  4. js-controller 4.0 jetzt im BETA/LATEST!
747 Beiträge 70 Kommentatoren 344.6k Aufrufe 60 Beobachtet
  • apollon77A apollon77
    @m0rph Ganz langsam ... wir schauen schon. Sagst du mir noch welche Ausgaben die Kommandos bringen? :-)
    M
    M
    m0rph
    #215
    @apollon77 6.14.16
    • apollon77A
      apollon77A
      #216
      die NPM package.json nicht gefunden Fehler werden in der kommenden 4.0.6 behoben sein
      AlligatorA J 2 Antworten Letzte Antwort
      • E e-s
        @apollon77 hatte die selben Fehler wie @Diginix, scheint also nicht unbedingt einmalig zu sein.
        santa@ubuntuserver:/opt/iobroker$ iob upgrade self
        Update js-controller from @3.3.22 to @4.0.5
        NPM version: 6.14.16
        npm install iobroker.js-controller@4.0.5 --loglevel error --unsafe-perm --prefix "/opt/iobroker" (System call)
        In file included from ../../nan/nan.h:56,
                         from ../src/unix_dgram.cc:5:
        /home/iobroker/.cache/node-gyp/14.19.0/include/node/node.h:793:43: warning: cast between incompatible function types from ‘void (*)(v8::Local<v8::Object>)’ to ‘node::addon_register_func’ {aka ‘void (*)(v8::Local<v8::Object>, v8::Local<v8::Value>, void*)’} [-Wcast-function-type]
          793 |       (node::addon_register_func) (regfunc),                          \
        /home/iobroker/.cache/node-gyp/14.19.0/include/node/node.h:827:3: note: in expansion of macro ‘NODE_MODULE_X’
          827 |   NODE_MODULE_X(modname, regfunc, NULL, 0)  // NOLINT (readability/null_usage)
        ../src/unix_dgram.cc:404:1: note: in expansion of macro ‘NODE_MODULE’
          404 | NODE_MODULE(unix_dgram, Initialize)
        Server Objects 127.0.0.1:47886 Error from InMemDB: Error: GET-UNSUPPORTED for namespace cfg.: Data=["meta.objects.features.useSets"]
        Server States 127.0.0.1:41258 Error from InMemDB: Error: GET-UNSUPPORTED for namespace meta.: Data=["meta.states.protocolVersion"]
        Server Objects 127.0.0.1:47886 Error from InMemDB: Error: GET-UNSUPPORTED for namespace cfg.: Data=["meta.objects.protocolVersion"]
        Server States 127.0.0.1:41260 Error from InMemDB: Error: PSUBSCRIBE-UNSUPPORTED for namespace meta.: Data=["meta.*"]
        Server Objects 127.0.0.1:47886 Error from InMemDB: Error: Unknown LUA script load
        Server Objects 127.0.0.1:47886 Error from InMemDB: Error: SET-UNSUPPORTED for namespace cfg.: Data=["meta.objects.features.useSets",{"type":"Buffer","data":[49]}]
        Could not migrate objects to corresponding sets: Error SET-UNSUPPORTED for namespace cfg.: Data=["meta.objects.features.useSets",{"type":"Buffer","data":[49]}]
        apollon77A
        apollon77A
        #217
        @e-s SInd halt die üblichen unix_dgram Compile Warnungen ...
        • apollon77A
          apollon77A
          #218
          Hi All,
          vielen Dank für Euren Support, die 4.0.6 kommt über Nacht wieder ins Repo und hat:
          4.0.6 (2022-02-09)
          • (AlCalzone) Optimize some JSONL cases
          • (foxriver76) Optimize Backup restore process
          • (AlCalzone) Fix issues that prevented adapter installs/updates (npm can not be located error message)
          • (Apollon77) Fix seq Logging issue
          • (foxriver76/Apollon77) Prevent several crash cases seen in Sentry
          Thomas BraunT O 2 Antworten Letzte Antwort
            Hi All,
            4.0.6 (2022-02-09)
            Thomas BraunT
            Thomas BraunT
            Most Active Developer
            #219
            @apollon77 @AlCalzone
            Das finde ich interessant. Was war da der Grund das npm nicht im $PATH gefunden wurde?
              #220
              @apollon77 update von 4.0.5 auf 4.0.6 ohne besondere Vorkommnisse.
                Hi All,
                4.0.6 (2022-02-09)
                O
                O
                oFbEQnpoLKKl6mbY5e13
                #221
                @apollon77
                Ist da mein Fall auch mit abgedeckt?
                • O oFbEQnpoLKKl6mbY5e13
                  @apollon77
                  apollon77A
                  apollon77A
                  #222
                  @ofbeqnpolkkl6mby5e13 das logfile hatte nicht mehr Infos drin. Von daher puuhhh. Ich sag mal so; Versuchs nochmal.
                  O 1 Antwort Letzte Antwort
                    O
                    O
                    #223
                    @apollon77
                    # iobroker upgrade self
                    Update js-controller from @3.3.22 to @4.0.6
                    npm install iobroker.js-controller@4.0.6 --loglevel error --unsafe-perm --prefix "/opt/iobroker" (System call)
                    Uncaught Rejection: TypeError: Cannot read property '_id' of null
                        at /opt/iobroker/node_modules/@iobroker/db-objects-redis/lib/objects/objectsInRedisClient.js:3421:42
                        at Array.map (<anonymous>)
                        at ObjectsInRedisClient._applyViewFunc (/opt/iobroker/node_modules/@iobroker/db-objects-redis/lib/objects/objectsInRedisClient.js:3413:39)
                        at processTicksAndRejections (internal/process/task_queues.js:95:5)
                    npm ERR! code ELIFECYCLE
                    npm ERR! errno 6
                    npm ERR! iobroker.js-controller@4.0.6 install: `node iobroker.js setup first`
                    npm ERR! Exit status 6
                    npm ERR!
                    npm ERR! Failed at the iobroker.js-controller@4.0.6 install script.
                    npm ERR!     /opt/iobroker/.npm/_logs/2022-02-10T06_53_37_143Z-debug.log
                    host.iobroker Cannot install iobroker.js-controller@4.0.6: 6
                    Hilft das?:
                    npm info lifecycle iobroker.js-controller@4.0.6~install: iobroker.js-controller@4.0.6
                    > iobroker.js-controller@4.0.6 install /opt/iobroker/node_modules/iobroker.js-controller
                    npm info lifecycle iobroker.js-controller@4.0.6~install: Failed to exec install script
                    foxriver76F 2 Antworten Letzte Antwort
                      AlCalzoneA
                      AlCalzoneA
                      AlCalzone
                      #224
                      @thomas-braun Wir verwenden seit 4.x (m)eine Library, die sich um die Aufrufe vom Paketmanager kümmert. Mein Hintergedanke ist, dass wir dann irgendwann ohne großen Ärger zu einem anderen wechseln können, der nicht jedes halbe Jahr alles anders macht und unsere Installation breakt.
                      Die Library sucht eigentlich vom aktuellen Pfad (bzw. da wo die .js-Datei liegt) aus nach einem lockfile (z.B. package-lock.json), um den aktiven Paketmanager zu bestimmen. Bei einigen Usern existiert das nicht.
                        @apollon77
                        npm ERR! errno 6
                        npm ERR!
                        Hilft das?:
                        foxriver76F
                        foxriver76F
                        foxriver76
                        #225
                        @ofbeqnpolkkl6mby5e13 welcher Datenbanktyp ist im Einsatz?
                        Videotutorials & mehr
                        • foxriver76F foxriver76
                          O
                          O
                          #226
                          @foxriver76
                          Redis States und Objects.
                          • DiginixD
                            DiginixD
                            Diginix
                            #227
                            Update von 4.0.5 auf 4.0.6 ohne Probleme.
                            CLI Ausgabe:
                            Update js-controller from @4.0.5 to @4.0.6
                            Stopped Objects DB
                            Stopped States DB
                            Installing iobroker.js-controller@4.0.6... (System call)
                            > iobroker.js-controller@4.0.6 preinstall /opt/iobroker/node_modules/iobroker.js-controller
                            > node lib/preinstallCheck.js
                            Successfully migrated 18783 objects to Redis Sets
                            object _design/system updated
                              "defaultPrivate": "-----BEGIN RSA PRIVATE KEY-----\r\n***\r\n-----END RSA PRIVATE KEY-----\r\n",
                              "defaultPublic": "-----BEGIN CERTIFICATE-----\r\n***\r\n-----END CERTIFICATE-----\r\n"
                            Update certificate defaultPrivate
                            The object "system.certificates" was updated successfully.
                            Update certificate defaultPublic
                            + iobroker.js-controller@4.0.6
                            updated 13 packages in 47.713s
                            73 packages are looking for funding
                              run `npm fund` for details
                            ..:: So long! Tom ::..
                              @apollon77
                              npm ERR! errno 6
                              npm ERR!
                              Hilft das?:
                              foxriver76F
                              foxriver76F
                              foxriver76
                              #228
                              @ofbeqnpolkkl6mby5e13 sagte in js-controller 4.0 jetzt im BETA/LATEST!:
                              npm info lifecycle iobroker.js-controller@4.0.6~install: iobroker.js-controller@4.0.6 > iobroker.js-controller@4.0.6 install /opt/iobroker/node_modules/iobroker.js-controller > node iobroker.js setup first Uncaught Rejection: TypeError: Cannot read property '_id' of null at /opt/iobroker/node_modules/@iobroker/db-objects-redis/lib/objects/objectsInRedisClient.js:3421:42 at Array.map (<anonymous>) at ObjectsInRedisClient._applyViewFunc (/opt/iobroker/node_modules/@iobroker/db-objects-redis/lib/objects/objectsInRedisClient.js:3413:39) at processTicksAndRejections (internal/process/task_queues.js:95:5) npm info lifecycle iobroker.js-controller@4.0.6~install: Failed to exec install script
                              Kannst du mal mittels npm i iobroker.js-controller@next im Verzeichnis /opt/iobroker das upgrade anstoßen, damit ich mehr Log sehe. Irgendein Object View liefert null zurück, das sollte nicht sein.
                                O
                                O
                                #229
                                @foxriver76 sagte in js-controller 4.0 jetzt im BETA/LATEST!:
                                # pwd
                                /opt/iobroker
                                # npm i iobroker.js-controller@next
                                > iobroker.js-controller@4.0.5 preinstall /opt/iobroker/node_modules/iobroker.js-controller
                                > iobroker.js-controller@4.0.5 install /opt/iobroker/node_modules/iobroker.js-controller
                                npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@~2.3.2 (node_modules/chokidar/node_modules/fsevents):
                                npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.3.2: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"x64"})
                                npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@2.3.2 (node_modules/zigbee-herdsman-converters/node_modules/fsevents):
                                npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@2.3.2 (node_modules/zigbee-herdsman-converters/node_modules/zigbee-herdsman/node_modules/fsevents):
                                npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@2.3.2 (node_modules/zigbee-herdsman/node_modules/fsevents):
                                npm ERR! errno 6
                                npm ERR! iobroker.js-controller@4.0.5 install: `node iobroker.js setup first`
                                npm ERR!
                                npm ERR! Failed at the iobroker.js-controller@4.0.5 install script.
                                npm ERR!     /root/.npm/_logs/2022-02-10T08_31_44_396Z-debug.log
                                  # pwd
                                  /opt/iobroker
                                  npm ERR! errno 6
                                  npm ERR!
                                  foxriver76F
                                  foxriver76F
                                  foxriver76
                                  #230
                                  @ofbeqnpolkkl6mby5e13 ok da passiert kein logging davor, thanks.
                                    # pwd
                                    /opt/iobroker
                                    npm ERR! errno 6
                                    npm ERR!
                                    foxriver76F
                                    foxriver76F
                                    foxriver76
                                    #231
                                    @ofbeqnpolkkl6mby5e13 single host oder multihost?
                                      O
                                      O
                                      #232
                                      @foxriver76
                                      Single.
                                        @foxriver76
                                        Single.
                                        foxriver76F
                                        foxriver76F
                                        foxriver76
                                        #233
                                        @ofbeqnpolkkl6mby5e13 super strange, dann müsste vor dem ersten view mindestens die ausgabe dass er zu sets migrieren möchte kommen. Zeig mal bitte Ausgabe von iob object list system.host.*
                                          O
                                          O
                                          #234
                                          Der JS-Controller ist ja jetzt nicht installiert, müsste ich erst die 3er wieder installieren.
                                          # iob object list system.host.*
                                          internal/modules/cjs/loader.js:905
                                            throw err;
                                          Error: Cannot find module '/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js'
                                              at Function.Module._resolveFilename (internal/modules/cjs/loader.js:902:15)
                                              at Function.Module._load (internal/modules/cjs/loader.js:746:27)
                                              at Function.executeUserEntryPoint [as runMain] (internal/modules/run_main.js:75:12)
                                              at internal/main/run_main_module.js:17:47 {
                                            code: 'MODULE_NOT_FOUND',
                                            requireStack: []
                                          84.1k
