    6.5k
7.6k Beiträge 296 Kommentatoren 7.8m Aufrufe 201 Beobachtet
  • s.bormannS s.bormann
    @docgame sagte in Test Adapter iQontrol 1.11.x Vis:
    @s-bormann Nach diesem letzten Update wird der Adapter nicht mehr grün...
    host.iobroker	2022-01-09 19:13:43.713	warn	Do not restart adapter system.adapter.iqontrol.0 because restart loop detected
    host.iobroker	2022-01-09 19:13:43.713	info	Restart adapter system.adapter.iqontrol.0 because enabled
    host.iobroker	2022-01-09 19:13:43.713	error	instance system.adapter.iqontrol.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
    host.iobroker	2022-01-09 19:13:43.713	error	Caught by controller[0]: at Iqontrol.onReady (/opt/iobroker/node_modules/iobroker.iqontrol/main.js:1014:15)
    host.iobroker	2022-01-09 19:13:43.713	error	Caught by controller[0]: at Iqontrol.createLists (/opt/iobroker/node_modules/iobroker.iqontrol/main.js:413:16)
    host.iobroker	2022-01-09 19:13:43.712	error	Caught by controller[0]: TypeError: sorting.indexOf is not a function
    host.iobroker	2022-01-09 19:13:43.712	error	Caught by controller[0]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejecte
    iqontrol.0	2022-01-09 19:13:43.134	warn	(32360) Terminated (UNCAUGHT_EXCEPTION): Without reason
    iqontrol.0	2022-01-09 19:13:43.134	info	(32360) terminating
    iqontrol.0	2022-01-09 19:13:43.134	info	(32360) cleaned everything up...
    iqontrol.0	2022-01-09 19:13:43.133	info	(32360) Stop trigger intervals
    iqontrol.0	2022-01-09 19:13:43.131	error	(32360) sorting.indexOf is not a function
    iqontrol.0	2022-01-09 19:13:43.130	error	at Iqontrol.onReady (/opt/iobroker/node_modules/iobroker.iqontrol/main.js:1014:15)
    iqontrol.0	2022-01-09 19:13:43.130	error	at Iqontrol.createLists (/opt/iobroker/node_modules/iobroker.iqontrol/main.js:413:16)
    iqontrol.0	2022-01-09 19:13:43.130	error	(32360) TypeError: sorting.indexOf is not a function
    iqontrol.0	2022-01-09 19:13:43.129	error	(32360) unhandled promise rejection: sorting.indexOf is not a function
    iqontrol.0	2022-01-09 19:13:43.129	error	(32360) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    iqontrol.0	2022-01-09 19:13:42.052	info	(32360) Creating List States...
    iqontrol.0	2022-01-09 19:13:42.052	info	(32360) Creating Widget States...
    iqontrol.0	2022-01-09 19:13:42.029	info	(32360) Creating Popup States...
    iqontrol.0	2022-01-09 19:13:41.982	info	(32360) starting. Version 1.11.0 in /opt/iobroker/node_modules/iobroker.iqontrol, node: v14.17.0, js-controller: 3.3.22
    Danke, probier es jetzt bitte noch mal.
    DocGame
    #6391
    @s-bormann vielen Dank. Jetzt ist er wieder grün. Zum Testen werde ich heute leider nicht mehr kommen. Das Thema mit den Listen interessiert mich brennend, da ich das bisher auch immer über die Blocklys gemacht habe. Bis jetzt kann ich euch aber nicht folgen wie das Vorgehen genau ist.
    • wendy2702W wendy2702
      Haben die neuen Versionen neue Nummern oder sind wir noch bei 1.11.0 ?
      s.bormannS Offline
      s.bormannS Offline
      s.bormann
      schrieb am zuletzt editiert von s.bormann
      #6392
      @wendy2702 sagte in Test Adapter iQontrol 1.11.x Vis:
      1.11.0 ist die aktuelle Beta. Die läuft auch meines Wissens nach gut.
      Auf Github befindet sich die Alpha-Version. Diese hat keine eigene (neue) Versionsnummer. Hier wird gerade quasi "am offenen Herzen" gearbeitet. Deshalb gibt es hier auch so viele Bugs und alle paar Stunden ein Update.
      Die Listen-Funktion ist halt a) komplett neu , b) sehr umfangreich und nutzt c) erstmalig auch sehr viele Server-Funktionen. Und da jeder Server und jede Konfig anders ist, bin ich über jeden, der mir Fehler meldet dankbar - man muss sich aber im Klaren sein, dass die Funktion derzeit noch instabil ist und man ggf. zurück auf die Beta oder die Stable wechseln muss - was ja zum Glück kein Problem ist.
      Edit: Nur noch mal zur Erklärung (weils gerade anderweitig auch Thema war): Github-Versionen sollten nur in Rücksprache mit dem Entwickler installiert werden. Hier sind wir im Gespräch darüber und im Austausch - deshalb ist es kein Problem. Aber ich würde unbedingt davon abraten, sonstige Adapter ohne Rücksprache von Github zu installieren - da weiß man schlicht nicht, was man sich installiert.
        martinschm
        #6393
        @s-bormann kurze Frage zum Export von Geräte Optionen. Sollte das auch addional controls etc übernehmen?
        Hab das gerade mal probiert und da kam irgendwie nicht so richtig was beim Import an.
        M s.bormannS 2 Antworten Letzte Antwort
        • M martinschm
          martinschm
          #6394
          kann mir das einer mal mit den Valve_States erklären?
          Hab es so verstanden, das es die Öffnung des Ventils bedeutet, da steht dann ein Prozentwert drin. Aber wie zeigt ihr das bei euch an, also außer als Prozentwert?
          ciao
          Martin
            @dslraser Überschrift und Boder-Styling sind online
            dslraserD Offline
            dslraserD Offline
            dslraser
            #6395
            @s-bormann sagte in Test Adapter iQontrol 1.11.x Vis:
            morgen kann ich wieder etwas weiter testen.
            • M martinschm
              s.bormannS Offline
              s.bormannS Offline
              s.bormann
              #6396
              @martinschm sagte in Test Adapter iQontrol 1.11.x Vis:
              Hi, nein, betrifft nur die Optionen, nicht den Rest des Gerätes.
              • M martinschm
                ciao
                Martin
                s.bormannS Offline
                s.bormannS Offline
                s.bormann
                #6397
                ciao
                Martin
                Genau, es ist so gedacht, dass es die Ventilöffnung in Prozent darstellt. Im Prinzip ist es aber ähnlich, wie die ADDITIONAL_INFOs, es sollte jeden beliebigen Datenpunkt anzeigen können.
                • wendy2702W Online
                  wendy2702W Online
                  #6398
                  Puh 320 Seiten.... was würdet Ihr von einem extra Unterforum für den Adapter halten?
                  Unabhängig davon hier meine ersten Fragen:
                  Was bedeutet das rot markierte:
                  Wenn ich das Drop Down öffne sehe ich da nichts mit "OC" kann aber auch die Spalte nicht größer machen oder wüsste nicht wo.
                  Zweite Frage: wo kann ich denn hier die Texte die vom Birthday Kalender kommen übersetzen?
                  In VIS geht das ja im Widget aber hier konnte ich es bisher nicht finden.
                    dslraserD Offline
                    dslraserD Offline
                    dslraser
                    #6399
                    Erstmal danke für Deinen Einsatz.
                    Die Überschrift wäre vielleicht „mittig“ besser platziert.
                    Edit:
                    kann ich für Badge gekippt und geöffnet irgendwie addieren, oder brauche ich ein kleines Blockly dafür ?
                    Ich habe versucht die Überschrift auf den Datenpunkt zu verlinken, aber da wird nur der Text dargestellt, geht das an dieser Stelle irgendwie ?
                    Überschrift
                    |Fenster geöffnet: {iqontrol.0.Lists.Fensterliste.Fenster_geöffnet}
                      @dslraser sagte in Test Adapter iQontrol 1.11.x Vis:
                      @s-bormann
                      Diese Geschichte funktioniert bei mir noch nicht.
                      Auch nicht wenn ich hier Name versuche
                      Hier habe ich HUE und HMIP gemischt drinn. (.on und .STATE)
                      Da steht dann manchmal .STATE dabei. Wenn ich einmal schalte, dann ist die Endung weg.
                      EDIT: ach das ist dann eine andere Liste.......(wird aber irgendwie nichts angezeigt) Muß ich dann was ändern ? parentName;plainText oder ändern in Name;plainText(bringt aber beides nichts)
                      da muss ich glaube ich noch mal danach schauen.
                      Ich habs doch richtig im Kopf:
                      Bei Dir sind die Aliase alle in einem Unterordnet, haben also kein "Parent", nach dem sie benannt werden, oder? D.h. im Widget müsstest Du statt parentName den name benutzen, dann soll der Name des Datenpunktes an sich angezeigt werden.
                      Hast Du Deine Aliase einschließlich des ".STATE" benannt? Dann würde das ja schon mal passen.
                      das sind die Originale, nicht die alias Aufzählung. Meine aliase haben keinen .STATE
                      Aber warum ändert sich das nach dem Schalten?? 😢
                      Edit: Benutz doch zum Testen im Widget mal beides, parentName und name, vielleicht ergibt sich daraus was?
                      Hier mal ein alias einer Steckdose (die haben nix mit .STATE)
                        "type": "state",
                        "common": {
                          "def": false,
                          "type": "boolean",
                          "read": true,
                          "write": true,
                          "role": "switch",
                          "name": "Kaminlampe",
                          "alias": {
                            "id": "hm-rpc.0.00021709A0EFE6.3.STATE"
                          "desc": "per Script erstellt",
                          "states": {
                            "false": "aus",
                            "true": "an"
                          "smartName": false
                        "native": {},
                        "from": "system.adapter.javascript.0",
                        "user": "system.user.admin",
                        "ts": 1607782398533,
                        "_id": "alias.0.Steckdosen.Kaminlampe",
                        "acl": {
                          "object": 1636,
                          "state": 1636,
                          "owner": "system.user.admin",
                      Hier mal das Original
                        "type": "state",
                        "common": {
                          "def": false,
                          "type": "boolean",
                          "read": true,
                          "write": true,
                          "role": "switch",
                          "name": "Kaminlampe.STATE",
                          "smartName": {
                            "de": "Kaminlampe,Kaminlicht",
                            "smartType": "LIGHT"
                        "native": {
                          "MIN": false,
                          "OPERATIONS": 7,
                          "MAX": true,
                          "FLAGS": 1,
                          "ID": "STATE",
                          "TYPE": "BOOL",
                          "DEFAULT": false,
                          "CONTROL": "SWITCH.STATE"
                        "from": "system.adapter.hm-rega.0",
                        "ts": 1639220879118,
                        "_id": "hm-rpc.0.00021709A0EFE6.3.STATE",
                        "acl": {
                          "object": 1636,
                          "state": 1636,
                      hier die Liste die iQontrol erstellt (in dem DP iqontrol.0.Lists.Steckdosenalias.TOTAL_NAMES_LIST_JSON)
                      ["Entfeuchter","Gäste WC Licht","Geschirrspüler","Kaminlampe","Kugellampe","Schreibtischlampen","Waschmaschine","Weihnachtsbaum gross","Weihnachtsbaum klein"]
                      So erstellt
                      angezeigt wird nichts, egal ob mit parentName oder mit name
                      Die Aufzählung ohne alias, also extra eine neue Aufzählung erstell, funktioniert.
                      Links und Mitte kein alias, rechts eine alias Aufzählung
                      EDIT: wenn ich die alias-Liste so erstelle (ohne den Haken)
                      und dann hier diese Liste nehme
                      und hier name einstelle
                      dann geht es wie gewünscht....(wäre sonst vielleicht auch doppelt gemoppelt, oder ?)
                      Alias Liste mit name ohne den Haken für erstelle eine Liste mit den Namen der Datenpunkte
                      EDIT 2:
                      links "normale" Aufzählung, rechts Aufzählung meiner alias
                      beide Listen sind nach an/aus sortiert.
                      Interessant ist, das bei der alias Liste schon alphabetisch sortiert ist !
                      ja, genau so ist es richtig, für das Widget muss man immer das JSON mit den Datenpunkten (und nicht mit den Namen) verwenden. Das Widget selbst setzt das ganze dann auf Namen bzw. parentNames um.
                      Deshalb habe ich das Generieren der NAMES und PARENTNAMES-Listen im JSON-Format wieder rausgeschmissen, da das ganze unnötig und verwirrend ist.
                      Außerdem habe ich die Auwahl der Listen im Widget verbessert.
                      Habe jetzt auch noch mal über das Sortieren nachgedacht: Am besten lässt man das auch das Widget erledigen. Werde das dort noch einbauen, melde mich gleich wieder.
                      dslraserD Offline
                      dslraserD Offline
                      dslraser
                      #6400
                      Die Namen Listen finde ich schon sinnvoll. Mann kann die sehr gut "missbrauchen/gebrauchen", z.B. wenn man sich geöffnete oder auch gekippte Fenster über den Alexa2 Adapter ansagen lassen möchte.
                      Dazu nur ein Hinweis. Alexa hat ein Textlimit (wieviel weiß ich gerade nicht aus dem Kopf), das kann man aber "umgehen", wenn mit Semikolon getrennt wird (nicht mit Komma). Nach jedem Semikolon beginnt das Textlimit neu. Die Ansage ist dann nur etwas langsamer.
                      Also in so einer Liste mit Komma wird in speak (alexa2 Adapter) nichts angesagt, zu lang (oder extra mit Blockly erledigen ?)
                      Bad Fenster links, Bad Fenster rechts, Gästezimmer Fenster links, Gästezimmer Fenster rechts, Keller Heizung, Keller Sauna links, Keller Sauna rechts, Keller Vorrat, Keller W Baum, Keller Werkstatt, Keller Wohnzimmer links, Keller Wohnzimmer mitte, Keller Wohnzimmer rechts, Küche Fenster links, Küche Fenster mitte, Küche Fenster rechts, Schlafzimmer Fenster links, Schlafzimmer Fenster rechts, Wohnzimmer Fenster links, Wohnzimmer Fenster rechts
                      Diese Liste wird in speak (Alexa2 Adapter) angesagt
                      Bad Fenster links; Bad Fenster rechts; Gästezimmer Fenster links; Gästezimmer Fenster rechts; Keller Heizung; Keller Sauna links; Keller Sauna rechts; Keller Vorrat; Keller W Baum; Keller Werkstatt; Keller Wohnzimmer links; Keller Wohnzimmer mitte; Keller Wohnzimmer rechts; Küche Fenster links; Küche Fenster mitte; Küche Fenster rechts; Schlafzimmer Fenster links; Schlafzimmer Fenster rechts; Wohnzimmer Fenster links; Wohnzimmer Fenster rechts
                        s.bormannS Offline
                        s.bormannS Offline
                        s.bormann
                        #6401
                        ich fände das sehr gut! Meiner Meinung nach wären möglichst viel Unterforen das beste, was die Übersichtlichkeit angeht. Aber da gibt es bestimmt auch andere Meinungen zu. @Jey-Cee , wie siehts Du das? Ist so was sinnvoll / möglich?
                        Bei lauter einzelnen Threads, die wild im Forum verteilt sind, weiß ich persönlich sonst gar nicht, wie ich die Übersicht behalten soll, wo ich welche Frage noch nicht beantwortet habe. Oder wie lösen das Andere?
                        Hier dieser ewig lange Thread ist natürlich überhaupt null geeignet irgenwas nachzuschlagen. Für mich ist das eher wie ein Chat.
                        Eigentlich sollte das so aussehen:
                        In Chrome funktioniert das auch. Welchen Browser nutzt Du?
                        Man kann damit die einzelnen Sektionen in "Collapsibles" verwandeln, also zuklappbare Sektionen.
                        Im JSON-Table-Widget gibt es Übersetzungen hier:
                        Hier kann man Wort-Paare eintragen, also z.B. Birthday,Geburtstag;age,Alter;birthYear,Geburtsjahr etc.
                        Viel Erfolg und Spaß!
                        da_WoodyD wendy2702W 2 Antworten Letzte Antwort
                        • wendy2702W Online
                          wendy2702W Online
                          #6402
                          Wenn ich das aufklappe kann ich das auch sehen was du zeigst. Bin nur über das "OC" verwundert gewesen.
                          Das mit dem Widget werde ich testen.
                          Danke.... wird noch ein langer harter weg für mich mit dem einrichten in iQontrol. Ich zähle auf euch ;-)
                          • dslraserD dslraser
                            Edit:
                            Überschrift
                            s.bormannS Offline
                            s.bormannS Offline
                            s.bormann
                            #6403
                            Versuch es mal so:
                            <center>Überschrift</center>
                            Sieht ja schon mal mega cool aus! Geht auf jeden Fall in eine gute Richtung!
                            Kannst Du mir mal die Farbwerte schicken, die Du vergeben hast? Dann könnte ich die als Standard in das Widget hinterlegen.
                            Edit:
                            Zwei Wege:
                            Einen neuen Counter anlegen, der sowohl offen, als auch gekippt zählt (also die Conditions mit ODER verknüpft):
                            6fa13b5c-b0ee-48c7-92c0-33daa68e9317-image.png (Die Werte von gekippt und geöffnet müssten halt noch angepasst werden)
                            Oder zweiter Weg:
                            Eine neue Calculation anlegen, die die beiden Werte addiert:
                            Überschrift
                            Das ist (noch) nicht implementiert. Muss ich mal überlegen, ob das geht. Aber eigentlich denke ich, sollte sich die Funktion in das Widget einbauen lassen. Ich denk später mal drüber nach.
                              s.bormannS Offline
                              s.bormannS Offline
                              s.bormann
                              #6404
                              Könnte das Trennzeichen einfach wählbar machen. Kommt auf die ToDo-Liste. Du hast immer gute Ideen!
                                Versuch es mal so:
                                Edit:
                                Zwei Wege:
                                Oder zweiter Weg:
                                Überschrift
                                dslraserD Offline
                                dslraserD Offline
                                dslraser
                                #6405
                                Versuch es mal so:
                                Edit:
                                Zwei Wege:
                                Oder zweiter Weg:
                                Überschrift
                                Die Farbwerte sind
                                #424242
                                und
                                white
                                Hier mal mein Zwischenstand.
                                iQontrol.pdf
                                Edit: Das funktioniert 👍
                                  wendy2702W Online
                                  wendy2702W Online
                                  #6406
                                  Sorry für die lästigen Anfänger fragen :-(
                                  Wie komme ich denn an diese Einstellungen wenn das Widget bereits erstellt ist?
                                  Wenn ich ein neues erstelle sehe ich das aber bei meinem bereits existierenden finde ich es nicht.
                                  dslraserD da_WoodyD 2 Antworten Letzte Antwort
                                    dslraserD Offline
                                    dslraserD Offline
                                    dslraser
                                    #6407
                                    @wendy2702
                                    auf den Bleistift klicken
                                      da_WoodyD Offline
                                      da_WoodyD Offline
                                      #6408
                                      passt schon! kein problem...
                                      der bleistift hilft, dauert bei mir aber auch manchmal etwas bis sich da alles aufbaut.
                                      wenn ich am abend schnell, viel in iQ mache wirds oft sehr zäh...
                                        @wendy2702
                                        wendy2702W Online
                                        wendy2702W Online
                                        #6409
                                        @dslraser OK.
                                        Muss man wissen und den richtigen Bleistift natürlich wählen.
                                        Danke!
                                        • NegaleinN Offline
                                          NegaleinN Offline
                                          Negalein
                                          #6410
                                          @da_Woody @s-bormann
                                          so, Verschieberei erledigt.
                                          Jetzt bitte hier weiter mit iQontrol :)
                                          ° Fixer ---> iob fix
