  4. ioBroker.admin 5.1.25. Blockly nur mit alter GUI.
41 Beiträge 4 Kommentatoren 4.0k Aufrufe 3 Beobachtet
    @nitrox9
    iobroker list adapters
    iobroker list instances
    iobroker update -i
    iobroker update all
    N Offline
    N Offline
    nitrox9
    @thomas-braun said in ioBroker.admin 5.1.25. Blockly nur mit alter GUI.:
    iobroker update -i
    iobroker update all
    iobroker update -i
    iobroker update all
    system.adapter.admin                   : admin          - v5.1.25
    system.adapter.discovery               : discovery      - v2.7.0
    system.adapter.fhem                    : fhem           - v1.6.3
    system.adapter.info                    : info           - v1.9.8
    system.adapter.javascript              : javascript     - v5.2.8
    system.adapter.mqtt                    : mqtt           - v2.4.0
    system.adapter.vis                     : vis            - v1.4.4
    system.adapter.web                     : web            - v3.4.9
    + system.adapter.admin.0                  : admin                 : fhem                                     -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
    + system.adapter.discovery.0              : discovery             : fhem                                     -  enabled
    + system.adapter.fhem.0                   : fhem                  : fhem                                     -  enabled, port: 7072
      system.adapter.info.0                   : info                  : fhem                                     - disabled
    + system.adapter.javascript.1             : javascript            : fhem                                     -  enabled
    + system.adapter.mqtt.0                   : mqtt                  : fhem                                     -  enabled, port: 1883, bind: 0.0.0.0
      system.adapter.vis.0                    : vis                   : fhem                                     -  enabled
    + system.adapter.web.0                    : web                   : fhem                                     -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
    + instance is alive
    Used repository: default
    hash unchanged, use cached sources
    update done
    Adapter    "admin"         : 5.1.25   , installed 5.1.25
    Adapter    "backitup"      : 2.1.17   , installed 2.2.2
    Adapter    "discovery"     : 2.7.3    , installed 2.7.0 [Updateable]
    Adapter    "fhem"          : 1.6.3    , installed 1.6.3
    Adapter    "info"          : 1.9.8    , installed 1.9.8
    Adapter    "javascript"    : 5.2.8    , installed 5.2.8
    Controller "js-controller" : 3.3.18   , installed 3.3.18
    Adapter    "mqtt"          : 2.4.0    , installed 2.4.0
    Adapter    "simple-api"    : 2.6.1    , installed 2.6.2
    Adapter    "socketio"      : 3.1.4    , installed 3.1.5
    Adapter    "vis"           : 1.4.4    , installed 1.4.4
    Adapter    "web"           : 3.4.9    , installed 3.4.9
    Used repository: all
    failed to download new sources, use cached sources
    update done
    Meine Neuinstallation:
    • iobroker stop
    • mv /opt/iobroker /opt/iobroker.old
    • curl -sL https://iobroker.net/install.sh | bash -
    • alle Einstellungen, Adapter, Instanzen und Passworte waren weg
    javascript.0 / JavaScript Rules war automatisch vorhanden (aber nicht gestartet) und musste gelöscht werden, um Skripte starten zu können.
    HomoranH crunchipC 3 Antworten Letzte Antwort
    • N nitrox9
      iobroker update -i
      iobroker update all
      iobroker update -i
      iobroker update all
      + instance is alive
      update done
      update done
      • iobroker stop
      HomoranH Offline
      HomoranH Offline
      @nitrox9 sagte in ioBroker.admin 5.1.25. Blockly nur mit alter GUI.:
      Ja, natürlich!
      die hast du ja verschoben und eine flammneue Installation aufgesetzt
      aber nur enn du die installiert hat. Wahrscheilich über discovery
      • N nitrox9
        iobroker update -i
        iobroker update all
        iobroker update -i
        iobroker update all
        + instance is alive
        update done
        update done
        • iobroker stop
        crunchipC Offline
        crunchipC Offline
        @nitrox9 bei dir stimmt doch etws mit dem Repo nicht, daher auch bei einigen Adapter die falsche Version
        bzw bist du scheinbar im latest unterwegs
        N 1 Antwort Letzte Antwort
          N Offline
          N Offline
          nitrox9
          @crunchip said in ioBroker.admin 5.1.25. Blockly nur mit alter GUI.:
          Betriebssystem? Eigentlich nicht:
          sources.list:
          deb http://deb.debian.org/debian bullseye main contrib non-free
          deb http://deb.debian.org/debian bullseye-updates main contrib non-free
          deb http://security.debian.org/debian-security bullseye-security main contrib non-free
          Ist Bullseye 11.1, sollte die aktuellste stable sein.
          Das ganze System wurde mit apt dist-upgrade eigentlich sauber von Buster hochgezogen. Altlasten im System?
          • N nitrox9
            sources.list:
            crunchipC Offline
            crunchipC Offline
            @nitrox9 iobroker war damit gemeint Systemeinstellung(Schraubenschlüssel) standard repository
            HomoranH N 2 Antworten Letzte Antwort
              HomoranH Offline
              HomoranH Offline
              @crunchip sagte in ioBroker.admin 5.1.25. Blockly nur mit alter GUI.:
              nicht nur dort:
              was soll das sein?
                N Offline
                N Offline
                nitrox9
                • N nitrox9
                  @nitrox9
                  iobroker repo list
                    nicht nur dort:
                    was soll das sein?
                    crunchipC Offline
                    crunchipC Offline
                    @homoran deswegen schrieb ich ja oben
                      @nitrox9
                      iobroker repo list
                      N Offline
                      N Offline
                      nitrox9
                      schrieb am zuletzt editiert von nitrox9
                      iobroker repo list
                      # iobroker repo list
                      default     : http://download.iobroker.net/sources-dist.json
                      latest      : http://download.iobroker.net/sources-dist-latest.json
                      Active repo: default
                      • N nitrox9
                        iobroker update -i
                        iobroker update all
                        iobroker update -i
                        iobroker update all
                        + instance is alive
                        update done
                        update done
                        • iobroker stop
                        crunchipC Offline
                        crunchipC Offline
                        kann es sein das keine verbindung besteht?
                        dann wäre besser
                        live-default   http://iobroker.live/repo/sources-dist.json
                        • HomoranH Offline
                          HomoranH Offline
                          Aber das ist doch eine neue Installation, oder?
                          wo kommt denn da der alte Mist her?
                            crunchipC Offline
                            crunchipC Offline
                            @homoran und wie kommt er dann zu
                              HomoranH Offline
                              HomoranH Offline
                              @crunchip ich sag ja, da ist irgendetwas grundlegend faul
                              @nitrox9
                              bitte immer auch die Eingabe und die vollständige Ausgabe posten
                                N Offline
                                N Offline
                                nitrox9
                                Adapter "simple-api" : 2.6.1 , installed 2.6.2 Adapter "socketio" : 3.1.4 , installed 3.1.5
                                Altlasten im System von der ersten Installation?
                                Bei der ersten Installation (die nach /opt/iobroker.old verschoben wurde) hatte ich alle Geräte angeklickt, die mir interessant vorkamen.
                                Sollte nach meinem Verständnis aber nach
                                erledigt sein.
                                Thomas BraunT HomoranH crunchipC 3 Antworten Letzte Antwort
                                • N nitrox9
                                  erledigt sein.
                                  erledigt sein.
                                  Da könnte aber noch Zeug im npm cache hängen und von dort wiederherstellt werden. Hatte so ein Phänomen die Tage (allerdings in einem leicht anderen Zusammenhang).
                                  • N nitrox9
                                    erledigt sein.
                                    HomoranH Offline
                                    HomoranH Offline
                                    das hatte ich vermutet / Zwei parallele Installationen
                                    @thomas-braun sagte in ioBroker.admin 5.1.25. Blockly nur mit alter GUI.:
                                    aber doch nicht die Pfade zum Repo?
                                    Ansonsten hilft ein
                                    cd/opt/iobroker
                                    npm cache clean --force
                                    • N nitrox9
                                      erledigt sein.
                                      crunchipC Offline
                                      crunchipC Offline
                                      @nitrox9 nein, es ist verwunderlich, das du versionen aus dem latest hast, dein repo auf default steht und zu gleich keine Ausgabe hergibt.
                                      ich persönlich würde den discover adapter aussen vor lassen und deine Geräte manuell nach und nach einrichten, bzw wenn du discover verwenden möchtet, dann Stück für Stück und nicht alles was dir angezeigt wird, gleich aktivieren. Da passieren nämlich hier und da, blöde Dinge, w.z.b. Geräte/Instanzen doppelt angelegt werden.
                                        HomoranH Offline
                                        HomoranH Offline
                                        Das wäre auch mein nächster Vorschlag, wenn wir eine saubere Basis haben
                                          N Offline
                                          N Offline
                                          nitrox9
                                          @homoran said in ioBroker.admin 5.1.25. Blockly nur mit alter GUI.:
                                          Vielen Dank für all den Support.
                                          Werde dann alles nochmal ganz neu als Minimalkonfig aufsetzen. Nur MQTT, FHEM, VIS und Blockly wird benötigt.
                                          Mir ging es hier in dieser Rubrik auch darum einen Fehler zwecks Verbesserung aufzuzeigen. Aber offensichtlich ist hier kein Bug im engen Sinne vorhanden.
                                          Grüße!
