  4. [How-to] Node.js ioBroker richtig updaten-2021/22 Edition
812 Beiträge 97 Kommentatoren 543.8k Aufrufe 83 Beobachtet
  • apollon77A apollon77
    @homecineplexx Das hietr ist auch komisch. Mach mal bitte in /opt/iobroker
    node --trace-warnings node_modules/iobroker.js-controller/iobroker.js status
    H
    H
    homecineplexx
    #306
    @apollon77 said in [How-to] Node.js für ioBroker richtig updaten - 2021 Edition:
    chris@IoBrokerSmartHome:/opt/iobroker$ node --trace-warnings node_modules/iobroker.js-controller/iobroker.js status
    Objects type: jsonl
    States  type: jsonl
      Ok, kannst Du denn "iob setup first" generell aufrufen ... nicht im Rahmen des Rebuilds?
      H
      H
      homecineplexx
      #307
      iob setup first
      ist das richtig so?
      chris@IoBrokerSmartHome:/opt/iobroker$ iob setup first
      Uncaught Rejection: Error: Connection is closed.
          at close (/opt/iobroker/node_modules/ioredis/built/redis/event_handler.js:184:25)
          at Socket.<anonymous> (/opt/iobroker/node_modules/ioredis/built/redis/event_handler.js:151:20)
          at Object.onceWrapper (events.js:520:26)
          at Socket.emit (events.js:400:28)
          at TCP.<anonymous> (net.js:686:12)
       Unable to subscribe to expiry Keyspace events from Redis Server: Connection is closed.
       Unable to subscribe to evicted Keyspace events from Redis Server: Connection is closed.
       Unable to subscribe to meta namespace "meta." changes: Connection is closed.
      Server Cannot start inMem-states on port 9000: Failed to lock DB file "/opt/iobroker/iobroker-data/states.jsonl"!
      • H homecineplexx
        Objects type: jsonl
        States  type: jsonl
        apollon77A
        apollon77A
        #308
        @homecineplexx mmeeehhhhhhhh ... warum ises jetzt weg?
        H 1 Antwort Letzte Antwort
          @alcalzone sagte in [How-to] Node.js für ioBroker richtig updaten - 2021 Edition:
          @apollon77 ne Idee wie das sein kann?
          Nope, müsste man prozessliste schauen
          H
          H
          homecineplexx
          #309
           PID USER      PR  NI    VIRT    RES    SHR S  %CPU %MEM     TIME+ COMMAND
            740 iobroker  20   0  961420 391716  35652 R  90,1  7,7  15:51.29 io.javascript.0
            648 iobroker  20   0 1071492 345812  35536 R  81,9  6,8  15:53.74 iobroker.js-con
           2682 iobroker  20   0  773400  77984  32184 S  55,3  1,5   0:06.77 io.ical.0
            812 iobroker  20   0  887992 320028  35728 S  37,2  6,3   7:16.57 io.javascript.1
           1210 iobroker  20   0  691884 112144  31084 R  28,3  2,2   3:07.88 io.homepilot20.
            834 iobroker  20   0  877164 302152  30764 S  28,0  5,9   5:04.49 io.javascript.2
            827 iobroker  20   0  713120 117676  30932 S  21,1  2,3   4:32.82 io.influxdb.0
            853 iobroker  20   0  717864  92828  30728 S   8,2  1,8   1:02.62 io.mqtt.0
           1404 iobroker  20   0  699892  72076  31552 S   5,6  1,4   0:35.33 io.unifi.0
            710 iobroker  20   0 1049460 161264  36348 S   3,6  3,2   0:48.42 io.admin.0
            460 root      20   0   44256   4720   4228 S   3,0  0,1   0:00.57 systemd-journal
           1047 iobroker  20   0  692692  62364  30720 S   1,6  1,2   0:04.51 io.text2command
            725 iobroker  20   0  693964  63832  30628 S   1,3  1,3   0:12.87 io.history.0
            782 iobroker  20   0  950172  66920  31624 S   1,3  1,3   0:13.74 io.telegram.1
            797 iobroker  20   0  884356  66448  31632 S   1,3  1,3   0:13.21 io.telegram.2
            766 iobroker  20   0  950200  67456  31492 S   1,0  1,3   0:14.05 io.telegram.0
           1449 iobroker  20   0  811760  59540  31772 S   1,0  1,2   0:04.31 io.parser.0
           1509 iobroker  20   0  692628  61876  31064 S   1,0  1,2   0:05.86 io.wled.0
            667 root      20   0  250112   3036   2432 S   0,7  0,1   0:00.09 rsyslogd
            994 iobroker  20   0  964656  68452  31804 S   0,7  1,3   0:15.78 io.alexa2.0
           2667 iobroker  20   0  691740  59736  30804 S   0,7  1,2   0:03.60 io.meteoalarm.0
           2710 chris     20   0   44932   3788   3144 R   0,7  0,1   0:00.09 top
              7 root      20   0       0      0      0 R   0,3  0,0   0:01.62 rcu_sched
            658 avahi     20   0   47132   3364   2956 S   0,3  0,1   0:00.75 avahi-daemon
            751 iobroker  20   0  694264  61820  30584 S   0,3  1,2   0:04.74 io.scenes.0
           1116 iobroker  20   0  669588  55876  30804 S   0,3  1,1   0:05.46 io.yeelight-2.0
           1167 iobroker  20   0  968468  67660  31664 S   0,3  1,3   0:07.69 io.cloud.0
              1 root      20   0   56888   6496   5112 S   0,0  0,1   0:01.73 systemd
              2 root      20   0       0      0      0 S   0,0  0,0   0:00.00 kthreadd
              3 root      20   0       0      0      0 S   0,0  0,0   0:00.17 ksoftirqd/0
              5 root       0 -20       0      0      0 S   0,0  0,0   0:00.00 kworker/0:0H
              8 root      20   0       0      0      0 S   0,0  0,0   0:00.00 rcu_bh
              9 root      rt   0       0      0      0 S   0,0  0,0   0:00.00 migration/0
             10 root       0 -20       0      0      0 S   0,0  0,0   0:00.00 lru-add-drain
             11 root      rt   0       0      0      0 S   0,0  0,0   0:00.00 watchdog/0
             12 root      20   0       0      0      0 S   0,0  0,0   0:00.00 cpuhp/0
             13 root      20   0       0      0      0 S   0,0  0,0   0:00.00 cpuhp/1
             14 root      rt   0       0      0      0 S   0,0  0,0   0:00.00 watchdog/1
             15 root      rt   0       0      0      0 S   0,0  0,0   0:00.00 migration/1
             16 root      20   0       0      0      0 S   0,0  0,0   0:00.67 ksoftirqd/1
             18 root       0 -20       0      0      0 S   0,0  0,0   0:00.00 kworker/1:0H
             19 root      20   0       0      0      0 S   0,0  0,0   0:00.00 cpuhp/2
             20 root      rt   0       0      0      0 S   0,0  0,0   0:00.00 watchdog/2
             21 root      rt   0       0      0      0 S   0,0  0,0   0:00.00 migration/2
             22 root      20   0       0      0      0 S   0,0  0,0   0:00.17 ksoftirqd/2
             24 root       0 -20       0      0      0 S   0,0  0,0   0:00.00 kworker/2:0H
             25 root      20   0       0      0      0 S   0,0  0,0   0:00.00 cpuhp/3
            H
            H
            homecineplexx
            #310
            ich hab keine ahnung...das darfst mich nicht fragen
            • H homecineplexx
              apollon77A
              apollon77A
              #311
              @homecineplexx ok, dann beende mal iobroker bevor du den rebuild machst ... irgendwas ist dennoch phishy weil an sich sollte er keine neuen states DB verbinden wenn schon eine an ist
                H
                H
                homecineplexx
                #312
                soviel dazu
                Thank you for using serialport!
                If you rely on this package, please consider supporting our open collective:
                > https://opencollective.com/serialport/donate
                > @serialport/bindings@9.0.4 install /opt/iobroker/node_modules/@serialport/bindings
                > prebuild-install --tag-prefix @serialport/bindings@ || node-gyp rebuild
                > serialport@6.2.2 install /opt/iobroker/node_modules/serialport
                > prebuild-install || node-gyp rebuild
                prebuild-install WARN install No prebuilt binaries found (target=14.19.0 runtime=node arch=x64 platform=linux)
                make: Verzeichnis „/opt/iobroker/node_modules/serialport/build“ wird betreten
                  CXX(target) Release/obj.target/serialport/src/serialport.o
                ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Open(Nan::NAN_METHOD_ARGS_TYPE)’:
                ../src/serialport.cpp:41:48: error: no matching function for call to ‘v8::Value::ToString()’
                   v8::String::Utf8Value path(info[0]->ToString());
                In file included from /home/iobroker/.cache/node-gyp/14.19.0/include/node/node.h:67:0,
                                 from ../../nan/nan.h:58,
                                 from ../src/./serialport.h:6,
                                 from ../src/serialport.cpp:1:
                /home/iobroker/.cache/node-gyp/14.19.0/include/node/v8.h:2810:44: note: candidate: v8::MaybeLocal<v8::String> v8::Value::ToString(v8::Local<v8::Context>) const
                   V8_WARN_UNUSED_RESULT MaybeLocal<String> ToString(
                /home/iobroker/.cache/node-gyp/14.19.0/include/node/v8.h:2810:44: note:   candidate expects 1 argument, 0 provided
                ../src/serialport.cpp:48:53: error: no matching function for call to ‘v8::Value::ToObject()’
                   v8::Local<v8::Object> options = info[1]->ToObject();
                /home/iobroker/.cache/node-gyp/14.19.0/include/node/v8.h:2822:44: note: candidate: v8::MaybeLocal<v8::Object> v8::Value::ToObject(v8::Local<v8::Context>) const
                   V8_WARN_UNUSED_RESULT MaybeLocal<Object> ToObject(
                /home/iobroker/.cache/node-gyp/14.19.0/include/node/v8.h:2822:44: note:   candidate expects 1 argument, 0 provided
                ../src/serialport.cpp: In function ‘void EIO_AfterOpen(uv_work_t*)’:
                ../src/serialport.cpp:95:30: warning: ‘v8::Local<v8::Value> Nan::Callback::Call(int, v8::Local<v8::Value>*) const’ is deprecated [-Wdeprecated-declarations]
                   data->callback.Call(2, argv);
                In file included from ../src/./serialport.h:6:0,
                ../../nan/nan.h:1744:3: note: declared here
                   Call(int argc, v8::Local<v8::Value> argv[]) const {
                ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Update(Nan::NAN_METHOD_ARGS_TYPE)’:
                ../src/serialport.cpp:113:53: error: no matching function for call to ‘v8::Value::ToObject()’
                ../src/serialport.cpp: In function ‘void EIO_AfterUpdate(uv_work_t*)’:
                ../src/serialport.cpp:150:30: warning: ‘v8::Local<v8::Value> Nan::Callback::Call(int, v8::Local<v8::Value>*) const’ is deprecated [-Wdeprecated-declarations]
                   data->callback.Call(1, argv);
                ../src/serialport.cpp: In function ‘void EIO_AfterClose(uv_work_t*)’:
                ../src/serialport.cpp:188:30: warning: ‘v8::Local<v8::Value> Nan::Callback::Call(int, v8::Local<v8::Value>*) const’ is deprecated [-Wdeprecated-declarations]
                ../src/serialport.cpp: In function ‘void EIO_AfterFlush(uv_work_t*)’:
                ../src/serialport.cpp:231:30: warning: ‘v8::Local<v8::Value> Nan::Callback::Call(int, v8::Local<v8::Value>*) const’ is deprecated [-Wdeprecated-declarations]
                ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Set(Nan::NAN_METHOD_ARGS_TYPE)’:
                ../src/serialport.cpp:250:53: error: no matching function for call to ‘v8::Value::ToObject()’
                ../src/serialport.cpp: In function ‘void EIO_AfterSet(uv_work_t*)’:
                ../src/serialport.cpp:285:30: warning: ‘v8::Local<v8::Value> Nan::Callback::Call(int, v8::Local<v8::Value>*) const’ is deprecated [-Wdeprecated-declarations]
                ../src/serialport.cpp: In function ‘void EIO_AfterGet(uv_work_t*)’:
                ../src/serialport.cpp:329:96: error: no matching function for call to ‘v8::Object::Set(v8::Local<v8::String>, Nan::imp::FactoryBase<v8::Boolean>::return_t)’
                     results->Set(Nan::New<v8::String>("cts").ToLocalChecked(), Nan::New<v8::Boolean>(data->cts));
                /home/iobroker/.cache/node-gyp/14.19.0/include/node/v8.h:3670:37: note: candidate: v8::Maybe<bool> v8::Object::Set(v8::Local<v8::Context>, v8::Local<v8::Value>, v8::Local<v8::Value>)
                   V8_WARN_UNUSED_RESULT Maybe<bool> Set(Local<Context> context,
                /home/iobroker/.cache/node-gyp/14.19.0/include/node/v8.h:3670:37: note:   candidate expects 3 arguments, 2 provided
                /home/iobroker/.cache/node-gyp/14.19.0/include/node/v8.h:3673:37: note: candidate: v8::Maybe<bool> v8::Object::Set(v8::Local<v8::Context>, uint32_t, v8::Local<v8::Value>)
                   V8_WARN_UNUSED_RESULT Maybe<bool> Set(Local<Context> context, uint32_t index,
                /home/iobroker/.cache/node-gyp/14.19.0/include/node/v8.h:3673:37: note:   candidate expects 3 arguments, 2 provided
                ../src/serialport.cpp:330:96: error: no matching function for call to ‘v8::Object::Set(v8::Local<v8::String>, Nan::imp::FactoryBase<v8::Boolean>::return_t)’
                     results->Set(Nan::New<v8::String>("dsr").ToLocalChecked(), Nan::New<v8::Boolean>(data->dsr));
                ../src/serialport.cpp:331:96: error: no matching function for call to ‘v8::Object::Set(v8::Local<v8::String>, Nan::imp::FactoryBase<v8::Boolean>::return_t)’
                     results->Set(Nan::New<v8::String>("dcd").ToLocalChecked(), Nan::New<v8::Boolean>(data->dcd));
                ../src/serialport.cpp:336:30: warning: ‘v8::Local<v8::Value> Nan::Callback::Call(int, v8::Local<v8::Value>*) const’ is deprecated [-Wdeprecated-declarations]
                ../src/serialport.cpp: In function ‘void EIO_AfterGetBaudRate(uv_work_t*)’:
                ../src/serialport.cpp:378:106: error: no matching function for call to ‘v8::Object::Set(v8::Local<v8::String>, Nan::imp::IntegerFactory<v8::Integer>::return_t)’
                     results->Set(Nan::New<v8::String>("baudRate").ToLocalChecked(), Nan::New<v8::Integer>(data->baudRate));
                ../src/serialport.cpp:383:30: warning: ‘v8::Local<v8::Value> Nan::Callback::Call(int, v8::Local<v8::Value>*) const’ is deprecated [-Wdeprecated-declarations]
                ../src/serialport.cpp: In function ‘void EIO_AfterDrain(uv_work_t*)’:
                ../src/serialport.cpp:424:30: warning: ‘v8::Local<v8::Value> Nan::Callback::Call(int, v8::Local<v8::Value>*) const’ is deprecated [-Wdeprecated-declarations]
                ../src/serialport.cpp: At global scope:
                ../src/serialport.cpp:460:17: error: variable or field ‘init’ declared void
                   void init(v8::Handle<v8::Object> target) {
                ../src/serialport.cpp:460:13: error: ‘Handle’ is not a member of ‘v8’
                ../src/serialport.cpp:460:34: error: expected primary-expression before ‘>’ token
                ../src/serialport.cpp:460:36: error: ‘target’ was not declared in this scope
                In file included from ../../nan/nan.h:58:0,
                ../src/serialport.cpp:485:25: error: ‘init’ was not declared in this scope
                 NODE_MODULE(serialport, init);
                /home/iobroker/.cache/node-gyp/14.19.0/include/node/node.h:793:36: note: in definition of macro ‘NODE_MODULE_X’
                       (node::addon_register_func) (regfunc),                          \
                ../src/serialport.cpp:485:1: note: in expansion of macro ‘NODE_MODULE’
                serialport.target.mk:114: die Regel für Ziel „Release/obj.target/serialport/src/serialport.o“ scheiterte
                make: *** [Release/obj.target/serialport/src/serialport.o] Fehler 1
                make: Verzeichnis „/opt/iobroker/node_modules/serialport/build“ wird verlassen
                gyp ERR! build error
                gyp ERR! stack Error: `make` failed with exit code: 2
                gyp ERR! stack     at ChildProcess.onExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:194:23)
                gyp ERR! stack     at ChildProcess.emit (events.js:400:28)
                gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:282:12)
                gyp ERR! System Linux 4.9.0-11-amd64
                gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"
                gyp ERR! cwd /opt/iobroker/node_modules/serialport
                gyp ERR! node -v v14.19.0
                gyp ERR! node-gyp -v v5.1.0
                gyp ERR! not ok
                npm ERR! code ELIFECYCLE
                npm ERR! errno 1
                npm ERR! serialport@6.2.2 install: `prebuild-install || node-gyp rebuild`
                npm ERR! Exit status 1
                npm ERR!
                npm ERR! Failed at the serialport@6.2.2 install script.
                npm ERR!     /home/iobroker/.npm/_logs/2022-02-08T08_35_50_311Z-debug.log
                • H homecineplexx
                  soviel dazu
                  gyp ERR! not ok
                  npm ERR! errno 1
                  npm ERR!
                  Thomas BraunT
                  Thomas BraunT
                  Most Active Developer
                  #313
                  @homecineplexx sagte in [How-to] Node.js für ioBroker richtig updaten - 2021 Edition:
                  4.9.0-11-amd64
                  Läuft da noch ein Debian Stretch?
                    4.9.0-11-amd64
                    H
                    H
                    homecineplexx
                    #314
                    @thomas-braun said in [How-to] Node.js für ioBroker richtig updaten - 2021 Edition:
                    4.9.0-11-amd64
                    Linux IoBrokerSmartHome 4.9.0-11-amd64 #1 SMP Debian 4.9.189-3+deb9u2 (2019-11-11) x86_64 GNU/Linux
                    • H homecineplexx
                      4.9.0-11-amd64
                      Thomas BraunT
                      Thomas BraunT
                      #315
                      @homecineplexx
                      cat /etc/debian_version
                      Kann sein, dass der ganze build stack zu alt ist. Stretch ist auch tot, update das ganze auf ein lebendes Release.
                        @homecineplexx
                        H
                        H
                        homecineplexx
                        #316
                        @homecineplexx
                        werd ich machen
                        9.11
                        • E
                          E
                          ecki945
                          #317
                          Guten Morgen. Bin gerade dabei meinen neuen NUC hochzuziehen. Proxmox 7.1-10 ist installiert. Ein neuer unpreviligiert Container mit akutellem debian ist erstellt. Doch nach der Installation meckert er herum.
                          Ist iobroker nun richtig installiert trotz der Fehlermeldung?
                          root@Iobroker:~# cat /etc/debian_version
                          11.2
                          root@Iobroker:~# node -v
                          v14.19.0
                          root@Iobroker:~# nodejs -v
                          -bash: nodejs: command not found
                          root@Iobroker:~# npm -v
                          6.14.16
                          root@Iobroker:~# curl -sLf https://iobroker.net/install.sh | bash -
                          library: loaded
                          Library version=2022-02-10
                              Welcome to the ioBroker installer!
                              Installer version: 2022-02-10
                              Installing prerequisites (1/4)
                          Hit:1 http://security.debian.org bullseye-security InRelease
                          Hit:2 http://ftp.debian.org/debian bullseye InRelease
                          Hit:3 http://ftp.debian.org/debian bullseye-updates InRelease
                          Hit:4 https://deb.nodesource.com/node_14.x bullseye InRelease
                          Reading package lists... Done
                          Changing npm registry to https://registry.npmjs.org
                          Installed acl
                          Installed build-essential
                          Installed gcc-c++
                          Installed libavahi-compat-libdnssd-dev
                          Installed libudev-dev
                          Installed libpam0g-dev
                          Installed git
                          Installed unzip
                          Installed libcairo2-dev
                          Installed libpango1.0-dev
                          Installed libjpeg-dev
                          Installed libgif-dev
                          Installed librsvg2-dev
                          Installed net-tools
                          Installed python-dev
                          Installed cmake
                              Creating ioBroker user and directory (2/4)
                          User iobroker created
                          Directory /opt/iobroker created
                              Installing ioBroker (3/4)
                          In file included from ../../nan/nan.h:58,
                                           from ../src/main.cpp:3:
                          /root/.cache/node-gyp/14.19.0/include/node/node.h:793:7: warning: cast between incompatible function types from 'void (*)(v8::Local<v8::Object>)' to 'node::addon_register_func' {aka 'void (*)(v8::Local<v8::Object>, v8::Local<v8::Value>, void*)'} [-Wcast-function-type]
                            793 |       (node::addon_register_func) (regfunc),                          \
                          /root/.cache/node-gyp/14.19.0/include/node/node.h:827:3: note: in expansion of macro 'NODE_MODULE_X'
                            827 |   NODE_MODULE_X(modname, regfunc, NULL, 0)  // NOLINT (readability/null_usage)
                          ../src/main.cpp:42:1: note: in expansion of macro 'NODE_MODULE'
                             42 | NODE_MODULE(diskusage, Init)
                                           from ../src/unix_dgram.cc:5:
                          ../src/unix_dgram.cc:404:1: note: in expansion of macro 'NODE_MODULE'
                            404 | NODE_MODULE(unix_dgram, Initialize)
                          ATTENTION: Error reporting via Sentry will be activated on next start of ioBroker
                          ioBroker wants to make sure to deliver the most stable smart home system.
                          To allow this we decided to implement an automatic error and crash reporting solution into the js-controller and also into adapters.
                          THIS REPORTING WILL BE ENABLED WITH THE NEXT START OF YOUR IOBROKER!
                          For any error that leads to the crash of the js-controller or one of the relevant adapters the error details are send to a server. For the js-controller and core adapters this server is located and operated in germany. For community adapters please check the Github Readme of the affected adapter for details which Sentry server is used.
                          If you want to disable the error reporting you can use the command
                          'iobroker plugin disable sentry'
                          This command will also make sure that no adapter that runs on this host will send crash reporting data to sentry.
                              Finalizing installation (4/4)
                          Enabling autostart...
                          Created symlink /etc/systemd/system/multi-user.target.wants/iobroker.service -> /lib/systemd/system/iobroker.service.
                          Autostart enabled!
                              ioBroker was installed successfully
                              Open http://192.168.178.11:8081 in a browser and start configuring!
                          You need to re-login before doing anything else on the console!
                          J apollon77A 2 Antworten Letzte Antwort
                          • E ecki945
                            11.2
                            v14.19.0
                            6.14.16
                            library: loaded
                            Installed acl
                            Installed gcc-c++
                            Installed git
                            Installed unzip
                            Installed net-tools
                            Installed cmake
                            Autostart enabled!
                            J
                            J
                            Jan1
                            #318
                            @ecki945
                            Die Frage ist eher, warum ist vor der IOBroker Installation schon Node drauf, muss das bei Proxmox manuell erledigt werden und wenn ja, warum stimmt dann die Abfrage der Installation nicht?
                            • E
                              E
                              ecki945
                              #319
                              Node habe ich vor der Installation von iobroker installiert.
                              So hab ich das aus der Doku verstanden.
                              KLICK
                              • E ecki945
                                KLICK
                                J
                                J
                                Jan1
                                #320
                                @ecki945
                                Der Doku kann man so folgen, wobei die mal erweiter werden müsste, mit dem Hinweis, das IOBroker Node mit installiert.
                                Mit dem Proxmox Zeug kenne ich mich nicht aus, wobei ich davon ausgehe, das die Pfade für Node identisch sein sollten und die sind bei Dir bei der Abfrage schon angemeckert worden ;)
                                Ich würde das jetzt einfach mal wieder alles löschen und schlicht die IOBroker Installation durchführen, danach mal die Node kontrollieren.
                                • E ecki945
                                  11.2
                                  v14.19.0
                                  6.14.16
                                  library: loaded
                                  Installed acl
                                  Installed gcc-c++
                                  Installed git
                                  Installed unzip
                                  Installed net-tools
                                  Installed cmake
                                  Autostart enabled!
                                  apollon77A
                                  apollon77A
                                  #321
                                  @ecki945 da meckert nix tun. Ist doch alles ok.
                                  • R
                                    R
                                    Rockfox
                                    #322
                                    Hallo bekomme beim Laden der Node.js 14 folgendes (Fehler) angezeigt. Kann ich die Installation trotzdem anstoßen.
                                    /opt/iobroker $ curl -sL https://deb.nodesource.com/setup_14.x | sudo -E bash -
                                    ## Installing the NodeSource Node.js 14.x repo...
                                    ## Populating apt-get cache...
                                    + apt-get update
                                    Holen:1 http://raspbian.raspberrypi.org/raspbian buster InRelease [15,0 kB]
                                    Holen:2 http://archive.raspberrypi.org/debian buster InRelease [32,6 kB]
                                    Ign:3 https://phoscon.de/apt/deconz buster InRelease
                                    Holen:4 https://deb.nodesource.com/node_12.x buster InRelease [4.584 B]
                                    Fehl:5 https://phoscon.de/apt/deconz buster Release
                                      Certificate verification failed: The certificate is NOT trusted. The certificate chain uses expired certificate.  Could not handshake: Error in the certificate verification.
                                    Holen:6 https://deb.nodesource.com/node_12.x buster/main armhf Packages [783 B]
                                    E: Das Depot »https://phoscon.de/apt/deconz buster Release« enthält keine Release-Datei mehr.
                                    N: Eine Aktualisierung von solch einem Depot kann nicht auf eine sichere Art durchgeführt werden, daher ist es standardmäßig deaktiviert.
                                    N: Weitere Details zur Erzeugung von Paketdepots sowie zu deren Benutzerkonfiguration finden Sie in der Handbuchseite apt-secure(8).
                                    E: Für das Depot »http://raspbian.raspberrypi.org/raspbian buster InRelease« wurde der »Suite«-Wert von »stable« in »oldstable« geändert.
                                    N: Sie müssen dies explizit bestätigen, bevor Aktualisierungen von diesem Depot angewendet werden können. Lesen Sie die apt-secure(8)-Handbuchseite, wenn Sie weitere Informationen benötigen.
                                    E: Für das Depot »http://archive.raspberrypi.org/debian buster InRelease« wurde der »Suite«-Wert von »testing« in »oldstable« geändert.
                                    Error executing command, exiting
                                    • R Rockfox
                                      + apt-get update
                                      Thomas BraunT
                                      Thomas BraunT
                                      #323
                                      @rockfox
                                      sudo apt update
                                      sudo apt full-upgrade
                                      sudo reboot
                                      Rückfragen bejahen.
                                      R 1 Antwort Letzte Antwort
                                        @rockfox
                                        sudo apt update
                                        sudo reboot
                                        Rückfragen bejahen.
                                        R
                                        R
                                        Rockfox
                                        #324
                                        • J Jan1
                                          @ecki945
                                          #325
                                          @jan1 sagte in [How-to] Node.js für ioBroker richtig updaten - 2021 Edition:
                                          das steht doch drin -in großem roten Kasten vorweg:
                                          mit dem aktuellen Installer von ioBroker (siehe unten) wird auf einem System ohne node.js automatisch die aktuell empfohlene Version von node.js mit installiert! Eine vorherige separate Installation von node.js ist somit nicht mehr nötig.
                                          84.2k
