  4. ioBroker Docker (Synology) startet nicht (Stromausfall)
    5.9k
102 Beiträge 6 Kommentatoren 13.7k Aufrufe 2 Beobachtet
  • T thorkillar
    @haselchen ![0_1637918943559_94724e0f-251a-4c2f-8191-3e86764a0021-image.png](Lade 100% hoch)
    buanet-iobroker-live
    date,stream,content
    2021-11-26 09:19:09,stdout,
    2021-11-26 09:19:09,stdout,Starting ioBroker...
    2021-11-26 09:19:09,stdout,------------------------------------------------------------
    2021-11-26 09:19:09,stdout,-----          Step 5 of 5: ioBroker startup           -----
    2021-11-26 09:19:04,stdout,/opt/scripts/iobroker_startup.sh: Zeile 192: [: 8081: Einstelliger (unärer) Operator erwartet.
    2021-11-26 09:19:02,stdout,The object system.adapter.admin.0 was not found!
    2021-11-26 09:18:59,stdout,
    2021-11-26 09:18:59,stdout,For more information take a look at readme.md on Github!
    2021-11-26 09:18:59,stdout,Some adapters have special requirements/ settings which can be activated by the use of environment variables.
    2021-11-26 09:18:59,stdout,------------------------------------------------------------
    2021-11-26 09:18:59,stdout,-----      Step 4 of 5: Applying special settings      -----
    2021-11-26 09:18:59,stdout,/opt/scripts/iobroker_startup.sh: Zeile 169: [: !=: Einstelliger (unärer) Operator erwartet.
    2021-11-26 09:18:57,stdout,The object system.adapter.admin.0 was not found!
    2021-11-26 09:18:44,stdout,
    2021-11-26 09:18:44,stdout,Done.
    2021-11-26 09:18:44,stdout,Fixing "sudo-bug" by replacing sudo in iobroker with gosu...
    2021-11-26 09:18:35,stdout,(Re)Setting folder permissions (This might take a while! Please be patient!)...
    2021-11-26 09:18:35,stdout,------------------------------------------------------------
    2021-11-26 09:18:35,stdout,-----   Step 3 of 5: Checking ioBroker installation    -----
    2021-11-26 09:18:35,stdout,Existing installation of ioBroker detected in /opt/iobroker.
    2021-11-26 09:18:30,stdout,
    2021-11-26 09:18:30,stdout,------------------------------------------------------------
    2021-11-26 09:18:30,stdout,-----   Step 2 of 5: Detecting ioBroker installation   -----
    2021-11-26 09:18:30,stdout,There are no changes in UID/ GID needed.
    2021-11-26 09:18:30,stdout,Done.
    2021-11-26 09:18:19,stdout,The following packages will be installed: vi...
    2021-11-26 09:18:19,stdout,Installing additional packages is set by ENV.
    2021-11-26 09:18:19,stdout,------------------------------------------------------------
    2021-11-26 09:18:19,stdout,-----         Step 1 of 5: Preparing container         -----
    2021-11-26 09:18:19,stdout,-----               ZWAVE:     false                   -----
    2021-11-26 09:18:19,stdout,-----               USBDEVICES: none                    -----
    2021-11-26 09:18:19,stdout,-----               SETUID:    1000                    -----
    2021-11-26 09:18:19,stdout,-----               SETGID:    1000                    -----
    2021-11-26 09:18:19,stdout,-----               REDIS:     false                   -----
    2021-11-26 09:18:19,stdout,-----               PACKAGES:  vi                      -----
    2021-11-26 09:18:19,stdout,-----               AVAHI:     false                   -----
    2021-11-26 09:18:19,stdout,-----               ADMINPORT: 8081                    -----
    2021-11-26 09:18:19,stdout,-----                       ENV                        -----
    2021-11-26 09:18:19,stdout,-----                                                  -----
    2021-11-26 09:18:19,stdout,-----               npm:       6.14.4                  -----
    2021-11-26 09:18:15,stdout,-----               node:      v12.18.0                -----
    2021-11-26 09:18:15,stdout,-----               image:     v4.1.0                  -----
    2021-11-26 09:18:15,stdout,-----                     Versions                     -----
    2021-11-26 09:18:15,stdout,-----                                                  -----
    2021-11-26 09:18:15,stdout,-----               arch:      x86_64                  -----
    2021-11-26 09:18:15,stdout,-----                      System                      -----
    2021-11-26 09:18:15,stdout,-----              Debugging information               -----
    2021-11-26 09:18:15,stdout,------------------------------------------------------------
    2021-11-26 09:18:15,stdout,-----                Please be patient!                -----
    2021-11-26 09:18:15,stdout,-----          Startupscript is now running.           -----
    2021-11-26 09:18:15,stdout,-----       Welcome to your ioBroker-container!        -----
    2021-11-26 09:18:15,stdout,---------------     2021-11-26 10:18:14      ---------------
    GlasfaserG Offline
    GlasfaserG Offline
    @thorkillar sagte in ioBroker Docker (Synology) startet nicht (Stromausfall):
    image: v4.1.0
    der ist alt ... und bekommt einen Bart :)
    @haselchen danke, hat geholfen.
    Setze einen neuen Container auf ( ioBroker Docker Version aktualisieren ) , Backup rein ... fertig
    • GlasfaserG Glasfaser
      image: v4.1.0
      thorkillar
      schrieb am zuletzt editiert von thorkillar
      @glasfaser sagte in ioBroker Docker (Synology) startet nicht (Stromausfall):
      Guten Abend, ich habe heute den Container regulär über den Docker gestoppt. Jedoch bekomme ich ihn nicht mehr gestartet. Kann mir jemand helfen, wie ich das jetzt am besten hin bekomme?
      • T thorkillar
        GlasfaserG Offline
        GlasfaserG Offline
        Hast du eine Meldung in der Syn dazu ?
        EDIT :
        OK dein Screenshot hast du beigefügt
        • T thorkillar
          GlasfaserG Offline
          GlasfaserG Offline
          @thorkillar
          ober im Reiter Protokoll , was steht dort ?
            @thorkillar
            thorkillar
            leider gar nichts.
            • T thorkillar
              leider gar nichts.
              GlasfaserG Offline
              GlasfaserG Offline
              @thorkillar
              Was hast du verändert , nachdem du Ihn gestoppt hast !?
                @thorkillar
                thorkillar
                @glasfaser ich hatte ihn gestoppt und neu gestartet, weil ich ein Problem mit VIS, (auf einem iOS Gerät wurde die Seite nicht mehr angezeigt) und mit der Verknüpfung zu Alexa<>Homematic hatte und dachte, einmal durchstarten kann nicht schaden. Verändert hatte ich nichts.
                Außerdem bekam ich auf der http://192.168.0.132:8081/#tab-hosts seite, laufend die Meldung, dass eine sehr langsame Verbindung entdeckt wurde...
                • T thorkillar
                  GlasfaserG Offline
                  GlasfaserG Offline
                  @thorkillar
                  Lösche das Log und starte ihn , was steht dann dort :
                  und was steht dort :
                    @thorkillar
                    thorkillar
                    Log:
                    Stufe Uhrzeit Benutzer Ereignis
                    Error 2021/11/28 18:04:49 thorkillar Start container buanet-iobroker-live failed: {"message":"failed to initialize logging driver: database is locked"}.
                    Netzwerk gibt es bei mir nicht.
                    • T thorkillar
                      Log:
                      GlasfaserG Offline
                      GlasfaserG Offline
                      Sollte eigentlich .
                      Entweder host oder bridge .
                      Bei dir eher host , da du keine Port-Einstellung hinterlegt hast
                        Sollte eigentlich .
                        thorkillar
                        @glasfaser ja, host hatte ich ausgewählt.
                        • T thorkillar
                          GlasfaserG Offline
                          GlasfaserG Offline
                          @thorkillar
                          dann muß es so sein und nicht leer :
                            @thorkillar
                            thorkillar
                            @glasfaser mmmm. wenn man an der richtigen Stelle sucht, findet man es auch
                            • T thorkillar
                              Log:
                              GlasfaserG Offline
                              GlasfaserG Offline
                              stimmt dein Mount noch , mal nachgesehen
                                thorkillar
                                ja, der Tippfehler ist seit der ersten Stunde dabei :-)
                                GlasfaserG T 2 Antworten Letzte Antwort
                                • T thorkillar
                                  GlasfaserG Offline
                                  GlasfaserG Offline
                                  @thorkillar
                                  Starte die SYN mal neu .
                                  • T thorkillar
                                    thorkillar
                                    sehe
                                    okay, die hat mir auch gerade folgende Meldung ausgespuckt.
                                    • T thorkillar
                                      sehe
                                      GlasfaserG Offline
                                      GlasfaserG Offline
                                      @thorkillar
                                      Deshalb ein Neustart der SYN .
                                      Und .. ich empfehle dir ganz dringendst , kauf dir eine USV !!!
                                        @thorkillar
                                        thorkillar
                                        @glasfaser : Neustart: dauert noch
                                        USV: Kannst du eine Empfehlen?
                                        Für den ioBroker: Weiter auf der Synology oder ein Umzug auf einen RAS in Betracht ziehen?
                                        • T thorkillar
                                          GlasfaserG Offline
                                          GlasfaserG Offline
                                          Empfehlung kann ich so nicht aussprechen , liegt an der Nutzung der USV , die habe ich : ( Syn , Fritzbox , Unitymedia , POE Switch usw. angeschlossen )
                                          https://www.apc.com/shop/de/de/products/Stromsparende-Back-UPS-Pro-1200-230-V-Schuko/P-BR1200G-GR
                                          Das mußt du wissen , habe iobroker im Docker , den Rest in Syn VMM . ( Influx , Grafana .Raspberrymatic ... usw )
