  4. ioBroker.admin 5.1.25. Blockly nur mit alter GUI.
41 Beiträge 4 Kommentatoren 4.0k Aufrufe 3 Beobachtet
    @nitrox9
    iobroker repo list
    N Offline
    N Offline
    nitrox9
    schrieb am zuletzt editiert von nitrox9
    @thomas-braun said in ioBroker.admin 5.1.25. Blockly nur mit alter GUI.:
    iobroker repo list
    # iobroker repo list
    default     : http://download.iobroker.net/sources-dist.json
    latest      : http://download.iobroker.net/sources-dist-latest.json
    Active repo: default
    • N nitrox9
      iobroker list adapters
      iobroker list instances
      iobroker update -i
      iobroker update all
      iobroker update -i
      iobroker update all
      system.adapter.admin                   : admin          - v5.1.25
      system.adapter.discovery               : discovery      - v2.7.0
      system.adapter.fhem                    : fhem           - v1.6.3
      system.adapter.info                    : info           - v1.9.8
      system.adapter.javascript              : javascript     - v5.2.8
      system.adapter.mqtt                    : mqtt           - v2.4.0
      system.adapter.vis                     : vis            - v1.4.4
      system.adapter.web                     : web            - v3.4.9
      + system.adapter.admin.0                  : admin                 : fhem                                     -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
      + system.adapter.discovery.0              : discovery             : fhem                                     -  enabled
      + system.adapter.fhem.0                   : fhem                  : fhem                                     -  enabled, port: 7072
        system.adapter.info.0                   : info                  : fhem                                     - disabled
      + system.adapter.javascript.1             : javascript            : fhem                                     -  enabled
      + system.adapter.mqtt.0                   : mqtt                  : fhem                                     -  enabled, port: 1883, bind: 0.0.0.0
        system.adapter.vis.0                    : vis                   : fhem                                     -  enabled
      + system.adapter.web.0                    : web                   : fhem                                     -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
      + instance is alive
      Used repository: default
      hash unchanged, use cached sources
      update done
      Adapter    "admin"         : 5.1.25   , installed 5.1.25
      Adapter    "backitup"      : 2.1.17   , installed 2.2.2
      Adapter    "discovery"     : 2.7.3    , installed 2.7.0 [Updateable]
      Adapter    "fhem"          : 1.6.3    , installed 1.6.3
      Adapter    "info"          : 1.9.8    , installed 1.9.8
      Adapter    "javascript"    : 5.2.8    , installed 5.2.8
      Controller "js-controller" : 3.3.18   , installed 3.3.18
      Adapter    "mqtt"          : 2.4.0    , installed 2.4.0
      Adapter    "simple-api"    : 2.6.1    , installed 2.6.2
      Adapter    "socketio"      : 3.1.4    , installed 3.1.5
      Adapter    "vis"           : 1.4.4    , installed 1.4.4
      Adapter    "web"           : 3.4.9    , installed 3.4.9
      Used repository: all
      failed to download new sources, use cached sources
      update done
      Meine Neuinstallation:
      • iobroker stop
      • mv /opt/iobroker /opt/iobroker.old
      • curl -sL https://iobroker.net/install.sh | bash -
      • alle Einstellungen, Adapter, Instanzen und Passworte waren weg
      javascript.0 / JavaScript Rules war automatisch vorhanden (aber nicht gestartet) und musste gelöscht werden, um Skripte starten zu können.
      crunchipC Offline
      crunchipC Offline
      @nitrox9 sagte in ioBroker.admin 5.1.25. Blockly nur mit alter GUI.:
      kann es sein das keine verbindung besteht?
      dann wäre besser
      live-default   http://iobroker.live/repo/sources-dist.json
      • HomoranH Offline
        HomoranH Offline
        Aber das ist doch eine neue Installation, oder?
        wo kommt denn da der alte Mist her?
          crunchipC Offline
          crunchipC Offline
          @homoran und wie kommt er dann zu
          HomoranH N 2 Antworten Letzte Antwort
            HomoranH Offline
            HomoranH Offline
            @crunchip ich sag ja, da ist irgendetwas grundlegend faul
            @nitrox9
            bitte immer auch die Eingabe und die vollständige Ausgabe posten
              N Offline
              N Offline
              nitrox9
              @crunchip said in ioBroker.admin 5.1.25. Blockly nur mit alter GUI.:
              Adapter "simple-api" : 2.6.1 , installed 2.6.2 Adapter "socketio" : 3.1.4 , installed 3.1.5
              Altlasten im System von der ersten Installation?
              Bei der ersten Installation (die nach /opt/iobroker.old verschoben wurde) hatte ich alle Geräte angeklickt, die mir interessant vorkamen.
              Sollte nach meinem Verständnis aber nach
              erledigt sein.
              Thomas BraunT HomoranH crunchipC 3 Antworten Letzte Antwort
              • N nitrox9
                erledigt sein.
                erledigt sein.
                Da könnte aber noch Zeug im npm cache hängen und von dort wiederherstellt werden. Hatte so ein Phänomen die Tage (allerdings in einem leicht anderen Zusammenhang).
                • N nitrox9
                  erledigt sein.
                  HomoranH Offline
                  HomoranH Offline
                  das hatte ich vermutet / Zwei parallele Installationen
                  @thomas-braun sagte in ioBroker.admin 5.1.25. Blockly nur mit alter GUI.:
                  aber doch nicht die Pfade zum Repo?
                  Ansonsten hilft ein
                  cd/opt/iobroker
                  npm cache clean --force
                  • N nitrox9
                    erledigt sein.
                    crunchipC Offline
                    crunchipC Offline
                    @nitrox9 nein, es ist verwunderlich, das du versionen aus dem latest hast, dein repo auf default steht und zu gleich keine Ausgabe hergibt.
                    ich persönlich würde den discover adapter aussen vor lassen und deine Geräte manuell nach und nach einrichten, bzw wenn du discover verwenden möchtet, dann Stück für Stück und nicht alles was dir angezeigt wird, gleich aktivieren. Da passieren nämlich hier und da, blöde Dinge, w.z.b. Geräte/Instanzen doppelt angelegt werden.
                      HomoranH Offline
                      HomoranH Offline
                      @crunchip sagte in ioBroker.admin 5.1.25. Blockly nur mit alter GUI.:
                      Das wäre auch mein nächster Vorschlag, wenn wir eine saubere Basis haben
                      N 1 Antwort Letzte Antwort
                        N Offline
                        N Offline
                        nitrox9
                        @homoran said in ioBroker.admin 5.1.25. Blockly nur mit alter GUI.:
                        Vielen Dank für all den Support.
                        Werde dann alles nochmal ganz neu als Minimalkonfig aufsetzen. Nur MQTT, FHEM, VIS und Blockly wird benötigt.
                        Mir ging es hier in dieser Rubrik auch darum einen Fehler zwecks Verbesserung aufzuzeigen. Aber offensichtlich ist hier kein Bug im engen Sinne vorhanden.
                        Grüße!
                        • N nitrox9
                          Grüße!
                          HomoranH Offline
                          HomoranH Offline
                          Sehe ich auch so
