61,"solarradiation":859010,"UVraw":65535,"uvi":6}
    2021-10-11 16:02:03.710 - info: sainlogic.0 (30283) Scheduler updating IOBroker states
    2021-10-11 16:02:03.712 - debug: sainlogic.0 (30283) Setting value from data for weather.maxvalues.absolut.UVraw to 65535
    2021-10-11 16:02:03.712 - debug: sainlogic.0 (30283) Setting value from data for weather.maxvalues.absolut.dailyrain to 3.3
    2021-10-11 16:02:03.712 - debug: sainlogic.0 (30283) Target for dailyrain unit is set: mm, using conversion: null
    2021-10-11 16:02:03.712 - debug: sainlogic.0 (30283) Setting value from data for weather.maxvalues.absolut.dewpointtemp to 16.3
    2021-10-11 16:02:03.713 - debug: sainlogic.0 (30283) Target for dewpointtemp unit is set: °C, using conversion: null
    2021-10-11 16:02:03.713 - debug: sainlogic.0 (30283) Setting value from data for weather.maxvalues.absolut.indoorhumidity to 65
    2021-10-11 16:02:03.713 - debug: sainlogic.0 (30283) Setting value from data for weather.maxvalues.absolut.indoortemp to 28.2
    2021-10-11 16:02:03.713 - debug: sainlogic.0 (30283) Target for indoortemp unit is set: °C, using conversion: null
    2021-10-11 16:02:03.714 - debug: sainlogic.0 (30283) Setting value from data for weather.maxvalues.absolut.monthlyrain to 6.1
    2021-10-11 16:02:03.714 - debug: sainlogic.0 (30283) Target for monthlyrain unit is set: mm, using conversion: null
    2021-10-11 16:02:03.714 - debug: sainlogic.0 (30283) Setting value from data for weather.maxvalues.absolut.outdoorhumidity to 99
    2021-10-11 16:02:03.715 - debug: sainlogic.0 (30283) Setting value from data for weather.maxvalues.absolut.outdoortemp to 23.6
    2021-10-11 16:02:03.715 - debug: sainlogic.0 (30283) Target for outdoortemp unit is set: °C, using conversion: null
    2021-10-11 16:02:03.716 - debug: sainlogic.0 (30283) Setting value from data for weather.maxvalues.absolut.pressureabs to 1026.9
    2021-10-11 16:02:03.716 - debug: sainlogic.0 (30283) Target for pressureabs unit is set: hPa, using conversion: null
    2021-10-11 16:02:03.716 - debug: sainlogic.0 (30283) Setting value from data for weather.maxvalues.absolut.pressurerel to 1026.9
    2021-10-11 16:02:03.717 - debug: sainlogic.0 (30283) Target for pressurerel unit is set: hPa, using conversion: null
    2021-10-11 16:02:03.717 - debug: sainlogic.0 (30283) Setting value from data for weather.maxvalues.absolut.rain to 9
    2021-10-11 16:02:03.718 - debug: sainlogic.0 (30283) Target for rain unit is set: mm, using conversion: null
    2021-10-11 16:02:03.718 - debug: sainlogic.0 (30283) Setting value from data for weather.maxvalues.absolut.solarradiation to 85901
    2021-10-11 16:02:03.719 - debug: sainlogic.0 (30283) Target for solarradiation unit is set: lx, using conversion: null
    2021-10-11 16:02:03.719 - debug: sainlogic.0 (30283) Setting value from data for weather.maxvalues.absolut.uvi to 6
    2021-10-11 16:02:03.719 - debug: sainlogic.0 (30283) Setting value from data for weather.maxvalues.absolut.weeklyrain to 5.9
    2021-10-11 16:02:03.720 - debug: sainlogic.0 (30283) Target for weeklyrain unit is set: mm, using conversion: null
    2021-10-11 16:02:03.720 - debug: sainlogic.0 (30283) Setting value from data for weather.maxvalues.absolut.windgustspeed to 33.1
    2021-10-11 16:02:03.721 - debug: sainlogic.0 (30283) Target for windgustspeed unit is set: km/h, using conversion: null
    2021-10-11 16:02:03.721 - debug: sainlogic.0 (30283) Setting value from data for weather.maxvalues.absolut.windspeed to 14.8
    2021-10-11 16:02:03.722 - debug: sainlogic.0 (30283) Target for windspeed unit is set: km/h, using conversion: null
    2021-10-11 16:02:03.722 - debug: sainlogic.0 (30283) Setting value from data for weather.maxvalues.absolut.yearlyrain to 6.1
    2021-10-11 16:02:03.722 - debug: sainlogic.0 (30283) Target for yearlyrain unit is set: mm, using conversion: null
    2021-10-11 16:02:03.722 - debug: sainlogic.0 (30283) Scheduler connected to weather station run 255,255,11,0,6,6,6,29
    2021-10-11 16:02:03.731 - debug: sainlogic.0 (30283) FW Scheduler Received data string: ffff0b001c060100c40200150300130400150625072a0826cd0926cd64ef
    2021-10-11 16:02:03.732 - debug: sainlogic.0 (30283) Data Command received: 11 subcommand 6
    2021-10-11 16:02:03.733 - debug: sainlogic.0 (30283) Data object: {"indoortemp":196,"outdoortemp":21,"dewpointtemp":19,"windchilltemp":21,"indoorhumidity":37,"outdoorhumidity":42,"pressureabs":9933,"pressurerel":9933}
    2021-10-11 16:02:03.733 - info: sainlogic.0 (30283) Scheduler updating IOBroker states
    2021-10-11 16:02:03.734 - debug: sainlogic.0 (30283) Setting value from data for weather.minvalues.absolut.dewpointtemp to 1.9
    2021-10-11 16:02:03.735 - debug: sainlogic.0 (30283) Target for dewpointtemp unit is set: °C, using conversion: null
    2021-10-11 16:02:03.735 - debug: sainlogic.0 (30283) Setting value from data for weather.minvalues.absolut.indoorhumidity to 37
    2021-10-11 16:02:03.735 - debug: sainlogic.0 (30283) Setting value from data for weather.minvalues.absolut.indoortemp to 19.6
    2021-10-11 16:02:03.736 - debug: sainlogic.0 (30283) Target for indoortemp unit is set: °C, using conversion: null
    2021-10-11 16:02:03.736 - debug: sainlogic.0 (30283) Setting value from data for weather.minvalues.absolut.outdoorhumidity to 42
    2021-10-11 16:02:03.737 - debug: sainlogic.0 (30283) Setting value from data for weather.minvalues.absolut.outdoortemp to 2.1
    2021-10-11 16:02:03.737 - debug: sainlogic.0 (30283) Target for outdoortemp unit is set: °C, using conversion: null
    2021-10-11 16:02:03.738 - debug: sainlogic.0 (30283) Setting value from data for weather.minvalues.absolut.pressureabs to 993.3
    2021-10-11 16:02:03.738 - debug: sainlogic.0 (30283) Target for pressureabs unit is set: hPa, using conversion: null
    2021-10-11 16:02:03.739 - debug: sainlogic.0 (30283) Setting value from data for weather.minvalues.absolut.pressurerel to 993.3
    2021-10-11 16:02:03.739 - debug: sainlogic.0 (30283) Target for pressurerel unit is set: hPa, using conversion: null
    2021-10-11 16:02:03.739 - debug: sainlogic.0 (30283) Setting value from data for weather.minvalues.absolut.windchilltemp to 2.1
    2021-10-11 16:02:03.740 - debug: sainlogic.0 (30283) Target for windchilltemp unit is set: °C, using conversion: null
    2021-10-11 16:02:03.740 - debug: sainlogic.0 (30283) Scheduler connected to weather station run 255,255,11,0,6,7,7,31
    2021-10-11 16:02:03.769 - debug: sainlogic.0 (30283) FW Scheduler Received data string: ffff0b004d074100e40e1342009a0e124300760b0545009a0e1246360712476301054827f20a0a4927f20a0a4b00110e2c4c001a0e2c4e0000000c0823550005faa00c2b5600010c2a57030c2a44e0
    2021-10-11 16:02:03.770 - debug: sainlogic.0 (30283) Data Command received: 11 subcommand 7
    2021-10-11 16:02:03.770 - debug: sainlogic.0 (30283) Data object: {"indoortemp":228,"indoortemptime":3603,"outdoortemp":154,"outdoortemptime":3602,"dewpointtemp":118,"dewpointtemptime":2821,"windchilltemp":154,"windchilltemptime":3602,"indoorhumidity":54,"indoorhumiditytime":1810,"outdoorhumidity":99,"outdoorhumiditytime":261,"pressureabs":10226,"pressureabstime":2570,"pressurerel":10226,"pressurereltime":2570,"windspeed":17,"windspeedtime":3628,"windgustspeed":26,"windgustspeedtime":3628,"dailyrain":12,"dailyraintime":2083,"solarradiation":391840,"solarradiationtime":3115,"UVraw":1,"UVrawtime":3114,"uvi":3,"uvitime":3114}
    2021-10-11 16:02:03.771 - info: sainlogic.0 (30283) Scheduler updating IOBroker states
    2021-10-11 16:02:03.772 - debug: sainlogic.0 (30283) Setting value from data for weather.maxvalues.daily.UVraw to 1
    2021-10-11 16:02:03.773 - debug: sainlogic.0 (30283) Setting value from data for weather.maxvalues.daily.dailyrain to 1.2
    2021-10-11 16:02:03.773 - debug: sainlogic.0 (30283) Target for dailyrain unit is set: mm, using conversion: null
    2021-10-11 16:02:03.773 - debug: sainlogic.0 (30283) Setting value from data for weather.maxvalues.daily.dewpointtemp to 11.8
    2021-10-11 16:02:03.773 - debug: sainlogic.0 (30283) Target for dewpointtemp unit is set: °C, using conversion: null
    2021-10-11 16:02:03.774 - debug: sainlogic.0 (30283) Setting value from data for weather.maxvalues.daily.indoorhumidity to 54
    2021-10-11 16:02:03.774 - debug: sainlogic.0 (30283) Setting value from data for weather.maxvalues.daily.indoortemp to 22.8
    2021-10-11 16:02:03.774 - debug: sainlogic.0 (30283) Target for indoortemp unit is set: °C, using conversion: null
    2021-10-11 16:02:03.774 - debug: sainlogic.0 (30283) Setting value from data for weather.maxvalues.daily.outdoorhumidity to 99
    2021-10-11 16:02:03.775 - debug: sainlogic.0 (30283) Setting value from data for weather.maxvalues.daily.outdoortemp to 15.4
    2021-10-11 16:02:03.775 - debug: sainlogic.0 (30283) Target for outdoortemp unit is set: °C, using conversion: null
    2021-10-11 16:02:03.775 - debug: sainlogic.0 (30283) Setting value from data for weather.maxvalues.daily.pressureabs to 1022.6
    2021-10-11 16:02:03.775 - debug: sainlogic.0 (30283) Target for pressureabs unit is set: hPa, using conversion: null
    2021-10-11 16:02:03.776 - debug: sainlogic.0 (30283) Setting value from data for weather.maxvalues.daily.pressurerel to 1022.6
    2021-10-11 16:02:03.776 - debug: sainlogic.0 (30283) Target for pressurerel unit is set: hPa, using conversion: null
    2021-10-11 16:02:03.776 - debug: sainlogic.0 (30283) Setting value from data for weather.maxvalues.daily.solarradiation to 39184
    2021-10-11 16:02:03.776 - debug: sainlogic.0 (30283) Target for solarradiation unit is set: lx, using conversion: null
    2021-10-11 16:02:03.776 - debug: sainlogic.0 (30283) Setting value from data for weather.maxvalues.daily.uvi to 3
    2021-10-11 16:02:03.777 - debug: sainlogic.0 (30283) Setting value from data for weather.maxvalues.daily.windchilltemp to 15.4
    2021-10-11 16:02:03.777 - debug: sainlogic.0 (30283) Target for windchilltemp unit is set: °C, using conversion: null
    2021-10-11 16:02:03.777 - debug: sainlogic.0 (30283) Setting value from data for weather.maxvalues.daily.windgustspeed to 9.4
    2021-10-11 16:02:03.778 - debug: sainlogic.0 (30283) Target for windgustspeed unit is set: km/h, using conversion: null
    2021-10-11 16:02:03.778 - debug: sainlogic.0 (30283) Setting value from data for weather.maxvalues.daily.windspeed to 6.1
    2021-10-11 16:02:03.779 - debug: sainlogic.0 (30283) Target for windspeed unit is set: km/h, using conversion: null
    2021-10-11 16:02:03.779 - debug: sainlogic.0 (30283) Scheduler connected to weather station run 255,255,11,0,6,8,8,33
    2021-10-11 16:02:03.787 - debug: sainlogic.0 (30283) FW Scheduler Received data string: ffff0b002c084100ce0424420035012843003301284400350128462f000c47400e2c4827de06254927de062553dd
    2021-10-11 16:02:03.788 - debug: sainlogic.0 (30283) Data Command received: 11 subcommand 8
    2021-10-11 16:02:03.788 - debug: sainlogic.0 (30283) Data object: {"indoortemp":206,"indoortemptime":1060,"outdoortemp":53,"outdoortemptime":296,"dewpointtemp":51,"dewpointtemptime":296,"windchilltemp":53,"windchilltemptime":296,"indoorhumidity":47,"indoorhumidityime":12,"outdoorhumidity":64,"outdoorhumiditytime":3628,"pressureabs":10206,"pressureabstime":1573,"pressurerl":10206,"pressurereltime":1573}
    2021-10-11 16:02:03.789 - info: sainlogic.0 (30283) Scheduler updating IOBroker states
    2021-10-11 16:02:03.790 - debug: sainlogic.0 (30283) Setting value from data for weather.minvalues.daily.dewpointtemp to 5.1
    2021-10-11 16:02:03.790 - debug: sainlogic.0 (30283) Target for dewpointtemp unit is set: °C, using conversion: null
    2021-10-11 16:02:03.791 - debug: sainlogic.0 (30283) Setting value from data for weather.minvalues.daily.indoorhumidity to 47
    2021-10-11 16:02:03.791 - debug: sainlogic.0 (30283) Setting value from data for weather.minvalues.daily.indoortemp to 20.6
    2021-10-11 16:02:03.792 - debug: sainlogic.0 (30283) Target for indoortemp unit is set: °C, using conversion: null
    2021-10-11 16:02:03.792 - debug: sainlogic.0 (30283) Setting value from data for weather.minvalues.daily.outdoorhumidity to 64
    2021-10-11 16:02:03.792 - debug: sainlogic.0 (30283) Setting value from data for weather.minvalues.daily.outdoortemp to 5.3
    2021-10-11 16:02:03.793 - debug: sainlogic.0 (30283) Target for outdoortemp unit is set: °C, using conversion: null
    2021-10-11 16:02:03.793 - debug: sainlogic.0 (30283) Setting value from data for weather.minvalues.daily.pressureabs to 1020.6
    2021-10-11 16:02:03.794 - debug: sainlogic.0 (30283) Target for pressureabs unit is set: hPa, using conversion: null
    2021-10-11 16:02:03.794 - debug: sainlogic.0 (30283) Setting value from data for weather.minvalues.daily.windchilltemp to 5.3
    2021-10-11 16:02:03.795 - debug: sainlogic.0 (30283) Target for windchilltemp unit is set: °C, using conversion: null
    2021-10-11 16:02:03.799 - debug: sainlogic.0 (30283) FW Scheduler Connection closed
    N Offline
    N Offline
    Neo110
    #238
    @fa-bio ich habe das mit Blockly (siehe Post 125) gelöst
    FabioF 1 Antwort Letzte Antwort
    • N Neo110
      FabioF Offline
      FabioF Offline
      Fabio
      #239
      @neo110 Danke dir eine gute Lösung.
      Iobroker:
      • Matter over Thread Hilfe
      • L Offline
        loi83
        #240
        Hallo zusammen
        ich hab die aktuelle Version und bekomme folgende Fehlermeldung.
        ainlogic.0	2021-11-01 10:47:22.975	debug	(19535) FW Scheduler Connection closed
        sainlogic.0	2021-11-01 10:47:22.973	error	(19535) Connection error on 192.168.178.103:8097: Error: connect EALREADY 192.168.178.103:8097 - Local (192.168.178.36:59034)
        sainlogic.0	2021-11-01 10:47:22.972	info	(19535) Scheduler pulling for new data
        sainlogic.0	2021-11-01 10:46:22.971	info	(19535) Scheduler pulling for new data
        sainlogic.0	2021-11-01 10:45:22.974	debug	(19535) FW Scheduler Connection closed
        sainlogic.0	2021-11-01 10:45:22.972	error	(19535) Connection error on 192.168.178.103:8097: Error: connect EALREADY 192.168.178.103:8097 - Local (192.168.178.36:58304)
        sainlogic.0	2021-11-01 10:45:22.970	info	(19535) Scheduler pulling for new data
        sainlogic.0	2021-11-01 10:44:22.969	info	(19535) Scheduler pulling for new data
        sainlogic.0	2021-11-01 10:43:22.973	debug	(19535) FW Scheduler Connection closed
        sainlogic.0	2021-11-01 10:43:22.971	error	(19535) Connection error on 192.168.178.103:8097: Error: connect EALREADY 192.168.178.103:8097 - Local (192.168.178.36:57516)
        sainlogic.0	2021-11-01 10:43:22.968	info	(19535) Scheduler pulling for new data
        sainlogic.0	2021-11-01 10:42:22.968	info	(19535) Scheduler pulling for new data
        sainlogic.0	2021-11-01 10:41:22.971	info	(19535) Starting Listener
        sainlogic.0	2021-11-01 10:41:22.970	debug	(19535) Forward URL:
        sainlogic.0	2021-11-01 10:41:22.969	debug	(19535) Listener protocol: wunderground
        sainlogic.0	2021-11-01 10:41:22.969	debug	(19535) Listener path: /weatherstation/updateweatherstation.php?
        sainlogic.0	2021-11-01 10:41:22.969	debug	(19535) Listener port: 8097
        sainlogic.0	2021-11-01 10:41:22.968	debug	(19535) Listener IP: 0.0.0.0
        sainlogic.0	2021-11-01 10:41:22.967	debug	(19535) Scheduler Interval: 60
        sainlogic.0	2021-11-01 10:41:22.967	debug	(19535) Weatherstation port: 8097
        sainlogic.0	2021-11-01 10:41:22.966	debug	(19535) Weatherstation IP: 192.168.178.103
        sainlogic.0	2021-11-01 10:41:22.965	info	(19535) Scheduler call ws_getcurrent activated
        sainlogic.0	2021-11-01 10:41:22.964	info	(19535) Scheduler call ws_getfirmware activated
        sainlogic.0	2021-11-01 10:41:22.963	info	(19535) Starting Scheduler
        Das Kuriose daran ist, das es am Anfang funktioniert hat, als sich die Temperatur nicht mehr änderte fand ich diesen Error vor. Neustart von Adapter und Container brachten keine Lösung.
        Gruß Michi
        • L loi83
          Hallo zusammen
          FabioF Offline
          FabioF Offline
          Fabio
          #241
          @loi83 er kann sich wohl nicht mit der IP Adresse deiner Wetterstation verbinden. Ist sie denn Online?
          Iobroker:
          L 1 Antwort Letzte Antwort
          • FabioF Fabio
            loi83
            schrieb am zuletzt editiert von loi83
            #242
            @fa-bio ja eigentlich schon. Zumindest kann ich in der App drauf zugreifen und die Daten werden auch an Wunderground übermittelt.
            ##EDIT##
            Hab das Display mal vom Strom, jetzt gehts wieder 🤦
            Gruß Michi
            • L loi83
              ##EDIT##
              FabioF Offline
              FabioF Offline
              Fabio
              #243
              @loi83 Prima 👍
              Iobroker:
              W 1 Antwort Letzte Antwort
              • FabioF Fabio
                @loi83 Prima 👍
                W Offline
                W Offline
                Waldmensch
                #244
                habe den Adapter installiert und greife die Daten von meiner ELV WS980 ab. Den Listener krieg ich nicht zum laufen, aber der Abruf rockt wie er soll. Das einzige, was stört ist, dass ich bei jedem Abruf folgendes Warning im Log hab. Vielleicht kann da mal wer nachschauen
                State value to set for "sainlogic.0.weather.maxvalues.absolut.UVraw" has value "65535" greater than max "2000"
                  Blade1987
                  #245
                  @Fogg
                  Du hast ja vor langer Zeit mal bezüglich der Weiterleitung geschrieben.
                  Ich versuche diese verzweifelt einzurichten.
                  Benötige die Weiterleitung der EcoWitt Rohdaten an internen Server mit Port 45000 ( an diesem werden die Daten auch Empfangen )
                  Habe es mit sämtlichen URL´s versucht, wird aber nix rausgeschickt.
                  Im js habe ich ein paar Debugwerte hinzugefügt um rauszufinden wo es hackt.
                  Komme immer auf diese Ecke
                  got(fwd_url, { searchParams: json_response, method: 'GET', retry: 0 }).then(response => {
                  this.adapter.log.info('response.bodyurl' + response.body.url);
                  this.adapter.log.info('response.body.explanation' + response.body.explanation);
                  Die bodyurl sowohl als auch die explanation gibt er im Log als undefined aus.
                  Leider kenne ich mich mit got gar nicht aus und dem JS noch nicht zu tief um den Fehler zu finden.
                  Im Endeffekt soll er ja wie du beschrieben hast einfach den Request 1:1 an einen weiteren Host weitergeben.
                  Vielen Dank im Voraus und Vielen Dank für den Umfangreichen Adapter
                  PS: Genutzt wird die DNT Profi Wetterstation falls das noch interessant wäre
                  Liebe Grüße
                  Marco
                  • wendy2702W Online
                    wendy2702W Online
                    #246
                    Sehe ich das richtig das der Adapter den Weg ins Stable noch nicht geschafft hat?
                    • wendy2702W wendy2702
                      #247
                      @wendy2702
                      Müsste drin sein:
                      sainlogic:
                      github:	0.8.1
                      latest:	0.8.1 for 27 days
                      stable:	0.8.1 for 27 days
                      • wendy2702W Online
                        wendy2702W Online
                        #248
                        Adapter installiert. Als Protokoll Ecowitt ausgewählt weil da eigentlich auch der Batteriestatus übertragen wird.
                        Wenn ich auf Scheduler stelle sieht es bei meiner W830 so im log aus:
                        2022-02-10 18:02:28.044  - info: sainlogic.0 (4190) starting. Version 0.8.1 (non-npm: phifogg/ioBroker.sainlogic#9e7d2bc23ed5074f4a5d6d58a74764418f20b70e) in /opt/iobroker/node_modules/iobroker.sainlogic, node: v14.19.0, js-controller: 4.0.7
                        2022-02-10 18:02:28.079  - info: sainlogic.0 (4190) Starting Scheduler
                        2022-02-10 18:02:28.080  - info: sainlogic.0 (4190) Scheduler call ws_getfirmware activated
                        2022-02-10 18:02:28.080  - info: sainlogic.0 (4190) Scheduler call ws_getcurrent activated
                        2022-02-10 18:02:28.080  - info: sainlogic.0 (4190) Scheduler call ws_getmax activated
                        2022-02-10 18:02:28.080  - info: sainlogic.0 (4190) Scheduler call ws_getmin activated
                        2022-02-10 18:02:28.081  - info: sainlogic.0 (4190) Scheduler call ws_getmaxdaily activated
                        2022-02-10 18:02:28.081  - debug: sainlogic.0 (4190) Weatherstation IP: 192.168.178.137
                        2022-02-10 18:02:28.081  - debug: sainlogic.0 (4190) Weatherstation port: 45000
                        2022-02-10 18:02:28.081  - debug: sainlogic.0 (4190) Scheduler Interval: 30
                        2022-02-10 18:02:58.081  - info: sainlogic.0 (4190) Scheduler pulling for new data
                        2022-02-10 18:02:58.096  - debug: sainlogic.0 (4190) Scheduler connected to weather station run 255,255,80,3,83
                        2022-02-10 18:02:58.099  - debug: sainlogic.0 (4190) FW Scheduler Received data string: ffff501511456173795765617468657256312e362e31
                        2022-02-10 18:02:58.100  - debug: sainlogic.0 (4190) Data Command received: 80 subcommand 69
                        2022-02-10 18:02:58.101  - debug: sainlogic.0 (4190) Data object: {"softwaretype":"EasyWeatherV1.6.1"}
                        2022-02-10 18:02:58.101  - info: sainlogic.0 (4190) Scheduler updating IOBroker states
                        2022-02-10 18:02:58.102  - debug: sainlogic.0 (4190) Setting value from data for info.softwaretype to EasyWeatherV1.6.1
                        2022-02-10 18:02:58.102  - debug: sainlogic.0 (4190) Scheduler connected to weather station run 255,255,11,0,6,4,4,25
                        2022-02-10 18:03:28.081  - info: sainlogic.0 (4190) Scheduler pulling for new data
                        2022-02-10 18:03:28.082  - debug: sainlogic.0 (4190) Scheduler connected to weather station run 255,255,80,3,83
                        2022-02-10 18:03:28.084  - debug: sainlogic.0 (4190) FW Scheduler Received data string: ffff501511456173795765617468657256312e362e31
                        2022-02-10 18:03:28.085  - debug: sainlogic.0 (4190) Data Command received: 80 subcommand 69
                        2022-02-10 18:03:28.085  - debug: sainlogic.0 (4190) Data object: {"softwaretype":"EasyWeatherV1.6.1"}
                        2022-02-10 18:03:28.085  - info: sainlogic.0 (4190) Scheduler updating IOBroker states
                        2022-02-10 18:03:28.085  - debug: sainlogic.0 (4190) Setting value from data for info.softwaretype to EasyWeatherV1.6.1
                        2022-02-10 18:03:28.086  - debug: sainlogic.0 (4190) Scheduler connected to weather station run 255,255,11,0,6,4,4,25
                        2022-02-10 18:03:58.081  - info: sainlogic.0 (4190) Scheduler pulling for new data
                        2022-02-10 18:03:58.083  - error: sainlogic.0 (4190) Connection error on 192.168.178.137:45000: Error: connect EISCONN 192.168.178.137:45000 - Local (192.168.178.18:57034)
                        2022-02-10 18:03:58.085  - debug: sainlogic.0 (4190) FW Scheduler Connection closed
                        2022-02-10 18:04:28.081  - info: sainlogic.0 (4190) Scheduler pulling for new data
                        2022-02-10 18:04:28.085  - debug: sainlogic.0 (4190) Scheduler connected to weather station run 255,255,80,3,83
                        2022-02-10 18:04:28.100  - debug: sainlogic.0 (4190) FW Scheduler Received data string: ffff501511456173795765617468657256312e362e31
                        2022-02-10 18:04:28.101  - debug: sainlogic.0 (4190) Data Command received: 80 subcommand 69
                        2022-02-10 18:04:28.101  - debug: sainlogic.0 (4190) Data object: {"softwaretype":"EasyWeatherV1.6.1"}
                        2022-02-10 18:04:28.101  - info: sainlogic.0 (4190) Scheduler updating IOBroker states
                        2022-02-10 18:04:28.102  - debug: sainlogic.0 (4190) Setting value from data for info.softwaretype to EasyWeatherV1.6.1
                        2022-02-10 18:04:28.102  - debug: sainlogic.0 (4190) Scheduler connected to weather station run 255,255,11,0,6,4,4,25
                        2022-02-10 18:04:28.104  - debug: sainlogic.0 (4190) FW Scheduler Received data string: ffff501511456173795765617468657256312e362e31
                        2022-02-10 18:04:28.104  - debug: sainlogic.0 (4190) Data Command received: 80 subcommand 69
                        2022-02-10 18:04:28.105  - debug: sainlogic.0 (4190) Data object: {"softwaretype":"EasyWeatherV1.6.1"}
                        2022-02-10 18:04:28.106  - info: sainlogic.0 (4190) Scheduler updating IOBroker states
                        2022-02-10 18:04:28.106  - debug: sainlogic.0 (4190) Setting value from data for info.softwaretype to EasyWeatherV1.6.1
                        2022-02-10 18:04:28.107  - debug: sainlogic.0 (4190) Scheduler connected to weather station run 255,255,11,0,6,5,5,27
                        2022-02-10 18:04:58.081  - info: sainlogic.0 (4190) Scheduler pulling for new data
                        2022-02-10 18:04:58.082  - debug: sainlogic.0 (4190) Scheduler connected to weather station run 255,255,80,3,83
                        2022-02-10 18:04:58.092  - debug: sainlogic.0 (4190) FW Scheduler Received data string: ffff501511456173795765617468657256312e362e31
                        2022-02-10 18:04:58.092  - debug: sainlogic.0 (4190) Data Command received: 80 subcommand 69
                        2022-02-10 18:04:58.092  - debug: sainlogic.0 (4190) Data object: {"softwaretype":"EasyWeatherV1.6.1"}
                        2022-02-10 18:04:58.092  - info: sainlogic.0 (4190) Scheduler updating IOBroker states
                        2022-02-10 18:04:58.093  - debug: sainlogic.0 (4190) Setting value from data for info.softwaretype to EasyWeatherV1.6.1
                        2022-02-10 18:04:58.093  - debug: sainlogic.0 (4190) Scheduler connected to weather station run 255,255,11,0,6,4,4,25
                        2022-02-10 18:05:28.081  - info: sainlogic.0 (4190) Scheduler pulling for new data
                        2022-02-10 18:05:28.082  - error: sainlogic.0 (4190) Connection error on 192.168.178.137:45000: Error: connect EISCONN 192.168.178.137:45000 - Local (192.168.178.18:57768)
                        2022-02-10 18:05:28.085  - debug: sainlogic.0 (4190) FW Scheduler Connection closed
                        2022-02-10 18:05:58.082  - info: sainlogic.0 (4190) Scheduler pulling for new data
                        Und so in den Objecten:
                        Stelle ich auf Listener um kommt das:
                        2022-02-10 18:12:27.844  - debug: sainlogic.0 (4622) States create System PubSub Client
                        2022-02-10 18:12:27.844  - debug: sainlogic.0 (4622) States create User PubSub Client
                        2022-02-10 18:12:27.885  - debug: sainlogic.0 (4622) States connected to redis: 0.0.0.0:9000
                        2022-02-10 18:12:28.197  - info: sainlogic.0 (4622) starting. Version 0.8.1 (non-npm: phifogg/ioBroker.sainlogic#9e7d2bc23ed5074f4a5d6d58a74764418f20b70e) in /opt/iobroker/node_modules/iobroker.sainlogic, node: v14.19.0, js-controller: 4.0.7
                        2022-02-10 18:12:28.230  - debug: sainlogic.0 (4622) Listener IP: 192.168.178.18
                        2022-02-10 18:12:28.230  - debug: sainlogic.0 (4622) Listener port: 45000
                        2022-02-10 18:12:28.230  - debug: sainlogic.0 (4622) Listener path: /weatherstation/updateweatherstation.php
                        2022-02-10 18:12:28.230  - debug: sainlogic.0 (4622) Listener protocol: ecowitt
                        2022-02-10 18:12:28.231  - debug: sainlogic.0 (4622) Forward URL:
                        2022-02-10 18:12:28.231  - info: sainlogic.0 (4622) Starting Listener
                        2022-02-10 18:12:33.771  - debug: sainlogic.0 (4622) Listener body is PASSKEY=6E8D338577B841F7DC608157C88988C7&stationtype=EasyWeatherV1.6.1&dateutc=2022-02-10+17:12:31&tempinf=71.1&humidityin=47&baromrelin=30.225&baromabsin=29.743&tempf=42.3&humidity=95&winddir=253&windspeedmph=0.7&windgustmph=1.1&maxdailygust=13.6&rainratein=0.000&eventrainin=0.110&hourlyrainin=0.000&dailyrainin=0.122&weeklyrainin=1.551&monthlyrainin=1.772&totalrainin=68.295&solarradiation=0.00&uv=0&wh65batt=0&freq=868M&model=WS2900_V2.01.10
                        2022-02-10 18:12:33.772  - debug: sainlogic.0 (4622) No mapping found for dataelement: PASSKEY
                        2022-02-10 18:12:33.773  - debug: sainlogic.0 (4622) Extracting value for info.softwaretype(stationtype)
                        2022-02-10 18:12:33.773  - debug: sainlogic.0 (4622) No mapping found for dataelement: dateutc
                        2022-02-10 18:12:33.773  - debug: sainlogic.0 (4622) Extracting value for weather.current.indoortemp(tempinf)
                        2022-02-10 18:12:33.776  - debug: sainlogic.0 (4622) Extracting value for weather.current.indoorhumidity(humidityin)
                        2022-02-10 18:12:33.777  - debug: sainlogic.0 (4622) Extracting value for weather.current.pressurerel(baromrelin)
                        2022-02-10 18:12:33.777  - debug: sainlogic.0 (4622) Extracting value for weather.current.pressureabs(baromabsin)
                        2022-02-10 18:12:33.778  - debug: sainlogic.0 (4622) Extracting value for weather.current.outdoortemp(tempf)
                        2022-02-10 18:12:33.778  - debug: sainlogic.0 (4622) Extracting value for weather.current.outdoorhumidity(humidity)
                        2022-02-10 18:12:33.778  - debug: sainlogic.0 (4622) Extracting value for weather.current.winddir(winddir)
                        2022-02-10 18:12:33.778  - debug: sainlogic.0 (4622) Extracting value for weather.current.windspeed(windspeedmph)
                        2022-02-10 18:12:33.779  - debug: sainlogic.0 (4622) Extracting value for weather.current.windgustspeed(windgustmph)
                        2022-02-10 18:12:33.779  - debug: sainlogic.0 (4622) Extracting value for weather.current.maxdailygust(maxdailygust)
                        2022-02-10 18:12:33.779  - debug: sainlogic.0 (4622) Extracting value for weather.current.rain(rainratein)
                        2022-02-10 18:12:33.780  - debug: sainlogic.0 (4622) No mapping found for dataelement: eventrainin
                        2022-02-10 18:12:33.780  - debug: sainlogic.0 (4622) No mapping found for dataelement: hourlyrainin
                        2022-02-10 18:12:33.780  - debug: sainlogic.0 (4622) Extracting value for weather.current.dailyrain(dailyrainin)
                        2022-02-10 18:12:33.780  - debug: sainlogic.0 (4622) Extracting value for weather.current.weeklyrain(weeklyrainin)
                        2022-02-10 18:12:33.780  - debug: sainlogic.0 (4622) Extracting value for weather.current.monthlyrain(monthlyrainin)
                        2022-02-10 18:12:33.781  - debug: sainlogic.0 (4622) No mapping found for dataelement: totalrainin
                        2022-02-10 18:12:33.781  - debug: sainlogic.0 (4622) Extracting value for weather.current.solarradiation(solarradiation)
                        2022-02-10 18:12:33.781  - debug: sainlogic.0 (4622) Extracting value for weather.current.uvi(uv)
                        2022-02-10 18:12:33.781  - debug: sainlogic.0 (4622) No mapping found for dataelement: wh65batt
                        2022-02-10 18:12:33.781  - debug: sainlogic.0 (4622) Extracting value for info.freq(freq)
                        2022-02-10 18:12:33.781  - debug: sainlogic.0 (4622) Extracting value for info.model(model)
                        2022-02-10 18:12:33.782  - debug: sainlogic.0 (4622) Setting value from data for info.softwaretype to EasyWeatherV1.6.1
                        2022-02-10 18:12:33.782  - debug: sainlogic.0 (4622) Setting value from data for weather.current.indoortemp to 21.7
                        2022-02-10 18:12:33.783  - debug: sainlogic.0 (4622) Target for indoortemp unit is set: °C, using conversion: null
                        2022-02-10 18:12:33.783  - debug: sainlogic.0 (4622) Setting value from data for weather.current.indoorhumidity to 47
                        2022-02-10 18:12:33.783  - debug: sainlogic.0 (4622) Setting value from data for weather.current.pressurerel to 1023.4
                        2022-02-10 18:12:33.783  - debug: sainlogic.0 (4622) Target for pressurerel unit is set: hPa, using conversion: null
                        2022-02-10 18:12:33.783  - debug: sainlogic.0 (4622) Setting value from data for weather.current.pressureabs to 1007.1
                        2022-02-10 18:12:33.783  - debug: sainlogic.0 (4622) Target for pressureabs unit is set: hPa, using conversion: null
                        2022-02-10 18:12:33.784  - debug: sainlogic.0 (4622) Setting value from data for weather.current.outdoortemp to 5.7
                        2022-02-10 18:12:33.784  - debug: sainlogic.0 (4622) Target for outdoortemp unit is set: °C, using conversion: null
                        2022-02-10 18:12:33.784  - debug: sainlogic.0 (4622) Setting value from data for weather.current.outdoorhumidity to 95
                        2022-02-10 18:12:33.784  - debug: sainlogic.0 (4622) Setting value from data for weather.current.winddir to 253
                        2022-02-10 18:12:33.784  - debug: sainlogic.0 (4622) Setting value from data for weather.current.windspeed to 1.1
                        2022-02-10 18:12:33.785  - debug: sainlogic.0 (4622) Target for windspeed unit is set: km/h, using conversion: null
                        2022-02-10 18:12:33.785  - debug: sainlogic.0 (4622) Setting value from data for weather.current.windgustspeed to 1.8
                        2022-02-10 18:12:33.785  - debug: sainlogic.0 (4622) Target for windgustspeed unit is set: km/h, using conversion: null
                        2022-02-10 18:12:33.785  - debug: sainlogic.0 (4622) Setting value from data for weather.current.maxdailygust to 21.9
                        2022-02-10 18:12:33.785  - debug: sainlogic.0 (4622) Target for maxdailygust unit is set: km/h, using conversion: null
                        2022-02-10 18:12:33.785  - debug: sainlogic.0 (4622) Setting value from data for weather.current.rain to 0
                        2022-02-10 18:12:33.785  - debug: sainlogic.0 (4622) Target for rain unit is set: mm, using conversion: null
                        2022-02-10 18:12:33.786  - debug: sainlogic.0 (4622) Setting value from data for weather.current.dailyrain to 3.1
                        2022-02-10 18:12:33.786  - debug: sainlogic.0 (4622) Target for dailyrain unit is set: mm, using conversion: null
                        2022-02-10 18:12:33.786  - debug: sainlogic.0 (4622) Setting value from data for weather.current.weeklyrain to 39.4
                        2022-02-10 18:12:33.786  - debug: sainlogic.0 (4622) Target for weeklyrain unit is set: mm, using conversion: null
                        2022-02-10 18:12:33.786  - debug: sainlogic.0 (4622) Setting value from data for weather.current.monthlyrain to 45
                        2022-02-10 18:12:33.786  - debug: sainlogic.0 (4622) Target for monthlyrain unit is set: mm, using conversion: null
                        2022-02-10 18:12:33.786  - debug: sainlogic.0 (4622) Setting value from data for weather.current.solarradiation to 0
                        2022-02-10 18:12:33.786  - debug: sainlogic.0 (4622) Target for solarradiation unit is set: lx, using conversion: null
                        2022-02-10 18:12:33.787  - debug: sainlogic.0 (4622) Setting value from data for weather.current.uvi to 0
                        2022-02-10 18:12:33.787  - debug: sainlogic.0 (4622) Setting value from data for info.freq to 868M
                        2022-02-10 18:12:33.787  - debug: sainlogic.0 (4622) Setting value from data for info.model to WS2900_V2.01.10
                        2022-02-10 18:12:33.787  - debug: sainlogic.0 (4622) Listener received EW update: {"PASSKEY":"6E8D338577B841F7DC608157C88988C7","stationtype":"EasyWeatherV1.6.1","dateutc":"2022-02-10 17:12:31","tempinf":"71.1","humidityin":"47","baromrelin":"30.225","baromabsin":"29.743","tempf":"42.3","humidity":"95","winddir":"253","windspeedmph":"0.7","windgustmph":"1.1","maxdailygust":"13.6","rainratein":"0.000","eventrainin":"0.110","hourlyrainin":"0.000","dailyrainin":"0.122","weeklyrainin":"1.551","monthlyrainin":"1.772","totalrainin":"68.295","solarradiation":"0.00","uv":"0","wh65batt":"0","freq":"868M","model":"WS2900_V2.01.10"}
                        2022-02-10 18:13:13.798  - debug: sainlogic.0 (4622) Listener body is PASSKEY=6E8D338577B841F7DC608157C88988C7&stationtype=EasyWeatherV1.6.1&dateutc=2022-02-10+17:13:10&tempinf=71.1&humidityin=47&baromrelin=30.225&baromabsin=29.743&tempf=42.3&humidity=95&winddir=253&windspeedmph=0.2&windgustmph=1.1&maxdailygust=13.6&rainratein=0.000&eventrainin=0.110&hourlyrainin=0.000&dailyrainin=0.122&weeklyrainin=1.551&monthlyrainin=1.772&totalrainin=68.295&solarradiation=0.00&uv=0&wh65batt=0&freq=868M&model=WS2900_V2.01.10
                        2022-02-10 18:13:13.799  - debug: sainlogic.0 (4622) No mapping found for dataelement: PASSKEY
                        2022-02-10 18:13:13.799  - debug: sainlogic.0 (4622) Extracting value for info.softwaretype(stationtype)
                        2022-02-10 18:13:13.800  - debug: sainlogic.0 (4622) No mapping found for dataelement: dateutc
                        2022-02-10 18:13:13.800  - debug: sainlogic.0 (4622) Extracting value for weather.current.indoortemp(tempinf)
                        2022-02-10 18:13:13.800  - debug: sainlogic.0 (4622) Extracting value for weather.current.indoorhumidity(humidityin)
                        2022-02-10 18:13:13.800  - debug: sainlogic.0 (4622) Extracting value for weather.current.pressurerel(baromrelin)
                        2022-02-10 18:13:13.800  - debug: sainlogic.0 (4622) Extracting value for weather.current.pressureabs(baromabsin)
                        2022-02-10 18:13:13.801  - debug: sainlogic.0 (4622) Extracting value for weather.current.outdoortemp(tempf)
                        2022-02-10 18:13:13.801  - debug: sainlogic.0 (4622) Extracting value for weather.current.outdoorhumidity(humidity)
                        2022-02-10 18:13:13.801  - debug: sainlogic.0 (4622) Extracting value for weather.current.winddir(winddir)
                        2022-02-10 18:13:13.801  - debug: sainlogic.0 (4622) Extracting value for weather.current.windspeed(windspeedmph)
                        2022-02-10 18:13:13.801  - debug: sainlogic.0 (4622) Extracting value for weather.current.windgustspeed(windgustmph)
                        2022-02-10 18:13:13.801  - debug: sainlogic.0 (4622) Extracting value for weather.current.maxdailygust(maxdailygust)
                        2022-02-10 18:13:13.801  - debug: sainlogic.0 (4622) Extracting value for weather.current.rain(rainratein)
                        2022-02-10 18:13:13.802  - debug: sainlogic.0 (4622) No mapping found for dataelement: eventrainin
                        2022-02-10 18:13:13.802  - debug: sainlogic.0 (4622) No mapping found for dataelement: hourlyrainin
                        2022-02-10 18:13:13.802  - debug: sainlogic.0 (4622) Extracting value for weather.current.dailyrain(dailyrainin)
                        2022-02-10 18:13:13.802  - debug: sainlogic.0 (4622) Extracting value for weather.current.weeklyrain(weeklyrainin)
                        2022-02-10 18:13:13.802  - debug: sainlogic.0 (4622) Extracting value for weather.current.monthlyrain(monthlyrainin)
                        2022-02-10 18:13:13.802  - debug: sainlogic.0 (4622) No mapping found for dataelement: totalrainin
                        2022-02-10 18:13:13.803  - debug: sainlogic.0 (4622) Extracting value for weather.current.solarradiation(solarradiation)
                        2022-02-10 18:13:13.803  - debug: sainlogic.0 (4622) Extracting value for weather.current.uvi(uv)
                        2022-02-10 18:13:13.803  - debug: sainlogic.0 (4622) No mapping found for dataelement: wh65batt
                        2022-02-10 18:13:13.803  - debug: sainlogic.0 (4622) Extracting value for info.freq(freq)
                        2022-02-10 18:13:13.803  - debug: sainlogic.0 (4622) Extracting value for info.model(model)
                        2022-02-10 18:13:13.803  - debug: sainlogic.0 (4622) Setting value from data for info.softwaretype to EasyWeatherV1.6.1
                        2022-02-10 18:13:13.803  - debug: sainlogic.0 (4622) Setting value from data for weather.current.indoortemp to 21.7
                        2022-02-10 18:13:13.803  - debug: sainlogic.0 (4622) Target for indoortemp unit is set: °C, using conversion: null
                        2022-02-10 18:13:13.804  - debug: sainlogic.0 (4622) Setting value from data for weather.current.indoorhumidity to 47
                        2022-02-10 18:13:13.804  - debug: sainlogic.0 (4622) Setting value from data for weather.current.pressurerel to 1023.4
                        2022-02-10 18:13:13.804  - debug: sainlogic.0 (4622) Target for pressurerel unit is set: hPa, using conversion: null
                        2022-02-10 18:13:13.804  - debug: sainlogic.0 (4622) Setting value from data for weather.current.pressureabs to 1007.1
                        2022-02-10 18:13:13.804  - debug: sainlogic.0 (4622) Target for pressureabs unit is set: hPa, using conversion: null
                        2022-02-10 18:13:13.804  - debug: sainlogic.0 (4622) Setting value from data for weather.current.outdoortemp to 5.7
                        2022-02-10 18:13:13.804  - debug: sainlogic.0 (4622) Target for outdoortemp unit is set: °C, using conversion: null
                        2022-02-10 18:13:13.804  - debug: sainlogic.0 (4622) Setting value from data for weather.current.outdoorhumidity to 95
                        2022-02-10 18:13:13.804  - debug: sainlogic.0 (4622) Setting value from data for weather.current.winddir to 253
                        2022-02-10 18:13:13.805  - debug: sainlogic.0 (4622) Setting value from data for weather.current.windspeed to 0.3
                        2022-02-10 18:13:13.805  - debug: sainlogic.0 (4622) Target for windspeed unit is set: km/h, using conversion: null
                        2022-02-10 18:13:13.805  - debug: sainlogic.0 (4622) Setting value from data for weather.current.windgustspeed to 1.8
                        2022-02-10 18:13:13.805  - debug: sainlogic.0 (4622) Target for windgustspeed unit is set: km/h, using conversion: null
                        2022-02-10 18:13:13.805  - debug: sainlogic.0 (4622) Setting value from data for weather.current.maxdailygust to 21.9
                        2022-02-10 18:13:13.805  - debug: sainlogic.0 (4622) Target for maxdailygust unit is set: km/h, using conversion: null
                        2022-02-10 18:13:13.806  - debug: sainlogic.0 (4622) Setting value from data for weather.current.rain to 0
                        2022-02-10 18:13:13.806  - debug: sainlogic.0 (4622) Target for rain unit is set: mm, using conversion: null
                        2022-02-10 18:13:13.806  - debug: sainlogic.0 (4622) Setting value from data for weather.current.dailyrain to 3.1
                        2022-02-10 18:13:13.806  - debug: sainlogic.0 (4622) Target for dailyrain unit is set: mm, using conversion: null
                        2022-02-10 18:13:13.806  - debug: sainlogic.0 (4622) Setting value from data for weather.current.weeklyrain to 39.4
                        2022-02-10 18:13:13.806  - debug: sainlogic.0 (4622) Target for weeklyrain unit is set: mm, using conversion: null
                        2022-02-10 18:13:13.806  - debug: sainlogic.0 (4622) Setting value from data for weather.current.monthlyrain to 45
                        2022-02-10 18:13:13.806  - debug: sainlogic.0 (4622) Target for monthlyrain unit is set: mm, using conversion: null
                        2022-02-10 18:13:13.806  - debug: sainlogic.0 (4622) Setting value from data for weather.current.solarradiation to 0
                        2022-02-10 18:13:13.807  - debug: sainlogic.0 (4622) Target for solarradiation unit is set: lx, using conversion: null
                        2022-02-10 18:13:13.807  - debug: sainlogic.0 (4622) Setting value from data for weather.current.uvi to 0
                        2022-02-10 18:13:13.807  - debug: sainlogic.0 (4622) Setting value from data for info.freq to 868M
                        2022-02-10 18:13:13.807  - debug: sainlogic.0 (4622) Setting value from data for info.model to WS2900_V2.01.10
                        2022-02-10 18:13:13.807  - debug: sainlogic.0 (4622) Listener received EW update: {"PASSKEY":"6E8D338577B841F7DC608157C88988C7","stationtype":"EasyWeatherV1.6.1","dateutc":"2022-02-10 17:13:10","tempinf":"71.1","humidityin":"47","baromrelin":"30.225","baromabsin":"29.743","tempf":"42.3","humidity":"95","winddir":"253","windspeedmph":"0.2","windgustmph":"1.1","maxdailygust":"13.6","rainratein":"0.000","eventrainin":"0.110","hourlyrainin":"0.000","dailyrainin":"0.122","weeklyrainin":"1.551","monthlyrainin":"1.772","totalrainin":"68.295","solarradiation":"0.00","uv":"0","wh65batt":"0","freq":"868M","model":"WS2900_V2.01.10"}
                        Und ein Teil der DPs werden befüllt:
                        Datenpunkte wie z.B. UVRaw sollte doch aber im Ecowitt Protokoll enthalten sein zumindest bekomme ich bei Verwendung des Scripts einen Wert.
                        Liegt da nich was im Adapter oder ist meine Station nicht 100% kompatibel?
                        • R Offline
                          rotamint
                          #249
                          Hallo zusammen! Ich habe eine grundlegende Frage zum Sainlogic-Adapter. Ich habe folgende Komponenten bei froggit.de gekauft:
                          Außeneinheit
                          zusammen mit
                          WiFi-USB-Dongle DP1500
                          Das ganze nach reichlich Nachlesem, "try & error" und wieder Nachlesen letztendlich mit dem Sainlogic-Adapter V.0.9.0 lauffähig bekommen:
                          Jedoch liefern die Datenpunkte "info, maxvalues und minvalues" keine Werte (null)
                          Ich vermute es hängt damit zusammen, dass die "Zeitplaneinstellungen" (pull) in der Config deaktiv steht (meine ich so bei Thomas Braun gelesen zu haben).
                          Setze ich die "Zeitplaneinstellungen" auf aktiv,
                          erhalte ich folgende Fehlermeldung ohne Veränderung der "null-Daten"
                          Hierzu meine Fragen:
                          Habe ich was falsch eingestellt (wenn ja - was), soviel kann da ja nicht konfiguriert werden.
                          Wer "erzeugt / liefert" die "Min- Maxvalues". Die Außeneinheit? Der DP1500 USB-Dongle? Ggf. das nicht vorhandene Display?
                          Wer hat eine Idee, wie ich das Problem lösen kann?
                          Danke für Eure Unterstützung, in diesem Sinne, ein tolles sonniges Wochenende!
                          S.
                          • R rotamint
                            Außeneinheit
                            zusammen mit
                            S.
                            mcm1957M Online
                            mcm1957M Online
                            mcm1957
                            #250
                            @rotamint
                            I do not see Min/Max values using listener mode too. i'm using a Conrad Eurochron EFWS2900. Actual values seem to be ok. I've created a issue https://github.com/phifogg/ioBroker.sainlogic/issues/131
                            In respect to unknow subcommand this topic might be covered by issue
                            https://github.com/phifogg/ioBroker.sainlogic/issues/127
                            Support Repositoryverwaltung.
                            LESEN - gute Forenbeitrage
                            • mcm1957M mcm1957
                              @rotamint
                              mcm1957M Online
                              mcm1957M Online
                              mcm1957
                              #251
                              According to phifoggs responce at issue 131 the min/max values will be set ONLY if the station itself transmits min/max values. Tha adapter does NOT calculate any values.
                              Laut phifoggs Antwort auf Issue 131 werden die Min/Max-Werte NUR gesetzt, wenn die Station selbst Min/Max-Werte sendet. Der Adapter berechnet KEINE Werte.
                              R 1 Antwort Letzte Antwort
                              • mcm1957M mcm1957
                                rotamint
                                #252
                                @mcm57 sagte in Test Adapter ioBroker.sainlogic v0.6.X GitHub/Latest:
                                Schade. Ernüchternd. Trotzdem Danke für die Info, jetzt weiß ich wenigstens was ich zu tun habe ;-) Möchte da eigentlich nicht ewig dran rum basteln, dass es zum Schluss dann doch eine "holprige" Lösung wird... Daher meine Frage:
                                Wer kann (welche?) Station empfehlen, die die Min-/Max-Werte mitliefert? Würde dann ggf. auf eine andere Ausseneinheit umsteigen.
                                Danke schonmal, schönen Rest-Sonntag noch...
                                LG Stefan.
                                • R rotamint
                                  LG Stefan.
                                  FabioF Offline
                                  FabioF Offline
                                  Fabio
                                  #253
                                  @rotamint sagte in Test Adapter ioBroker.sainlogic v0.6.X GitHub/Latest:
                                  Ich habe diese hier zuverlässig im Einsatz: https://www.froggit.de/product_info.php?info=p356_wh4000se-wifi-internet-funk-wetterstation---wunderground--ecowitt--pc-anbindung--auswertungssoftware.html
                                  Fabio
                                  Iobroker:
                                  • FabioF Fabio
                                    Fabio
                                    rotamint
                                    #254
                                    @fa-bio Besten Dank für die Info. Ich habe eben bestellt ;-)
                                    LG Stefan.
                                    • R rotamint
                                      LG Stefan.
                                      FabioF Offline
                                      FabioF Offline
                                      Fabio
                                      #255
                                      @rotamint dann viel Spaß damit.👍
                                      Fabio
                                      Iobroker:
                                      • FabioF Fabio
                                        Fabio
                                        rotamint
                                        #256
                                        @fa-bio Kurzes Feedback: Habe vieles probiert, verknüpft, visualisiert... Bin super glücklich und mehr als zufrieden damit. Absolut kein Vergleich zu der unzuverlässigen Homematic-Station, die ein vielfaches gekostet hat, vielfach weniger konnte und nur grobe "Schätzwerte" lieferte. Und letztendlich nach vier Jahren lt. EQ3 "irreparabel" defekt war...
                                        • R rotamint
                                          FabioF Offline
                                          FabioF Offline
                                          Fabio
                                          #257
                                          @rotamint das freut mich doch.👍 ☺ Dann wünsche ich dir damit weiter viel Freude.
                                          Fabio
                                          Iobroker:
