  4. js-controller 4.0 jetzt im BETA/LATEST!
    apollon77A
747 Beiträge 70 Kommentatoren 337.3k Aufrufe 60 Beobachtet
  • apollon77A
    apollon77A
    #216
    die NPM package.json nicht gefunden Fehler werden in der kommenden 4.0.6 behoben sein
    AlligatorA J 2 Antworten Letzte Antwort
    • E e-s
      @apollon77 hatte die selben Fehler wie @Diginix, scheint also nicht unbedingt einmalig zu sein.
      santa@ubuntuserver:/opt/iobroker$ iob upgrade self
      Update js-controller from @3.3.22 to @4.0.5
      NPM version: 6.14.16
      npm install iobroker.js-controller@4.0.5 --loglevel error --unsafe-perm --prefix "/opt/iobroker" (System call)
      In file included from ../../nan/nan.h:56,
                       from ../src/unix_dgram.cc:5:
      /home/iobroker/.cache/node-gyp/14.19.0/include/node/node.h:793:43: warning: cast between incompatible function types from ‘void (*)(v8::Local<v8::Object>)’ to ‘node::addon_register_func’ {aka ‘void (*)(v8::Local<v8::Object>, v8::Local<v8::Value>, void*)’} [-Wcast-function-type]
        793 |       (node::addon_register_func) (regfunc),                          \
      /home/iobroker/.cache/node-gyp/14.19.0/include/node/node.h:827:3: note: in expansion of macro ‘NODE_MODULE_X’
        827 |   NODE_MODULE_X(modname, regfunc, NULL, 0)  // NOLINT (readability/null_usage)
      ../src/unix_dgram.cc:404:1: note: in expansion of macro ‘NODE_MODULE’
        404 | NODE_MODULE(unix_dgram, Initialize)
      Server Objects 127.0.0.1:47886 Error from InMemDB: Error: GET-UNSUPPORTED for namespace cfg.: Data=["meta.objects.features.useSets"]
      Server States 127.0.0.1:41258 Error from InMemDB: Error: GET-UNSUPPORTED for namespace meta.: Data=["meta.states.protocolVersion"]
      Server Objects 127.0.0.1:47886 Error from InMemDB: Error: GET-UNSUPPORTED for namespace cfg.: Data=["meta.objects.protocolVersion"]
      Server States 127.0.0.1:41260 Error from InMemDB: Error: PSUBSCRIBE-UNSUPPORTED for namespace meta.: Data=["meta.*"]
      Server Objects 127.0.0.1:47886 Error from InMemDB: Error: Unknown LUA script load
      Server Objects 127.0.0.1:47886 Error from InMemDB: Error: SET-UNSUPPORTED for namespace cfg.: Data=["meta.objects.features.useSets",{"type":"Buffer","data":[49]}]
      Could not migrate objects to corresponding sets: Error SET-UNSUPPORTED for namespace cfg.: Data=["meta.objects.features.useSets",{"type":"Buffer","data":[49]}]
      apollon77A
      apollon77A
      #217
      @e-s SInd halt die üblichen unix_dgram Compile Warnungen ...
      • apollon77A
        apollon77A
        #218
        Hi All,
        vielen Dank für Euren Support, die 4.0.6 kommt über Nacht wieder ins Repo und hat:
        4.0.6 (2022-02-09)
        • (AlCalzone) Optimize some JSONL cases
        • (foxriver76) Optimize Backup restore process
        • (AlCalzone) Fix issues that prevented adapter installs/updates (npm can not be located error message)
        • (Apollon77) Fix seq Logging issue
        • (foxriver76/Apollon77) Prevent several crash cases seen in Sentry
        Thomas BraunT O 2 Antworten Letzte Antwort
        • apollon77A apollon77
          Hi All,
          4.0.6 (2022-02-09)
          Thomas BraunT
          Thomas BraunT
          #219
          @apollon77 @AlCalzone
          Das finde ich interessant. Was war da der Grund das npm nicht im $PATH gefunden wurde?
            #220
            @apollon77 update von 4.0.5 auf 4.0.6 ohne besondere Vorkommnisse.
              Hi All,
              4.0.6 (2022-02-09)
              O
              O
              oFbEQnpoLKKl6mbY5e13
              #221
              @apollon77
              Ist da mein Fall auch mit abgedeckt?
              • O oFbEQnpoLKKl6mbY5e13
                @apollon77
                apollon77A
                apollon77A
                #222
                @ofbeqnpolkkl6mby5e13 das logfile hatte nicht mehr Infos drin. Von daher puuhhh. Ich sag mal so; Versuchs nochmal.
                O 1 Antwort Letzte Antwort
                  O
                  O
                  #223
                  @apollon77
                  # iobroker upgrade self
                  Update js-controller from @3.3.22 to @4.0.6
                  npm install iobroker.js-controller@4.0.6 --loglevel error --unsafe-perm --prefix "/opt/iobroker" (System call)
                  Uncaught Rejection: TypeError: Cannot read property '_id' of null
                      at /opt/iobroker/node_modules/@iobroker/db-objects-redis/lib/objects/objectsInRedisClient.js:3421:42
                      at Array.map (<anonymous>)
                      at ObjectsInRedisClient._applyViewFunc (/opt/iobroker/node_modules/@iobroker/db-objects-redis/lib/objects/objectsInRedisClient.js:3413:39)
                      at processTicksAndRejections (internal/process/task_queues.js:95:5)
                  npm ERR! code ELIFECYCLE
                  npm ERR! errno 6
                  npm ERR! iobroker.js-controller@4.0.6 install: `node iobroker.js setup first`
                  npm ERR! Exit status 6
                  npm ERR!
                  npm ERR! Failed at the iobroker.js-controller@4.0.6 install script.
                  npm ERR!     /opt/iobroker/.npm/_logs/2022-02-10T06_53_37_143Z-debug.log
                  host.iobroker Cannot install iobroker.js-controller@4.0.6: 6
                  Hilft das?:
                  npm info lifecycle iobroker.js-controller@4.0.6~install: iobroker.js-controller@4.0.6
                  > iobroker.js-controller@4.0.6 install /opt/iobroker/node_modules/iobroker.js-controller
                  npm info lifecycle iobroker.js-controller@4.0.6~install: Failed to exec install script
                  foxriver76F 2 Antworten Letzte Antwort
                    AlCalzoneA
                    AlCalzoneA
                    AlCalzone
                    #224
                    @thomas-braun Wir verwenden seit 4.x (m)eine Library, die sich um die Aufrufe vom Paketmanager kümmert. Mein Hintergedanke ist, dass wir dann irgendwann ohne großen Ärger zu einem anderen wechseln können, der nicht jedes halbe Jahr alles anders macht und unsere Installation breakt.
                    Die Library sucht eigentlich vom aktuellen Pfad (bzw. da wo die .js-Datei liegt) aus nach einem lockfile (z.B. package-lock.json), um den aktiven Paketmanager zu bestimmen. Bei einigen Usern existiert das nicht.
                      @apollon77
                      npm ERR! errno 6
                      npm ERR!
                      Hilft das?:
                      foxriver76F
                      foxriver76F
                      foxriver76
                      #225
                      @ofbeqnpolkkl6mby5e13 welcher Datenbanktyp ist im Einsatz?
                      Videotutorials & mehr
                      • foxriver76F foxriver76
                        O
                        O
                        #226
                        @foxriver76
                        Redis States und Objects.
                        • DiginixD
                          DiginixD
                          Diginix
                          #227
                          Update von 4.0.5 auf 4.0.6 ohne Probleme.
                          CLI Ausgabe:
                          Update js-controller from @4.0.5 to @4.0.6
                          Stopped Objects DB
                          Stopped States DB
                          Installing iobroker.js-controller@4.0.6... (System call)
                          > iobroker.js-controller@4.0.6 preinstall /opt/iobroker/node_modules/iobroker.js-controller
                          > node lib/preinstallCheck.js
                          Successfully migrated 18783 objects to Redis Sets
                          object _design/system updated
                            "defaultPrivate": "-----BEGIN RSA PRIVATE KEY-----\r\n***\r\n-----END RSA PRIVATE KEY-----\r\n",
                            "defaultPublic": "-----BEGIN CERTIFICATE-----\r\n***\r\n-----END CERTIFICATE-----\r\n"
                          Update certificate defaultPrivate
                          The object "system.certificates" was updated successfully.
                          Update certificate defaultPublic
                          + iobroker.js-controller@4.0.6
                          updated 13 packages in 47.713s
                          73 packages are looking for funding
                            run `npm fund` for details
                          ..:: So long! Tom ::..
                            @apollon77
                            npm ERR! errno 6
                            npm ERR!
                            Hilft das?:
                            foxriver76F
                            foxriver76F
                            foxriver76
                            #228
                            @ofbeqnpolkkl6mby5e13 sagte in js-controller 4.0 jetzt im BETA/LATEST!:
                            npm info lifecycle iobroker.js-controller@4.0.6~install: iobroker.js-controller@4.0.6 > iobroker.js-controller@4.0.6 install /opt/iobroker/node_modules/iobroker.js-controller > node iobroker.js setup first Uncaught Rejection: TypeError: Cannot read property '_id' of null at /opt/iobroker/node_modules/@iobroker/db-objects-redis/lib/objects/objectsInRedisClient.js:3421:42 at Array.map (<anonymous>) at ObjectsInRedisClient._applyViewFunc (/opt/iobroker/node_modules/@iobroker/db-objects-redis/lib/objects/objectsInRedisClient.js:3413:39) at processTicksAndRejections (internal/process/task_queues.js:95:5) npm info lifecycle iobroker.js-controller@4.0.6~install: Failed to exec install script
                            Kannst du mal mittels npm i iobroker.js-controller@next im Verzeichnis /opt/iobroker das upgrade anstoßen, damit ich mehr Log sehe. Irgendein Object View liefert null zurück, das sollte nicht sein.
                              O
                              O
                              #229
                              @foxriver76 sagte in js-controller 4.0 jetzt im BETA/LATEST!:
                              # pwd
                              /opt/iobroker
                              # npm i iobroker.js-controller@next
                              > iobroker.js-controller@4.0.5 preinstall /opt/iobroker/node_modules/iobroker.js-controller
                              > iobroker.js-controller@4.0.5 install /opt/iobroker/node_modules/iobroker.js-controller
                              npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@~2.3.2 (node_modules/chokidar/node_modules/fsevents):
                              npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.3.2: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"x64"})
                              npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@2.3.2 (node_modules/zigbee-herdsman-converters/node_modules/fsevents):
                              npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@2.3.2 (node_modules/zigbee-herdsman-converters/node_modules/zigbee-herdsman/node_modules/fsevents):
                              npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@2.3.2 (node_modules/zigbee-herdsman/node_modules/fsevents):
                              npm ERR! errno 6
                              npm ERR! iobroker.js-controller@4.0.5 install: `node iobroker.js setup first`
                              npm ERR!
                              npm ERR! Failed at the iobroker.js-controller@4.0.5 install script.
                              npm ERR!     /root/.npm/_logs/2022-02-10T08_31_44_396Z-debug.log
                                # pwd
                                /opt/iobroker
                                npm ERR! errno 6
                                npm ERR!
                                foxriver76F
                                foxriver76F
                                foxriver76
                                #230
                                @ofbeqnpolkkl6mby5e13 ok da passiert kein logging davor, thanks.
                                  # pwd
                                  /opt/iobroker
                                  npm ERR! errno 6
                                  npm ERR!
                                  foxriver76F
                                  foxriver76F
                                  foxriver76
                                  #231
                                  @ofbeqnpolkkl6mby5e13 single host oder multihost?
                                    O
                                    O
                                    #232
                                    @foxriver76
                                    Single.
                                      @foxriver76
                                      Single.
                                      foxriver76F
                                      foxriver76F
                                      foxriver76
                                      #233
                                      @ofbeqnpolkkl6mby5e13 super strange, dann müsste vor dem ersten view mindestens die ausgabe dass er zu sets migrieren möchte kommen. Zeig mal bitte Ausgabe von iob object list system.host.*
                                        O
                                        O
                                        #234
                                        Der JS-Controller ist ja jetzt nicht installiert, müsste ich erst die 3er wieder installieren.
                                        # iob object list system.host.*
                                        internal/modules/cjs/loader.js:905
                                          throw err;
                                        Error: Cannot find module '/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js'
                                            at Function.Module._resolveFilename (internal/modules/cjs/loader.js:902:15)
                                            at Function.Module._load (internal/modules/cjs/loader.js:746:27)
                                            at Function.executeUserEntryPoint [as runMain] (internal/modules/run_main.js:75:12)
                                            at internal/main/run_main_module.js:17:47 {
                                          code: 'MODULE_NOT_FOUND',
                                          requireStack: []
                                          O
                                          O
                                          #235
                                          ObjectAC | StateAC |     User     |     Group    | ID
                                          rw-rw-r--                    admin  administrator system.host.NAS.notifications
                                          rw-rw-r--                    admin  administrator system.host.NAS.plugins.sentry
                                          rw-rw-r--                    admin  administrator system.host.NAS.zip
                                          rw-rw-r--                    admin  administrator system.host.d631abdf99e6.plugins.sentry
                                          rw-rw-r--                    admin  administrator system.host.d631abdf99e6.zip
                                          rw-rw-r--                    admin  administrator system.host.iobroker
                                          rw-rw-r--                    admin  administrator system.host.iobroker-d.notifications
                                          rw-rw-r--                    admin  administrator system.host.iobroker-d.plugins.sentry
                                          rw-rw-r--                    admin  administrator system.host.iobroker-d.zip
                                          rw-rw-r-- rw-rw-r--          admin  administrator system.host.iobroker.alive
                                          rw-rw-r-- rw-rw-r--          admin  administrator system.host.iobroker.compactModeEnabled
                                          rw-rw-r-- rw-rw-r--          admin  administrator system.host.iobroker.compactgroupProcesses
                                          rw-rw-r-- rw-rw-r--          admin  administrator system.host.iobroker.cpu
                                          rw-rw-r-- rw-rw-r--          admin  administrator system.host.iobroker.cputime
                                          rw-rw-r-- rw-rw-r--          admin  administrator system.host.iobroker.diskFree
                                          rw-rw-r-- rw-rw-r--          admin  administrator system.host.iobroker.diskSize
                                          rw-rw-r-- rw-rw-r--          admin  administrator system.host.iobroker.diskWarning
                                          rw-rw-r-- rw-rw-r--          admin  administrator system.host.iobroker.eventLoopLag
                                          rw-rw-r-- rw-rw-r--          admin  administrator system.host.iobroker.freemem
                                          rw-rw-r-- rw-rw-r--          admin  administrator system.host.iobroker.inputCount
                                          rw-rw-r-- rw-rw-r--          admin  administrator system.host.iobroker.instancesAsCompact
                                          rw-rw-r-- rw-rw-r--          admin  administrator system.host.iobroker.instancesAsProcess
                                          rw-rw-r-- rw-rw-r--          admin  administrator system.host.iobroker.load
                                          rw-rw-r-- rw-rw-r--          admin  administrator system.host.iobroker.logLevel
                                          rw-rw-r-- rw-rw-r--          admin  administrator system.host.iobroker.mem
                                          rw-rw-r-- rw-rw-r--          admin  administrator system.host.iobroker.memAvailable
                                          rw-rw-r-- rw-rw-r--          admin  administrator system.host.iobroker.memHeapTotal
                                          rw-rw-r-- rw-rw-r--          admin  administrator system.host.iobroker.memHeapUsed
                                          rw-rw-r-- rw-rw-r--          admin  administrator system.host.iobroker.memRss
                                          rw-rw-r--                    admin  administrator system.host.iobroker.notifications
                                          rw-rw-r-- rw-rw-r--          admin  administrator system.host.iobroker.notifications.system
                                          rw-rw-r-- rw-rw-r--          admin  administrator system.host.iobroker.outputCount
                                          rw-rw-r--                    admin  administrator system.host.iobroker.plugins.sentry
                                          rw-rw-r-- rw-rw-r--          admin  administrator system.host.iobroker.plugins.sentry.enabled
                                          rw-rw-r-- rw-rw-r--          admin  administrator system.host.iobroker.uptime
                                          rw-rw-r--                    admin  administrator system.host.iobroker.zip
                                          84.0k
