  4. Adapter Paketverfolgung DHL, Briefe, Amazon, DPD,GLS,UPS,17T
17trackamazonbriefedhldpdglsups
1.6k Beiträge 130 Kommentatoren 870.0k Aufrufe 117 Beobachtet
  • Jabba_the_HuttJ
    Jabba_the_HuttJ
    Jabba_the_Hutt
    #239
    minimal reicht .... wenn du eben libpango-1.0-0 verwendest. (aber das brauche ich dir ja nicht zu sagen ;) )
    • G Gruter
      @tombox
      Leider wieder ein schwall mit Fehlermeldungen:
      parcel.0
      2022-02-07 22:07:26.925 warn No image received for https://briefankuendigung.dhl.de/pdapp-web/image/XXXX
      parcel.0
      2022-02-07 22:07:26.924 error {"type":"Buffer","data":[123,34,101,114,114,111,114,95,99,111,100,101,34,58,32,34,85,78,65,85,84,72,79,82,73,90,69,68,34,44,32,34,101,114,114,111,114,95,109,101,115,115,97,103,101,34,58,32,34,84,104,101,32,117,115,101,114,32,97,99,99,101,115,115,32,116,111,107,101,110,32,105,115,32,109,105,115,115,105,110,103,34,44,32,34,115,116,97,116,117,115,34,58,32,52,48,49,125]}
      parcel.0
      2022-02-07 22:07:26.924 error Error: Request failed with status code 401
      parcel.0
      2022-02-07 22:07:26.922 warn No image received for https://briefankuendigung.dhl.de/pdapp-web/image/XXXX
      parcel.0
      2022-02-07 22:07:26.921 error {"type":"Buffer","data":[123,34,101,114,114,111,114,95,99,111,100,101,34,58,32,34,85,78,65,85,84,72,79,82,73,90,69,68,34,44,32,34,101,114,114,111,114,95,109,101,115,115,97,103,101,34,58,32,34,84,104,101,32,117,115,101,114,32,97,99,99,101,115,115,32,116,111,107,101,110,32,105,115,32,109,105,115,115,105,110,103,34,44,32,34,115,116,97,116,117,115,34,58,32,52,48,49,125]}
      parcel.0
      2022-02-07 22:07:26.921 error Error: Request failed with status code 401
      parcel.0
      2022-02-07 22:07:26.910 info undefined is not a valid state value for id "parcel.0.dpd.json"
      parcel.0
      2022-02-07 22:07:26.083 warn No image received for https://briefankuendigung.dhl.de/pdapp-web/image/XXXX
      parcel.0
      2022-02-07 22:07:26.083 error {"type":"Buffer","data":[123,34,101,114,114,111,114,95,99,111,100,101,34,58,32,34,85,78,65,85,84,72,79,82,73,90,69,68,34,44,32,34,101,114,114,111,114,95,109,101,115,115,97,103,101,34,58,32,34,84,104,101,32,117,115,101,114,32,97,99,99,101,115,115,32,116,111,107,101,110,32,105,115,32,109,105,115,115,105,110,103,34,44,32,34,115,116,97,116,117,115,34,58,32,52,48,49,125]}
      parcel.0
      2022-02-07 22:07:26.082 error Error: Request failed with status code 401
      parcel.0
      2022-02-07 22:07:26.076 warn No image received for https://briefankuendigung.dhl.de/pdapp-web/image/XXXX
      parcel.0
      2022-02-07 22:07:26.076 error {"type":"Buffer","data":[123,34,101,114,114,111,114,95,99,111,100,101,34,58,32,34,85,78,65,85,84,72,79,82,73,90,69,68,34,44,32,34,101,114,114,111,114,95,109,101,115,115,97,103,101,34,58,32,34,84,104,101,32,117,115,101,114,32,97,99,99,101,115,115,32,116,111,107,101,110,32,105,115,32,109,105,115,115,105,110,103,34,44,32,34,115,116,97,116,117,115,34,58,32,52,48,49,125]}
      parcel.0
      2022-02-07 22:07:26.075 error Error: Request failed with status code 401
      parcel.0
      2022-02-07 22:07:26.065 warn No image received for https://briefankuendigung.dhl.de/pdapp-web/image/XXXX
      parcel.0
      2022-02-07 22:07:26.064 error {"type":"Buffer","data":[123,34,101,114,114,111,114,95,99,111,100,101,34,58,32,34,85,78,65,85,84,72,79,82,73,90,69,68,34,44,32,34,101,114,114,111,114,95,109,101,115,115,97,103,101,34,58,32,34,84,104,101,32,117,115,101,114,32,97,99,99,101,115,115,32,116,111,107,101,110,32,105,115,32,109,105,115,115,105,110,103,34,44,32,34,115,116,97,116,117,115,34,58,32,52,48,49,125]}
      parcel.0
      2022-02-07 22:07:26.064 error Error: Request failed with status code 401
      parcel.0
      2022-02-07 22:07:26.062 warn No image received for https://briefankuendigung.dhl.de/pdapp-web/image/XXXX
      parcel.0
      2022-02-07 22:07:26.062 error {"type":"Buffer","data":[123,34,101,114,114,111,114,95,99,111,100,101,34,58,32,34,85,78,65,85,84,72,79,82,73,90,69,68,34,44,32,34,101,114,114,111,114,95,109,101,115,115,97,103,101,34,58,32,34,84,104,101,32,117,115,101,114,32,97,99,99,101,115,115,32,116,111,107,101,110,32,105,115,32,109,105,115,115,105,110,103,34,44,32,34,115,116,97,116,117,115,34,58,32,52,48,49,125]}
      parcel.0
      2022-02-07 22:07:26.061 error Error: Request failed with status code 401
      parcel.0
      2022-02-07 22:07:26.054 warn No image received for https://briefankuendigung.dhl.de/pdapp-web/image/XXXX
      parcel.0
      2022-02-07 22:07:26.053 error {"type":"Buffer","data":[123,34,101,114,114,111,114,95,99,111,100,101,34,58,32,34,85,78,65,85,84,72,79,82,73,90,69,68,34,44,32,34,101,114,114,111,114,95,109,101,115,115,97,103,101,34,58,32,34,84,104,101,32,117,115,101,114,32,97,99,99,101,115,115,32,116,111,107,101,110,32,105,115,32,109,105,115,115,105,110,103,34,44,32,34,115,116,97,116,117,115,34,58,32,52,48,49,125]}
      parcel.0
      2022-02-07 22:07:26.052 error Error: Request failed with status code 401
      T
      T
      tombox
      #240
      @gruter ich habe die anzahl reduziert aber es ist nun mal ein fehler. was du probieren kann sind dhl.briefe zu löschen
      • Jabba_the_HuttJ Jabba_the_Hutt
        Thomas BraunT
        Thomas BraunT
        Most Active Developer
        #241
        @jabba_the_hutt
        Mit Variante #1 in RunLevel 3 hatte ich angefangen.
        Final gelaufen ist das erst nach Variante#3 + zusätzlicher Installation des Paketes 'chromium-browser' in RunLevel 5.
        Das werde ich aber nicht weiter so fahren.
        Jabba_the_HuttJ T 2 Antworten Letzte Antwort
          @jabba_the_hutt
          Jabba_the_HuttJ
          Jabba_the_HuttJ
          Jabba_the_Hutt
          #242
          Variante 1 hat bei mir gereicht. Die sandbox für chromium war das einzige Problem wegen Proxmox.
            @jabba_the_hutt
            T
            T
            tombox
            #243
            @thomas-braun sind zwar viele unschöne abhängigkeiten aber ein ganzer desktop ist es nicht
            https://packages.ubuntu.com/bionic/chromium-browser
            chromium-browser wird auf jeden fall nicht gebraucht das kommt mit puppeteer mit
            Leider habe ich keine Möglichkeit gefunden amazon ohne echten browser zu rendern
            • T tombox
              Thomas BraunT
              Thomas BraunT
              #244
              @tombox
              Hier wird doch sogar nach der Binairy von chromium-browser verlangt:
              Error: Failed to launch the browser process! spawn /usr/bin/chromium-browser
              Jabba_the_HuttJ 1 Antwort Letzte Antwort
                @tombox
                Jabba_the_HuttJ
                Jabba_the_HuttJ
                Jabba_the_Hutt
                #245
                puppeteer ... headless chrom ;)
                Da hat es was anders bei dir. Ich bin noch immer auf runlevel 3 ohne x server.
                • T tombox
                  Thomas BraunT
                  Thomas BraunT
                  #246
                  @tombox sagte in Test Adapter parcel Paketverfolgung DHL v0.0.1:
                  Das muss aber auch irgendwie gehen. Die von mir verwendete Tracking-App auf meinem Android-Gerät parst bestimmt nicht die komplette Webseite von amazon:
                  https://deliveries.orrs.de/
                  • Jabba_the_HuttJ
                    Jabba_the_HuttJ
                    Jabba_the_Hutt
                    schrieb am zuletzt editiert von Jabba_the_Hutt
                    #247
                    @tombox
                    Gugg mal, ob Du damit etwas anfangen kannst. Ich hab mir das nicht im Dteail angeguggt, aber das ist jedenfalls ne API für Lieferanten/Zusteller usw ...
                    https://www.tracktry.com/api-all-couriers.html!Bildschirmfoto vom 2022-02-07 22-54-18.png
                      T
                      T
                      tombox
                      #248
                      @Jabba_the_Hutt
                      Tracktry unterstütztnicht laut webseite amazon.de
                      • T tombox
                        @Jabba_the_Hutt
                        Thomas BraunT
                        Thomas BraunT
                        #249
                        @tombox
                        Klar macht 'Lieferungen' das:
                        Versandhandel-Integration
                        In den Synchronisationseinstellungen können Pro-Benutzer ganz einfach sämtliche Bestellungen ihres Amazon und eBay-Accounts importieren. Außerdem wird die Sendungsverfolgung fortgeführt, sobald das Paket an DHL, Hermes, UPS usw. übergeben wurde (nur für nachverfolgbare Direktkäufe).
                        Aber ich weiß halt nicht wie es gemacht wird.
                        • FlexerF
                          FlexerF
                          Flexer
                          #250
                          @tombox Guten Morgen.
                          Habe gerade festgestellt dass mein Script nicht mehr triggert. Wenn ich bei DHL, DPD und Amazon eingeloggt findet keine Änderung statt. Wenn ich nur bei DHL eingeloggt bin klappt es wieder. Grüße
                          Unterm Strich ist alles besser.
                          Ja, voll geil hier!
                          • FlexerF Flexer
                            T
                            T
                            tombox
                            #251
                            @flexer welcher datenpunkt/datenpunkte ändert sich nicht
                            • WszeneW
                              WszeneW
                              Wszene
                              #252
                              Ich habe mir jetzt auch mal den Adapter installiert weil er mich neugierig gemacht hat
                              Aber wie mache ich das mit Amazon
                              Wo kann ich denn den SMS-Code eingeben
                              Bei DHL hat es wunderbar geklappt
                              Marcel
                              Meine Hard- & Software:
                              • CC2652P Zigbee Stick
                              • Lichtschalter mit Tasmota
                              • IKEA TRÅDFRI Glühbirnen
                              • Aqara Sensoren
                              • WszeneW Wszene
                                Marcel
                                T
                                T
                                tombox
                                #253
                                @wszene Eigentlich gibt es keine SMS oder gibt es amazon account auch 2fa ?
                                K WszeneW 2 Antworten Letzte Antwort
                                • T tombox
                                  K
                                  K
                                  kiste01
                                  #254
                                  @tombox
                                  Ich bekomme amazon auch nicht angezeigt. Bei Amazon hab ich 2FA - bei jeder Anmeldung an einem neuen Browser muss ich die Anmeldung mit einer SMS bestätigen. Vielleicht geht Amazon aktuell erst bei denen, die keine 2FA haben. Bestimmt wird das noch eingebaut in den Adapter.
                                  • L
                                    L
                                    Lucky_ESA
                                    #255
                                    leider bekomme ich amazon gar nicht zum laufen. Habe Raspi 4 mit Buster...Variante 1-3 bringen auch keine Abhilfe.
                                    2022-02-08 21:42:18.331  - info: parcel.0 (497) starting. Version 0.0.1 (non-npm: TA2k/ioBroker.parcel#dfc2068a8772a670fe6e53a2203a13765b34fe7f) in /opt/iobroker/node_modules/iobroker.parcel, node: v14.19.0, js-controller: 4.0.4
                                    2022-02-08 21:42:18.435  - info: parcel.0 (497) Login to Amazon
                                    2022-02-08 21:42:18.507  - error: parcel.0 (497) Error: Failed to launch the browser process!
                                    /opt/iobroker/node_modules/puppeteer/.local-chromium/linux-961656/chrome-linux/chrome: 1: /opt/iobroker/node_modules/puppeteer/.local-chromium/linux-961656/chrome-linux/chrome: cannot open DLS]dq}����������������
                                    $-5DTY_hr: No such file
                                    /opt/iobroker/node_modules/puppeteer/.local-chromium/linux-961656/chrome-linux/chrome: 1: /opt/iobroker/node_modules/puppeteer/.local-chromium/linux-961656/chrome-linux/chrome: ������������: not found
                                    /opt/iobroker/node_modules/puppeteer/.local-chromium/linux-961656/chrome-linux/chrome: 1: /opt/iobroker/node_modules/puppeteer/.local-chromium/linux-961656/chrome-linux/chrome: @GKRahqx�������������
                                    9@MZp: not found
                                    /opt/iobroker/node_modules/puppeteer/.local-chromium/linux-961656/chrome-linux/chrome: 1: /opt/iobroker/node_modules/puppeteer/.local-chromium/linux-961656/chrome-linux/chrome: ELF: not found
                                    /opt/iobroker/node_modules/puppeteer/.local-chromium/linux-961656/chrome-linux/chrome: 2: /opt/iobroker/node_modules/puppeteer/.local-chromium/linux-961656/chrome-linux/chrome: Syntax error: Unterminated quoted string
                                    TROUBLESHOOTING: https://github.com/puppeteer/puppeteer/blob/main/docs/troubleshooting.md
                                    2022-02-08 21:42:18.509  - error: parcel.0 (497) Can't start puppeteer please execute on your ioBroker command line
                                    2022-02-08 21:42:18.510  - error: parcel.0 (497) sudo apt-get install -y libnss3 libatk1.0-0 libatk-bridge2.0-0 libcups2 libdrm-dev libxkbcommon-dev libxcomposite1 libxdamage1 libxfixes3 libxrandr2 libgbm-dev libpango-1.0-0
                                    2022-02-08 21:42:18.510  - error: parcel.0 (497) More infos: https://github.com/TA2k/ioBroker.parcel/blob/master/README.md#amazon-vorbedingungen
                                    2022-02-08 21:42:41.517  - info: host.raspberrypi stopInstance system.adapter.parcel.0 (force=false, process=true)
                                    Es ist sehr befremdlich diese Umstände zu betreiben um einen Adapter zum Laufen zu bekommen.
                                    @tombox Gibt es da nicht ein delivery tracker von Amazon? Habe leider gerade keine Zeit mir das anzuschauen...
                                    ChaotC Thomas BraunT T 3 Antworten Letzte Antwort
                                    -2
                                    • L Lucky_ESA
                                      9@MZp: not found
                                      ChaotC
                                      ChaotC
                                      Chaot
                                      #256
                                      @lucky_esa sagte in Test Adapter parcel Paketverfolgung DHL v0.0.1:
                                      Du hast schon die Überschrift und den ersten Post gelesen?
                                      Das ist ein TEST! und der Adapter wird gerade erst entwickelt. Wenn du was fertiges haben willst das einfach zu bedienen ist dann musst du warten.
                                      • L
                                        L
                                        Lucky_ESA
                                        #257
                                        @Chaot Ja, Überschrift und Thread Inhalt ist mir bekannt.
                                        • DickenD
                                          DickenD
                                          Dicken
                                          schrieb am zuletzt editiert von Dicken
                                          #258
                                          Und dann wunderst du dich darüber, dass man Aufwand betreiben muss um das Ding ans laufen zu kriegen? :D
                                          Der Adapter is doch noch in der Entwicklung und hier sind ein haufen Leute grade am testen.
                                          Ich verfolge den Thread hier seit Beginn und find es total genial in welch kurzer Zeit man hier Fortschritte macht, wenn man bedenkt, dass hier vor zwei Wochen mit gestartet wurde.
                                          Wenn man keine Zeit oder Ahnung hat zu helfen, sollte man vllt einfach abwarten, bis der Adapter im stable ist ;)
                                          L 1 Antwort Letzte Antwort
                                          84.2k
