  4. js-controller 4.0 jetzt im BETA/LATEST!
    apollon77A
747 Beiträge 70 Kommentatoren 326.4k Aufrufe 60 Beobachtet
  • O oFbEQnpoLKKl6mbY5e13
    @foxriver76 sagte in js-controller 4.0 jetzt im BETA/LATEST!:
    iob object get system.host.iobroker
    # iob object get system.host.iobroker
    {"_id":"system.host.iobroker","type":"host","common":{"name":"iobroker","title":"JS controller","installedVersion":"3.3.22","platform":"Javascript/Node.js","cmd":"/usr/bin/node  /opt/iobroker/node_modules/iobroker.js-controller/controller.js","hostname":"iobroker","address":["192.168.0.202"],"type":"js-controller"},"native":{"process":{"title":"iobroker.js-controller","versions":{"node":"14.19.0","v8":"8.4.371.23-node.85","uv":"1.42.0","zlib":"1.2.11","brotli":"1.0.9","ares":"1.18.1","modules":"83","nghttp2":"1.42.0","napi":"8","llhttp":"2.1.4","openssl":"1.1.1m","cldr":"40.0","icu":"70.1","tz":"2021a3","unicode":"14.0"},"env":{"HOSTNAME":"iobroker","LANGUAGE":"de_DE:de","PWD":"/opt/iobroker","SETUID":"1000","TZ":"Europe/Berlin","LANG":"de_DE.UTF-8","TERM":"xterm","SHLVL":"0","LC_ALL":"de_DE.UTF-8","PATH":"/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin","DEBIAN_FRONTEND":"teletype","SETGID":"1000","OLDPWD":"/opt/iobroker","_":"/usr/sbin/gosu","HOME":"/opt/iobroker"}},"os":{"hostname":"iobroker","type":"Linux","platform":"linux","arch":"x64","release":"5.10.60-qnap","endianness":"LE","tmpdir":"/tmp"},"hardware":{"cpus":[{"model":"Intel(R) Celeron(R) CPU  J1900  @ 1.99GHz","speed":2380},{"model":"Intel(R) Celeron(R) CPU  J1900  @ 1.99GHz","speed":2395},{"model":"Intel(R) Celeron(R) CPU  J1900  @ 1.99GHz","speed":2411},{"model":"Intel(R) Celeron(R) CPU  J1900  @ 1.99GHz","speed":2413}],"totalmem":8236285952,"networkInterfaces":{"lo":[{"address":"127.0.0.1","netmask":"255.0.0.0","family":"IPv4","mac":"00:00:00:00:00:00","internal":true,"cidr":"127.0.0.1/8"}],"eth0":[{"address":"192.168.0.202","netmask":"255.255.255.0","family":"IPv4","mac":"02:42:0f:41:18:53","internal":false,"cidr":"192.168.0.202/24"}]}}},"from":"system.host.iobroker","ts":1644410814860,"acl":{"object":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"}}
    foxriver76F
    foxriver76F
    foxriver76
    schrieb am zuletzt editiert von foxriver76
    #249
    @ofbeqnpolkkl6mby5e13 Schaut alles gut aus... wenn du keine wichtigen PWs in deiner Installation hast, bzw diese vorher abänderst, könntest du mir auch mal deine Redis DB privat schicken, dann könnte ich bei mir probieren die Ursache zu finden.
    Workaround geht notfalls auch, aber wäre schick, das Problem zu beheben.
    Videotutorials & mehr
    O 1 Antwort Letzte Antwort
    • foxriver76F foxriver76
      O
      O
      #250
      @foxriver76
      Kein Problem. Wohin?
      Kein Problem, ich habe Zeit. Und mein iobroker läuft ja perfekt mit 3.3.22.
      Edit:
      Das Problem wurde behoben.
      • apollon77A apollon77
        Hey All
        die 4.0.7 ist auf dem Weg mit einem kleinen Fix nochmal wegen der Paketmanager-Erkennung
        wendy2702W
        wendy2702W
        #251
        @apollon77 sagte in js-controller 4.0 jetzt im BETA/LATEST!:
        Hey All
        Sollte die oder 4.0.6 schon im latest sichtbar sein?
        Noch ne Frage. Wie läuft unter JS4.x ein Restore eines Slaves?
        DiginixD apollon77A 2 Antworten Letzte Antwort
        • wendy2702W wendy2702
          Hey All
          DiginixD
          DiginixD
          Diginix
          #252
          @wendy2702 4.0.6 und 4.0.7 sind über latest bereits verfügbar und bei mir .7 seit 12 Uhr installiert.
          ..:: So long! Tom ::..
            Hey All
            apollon77A
            apollon77A
            #253
            @wendy2702 sagte in js-controller 4.0 jetzt im BETA/LATEST!:
            Naja eher die 4.0.7 inzwischen :-) Aber ja ... sollte eins von beiden. Ggf iob update
            Wie auch unter 3.3.22 :-)
            Das bringt eher die Frage nach generell dem Restore einen slaves auf denke ich :-)
            Formal Slave-Host neu aufsetzen mit nem leeren ioBroker und schauen das der Hostname der gleich ist wie früher!! Dann den Host via "iob setup custom" (oder mit mh browse) an den Master verbinden. Dann sollte der Slave merken welche Adapter nachinstalliert werden müssen und das automatisch tun
            wendy2702W 2 Antworten Letzte Antwort
            • DiginixD Diginix
              wendy2702W
              wendy2702W
              #254
              @diginix sagte in js-controller 4.0 jetzt im BETA/LATEST!:
              Hm...
              hast du die also im HOST Tab gesehen?
              Bei mir auch nach STRG+F5 immer noch 4.0.5:
              Obwohl im latest tatsächlich 4.0.7 kommt:
              Admin 5.2.3 sowohl mit FF als auch mit Chrome
              EDIT: iob update auf dem Slave gemacht. Dann reload im FF und jetzt steht bei allen 4.0.7
                wendy2702W
                wendy2702W
                #255
                Wenn ich es schaffe teste ich es heute.
                • wendy2702W
                  wendy2702W
                  #256
                  auch mit 4.0.7 bei mir leider so auf dem Slave der die Probleme macht:
                  pi@pi-iobroker:~ $ iob upgrade self
                  Update js-controller from @4.0.3 to @4.0.7
                  NPM version: 6.14.16
                  Installing iobroker.js-controller@4.0.7... (System call)
                  Could not check npm version: This directory tree does not contain a package.json
                  Assuming that correct version is installed.
                  pi@pi-iobroker:~ $ cd /opt/iobroker/
                  pi@pi-iobroker:/opt/iobroker $ iob upgrade self
                    apollon77A
                    apollon77A
                    #257
                    @wendy2702 Naja nee ... du hast ja immer noch die 4.0.3 ... der Fix ist ja erst später drin gewesen :) Dann upgrade "hart"
                    cd /opt/iobrokerund npm i iobroker.js-controller@4.0.7 --production
                      wendy2702W
                      wendy2702W
                      #258
                      @apollon77 Stimmt mein Fehler.
                      Macht es sinn zum testen zuerst auf 4.0.6 und dann auf 4.0.7 um zu sehen ob der fix wirkt?
                      apollon77A B 2 Antworten Letzte Antwort
                        apollon77A
                        apollon77A
                        #259
                        @wendy2702 Das kannst du gern tun
                          B
                          B
                          bommel_030
                          #260
                          @wendy2702 @apollon77
                          Hat bei einem Slave auch das Problem bei 4.0.4 ->4.0.5 ->4.0.6.
                          Von 4.0.6 auf 4.0.7 ging es fehlerfrei.
                          • wendy2702W
                            wendy2702W
                            #261
                            4.0.3 - 4.0.6 - 4.0.7 hat jetzt geklappt.
                            Danke für euren unermüdlichen Einsatz!
                            • E
                              E
                              e-i-k-e
                              #262
                              Als ich mit meinem Master/Slave-System angefangen bin, war es erforderlich, für jeden Slave den Admin-Adapter zu installieren.
                              Ist dies immer noch nötig?
                              Thomas BraunT apollon77A 2 Antworten Letzte Antwort
                              • E e-i-k-e
                                Thomas BraunT
                                Thomas BraunT
                                #263
                                @e-i-k-e sagte in js-controller 4.0 jetzt im BETA/LATEST!:
                                Nein. Da kannst du auch eine zunächst leere Hülle andocken. Also alle Adapter deinstallieren, dann den Slave anbinden, Adapter auf den Slave schieben.
                                E 1 Antwort Letzte Antwort
                                  E
                                  E
                                  e-i-k-e
                                  #264
                                  Dauerschleife:
                                  Thomas BraunT apollon77A 3 Antworten Letzte Antwort
                                  • E e-i-k-e
                                    Dauerschleife:
                                    Thomas BraunT
                                    Thomas BraunT
                                    #265
                                    @e-i-k-e
                                    Mach's über die Kommandozeile.
                                    Wobei ich nicht weiß, wie sich bereits eingerichtete Slaves verhalten, wenn der admin rausgehauen wird.
                                    • E e-i-k-e
                                      apollon77A
                                      apollon77A
                                      #266
                                      @e-i-k-e Das war noch nie nötig:-) Fakt war nur das im Normalfall der Admin Code auf jedem Slave liegt, aber sonst nichts. Also: Nein braucht man nicht
                                      • E e-i-k-e
                                        Dauerschleife:
                                        apollon77A
                                        apollon77A
                                        #267
                                        @e-i-k-e Und er löscht dabei nichts? Strange. Aber ja, geht es auf der CLI?
                                        • E e-i-k-e
                                          Dauerschleife:
                                          apollon77A
                                          apollon77A
                                          #268
                                          @e-i-k-e Danke, Hast nen Bug gefunden. Wird in der 4.0.8 gefixt
                                          K E 3 Antworten Letzte Antwort
                                          83.9k
