    apollon77A
7.6k Beiträge 296 Kommentatoren 8.5m Aufrufe 201 Beobachtet
  • s.bormannS s.bormann
    @buchner51 sagte in Test Adapter iQontrol 1.11.x Vis:
        {        "common": {        "name": "Trigger LOCK action",        "role": "button",        "type": "boolean",        "write": true,        "read": false        },        "type": "state",        "native": {},        "from": "system.adapter.nuki-extended.0",        "user": "system.user.admin",        "ts": 1622990362528,        "_id": "nuki-extended.0.smartlocks.haustür_._ACTION.LOCK",        "acl": {        "object": 1636,        "state": 1636,        "owner": "system.user.admin",        "ownerGroup": "system.group.administrator"        }        }
    Da müssen doch trotzdem noch mehr sein. Womit öffnet man die Tür. Wäre echt gut, wenn Du die Infos nicht so sparsam rausrücken könntest. Muss mich da jedes mal wieder rein denken.
    Edit: Exportier doch mal den ganzen NUKI-Baum und poste ihn mir, dann kann ich ihn importieren und schauen, wie es gehen könnte.
    B
    B
    buchner51
    #6779
    @s-bormann
      "nuki-extended.0.smartlocks": {
        "common": {
          "name": "Nuki Smartlocks",
          "write": false
        "type": "channel",
        "native": {},
        "ts": 1622990362526,
        "_id": "nuki-extended.0.smartlocks",
        "acl": {
          "object": 1636,
      "nuki-extended.0.smartlocks.haustür_": {
        "common": {
          "name": "Haustür ",
          "write": false
        "type": "channel",
        "native": {},
        "_id": "nuki-extended.0.smartlocks.haustür_",
        "acl": {
          "object": 1636,
      "nuki-extended.0.smartlocks.haustür_._ACTION": {
        "common": {
          "name": "Trigger an action",
          "role": "value",
          "type": "number",
          "write": true,
          "states": {
            "0": "NO_ACTION",
            "1": "UNLOCK",
            "2": "LOCK",
            "3": "UNLATCH",
            "4": "LOCK_N_GO",
            "5": "LOCK_N_GO_WITH_UNLATCH"
        "type": "state",
        "native": {},
        "_id": "nuki-extended.0.smartlocks.haustür_._ACTION",
        "acl": {
          "object": 1636,
          "state": 1636,
      "nuki-extended.0.smartlocks.haustür_._ACTION.LOCK": {
        "common": {
          "role": "button",
          "type": "boolean",
          "write": true,
          "read": false
        "type": "state",
        "native": {},
        "acl": {
          "object": 1636,
          "state": 1636,
      "nuki-extended.0.smartlocks.haustür_._ACTION.LOCK_N_GO": {
        "common": {
          "name": "Trigger LOCK_N_GO action",
          "role": "button",
          "type": "boolean",
          "write": true,
          "read": false
        "type": "state",
        "native": {},
        "_id": "nuki-extended.0.smartlocks.haustür_._ACTION.LOCK_N_GO",
        "acl": {
          "object": 1636,
          "state": 1636,
      "nuki-extended.0.smartlocks.haustür_._ACTION.LOCK_N_GO_WITH_UNLATCH": {
        "common": {
          "name": "Trigger LOCK_N_GO_WITH_UNLATCH action",
          "role": "button",
          "type": "boolean",
          "write": true,
          "read": false
        "type": "state",
        "native": {},
        "_id": "nuki-extended.0.smartlocks.haustür_._ACTION.LOCK_N_GO_WITH_UNLATCH",
        "acl": {
          "object": 1636,
          "state": 1636,
      "nuki-extended.0.smartlocks.haustür_._ACTION.UNLATCH": {
        "common": {
          "name": "Trigger UNLATCH action",
          "role": "button",
          "type": "boolean",
          "write": true,
          "read": false
        "type": "state",
        "native": {},
        "_id": "nuki-extended.0.smartlocks.haustür_._ACTION.UNLATCH",
        "acl": {
          "object": 1636,
          "state": 1636,
      "nuki-extended.0.smartlocks.haustür_._ACTION.UNLOCK": {
        "common": {
          "name": "Trigger UNLOCK action",
          "role": "button",
          "type": "boolean",
          "write": true,
          "read": false
        "type": "state",
        "native": {},
        "_id": "nuki-extended.0.smartlocks.haustür_._ACTION.UNLOCK",
        "acl": {
          "object": 1636,
          "state": 1636,
      "nuki-extended.0.smartlocks.haustür_.bridgeId": {
        "common": {
          "name": "Bridge ID of the Nuki",
          "role": "value",
          "type": "number",
          "write": false
        "type": "state",
        "native": {},
        "ts": 1622990362529,
        "_id": "nuki-extended.0.smartlocks.haustür_.bridgeId",
        "acl": {
          "object": 1636,
          "state": 1636,
      "nuki-extended.0.smartlocks.haustür_.hex": {
        "common": {
          "name": "Hex ID of the Nuki",
          "role": "text",
          "type": "string",
          "write": false
        "type": "state",
        "native": {},
        "ts": 1622990362563,
        "_id": "nuki-extended.0.smartlocks.haustür_.hex",
        "acl": {
          "object": 1636,
          "state": 1636,
      "nuki-extended.0.smartlocks.haustür_.id": {
        "common": {
          "name": "ID of the Nuki",
          "role": "value",
          "type": "number",
          "write": false
        "type": "state",
        "native": {},
        "_id": "nuki-extended.0.smartlocks.haustür_.id",
        "acl": {
          "object": 1636,
          "state": 1636,
      "nuki-extended.0.smartlocks.haustür_.info": {
        "common": {
          "name": "Additional Information",
          "write": false
        "type": "channel",
        "native": {},
        "_id": "nuki-extended.0.smartlocks.haustür_.info",
        "acl": {
          "object": 1636,
      "nuki-extended.0.smartlocks.haustür_.info.firmwareVersion": {
        "common": {
          "name": "The firmware version",
          "role": "value",
          "type": "number",
          "write": false
        "type": "state",
        "native": {},
        "_id": "nuki-extended.0.smartlocks.haustür_.info.firmwareVersion",
        "acl": {
          "object": 1636,
          "state": 1636,
      "nuki-extended.0.smartlocks.haustür_.name": {
        "common": {
          "name": "Name of the Bridge / Nuki",
          "role": "text",
          "type": "string",
          "write": false
        "type": "state",
        "native": {},
        "_id": "nuki-extended.0.smartlocks.haustür_.name",
        "acl": {
          "object": 1636,
          "state": 1636,
      "nuki-extended.0.smartlocks.haustür_.state": {
        "common": {
          "name": "Current states",
          "write": false
        "type": "channel",
        "native": {},
        "_id": "nuki-extended.0.smartlocks.haustür_.state",
        "acl": {
          "object": 1636,
      "nuki-extended.0.smartlocks.haustür_.state.batteryChargeState": {
        "common": {
          "name": "Indicates battery charge level",
          "role": "value",
          "type": "number",
          "write": false
        "type": "state",
        "native": {},
        "ts": 1622995898502,
        "_id": "nuki-extended.0.smartlocks.haustür_.state.batteryChargeState",
        "acl": {
          "object": 1636,
          "state": 1636,
      "nuki-extended.0.smartlocks.haustür_.state.batteryCharging": {
        "common": {
          "name": "Indicates battery charging",
          "role": "indicator",
          "type": "boolean",
          "write": true,
          "read": false
        "type": "state",
        "native": {},
        "ts": 1622995898501,
        "_id": "nuki-extended.0.smartlocks.haustür_.state.batteryCharging",
        "acl": {
          "object": 1636,
          "state": 1636,
      "nuki-extended.0.smartlocks.haustür_.state.batteryCritical": {
        "common": {
          "name": "Indicates critical battery level",
          "role": "indicator.lowbat",
          "type": "boolean",
          "write": true,
          "read": false
        "type": "state",
        "native": {},
        "_id": "nuki-extended.0.smartlocks.haustür_.state.batteryCritical",
        "acl": {
          "object": 1636,
          "state": 1636,
      "nuki-extended.0.smartlocks.haustür_.state.deviceType": {
        "common": {
          "name": "Type of device",
          "role": "value",
          "type": "number",
          "write": false,
          "states": {
            "0": "Nuki Smart Lock",
            "2": "Nuki Opener"
        "type": "state",
        "native": {},
        "ts": 1622990531628,
        "_id": "nuki-extended.0.smartlocks.haustür_.state.deviceType",
        "acl": {
          "object": 1636,
          "state": 1636,
      "nuki-extended.0.smartlocks.haustür_.state.doorState": {
        "common": {
          "name": "Türsensor-DoorClosed(2)-DoorOpen(3)",
          "role": "value",
          "type": "number",
          "write": false,
          "states": {
            "0": "UNAVAILABLE",
            "1": "DEACTIVATED",
            "2": "DOOR_CLOSED",
            "3": "DOOR_OPENED",
            "4": "DOOR_STATE_UNKNOWN",
            "5": "CALIBRATING"
          "custom": {
            "iqontrol.0": {
              "0": "",
              "1": "",
              "2": "",
              "enabled": true,
              "invert": false,
              "confirm": false,
              "pincode": "",
              "step": "",
              "roundDigits": 2,
              "timeFormat": "x",
              "timeDisplayFormat": "dddd, DD.MM.YYYY HH:mm:ss",
              "targetValueId": "",
              "statesAddInput": false,
              "statesAddInputCaption": "Enter other value...",
              "showOnlyTargetValues": false,
              "readonly": false,
              "unit": "",
              "unit_zero": "LOCKED",
              "unit_one": "UNLATCHED",
              "min": "",
              "max": "",
              "type": "number",
              "role": "value",
              "targetValues": "",
              "states": {
                "DOOR_CLOSED": "true",
                "DOOR_OPENED": "false"
              "timeDisplayDontShowDistance": false
        "type": "state",
        "native": {},
        "_id": "nuki-extended.0.smartlocks.haustür_.state.doorState",
        "acl": {
          "object": 1636,
          "state": 1636,
        "ts": 1642363067003
      "nuki-extended.0.smartlocks.haustür_.state.doorStateName": {
        "common": {
          "name": "Current door-state name of the Nuki",
          "role": "text",
          "type": "string",
          "write": false
        "type": "state",
        "native": {},
        "_id": "nuki-extended.0.smartlocks.haustür_.state.doorStateName",
        "acl": {
          "object": 1636,
          "state": 1636,
      "nuki-extended.0.smartlocks.haustür_.state.lastDataUpdate": {
        "common": {
          "name": "Timestamp of last data update / refresh",
          "role": "date",
          "type": "string",
          "write": false
        "type": "state",
        "native": {},
        "_id": "nuki-extended.0.smartlocks.haustür_.state.lastDataUpdate",
        "acl": {
          "object": 1636,
          "state": 1636,
      "nuki-extended.0.smartlocks.haustür_.state.lastStateUpdate": {
        "common": {
          "name": "Timestamp of last state change",
          "role": "date",
          "type": "string",
          "write": false
        "type": "state",
        "native": {},
        "ts": 1622990362530,
        "_id": "nuki-extended.0.smartlocks.haustür_.state.lastStateUpdate",
        "acl": {
          "object": 1636,
          "state": 1636,
      "nuki-extended.0.smartlocks.haustür_.state.lockState": {
        "common": {
          "name": "Motorschloss-Locked(1)-Unlocked(3)",
          "role": "value",
          "type": "number",
          "write": false,
          "states": {
            "0": "UNCALIBRATED",
            "1": "LOCKED",
            "2": "UNLOCKING",
            "3": "UNLOCKED",
            "4": "LOCKING",
            "5": "UNLATCHED",
            "6": "UNLOCKED_LOCK_N_GO",
            "7": "UNLATCHING",
            "254": "MOTOR_BLOCKED",
            "255": "UNDEFINED"
          "custom": {
            "iqontrol.0": {
              "0": "",
              "1": "",
              "3": "",
              "enabled": true,
              "invert": false,
              "confirm": false,
              "pincode": "",
              "step": "",
              "roundDigits": 2,
              "timeFormat": "x",
              "readonly": false,
              "unit": "",
              "unit_zero": "",
              "unit_one": "",
              "min": "",
              "max": "",
              "type": "number",
              "role": "value",
              "targetValues": {},
              "states": {
                "1": "true",
                "3": "false"
        "type": "state",
        "native": {},
        "_id": "nuki-extended.0.smartlocks.haustür_.state.lockState",
        "acl": {
          "object": 1636,
          "state": 1636,
        "ts": 1642363118406
      "nuki-extended.0.smartlocks.haustür_.state.locked": {
        "common": {
          "name": "Indication if door is locked (boolean of lockState)",
          "role": "sensor.lock",
          "type": "boolean",
          "write": false,
          "states": {
            "0": "false",
            "1": "true",
            "2": "false",
            "3": "false",
            "4": "true",
            "5": "false",
            "6": "false",
            "7": "false",
            "254": "false",
            "255": "false"
        "type": "state",
        "native": {},
        "_id": "nuki-extended.0.smartlocks.haustür_.state.locked",
        "acl": {
          "object": 1636,
          "state": 1636,
        "ts": 1641742002315
      "nuki-extended.0.smartlocks.haustür_.state.mode": {
        "common": {
          "name": "Operation Mode of the Nuki or Opener",
          "role": "value",
          "type": "number",
          "write": false,
          "states": {
            "0": "UNINITIALIZED",
            "1": "PAIRING",
            "2": "NORMAL",
            "3": "CONTINUOUS",
            "4": "MAINTENANCE"
        "type": "state",
        "native": {},
        "_id": "nuki-extended.0.smartlocks.haustür_.state.mode",
        "acl": {
          "object": 1636,
          "state": 1636,
      "nuki-extended.0.smartlocks.haustür_.type": {
        "common": {
          "role": "value",
          "type": "number",
          "write": false,
          "states": {
            "2": "Nuki Opener"
        "type": "state",
        "native": {},
        "_id": "nuki-extended.0.smartlocks.haustür_.type",
        "acl": {
          "object": 1636,
          "state": 1636,
    meinst du so als Json?
    • dslraserD
      dslraserD
      dslraser
      #6780
      @s-bormann
      Hallo Sebastian,
      ich habe mich nochmal mit den Listen für Temperaturen und Batterien usw. beschäftigt. Gibt es eine "einfachere" Möglichkeit eine Liste mit Werten zu erstellen ? (z.B. auch über Aufzählungen) Ich bekomme es zwar damit hin, aber bei Batterien ist das viel klickerei.
      Hintergund:
      Ich lasse mir z.B. durch Alexa die Liste der Temperaturen ansagen, oder ich lasse mir auch eine Liste mit Temperaturen oder auch Batterien mit Werten per Telegram oder EMAIL schicken.
      Alle Listen die sonst erstellt werden sind aber immer ohne Werte. Oder habe ich es nur noch nicht gefunden wie es anders geht ?
      EDIT:
      In z.B. Telegram kann man es dann z.B. so darstellen
      oder auch so…
      • dslraserD dslraser
        @s-bormann
        Hallo Sebastian,
        Hintergund:
        EDIT:
        oder auch so…
        s.bormannS
        s.bormannS
        s.bormann
        #6781
        @dslraser sagte in Test Adapter iQontrol 1.11.x Vis:
        @s-bormann
        Hallo Sebastian,
        Hintergund:
        EDIT:
        oder auch so…
        Hi, aktuell geht das noch nicht, sollte sich aber implementieren lassen. Ich schau später mal danach.
          @s-bormann
          Hallo Sebastian,
          Hintergund:
          EDIT:
          oder auch so…
          s.bormannS
          s.bormannS
          s.bormann
          schrieb am zuletzt editiert von s.bormann
          #6782
          @s-bormann sagte in Test Adapter iQontrol 1.11.x Vis:
          @s-bormann
          Hallo Sebastian,
          Hintergund:
          EDIT:
          oder auch so…
          Ist jetzt auf Github. Waren ziemlich umfangreiche Änderungen nötig, also bitte gut testen :)
          Edit: Achso, hier muss es aktiviert werden:
            @s-bormann
            Hallo Sebastian,
            Hintergund:
            EDIT:
            oder auch so…
            dslraserD
            dslraserD
            dslraser
            #6783
            @s-bormann
            Danke, probiere ich und teste auch.
              @s-bormann
              Hallo Sebastian,
              Hintergund:
              EDIT:
              oder auch so…
              dslraserD
              dslraserD
              dslraser
              #6784
              Die Listen sind perfekt da, so wie ich sie brauche, aber es hagelt Fehler im Log.
              Log.txt
              Komme ich irgendwie zurück zu der Version davor ? Ich mußte iQontrol erstmal stoppen.
              EDIT:
              wieso läuft eigentlich iQontrol noch komplett, obwohl ich die Instanz gestoppt habe ? Ich kann sogar noch über iQontrol schalten...? (ist nach dem stoppen nur das Backend aus ?)
              Hier noch das Log aus dem Browserfenster
              host.iobroker	2022-01-29 21:00:21.708	info	instance system.adapter.tvspielfilm.0 terminated with code 0 (NO_ERROR)
              host.iobroker	2022-01-29 21:00:08.851	info	instance system.adapter.daswetter.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
              host.iobroker	2022-01-29 21:00:08.075	info	instance system.adapter.tvspielfilm.0 started with pid 23553
              host.iobroker	2022-01-29 21:00:06.489	info	instance system.adapter.ical.0 terminated with code 0 (NO_ERROR)
              host.iobroker	2022-01-29 21:00:04.056	info	instance system.adapter.daswetter.0 started with pid 23538
              host.iobroker	2022-01-29 21:00:00.037	info	instance system.adapter.ical.0 started with pid 23523
              host.iobroker	2022-01-29 20:54:51.546	info	instance system.adapter.admin.0 started with pid 23504
              host.iobroker	2022-01-29 20:54:49.051	info	instance system.adapter.admin.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
              host.iobroker	2022-01-29 20:54:48.478	info	stopInstance system.adapter.admin.0 send kill signal
              host.iobroker	2022-01-29 20:54:48.474	info	stopInstance system.adapter.admin.0 (force=false, process=true)
              host.iobroker	2022-01-29 20:47:56.364	info	instance system.adapter.admin.0 started with pid 23484
              host.iobroker	2022-01-29 20:47:53.861	info	instance system.adapter.admin.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
              host.iobroker	2022-01-29 20:47:53.296	info	stopInstance system.adapter.admin.0 send kill signal
              host.iobroker	2022-01-29 20:47:53.294	info	stopInstance system.adapter.admin.0 (force=false, process=true)
              host.iobroker	2022-01-29 20:47:36.106	info	"system.adapter.iqontrol.0" disabled
              host.iobroker	2022-01-29 20:47:20.321	warn	Do not restart adapter system.adapter.iqontrol.0 because restart loop detected
              host.iobroker	2022-01-29 20:47:20.321	info	Restart adapter system.adapter.iqontrol.0 because enabled
              host.iobroker	2022-01-29 20:47:20.321	error	instance system.adapter.iqontrol.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
              host.iobroker	2022-01-29 20:47:20.321	error	Caught by controller[5]: at processImmediate (internal/timers.js:466:21)
              host.iobroker	2022-01-29 20:47:20.321	error	Caught by controller[5]: at Immediate.<anonymous> (/opt/iobroker/node_modules/@iobroker/db-objects-redis/lib/objects/objectsInRedisClient.js:2332:33)
              host.iobroker	2022-01-29 20:47:20.321	error	Caught by controller[5]: at ObjectsInRedisClient._getObject (/opt/iobroker/node_modules/@iobroker/db-objects-redis/lib/objects/objectsInRedisClient.js:2286:37)
              host.iobroker	2022-01-29 20:47:20.321	error	Caught by controller[5]: at Redis.get (/opt/iobroker/node_modules/ioredis/built/commander.js:122:25)
              host.iobroker	2022-01-29 20:47:20.321	error	Caught by controller[5]: at Redis.sendCommand (/opt/iobroker/node_modules/ioredis/built/redis/index.js:628:24)
              host.iobroker	2022-01-29 20:47:20.321	error	Caught by controller[5]: Error: Connection is closed.
              host.iobroker	2022-01-29 20:47:20.321	error	Caught by controller[4]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejecte
              host.iobroker	2022-01-29 20:47:20.321	error	Caught by controller[3]: at Array.calculationFunction (/opt/iobroker/node_modules/iobroker.iqontrol/main.js:974:11)
              host.iobroker	2022-01-29 20:47:20.321	error	Caught by controller[3]: ReferenceError: concat is not defined
              host.iobroker	2022-01-29 20:47:20.321	error	Caught by controller[3]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejecte
              host.iobroker	2022-01-29 20:47:20.321	error	Caught by controller[2]: at processImmediate (internal/timers.js:437:9)
              host.iobroker	2022-01-29 20:47:20.321	error	Caught by controller[2]: at runNextTicks (internal/process/task_queues.js:60:5)
              host.iobroker	2022-01-29 20:47:20.321	error	Caught by controller[2]: at Array.calculationFunction (/opt/iobroker/node_modules/iobroker.iqontrol/main.js:974:11)
              host.iobroker	2022-01-29 20:47:20.321	error	Caught by controller[2]: ReferenceError: concat is not defined
              host.iobroker	2022-01-29 20:47:20.321	error	Caught by controller[2]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejecte
              host.iobroker	2022-01-29 20:47:20.321	error	Caught by controller[1]: at Array.calculationFunction (/opt/iobroker/node_modules/iobroker.iqontrol/main.js:974:11)
              host.iobroker	2022-01-29 20:47:20.321	error	Caught by controller[1]: ReferenceError: concat is not defined
              host.iobroker	2022-01-29 20:47:20.321	error	Caught by controller[1]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejecte
              host.iobroker	2022-01-29 20:47:20.321	error	Caught by controller[0]: at Array.calculationFunction (/opt/iobroker/node_modules/iobroker.iqontrol/main.js:974:11)
              host.iobroker	2022-01-29 20:47:20.321	error	Caught by controller[0]: ReferenceError: concat is not defined
              host.iobroker	2022-01-29 20:47:20.320	error	Caught by controller[0]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejecte
              iqontrol.0	2022-01-29 20:47:20.259	error	(23469) Connection is closed.
              iqontrol.0	2022-01-29 20:47:20.259	error	at processImmediate (internal/timers.js:466:21)
              iqontrol.0	2022-01-29 20:47:20.259	error	at Immediate.<anonymous> (/opt/iobroker/node_modules/@iobroker/db-objects-redis/lib/objects/objectsInRedisClient.js:2332:33)
              iqontrol.0	2022-01-29 20:47:20.259	error	at ObjectsInRedisClient._getObject (/opt/iobroker/node_modules/@iobroker/db-objects-redis/lib/objects/objectsInRedisClient.js:2286:37)
              iqontrol.0	2022-01-29 20:47:20.259	error	at Redis.get (/opt/iobroker/node_modules/ioredis/built/commander.js:122:25)
              iqontrol.0	2022-01-29 20:47:20.259	error	at Redis.sendCommand (/opt/iobroker/node_modules/ioredis/built/redis/index.js:628:24)
              iqontrol.0	2022-01-29 20:47:20.259	error	(23469) Error: Connection is closed.
              iqontrol.0	2022-01-29 20:47:20.257	error	(23469) unhandled promise rejection: Connection is closed.
              iqontrol.0	2022-01-29 20:47:20.257	error	(23469) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
              iqontrol.0	2022-01-29 20:47:20.257	debug	(23469) redis get iqontrol.0.Lists.Batterienliste_Volt_1_5.Anzahl_1_2_LIST_JSON, error - Connection is closed.
              iqontrol.0	2022-01-29 20:47:20.257	error	(23469) ERROR updating object: Lists.Batterienliste_Volt_1_5.Anzahl_1_2_LIST: Error: DB closed
              iqontrol.0	2022-01-29 20:47:20.254	debug	(23469) updated object: Lists.Batterienliste_Volt_1_5.Anzahl_1_2
              iqontrol.0	2022-01-29 20:47:20.252	debug	(23469) ...processing counter Batterienliste_Volt_1_5_Anzahl_1_2...
              iqontrol.0	2022-01-29 20:47:20.252	debug	(23469) updated object: Lists.Batterienliste_Volt_1_5.Anzahl_1_1_NAMES_LIST
              iqontrol.0	2022-01-29 20:47:20.251	debug	(23469) updated object: Lists.Batterienliste_Volt_1_5.Anzahl_1_1_LIST_JSON
              iqontrol.0	2022-01-29 20:47:20.249	debug	(23469) updated object: Lists.Batterienliste_Volt_1_5.Anzahl_1_1_LIST
              iqontrol.0	2022-01-29 20:47:20.248	debug	(23469) updated object: Lists.Batterienliste_Volt_1_5.Anzahl_1_1
              iqontrol.0	2022-01-29 20:47:20.247	debug	(23469) ...processing counter Batterienliste_Volt_1_5_Anzahl_1_1...
              iqontrol.0	2022-01-29 20:47:20.246	debug	(23469) set state: Lists.Batterienliste_Volt_1_5.TOTAL_NAMES_LIST --> Bad Fenster links, Bad Fenster rechts, Fernbedienung Heiko, Fernbedienung Kerstin, Gästezimmer Fenster links, Gästezimmer Fenster
              iqontrol.0	2022-01-29 20:47:20.245	debug	(23469) updated object: Lists.Batterienliste_Volt_1_5.TOTAL_NAMES_LIST
              iqontrol.0	2022-01-29 20:47:20.243	debug	(23469) set state: Lists.Batterienliste_Volt_1_5.TOTAL_LIST_JSON --> ["alias.0.Batterien_Volt.Gaestezimmer_Fenster_rechts","alias.0.Batterien_Volt.Haustuerklingel","alias.0.Batterien_Volt.Keller_Saun
              iqontrol.0	2022-01-29 20:47:20.242	debug	(23469) updated object: Lists.Batterienliste_Volt_1_5.TOTAL_LIST_JSON
              iqontrol.0	2022-01-29 20:47:20.240	debug	(23469) set state: Lists.Batterienliste_Volt_1_5.TOTAL_LIST --> alias.0.Batterien_Volt.Gaestezimmer_Fenster_rechts, alias.0.Batterien_Volt.Haustuerklingel, alias.0.Batterien_Volt.Keller_Sauna_Fenster
              iqontrol.0	2022-01-29 20:47:20.239	debug	(23469) updated object: Lists.Batterienliste_Volt_1_5.TOTAL_LIST
              iqontrol.0	2022-01-29 20:47:20.238	debug	(23469) set state: Lists.Batterienliste_Volt_1_5.TOTAL --> 27
              iqontrol.0	2022-01-29 20:47:20.196	debug	(23469) updated object: Lists.Batterienliste_Volt_1_5.TOTAL
              iqontrol.0	2022-01-29 20:47:20.180	debug	(23469) set state: Lists.Fenster.Fenster_geschlossen_NAMES_LIST --> Bad Fenster links;Bad Fenster rechts;Gästezimmer Fenster links;Gästezimmer Fenster rechts;Keller Heizung;Keller Sauna links;Keller
              iqontrol.0	2022-01-29 20:47:20.137	debug	(23469) set state: Lists.Fenster.Fenster_geoeffnet_NAMES_LIST -->
              iqontrol.0	2022-01-29 20:47:20.135	debug	(23469) set state: Lists.Fenster.Fenster_gekippt_NAMES_LIST -->
              iqontrol.0	2022-01-29 20:47:20.135	debug	(23469) set state: Lists.Fenster.Fenster_geschlossen_LIST_WITH_VALUES --> alias.0.Fenster.Bad_Fenster_links: geschlossen;alias.0.Fenster.Bad_Fenster_rechts: geschlossen;alias.0.Fenster.Gaestezimmer_F
              iqontrol.0	2022-01-29 20:47:20.133	debug	(23469) set state: Lists.Fenster.Fenster_geoeffnet_LIST_WITH_VALUES -->
              iqontrol.0	2022-01-29 20:47:20.132	warn	(23469) State "iqontrol.0.Lists.Fenster.Fenster_geschlossen_LIST_WITH_VALUES" has no existing object, this might lead to an error in future versions
              iqontrol.0	2022-01-29 20:47:20.132	debug	(23469) set state: Lists.Fenster.Fenster_gekippt_LIST_WITH_VALUES -->
              iqontrol.0	2022-01-29 20:47:20.132	warn	(23469) State "iqontrol.0.Lists.Fenster.Fenster_geoeffnet_LIST_WITH_VALUES" has no existing object, this might lead to an error in future versions
              iqontrol.0	2022-01-29 20:47:20.131	debug	(23469) set state: Lists.Fenster.Fenster_geschlossen_LIST_JSON --> ["alias.0.Fenster.Bad_Fenster_links","alias.0.Fenster.Bad_Fenster_rechts","alias.0.Fenster.Gaestezimmer_Fenster_links","alias.0.Fens
              iqontrol.0	2022-01-29 20:47:20.131	debug	(23469) set state: Lists.Fenster.Fenster_geoeffnet_LIST_JSON --> []
              iqontrol.0	2022-01-29 20:47:20.130	warn	(23469) State "iqontrol.0.Lists.Fenster.Fenster_gekippt_LIST_WITH_VALUES" has no existing object, this might lead to an error in future versions
              iqontrol.0	2022-01-29 20:47:20.129	debug	(23469) set state: Lists.Fenster.Fenster_gekippt_LIST_JSON --> []
              iqontrol.0	2022-01-29 20:47:20.128	debug	(23469) set state: Lists.Fenster.Fenster_geschlossen_LIST --> alias.0.Fenster.Bad_Fenster_links;alias.0.Fenster.Bad_Fenster_rechts;alias.0.Fenster.Gaestezimmer_Fenster_links;alias.0.Fenster.Gaestezim
              iqontrol.0	2022-01-29 20:47:20.127	debug	(23469) set state: Lists.Fenster.Fenster_geoeffnet_LIST -->
              iqontrol.0	2022-01-29 20:47:20.126	debug	(23469) set state: Lists.Fenster.Fenster_gekippt_LIST -->
              iqontrol.0	2022-01-29 20:47:20.124	debug	(23469) set state: Lists.Fenster.Fenster_geschlossen --> 20
              iqontrol.0	2022-01-29 20:47:20.124	debug	(23469) set state: Lists.Fenster.Fenster_geoeffnet --> 0
              iqontrol.0	2022-01-29 20:47:20.123	debug	(23469) set state: Lists.Fenster.Fenster_gekippt --> 0
              iqontrol.0	2022-01-29 20:47:20.122	info	(23469) COUNTER Fenster Fenster_geschlossen: 20 of 20
              iqontrol.0	2022-01-29 20:47:20.121	info	(23469) COUNTER Fenster Fenster_geoeffnet: 0 of 20
              iqontrol.0	2022-01-29 20:47:20.121	info	(23469) COUNTER Fenster Fenster_gekippt: 0 of 20
              iqontrol.0	2022-01-29 20:47:20.110	debug	(23469) ...processing Selector 1...
              iqontrol.0	2022-01-29 20:47:20.110	debug	(23469) Creating List Batterienliste_Volt_1_5...
              iqontrol.0	2022-01-29 20:47:20.110	debug	(23469) ...triggering calculation function Batterien_LOWBAT Batterien_sortiert by creation...
              iqontrol.0	2022-01-29 20:47:20.110	debug	(23469) ...subscribing to items of calculation Batterien_LOWBAT Batterien_sortiert (2 objects)...
              iqontrol.0	2022-01-29 20:47:20.110	debug	(23469) updated object: Lists.Batterien_LOWBAT.Batterien_sortiert
              iqontrol.0	2022-01-29 20:47:20.106	debug	(23469) ...processing calculation Batterien_LOWBAT_Batterien_sortiert...
              iqontrol.0	2022-01-29 20:47:20.106	debug	(23469) ...triggering counter functions of list Batterien_LOWBAT by creation...
              iqontrol.0	2022-01-29 20:47:20.106	debug	(23469) ...no trigger interval for list Batterien_LOWBAT...
              iqontrol.0	2022-01-29 20:47:20.106	debug	(23469) ...subscribing to items of list Batterien_LOWBAT (70 objects)...
              iqontrol.0	2022-01-29 20:47:20.106	debug	(23469) updated object: Lists.Batterien_LOWBAT.Batterien_leer_NAMES_LIST
              iqontrol.0	2022-01-29 20:47:20.103	debug	(23469) updated object: Lists.Batterien_LOWBAT.Batterien_leer_LIST_JSON
              iqontrol.0	2022-01-29 20:47:20.100	debug	(23469) updated object: Lists.Batterien_LOWBAT.Batterien_leer_LIST
              iqontrol.0	2022-01-29 20:47:20.098	debug	(23469) updated object: Lists.Batterien_LOWBAT.Batterien_leer
              iqontrol.0	2022-01-29 20:47:20.094	debug	(23469) ...processing counter Batterien_LOWBAT_Batterien_leer...
              iqontrol.0	2022-01-29 20:47:20.094	debug	(23469) updated object: Lists.Batterien_LOWBAT.Batterien_voll_NAMES_LIST
              iqontrol.0	2022-01-29 20:47:20.093	debug	(23469) set state: Lists.Fenster.Fenster_geoeffnet_oder_gekippt --> 0
              iqontrol.0	2022-01-29 20:47:20.090	debug	(23469) updated object: Lists.Fenster.Fenster_geoeffnet_oder_gekippt
              iqontrol.0	2022-01-29 20:47:20.089	debug	(23469) updated object: Lists.Batterien_LOWBAT.Batterien_voll_LIST_JSON
              iqontrol.0	2022-01-29 20:47:20.085	info	(23469) CALCULATION Fenster Fenster_geoeffnet_oder_gekippt result: 0
              iqontrol.0	2022-01-29 20:47:20.083	debug	(23469) updated object: Lists.Batterien_LOWBAT.Batterien_voll_LIST
              iqontrol.0	2022-01-29 20:47:20.083	debug	(23469) CALCULATION Fenster Fenster_geoeffnet_oder_gekippt function started, TRIGGERED BY triggeredByCreation
              iqontrol.0	2022-01-29 20:47:20.080	error	(23469) concat is not defined
              iqontrol.0	2022-01-29 20:47:20.080	error	at Array.calculationFunction (/opt/iobroker/node_modules/iobroker.iqontrol/main.js:974:11)
              iqontrol.0	2022-01-29 20:47:20.080	error	(23469) ReferenceError: concat is not defined
              iqontrol.0	2022-01-29 20:47:20.080	error	(23469) unhandled promise rejection: concat is not defined
              iqontrol.0	2022-01-29 20:47:20.080	error	(23469) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
              iqontrol.0	2022-01-29 20:47:20.079	debug	(23469) CALCULATION Fenster Fenster_sortiert function started, TRIGGERED BY triggeredByCreation
              iqontrol.0	2022-01-29 20:47:20.075	debug	(23469) COUNTER Fenster Fenster_geschlossen function started, TRIGGERED BY triggeredByCreation
              iqontrol.0	2022-01-29 20:47:20.075	debug	(23469) COUNTER Fenster Fenster_geoeffnet function started, TRIGGERED BY triggeredByCreation
              iqontrol.0	2022-01-29 20:47:20.075	debug	(23469) COUNTER Fenster Fenster_gekippt function started, TRIGGERED BY triggeredByCreation
              iqontrol.0	2022-01-29 20:47:20.074	debug	(23469) updated object: Lists.Batterien_LOWBAT.Batterien_voll
              iqontrol.0	2022-01-29 20:47:20.072	debug	(23469) ...processing counter Batterien_LOWBAT_Batterien_voll...
              iqontrol.0	2022-01-29 20:47:20.072	debug	(23469) set state: Lists.Batterien_LOWBAT.TOTAL_NAMES_LIST --> Bad Fenster links, Bad Fenster rechts, Bewegungsmelder Flur Gäste WC, Bewegungsmelder Garage, Bewegungsmelder Garten, Bewegungsmelder Ga
              iqontrol.0	2022-01-29 20:47:20.070	debug	(23469) updated object: Lists.Batterien_LOWBAT.TOTAL_NAMES_LIST
              iqontrol.0	2022-01-29 20:47:20.068	debug	(23469) set state: Lists.Batterien_LOWBAT.TOTAL_LIST_JSON --> ["alias.0.Batterien_voll_leer.Bad_Fenster_links","alias.0.Batterien_voll_leer.Bad_Fenster_rechts","alias.0.Batterien_voll_leer.Bewegungsm
              iqontrol.0	2022-01-29 20:47:20.066	debug	(23469) updated object: Lists.Batterien_LOWBAT.TOTAL_LIST_JSON
              M s.bormannS 2 Antworten Letzte Antwort
                Log.txt
                EDIT:
                M
                M
                muuulle
                #6785
                @dslraser
                Richtig. So wie ich das bisher verstanden habe, läuft das frontend über den web Adapter! Adapter pausieren, stoppt nur das backend.
                • M muuulle
                  @dslraser
                  s.bormannS
                  s.bormannS
                  s.bormann
                  #6786
                  @muuulle sagte in Test Adapter iQontrol 1.11.x Vis:
                  @dslraser
                  Korrekt, der laufende Adapter ist nur für ein paar Sonderfunktionen wie das Popup und jetzt eben die Listen notwendig. Der Rest läuft über den web-adapter.
                    Log.txt
                    EDIT:
                    s.bormannS
                    s.bormannS
                    s.bormann
                    #6787
                    Log.txt
                    EDIT:
                    a) Fix ist online.
                    b) Man kann irgendwie auf die Vorgänger-Versionen zurück, leider weiß ich auswendig selbst gerade nicht, wie es geht. Man muss im beim Installations-Pfad den letzten commit von github referenzieren. Wenn ich es finde, sag ich noch mal bescheid.
                    L dslraserD 2 Antworten Letzte Antwort
                      Log.txt
                      EDIT:
                      a) Fix ist online.
                      L
                      L
                      Labersack
                      #6788
                      @s-bormann
                      Auch wenn ich mich nicht ständig zu Wort melde, so verfolge ich diesen Thread doch aufmerksam.
                      Wollte mal was loswerden:
                      Großes Lob an @s-bormann, du gehst auf sinnvolle Anfragen bereitwillig ein und bist echt sehr aktiv mit der Optimierung deines Adapters.
                        Log.txt
                        EDIT:
                        a) Fix ist online.
                        dslraserD
                        dslraserD
                        dslraser
                        #6789
                        a) Fix ist online.
                        Danke, läuft 👍 erstmal wieder. Ich werde weiter testen. Im Log werden einige Datenpunkte angemeckert.Das komische dabei, ich habe bisher nur für die Temperatur eine LIST_WITH_VALUESerstellt. Es werden also auch Datenpunkte angemeckert die ich noch gar nicht erstellt habe ?
                        iqontrol.0	2022-01-30 08:45:50.905	warn	(24608) State "iqontrol.0.Lists.Tueren.Tueren_geschlossen_LIST_WITH_VALUES" has no existing object, this might lead to an error in future versions
                        iqontrol.0	2022-01-30 08:45:50.905	warn	(24608) State "iqontrol.0.Lists.Tueren.Tueren_geoeffnet_LIST_WITH_VALUES" has no existing object, this might lead to an error in future versions
                        iqontrol.0	2022-01-30 08:45:50.905	warn	(24608) State "iqontrol.0.Lists.Tueren.Tueren_gekippt_LIST_WITH_VALUES" has no existing object, this might lead to an error in future versions
                        iqontrol.0	2022-01-30 08:43:53.848	warn	(24608) State "iqontrol.0.Lists.Batterienliste_Volt_3.Anzahl_kleiner_gleich_2_5_LIST_WITH_VALUES" has no existing object, this might lead to an error in future versions
                        iqontrol.0	2022-01-30 08:43:53.708	warn	(24608) State "iqontrol.0.Lists.Batterienliste_Volt_1_5.Anzahl_kleiner_1_1_LIST_WITH_VALUES" has no existing object, this might lead to an error in future versions
                        iqontrol.0	2022-01-30 08:43:53.708	warn	(24608) State "iqontrol.0.Lists.Batterienliste_Volt_1_5.Anzahl_1_2_LIST_WITH_VALUES" has no existing object, this might lead to an error in future versions
                        iqontrol.0	2022-01-30 08:43:53.707	warn	(24608) State "iqontrol.0.Lists.Batterienliste_Volt_1_5.Anzahl_1_1_LIST_WITH_VALUES" has no existing object, this might lead to an error in future versions
                        iqontrol.0	2022-01-30 08:43:53.611	warn	(24608) State "iqontrol.0.Lists.Batterien_LOWBAT.Batterien_leer_LIST_WITH_VALUES" has no existing object, this might lead to an error in future versions
                        iqontrol.0	2022-01-30 08:43:53.571	warn	(24608) State "iqontrol.0.Lists.Batterien_LOWBAT.Batterien_voll_LIST_WITH_VALUES" has no existing object, this might lead to an error in future versions
                        iqontrol.0	2022-01-30 08:43:53.444	warn	(24608) State "iqontrol.0.Lists.Bewegungsmelder.Bewegungsmelder_inaktiv_LIST_WITH_VALUES" has no existing object, this might lead to an error in future versions
                        iqontrol.0	2022-01-30 08:43:53.443	warn	(24608) State "iqontrol.0.Lists.Bewegungsmelder.Bewegungsmelder_aktiv_LIST_WITH_VALUES" has no existing object, this might lead to an error in future versions
                        iqontrol.0	2022-01-30 08:43:53.363	warn	(24608) State "iqontrol.0.Lists.Tueren.Tueren_geschlossen_LIST_WITH_VALUES" has no existing object, this might lead to an error in future versions
                        iqontrol.0	2022-01-30 08:43:53.362	warn	(24608) State "iqontrol.0.Lists.Tueren.Tueren_geoeffnet_LIST_WITH_VALUES" has no existing object, this might lead to an error in future versions
                        iqontrol.0	2022-01-30 08:43:53.362	warn	(24608) State "iqontrol.0.Lists.Tueren.Tueren_gekippt_LIST_WITH_VALUES" has no existing object, this might lead to an error in future versions
                        iqontrol.0	2022-01-30 08:43:53.235	warn	(24608) State "iqontrol.0.Lists.Fenster.Fenster_geschlossen_LIST_WITH_VALUES" has no existing object, this might lead to an error in future versions
                        iqontrol.0	2022-01-30 08:43:53.231	warn	(24608) State "iqontrol.0.Lists.Fenster.Fenster_geoeffnet_LIST_WITH_VALUES" has no existing object, this might lead to an error in future versions
                        iqontrol.0	2022-01-30 08:43:53.229	warn	(24608) State "iqontrol.0.Lists.Fenster.Fenster_gekippt_LIST_WITH_VALUES" has no existing object, this might lead to an error in future versions
                        iqontrol.0	2022-01-30 08:43:53.129	warn	(24608) State "iqontrol.0.Lists.Rollos.Rollos_teil_LIST_WITH_VALUES" has no existing object, this might lead to an error in future versions
                        iqontrol.0	2022-01-30 08:43:53.128	warn	(24608) State "iqontrol.0.Lists.Rollos.Rollos_zu_LIST_WITH_VALUES" has no existing object, this might lead to an error in future versions
                        iqontrol.0	2022-01-30 08:43:53.124	warn	(24608) State "iqontrol.0.Lists.Rollos.Rollos_auf_LIST_WITH_VALUES" has no existing object, this might lead to an error in future versions
                        iqontrol.0	2022-01-30 08:43:53.089	warn	(24608) State "iqontrol.0.Lists.Licht.Licht_aus_LIST_WITH_VALUES" has no existing object, this might lead to an error in future versions
                        iqontrol.0	2022-01-30 08:43:53.087	warn	(24608) State "iqontrol.0.Lists.Licht.Licht_an_LIST_WITH_VALUES" has no existing object, this might lead to an error in future versions
                        iqontrol.0	2022-01-30 08:43:53.032	warn	(24608) State "iqontrol.0.Lists.Steckdosen.Steckdosen_aus_LIST_WITH_VALUES" has no existing object, this might lead to an error in future versions
                        iqontrol.0	2022-01-30 08:43:53.030	warn	(24608) State "iqontrol.0.Lists.Steckdosen.Steckdosen_an_LIST_WITH_VALUES" has no existing object, this might lead to an error in future versions
                        EDIT: könntest Du beim nächsten Update eventuell glich noch "passende Namen" mit vergeben lassen ? Von mir aus könnte der Name auch genau so sein wie die ID. So sind die Datenpunkte in Blockly schwer auseinander zu halten, da dort in den Bausteinen immer nur der Name angezeigt wird.
                        EDIT2: Die TOTAL Liste kommt in der Sortierung wie im Selektor eingestellt. (Wert aufsteigend)
                        Die anderen Listen sind alphabetisch, oder ?
                        Diese ist nach Wert aaufsteigend wie eingestellt
                        Edit3: Hier mal ein Alexa Ansage Beispiel über die neue Liste
                        Temperaturenansage.m4a
                        • L Labersack
                          @s-bormann
                          s.bormannS
                          s.bormannS
                          s.bormann
                          #6790
                          @labersack sagte in Test Adapter iQontrol 1.11.x Vis:
                          @s-bormann
                          Vielen Dank für dieses nette Kompliment :)
                          • V
                            V
                            vepman
                            #6791
                            ich such mir gerade nen Wolf, um Gerätename und Status in der Liste auszublenden.
                            Kann mir jemand mal einenTipp geben, wo das ist?
                            Mir fehlen nämlich noch ein paar Millimeter, um die Liste ohne Scrollen darzustellen.
                              a) Fix ist online.
                              s.bormannS
                              s.bormannS
                              s.bormann
                              #6792
                              a) Fix ist online.
                              • Der Fehler im Log ist korrigiert
                              • Das mit den Namen mache ich heute Abend
                              • Das mit der Sortierung schaue ich heute Abend auch noch mal an, muss jetzt erst mal weg. Ich glaube aber, dass ich die NAMES und PARENTNAMES-Listen immer nur alphabetisch sortieren lasse (am Anfang gabs ja nur sortieren nach ID, NAME oder PARENTNAME - und das machte ja auch nur in den Listen mit IDs sinn. Aber das neue "nach Wert sortieren" ist vermutlich auch in den NAME und PARENTNAME-Listen sinnvoll - müsste ich also noch ergänzen)
                              • Die Alexa-Ansage ist mega, das bau ich mir heute Abend auch nach :)
                              LG und bis später!
                                a) Fix ist online.
                                LG und bis später!
                                dslraserD
                                dslraserD
                                dslraser
                                #6793
                                Kannst ja mal testen. Ich beschreibe später noch die Erstellung der nötigen Routine für die Ansage.
                                iQontrol_Listen_Ueberschrift_Telegram_EMAIL_ALEXA_Temperaturen.zip
                                • V vepman
                                  dslraserD
                                  dslraserD
                                  dslraser
                                  #6794
                                  @vepman sagte in Test Adapter iQontrol 1.11.x Vis:
                                  Ich weiß nicht was Du meinst ?
                                  V 1 Antwort Letzte Antwort
                                    V
                                    V
                                    vepman
                                    #6795
                                    @dslraser
                                    Hier:
                                    dslraserD s.bormannS 2 Antworten Letzte Antwort
                                    • V vepman
                                      @dslraser
                                      Hier:
                                      dslraserD
                                      dslraserD
                                      dslraser
                                      #6796
                                      @vepman
                                      das ist die Überschrift, oder ? Ich habe da eine Verlinkung drinn
                                        @vepman
                                        V
                                        V
                                        vepman
                                        #6797
                                        @dslraser
                                        Nee. die habe ich auch:
                                        • V vepman
                                          @dslraser
                                          dslraserD
                                          dslraserD
                                          dslraser
                                          #6798
                                          @dslraser
                                          Ah, Du bist aber hier....
                                          Da weiß ich es nicht.
                                          84.0k
