  4. Adapter Paketverfolgung DHL, Briefe, Amazon, DPD,GLS,UPS,17T
    6.7k
17trackamazonbriefedhldpdglsups
1.6k Beiträge 129 Kommentatoren 729.1k Aufrufe 117 Beobachtet
  • T tombox
    @gruter Fehlermeldung das mit der PIN muss ich mal schauen ob ich es hinbekomme aber wird schwer. reicht manchmal einfach kurz zu warten und dann adapter neustarten
    Gruter
    #234
    @tombox
    Leider wieder ein schwall mit Fehlermeldungen:
    parcel.0
    2022-02-07 22:07:26.925 warn No image received for https://briefankuendigung.dhl.de/pdapp-web/image/XXXX
    parcel.0
    2022-02-07 22:07:26.924 error {"type":"Buffer","data":[123,34,101,114,114,111,114,95,99,111,100,101,34,58,32,34,85,78,65,85,84,72,79,82,73,90,69,68,34,44,32,34,101,114,114,111,114,95,109,101,115,115,97,103,101,34,58,32,34,84,104,101,32,117,115,101,114,32,97,99,99,101,115,115,32,116,111,107,101,110,32,105,115,32,109,105,115,115,105,110,103,34,44,32,34,115,116,97,116,117,115,34,58,32,52,48,49,125]}
    parcel.0
    2022-02-07 22:07:26.924 error Error: Request failed with status code 401
    parcel.0
    2022-02-07 22:07:26.922 warn No image received for https://briefankuendigung.dhl.de/pdapp-web/image/XXXX
    parcel.0
    2022-02-07 22:07:26.921 error {"type":"Buffer","data":[123,34,101,114,114,111,114,95,99,111,100,101,34,58,32,34,85,78,65,85,84,72,79,82,73,90,69,68,34,44,32,34,101,114,114,111,114,95,109,101,115,115,97,103,101,34,58,32,34,84,104,101,32,117,115,101,114,32,97,99,99,101,115,115,32,116,111,107,101,110,32,105,115,32,109,105,115,115,105,110,103,34,44,32,34,115,116,97,116,117,115,34,58,32,52,48,49,125]}
    parcel.0
    2022-02-07 22:07:26.921 error Error: Request failed with status code 401
    parcel.0
    2022-02-07 22:07:26.910 info undefined is not a valid state value for id "parcel.0.dpd.json"
    parcel.0
    2022-02-07 22:07:26.083 warn No image received for https://briefankuendigung.dhl.de/pdapp-web/image/XXXX
    parcel.0
    2022-02-07 22:07:26.083 error {"type":"Buffer","data":[123,34,101,114,114,111,114,95,99,111,100,101,34,58,32,34,85,78,65,85,84,72,79,82,73,90,69,68,34,44,32,34,101,114,114,111,114,95,109,101,115,115,97,103,101,34,58,32,34,84,104,101,32,117,115,101,114,32,97,99,99,101,115,115,32,116,111,107,101,110,32,105,115,32,109,105,115,115,105,110,103,34,44,32,34,115,116,97,116,117,115,34,58,32,52,48,49,125]}
    parcel.0
    2022-02-07 22:07:26.082 error Error: Request failed with status code 401
    parcel.0
    2022-02-07 22:07:26.076 warn No image received for https://briefankuendigung.dhl.de/pdapp-web/image/XXXX
    parcel.0
    2022-02-07 22:07:26.076 error {"type":"Buffer","data":[123,34,101,114,114,111,114,95,99,111,100,101,34,58,32,34,85,78,65,85,84,72,79,82,73,90,69,68,34,44,32,34,101,114,114,111,114,95,109,101,115,115,97,103,101,34,58,32,34,84,104,101,32,117,115,101,114,32,97,99,99,101,115,115,32,116,111,107,101,110,32,105,115,32,109,105,115,115,105,110,103,34,44,32,34,115,116,97,116,117,115,34,58,32,52,48,49,125]}
    parcel.0
    2022-02-07 22:07:26.075 error Error: Request failed with status code 401
    parcel.0
    2022-02-07 22:07:26.065 warn No image received for https://briefankuendigung.dhl.de/pdapp-web/image/XXXX
    parcel.0
    2022-02-07 22:07:26.064 error {"type":"Buffer","data":[123,34,101,114,114,111,114,95,99,111,100,101,34,58,32,34,85,78,65,85,84,72,79,82,73,90,69,68,34,44,32,34,101,114,114,111,114,95,109,101,115,115,97,103,101,34,58,32,34,84,104,101,32,117,115,101,114,32,97,99,99,101,115,115,32,116,111,107,101,110,32,105,115,32,109,105,115,115,105,110,103,34,44,32,34,115,116,97,116,117,115,34,58,32,52,48,49,125]}
    parcel.0
    2022-02-07 22:07:26.064 error Error: Request failed with status code 401
    parcel.0
    2022-02-07 22:07:26.062 warn No image received for https://briefankuendigung.dhl.de/pdapp-web/image/XXXX
    parcel.0
    2022-02-07 22:07:26.062 error {"type":"Buffer","data":[123,34,101,114,114,111,114,95,99,111,100,101,34,58,32,34,85,78,65,85,84,72,79,82,73,90,69,68,34,44,32,34,101,114,114,111,114,95,109,101,115,115,97,103,101,34,58,32,34,84,104,101,32,117,115,101,114,32,97,99,99,101,115,115,32,116,111,107,101,110,32,105,115,32,109,105,115,115,105,110,103,34,44,32,34,115,116,97,116,117,115,34,58,32,52,48,49,125]}
    parcel.0
    2022-02-07 22:07:26.061 error Error: Request failed with status code 401
    parcel.0
    2022-02-07 22:07:26.054 warn No image received for https://briefankuendigung.dhl.de/pdapp-web/image/XXXX
    parcel.0
    2022-02-07 22:07:26.053 error {"type":"Buffer","data":[123,34,101,114,114,111,114,95,99,111,100,101,34,58,32,34,85,78,65,85,84,72,79,82,73,90,69,68,34,44,32,34,101,114,114,111,114,95,109,101,115,115,97,103,101,34,58,32,34,84,104,101,32,117,115,101,114,32,97,99,99,101,115,115,32,116,111,107,101,110,32,105,115,32,109,105,115,115,105,110,103,34,44,32,34,115,116,97,116,117,115,34,58,32,52,48,49,125]}
    parcel.0
    2022-02-07 22:07:26.052 error Error: Request failed with status code 401
    • T tombox
      #235
      @tombox
      Ich glaube da muss doch ein X laufen:
      2022-02-07 22:09:10.352  - info: parcel.0 (34868) Login to Amazon
      2022-02-07 22:09:10.389  - error: parcel.0 (34868) Error: Failed to launch the browser process! spawn /usr/bin/chromium-browser ENOENT
      TROUBLESHOOTING: https://github.com/puppeteer/puppeteer/blob/main/docs/troubleshooting.md
      2022-02-07 22:09:10.390  - error: parcel.0 (34868) Can't start puppeteer please execute on your ioBroker command line
      Und das Paket chromium-browser muss noch installiert werden.
      • Jabba_the_HuttJ Offline
        Jabba_the_Hutt
        #236
        Amazon läuft jetzt auch bei mir unter Proxmox ^_^
        Gute Arbeit! (y)
          @tombox
          tombox
          #237
          @thomas-braun Es muss nicht zwingend das komplette paket installiert werden
          https://github.com/TA2k/ioBroker.parcel#amazon-vorbedingungen
          • T tombox
            #238
            @tombox
            Ich habe aufsteigend alle 3 Varianten installiert. Am Ende fehlte immer noch chromium-browser. Nach der Installation lief es. Aber das hat mir natürlich einen kompletten Desktop auf das System geballert.
              Jabba_the_Hutt
              #239
              minimal reicht .... wenn du eben libpango-1.0-0 verwendest. (aber das brauche ich dir ja nicht zu sagen ;) )
              • G Gruter
                @tombox
                parcel.0
                parcel.0
                parcel.0
                parcel.0
                parcel.0
                parcel.0
                parcel.0
                parcel.0
                parcel.0
                parcel.0
                parcel.0
                parcel.0
                parcel.0
                parcel.0
                parcel.0
                parcel.0
                parcel.0
                parcel.0
                parcel.0
                parcel.0
                parcel.0
                parcel.0
                tombox
                #240
                @gruter ich habe die anzahl reduziert aber es ist nun mal ein fehler. was du probieren kann sind dhl.briefe zu löschen
                • Jabba_the_HuttJ Jabba_the_Hutt
                  #241
                  @jabba_the_hutt
                  Mit Variante #1 in RunLevel 3 hatte ich angefangen.
                  Final gelaufen ist das erst nach Variante#3 + zusätzlicher Installation des Paketes 'chromium-browser' in RunLevel 5.
                  Das werde ich aber nicht weiter so fahren.
                  Jabba_the_HuttJ T 2 Antworten Letzte Antwort
                    @jabba_the_hutt
                    Jabba_the_Hutt
                    #242
                    Variante 1 hat bei mir gereicht. Die sandbox für chromium war das einzige Problem wegen Proxmox.
                      @jabba_the_hutt
                      tombox
                      #243
                      @thomas-braun sind zwar viele unschöne abhängigkeiten aber ein ganzer desktop ist es nicht
                      https://packages.ubuntu.com/bionic/chromium-browser
                      chromium-browser wird auf jeden fall nicht gebraucht das kommt mit puppeteer mit
                      Leider habe ich keine Möglichkeit gefunden amazon ohne echten browser zu rendern
                      • T tombox
                        #244
                        @tombox
                        Hier wird doch sogar nach der Binairy von chromium-browser verlangt:
                        Jabba_the_HuttJ 1 Antwort Letzte Antwort
                          @tombox
                          Jabba_the_Hutt
                          #245
                          puppeteer ... headless chrom ;)
                          Da hat es was anders bei dir. Ich bin noch immer auf runlevel 3 ohne x server.
                          • T tombox
                            #246
                            @tombox sagte in Test Adapter parcel Paketverfolgung DHL v0.0.1:
                            Das muss aber auch irgendwie gehen. Die von mir verwendete Tracking-App auf meinem Android-Gerät parst bestimmt nicht die komplette Webseite von amazon:
                            https://deliveries.orrs.de/
                              Jabba_the_Hutt
                              schrieb am zuletzt editiert von Jabba_the_Hutt
                              #247
                              @tombox
                              Gugg mal, ob Du damit etwas anfangen kannst. Ich hab mir das nicht im Dteail angeguggt, aber das ist jedenfalls ne API für Lieferanten/Zusteller usw ...
                              https://www.tracktry.com/api-all-couriers.html!Bildschirmfoto vom 2022-02-07 22-54-18.png
                                tombox
                                #248
                                @Jabba_the_Hutt
                                Tracktry unterstütztnicht laut webseite amazon.de
                                • T tombox
                                  @Jabba_the_Hutt
                                  #249
                                  @tombox
                                  Klar macht 'Lieferungen' das:
                                  Versandhandel-Integration
                                  In den Synchronisationseinstellungen können Pro-Benutzer ganz einfach sämtliche Bestellungen ihres Amazon und eBay-Accounts importieren. Außerdem wird die Sendungsverfolgung fortgeführt, sobald das Paket an DHL, Hermes, UPS usw. übergeben wurde (nur für nachverfolgbare Direktkäufe).
                                  Aber ich weiß halt nicht wie es gemacht wird.
                                  • FlexerF Offline
                                    FlexerF Offline
                                    Flexer
                                    #250
                                    @tombox Guten Morgen.
                                    Habe gerade festgestellt dass mein Script nicht mehr triggert. Wenn ich bei DHL, DPD und Amazon eingeloggt findet keine Änderung statt. Wenn ich nur bei DHL eingeloggt bin klappt es wieder. Grüße
                                    Unterm Strich ist alles besser.
                                    Ja, voll geil hier!
                                    • FlexerF Flexer
                                      tombox
                                      #251
                                      @flexer welcher datenpunkt/datenpunkte ändert sich nicht
                                      • WszeneW Offline
                                        WszeneW Offline
                                        Wszene
                                        #252
                                        Ich habe mir jetzt auch mal den Adapter installiert weil er mich neugierig gemacht hat
                                        Aber wie mache ich das mit Amazon
                                        Wo kann ich denn den SMS-Code eingeben
                                        Bei DHL hat es wunderbar geklappt
                                        Marcel
                                        Meine Hard- & Software:
                                        • CC2652P Zigbee Stick
                                        • Lichtschalter mit Tasmota
                                        • IKEA TRÅDFRI Glühbirnen
                                        • Aqara Sensoren
                                        • WszeneW Wszene
                                          Marcel
                                          tombox
                                          #253
                                          @wszene Eigentlich gibt es keine SMS oder gibt es amazon account auch 2fa ?
                                          K WszeneW 2 Antworten Letzte Antwort
