  4. Test Adapter homeconnect (BSH Home-Connect) v0.0.x
    6.4k
bshbsh home connecthome connecthomeconnect adapter
1.4k Beiträge 202 Kommentatoren 689.0k Aufrufe 153 Beobachtet
  • T tombox
    @arteck Also der notify event kann nicht im direkten zusammenhang stehen. Es muss vorher passieren. Ist der adapter schon im debug?
    arteckA Offline
    arteckA Offline
    arteck
    #654
    @tombox jo ist der.... seid 1 woche
    ich liebe SEQ
    04 Nov 2021 09:38:55.607
     homeconnect.0 (22023) SIEMENS-TI909701HC-68A40E188708: The rate limit "10 successive error calls in 10 minutes" was reached. Requests are blocked during the remaining period of 574 seconds.
     homeconnect.0 (22023) SIEMENS-TI909701HC-68A40E188708: The rate limit "10 successive error calls in 10 minutes" was reached. Requests are blocked during the remaining period of 575 seconds.
    04 Nov 2021 09:38:55.114
     master homeconnect.0: SIEMENS-TI909701HC-68A40E188708: The rate limit "10 successive error calls in 10 minutes" was reached. Requests are blocked during the remaining period of 574 seconds.
    04 Nov 2021 09:38:53.603
     master homeconnect.0: SIEMENS-TI909701HC-68A40E188708: The rate limit "10 successive error calls in 10 minutes" was reached. Requests are blocked during the remaining period of 575 seconds.
    04 Nov 2021 09:38:52.721
     master homeconnect.0: SIEMENS-TI909701HC-68A40E188708.programs.active.options.BSH_Common_Option_ProgramProgress:10
    04 Nov 2021 09:38:52.720
     master homeconnect.0: event: {"type":"NOTIFY","data":"{\"items\":[{\"timestamp\":1636015132,\"handling\":\"none\",\"uri\":\"/api/homeappliances/SIEMENS-TI909701HC-68A40E188708/programs/active/options/BSH.Common.Option.ProgramProgress\",\"key\":\"BSH.Common.Option.ProgramProgress\",\"unit\":\"%\",\"value\":10,\"level\":\"hint\"}],\"haId\":\"SIEMENS-TI909701HC-68A40E188708\"}","lastEventId":"SIEMENS-TI909701HC-68A40E188708","origin":"https://api.home-connect.com"}
    04 Nov 2021 09:38:52.589
     homeconnect.0 (22023) SIEMENS-TI909701HC-68A40E188708: The rate limit "10 successive error calls in 10 minutes" was reached. Requests are blocked during the remaining period of 577 seconds.
    04 Nov 2021 09:38:52.588
     homeconnect.0 (22023) SIEMENS-TI909701HC-68A40E188708: The rate limit "10 successive error calls in 10 minutes" was reached. Requests are blocked during the remaining period of 579 seconds.
    04 Nov 2021 09:38:52.104
     master homeconnect.0: SIEMENS-TI909701HC-68A40E188708: The rate limit "10 successive error calls in 10 minutes" was reached. Requests are blocked during the remaining period of 577 seconds.
    04 Nov 2021 09:38:51.706
     master homeconnect.0: SIEMENS-TI909701HC-68A40E188708.programs.active.options.BSH_Common_Option_ProgramProgress:9
     master homeconnect.0: event: {"type":"NOTIFY","data":"{\"items\":[{\"timestamp\":1636015131,\"handling\":\"none\",\"uri\":\"/api/homeappliances/SIEMENS-TI909701HC-68A40E188708/programs/active/options/BSH.Common.Option.ProgramProgress\",\"key\":\"BSH.Common.Option.ProgramProgress\",\"unit\":\"%\",\"value\":9,\"level\":\"hint\"}],\"haId\":\"SIEMENS-TI909701HC-68A40E188708\"}","lastEventId":"SIEMENS-TI909701HC-68A40E188708","origin":"https://api.home-connect.com"}
    04 Nov 2021 09:38:50.715
     master homeconnect.0: SIEMENS-TI909701HC-68A40E188708.programs.active.options.BSH_Common_Option_ProgramProgress:8
     master homeconnect.0: event: {"type":"NOTIFY","data":"{\"items\":[{\"timestamp\":1636015130,\"handling\":\"none\",\"uri\":\"/api/homeappliances/SIEMENS-TI909701HC-68A40E188708/programs/active/options/BSH.Common.Option.ProgramProgress\",\"key\":\"BSH.Common.Option.ProgramProgress\",\"unit\":\"%\",\"value\":8,\"level\":\"hint\"}],\"haId\":\"SIEMENS-TI909701HC-68A40E188708\"}","lastEventId":"SIEMENS-TI909701HC-68A40E188708","origin":"https://api.home-connect.com"}
    04 Nov 2021 09:38:50.585
     master homeconnect.0: SIEMENS-TI909701HC-68A40E188708: The rate limit "10 successive error calls in 10 minutes" was reached. Requests are blocked during the remaining period of 579 seconds.
    04 Nov 2021 09:38:49.698
     master homeconnect.0: SIEMENS-TI909701HC-68A40E188708.programs.active.options.BSH_Common_Option_ProgramProgress:7
     master homeconnect.0: event: {"type":"NOTIFY","data":"{\"items\":[{\"timestamp\":1636015129,\"handling\":\"none\",\"uri\":\"/api/homeappliances/SIEMENS-TI909701HC-68A40E188708/programs/active/options/BSH.Common.Option.ProgramProgress\",\"key\":\"BSH.Common.Option.ProgramProgress\",\"unit\":\"%\",\"value\":7,\"level\":\"hint\"}],\"haId\":\"SIEMENS-TI909701HC-68A40E188708\"}","lastEventId":"SIEMENS-TI909701HC-68A40E188708","origin":"https://api.home-connect.com"}
    04 Nov 2021 09:38:49.591
     homeconnect.0 (22023) SIEMENS-TI909701HC-68A40E188708: The rate limit "10 successive error calls in 10 minutes" was reached. Requests are blocked during the remaining period of 580 seconds.
    04 Nov 2021 09:38:49.590
     homeconnect.0 (22023) SIEMENS-TI909701HC-68A40E188708: The rate limit "10 successive error calls in 10 minutes" was reached. Requests are blocked during the remaining period of 582 seconds.
    04 Nov 2021 09:38:49.095
     master homeconnect.0: SIEMENS-TI909701HC-68A40E188708: The rate limit "10 successive error calls in 10 minutes" was reached. Requests are blocked during the remaining period of 580 seconds.
    04 Nov 2021 09:38:48.695
     master homeconnect.0: SIEMENS-TI909701HC-68A40E188708.programs.active.options.BSH_Common_Option_ProgramProgress:6
    04 Nov 2021 09:38:48.694
     master homeconnect.0: event: {"type":"NOTIFY","data":"{\"items\":[{\"timestamp\":1636015128,\"handling\":\"none\",\"uri\":\"/api/homeappliances/SIEMENS-TI909701HC-68A40E188708/programs/active/options/BSH.Common.Option.ProgramProgress\",\"key\":\"BSH.Common.Option.ProgramProgress\",\"unit\":\"%\",\"value\":6,\"level\":\"hint\"}],\"haId\":\"SIEMENS-TI909701HC-68A40E188708\"}","lastEventId":"SIEMENS-TI909701HC-68A40E188708","origin":"https://api.home-connect.com"}
    04 Nov 2021 09:38:47.697
     master homeconnect.0: SIEMENS-TI909701HC-68A40E188708.programs.active.options.BSH_Common_Option_ProgramProgress:5
     master homeconnect.0: event: {"type":"NOTIFY","data":"{\"items\":[{\"timestamp\":1636015127,\"handling\":\"none\",\"uri\":\"/api/homeappliances/SIEMENS-TI909701HC-68A40E188708/programs/active/options/BSH.Common.Option.ProgramProgress\",\"key\":\"BSH.Common.Option.ProgramProgress\",\"unit\":\"%\",\"value\":5,\"level\":\"hint\"}],\"haId\":\"SIEMENS-TI909701HC-68A40E188708\"}","lastEventId":"SIEMENS-TI909701HC-68A40E188708","origin":"https://api.home-connect.com"}
    04 Nov 2021 09:38:47.587
     master homeconnect.0: SIEMENS-TI909701HC-68A40E188708: The rate limit "10 successive error calls in 10 minutes" was reached. Requests are blocked during the remaining period of 582 seconds.
    04 Nov 2021 09:38:46.693
     master homeconnect.0: SIEMENS-TI909701HC-68A40E188708.programs.active.options.BSH_Common_Option_ProgramProgress:4
     master homeconnect.0: event: {"type":"NOTIFY","data":"{\"items\":[{\"timestamp\":1636015126,\"handling\":\"none\",\"uri\":\"/api/homeappliances/SIEMENS-TI909701HC-68A40E188708/programs/active/options/BSH.Common.Option.ProgramProgress\",\"key\":\"BSH.Common.Option.ProgramProgress\",\"unit\":\"%\",\"value\":4,\"level\":\"hint\"}],\"haId\":\"SIEMENS-TI909701HC-68A40E188708\"}","lastEventId":"SIEMENS-TI909701HC-68A40E188708","origin":"https://api.home-connect.com"}
    04 Nov 2021 09:38:46.604
     homeconnect.0 (22023) SIEMENS-TI909701HC-68A40E188708: The rate limit "10 successive error calls in 10 minutes" was reached. Requests are blocked during the remaining period of 583 seconds.
     homeconnect.0 (22023) SIEMENS-TI909701HC-68A40E188708: The rate limit "10 successive error calls in 10 minutes" was reached. Requests are blocked during the remaining period of 585 seconds.
    04 Nov 2021 09:38:46.077
     master homeconnect.0: SIEMENS-TI909701HC-68A40E188708: The rate limit "10 successive error calls in 10 minutes" was reached. Requests are blocked during the remaining period of 583 seconds.
    04 Nov 2021 09:38:45.704
     master homeconnect.0: SIEMENS-TI909701HC-68A40E188708.programs.active.options.BSH_Common_Option_ProgramProgress:3
    04 Nov 2021 09:38:45.703
     master homeconnect.0: event: {"type":"NOTIFY","data":"{\"items\":[{\"timestamp\":1636015125,\"handling\":\"none\",\"uri\":\"/api/homeappliances/SIEMENS-TI909701HC-68A40E188708/programs/active/options/BSH.Common.Option.ProgramProgress\",\"key\":\"BSH.Common.Option.ProgramProgress\",\"unit\":\"%\",\"value\":3,\"level\":\"hint\"}],\"haId\":\"SIEMENS-TI909701HC-68A40E188708\"}","lastEventId":"SIEMENS-TI909701HC-68A40E188708","origin":"https://api.home-connect.com"}
    04 Nov 2021 09:38:44.600
     master homeconnect.0: SIEMENS-TI909701HC-68A40E188708: The rate limit "10 successive error calls in 10 minutes" was reached. Requests are blocked during the remaining period of 585 seconds.
    04 Nov 2021 09:38:43.596
     homeconnect.0 (22023) SIEMENS-TI909701HC-68A40E188708: Program currently not available
    04 Nov 2021 09:38:43.152
     master homeconnect.0: SIEMENS-TI909701HC-68A40E188708: Program currently not available
    04 Nov 2021 09:38:41.591
    04 Nov 2021 09:38:40.587
    04 Nov 2021 09:38:40.098
    04 Nov 2021 09:38:38.584
    04 Nov 2021 09:38:37.598
    04 Nov 2021 09:38:37.085
    04 Nov 2021 09:38:35.595
    04 Nov 2021 09:38:34.599
    04 Nov 2021 09:38:34.076
    04 Nov 2021 09:38:33.562
     master homeconnect.0: SIEMENS-TI909701HC-68A40E188708.status.BSH_Common_Status_LocalControlActive:false
     master homeconnect.0: event: {"type":"STATUS","data":"{\"items\":[{\"timestamp\":1636015113,\"handling\":\"none\",\"uri\":\"/api/homeappliances/SIEMENS-TI909701HC-68A40E188708/status/BSH.Common.Status.LocalControlActive\",\"key\":\"BSH.Common.Status.LocalControlActive\",\"value\":false,\"level\":\"hint\"}],\"haId\":\"SIEMENS-TI909701HC-68A40E188708\"}","lastEventId":"SIEMENS-TI909701HC-68A40E188708","origin":"https://api.home-connect.com"}
    04 Nov 2021 09:38:32.594
    04 Nov 2021 09:38:31.604
    04 Nov 2021 09:38:31.081
    04 Nov 2021 09:38:30.137
     master homeconnect.0: Delete: SIEMENS-TI909701HC-68A40E188708.programs.active.options
    04 Nov 2021 09:38:30.072
     master homeconnect.0: SIEMENS-TI909701HC-68A40E188708.programs.selected.BSH_Common_Root_SelectedProgram:null
     master homeconnect.0: event: {"type":"NOTIFY","data":"{\"items\":[{\"timestamp\":1636015110,\"handling\":\"none\",\"uri\":\"/api/homeappliances/SIEMENS-TI909701HC-68A40E188708/programs/selected\",\"key\":\"BSH.Common.Root.SelectedProgram\",\"value\":null,\"level\":\"hint\"}],\"haId\":\"SIEMENS-TI909701HC-68A40E188708\"}","lastEventId":"SIEMENS-TI909701HC-68A40E188708","origin":"https://api.home-connect.com"}
    04 Nov 2021 09:38:30.038
     master homeconnect.0: SIEMENS-TI909701HC-68A40E188708.programs.active.BSH_Common_Root_ActiveProgram:ConsumerProducts.CoffeeMaker.Program.Beverage.Coffee
     master homeconnect.0: event: {"type":"NOTIFY","data":"{\"items\":[{\"timestamp\":1636015110,\"handling\":\"none\",\"uri\":\"/api/homeappliances/SIEMENS-TI909701HC-68A40E188708/programs/active\",\"key\":\"BSH.Common.Root.ActiveProgram\",\"value\":\"ConsumerProducts.CoffeeMaker.Program.Beverage.Coffee\",\"level\":\"hint\"}],\"haId\":\"SIEMENS-TI909701HC-68A40E188708\"}","lastEventId":"SIEMENS-TI909701HC-68A40E188708","origin":"https://api.home-connect.com"}
    04 Nov 2021 09:38:30.035
     master homeconnect.0: SIEMENS-TI909701HC-68A40E188708.status.BSH_Common_Status_OperationState:BSH.Common.EnumType.OperationState.Run
     master homeconnect.0: event: {"type":"STATUS","data":"{\"items\":[{\"timestamp\":1636015110,\"handling\":\"none\",\"uri\":\"/api/homeappliances/SIEMENS-TI909701HC-68A40E188708/status/BSH.Common.Status.OperationState\",\"key\":\"BSH.Common.Status.OperationState\",\"value\":\"BSH.Common.EnumType.OperationState.Run\",\"level\":\"hint\"}],\"haId\":\"SIEMENS-TI909701HC-68A40E188708\"}","lastEventId":"SIEMENS-TI909701HC-68A40E188708","origin":"https://api.home-connect.com"}
    04 Nov 2021 09:38:29.601
    04 Nov 2021 09:38:29.022
     master homeconnect.0: SIEMENS-TI909701HC-68A40E188708.status.BSH_Common_Status_OperationState:BSH.Common.EnumType.OperationState.ActionRequired
    04 Nov 2021 09:38:29.021
     master homeconnect.0: event: {"type":"STATUS","data":"{\"items\":[{\"timestamp\":1636015109,\"handling\":\"none\",\"uri\":\"/api/homeappliances/SIEMENS-TI909701HC-68A40E188708/status/BSH.Common.Status.OperationState\",\"key\":\"BSH.Common.Status.OperationState\",\"value\":\"BSH.Common.EnumType.OperationState.ActionRequired\",\"level\":\"hint\"}],\"haId\":\"SIEMENS-TI909701HC-68A40E188708\"}","lastEventId":"SIEMENS-TI909701HC-68A40E188708","origin":"https://api.home-connect.com"}
    04 Nov 2021 09:38:28.507
     master homeconnect.0: SIEMENS-TI909701HC-68A40E188708.status.BSH_Common_Status_LocalControlActive:true
    04 Nov 2021 09:38:28.506
     master homeconnect.0: event: {"type":"STATUS","data":"{\"items\":[{\"timestamp\":1636015108,\"handling\":\"none\",\"uri\":\"/api/homeappliances/SIEMENS-TI909701HC-68A40E188708/status/BSH.Common.Status.LocalControlActive\",\"key\":\"BSH.Common.Status.LocalControlActive\",\"value\":true,\"level\":\"hint\"}],\"haId\":\"SIEMENS-TI909701HC-68A40E188708\"}","lastEventId":"SIEMENS-TI909701HC-68A40E188708","origin":"https://api.home-connect.com"}
    04 Nov 2021 09:38:26.453
     master homeconnect.0: SIEMENS-TI909701HC-68A40E188708.programs.selected.options.ConsumerProducts_CoffeeMaker_Option_BeanContainerSelection:ConsumerProducts.CoffeeMaker.EnumType.BeanContainerSelection.Left
     master homeconnect.0: SIEMENS-TI909701HC-68A40E188708.programs.selected.options.BSH_Common_Option_ProgramProgress:0
     master homeconnect.0: SIEMENS-TI909701HC-68A40E188708.programs.selected.options.ConsumerProducts_CoffeeMaker_Option_FlowRate:ConsumerProducts.CoffeeMaker.EnumType.FlowRate.Intense
    04 Nov 2021 09:38:26.452
     master homeconnect.0: SIEMENS-TI909701HC-68A40E188708.programs.selected.options.ConsumerProducts_CoffeeMaker_Option_FillQuantity:140
     master homeconnect.0: SIEMENS-TI909701HC-68A40E188708.programs.selected.options.ConsumerProducts_CoffeeMaker_Option_BeanAmount:ConsumerProducts.CoffeeMaker.EnumType.BeanAmount.VeryStrong
     master homeconnect.0: SIEMENS-TI909701HC-68A40E188708.programs.selected.options.ConsumerProducts_CoffeeMaker_Option_CoffeeTemperature:ConsumerProducts.CoffeeMaker.EnumType.CoffeeTemperature.96C
     master homeconnect.0: SIEMENS-TI909701HC-68A40E188708.programs.selected.BSH_Common_Root_SelectedProgram:ConsumerProducts.CoffeeMaker.Program.Beverage.Coffee
     master homeconnect.0: event: {"type":"NOTIFY","data":"{\"items\":[{\"timestamp\":1636015104,\"handling\":\"none\",\"uri\":\"/api/homeappliances/SIEMENS-TI909701HC-68A40E188708/programs/selected\",\"key\":\"BSH.Common.Root.SelectedProgram\",\"value\":\"ConsumerProducts.CoffeeMaker.Program.Beverage.Coffee\",\"level\":\"hint\"},{\"timestamp\":1636015104,\"handling\":\"none\",\"uri\":\"/api/homeappliances/SIEMENS-TI909701HC-68A40E188708/programs/selected/options/ConsumerProducts.CoffeeMaker.Option.CoffeeTemperature\",\"key\":\"ConsumerProducts.CoffeeMaker.Option.CoffeeTemperature\",\"value\":\"ConsumerProducts.CoffeeMaker.EnumType.CoffeeTemperature.96C\",\"level\":\"hint\"},{\"timestamp\":1636015104,\"handling\":\"none\",\"uri\":\"/api/homeappliances/SIEMENS-TI909701HC-68A40E188708/programs/selected/options/ConsumerProducts.CoffeeMaker.Option.BeanAmount\",\"key\":\"ConsumerProducts.CoffeeMaker.Option.BeanAmount\",\"value\":\"ConsumerProducts.CoffeeMaker.EnumType.BeanAmount.VeryStrong\",\"level\":\"hint\"},{\"timestamp\":1636015104,\"handling\":\"none\",\"uri\":\"/api/homeappliances/SIEMENS-TI909701HC-68A40E188708/programs/selected/options/ConsumerProducts.CoffeeMaker.Option.FillQuantity\",\"key\":\"ConsumerProducts.CoffeeMaker.Option.FillQuantity\",\"unit\":\"ml\",\"value\":140,\"level\":\"hint\"},{\"timestamp\":1636015104,\"handling\":\"none\",\"uri\":\"/api/homeappliances/SIEMENS-TI909701HC-68A40E188708/programs/selected/options/ConsumerProducts.CoffeeMaker.Option.FlowRate\",\"key\":\"ConsumerProducts.CoffeeMaker.Option.FlowRate\",\"value\":\"ConsumerProducts.CoffeeMaker.EnumType.FlowRate.Intense\",\"level\":\"hint\"},{\"timestamp\":1636015104,\"handling\":\"none\",\"uri\":\"/api/homeappliances/SIEMENS-TI909701HC-68A40E188708/programs/selected/options/BSH.Common.Option.ProgramProgress\",\"key\":\"BSH.Common.Option.ProgramProgress\",\"unit\":\"%\",\"value\":0,\"level\":\"hint\"},{\"timestamp\":1636015104,\"handling\":\"none\",\"uri\":\"/api/homeappliances/SIEMENS-TI909701HC-68A40E188708/programs/selected/options/ConsumerProducts.CoffeeMaker.Option.BeanContainerSelection\",\"key\":\"ConsumerProducts.CoffeeMaker.Option.BeanContainerSelection\",\"value\":\"ConsumerProducts.CoffeeMaker.EnumType.BeanContainerSelection.Left\",\"level\":\"hint\"}],\"haId\":\"SIEMENS-TI909701HC-68A40E188708\"}","lastEventId":"SIEMENS-TI909701HC-68A40E188708","origin":"https://api.home-connect.com"}
    04 Nov 2021 09:38:26.431
     master homeconnect.0: SIEMENS-TI909701HC-68A40E188708.status.BSH_Common_Status_OperationState:BSH.Common.EnumType.OperationState.Ready
     master homeconnect.0: event: {"type":"STATUS","data":"{\"items\":[{\"timestamp\":1636015104,\"handling\":\"none\",\"uri\":\"/api/homeappliances/SIEMENS-TI909701HC-68A40E188708/status/BSH.Common.Status.OperationState\",\"key\":\"BSH.Common.Status.OperationState\",\"value\":\"BSH.Common.EnumType.OperationState.Ready\",\"level\":\"hint\"}],\"haId\":\"SIEMENS-TI909701HC-68A40E188708\"}","lastEventId":"SIEMENS-TI909701HC-68A40E188708","origin":"https://api.home-connect.com"}
    04 Nov 2021 09:38:25.600
    04 Nov 2021 09:38:24.533
    04 Nov 2021 09:38:24.458
     master homeconnect.0: SIEMENS-TI909701HC-68A40E188708.programs.active.BSH_Common_Root_ActiveProgram:null
     master homeconnect.0: event: {"type":"NOTIFY","data":"{\"items\":[{\"timestamp\":1636015104,\"handling\":\"none\",\"uri\":\"/api/homeappliances/SIEMENS-TI909701HC-68A40E188708/programs/active\",\"key\":\"BSH.Common.Root.ActiveProgram\",\"value\":null,\"level\":\"hint\"}],\"haId\":\"SIEMENS-TI909701HC-68A40E188708\"}","lastEventId":"SIEMENS-TI909701HC-68A40E188708","origin":"https://api.home-connect.com"}
    04 Nov 2021 09:38:23.596
    04 Nov 2021 09:38:22.591
    04 Nov 2021 09:38:22.102
    04 Nov 2021 09:38:20.586
    04 Nov 2021 09:38:19.598
    04 Nov 2021 09:38:19.124
    04 Nov 2021 09:38:17.593
    04 Nov 2021 09:38:16.605
    04 Nov 2021 09:38:16.101
    04 Nov 2021 09:38:14.717
     master homeconnect.0: SIEMENS-TI909701HC-68A40E188708.programs.active.options.BSH_Common_Option_ProgramProgress:95
    04 Nov 2021 09:38:14.716
     master homeconnect.0: event: {"type":"NOTIFY","data":"{\"items\":[{\"timestamp\":1636015094,\"handling\":\"none\",\"uri\":\"/api/homeappliances/SIEMENS-TI909701HC-68A40E188708/programs/active/options/BSH.Common.Option.ProgramProgress\",\"key\":\"BSH.Common.Option.ProgramProgress\",\"unit\":\"%\",\"value\":95,\"level\":\"hint\"}],\"haId\":\"SIEMENS-TI909701HC-68A40E188708\"}","lastEventId":"SIEMENS-TI909701HC-68A40E188708","origin":"https://api.home-connect.com"}
    04 Nov 2021 09:38:14.601
    04 Nov 2021 09:38:13.715
     master homeconnect.0: SIEMENS-TI909701HC-68A40E188708.programs.active.options.BSH_Common_Option_ProgramProgress:70
     master homeconnect.0: event: {"type":"NOTIFY","data":"{\"items\":[{\"timestamp\":1636015093,\"handling\":\"none\",\"uri\":\"/api/homeappliances/SIEMENS-TI909701HC-68A40E188708/programs/active/options/BSH.Common.Option.ProgramProgress\",\"key\":\"BSH.Common.Option.ProgramProgress\",\"unit\":\"%\",\"value\":70,\"level\":\"hint\"}],\"haId\":\"SIEMENS-TI909701HC-68A40E188708\"}","lastEventId":"SIEMENS-TI909701HC-68A40E188708","origin":"https://api.home-connect.com"}
    04 Nov 2021 09:38:13.661
    04 Nov 2021 09:38:13.093
    04 Nov 2021 09:38:12.712
     master homeconnect.0: SIEMENS-TI909701HC-68A40E188708.programs.active.options.BSH_Common_Option_ProgramProgress:69
     master homeconnect.0: event: {"type":"NOTIFY","data":"{\"items\":[{\"timestamp\":1636015092,\"handling\":\"none\",\"uri\":\"/api/homeappliances/SIEMENS-TI909701HC-68A40E188708/programs/active/options/BSH.Common.Option.ProgramProgress\",\"key\":\"BSH.Common.Option.ProgramProgress\",\"unit\":\"%\",\"value\":69,\"level\":\"hint\"}],\"haId\":\"SIEMENS-TI909701HC-68A40E188708\"}","lastEventId":"SIEMENS-TI909701HC-68A40E188708","origin":"https://api.home-connect.com"}
    04 Nov 2021 09:38:11.717
     master homeconnect.0: SIEMENS-TI909701HC-68A40E188708.programs.active.options.BSH_Common_Option_ProgramProgress:67
     master homeconnect.0: event: {"type":"NOTIFY","data":"{\"items\":[{\"timestamp\":1636015091,\"handling\":\"none\",\"uri\":\"/api/homeappliances/SIEMENS-TI909701HC-68A40E188708/programs/active/options/BSH.Common.Option.ProgramProgress\",\"key\":\"BSH.Common.Option.ProgramProgress\",\"unit\":\"%\",\"value\":67,\"level\":\"hint\"}],\"haId\":\"SIEMENS-TI909701HC-68A40E188708\"}","lastEventId":"SIEMENS-TI909701HC-68A40E188708","origin":"https://api.home-connect.com"}
    04 Nov 2021 09:38:11.583
    04 Nov 2021 09:38:11.549
     homeconnect.0 (22023) SIEMENS-TI909701HC-68A40E188708: There is no program selected
    04 Nov 2021 09:38:10.714
     master homeconnect.0: SIEMENS-TI909701HC-68A40E188708.programs.active.options.BSH_Common_Option_ProgramProgress:64
    04 Nov 2021 09:38:10.713
     master homeconnect.0: event: {"type":"NOTIFY","data":"{\"items\":[{\"timestamp\":1636015090,\"handling\":\"none\",\"uri\":\"/api/homeappliances/SIEMENS-TI909701HC-68A40E188708/programs/active/options/BSH.Common.Option.ProgramProgress\",\"key\":\"BSH.Common.Option.ProgramProgress\",\"unit\":\"%\",\"value\":64,\"level\":\"hint\"}],\"haId\":\"SIEMENS-TI909701HC-68A40E188708\"}","lastEventId":"SIEMENS-TI909701HC-68A40E188708","origin":"https://api.home-connect.com"}
    04 Nov 2021 09:38:09.723
     master homeconnect.0: SIEMENS-TI909701HC-68A40E188708.programs.active.options.BSH_Common_Option_ProgramProgress:62
    04 Nov 2021 09:38:09.722
     master homeconnect.0: event: {"type":"NOTIFY","data":"{\"items\":[{\"timestamp\":1636015089,\"handling\":\"none\",\"uri\":\"/api/homeappliances/SIEMENS-TI909701HC-68A40E188708/programs/active/options/BSH.Common.Option.ProgramProgress\",\"key\":\"BSH.Common.Option.ProgramProgress\",\"unit\":\"%\",\"value\":62,\"level\":\"hint\"}],\"haId\":\"SIEMENS-TI909701HC-68A40E188708\"}","lastEventId":"SIEMENS-TI909701HC-68A40E188708","origin":"https://api.home-connect.com"}
    04 Nov 2021 09:38:09.546
     master homeconnect.0: SIEMENS-TI909701HC-68A40E188708: There is no program selected
    04 Nov 2021 09:38:08.709
     master homeconnect.0: SIEMENS-TI909701HC-68A40E188708.programs.active.options.BSH_Common_Option_ProgramProgress:59
     master homeconnect.0: event: {"type":"NOTIFY","data":"{\"items\":[{\"timestamp\":1636015088,\"handling\":\"none\",\"uri\":\"/api/homeappliances/SIEMENS-TI909701HC-68A40E188708/programs/active/options/BSH.Common.Option.ProgramProgress\",\"key\":\"BSH.Common.Option.ProgramProgress\",\"unit\":\"%\",\"value\":59,\"level\":\"hint\"}],\"haId\":\"SIEMENS-TI909701HC-68A40E188708\"}","lastEventId":"SIEMENS-TI909701HC-68A40E188708","origin":"https://api.home-connect.com"}
    04 Nov 2021 09:38:08.354
    04 Nov 2021 09:38:07.952
     master homeconnect.0: Create State: SIEMENS-TI909701HC-68A40E188708.programs.active.options.BSH_Common_Option_ProgramProgress
    04 Nov 2021 09:38:07.712
     master homeconnect.0: SIEMENS-TI909701HC-68A40E188708.programs.active.options.BSH_Common_Option_ProgramProgress:57
     master homeconnect.0: event: {"type":"NOTIFY","data":"{\"items\":[{\"timestamp\":1636015087,\"handling\":\"none\",\"uri\":\"/api/homeappliances/SIEMENS-TI909701HC-68A40E188708/programs/active/options/BSH.Common.Option.ProgramProgress\",\"key\":\"BSH.Common.Option.ProgramProgress\",\"unit\":\"%\",\"value\":57,\"level\":\"hint\"}],\"haId\":\"SIEMENS-TI909701HC-68A40E188708\"}","lastEventId":"SIEMENS-TI909701HC-68A40E188708","origin":"https://api.home-connect.com"}
    04 Nov 2021 09:38:06.716
     master homeconnect.0: SIEMENS-TI909701HC-68A40E188708.programs.active.options.BSH_Common_Option_ProgramProgress:54
    04 Nov 2021 09:38:06.715
     master homeconnect.0: event: {"type":"NOTIFY","data":"{\"items\":[{\"timestamp\":1636015086,\"handling\":\"none\",\"uri\":\"/api/homeappliances/SIEMENS-TI909701HC-68A40E188708/programs/active/options/BSH.Common.Option.ProgramProgress\",\"key\":\"BSH.Common.Option.ProgramProgress\",\"unit\":\"%\",\"value\":54,\"level\":\"hint\"}],\"haId\":\"SIEMENS-TI909701HC-68A40E188708\"}","lastEventId":"SIEMENS-TI909701HC-68A40E188708","origin":"https://api.home-connect.com"}
    04 Nov 2021 09:38:06.350
    04 Nov 2021 09:38:05.708
     master homeconnect.0: SIEMENS-TI909701HC-68A40E188708.programs.active.options.BSH_Common_Option_ProgramProgress:52
     master homeconnect.0: event: {"type":"NOTIFY","data":"{\"items\":[{\"timestamp\":1636015085,\"handling\":\"none\",\"uri\":\"/api/homeappliances/SIEMENS-TI909701HC-68A40E188708/programs/active/options/BSH.Common.Option.ProgramProgress\",\"key\":\"BSH.Common.Option.ProgramProgress\",\"unit\":\"%\",\"value\":52,\"level\":\"hint\"}],\"haId\":\"SIEMENS-TI909701HC-68A40E188708\"}","lastEventId":"SIEMENS-TI909701HC-68A40E188708","origin":"https://api.home-connect.com"}
    04 Nov 2021 09:38:04.987
    04 Nov 2021 09:38:04.912
     master homeconnect.0: Create State: SIEMENS-TI909701HC-68A40E188708.programs.active.BSH_Common_Root_ActiveProgram
    04 Nov 2021 09:38:04.712
     master homeconnect.0: SIEMENS-TI909701HC-68A40E188708.programs.active.options.BSH_Common_Option_ProgramProgress:49
     master homeconnect.0: event: {"type":"NOTIFY","data":"{\"items\":[{\"timestamp\":1636015084,\"handling\":\"none\",\"uri\":\"/api/homeappliances/SIEMENS-TI909701HC-68A40E188708/programs/active/options/BSH.Common.Option.ProgramProgress\",\"key\":\"BSH.Common.Option.ProgramProgress\",\"unit\":\"%\",\"value\":49,\"level\":\"hint\"}],\"haId\":\"SIEMENS-TI909701HC-68A40E188708\"}","lastEventId":"SIEMENS-TI909701HC-68A40E188708","origin":"https://api.home-connect.com"}
    04 Nov 2021 09:38:03.705
     master homeconnect.0: SIEMENS-TI909701HC-68A40E188708.programs.active.options.BSH_Common_Option_ProgramProgress:47
     master homeconnect.0: event: {"type":"NOTIFY","data":"{\"items\":[{\"timestamp\":1636015083,\"handling\":\"none\",\"uri\":\"/api/homeappliances/SIEMENS-TI909701HC-68A40E188708/programs/active/options/BSH.Common.Option.ProgramProgress\",\"key\":\"BSH.Common.Option.ProgramProgress\",\"unit\":\"%\",\"value\":47,\"level\":\"hint\"}],\"haId\":\"SIEMENS-TI909701HC-68A40E188708\"}","lastEventId":"SIEMENS-TI909701HC-68A40E188708","origin":"https://api.home-connect.com"}
    04 Nov 2021 09:38:02.713
     master homeconnect.0: SIEMENS-TI909701HC-68A40E188708.programs.active.options.BSH_Common_Option_ProgramProgress:44
    04 Nov 2021 09:38:02.712
     master homeconnect.0: event: {"type":"NOTIFY","data":"{\"items\":[{\"timestamp\":1636015082,\"handling\":\"none\",\"uri\":\"/api/homeappliances/SIEMENS-TI909701HC-68A40E188708/programs/active/options/BSH.Common.Option.ProgramProgress\",\"key\":\"BSH.Common.Option.ProgramProgress\",\"unit\":\"%\",\"value\":44,\"level\":\"hint\"}],\"haId\":\"SIEMENS-TI909701HC-68A40E188708\"}","lastEventId":"SIEMENS-TI909701HC-68A40E188708","origin":"https://api.home-connect.com"}
    04 Nov 2021 09:38:01.808
     master homeconnect.0: SIEMENS-TI909701HC-68A40E188708.programs.active.options.BSH_Common_Option_ProgramProgress:42
     master homeconnect.0: event: {"type":"NOTIFY","data":"{\"items\":[{\"timestamp\":1636015081,\"handling\":\"none\",\"uri\":\"/api/homeappliances/SIEMENS-TI909701HC-68A40E188708/programs/active/options/BSH.Common.Option.ProgramProgress\",\"key\":\"BSH.Common.Option.ProgramProgress\",\"unit\":\"%\",\"value\":42,\"level\":\"hint\"}],\"haId\":\"SIEMENS-TI909701HC-68A40E188708\"}","lastEventId":"SIEMENS-TI909701HC-68A40E188708","origin":"https://api.home-connect.com"}
    04 Nov 2021 09:38:01.052
    04 Nov 2021 09:38:00.948
    04 Nov 2021 09:38:00.947
     master homeconnect.0: event: {"type":"NOTIFY","data":"{\"items\":[{\"timestamp\":1636015080,\"handling\":\"none\",\"uri\":\"/api/homeappliances/SIEMENS-TI909701HC-68A40E188708/programs/selected\",\"key\":\"BSH.Common.Root.SelectedProgram\",\"value\":null,\"level\":\"hint\"}],\"haId\":\"SIEMENS-TI909701HC-68A40E188708\"}","lastEventId":"SIEMENS-TI909701HC-68A40E188708","origin":"https://api.home-connect.com"}
    04 Nov 2021 09:38:00.931
     master homeconnect.0: Create State: SIEMENS-TI909701HC-68A40E188708.status.ConsumerProducts_CoffeeMaker_Status_BeverageCounterPowderCoffee
     master homeconnect.0: Create State: SIEMENS-TI909701HC-68A40E188708.status.ConsumerProducts_CoffeeMaker_Status_BeverageCounterHotWater
     master homeconnect.0: Create State: SIEMENS-TI909701HC-68A40E188708.status.ConsumerProducts_CoffeeMaker_Status_BeverageCounterHotMilk
     master homeconnect.0: Create State: SIEMENS-TI909701HC-68A40E188708.status.ConsumerProducts_CoffeeMaker_Status_BeverageCounterFrothyMilk
     master homeconnect.0: Create State: SIEMENS-TI909701HC-68A40E188708.status.ConsumerProducts_CoffeeMaker_Status_BeverageCounterCoffeeAndMilk
     master homeconnect.0: Create State: SIEMENS-TI909701HC-68A40E188708.status.ConsumerProducts_CoffeeMaker_Status_BeverageCounterRistrettoEspresso
     master homeconnect.0: Create State: SIEMENS-TI909701HC-68A40E188708.status.BSH_Common_Status_RemoteControlStartAllowed
     master homeconnect.0: Create State: SIEMENS-TI909701HC-68A40E188708.status.BSH_Common_Status_OperationState
    04 Nov 2021 09:38:00.930
     master homeconnect.0: Create State: SIEMENS-TI909701HC-68A40E188708.status.BSH_Common_Status_LocalControlActive
     master homeconnect.0: Create State: SIEMENS-TI909701HC-68A40E188708.status.BSH_Common_Status_DoorState
     master homeconnect.0: Create State: SIEMENS-TI909701HC-68A40E188708.settings.ConsumerProducts_CoffeeMaker_Setting_CupWarmer
     master homeconnect.0: Create State: SIEMENS-TI909701HC-68A40E188708.settings.BSH_Common_Setting_PowerState
    04 Nov 2021 09:38:00.929
     master homeconnect.0: Create State: SIEMENS-TI909701HC-68A40E188708.settings.BSH_Common_Setting_ChildLock
    04 Nov 2021 09:38:00.909
     master homeconnect.0: Create State: SIEMENS-TI909701HC-68A40E188708.programs.available.ConsumerProducts_CoffeeMaker_Program_CoffeeWorld_DeadEye
     master homeconnect.0: SIEMENS-TI909701HC-68A40E188708 available: {"key":"ConsumerProducts.CoffeeMaker.Program.CoffeeWorld.DeadEye","name":"Dead Eye","constraints":{"execution":"selectandstart","available":true}}
     master homeconnect.0: Create State: SIEMENS-TI909701HC-68A40E188708.programs.available.ConsumerProducts_CoffeeMaker_Program_CoffeeWorld_BlackEye
     master homeconnect.0: SIEMENS-TI909701HC-68A40E188708 available: {"key":"ConsumerProducts.CoffeeMaker.Program.CoffeeWorld.BlackEye","name":"Black Eye","constraints":{"execution":"selectandstart","available":true}}
     master homeconnect.0: Create State: SIEMENS-TI909701HC-68A40E188708.programs.available.ConsumerProducts_CoffeeMaker_Program_CoffeeWorld_RedEye
     master homeconnect.0: SIEMENS-TI909701HC-68A40E188708 available: {"key":"ConsumerProducts.CoffeeMaker.Program.CoffeeWorld.RedEye","name":"Red Eye","constraints":{"execution":"selectandstart","available":true}}
     master homeconnect.0: Create State: SIEMENS-TI909701HC-68A40E188708.programs.available.ConsumerProducts_CoffeeMaker_Program_CoffeeWorld_Americano
    04 Nov 2021 09:38:00.908
     master homeconnect.0: SIEMENS-TI909701HC-68A40E188708 available: {"key":"ConsumerProducts.CoffeeMaker.Program.CoffeeWorld.Americano","name":"Americano","constraints":{"execution":"selectandstart","available":true}}
     master homeconnect.0: Create State: SIEMENS-TI909701HC-68A40E188708.programs.available.ConsumerProducts_CoffeeMaker_Program_CoffeeWorld_Garoto
     master homeconnect.0: SIEMENS-TI909701HC-68A40E188708 available: {"key":"ConsumerProducts.CoffeeMaker.Program.CoffeeWorld.Garoto","name":"Garoto","constraints":{"execution":"selectandstart","available":true}}
     master homeconnect.0: Create State: SIEMENS-TI909701HC-68A40E188708.programs.available.ConsumerProducts_CoffeeMaker_Program_CoffeeWorld_Galao
     master homeconnect.0: SIEMENS-TI909701HC-68A40E188708 available: {"key":"ConsumerProducts.CoffeeMaker.Program.CoffeeWorld.Galao","name":"Galão","constraints":{"execution":"selectandstart","available":true}}
     master homeconnect.0: Create State: SIEMENS-TI909701HC-68A40E188708.programs.available.ConsumerProducts_CoffeeMaker_Program_CoffeeWorld_KoffieVerkeerd
     master homeconnect.0: SIEMENS-TI909701HC-68A40E188708 available: {"key":"ConsumerProducts.CoffeeMaker.Program.CoffeeWorld.KoffieVerkeerd","name":"Koffie verkeerd","constraints":{"execution":"selectandstart","available":true}}
     master homeconnect.0: Create State: SIEMENS-TI909701HC-68A40E188708.programs.available.ConsumerProducts_CoffeeMaker_Program_CoffeeWorld_Kaapi
     master homeconnect.0: SIEMENS-TI909701HC-68A40E188708 available: {"key":"ConsumerProducts.CoffeeMaker.Program.CoffeeWorld.Kaapi","name":"Kaapi","constraints":{"execution":"selectandstart","available":true}}
    04 Nov 2021 09:38:00.907
     master homeconnect.0: Create State: SIEMENS-TI909701HC-68A40E188708.programs.available.ConsumerProducts_CoffeeMaker_Program_CoffeeWorld_CafeAuLait
     master homeconnect.0: SIEMENS-TI909701HC-68A40E188708 available: {"key":"ConsumerProducts.CoffeeMaker.Program.CoffeeWorld.CafeAuLait","name":"Café au lait","constraints":{"execution":"selectandstart","available":true}}
     master homeconnect.0: Create State: SIEMENS-TI909701HC-68A40E188708.programs.available.ConsumerProducts_CoffeeMaker_Program_CoffeeWorld_CafeConLeche
     master homeconnect.0: SIEMENS-TI909701HC-68A40E188708 available: {"key":"ConsumerProducts.CoffeeMaker.Program.CoffeeWorld.CafeConLeche","name":"Café con leche","constraints":{"execution":"selectandstart","available":true}}
     master homeconnect.0: Create State: SIEMENS-TI909701HC-68A40E188708.programs.available.ConsumerProducts_CoffeeMaker_Program_CoffeeWorld_CafeCortado
     master homeconnect.0: SIEMENS-TI909701HC-68A40E188708 available: {"key":"ConsumerProducts.CoffeeMaker.Program.CoffeeWorld.CafeCortado","name":"Café cortado","constraints":{"execution":"selectandstart","available":true}}
     master homeconnect.0: Create State: SIEMENS-TI909701HC-68A40E188708.programs.available.ConsumerProducts_CoffeeMaker_Program_CoffeeWorld_Cortado
     master homeconnect.0: SIEMENS-TI909701HC-68A40E188708 available: {"key":"ConsumerProducts.CoffeeMaker.Program.CoffeeWorld.Cortado","name":"Cortado","constraints":{"execution":"selectandstart","available":true}}
     master homeconnect.0: Create State: SIEMENS-TI909701HC-68A40E188708.programs.available.ConsumerProducts_CoffeeMaker_Program_CoffeeWorld_FlatWhite
     master homeconnect.0: SIEMENS-TI909701HC-68A40E188708 available: {"key":"ConsumerProducts.CoffeeMaker.Program.CoffeeWorld.FlatWhite","name":"Flat White","constraints":{"execution":"selectandstart","available":true}}
    04 Nov 2021 09:38:00.906
     master homeconnect.0: Create State: SIEMENS-TI909701HC-68A40E188708.programs.available.ConsumerProducts_CoffeeMaker_Program_CoffeeWorld_WienerMelange
     master homeconnect.0: SIEMENS-TI909701HC-68A40E188708 available: {"key":"ConsumerProducts.CoffeeMaker.Program.CoffeeWorld.WienerMelange","name":"Wiener Melange","constraints":{"execution":"selectandstart","available":true}}
     master homeconnect.0: Create State: SIEMENS-TI909701HC-68A40E188708.programs.available.ConsumerProducts_CoffeeMaker_Program_CoffeeWorld_VerlaengerterBraun
     master homeconnect.0: SIEMENS-TI909701HC-68A40E188708 available: {"key":"ConsumerProducts.CoffeeMaker.Program.CoffeeWorld.VerlaengerterBraun","name":"Verlängerter braun","constraints":{"execution":"selectandstart","available":true}}
     master homeconnect.0: SIEMENS-TI909701HC-68A40E188708 available: {"key":"ConsumerProducts.CoffeeMaker.Program.CoffeeWorld.Verlaengerter","name":"Verlängerter","constraints":{"execution":"selectandstart","available":true}}
     master homeconnect.0: Create State: SIEMENS-TI909701HC-68A40E188708.programs.available.ConsumerProducts_CoffeeMaker_Program_CoffeeWorld_GrosserBrauner
    04 Nov 2021 09:38:00.904
     master homeconnect.0: SIEMENS-TI909701HC-68A40E188708 available: {"key":"ConsumerProducts.CoffeeMaker.Program.CoffeeWorld.GrosserBrauner","name":"Großer Brauner","constraints":{"execution":"selectandstart","available":true}}
     master homeconnect.0: Create State: SIEMENS-TI909701HC-68A40E188708.programs.available.ConsumerProducts_CoffeeMaker_Program_CoffeeWorld_KleinerBrauner
     master homeconnect.0: SIEMENS-TI909701HC-68A40E188708 available: {"key":"ConsumerProducts.CoffeeMaker.Program.CoffeeWorld.KleinerBrauner","name":"Kleiner Brauner","constraints":{"execution":"selectandstart","available":true}}
     master homeconnect.0: Create State: SIEMENS-TI909701HC-68A40E188708.programs.available.ConsumerProducts_CoffeeMaker_Program_Beverage_WarmMilk
     master homeconnect.0: SIEMENS-TI909701HC-68A40E188708 available: {"key":"ConsumerProducts.CoffeeMaker.Program.Beverage.WarmMilk","name":"Warme Milch","constraints":{"execution":"selectandstart","available":true}}
     master homeconnect.0: Create State: SIEMENS-TI909701HC-68A40E188708.programs.available.ConsumerProducts_CoffeeMaker_Program_Beverage_MilkFroth
     master homeconnect.0: SIEMENS-TI909701HC-68A40E188708 available: {"key":"ConsumerProducts.CoffeeMaker.Program.Beverage.MilkFroth","name":"Milchschaum","constraints":{"execution":"selectandstart","available":true}}
     master homeconnect.0: Create State: SIEMENS-TI909701HC-68A40E188708.programs.available.ConsumerProducts_CoffeeMaker_Program_Beverage_CaffeLatte
     master homeconnect.0: SIEMENS-TI909701HC-68A40E188708 available: {"key":"ConsumerProducts.CoffeeMaker.Program.Beverage.CaffeLatte","name":"Milchkaffee","constraints":{"execution":"selectandstart","available":true}}
     master homeconnect.0: Create State: SIEMENS-TI909701HC-68A40E188708.programs.available.ConsumerProducts_CoffeeMaker_Program_Beverage_LatteMacchiato
    04 Nov 2021 09:38:00.903
     master homeconnect.0: SIEMENS-TI909701HC-68A40E188708 available: {"key":"ConsumerProducts.CoffeeMaker.Program.Beverage.LatteMacchiato","name":"Latte Macchiato","constraints":{"execution":"selectandstart","available":true}}
     master homeconnect.0: Create State: SIEMENS-TI909701HC-68A40E188708.programs.available.ConsumerProducts_CoffeeMaker_Program_Beverage_Cappuccino
     master homeconnect.0: SIEMENS-TI909701HC-68A40E188708 available: {"key":"ConsumerProducts.CoffeeMaker.Program.Beverage.Cappuccino","name":"Cappuccino","constraints":{"execution":"selectandstart","available":true}}
     master homeconnect.0: Create State: SIEMENS-TI909701HC-68A40E188708.programs.available.ConsumerProducts_CoffeeMaker_Program_Beverage_Coffee
     master homeconnect.0: SIEMENS-TI909701HC-68A40E188708 available: {"key":"ConsumerProducts.CoffeeMaker.Program.Beverage.Coffee","name":"Caffè Crema","constraints":{"execution":"selectandstart","available":true}}
     master homeconnect.0: Create State: SIEMENS-TI909701HC-68A40E188708.programs.available.ConsumerProducts_CoffeeMaker_Program_Beverage_EspressoMacchiato
     master homeconnect.0: SIEMENS-TI909701HC-68A40E188708 available: {"key":"ConsumerProducts.CoffeeMaker.Program.Beverage.EspressoMacchiato","name":"Espresso Macchiato","constraints":{"execution":"selectandstart","available":true}}
     master homeconnect.0: SIEMENS-TI909701HC-68A40E188708 available: {"key":"ConsumerProducts.CoffeeMaker.Program.Beverage.Espresso","name":"Espresso","constraints":{"execution":"selectandstart","available":true}}
    04 Nov 2021 09:38:00.902
     master homeconnect.0: Create State: SIEMENS-TI909701HC-68A40E188708.programs.available.ConsumerProducts_CoffeeMaker_Program_Beverage_EspressoDoppio
     master homeconnect.0: SIEMENS-TI909701HC-68A40E188708 available: {"key":"ConsumerProducts.CoffeeMaker.Program.Beverage.EspressoDoppio","name":"Espresso doppio","constraints":{"execution":"selectandstart","available":true}}
     master homeconnect.0: Create State: SIEMENS-TI909701HC-68A40E188708.programs.available.ConsumerProducts_CoffeeMaker_Program_Beverage_Ristretto
     master homeconnect.0: SIEMENS-TI909701HC-68A40E188708 available: {"key":"ConsumerProducts.CoffeeMaker.Program.Beverage.Ristretto","name":"Ristretto","constraints":{"execution":"selectandstart","available":true}}
    04 Nov 2021 09:38:00.895
     master homeconnect.0: SIEMENS-TI909701HC-68A40E188708.programs.active.options.BSH_Common_Option_ProgramProgress:39
    04 Nov 2021 09:38:00.894
     master homeconnect.0: SIEMENS-TI909701HC-68A40E188708.programs.active.BSH_Common_Root_ActiveProgram:ConsumerProducts.CoffeeMaker.Program.CleaningModes.ApplianceOnRinsing
     master homeconnect.0: event: {"type":"NOTIFY","data":"{\"items\":[{\"timestamp\":1636015080,\"handling\":\"none\",\"uri\":\"/api/homeappliances/SIEMENS-TI909701HC-68A40E188708/programs/active\",\"key\":\"BSH.Common.Root.ActiveProgram\",\"value\":\"ConsumerProducts.CoffeeMaker.Program.CleaningModes.ApplianceOnRinsing\",\"level\":\"hint\"},{\"timestamp\":1636015080,\"handling\":\"none\",\"uri\":\"/api/homeappliances/SIEMENS-TI909701HC-68A40E188708/programs/active/options/BSH.Common.Option.ProgramProgress\",\"key\":\"BSH.Common.Option.ProgramProgress\",\"unit\":\"%\",\"value\":39,\"level\":\"hint\"}],\"haId\":\"SIEMENS-TI909701HC-68A40E188708\"}","lastEventId":"SIEMENS-TI909701HC-68A40E188708","origin":"https://api.home-connect.com"}
    04 Nov 2021 09:38:00.261
    04 Nov 2021 09:38:00.151
     master homeconnect.0: event: {"type":"CONNECTED","data":"","lastEventId":"SIEMENS-TI909701HC-68A40E188708","origin":"https://api.home-connect.com"}
    so log von unten ..kaffe maschiene AN
    kaffe gezogen kannst im LOG 04 Nov 2021 09:38:14.717 erkennen da progress 95
    bis dahin alles gut
    um
    gings los
    hängts mit dem
    Program currently not available vielleicht zusammen..dass der hier murks macht
    dann weiter um 04 Nov 2021 09:38:45.704 läuft der 2-te kaffee...
    • T tombox
      @derdominik @oberfragger Ich habe mal in die github version eine option eingebaut mit der man das programm holen bei wiederverbinden deaktivieren
      oberfraggerO Offline
      oberfragger
      #655
      @tombox said in Test Adapter homeconnect (BSH Home-Connect) v0.0.x:
      ich bin gerade überfordert bei dem Satz...? Was meinst du genau? Da fehlt irgendwie ein verb? Sorry. Vielleicht ist das aber auch nur zu spät heute aben. Ich hoffe ja es kommt jetzt etwas schwung rein und der Fehler wird gefunden.
      Ich möchte ja gerne wieder die verläßliche Kaffeeansage...
      • oberfraggerO oberfragger
        tombox
        #656
        @oberfragger installiere bitte den Adapter via github
        Dann hast du eine zusätzliche Option in denn Einstellungen die du bitte aktivierst
        oberfraggerO 2 Antworten Letzte Antwort
        • T tombox
          oberfragger
          schrieb am zuletzt editiert von oberfragger
          #657
          @tombox Ok. Wird gemacht!
          Gib mir bitte 2-3 Tage Zeit.
          Das hier, oder?
          (War irritierend dass mir keine neue Versionsnummer angezeigt wurde).
          Ich bin gespannt.
          • T tombox
            oberfragger
            #658
            @tombox ...sieht gut aus. Mein Kaffee wird wieder schön angesagt und bisher keine Errors im Log (aktuell läuft die Instanz in der Zeit 7 - 16.30 Uhr).
            Danke.
              Danke.
              tombox
              #659
              @oberfragger kannst ja mal Vollzeit laufen lassen
              oberfraggerO 1 Antwort Letzte Antwort
              • T tombox
                oberfragger
                #660
                @tombox Ok. Gucken wir mal.
                • J Offline
                  JohnnyBahama
                  #661
                  @tombox hast du meinen Log bekommen?
                  • T tombox
                    Update der Beschreibung nach Maintainer-Änderung 2022:
                    Der Adapter ermöglicht die Anbindung von Homeconnect Geräte an den ioBroker.
                    https://github.com/iobroker-community-adapters/ioBroker.homeconnect
                    Es wird dabei die offizielle Homeconnect API verwendet.
                    https://developer.home-connect.com/changelog
                    Es werden nicht alle Funktionen aus der Homeconnect App unterstützt. Einige Status oder Programme sind nicht via Homeconnect API verfügbar. Wenn es dahingehend Änderungswünsche gibt, bitte direkt an Homeconnect API wenden:
                    https://developer.home-connect.com/support/contact
                    Anleitung für Client ID
                    Für den Adapter wird eine Homeconnect API ClientID benötigt.
                    https://developer.home-connect.com/user/register
                    Bei Default Home Connect User Account for Testing die E-Mail-Adresse angeben, mit der die Home-Connect-App
                    registriert wurde, diese wird später auch beim Authorization-Prozess benötigt.
                    Bei Account Type Individual auswählen. Die restlichen Daten sofern vorhanden ergänzen.
                    Dann auf Applications und anschließend auf Register Application gehen.
                    https://developer.home-connect.com/applications
                    Bei Application ID einen Namen für die Application eintragen, z.B. ioBroker. Bei OAuth Flow Device Flow selektieren.
                    Home Connect User Account for Testing kann leer bleiben. Bei Success Redirect eine URI eintragen, z.B. https://example.com.
                    Dann Speichern und dann hat man die benötigte ClientID.
                    Konfiguration
                    In der Adapter-Config muss der Homeconnect App Benutzername und Passwort und die erstellte ClientID eingetragen werden.
                    Benutzung
                    Mit den states in commands kannst du das Programm stoppen, pausieren oder fortführen.
                    Mit den states in settings kannst du das Gerät ein oder ausschalten.
                    Ändern des States programs.active.BSH_Common_Root_ActiveProgram führt zum starten eines Programms
                    Ändern des States programs.selected.BSH_Common_Root_SelectedProgram führt zum auswählen des Programms oder Optionen
                    Wenn man checken möchte, ob ein Programm fertig ist muss
                    auf den kompletten Status Name übrprüft werden:
                    BSH.Common.EnumType.OperationState.Finished
                    Weitere Zustände sind noch:
                    "BSH.Common.EnumType.OperationState.Inactive": "Inactive",
                    "BSH.Common.EnumType.OperationState.Ready": "Ready",
                    "BSH.Common.EnumType.OperationState.Run": "Run",
                    "BSH.Common.EnumType.OperationState.ActionRequired": "ActionRequired",
                    "BSH.Common.EnumType.OperationState.Finished": "Finished"
                    Oder ob ein Gerät geöffnet ist
                    "BSH.Common.EnumType.DoorState.Open": "Open",
                    "BSH.Common.EnumType.DoorState.Closed": "Closed"
                    Original AdapterAnnouncement von 2018:
                    So, der Anfang ist gemacht.
                    Der Adapter kann aber bisher noch nicht viel. Eigentlich fast garnix :D
                    Bisher funktioniert erstmal nur die Authorisierung und die verbundenen Geräte werden abgefragt und in Datenpunkten hinterlegt.
                    Da ich nur ein Home-Connect-Gerät besitze, kann ich leider nicht testen, ob auch mehrere Geräte in der Objektstruktur angelegt werden. Denke aber das funktioniert.
                    Dummerweise kann ich das ganze auch nicht mit dem Simulator testen, da der leider den OAuth2-Deviceflow nicht unterstützt.
                    Daher bin ich auf Eure Hilfe angewiesen.
                    Wer möchte kann den Adapter ja mal installieren und schauen, ob die Geräte soweit angelegt werden.
                    Eine Beschreibung ist in der Readme zum Adapter.
                    Ich würde mich über Feedback freuen.
                    Dann noch ein kleiner Hinweis:
                    Der automatische Token-Refresh funktioniert scheinbar noch nicht richtig.
                    Sollte der Token abgelaufen sein (Hinweis im Log), einfach den Datenpunkt 'access' unter dev auf false setzen
                    und anschließend den Adapter neu starten. Dann wird der Authorisierungsprozess nochmals gestartet.
                    LG
                    dna909
                    sigi234S Online
                    sigi234S Online
                    #662
                    @dna909
                    Hallo, ich glaube die haben die Api umgestellt?
                    homeconnect.0
                    2021-11-16 08:22:19.621	info	Undefined Error from Homeconnect this happens sometimes.
                    homeconnect.0
                    2021-11-16 08:22:19.620	error	EventSource error: {"type":"error"}
                    homeconnect.0
                    2021-11-16 08:22:19.620	error	Homeconnect API are not available please try again later
                    homeconnect.0
                    2021-11-16 08:22:19.620	error	Error: {"type":"error","status":500,"message":"Internal Server Error"}
                    homeconnect.0
                    2021-11-16 08:22:19.620	error	Error: 500
                    homeconnect.0
                    2021-11-16 08:22:19.620	error	Error (401010522278007458)
                    homeconnect.0
                    2021-11-16 08:22:19.620	error	500 Internal Server Error
                    homeconnect.0
                    2021-11-16 08:22:19.620	error	EventSource error: {"type":"error","status":500,"message":"Internal Server Error"}
                    homeconnect.0
                    2021-11-16 08:22:18.476	info	Undefined Error from Homeconnect this happens sometimes.
                    homeconnect.0
                    2021-11-16 08:22:18.475	error	EventSource error: {"type":"error"}
                    homeconnect.0
                    homeconnect.0
                    2021-11-16 08:22:18.475	error	Homeconnect API are not available please try again later
                    homeconnect.0
                    2021-11-16 08:22:18.475	error	Error: {"type":"error","status":500,"message":"Internal Server Error"}
                    homeconnect.0
                    2021-11-16 08:22:18.475	error	Error: 500
                    homeconnect.0
                    2021-11-16 08:22:18.475	error	Error (401010522278007458)
                    homeconnect.0
                    2021-11-16 08:22:18.475	error	500 Internal Server Error
                    homeconnect.0
                    2021-11-16 08:22:18.475	error	EventSource error: {"type":"error","status":500,"message":"Internal Server Error"}
                    Aha:
                    Wartungsarbeiten am 16. November 2021
                    Home Connect wird am 16. November 2021, von 12:00 Uhr bis 17:00 Uhr nicht verfügbar sein. Außerdem kann es auch am 17. November noch zu kleineren Störungen kommen. Hintergrund ist die Durchführung eines umfangreichen Upgrades unserer Infrastruktur. Dies wird zu einer verbesserten Netzwerkstabilität und einer besseren Performance der gesamten App führen.
                    Bitte entschuldige diese Unannehmlichkeit,
                    Dein Home Connect Team
                    • sigi234S sigi234
                      @dna909
                      homeconnect.0
                      homeconnect.0
                      homeconnect.0
                      homeconnect.0
                      homeconnect.0
                      homeconnect.0
                      homeconnect.0
                      homeconnect.0
                      homeconnect.0
                      homeconnect.0
                      homeconnect.0
                      homeconnect.0
                      homeconnect.0
                      homeconnect.0
                      homeconnect.0
                      homeconnect.0
                      homeconnect.0
                      Aha:
                      Michi_Pi
                      schrieb am zuletzt editiert von Michi_Pi
                      #663
                      @sigi234 hab das gleiche Problem. Komme aber auch über die App nicht mehr drauf.
                      Ahja, man sollte bis zum Ende lesen :P
                      • M Michi_Pi
                        oberfragger
                        #664
                        @michi_pi @sigi234 Ah. Sehr interessant und danke für den heinweis.
                        War heute früh m.E. bereits so. Jedenfalls wurde mir der Kaffee nicht angesagt...
                        • G Offline
                          GrillSgt
                          schrieb am zuletzt editiert von GrillSgt
                          #665
                          bin zur Zeit etwas ratlos.
                          Habe einen HomeConnect fähigen Trockner sowie eine Kaffeemaschine.
                          Aber augenscheinlich würde ich sagen, dass keine Stati angelegt werden um etwa die Kaffeemaschine anzuschalten. Ich denke auch nicht, dass es was mit dem Adapter selbst zu tun hat. Das Homebridge Plug-In für HomeConnect sagt auch nur, dass keine Steuerung möglich wäre / sei.
                          Interessant ist auch, dass die Geräte angeblich im State "Connected" immer auf "false" stehen. Über die HomeConnect App aber lassen sich die Geräte problemlos steuern.
                          Anbei mal exemplarisch die States für die Kaffeemaschine. Sieht für den Trockner ähnlich aus:
                          Habe auch schon neue Client IDs auf der Developer Seite neu angelegt. Hat alles nichts gebracht. Jmd noch ne Idee?
                          Adapterversion ist 0.0.36.
                          Zu den Meldungen vorher:
                          Das mit den Wartungsarbeiten heute wusste ich. Es kam eine E-Mail.
                          • G GrillSgt
                            tombox
                            #666
                            @grillsgt gib der api noch zwei Tage und probiere es dann nochmal
                            G 1 Antwort Letzte Antwort
                            • T tombox
                              GrillSgt
                              #667
                              @tombox Alles klar, danke :)
                              Allerdings, habe ich den Adapter schon vor einigen Tagen installiert. Hatte bisher nur selbst geschaut ob ich das in den Griff bekomme. Aber ich warte mal ab.
                              Hatte den Adapter auch mal zwei Tage deaktiviert um nicht die max. Anzahl von Anfragen zu erreichen.
                              • H Online
                                H Online
                                holgerwolf
                                #668
                                Seit der API Änderungen auf BSH-Seite laufe ich in das Request Limit:
                                homeconnect.0
                                	2021-11-19 08:43:58.958	warn	Retry Refresh Token in 5min
                                homeconnect.0
                                	2021-11-19 08:43:58.958	error	Error Refresh-Token: 429 undefined
                                homeconnect.0
                                	2021-11-19 08:43:58.953	warn	Restart the Adapter to get all devices correctly.
                                homeconnect.0
                                	2021-11-19 08:43:58.953	error	Error getting Aplliances with existing Token: 429 The rate limit "1000 calls in 1 day" was reached. Requests are blocked during the remaining period of 17:13:24
                                homeconnect.0
                                	2021-11-19 08:43:58.813	info	starting. Version 0.0.36 in /opt/iobroker/node_modules/iobroker.homeconnect, node: v12.21.0, js-controller: 3.3.14
                                Habe nur zwei Geräte dran. Kann man das Abfrage-Intervall irgendwo einstellen?
                                H 1 Antwort Letzte Antwort
                                • H holgerwolf
                                  homeconnect.0
                                  homeconnect.0
                                  homeconnect.0
                                  homeconnect.0
                                  homeconnect.0
                                  H Online
                                  H Online
                                  holgerwolf
                                  #669
                                  @holgerwolf Gerade oben gelesen, dass es eien Github Version mit der Option gibt.
                                  Hab ich mal nachinstalliert und jetzt heißt es warten bis morgen...
                                  • H holgerwolf
                                    derdominik
                                    #670
                                    @holgerwolf im DEBUG mode siehst du auch, wie oft so ein restart bzw reload der Programme statt findet.
                                    Hatte ich kürzlich auch, die Logs waren voll mit RECONNECT Meldungen und @tombox hat daraufhin netterweise diese Option eingebaut, dass die Programme nicht mehr geladen werden.
                                    Bevor ich die neue Version installieren konnte habe ich allerdings meinen Geschirrspüler per Strom AUS/AN neu gestartet. Seit dem hatte ich keine RECONNECTs mehr...
                                    • D derdominik
                                      oberfragger
                                      #671
                                      @tombox Hi, diese Option scheint was gebracht zu haben. Der Adapter läuft nun fehlerfrei seit ca. 4 Tagen.
                                      • H Online
                                        H Online
                                        holgerwolf
                                        #672
                                        Bei mir läuft der Adapter jetzt auch seit Samstag wieder.
                                        • G Offline
                                          GrillSgt
                                          #673
                                          Bei mir läuft der Adapter grundsätzlich auch. Steuern lässt sich aber nix. Angeblich sind meine Geräte offline und entsprechend werden auch die Stati nicht angelegt. Habe auch keine Idee mehr was ich dagegen noch machen soll.
                                          M T 2 Antworten Letzte Antwort
