  4. Alpha Testing: OCPP Wallbox Adapter
    6.3k
ocppwallboxadapter
448 Beiträge 49 Kommentatoren 152.4k Aufrufe 47 Beobachtet
  • GlasfaserG Glasfaser
    @foxriver76
    Wallbox ist eine
    Schneider Electric EVlink Wallbox G4 Smart 22kW
    Ladestationeinstellung
    OCPP-Version : 1.6
    Überwachung URL : ws://192.168.xxx.xxx:9220
    Lade-Modus gerade :
    Auto wird geladen , 1 Phase 16A , Ladeleistung ~3509 W
    Stecker gezogen :
    2021-10-28 17:55:56.027 - info: host.iobroker stopInstance system.adapter.ocpp.0 (force=false, process=true)
    2021-10-28 17:55:56.254 - info: ocpp.0 (11858) Got terminate signal TERMINATE_YOURSELF
    2021-10-28 17:55:56.437 - info: host.iobroker stopInstance system.adapter.ocpp.0 send kill signal
    2021-10-28 17:55:56.513 - info: ocpp.0 (11858) terminating
    2021-10-28 17:55:56.519 - info: ocpp.0 (11858) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    2021-10-28 17:55:57.226 - info: host.iobroker instance system.adapter.ocpp.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2021-10-28 17:56:00.040 - info: host.iobroker instance system.adapter.ocpp.0 started with pid 4908
    2021-10-28 17:56:02.288 - debug: ocpp.0 (4908) Redis Objects: Use Redis connection: 127.0.0.1:9001
    2021-10-28 17:56:04.748 - debug: ocpp.0 (4908) Objects client ready ... initialize now
    2021-10-28 17:56:05.138 - debug: ocpp.0 (4908) Objects create System PubSub Client
    2021-10-28 17:56:05.140 - debug: ocpp.0 (4908) Objects create User PubSub Client
    2021-10-28 17:56:05.141 - debug: ocpp.0 (4908) Objects client initialize lua scripts
    2021-10-28 17:56:06.000 - debug: ocpp.0 (4908) Objects connected to redis: 127.0.0.1:9001
    2021-10-28 17:56:06.078 - debug: ocpp.0 (4908) objectDB connected
    2021-10-28 17:56:06.110 - debug: ocpp.0 (4908) Redis States: Use Redis connection: 127.0.0.1:9000
    2021-10-28 17:56:06.483 - debug: ocpp.0 (4908) States create System PubSub Client
    2021-10-28 17:56:06.484 - debug: ocpp.0 (4908) States create User PubSub Client
    2021-10-28 17:56:07.849 - debug: ocpp.0 (4908) States connected to redis: 127.0.0.1:9000
    2021-10-28 17:56:07.854 - debug: ocpp.0 (4908) statesDB connected
    2021-10-28 17:56:11.356 - info: ocpp.0 (4908) starting. Version 0.0.5 in /opt/iobroker/node_modules/iobroker.ocpp, node: v14.17.6, js-controller: 3.3.18
    2021-10-28 17:56:11.409 - info: ocpp.0 (4908) Starting OCPP Server
    2021-10-28 17:56:11.437 - info: ocpp.0 (4908) Server listening on port 9220
    2021-10-28 17:56:24.483 - info: ocpp.0 (4908) New device connected: "/Dorn"
    2021-10-28 17:56:24.486 - info: ocpp.0 (4908) Requesting BootNotification from "/Dorn"
    2021-10-28 17:56:25.548 - info: ocpp.0 (4908) Requesting StatusNotification from "/Dorn"
    2021-10-28 17:56:26.565 - info: ocpp.0 (4908) Requesting MeterValues from "/Dorn"
    2021-10-28 17:56:29.831 - debug: ocpp.0 (4908) {}
    2021-10-28 17:56:29.832 - debug: ocpp.0 (4908) Received heartbeat from "/Dorn"
    2021-10-28 17:56:29.878 - debug: ocpp.0 (4908) {"connectorId":1,"transactionId":1,"meterValue":[{"sampledValue":[{"value":"1121"}],"timestamp":"2021-10-28T15:56:26Z"}]}
    2021-10-28 17:56:29.880 - info: ocpp.0 (4908) Received MeterValues from "/Dorn"
    2021-10-28 17:56:30.019 - debug: ocpp.0 (4908) {"connectorId":1,"errorCode":"NoError","status":"Charging","timestamp":"2021-10-28T15:56:25Z"}
    2021-10-28 17:56:30.020 - info: ocpp.0 (4908) Received Status Notification from "/Dorn": Charging
    2021-10-28 17:57:25.026 - debug: ocpp.0 (4908) {}
    2021-10-28 17:57:25.027 - debug: ocpp.0 (4908) Received heartbeat from "/Dorn"
    2021-10-28 17:58:20.027 - debug: ocpp.0 (4908) {}
    2021-10-28 17:58:20.028 - debug: ocpp.0 (4908) Received heartbeat from "/Dorn"
    2021-10-28 17:59:15.015 - debug: ocpp.0 (4908) {}
    2021-10-28 17:59:15.016 - debug: ocpp.0 (4908) Received heartbeat from "/Dorn"
    2021-10-28 18:00:10.030 - debug: ocpp.0 (4908) {}
    2021-10-28 18:00:10.030 - debug: ocpp.0 (4908) Received heartbeat from "/Dorn"
    2021-10-28 18:01:05.025 - debug: ocpp.0 (4908) {}
    2021-10-28 18:01:05.026 - debug: ocpp.0 (4908) Received heartbeat from "/Dorn"
    2021-10-28 18:02:00.015 - debug: ocpp.0 (4908) {}
    2021-10-28 18:02:00.016 - debug: ocpp.0 (4908) Received heartbeat from "/Dorn"
    2021-10-28 18:02:55.030 - debug: ocpp.0 (4908) {}
    2021-10-28 18:02:55.031 - debug: ocpp.0 (4908) Received heartbeat from "/Dorn"
    2021-10-28 18:03:00.370 - info: javascript.0 (540) script.js.Wetter.UWZ: []
    2021-10-28 18:03:50.032 - debug: ocpp.0 (4908) {}
    2021-10-28 18:03:50.033 - debug: ocpp.0 (4908) Received heartbeat from "/Dorn"
    2021-10-28 18:04:45.027 - debug: ocpp.0 (4908) {}
    2021-10-28 18:04:45.028 - debug: ocpp.0 (4908) Received heartbeat from "/Dorn"
    2021-10-28 18:05:40.015 - debug: ocpp.0 (4908) {}
    2021-10-28 18:05:40.016 - debug: ocpp.0 (4908) Received heartbeat from "/Dorn"
    2021-10-28 18:06:35.028 - debug: ocpp.0 (4908) {}
    2021-10-28 18:06:35.028 - debug: ocpp.0 (4908) Received heartbeat from "/Dorn"
    2021-10-28 18:06:49.356 - debug: ocpp.0 (4908) {"connectorId":1,"transactionId":1,"meterValue":[{"sampledValue":[{"value":"1715"}],"timestamp":"2021-10-28T16:06:49Z"}]}
    2021-10-28 18:06:49.356 - info: ocpp.0 (4908) Received MeterValues from "/Dorn"
    2021-10-28 18:07:44.404 - debug: ocpp.0 (4908) {}
    2021-10-28 18:07:44.405 - debug: ocpp.0 (4908) Received heartbeat from "/Dorn"
    2021-10-28 18:08:28.524 - info: admin.0 (518) Adapter rating updated
    2021-10-28 18:08:39.407 - debug: ocpp.0 (4908) {}
    2021-10-28 18:08:39.410 - debug: ocpp.0 (4908) Received heartbeat from "/Dorn"
    2021-10-28 18:08:41.480 - info: admin.1 (533) Adapter rating updated
    2021-10-28 18:09:34.405 - debug: ocpp.0 (4908) {}
    2021-10-28 18:09:34.406 - debug: ocpp.0 (4908) Received heartbeat from "/Dorn"
    2021-10-28 18:10:29.405 - debug: ocpp.0 (4908) {}
    2021-10-28 18:10:29.405 - debug: ocpp.0 (4908) Received heartbeat from "/Dorn"
    2021-10-28 18:11:24.405 - debug: ocpp.0 (4908) {}
    2021-10-28 18:11:24.405 - debug: ocpp.0 (4908) Received heartbeat from "/Dorn"
    2021-10-28 18:12:19.405 - debug: ocpp.0 (4908) {}
    2021-10-28 18:12:19.405 - debug: ocpp.0 (4908) Received heartbeat from "/Dorn"
    2021-10-28 18:13:14.405 - debug: ocpp.0 (4908) {}
    2021-10-28 18:13:14.407 - debug: ocpp.0 (4908) Received heartbeat from "/Dorn"
    2021-10-28 18:14:09.405 - debug: ocpp.0 (4908) {}
    2021-10-28 18:14:09.406 - debug: ocpp.0 (4908) Received heartbeat from "/Dorn"
    2021-10-28 18:15:04.405 - debug: ocpp.0 (4908) {}
    2021-10-28 18:15:04.407 - debug: ocpp.0 (4908) Received heartbeat from "/Dorn"
    Message Logs
    Plug #99
    Date	Message (Response code)
    Thu Oct 28 15:54:34 2021 	Received HeartbeatConf: 2021-10-28T15:54:34+00:00
    Thu Oct 28 15:55:28 2021 	Sending HeartbeatReq
    Thu Oct 28 15:55:29 2021 	Received HeartbeatConf: 2021-10-28T15:55:29+00:00
    Thu Oct 28 15:56:23 2021 	Sending HeartbeatReq
    Thu Oct 28 15:56:24 2021 	Received TriggerMessage(BootNotification, 0) => NotImplemented
    Thu Oct 28 15:56:25 2021 	Received TriggerMessage(StatusNotification, 0) => Accepted
    Thu Oct 28 15:56:26 2021 	Received TriggerMessage(MeterValues, 0) => Accepted
    Thu Oct 28 15:56:29 2021 	Received HeartbeatConf: 2021-10-28T15:56:29+00:00
    Thu Oct 28 15:56:29 2021 	Sending MeterValues transactionId:1 Energy: 1121Wh
    Thu Oct 28 15:56:29 2021 	Received MeterValuesConf
    Thu Oct 28 15:56:29 2021 	Sending StatusNotificationReq: connectorId=1 Charging
    Thu Oct 28 15:56:29 2021 	Received StatusNotificationConf
    Thu Oct 28 15:57:24 2021 	Sending HeartbeatReq
    Thu Oct 28 15:57:25 2021 	Received HeartbeatConf: 2021-10-28T15:57:25+00:00
    Thu Oct 28 15:58:19 2021 	Sending HeartbeatReq
    Thu Oct 28 15:58:20 2021 	Received HeartbeatConf: 2021-10-28T15:58:20+00:00
    Thu Oct 28 15:59:14 2021 	Sending HeartbeatReq
    EDIT:
    Das hat er auch zwischendurch gesendet :
    2021-10-28 19:07:40.954 - debug: ocpp.0 (16756) {"chargePointVendor":"Schneider Electric","chargePointModel":"EVlink Smart Wallbox","chargePointSerialNumber":"3N204510261D2S1Bxxxxxxxxx","chargeBoxSerialNumber":"EVB1A22PCKI3N2046xxxxxxxxxxx","firmwareVersion":"3.4.0.1"}
    foxriver76F Offline
    foxriver76F Offline
    foxriver76
    @glasfaser das zwischendurch kam als BootNotification oder? Was sagt die Logzeile danach?
    Oh auf den Screenshots fallen mir mal zumindest 2 Schönheitsfehler auf.
    Videotutorials & mehr
    -1
    • foxriver76F foxriver76
      GlasfaserG Offline
      GlasfaserG Offline
      @foxriver76 sagte in Alpha Testing: OCPP Wallbox Adapter:
      immer das gleiche , da ich den Pool erst auf 900 hatte in der Wallbox , schon selber gewundert.
      Habe es umgestellt 5 s Poll , dann sendet er immer die Werte.
      Beispiel :
      Ist nur beim Adapterstart :
      2021-10-28 19:23:32.222 - info: ocpp.0 (14463) starting. Version 0.0.5 in /opt/iobroker/node_modules/iobroker.ocpp, node: v14.17.6, js-controller: 3.3.18
      2021-10-28 19:23:32.279 - info: ocpp.0 (14463) Starting OCPP Server
      2021-10-28 19:23:32.322 - info: ocpp.0 (14463) Server listening on port 9222
      2021-10-28 19:24:14.282 - info: ocpp.0 (14463) New device connected: "/Dorn"
      2021-10-28 19:24:14.284 - info: ocpp.0 (14463) Requesting BootNotification from "/Dorn"
      2021-10-28 19:24:14.543 - debug: ocpp.0 (14463) {}
      2021-10-28 19:24:14.544 - debug: ocpp.0 (14463) Received heartbeat from "/Dorn"
      2021-10-28 19:24:15.304 - info: ocpp.0 (14463) Requesting StatusNotification from "/Dorn"
      2021-10-28 19:24:16.326 - info: ocpp.0 (14463) Requesting MeterValues from "/Dorn"
      2021-10-28 19:24:17.356 - debug: ocpp.0 (14463) {"connectorId":1,"errorCode":"NoError","status":"Available","timestamp":"2021-10-28T17:24:14Z"}
      2021-10-28 19:24:17.358 - info: ocpp.0 (14463) Received Status Notification from "/Dorn": Available
        Beispiel :
        foxriver76F Offline
        foxriver76F Offline
        foxriver76
        @glasfaser Okay, kannst du den Wert von 1715 sinnvoll zuordnen? Laut Protokoll ist er nicht unbediengt festgelegt. Villt. der Verbrauch der aktuellen Transaktion, falls er mit zunehmender Ladedauer ansteigt.
        Ich habe eine neue Version gemacht, fixt paar Kleinigkeiten:
        • unnötiges Komma im info.connection state
        • Falscher Name beim availability switch
        • Evtl. nicht Ausfüllen des info.connection States bei erstmaliger Adapterausführung
        Curisoity: Kannst du dein Charger weiterhin komplett per App steuern trotz aktiviertem OCPP? Und auch schick, dass du das Intervall für das senden der Meter Daten festlegen kannst in der App.
        beste Grüße
        fox
          beste Grüße
          fox
          GlasfaserG Offline
          GlasfaserG Offline
          Noch nicht , obwohl ich alles per Modbus auslese habe ich noch nichts vergleichbares gefunden , bin noch am suchen .
          Der Hersteller Schneider Electric hat keine APP nur für die Wallbox (noch nicht) , nur eine Art Steuerzentrale über Prosumer .
          Habe ich auch , ist aber nicht das ware .
          Ich steuere meine Wallbox über ioBroker Modbus.
          siehe hier
          Über dein Update werde ich heute Abend berichten
            beste Grüße
            fox
            GlasfaserG Offline
            GlasfaserG Offline
            Instanz angehalten , Update eingespielt , Datenpunkte alle gelöscht.
            Instanz gestartet und die Datenpunkte wurden angelegt .
            Bei 2 Datenpunkt stand (null) auch bei der anschließen Ladung vom Auto.
            Bin dann jeweils in den Datenpunkt auf (null) und konnte dann true/false auswählen.
            Ja , habe es gefunden , habe wohl im falschen Register geschaut .
            Das ist die hinzugefügte Energie in Wh für " eine " Ladung 4873 Wh ( siehe Debug Log ).
            2021-10-29 14:55:23.393 - debug: ocpp.0 (26627) {}
            2021-10-29 14:55:23.404 - debug: ocpp.0 (26627) Received heartbeat from "/Dorn"
            2021-10-29 14:55:25.521 - debug: ocpp.0 (26627) {"connectorId":1,"transactionId":1,"meterValue":[{"sampledValue":[{"value":"503"}],"timestamp":"2021-10-29T12:55:24Z"}]}
            2021-10-29 14:55:25.522 - info: ocpp.0 (26627) Received MeterValues from "/Dorn"
            2021-10-29 14:56:20.780 - debug: ocpp.0 (26627) {}
            2021-10-29 14:56:20.781 - debug: ocpp.0 (26627) Received heartbeat from "/Dorn"
            2021-10-29 14:56:25.503 - debug: ocpp.0 (26627) {"connectorId":1,"transactionId":1,"meterValue":[{"sampledValue":[{"value":"560"}],"timestamp":"2021-10-29T12:56:24Z"}]}
            2021-10-29 14:56:25.505 - info: ocpp.0 (26627) Received MeterValues from "/Dorn"
            2021-10-29 14:57:23.611 - debug: ocpp.0 (26627) {}
            2021-10-29 14:57:23.613 - debug: ocpp.0 (26627) Received heartbeat from "/Dorn"
            2021-10-29 14:57:25.500 - debug: ocpp.0 (26627) {"connectorId":1,"transactionId":1,"meterValue":[{"sampledValue":[{"value":"616"}],"timestamp":"2021-10-29T12:57:24Z"}]}
            2021-10-29 14:57:25.502 - info: ocpp.0 (26627) Received MeterValues from "/Dorn"
            2021-10-29 14:58:20.642 - debug: ocpp.0 (26627) {}
            2021-10-29 14:58:20.643 - debug: ocpp.0 (26627) Received heartbeat from "/Dorn"
            2021-10-29 14:58:25.493 - debug: ocpp.0 (26627) {"connectorId":1,"transactionId":1,"meterValue":[{"sampledValue":[{"value":"673"}],"timestamp":"2021-10-29T12:58:24Z"}]}
            2021-10-29 14:58:25.496 - info: ocpp.0 (26627) Received MeterValues from "/Dorn"
            2021-10-29 14:59:23.061 - debug: ocpp.0 (26627) {}
            2021-10-29 14:59:23.063 - debug: ocpp.0 (26627) Received heartbeat from "/Dorn"
            2021-10-29 14:59:25.524 - debug: ocpp.0 (26627) {"connectorId":1,"transactionId":1,"meterValue":[{"sampledValue":[{"value":"729"}],"timestamp":"2021-10-29T12:59:25Z"}]}
            2021-10-29 14:59:25.525 - info: ocpp.0 (26627) Received MeterValues from "/Dorn"
            2021-10-29 15:00:00.167 - info: host.iobroker instance system.adapter.daswetter.0 started with pid 5770
            2021-10-29 15:00:20.609 - debug: ocpp.0 (26627) {}
            2021-10-29 15:00:20.610 - debug: ocpp.0 (26627) Received heartbeat from "/Dorn"
            2021-10-29 15:00:25.502 - debug: ocpp.0 (26627) {"connectorId":1,"transactionId":1,"meterValue":[{"sampledValue":[{"value":"786"}],"timestamp":"2021-10-29T13:00:24Z"}]}
            2021-10-29 15:00:25.503 - info: ocpp.0 (26627) Received MeterValues from "/Dorn"
            2021-10-29 15:01:23.429 - debug: ocpp.0 (26627) {}
            2021-10-29 15:01:23.429 - debug: ocpp.0 (26627) Received heartbeat from "/Dorn"
            2021-10-29 15:01:25.510 - debug: ocpp.0 (26627) {"connectorId":1,"transactionId":1,"meterValue":[{"sampledValue":[{"value":"843"}],"timestamp":"2021-10-29T13:01:24Z"}]}
            2021-10-29 15:01:25.511 - info: ocpp.0 (26627) Received MeterValues from "/Dorn"
            2021-10-29 15:02:02.223 - info: host.iobroker instance system.adapter.daswetter.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
            2021-10-29 15:02:20.589 - debug: ocpp.0 (26627) {}
            2021-10-29 15:02:20.590 - debug: ocpp.0 (26627) Received heartbeat from "/Dorn"
            2021-10-29 15:02:25.501 - debug: ocpp.0 (26627) {"connectorId":1,"transactionId":1,"meterValue":[{"sampledValue":[{"value":"899"}],"timestamp":"2021-10-29T13:02:24Z"}]}
            2021-10-29 15:02:25.502 - info: ocpp.0 (26627) Received MeterValues from "/Dorn"
            2021-10-29 15:03:23.511 - debug: ocpp.0 (26627) {}
            2021-10-29 15:03:23.512 - debug: ocpp.0 (26627) Received heartbeat from "/Dorn"
            2021-10-29 15:03:25.519 - debug: ocpp.0 (26627) {"connectorId":1,"transactionId":1,"meterValue":[{"sampledValue":[{"value":"956"}],"timestamp":"2021-10-29T13:03:24Z"}]}
            2021-10-29 15:03:25.520 - info: ocpp.0 (26627) Received MeterValues from "/Dorn"
            2021-10-29 15:04:20.579 - debug: ocpp.0 (26627) {}
            2021-10-29 15:04:20.580 - debug: ocpp.0 (26627) Received heartbeat from "/Dorn"
            2021-10-29 15:04:25.502 - debug: ocpp.0 (26627) {"connectorId":1,"transactionId":1,"meterValue":[{"sampledValue":[{"value":"1013"}],"timestamp":"2021-10-29T13:04:24Z"}]}
            2021-10-29 15:04:25.503 - info: ocpp.0 (26627) Received MeterValues from "/Dorn"
            2021-10-29 15:05:23.478 - debug: ocpp.0 (26627) {}
            2021-10-29 15:05:23.479 - debug: ocpp.0 (26627) Received heartbeat from "/Dorn"
            2021-10-29 15:05:25.503 - debug: ocpp.0 (26627) {"connectorId":1,"transactionId":1,"meterValue":[{"sampledValue":[{"value":"1069"}],"timestamp":"2021-10-29T13:05:24Z"}]}
            2021-10-29 15:05:25.503 - info: ocpp.0 (26627) Received MeterValues from "/Dorn"
            2021-10-29 15:06:20.548 - debug: ocpp.0 (26627) {}
            2021-10-29 15:06:20.549 - debug: ocpp.0 (26627) Received heartbeat from "/Dorn"
            2021-10-29 15:06:25.499 - debug: ocpp.0 (26627) {"connectorId":1,"transactionId":1,"meterValue":[{"sampledValue":[{"value":"1126"}],"timestamp":"2021-10-29T13:06:24Z"}]}
            2021-10-29 15:06:25.500 - info: ocpp.0 (26627) Received MeterValues from "/Dorn"
            2021-10-29 15:07:23.479 - debug: ocpp.0 (26627) {}
            2021-10-29 15:07:23.479 - debug: ocpp.0 (26627) Received heartbeat from "/Dorn"
            2021-10-29 15:07:25.498 - debug: ocpp.0 (26627) {"connectorId":1,"transactionId":1,"meterValue":[{"sampledValue":[{"value":"1183"}],"timestamp":"2021-10-29T13:07:24Z"}]}
            2021-10-29 15:07:25.499 - info: ocpp.0 (26627) Received MeterValues from "/Dorn"
            2021-10-29 15:08:20.548 - debug: ocpp.0 (26627) {}
            2021-10-29 15:08:20.549 - debug: ocpp.0 (26627) Received heartbeat from "/Dorn"
            2021-10-29 15:08:25.491 - debug: ocpp.0 (26627) {"connectorId":1,"transactionId":1,"meterValue":[{"sampledValue":[{"value":"1240"}],"timestamp":"2021-10-29T13:08:24Z"}]}
            2021-10-29 15:08:25.493 - info: ocpp.0 (26627) Received MeterValues from "/Dorn"
            2021-10-29 15:09:23.418 - debug: ocpp.0 (26627) {}
            2021-10-29 15:09:23.420 - debug: ocpp.0 (26627) Received heartbeat from "/Dorn"
            2021-10-29 15:09:25.501 - debug: ocpp.0 (26627) {"connectorId":1,"transactionId":1,"meterValue":[{"sampledValue":[{"value":"1296"}],"timestamp":"2021-10-29T13:09:24Z"}]}
            2021-10-29 15:09:25.501 - info: ocpp.0 (26627) Received MeterValues from "/Dorn"
            2021-10-29 15:10:20.549 - debug: ocpp.0 (26627) {}
            2021-10-29 15:10:20.549 - debug: ocpp.0 (26627) Received heartbeat from "/Dorn"
            2021-10-29 15:10:25.502 - debug: ocpp.0 (26627) {"connectorId":1,"transactionId":1,"meterValue":[{"sampledValue":[{"value":"1352"}],"timestamp":"2021-10-29T13:10:24Z"}]}
            2021-10-29 15:10:25.502 - info: ocpp.0 (26627) Received MeterValues from "/Dorn"
            2021-10-29 15:11:23.445 - debug: ocpp.0 (26627) {}
            2021-10-29 15:11:23.445 - debug: ocpp.0 (26627) Received heartbeat from "/Dorn"
            2021-10-29 15:11:25.498 - debug: ocpp.0 (26627) {"connectorId":1,"transactionId":1,"meterValue":[{"sampledValue":[{"value":"1408"}],"timestamp":"2021-10-29T13:11:24Z"}]}
            2021-10-29 15:11:25.499 - info: ocpp.0 (26627) Received MeterValues from "/Dorn"
            2021-10-29 15:12:21.360 - debug: ocpp.0 (26627) {}
            2021-10-29 15:12:21.360 - debug: ocpp.0 (26627) Received heartbeat from "/Dorn"
            2021-10-29 15:12:25.500 - debug: ocpp.0 (26627) {"connectorId":1,"transactionId":1,"meterValue":[{"sampledValue":[{"value":"1465"}],"timestamp":"2021-10-29T13:12:25Z"}]}
            2021-10-29 15:12:25.501 - info: ocpp.0 (26627) Received MeterValues from "/Dorn"
            2021-10-29 15:13:22.778 - debug: ocpp.0 (26627) {}
            2021-10-29 15:13:22.779 - debug: ocpp.0 (26627) Received heartbeat from "/Dorn"
            2021-10-29 15:13:25.498 - debug: ocpp.0 (26627) {"connectorId":1,"transactionId":1,"meterValue":[{"sampledValue":[{"value":"1521"}],"timestamp":"2021-10-29T13:13:24Z"}]}
            2021-10-29 15:13:25.498 - info: ocpp.0 (26627) Received MeterValues from "/Dorn"
            2021-10-29 15:14:20.541 - debug: ocpp.0 (26627) {}
            2021-10-29 15:14:20.541 - debug: ocpp.0 (26627) Received heartbeat from "/Dorn"
            2021-10-29 15:14:25.518 - debug: ocpp.0 (26627) {"connectorId":1,"transactionId":1,"meterValue":[{"sampledValue":[{"value":"1578"}],"timestamp":"2021-10-29T13:14:24Z"}]}
            2021-10-29 15:14:25.518 - info: ocpp.0 (26627) Received MeterValues from "/Dorn"
            2021-10-29 15:15:23.678 - debug: ocpp.0 (26627) {}
            2021-10-29 15:15:23.679 - debug: ocpp.0 (26627) Received heartbeat from "/Dorn"
            2021-10-29 15:15:25.497 - debug: ocpp.0 (26627) {"connectorId":1,"transactionId":1,"meterValue":[{"sampledValue":[{"value":"1634"}],"timestamp":"2021-10-29T13:15:24Z"}]}
            2021-10-29 15:15:25.498 - info: ocpp.0 (26627) Received MeterValues from "/Dorn"
            2021-10-29 15:16:20.548 - debug: ocpp.0 (26627) {}
            2021-10-29 15:16:20.551 - debug: ocpp.0 (26627) Received heartbeat from "/Dorn"
            2021-10-29 15:16:25.498 - debug: ocpp.0 (26627) {"connectorId":1,"transactionId":1,"meterValue":[{"sampledValue":[{"value":"1690"}],"timestamp":"2021-10-29T13:16:24Z"}]}
            2021-10-29 15:16:25.500 - info: ocpp.0 (26627) Received MeterValues from "/Dorn"
            2021-10-29 15:17:23.375 - debug: ocpp.0 (26627) {}
            2021-10-29 15:17:23.377 - debug: ocpp.0 (26627) Received heartbeat from "/Dorn"
            2021-10-29 15:17:25.507 - debug: ocpp.0 (26627) {"connectorId":1,"transactionId":1,"meterValue":[{"sampledValue":[{"value":"1747"}],"timestamp":"2021-10-29T13:17:24Z"}]}
            2021-10-29 15:17:25.508 - info: ocpp.0 (26627) Received MeterValues from "/Dorn"
            2021-10-29 15:18:20.559 - debug: ocpp.0 (26627) {}
            2021-10-29 15:18:20.559 - debug: ocpp.0 (26627) Received heartbeat from "/Dorn"
            2021-10-29 15:18:25.504 - debug: ocpp.0 (26627) {"connectorId":1,"transactionId":1,"meterValue":[{"sampledValue":[{"value":"1804"}],"timestamp":"2021-10-29T13:18:24Z"}]}
            2021-10-29 15:18:25.506 - info: ocpp.0 (26627) Received MeterValues from "/Dorn"
            2021-10-29 15:19:23.288 - debug: ocpp.0 (26627) {}
            2021-10-29 15:19:23.288 - debug: ocpp.0 (26627) Received heartbeat from "/Dorn"
            2021-10-29 15:19:25.499 - debug: ocpp.0 (26627) {"connectorId":1,"transactionId":1,"meterValue":[{"sampledValue":[{"value":"1861"}],"timestamp":"2021-10-29T13:19:25Z"}]}
            2021-10-29 15:19:25.499 - info: ocpp.0 (26627) Received MeterValues from "/Dorn"
            2021-10-29 15:20:20.547 - debug: ocpp.0 (26627) {}
            2021-10-29 15:20:20.548 - debug: ocpp.0 (26627) Received heartbeat from "/Dorn"
            2021-10-29 15:20:25.507 - debug: ocpp.0 (26627) {"connectorId":1,"transactionId":1,"meterValue":[{"sampledValue":[{"value":"1917"}],"timestamp":"2021-10-29T13:20:24Z"}]}
            2021-10-29 15:20:25.509 - info: ocpp.0 (26627) Received MeterValues from "/Dorn"
            2021-10-29 15:21:23.598 - debug: ocpp.0 (26627) {}
            2021-10-29 15:21:23.598 - debug: ocpp.0 (26627) Received heartbeat from "/Dorn"
            2021-10-29 15:21:25.497 - debug: ocpp.0 (26627) {"connectorId":1,"transactionId":1,"meterValue":[{"sampledValue":[{"value":"1973"}],"timestamp":"2021-10-29T13:21:24Z"}]}
            2021-10-29 15:21:25.497 - info: ocpp.0 (26627) Received MeterValues from "/Dorn"
            2021-10-29 15:22:20.543 - debug: ocpp.0 (26627) {}
            2021-10-29 15:22:20.544 - debug: ocpp.0 (26627) Received heartbeat from "/Dorn"
            2021-10-29 15:22:25.500 - debug: ocpp.0 (26627) {"connectorId":1,"transactionId":1,"meterValue":[{"sampledValue":[{"value":"2029"}],"timestamp":"2021-10-29T13:22:24Z"}]}
            2021-10-29 15:22:25.501 - info: ocpp.0 (26627) Received MeterValues from "/Dorn"
            2021-10-29 15:22:45.581 - info: host.iobroker stopInstance system.adapter.ocpp.0 (force=false, process=true)
            2021-10-29 15:22:45.643 - info: ocpp.0 (26627) Got terminate signal TERMINATE_YOURSELF
            2021-10-29 15:22:45.802 - info: host.iobroker stopInstance system.adapter.ocpp.0 send kill signal
            2021-10-29 15:22:45.869 - info: ocpp.0 (26627) terminating
            2021-10-29 15:22:45.871 - info: ocpp.0 (26627) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
            2021-10-29 15:22:46.804 - info: host.iobroker instance system.adapter.ocpp.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
            2021-10-29 15:22:54.771 - info: host.iobroker instance system.adapter.ocpp.0 started with pid 9927
            2021-10-29 15:22:57.636 - debug: ocpp.0 (9927) Redis Objects: Use Redis connection: 127.0.0.1:9001
            2021-10-29 15:22:57.765 - debug: ocpp.0 (9927) Objects client ready ... initialize now
            2021-10-29 15:22:57.815 - debug: ocpp.0 (9927) Objects create System PubSub Client
            2021-10-29 15:22:57.817 - debug: ocpp.0 (9927) Objects create User PubSub Client
            2021-10-29 15:22:57.823 - debug: ocpp.0 (9927) Objects client initialize lua scripts
            2021-10-29 15:22:57.984 - debug: ocpp.0 (9927) Objects connected to redis: 127.0.0.1:9001
            2021-10-29 15:22:57.998 - debug: ocpp.0 (9927) objectDB connected
            2021-10-29 15:22:58.001 - debug: ocpp.0 (9927) Redis States: Use Redis connection: 127.0.0.1:9000
            2021-10-29 15:22:58.106 - debug: ocpp.0 (9927) States create System PubSub Client
            2021-10-29 15:22:58.108 - debug: ocpp.0 (9927) States create User PubSub Client
            2021-10-29 15:22:58.277 - debug: ocpp.0 (9927) States connected to redis: 127.0.0.1:9000
            2021-10-29 15:22:58.280 - debug: ocpp.0 (9927) statesDB connected
            2021-10-29 15:23:02.750 - info: ocpp.0 (9927) starting. Version 0.0.6 in /opt/iobroker/node_modules/iobroker.ocpp, node: v14.17.6, js-controller: 3.3.18
            2021-10-29 15:23:02.794 - info: ocpp.0 (9927) Starting OCPP Server
            2021-10-29 15:23:03.259 - info: ocpp.0 (9927) Server listening on port 9220
            2021-10-29 15:23:24.811 - info: ocpp.0 (9927) New device connected: "/Dorn"
            2021-10-29 15:23:24.826 - info: ocpp.0 (9927) Requesting BootNotification from "/Dorn"
            2021-10-29 15:23:25.266 - debug: ocpp.0 (9927) {}
            2021-10-29 15:23:25.267 - debug: ocpp.0 (9927) Received heartbeat from "/Dorn"
            2021-10-29 15:23:25.502 - debug: ocpp.0 (9927) {"connectorId":1,"transactionId":1,"meterValue":[{"sampledValue":[{"value":"2086"}],"timestamp":"2021-10-29T13:23:25Z"}]}
            2021-10-29 15:23:25.503 - info: ocpp.0 (9927) Received MeterValues from "/Dorn"
            2021-10-29 15:23:25.858 - info: ocpp.0 (9927) Requesting StatusNotification from "/Dorn"
            2021-10-29 15:23:26.875 - info: ocpp.0 (9927) Requesting MeterValues from "/Dorn"
            2021-10-29 15:23:27.018 - debug: ocpp.0 (9927) {"connectorId":1,"transactionId":1,"meterValue":[{"sampledValue":[{"value":"2088"}],"timestamp":"2021-10-29T13:23:26Z"}]}
            2021-10-29 15:23:27.021 - info: ocpp.0 (9927) Received MeterValues from "/Dorn"
            2021-10-29 15:23:27.900 - debug: ocpp.0 (9927) {"connectorId":1,"errorCode":"NoError","status":"Charging","timestamp":"2021-10-29T13:23:25Z"}
            2021-10-29 15:23:27.909 - info: ocpp.0 (9927) Received Status Notification from "/Dorn": Charging
            2021-10-29 15:24:22.888 - debug: ocpp.0 (9927) {}
            2021-10-29 15:24:22.889 - debug: ocpp.0 (9927) Received heartbeat from "/Dorn"
            2021-10-29 15:24:25.525 - debug: ocpp.0 (9927) {"connectorId":1,"transactionId":1,"meterValue":[{"sampledValue":[{"value":"2142"}],"timestamp":"2021-10-29T13:24:24Z"}]}
            2021-10-29 15:24:25.527 - info: ocpp.0 (9927) Received MeterValues from "/Dorn"
            2021-10-29 15:25:23.227 - debug: ocpp.0 (9927) {}
            2021-10-29 15:25:23.228 - debug: ocpp.0 (9927) Received heartbeat from "/Dorn"
            2021-10-29 15:25:25.498 - debug: ocpp.0 (9927) {"connectorId":1,"transactionId":1,"meterValue":[{"sampledValue":[{"value":"2199"}],"timestamp":"2021-10-29T13:25:25Z"}]}
            2021-10-29 15:25:25.499 - info: ocpp.0 (9927) Received MeterValues from "/Dorn"
            2021-10-29 15:26:20.567 - debug: ocpp.0 (9927) {}
            2021-10-29 15:26:20.567 - debug: ocpp.0 (9927) Received heartbeat from "/Dorn"
            2021-10-29 15:26:25.500 - debug: ocpp.0 (9927) {"connectorId":1,"transactionId":1,"meterValue":[{"sampledValue":[{"value":"2256"}],"timestamp":"2021-10-29T13:26:24Z"}]}
            2021-10-29 15:26:25.501 - info: ocpp.0 (9927) Received MeterValues from "/Dorn"
            2021-10-29 15:27:23.877 - debug: ocpp.0 (9927) {}
            2021-10-29 15:27:23.878 - debug: ocpp.0 (9927) Received heartbeat from "/Dorn"
            2021-10-29 15:27:25.492 - debug: ocpp.0 (9927) {"connectorId":1,"transactionId":1,"meterValue":[{"sampledValue":[{"value":"2312"}],"timestamp":"2021-10-29T13:27:24Z"}]}
            2021-10-29 15:27:25.493 - info: ocpp.0 (9927) Received MeterValues from "/Dorn"
            2021-10-29 15:28:20.540 - debug: ocpp.0 (9927) {}
            2021-10-29 15:28:20.540 - debug: ocpp.0 (9927) Received heartbeat from "/Dorn"
            2021-10-29 15:28:25.511 - debug: ocpp.0 (9927) {"connectorId":1,"transactionId":1,"meterValue":[{"sampledValue":[{"value":"2368"}],"timestamp":"2021-10-29T13:28:24Z"}]}
            2021-10-29 15:28:25.516 - info: ocpp.0 (9927) Received MeterValues from "/Dorn"
            2021-10-29 15:29:20.807 - debug: ocpp.0 (9927) {}
            2021-10-29 15:29:20.808 - debug: ocpp.0 (9927) Received heartbeat from "/Dorn"
            2021-10-29 15:29:25.498 - debug: ocpp.0 (9927) {"connectorId":1,"transactionId":1,"meterValue":[{"sampledValue":[{"value":"2425"}],"timestamp":"2021-10-29T13:29:24Z"}]}
            2021-10-29 15:29:25.501 - info: ocpp.0 (9927) Received MeterValues from "/Dorn"
            2021-10-29 15:30:20.597 - debug: ocpp.0 (9927) {}
            2021-10-29 15:30:20.598 - debug: ocpp.0 (9927) Received heartbeat from "/Dorn"
            2021-10-29 15:30:25.497 - debug: ocpp.0 (9927) {"connectorId":1,"transactionId":1,"meterValue":[{"sampledValue":[{"value":"2481"}],"timestamp":"2021-10-29T13:30:24Z"}]}
            2021-10-29 15:30:25.498 - info: ocpp.0 (9927) Received MeterValues from "/Dorn"
            2021-10-29 15:31:23.896 - debug: ocpp.0 (9927) {}
            2021-10-29 15:31:23.897 - debug: ocpp.0 (9927) Received heartbeat from "/Dorn"
            2021-10-29 15:31:25.498 - debug: ocpp.0 (9927) {"connectorId":1,"transactionId":1,"meterValue":[{"sampledValue":[{"value":"2538"}],"timestamp":"2021-10-29T13:31:24Z"}]}
            2021-10-29 15:31:25.499 - info: ocpp.0 (9927) Received MeterValues from "/Dorn"
            2021-10-29 15:32:20.547 - debug: ocpp.0 (9927) {}
            2021-10-29 15:32:20.549 - debug: ocpp.0 (9927) Received heartbeat from "/Dorn"
            2021-10-29 15:32:25.489 - debug: ocpp.0 (9927) {"connectorId":1,"transactionId":1,"meterValue":[{"sampledValue":[{"value":"2594"}],"timestamp":"2021-10-29T13:32:24Z"}]}
            2021-10-29 15:32:25.490 - info: ocpp.0 (9927) Received MeterValues from "/Dorn"
            2021-10-29 15:33:24.006 - debug: ocpp.0 (9927) {}
            2021-10-29 15:33:24.007 - debug: ocpp.0 (9927) Received heartbeat from "/Dorn"
            2021-10-29 15:33:25.498 - debug: ocpp.0 (9927) {"connectorId":1,"transactionId":1,"meterValue":[{"sampledValue":[{"value":"2651"}],"timestamp":"2021-10-29T13:33:25Z"}]}
            2021-10-29 15:33:25.498 - info: ocpp.0 (9927) Received MeterValues from "/Dorn"
            2021-10-29 15:34:20.616 - debug: ocpp.0 (9927) {}
            2021-10-29 15:34:20.617 - debug: ocpp.0 (9927) Received heartbeat from "/Dorn"
            2021-10-29 15:34:25.494 - debug: ocpp.0 (9927) {"connectorId":1,"transactionId":1,"meterValue":[{"sampledValue":[{"value":"2707"}],"timestamp":"2021-10-29T13:34:24Z"}]}
            2021-10-29 15:34:25.495 - info: ocpp.0 (9927) Received MeterValues from "/Dorn"
            2021-10-29 15:35:23.587 - debug: ocpp.0 (9927) {}
            2021-10-29 15:35:23.587 - debug: ocpp.0 (9927) Received heartbeat from "/Dorn"
            2021-10-29 15:35:25.516 - debug: ocpp.0 (9927) {"connectorId":1,"transactionId":1,"meterValue":[{"sampledValue":[{"value":"2763"}],"timestamp":"2021-10-29T13:35:24Z"}]}
            2021-10-29 15:35:25.516 - info: ocpp.0 (9927) Received MeterValues from "/Dorn"
            2021-10-29 15:36:20.578 - debug: ocpp.0 (9927) {}
            2021-10-29 15:36:20.579 - debug: ocpp.0 (9927) Received heartbeat from "/Dorn"
            2021-10-29 15:36:25.496 - debug: ocpp.0 (9927) {"connectorId":1,"transactionId":1,"meterValue":[{"sampledValue":[{"value":"2820"}],"timestamp":"2021-10-29T13:36:24Z"}]}
            2021-10-29 15:36:25.497 - info: ocpp.0 (9927) Received MeterValues from "/Dorn"
            2021-10-29 15:37:23.877 - debug: ocpp.0 (9927) {}
            2021-10-29 15:37:23.881 - debug: ocpp.0 (9927) Received heartbeat from "/Dorn"
            2021-10-29 15:37:25.499 - debug: ocpp.0 (9927) {"connectorId":1,"transactionId":1,"meterValue":[{"sampledValue":[{"value":"2876"}],"timestamp":"2021-10-29T13:37:24Z"}]}
            2021-10-29 15:37:25.500 - info: ocpp.0 (9927) Received MeterValues from "/Dorn"
            2021-10-29 15:38:20.538 - debug: ocpp.0 (9927) {}
            2021-10-29 15:38:20.539 - debug: ocpp.0 (9927) Received heartbeat from "/Dorn"
            2021-10-29 15:38:25.500 - debug: ocpp.0 (9927) {"connectorId":1,"transactionId":1,"meterValue":[{"sampledValue":[{"value":"2933"}],"timestamp":"2021-10-29T13:38:24Z"}]}
            2021-10-29 15:38:25.502 - info: ocpp.0 (9927) Received MeterValues from "/Dorn"
            2021-10-29 15:39:23.557 - debug: ocpp.0 (9927) {}
            2021-10-29 15:39:23.558 - debug: ocpp.0 (9927) Received heartbeat from "/Dorn"
            2021-10-29 15:39:25.509 - debug: ocpp.0 (9927) {"connectorId":1,"transactionId":1,"meterValue":[{"sampledValue":[{"value":"2990"}],"timestamp":"2021-10-29T13:39:24Z"}]}
            2021-10-29 15:39:25.510 - info: ocpp.0 (9927) Received MeterValues from "/Dorn"
            2021-10-29 15:40:20.566 - debug: ocpp.0 (9927) {}
            2021-10-29 15:40:20.567 - debug: ocpp.0 (9927) Received heartbeat from "/Dorn"
            2021-10-29 15:40:25.505 - debug: ocpp.0 (9927) {"connectorId":1,"transactionId":1,"meterValue":[{"sampledValue":[{"value":"3047"}],"timestamp":"2021-10-29T13:40:24Z"}]}
            2021-10-29 15:40:25.505 - info: ocpp.0 (9927) Received MeterValues from "/Dorn"
            2021-10-29 15:41:20.586 - debug: ocpp.0 (9927) {}
            2021-10-29 15:41:20.587 - debug: ocpp.0 (9927) Received heartbeat from "/Dorn"
            2021-10-29 15:41:25.503 - debug: ocpp.0 (9927) {"connectorId":1,"transactionId":1,"meterValue":[{"sampledValue":[{"value":"3103"}],"timestamp":"2021-10-29T13:41:24Z"}]}
            2021-10-29 15:41:25.505 - info: ocpp.0 (9927) Received MeterValues from "/Dorn"
            2021-10-29 15:42:20.576 - debug: ocpp.0 (9927) {}
            2021-10-29 15:42:20.577 - debug: ocpp.0 (9927) Received heartbeat from "/Dorn"
            2021-10-29 15:42:25.498 - debug: ocpp.0 (9927) {"connectorId":1,"transactionId":1,"meterValue":[{"sampledValue":[{"value":"3160"}],"timestamp":"2021-10-29T13:42:24Z"}]}
            2021-10-29 15:42:25.499 - info: ocpp.0 (9927) Received MeterValues from "/Dorn"
            2021-10-29 15:43:23.258 - debug: ocpp.0 (9927) {}
            2021-10-29 15:43:23.259 - debug: ocpp.0 (9927) Received heartbeat from "/Dorn"
            2021-10-29 15:43:25.496 - debug: ocpp.0 (9927) {"connectorId":1,"transactionId":1,"meterValue":[{"sampledValue":[{"value":"3216"}],"timestamp":"2021-10-29T13:43:25Z"}]}
            2021-10-29 15:43:25.497 - info: ocpp.0 (9927) Received MeterValues from "/Dorn"
            2021-10-29 15:44:20.548 - debug: ocpp.0 (9927) {}
            2021-10-29 15:44:20.549 - debug: ocpp.0 (9927) Received heartbeat from "/Dorn"
            2021-10-29 15:44:25.495 - debug: ocpp.0 (9927) {"connectorId":1,"transactionId":1,"meterValue":[{"sampledValue":[{"value":"3273"}],"timestamp":"2021-10-29T13:44:24Z"}]}
            2021-10-29 15:44:25.496 - info: ocpp.0 (9927) Received MeterValues from "/Dorn"
            2021-10-29 15:45:23.358 - debug: ocpp.0 (9927) {}
            2021-10-29 15:45:23.359 - debug: ocpp.0 (9927) Received heartbeat from "/Dorn"
            2021-10-29 15:45:25.500 - debug: ocpp.0 (9927) {"connectorId":1,"transactionId":1,"meterValue":[{"sampledValue":[{"value":"3329"}],"timestamp":"2021-10-29T13:45:25Z"}]}
            2021-10-29 15:45:25.500 - info: ocpp.0 (9927) Received MeterValues from "/Dorn"
            2021-10-29 15:46:20.545 - debug: ocpp.0 (9927) {}
            2021-10-29 15:46:20.545 - debug: ocpp.0 (9927) Received heartbeat from "/Dorn"
            2021-10-29 15:46:25.546 - debug: ocpp.0 (9927) {"connectorId":1,"transactionId":1,"meterValue":[{"sampledValue":[{"value":"3385"}],"timestamp":"2021-10-29T13:46:24Z"}]}
            2021-10-29 15:46:25.550 - info: ocpp.0 (9927) Received MeterValues from "/Dorn"
            2021-10-29 15:47:23.539 - debug: ocpp.0 (9927) {}
            2021-10-29 15:47:23.540 - debug: ocpp.0 (9927) Received heartbeat from "/Dorn"
            2021-10-29 15:47:25.497 - debug: ocpp.0 (9927) {"connectorId":1,"transactionId":1,"meterValue":[{"sampledValue":[{"value":"3442"}],"timestamp":"2021-10-29T13:47:24Z"}]}
            2021-10-29 15:47:25.498 - info: ocpp.0 (9927) Received MeterValues from "/Dorn"
            2021-10-29 15:48:20.565 - debug: ocpp.0 (9927) {}
            2021-10-29 15:48:20.566 - debug: ocpp.0 (9927) Received heartbeat from "/Dorn"
            2021-10-29 15:48:25.496 - debug: ocpp.0 (9927) {"connectorId":1,"transactionId":1,"meterValue":[{"sampledValue":[{"value":"3499"}],"timestamp":"2021-10-29T13:48:24Z"}]}
            2021-10-29 15:48:25.496 - info: ocpp.0 (9927) Received MeterValues from "/Dorn"
            2021-10-29 15:49:23.538 - debug: ocpp.0 (9927) {}
            2021-10-29 15:49:23.538 - debug: ocpp.0 (9927) Received heartbeat from "/Dorn"
            2021-10-29 15:49:25.499 - debug: ocpp.0 (9927) {"connectorId":1,"transactionId":1,"meterValue":[{"sampledValue":[{"value":"3556"}],"timestamp":"2021-10-29T13:49:24Z"}]}
            2021-10-29 15:49:25.500 - info: ocpp.0 (9927) Received MeterValues from "/Dorn"
            2021-10-29 15:50:20.558 - debug: ocpp.0 (9927) {}
            2021-10-29 15:50:20.559 - debug: ocpp.0 (9927) Received heartbeat from "/Dorn"
            2021-10-29 15:50:25.656 - debug: ocpp.0 (9927) {"connectorId":1,"transactionId":1,"meterValue":[{"sampledValue":[{"value":"3612"}],"timestamp":"2021-10-29T13:50:24Z"}]}
            2021-10-29 15:50:25.656 - info: ocpp.0 (9927) Received MeterValues from "/Dorn"
            2021-10-29 15:51:23.495 - debug: ocpp.0 (9927) {}
            2021-10-29 15:51:23.496 - debug: ocpp.0 (9927) Received heartbeat from "/Dorn"
            2021-10-29 15:51:25.505 - debug: ocpp.0 (9927) {"connectorId":1,"transactionId":1,"meterValue":[{"sampledValue":[{"value":"3669"}],"timestamp":"2021-10-29T13:51:24Z"}]}
            2021-10-29 15:51:25.505 - info: ocpp.0 (9927) Received MeterValues from "/Dorn"
            2021-10-29 15:52:20.645 - debug: ocpp.0 (9927) {}
            2021-10-29 15:52:20.646 - debug: ocpp.0 (9927) Received heartbeat from "/Dorn"
            2021-10-29 15:52:25.497 - debug: ocpp.0 (9927) {"connectorId":1,"transactionId":1,"meterValue":[{"sampledValue":[{"value":"3725"}],"timestamp":"2021-10-29T13:52:24Z"}]}
            2021-10-29 15:52:25.499 - info: ocpp.0 (9927) Received MeterValues from "/Dorn"
            2021-10-29 15:53:23.426 - debug: ocpp.0 (9927) {}
            2021-10-29 15:53:23.426 - debug: ocpp.0 (9927) Received heartbeat from "/Dorn"
            2021-10-29 15:53:25.538 - debug: ocpp.0 (9927) {"connectorId":1,"transactionId":1,"meterValue":[{"sampledValue":[{"value":"3782"}],"timestamp":"2021-10-29T13:53:24Z"}]}
            2021-10-29 15:53:25.539 - info: ocpp.0 (9927) Received MeterValues from "/Dorn"
            2021-10-29 15:54:20.595 - debug: ocpp.0 (9927) {}
            2021-10-29 15:54:20.597 - debug: ocpp.0 (9927) Received heartbeat from "/Dorn"
            2021-10-29 15:54:25.496 - debug: ocpp.0 (9927) {"connectorId":1,"transactionId":1,"meterValue":[{"sampledValue":[{"value":"3838"}],"timestamp":"2021-10-29T13:54:24Z"}]}
            2021-10-29 15:54:25.497 - info: ocpp.0 (9927) Received MeterValues from "/Dorn"
            2021-10-29 15:55:24.315 - debug: ocpp.0 (9927) {}
            2021-10-29 15:55:24.316 - debug: ocpp.0 (9927) Received heartbeat from "/Dorn"
            2021-10-29 15:55:25.506 - debug: ocpp.0 (9927) {"connectorId":1,"transactionId":1,"meterValue":[{"sampledValue":[{"value":"3895"}],"timestamp":"2021-10-29T13:55:25Z"}]}
            2021-10-29 15:55:25.507 - info: ocpp.0 (9927) Received MeterValues from "/Dorn"
            2021-10-29 15:56:20.565 - debug: ocpp.0 (9927) {}
            2021-10-29 15:56:20.566 - debug: ocpp.0 (9927) Received heartbeat from "/Dorn"
            2021-10-29 15:56:25.488 - debug: ocpp.0 (9927) {"connectorId":1,"transactionId":1,"meterValue":[{"sampledValue":[{"value":"3952"}],"timestamp":"2021-10-29T13:56:24Z"}]}
            2021-10-29 15:56:25.488 - info: ocpp.0 (9927) Received MeterValues from "/Dorn"
            2021-10-29 15:57:20.909 - debug: ocpp.0 (9927) {}
            2021-10-29 15:57:20.917 - debug: ocpp.0 (9927) Received heartbeat from "/Dorn"
            2021-10-29 15:57:25.495 - debug: ocpp.0 (9927) {"connectorId":1,"transactionId":1,"meterValue":[{"sampledValue":[{"value":"4009"}],"timestamp":"2021-10-29T13:57:24Z"}]}
            2021-10-29 15:57:25.496 - info: ocpp.0 (9927) Received MeterValues from "/Dorn"
            2021-10-29 15:58:20.565 - debug: ocpp.0 (9927) {}
            2021-10-29 15:58:20.565 - debug: ocpp.0 (9927) Received heartbeat from "/Dorn"
            2021-10-29 15:58:25.538 - debug: ocpp.0 (9927) {"connectorId":1,"transactionId":1,"meterValue":[{"sampledValue":[{"value":"4066"}],"timestamp":"2021-10-29T13:58:24Z"}]}
            2021-10-29 15:58:25.540 - info: ocpp.0 (9927) Received MeterValues from "/Dorn"
            2021-10-29 15:59:23.355 - debug: ocpp.0 (9927) {}
            2021-10-29 15:59:23.356 - debug: ocpp.0 (9927) Received heartbeat from "/Dorn"
            2021-10-29 15:59:25.501 - debug: ocpp.0 (9927) {"connectorId":1,"transactionId":1,"meterValue":[{"sampledValue":[{"value":"4123"}],"timestamp":"2021-10-29T13:59:25Z"}]}
            2021-10-29 15:59:25.503 - info: ocpp.0 (9927) Received MeterValues from "/Dorn"
            2021-10-29 16:00:20.546 - debug: ocpp.0 (9927) {}
            2021-10-29 16:00:20.547 - debug: ocpp.0 (9927) Received heartbeat from "/Dorn"
            2021-10-29 16:00:25.500 - debug: ocpp.0 (9927) {"connectorId":1,"transactionId":1,"meterValue":[{"sampledValue":[{"value":"4180"}],"timestamp":"2021-10-29T14:00:24Z"}]}
            2021-10-29 16:00:25.502 - info: ocpp.0 (9927) Received MeterValues from "/Dorn"
            2021-10-29 16:01:23.838 - debug: ocpp.0 (9927) {}
            2021-10-29 16:01:23.839 - debug: ocpp.0 (9927) Received heartbeat from "/Dorn"
            2021-10-29 16:01:25.488 - debug: ocpp.0 (9927) {"connectorId":1,"transactionId":1,"meterValue":[{"sampledValue":[{"value":"4237"}],"timestamp":"2021-10-29T14:01:24Z"}]}
            2021-10-29 16:01:25.488 - info: ocpp.0 (9927) Received MeterValues from "/Dorn"
            2021-10-29 16:02:20.525 - debug: ocpp.0 (9927) {}
            2021-10-29 16:02:20.526 - debug: ocpp.0 (9927) Received heartbeat from "/Dorn"
            2021-10-29 16:02:25.498 - debug: ocpp.0 (9927) {"connectorId":1,"transactionId":1,"meterValue":[{"sampledValue":[{"value":"4293"}],"timestamp":"2021-10-29T14:02:24Z"}]}
            2021-10-29 16:02:25.499 - info: ocpp.0 (9927) Received MeterValues from "/Dorn"
            2021-10-29 16:03:23.685 - debug: ocpp.0 (9927) {}
            2021-10-29 16:03:23.686 - debug: ocpp.0 (9927) Received heartbeat from "/Dorn"
            2021-10-29 16:03:25.577 - debug: ocpp.0 (9927) {"connectorId":1,"transactionId":1,"meterValue":[{"sampledValue":[{"value":"4350"}],"timestamp":"2021-10-29T14:03:24Z"}]}
            2021-10-29 16:03:25.579 - info: ocpp.0 (9927) Received MeterValues from "/Dorn"
            2021-10-29 16:04:20.658 - debug: ocpp.0 (9927) {}
            2021-10-29 16:04:20.658 - debug: ocpp.0 (9927) Received heartbeat from "/Dorn"
            2021-10-29 16:04:25.499 - debug: ocpp.0 (9927) {"connectorId":1,"transactionId":1,"meterValue":[{"sampledValue":[{"value":"4407"}],"timestamp":"2021-10-29T14:04:24Z"}]}
            2021-10-29 16:04:25.500 - info: ocpp.0 (9927) Received MeterValues from "/Dorn"
            2021-10-29 16:05:23.304 - debug: ocpp.0 (9927) {}
            2021-10-29 16:05:23.304 - debug: ocpp.0 (9927) Received heartbeat from "/Dorn"
            2021-10-29 16:05:25.505 - debug: ocpp.0 (9927) {"connectorId":1,"transactionId":1,"meterValue":[{"sampledValue":[{"value":"4464"}],"timestamp":"2021-10-29T14:05:25Z"}]}
            2021-10-29 16:05:25.506 - info: ocpp.0 (9927) Received MeterValues from "/Dorn"
            2021-10-29 16:06:20.555 - debug: ocpp.0 (9927) {}
            2021-10-29 16:06:20.556 - debug: ocpp.0 (9927) Received heartbeat from "/Dorn"
            2021-10-29 16:06:25.512 - debug: ocpp.0 (9927) {"connectorId":1,"transactionId":1,"meterValue":[{"sampledValue":[{"value":"4521"}],"timestamp":"2021-10-29T14:06:24Z"}]}
            2021-10-29 16:06:25.514 - info: ocpp.0 (9927) Received MeterValues from "/Dorn"
            2021-10-29 16:07:25.502 - debug: ocpp.0 (9927) {"connectorId":1,"transactionId":1,"meterValue":[{"sampledValue":[{"value":"4578"}],"timestamp":"2021-10-29T14:07:24Z"}]}
            2021-10-29 16:07:25.503 - info: ocpp.0 (9927) Received MeterValues from "/Dorn"
            2021-10-29 16:07:29.156 - debug: ocpp.0 (9927) {}
            2021-10-29 16:07:29.159 - debug: ocpp.0 (9927) Received heartbeat from "/Dorn"
            2021-10-29 16:08:24.146 - debug: ocpp.0 (9927) {}
            2021-10-29 16:08:24.148 - debug: ocpp.0 (9927) Received heartbeat from "/Dorn"
            2021-10-29 16:08:25.506 - debug: ocpp.0 (9927) {"connectorId":1,"transactionId":1,"meterValue":[{"sampledValue":[{"value":"4635"}],"timestamp":"2021-10-29T14:08:25Z"}]}
            2021-10-29 16:08:25.506 - info: ocpp.0 (9927) Received MeterValues from "/Dorn"
            2021-10-29 16:09:25.499 - debug: ocpp.0 (9927) {"connectorId":1,"transactionId":1,"meterValue":[{"sampledValue":[{"value":"4691"}],"timestamp":"2021-10-29T14:09:25Z"}]}
            2021-10-29 16:09:25.500 - info: ocpp.0 (9927) Received MeterValues from "/Dorn"
            2021-10-29 16:10:20.585 - debug: ocpp.0 (9927) {}
            2021-10-29 16:10:20.585 - debug: ocpp.0 (9927) Received heartbeat from "/Dorn"
            2021-10-29 16:10:25.515 - debug: ocpp.0 (9927) {"connectorId":1,"transactionId":1,"meterValue":[{"sampledValue":[{"value":"4745"}],"timestamp":"2021-10-29T14:10:24Z"}]}
            2021-10-29 16:10:25.517 - info: ocpp.0 (9927) Received MeterValues from "/Dorn"
            2021-10-29 16:11:25.498 - debug: ocpp.0 (9927) {"connectorId":1,"transactionId":1,"meterValue":[{"sampledValue":[{"value":"4787"}],"timestamp":"2021-10-29T14:11:24Z"}]}
            2021-10-29 16:11:25.498 - info: ocpp.0 (9927) Received MeterValues from "/Dorn"
            2021-10-29 16:12:20.535 - debug: ocpp.0 (9927) {}
            2021-10-29 16:12:20.536 - debug: ocpp.0 (9927) Received heartbeat from "/Dorn"
            2021-10-29 16:12:25.499 - debug: ocpp.0 (9927) {"connectorId":1,"transactionId":1,"meterValue":[{"sampledValue":[{"value":"4824"}],"timestamp":"2021-10-29T14:12:24Z"}]}
            2021-10-29 16:12:25.500 - info: ocpp.0 (9927) Received MeterValues from "/Dorn"
            2021-10-29 16:13:24.726 - debug: ocpp.0 (9927) {}
            2021-10-29 16:13:24.728 - debug: ocpp.0 (9927) Received heartbeat from "/Dorn"
            2021-10-29 16:13:25.500 - debug: ocpp.0 (9927) {"connectorId":1,"transactionId":1,"meterValue":[{"sampledValue":[{"value":"4854"}],"timestamp":"2021-10-29T14:13:24Z"}]}
            2021-10-29 16:13:25.501 - info: ocpp.0 (9927) Received MeterValues from "/Dorn"
            2021-10-29 16:14:20.564 - debug: ocpp.0 (9927) {}
            2021-10-29 16:14:20.565 - debug: ocpp.0 (9927) Received heartbeat from "/Dorn"
            2021-10-29 16:14:25.526 - debug: ocpp.0 (9927) {"connectorId":1,"transactionId":1,"meterValue":[{"sampledValue":[{"value":"4873"}],"timestamp":"2021-10-29T14:14:24Z"}]}
            2021-10-29 16:14:25.527 - info: ocpp.0 (9927) Received MeterValues from "/Dorn"
            2021-10-29 16:14:27.762 - info: javascript.0 (540) script.js.Strommessung.Wallbox: -Wallbox- 88 Minuten / 5.04 kWh / 1.41 € -Wallbox-
            2021-10-29 16:14:56.369 - debug: ocpp.0 (9927) {"connectorId":1,"errorCode":"NoError","status":"SuspendedEV","timestamp":"2021-10-29T14:14:53Z"}
            2021-10-29 16:14:56.369 - info: ocpp.0 (9927) Received Status Notification from "/Dorn": SuspendedEV
            2021-10-29 16:15:25.496 - debug: ocpp.0 (9927) {"connectorId":1,"transactionId":1,"meterValue":[{"sampledValue":[{"value":"4873"}],"timestamp":"2021-10-29T14:15:24Z"}]}
            2021-10-29 16:15:25.496 - info: ocpp.0 (9927) Received MeterValues from "/Dorn"
            2021-10-29 16:16:20.524 - debug: ocpp.0 (9927) {}
            2021-10-29 16:16:20.525 - debug: ocpp.0 (9927) Received heartbeat from "/Dorn"
            2021-10-29 16:16:25.498 - debug: ocpp.0 (9927) {"connectorId":1,"transactionId":1,"meterValue":[{"sampledValue":[{"value":"4873"}],"timestamp":"2021-10-29T14:16:24Z"}]}
            2021-10-29 16:16:25.499 - info: ocpp.0 (9927) Received MeterValues from "/Dorn"
            2021-10-29 16:17:23.294 - debug: ocpp.0 (9927) {}
            2021-10-29 16:17:23.295 - debug: ocpp.0 (9927) Received heartbeat from "/Dorn"
            2021-10-29 16:17:25.495 - debug: ocpp.0 (9927) {"connectorId":1,"transactionId":1,"meterValue":[{"sampledValue":[{"value":"4873"}],"timestamp":"2021-10-29T14:17:25Z"}]}
            2021-10-29 16:17:25.496 - info: ocpp.0 (9927) Received MeterValues from "/Dorn"
            2021-10-29 16:18:20.534 - debug: ocpp.0 (9927) {}
            2021-10-29 16:18:20.535 - debug: ocpp.0 (9927) Received heartbeat from "/Dorn"
            2021-10-29 16:18:25.496 - debug: ocpp.0 (9927) {"connectorId":1,"transactionId":1,"meterValue":[{"sampledValue":[{"value":"4873"}],"timestamp":"2021-10-29T14:18:24Z"}]}
            2021-10-29 16:18:25.496 - info: ocpp.0 (9927) Received MeterValues from "/Dorn"
            2021-10-29 16:19:23.404 - debug: ocpp.0 (9927) {}
            2021-10-29 16:19:23.406 - debug: ocpp.0 (9927) Received heartbeat from "/Dorn"
            2021-10-29 16:19:25.499 - debug: ocpp.0 (9927) {"connectorId":1,"transactionId":1,"meterValue":[{"sampledValue":[{"value":"4873"}],"timestamp":"2021-10-29T14:19:24Z"}]}
            2021-10-29 16:19:25.500 - info: ocpp.0 (9927) Received MeterValues from "/Dorn"
            2021-10-29 16:20:20.594 - debug: ocpp.0 (9927) {}
            2021-10-29 16:20:20.595 - debug: ocpp.0 (9927) Received heartbeat from "/Dorn"
            2021-10-29 16:20:25.495 - debug: ocpp.0 (9927) {"connectorId":1,"transactionId":1,"meterValue":[{"sampledValue":[{"value":"4873"}],"timestamp":"2021-10-29T14:20:24Z"}]}
            2021-10-29 16:20:25.496 - info: ocpp.0 (9927) Received MeterValues from "/Dorn"
            2021-10-29 16:21:21.354 - debug: ocpp.0 (9927) {}
            2021-10-29 16:21:21.355 - debug: ocpp.0 (9927) Received heartbeat from "/Dorn"
            2021-10-29 16:21:25.494 - debug: ocpp.0 (9927) {"connectorId":1,"transactionId":1,"meterValue":[{"sampledValue":[{"value":"4873"}],"timestamp":"2021-10-29T14:21:25Z"}]}
            2021-10-29 16:21:25.495 - info: ocpp.0 (9927) Received MeterValues from "/Dorn"
            2021-10-29 16:22:20.534 - debug: ocpp.0 (9927) {}
            2021-10-29 16:22:20.536 - debug: ocpp.0 (9927) Received heartbeat from "/Dorn"
            2021-10-29 16:22:25.494 - debug: ocpp.0 (9927) {"connectorId":1,"transactionId":1,"meterValue":[{"sampledValue":[{"value":"4873"}],"timestamp":"2021-10-29T14:22:24Z"}]}
            2021-10-29 16:22:25.495 - info: ocpp.0 (9927) Received MeterValues from "/Dorn"
            2021-10-29 16:23:23.835 - debug: ocpp.0 (9927) {}
            2021-10-29 16:23:23.836 - debug: ocpp.0 (9927) Received heartbeat from "/Dorn"
            2021-10-29 16:23:25.506 - debug: ocpp.0 (9927) {"connectorId":1,"transactionId":1,"meterValue":[{"sampledValue":[{"value":"4873"}],"timestamp":"2021-10-29T14:23:24Z"}]}
            2021-10-29 16:23:25.506 - info: ocpp.0 (9927) Received MeterValues from "/Dorn"
            2021-10-29 16:24:20.554 - debug: ocpp.0 (9927) {}
            2021-10-29 16:24:20.555 - debug: ocpp.0 (9927) Received heartbeat from "/Dorn"
            2021-10-29 16:24:25.504 - debug: ocpp.0 (9927) {"connectorId":1,"transactionId":1,"meterValue":[{"sampledValue":[{"value":"4873"}],"timestamp":"2021-10-29T14:24:24Z"}]}
            2021-10-29 16:24:25.505 - info: ocpp.0 (9927) Received MeterValues from "/Dorn"
            2021-10-29 16:25:20.577 - debug: ocpp.0 (9927) {}
            2021-10-29 16:25:20.577 - debug: ocpp.0 (9927) Received heartbeat from "/Dorn"
            2021-10-29 16:25:25.515 - debug: ocpp.0 (9927) {"connectorId":1,"transactionId":1,"meterValue":[{"sampledValue":[{"value":"4873"}],"timestamp":"2021-10-29T14:25:24Z"}]}
            2021-10-29 16:25:25.515 - info: ocpp.0 (9927) Received MeterValues from "/Dorn"
            2021-10-29 16:26:20.564 - debug: ocpp.0 (9927) {}
            2021-10-29 16:26:20.565 - debug: ocpp.0 (9927) Received heartbeat from "/Dorn"
            2021-10-29 16:26:25.495 - debug: ocpp.0 (9927) {"connectorId":1,"transactionId":1,"meterValue":[{"sampledValue":[{"value":"4873"}],"timestamp":"2021-10-29T14:26:24Z"}]}
            2021-10-29 16:26:25.496 - info: ocpp.0 (9927) Received MeterValues from "/Dorn"
            2021-10-29 16:27:22.734 - debug: ocpp.0 (9927) {}
            2021-10-29 16:27:22.735 - debug: ocpp.0 (9927) Received heartbeat from "/Dorn"
            2021-10-29 16:27:25.495 - debug: ocpp.0 (9927) {"connectorId":1,"transactionId":1,"meterValue":[{"sampledValue":[{"value":"4873"}],"timestamp":"2021-10-29T14:27:24Z"}]}
            2021-10-29 16:27:25.495 - info: ocpp.0 (9927) Received MeterValues from "/Dorn"
            2021-10-29 16:28:20.412 - debug: ocpp.0 (9927) {"meterStop":4873,"timestamp":"2021-10-29T14:28:19Z","transactionId":1,"reason":"Remote"}
            2021-10-29 16:28:20.413 - info: ocpp.0 (9927) Received stop transaction from "/Dorn"
            2021-10-29 16:28:22.244 - debug: ocpp.0 (9927) {"connectorId":1,"errorCode":"NoError","status":"Finishing","timestamp":"2021-10-29T14:28:19Z"}
            2021-10-29 16:28:22.245 - info: ocpp.0 (9927) Received Status Notification from "/Dorn": Finishing
            2021-10-29 16:28:41.417 - debug: ocpp.0 (9927) {"connectorId":1,"errorCode":"NoError","status":"Unavailable","timestamp":"2021-10-29T14:28:38Z"}
            2021-10-29 16:28:41.418 - info: ocpp.0 (9927) Received Status Notification from "/Dorn": Unavailable
            2021-10-29 16:29:02.385 - debug: ocpp.0 (9927) {"connectorId":1,"errorCode":"NoError","status":"Finishing","timestamp":"2021-10-29T14:28:59Z"}
            2021-10-29 16:29:02.386 - info: ocpp.0 (9927) Received Status Notification from "/Dorn": Finishing
            2021-10-29 16:29:57.386 - debug: ocpp.0 (9927) {}
            2021-10-29 16:29:57.388 - debug: ocpp.0 (9927) Received heartbeat from "/Dorn"
            2021-10-29 16:30:52.384 - debug: ocpp.0 (9927) {}
            2021-10-29 16:30:52.385 - debug: ocpp.0 (9927) Received heartbeat from "/Dorn"
            2021-10-29 16:31:47.384 - debug: ocpp.0 (9927) {}
            2021-10-29 16:31:47.385 - debug: ocpp.0 (9927) Received heartbeat from "/Dorn"
            2021-10-29 16:32:33.646 - debug: ocpp.0 (9927) {"connectorId":1,"errorCode":"NoError","status":"Unavailable","timestamp":"2021-10-29T14:32:31Z"}
            2021-10-29 16:32:33.646 - info: ocpp.0 (9927) Received Status Notification from "/Dorn": Unavailable
            2021-10-29 16:33:28.634 - debug: ocpp.0 (9927) {}
            2021-10-29 16:33:28.635 - debug: ocpp.0 (9927) Received heartbeat from "/Dorn"
            2021-10-29 16:34:23.634 - debug: ocpp.0 (9927) {}
            2021-10-29 16:34:23.634 - debug: ocpp.0 (9927) Received heartbeat from "/Dorn"
            2021-10-29 16:35:18.634 - debug: ocpp.0 (9927) {}
            2021-10-29 16:35:18.635 - debug: ocpp.0 (9927) Received heartbeat from "/Dorn"
            2021-10-29 16:36:09.960 - info: host.iobroker stopInstance system.adapter.ocpp.0 (force=false, process=true)
            2021-10-29 16:36:10.066 - info: ocpp.0 (9927) Got terminate signal TERMINATE_YOURSELF
            2021-10-29 16:36:10.076 - info: host.iobroker stopInstance system.adapter.ocpp.0 send kill signal
            2021-10-29 16:36:10.157 - info: ocpp.0 (9927) terminating
            2021-10-29 16:36:10.158 - info: ocpp.0 (9927) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
            2021-10-29 16:36:10.838 - info: host.iobroker instance system.adapter.ocpp.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
            2021-10-29 16:36:13.457 - info: host.iobroker instance system.adapter.ocpp.0 started with pid 29581
            2021-10-29 16:36:15.952 - debug: ocpp.0 (29581) Redis Objects: Use Redis connection: 127.0.0.1:9001
            2021-10-29 16:36:17.707 - debug: ocpp.0 (29581) Objects client ready ... initialize now
            2021-10-29 16:36:19.476 - debug: ocpp.0 (29581) Objects create System PubSub Client
            2021-10-29 16:36:19.481 - debug: ocpp.0 (29581) Objects create User PubSub Client
            2021-10-29 16:36:19.483 - debug: ocpp.0 (29581) Objects client initialize lua scripts
            2021-10-29 16:36:20.872 - debug: ocpp.0 (29581) Objects connected to redis: 127.0.0.1:9001
            2021-10-29 16:36:20.887 - debug: ocpp.0 (29581) objectDB connected
            2021-10-29 16:36:20.891 - debug: ocpp.0 (29581) Redis States: Use Redis connection: 127.0.0.1:9000
            2021-10-29 16:36:21.346 - debug: ocpp.0 (29581) States create System PubSub Client
            2021-10-29 16:36:21.349 - debug: ocpp.0 (29581) States create User PubSub Client
            2021-10-29 16:36:21.992 - debug: ocpp.0 (29581) States connected to redis: 127.0.0.1:9000
            2021-10-29 16:36:21.999 - debug: ocpp.0 (29581) statesDB connected
            2021-10-29 16:36:24.089 - info: ocpp.0 (29581) starting. Version 0.0.6 in /opt/iobroker/node_modules/iobroker.ocpp, node: v14.17.6, js-controller: 3.3.18
            2021-10-29 16:36:24.169 - info: ocpp.0 (29581) Starting OCPP Server
            2021-10-29 16:36:25.271 - info: ocpp.0 (29581) Server listening on port 9220
            2021-10-29 16:37:08.653 - info: ocpp.0 (29581) New device connected: "/Dorn"
            2021-10-29 16:37:08.656 - info: ocpp.0 (29581) Requesting BootNotification from "/Dorn"
            2021-10-29 16:37:09.690 - info: ocpp.0 (29581) Requesting StatusNotification from "/Dorn"
            2021-10-29 16:37:09.923 - debug: ocpp.0 (29581) {}
            2021-10-29 16:37:09.924 - debug: ocpp.0 (29581) Received heartbeat from "/Dorn"
            2021-10-29 16:37:10.710 - info: ocpp.0 (29581) Requesting MeterValues from "/Dorn"
            2021-10-29 16:37:11.720 - debug: ocpp.0 (29581) {"connectorId":1,"errorCode":"NoError","status":"Unavailable","timestamp":"2021-10-29T14:37:09Z"}
            2021-10-29 16:37:11.721 - info: ocpp.0 (29581) Received Status Notification from "/Dorn": Unavailable
            2021-10-29 16:37:26.359 - debug: ocpp.0 (29581) {"connectorId":1,"idTag":"UNDEFINED","meterStart":0,"timestamp":"2021-10-29T14:37:25Z"}
            2021-10-29 16:37:26.361 - info: ocpp.0 (29581) Received Start transaction from "/Dorn"
            2021-10-29 16:37:29.037 - debug: ocpp.0 (29581) {"connectorId":1,"errorCode":"NoError","status":"Charging","timestamp":"2021-10-29T14:37:26Z"}
            2021-10-29 16:37:29.039 - info: ocpp.0 (29581) Received Status Notification from "/Dorn": Charging
            2021-10-29 16:38:16.189 - debug: ocpp.0 (29581) {"connectorId":1,"errorCode":"NoError","status":"SuspendedEV","timestamp":"2021-10-29T14:38:13Z"}
            2021-10-29 16:38:16.191 - info: ocpp.0 (29581) Received Status Notification from "/Dorn": SuspendedEV
            2021-10-29 16:38:26.485 - debug: ocpp.0 (29581) {"connectorId":1,"transactionId":1,"meterValue":[{"sampledValue":[{"value":"1"}],"timestamp":"2021-10-29T14:38:25Z"}]}
            2021-10-29 16:38:26.487 - info: ocpp.0 (29581) Received MeterValues from "/Dorn"
            2021-10-29 16:39:22.936 - debug: ocpp.0 (29581) {}
            2021-10-29 16:39:22.939 - debug: ocpp.0 (29581) Received heartbeat from "/Dorn"
            2021-10-29 16:39:26.476 - debug: ocpp.0 (29581) {"connectorId":1,"transactionId":1,"meterValue":[{"sampledValue":[{"value":"1"}],"timestamp":"2021-10-29T14:39:25Z"}]}
            2021-10-29 16:39:26.477 - info: ocpp.0 (29581) Received MeterValues from "/Dorn"
            2021-10-29 16:40:21.584 - debug: ocpp.0 (29581) {}
            2021-10-29 16:40:21.585 - debug: ocpp.0 (29581) Received heartbeat from "/Dorn"
            2021-10-29 16:40:26.496 - debug: ocpp.0 (29581) {"connectorId":1,"transactionId":1,"meterValue":[{"sampledValue":[{"value":"1"}],"timestamp":"2021-10-29T14:40:25Z"}]}
            2021-10-29 16:40:26.497 - info: ocpp.0 (29581) Received MeterValues from "/Dorn"
            2021-10-29 16:41:24.254 - debug: ocpp.0 (29581) {}
            2021-10-29 16:41:24.256 - debug: ocpp.0 (29581) Received heartbeat from "/Dorn"
            2021-10-29 16:41:26.497 - debug: ocpp.0 (29581) {"connectorId":1,"transactionId":1,"meterValue":[{"sampledValue":[{"value":"1"}],"timestamp":"2021-10-29T14:41:26Z"}]}
            2021-10-29 16:41:26.498 - info: ocpp.0 (29581) Received MeterValues from "/Dorn"
            2021-10-29 16:42:21.854 - debug: ocpp.0 (29581) {}
            2021-10-29 16:42:21.855 - debug: ocpp.0 (29581) Received heartbeat from "/Dorn"
            2021-10-29 16:42:26.469 - debug: ocpp.0 (29581) {"connectorId":1,"transactionId":1,"meterValue":[{"sampledValue":[{"value":"1"}],"timestamp":"2021-10-29T14:42:25Z"}]}
            2021-10-29 16:42:26.470 - info: ocpp.0 (29581) Received MeterValues from "/Dorn"
            2021-10-29 16:43:23.654 - debug: ocpp.0 (29581) {}
            2021-10-29 16:43:23.655 - debug: ocpp.0 (29581) Received heartbeat from "/Dorn"
            2021-10-29 16:43:26.466 - debug: ocpp.0 (29581) {"connectorId":1,"transactionId":1,"meterValue":[{"sampledValue":[{"value":"1"}],"timestamp":"2021-10-29T14:43:25Z"}]}
            2021-10-29 16:43:26.466 - info: ocpp.0 (29581) Received MeterValues from "/Dorn"
            2021-10-29 16:44:21.574 - debug: ocpp.0 (29581) {}
            2021-10-29 16:44:21.575 - debug: ocpp.0 (29581) Received heartbeat from "/Dorn"
            2021-10-29 16:44:26.476 - debug: ocpp.0 (29581) {"connectorId":1,"transactionId":1,"meterValue":[{"sampledValue":[{"value":"1"}],"timestamp":"2021-10-29T14:44:25Z"}]}
            2021-10-29 16:44:26.477 - info: ocpp.0 (29581) Received MeterValues from "/Dorn"
            2021-10-29 16:45:23.186 - debug: ocpp.0 (29581) {}
            2021-10-29 16:45:23.187 - debug: ocpp.0 (29581) Received heartbeat from "/Dorn"
            2021-10-29 16:45:26.464 - debug: ocpp.0 (29581) {"connectorId":1,"transactionId":1,"meterValue":[{"sampledValue":[{"value":"1"}],"timestamp":"2021-10-29T14:45:26Z"}]}
            2021-10-29 16:45:26.465 - info: ocpp.0 (29581) Received MeterValues from "/Dorn"
            2021-10-29 16:46:21.584 - debug: ocpp.0 (29581) {}
            2021-10-29 16:46:21.585 - debug: ocpp.0 (29581) Received heartbeat from "/Dorn"
            2021-10-29 16:46:26.468 - debug: ocpp.0 (29581) {"connectorId":1,"transactionId":1,"meterValue":[{"sampledValue":[{"value":"1"}],"timestamp":"2021-10-29T14:46:25Z"}]}
            2021-10-29 16:46:26.475 - info: ocpp.0 (29581) Received MeterValues from "/Dorn"
            2021-10-29 16:46:31.651 - info: javascript.0 (540) script.js.Strommessung.Waschmaschine: -Wa- 55 Minuten / 0.5 kWh / 0.14 € -Wa-
            2021-10-29 16:47:23.364 - debug: ocpp.0 (29581) {}
            2021-10-29 16:47:23.364 - debug: ocpp.0 (29581) Received heartbeat from "/Dorn"
            2021-10-29 16:47:26.472 - debug: ocpp.0 (29581) {"connectorId":1,"transactionId":1,"meterValue":[{"sampledValue":[{"value":"1"}],"timestamp":"2021-10-29T14:47:25Z"}]}
            2021-10-29 16:47:26.474 - info: ocpp.0 (29581) Received MeterValues from "/Dorn"
            Fri Oct 29 14:37:07 2021 	Sending HeartbeatReq
            Fri Oct 29 14:37:08 2021 	Received TriggerMessage(BootNotification, 0) => NotImplemented
            Fri Oct 29 14:37:09 2021 	Received TriggerMessage(StatusNotification, 0) => Accepted
            Fri Oct 29 14:37:09 2021 	Received HeartbeatConf: 2021-10-29T14:37:09+00:00
            Fri Oct 29 14:37:09 2021 	Received TriggerMessage(MeterValues, 0) => Rejected
            Fri Oct 29 14:37:10 2021 	Sending StatusNotificationReq: connectorId=1 Unavailable
            Fri Oct 29 14:37:10 2021 	Received StatusNotificationConf
            Fri Oct 29 14:37:22 2021 	Received ChangeAvailability connectorId=1 type=Operative
            Fri Oct 29 14:37:23 2021 	Sent ChangeAvailabilityConf: Accepted
            Fri Oct 29 14:37:25 2021 	Sending StartTransactionReq tag:UNDEFINED
            Fri Oct 29 14:37:25 2021 	Received StartTransactionConf transactionId: 1 status: Accepted
            Fri Oct 29 14:37:26 2021 	Received RemoteStartTransaction _connectorId=1 _idTag=1
            Fri Oct 29 14:37:26 2021 	Sent RemoteStartTransactionConf: Rejected
            Fri Oct 29 14:37:28 2021 	Sending StatusNotificationReq: connectorId=1 Charging
            Fri Oct 29 14:37:28 2021 	Received StatusNotificationConf
            Fri Oct 29 14:38:15 2021 	Sending StatusNotificationReq: connectorId=1 SuspendedEV
            Fri Oct 29 14:38:15 2021 	Received StatusNotificationConf
            Fri Oct 29 14:38:25 2021 	Sending MeterValues transactionId:1 Energy: 1Wh
            Fri Oct 29 14:38:26 2021 	Received MeterValuesConf
            Frage , kann man damit auch ein Ladelimlit ( 6 A - ... A ) , bzw. eine Ladepause ansteuern , zb. bei Überschuss der Photovoltaik Anlage
            https://www.oasis-open.org/committees/download.php/58944/ocpp-1.6.pdf
            • foxriver76F Offline
              foxriver76F Offline
              foxriver76
              @glasfaser Bekomme das Matching von 1715 auf 4873 noch nicht so ganz hin, villt. kannst du mir nochmal auf die Sprünge helfen, wie du das meinst.
              Die beiden Datenpunkte mit null sind nur zum steuern, wobei transactionActive theoretisch ein ack nach dem Steuern bekommen kann. Availability kann man bei mir zwar steuern, bekommt aber keine Rückmeldung.
              Also eine Ladepause könntest du mal mindestens manuell ansteuern, indem du transactionActive auf false setzt, das sollte die aktuelle Transaktion (Ladung) stoppen und mit true fortsetzen. ein Ampere Limit scheint nur über SetChargingProfile möglich zu sein. Hier bin ich noch am überlegen, wie man das sinnvoll implementiert. Ich würde vermutlich nur ermöglichen die Ladung zu beschränken und nicht das konfigurieren von Profilen mit schedule etc. da da dann keiner mehr durchsteigt und vermutlich der Use-Case besser über ein Skript abdeckbar ist insofern man die Ampere über den Adapter beschränken kann.
                GlasfaserG Offline
                GlasfaserG Offline
                @foxriver76
                Der Wert 1715 war von der ersten Ladung ( Moment LOG Aufnahme ) , hat mit dem zweiten Wert nichts zu tun der ist von gestern , Sorry wenn du es so verstanden hast.
                Der Wert 4873 Wh ist der Endwert eines Ladevorganges.
                " Ladevorgang wird mit 0 Wh gestartet und endet bei mir mit 4873 Wh auch im Datenpunkt meterValue sichtbar "
                Ich hatte ja wie ich oben schon geschrieben in der Wallbox einen Pool von 900 s , da ich den Pool der Wallbox dann auf 5 s gestellt hatte und dann in den Modbus-Registern geschaut hatte konnte ich den Wert hinzugefügte Wh ( pro Ladevorgang) zuordnen .
                Das habe ich gemacht , das komische ist es tut sich nichts ( mehr ),
                Datenpunkt transactionActive mit true/false auch bei dem anderen Datenpunkt availability true/false.
                Im DEBUG LOG ist auch nichts zu erkennen .
                Ich bin mir sicher , wo ich die Version 0.0.5 nach deiner Thread Eröffung aufgespielt hatte , das ich den Datenpunkt transactionActive mit true/false schalten konnte und es änderte sich auch dazu der Datenpunkt status dazu .
                Eventuell hat es damit zu tun , das Datenpunkt transactionActive nicht (null) war ,sondern schon auf true .
                Screenshot´s von den Änderungen der Datenpunkte auf true/false :
                2021-10-30 12:10:48.757 - info: ocpp.0 (7202) Received MeterValues from "/Dorn"
                2021-10-30 12:10:48.888 - debug: ocpp.0 (7202) {"connectorId":1,"transactionId":1,"meterValue":[{"sampledValue":[{"value":"3976"}],"timestamp":"2021-10-30T10:05:40Z"},{"sampledValue":[{"value":"4033"}],"timestamp":"2021-10-30T10:06:40Z"},{"sampledValue":[{"value":"4090"}],"timestamp":"2021-10-30T10:07:40Z"},{"sampledValue":[{"value":"4147"}],"timestamp":"2021-10-30T10:08:40Z"},{"sampledValue":[{"value":"4205"}],"timestamp":"2021-10-30T10:09:40Z"},{"sampledValue":[{"value":"4262"}],"timestamp":"2021-10-30T10:10:40Z"}]}
                2021-10-30 12:10:48.889 - info: ocpp.0 (7202) Received MeterValues from "/Dorn"
                2021-10-30 12:11:40.656 - debug: ocpp.0 (7202) {"connectorId":1,"transactionId":1,"meterValue":[{"sampledValue":[{"value":"4319"}],"timestamp":"2021-10-30T10:11:40Z"}]}
                2021-10-30 12:11:40.656 - info: ocpp.0 (7202) Received MeterValues from "/Dorn"
                2021-10-30 12:12:35.726 - debug: ocpp.0 (7202) {}
                2021-10-30 12:12:35.726 - debug: ocpp.0 (7202) Received heartbeat from "/Dorn"
                2021-10-30 12:12:40.644 - debug: ocpp.0 (7202) {"connectorId":1,"transactionId":1,"meterValue":[{"sampledValue":[{"value":"4376"}],"timestamp":"2021-10-30T10:12:39Z"}]}
                2021-10-30 12:12:40.646 - info: ocpp.0 (7202) Received MeterValues from "/Dorn"
                2021-10-30 12:13:35.786 - debug: ocpp.0 (7202) {}
                2021-10-30 12:13:35.787 - debug: ocpp.0 (7202) Received heartbeat from "/Dorn"
                2021-10-30 12:13:40.637 - debug: ocpp.0 (7202) {"connectorId":1,"transactionId":1,"meterValue":[{"sampledValue":[{"value":"4434"}],"timestamp":"2021-10-30T10:13:39Z"}]}
                2021-10-30 12:13:40.647 - info: ocpp.0 (7202) Received MeterValues from "/Dorn"
                2021-10-30 12:15:40.643 - info: ocpp.0 (7202) Received MeterValues from "/Dorn"
                2021-10-30 12:16:35.704 - debug: ocpp.0 (7202) {}
                2021-10-30 12:16:35.705 - debug: ocpp.0 (7202) Received heartbeat from "/Dorn"
                2021-10-30 12:16:40.660 - debug: ocpp.0 (7202) {"connectorId":1,"transactionId":1,"meterValue":[{"sampledValue":[{"value":"4607"}],"timestamp":"2021-10-30T10:16:39Z"}]}
                2021-10-30 12:16:40.664 - info: ocpp.0 (7202) Received MeterValues from "/Dorn"
                2021-10-30 12:17:36.026 - debug: ocpp.0 (7202) {}
                2021-10-30 12:17:36.026 - debug: ocpp.0 (7202) Received heartbeat from "/Dorn"
                2021-10-30 12:17:40.636 - debug: ocpp.0 (7202) {"connectorId":1,"transactionId":1,"meterValue":[{"sampledValue":[{"value":"4664"}],"timestamp":"2021-10-30T10:17:40Z"}]}
                2021-10-30 12:17:40.637 - info: ocpp.0 (7202) Received MeterValues from "/Dorn"
                2021-10-30 12:18:35.725 - debug: ocpp.0 (7202) {}
                2021-10-30 12:18:35.726 - debug: ocpp.0 (7202) Received heartbeat from "/Dorn"
                2021-10-30 12:18:40.629 - debug: ocpp.0 (7202) {"connectorId":1,"transactionId":1,"meterValue":[{"sampledValue":[{"value":"4721"}],"timestamp":"2021-10-30T10:18:39Z"}]}
                2021-10-30 12:18:40.629 - info: ocpp.0 (7202) Received MeterValues from "/Dorn"
                  GlasfaserG Offline
                  GlasfaserG Offline
                  @foxriver76
                  Habe nochmal alles neu Probiert und folgendes herrausgefunden :
                  Wenn der Datenpunkt transactionActive mit false gesetzt wird , dann wird der Datenpunkt status auf Finishing gesetzt und di Ladung dadurch unterbrochen .
                  2021-10-30 15:20:36.394 - debug: ocpp.0 (27124) {"connectorId":1,"transactionId":1,"meterValue":[{"sampledValue":[{"value":"424"}],"timestamp":"2021-10-30T13:20:35Z"}]}
                  2021-10-30 15:20:36.398 - info: ocpp.0 (27124) Received MeterValues from "/Dorn"
                  2021-10-30 15:20:37.836 - debug: ocpp.0 (27124) {"meterStop":425,"timestamp":"2021-10-30T13:20:36Z","transactionId":1,"reason":"Remote"}
                  2021-10-30 15:20:37.837 - info: ocpp.0 (27124) Received stop transaction from "/Dorn"
                  2021-10-30 15:20:39.673 - debug: ocpp.0 (27124) {"connectorId":1,"errorCode":"NoError","status":"Finishing","timestamp":"2021-10-30T13:20:36Z"}
                  2021-10-30 15:20:39.674 - info: ocpp.0 (27124) Received Status Notification from "/Dorn": Finishing
                  Wenn ich Ihn wieder auf true setze passiert nichts und auch keine Log Ausgabe dazu.
                  Erst wenn ich den Datenpunkt availability true/false. schalte , wird es wieder freigegeben / geladen .
                  Aber dabei wird ein neuer Ladevorgang gesetzt , so das der Zähler Wh bei 0 beginnt , also keine Pause sondern ein Neustart .
                  hier ein GIF dazu :
                  • GlasfaserG Glasfaser
                    @foxriver76
                    hier ein GIF dazu :
                    foxriver76F Offline
                    foxriver76F Offline
                    foxriver76
                    @glasfaser Ich denke es unterscheidet sich teilweise stark, wie die Wallbox Hersteller das Protokoll intern umsetzen. Bei mir ist es z. B. so, dass der availability state alles andere blockiert, sprich wenn Unvailable mittels availability state gesetzt wurde, dann kann ich keine Transaktion mehr starten, muss erst wieder mit dem availability state aktiviert werden. Sowas wie PauseTransaction gibts leider meines Wissens nicht in OCPP, weshalb es immer eine neue Transaktion ist und der Counter neu anfängt. Gedanke von OCPP ja auch eher kommerziell mehrere WBs managen, daher kann ich es etwas nachvollziehen.
                    Ich habe mal eine 0.0.7 gemacht, bei der gibts nen State zum setzen des Limits in Watt, der wird aber nur angezogen wenn eine neue Transaktion gestartet wird, das direkte setzen geht derzeit meist nicht, da die Library nen Bug hat, scheint auch leider nicht mehr so maintained zu sein. Deshalb kommt jetzt aktuell beim eintragen eines Wertes ein Fehler im Log.
                    • S Online
                      S Online
                      Schimi
                      wenn man es "über die katze" installieren kann... wäre ich mit einer "cfos Power Brain" Wallbox dabei :-)
                      • S Schimi
                        GlasfaserG Offline
                        GlasfaserG Offline
                        @schimi sagte in Alpha Testing: OCPP Wallbox Adapter:
                        kannst du doch ... , wenn du dich nicht über den oben genannten Weg traust !?
                        • GlasfaserG Offline
                          GlasfaserG Offline
                          @foxriver76 sagte in Alpha Testing: OCPP Wallbox Adapter:
                          Du meinst das hier :
                          2021-10-30 21:27:06.199 - debug: ocpp.0 (18684) Sending SetChargingProfile for /Dorn
                          2021-10-30 21:27:06.211 - error: ocpp.0 (18684) Cannot execute command "chargeLimit" for "/Dorn": Invalid value "[object Object]" for field csChargingProfiles
                            S Online
                            S Online
                            Schimi
                            @glasfaser der weg oben hat irgendwie nicjt geklappt.... Und über "die katze" findet er nichts wenn ich mach ocpp suche
                            Fehler sitzt wohl vor dem Bildschirm 😂
                            • S Schimi
                              GlasfaserG Offline
                              GlasfaserG Offline
                              weil ...nicht geklappt ??? sind Fehlermeldungen oder was !?
                              Ich hoffe du hast im Verzeichniss /opt/iobroker den Befehl ausgeführt.
                              Du mußt über URL installieren .
                                S Online
                                S Online
                                Schimi
                                @glasfaser Das wirds gewesen sein.... Bin nicht im iobroker Ordner gewesen....
                                Ich probier mal heute abend wieder 👍
                                • S Online
                                  S Online
                                  Schimi
                                  Ok, hat geklappt (Url im iobroker)...
                                  Die ersten daten sind da... Bin noch unterwegs (habe es uber vpn "eingerichtet"...
                                  Ich mache später mal nen screenshot... Oder was "braucht" ihr noch?
                                  • S Schimi
                                    S Online
                                    S Online
                                    Schimi
                                    schrieb am zuletzt editiert von Schimi
                                    Wallbox:
                                    cFos PowerBrain Wallbox (PowerBrain Controller)
                                    1a5ca2c1-c4a5-4923-a00b-ca8d97c8bae9-image.png fc86dfa9-98d3-48e5-9a91-327539d1f779-image.png
                                    Ich kann das laden mit dem Datenpunkt "transactionActive" starten und beenden.... das chargeLimit scheint keine auswirkung zu haben.
                                    Wenn ich "aviability" auf false stelle geht das laden auch aus bzw bei true auf an....
                                    Viel mehr konnte ich nicht testen da keine großartige ladung gerade bevorsteht....
                                    Scheint sich auch mit dem automatischen überschussladen der Box zu beissen (die Box habe ich im iobroker über Modbus eingebunden (und ein zwei HTTP befehle (dokumentiert auf der Webseite)...
                                    Das wurde vom Log ausgespuckt während ich "rumprobiert" habe:
                                    ocpp.0
                                    2021-10-31 16:40:21.224	info	Received Status Notification from "/1": SuspendedEVSE
                                    ocpp.0
                                    2021-10-31 16:40:16.392	info	Received MeterValues from "/1"
                                    jarvis.0
                                    2021-10-31 16:40:15.955	info	Client with IP ::ffff:192.168.1.182 connected
                                    ocpp.0
                                    2021-10-31 16:39:17.671	info	Received Status Notification from "/1": Charging
                                    ocpp.0
                                    2021-10-31 16:39:16.382	info	Received Status Notification from "/1": SuspendedEVSE
                                    ocpp.0
                                    2021-10-31 16:39:16.359	info	Received Start transaction from "/1"
                                    ocpp.0
                                    2021-10-31 16:39:16.345	info	Received Authorization Request from "/1"
                                    ocpp.0
                                    2021-10-31 16:39:07.639	info	Received Status Notification from "/1": Preparing
                                    ocpp.0
                                    2021-10-31 16:38:58.020	info	Received stop transaction from "/1"
                                    ocpp.0
                                    2021-10-31 16:38:57.998	info	Received Status Notification from "/1": Unavailable
                                    ocpp.0
                                    2021-10-31 16:38:44.232	error	Cannot execute command "chargeLimit" for "/1": Invalid value "[object Object]" for field csChargingProfiles
                                    ocpp.0
                                    2021-10-31 16:38:35.310	info	Received MeterValues from "/1"
                                    ocpp.0
                                    2021-10-31 16:37:37.301	error	Cannot execute command "chargeLimit" for "/1": Invalid value "[object Object]" for field csChargingProfiles
                                    ocpp.0
                                    2021-10-31 16:37:35.316	info	Received MeterValues from "/1"
                                    ocpp.0
                                    2021-10-31 16:37:03.640	error	Cannot execute command "chargeLimit" for "/1": Invalid value "[object Object]" for field csChargingProfiles
                                    ocpp.0
                                    2021-10-31 16:36:36.598	info	Received Status Notification from "/1": Charging
                                    ocpp.0
                                    2021-10-31 16:36:35.299	info	Received Status Notification from "/1": SuspendedEVSE
                                    ocpp.0
                                    2021-10-31 16:36:35.282	info	Received Start transaction from "/1"
                                    ocpp.0
                                    2021-10-31 16:36:35.259	info	Received Authorization Request from "/1"
                                    ocpp.0
                                    2021-10-31 16:35:51.234	info	Received Status Notification from "/1": Preparing
                                    ocpp.0
                                    2021-10-31 16:35:51.195	info	Received stop transaction from "/1"
                                    ocpp.0
                                    2021-10-31 16:35:40.172	info	Received Status Notification from "/1": SuspendedEVSE
                                    ocpp.0
                                    2021-10-31 16:35:40.139	info	Received Start transaction from "/1"
                                    ocpp.0
                                    2021-10-31 16:35:40.125	info	Received Authorization Request from "/1"
                                    ocpp.0
                                    2021-10-31 16:35:24.183	error	Cannot execute command "chargeLimit" for "/1": Invalid value "[object Object]" for field csChargingProfiles
                                    ocpp.0
                                    2021-10-31 16:34:54.505	info	Received Status Notification from "/1": Preparing
                                    ocpp.0
                                    2021-10-31 16:34:48.702	info	Received Status Notification from "/1": Unavailable
                                    ocpp.0
                                    2021-10-31 16:34:39.182	error	Cannot execute command "chargeLimit" for "/1": Invalid value "[object Object]" for field csChargingProfiles
                                    ocpp.0
                                    2021-10-31 16:34:28.088	error	Cannot execute command "chargeLimit" for "/1": Invalid value "[object Object]" for field csChargingProfiles
                                      manuBT
                                      Schönen guten Abend!
                                      Also nach dem ich lange den „/„ am Ende der OCPP Server Adresse vergessen habe kann ich nun Erfolg melden.
                                      Der Adapter spricht mit einer EVBox Elvi.
                                      Es kommt nicht viel an aber wenigstens etwas!
                                      Sollte eigentlich mehr kommen oder ist das der aktuelle Stand ?!
                                      Beste Grüße !
                                      foxriver76F D Meister MopperM 3 Antworten Letzte Antwort
                                      • M manuBT
                                        Beste Grüße !
                                        foxriver76F Offline
                                        foxriver76F Offline
                                        foxriver76
                                        schrieb am zuletzt editiert von foxriver76
                                        @manubt Ne das ist alles zur Zeit.. ihr könnt euch gerne mal das Protokoll anschauen. Ich weiß aktuell nicht was ich da noch sinnvolles rausziehen soll/kann. Sehe gerade, dass er dir wegen der IP-Adresse ein Haufen "Ordner" anzeigt.
                                        Edit: Habe eine 0.0.8 gemacht, da sollten solche Strukturen nun vermieden werden.
                                        Videotutorials & mehr
                                        M S 2 Antworten Letzte Antwort
                                        • foxriver76F foxriver76
                                          manuBT
                                          @foxriver76 Ich schaue mir das bei Gelegenheit mal an. Kämpfe gerade noch an einer anderen Stelle mit der Wallbox das sie den originalen Nachgerüsteten ModBus Zähler erkennen will ! :)
                                          Danke trotzdem!
