  3. Off Topic
  4. Proxmox
  5. Proxmox LXC Bootdisk vergrößern
    6.7k
Geplant Angeheftet Gesperrt Verschoben Proxmox
39 Beiträge 3 Kommentatoren 4.8k Aufrufe 4 Beobachtet
    @negalein sagte in Proxmox LXC Bootdisk vergrößern:
    root@ioBroker:~# sudo
    merkste selber 😁
    NegaleinN Offline
    NegaleinN Offline
    Negalein
    @crunchip sagte in Proxmox LXC Bootdisk vergrößern:
    merkste selber
    stimmt
    root braucht kein sudo
    aber mit iobroker npm cache clean --force kommt
    root@ioBroker:~# iobroker npm cache clean --force
    iobroker [command]
    Commands:
      iobroker setup                                               Setup ioBroker
      iobroker start                                               Starts the js-controller
      iobroker stop                                                stops the js-controller
      iobroker restart                                             Restarts js-controller
      iobroker debug <adapter>[.<instance>]                        Starts a Node.js debugging session for the adapter instance
      iobroker info                                                Shows the host info
      iobroker logs [<adapter>]                                    Monitor log
      iobroker add <adapter> [desiredNumber]                       Add instance of adapter
      iobroker install <adapter>                                   Installs a specified adapter
      iobroker rebuild <adapter>|self                              Rebuilds a specified adapter
      iobroker url <url> [<name>]                                  Install adapter from specified url, e.g. GitHub
      iobroker del <adapter>                                       Remove adapter from system
      iobroker del <adapter>.<instance>                            Remove adapter instance
      iobroker update [<repositoryUrl>]                            Update repository and list adapters
      iobroker upgrade                                             Upgrade management
      iobroker upload                                              Upload management
      iobroker object                                              Object management
      iobroker state                                               State management
      iobroker message <adapter>[.instance] <command> [<message>]  Send message to adapter instance/s
      iobroker list <type> [<filter>]                              List all entries, like objects
      iobroker chmod <mode> <file>                                 Change file rights
      iobroker chown <user> <group> <file>                         Change file ownership
      iobroker touch <file>                                        Touch file
      iobroker rm <file>                                           Remove file
      iobroker file                                                File management
      iobroker user                                                User commands
      iobroker group                                               group management
      iobroker host <hostname>                                     Set host to given hostname
      iobroker set <adapter>.<instance>                            Change settings of adapter config
      iobroker license <license.file or license.text>              Update license by given file
      iobroker cert                                                Certificate management
      iobroker clean <yes>                                         Clears all objects and states
      iobroker backup                                              Create backup
      iobroker restore <backup name or path>                       Restore a specified backup
      iobroker validate <backup name or path>                      Validate a specified backup
      iobroker status [all|<adapter>.<instance>]                   Status of ioBroker or adapter instance
      iobroker repo [<name>]                                       Show repo information
      iobroker uuid                                                Show uuid of the installation
      iobroker unsetup                                             Reset license, installation secret and language
      iobroker fix                                                 Execute the installation fixer script, this updates your ioBroker installation
      iobroker multihost                                           Multihost management
      iobroker compact                                             compact group management
      iobroker plugin                                              Plugin management
      iobroker version [<adapter>]                                 Show version of js-controller or specified adapter
    Options:
          --help     Show help  [boolean]
      -v, --version  Show version  [boolean]
    root@ioBroker:~#
    ° Fixer ---> iob fix
    • NegaleinN Negalein
      merkste selber
      stimmt
      iobroker [command]
      Commands:
      Options:
      root@ioBroker:~#
      crunchipC Offline
      crunchipC Offline
      @negalein bist ja auch mit root unterwegs
      löscht den cache deines LXC`s
      dein iobroker hat aber seinen eigenen cache, dieser liegt in home/iobroker/.npm
      solltest dich mit deinem user anmelden und dann den oben erwähnten sudo -u iobroker npm cache clean --force Befehl absetzen
      NegaleinN 2 Antworten Letzte Antwort
        NegaleinN Offline
        NegaleinN Offline
        Negalein
        Ah, jetzt gecheckt
          NegaleinN Offline
          NegaleinN Offline
          Negalein
          wieder permission error :(
          nega@ioBroker:/root$ sudo -u iobroker npm cache clean --force
          [sudo] password for nega:
          Error: EACCES: permission denied, scandir '/root'
            crunchipC Offline
            crunchipC Offline
              NegaleinN Offline
              NegaleinN Offline
              Negalein
              muss ich zuerst in home/iobroker/.npm wechseln und dann sudo -u iobroker npm cache clean --force ?
                crunchipC Offline
                crunchipC Offline
                @negalein nein, du meldest dich ganz normal an und stehst in deinem home Verzeichnis
                  NegaleinN Offline
                  NegaleinN Offline
                  Negalein
                  hab mit su nega gewechselt
                  das stimmt dann so nicht?
                  hab jetzt exit gefunden. ;)
                  dürfte funktioniert haben.
                  An der Größe hat sich nicht wirklich was geändert.
                  nega@ioBroker:~$ sudo -u iobroker npm cache clean --force
                  npm WARN using --force I sure hope you know what you are doing.
                     │     New major version of npm available! 6.14.13 -> 8.1.1      │
                     │   Changelog: https://github.com/npm/cli/releases/tag/v8.1.1   │
                     │               Run npm install -g npm to update!               │
                  nega@ioBroker:~$
                    nega@ioBroker:~$
                    crunchipC Offline
                    crunchipC Offline
                    das war auch nur eine Idee, da sich dort mit der Zeit so einiges ansammelt
                    andernfalls, wenn du nicht weisst, was noch so Platz braucht, kannst du ncdu verwenden, zum suchen.
                    falls nicht installiert
                    sudo apt install ncdu
                    wenn installiert, starten mit
                    sudo ncdu /
                      sudo ncdu /
                      NegaleinN Offline
                      NegaleinN Offline
                      Negalein
                          8.4 GiB [##########] /opt
                          1.0 GiB [#         ] /var
                          1.0 GiB [#         ] /usr
                         46.2 MiB [          ] /lib
                         29.0 MiB [          ] /home
                         13.2 MiB [          ] /bin
                          9.0 MiB [          ] /sbin
                          7.1 MiB [          ] /root
                          4.4 MiB [          ] /etc
                        100.0 KiB [          ] /run
                         40.0 KiB [          ] /tmp
                      !  16.0 KiB [          ] /lost+found
                         12.0 KiB [          ] /mnt
                      .   4.0 KiB [          ] /proc
                          4.0 KiB [          ] /lib64
                      e   4.0 KiB [          ] /srv
                      e   4.0 KiB [          ] /media
                      e   4.0 KiB [          ] /boot
                          4.0 KiB [          ] /dev
                      .   0.0   B [          ] /sys
                      • NegaleinN Offline
                        NegaleinN Offline
                        Negalein
                        Backup mit 4.1 GB :(
                        dachte die werden gellöscht nach x Tagen
                        --- /opt/iobroker/backups ---------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------
                          406.3 MiB [##########]  .nfs00000000001a056f00000028
                          406.3 MiB [######### ]  iobroker_2021_10_15-23_00_10_Standard_backupiobroker.tar.gz
                          406.2 MiB [######### ]  .nfs00000000001a07880000002a
                          406.2 MiB [######### ]  iobroker_2021_10_17-23_00_10_Standard_backupiobroker.tar.gz
                          406.2 MiB [######### ]  iobroker_2021_10_16-23_00_10_Standard_backupiobroker.tar.gz
                          406.2 MiB [######### ]  .nfs00000000001a056100000029
                          406.2 MiB [######### ]  .nfs00000000001a055800000024
                          406.2 MiB [######### ]  .nfs00000000001a075d00000026
                          406.2 MiB [######### ]  .nfs00000000001a075e00000027
                          406.1 MiB [######### ]  .nfs00000000001a076e00000025
                           39.0 MiB [          ]  historyDB_2021_10_17-23_00_54_Standard_backupiobroker.tar.gz
                           38.7 MiB [          ]  historyDB_2021_10_16-23_00_54_Standard_backupiobroker.tar.gz
                           38.3 MiB [          ]  historyDB_2021_10_15-23_00_51_Standard_backupiobroker.tar.gz
                            2.2 MiB [          ]  homematic_2021_10_16-01_30_11_3.59.6_backupiobroker.tar.sbk
                            2.2 MiB [          ]  homematic_2021_10_13-01_30_11_3.59.6_backupiobroker.tar.sbk
                            2.2 MiB [          ]  homematic_2021_10_10-01_30_11_3.59.6_backupiobroker.tar.sbk
                          744.0 KiB [          ]  javascripts_2021_10_16-23_01_15_Standard_backupiobroker.tar.gz
                          744.0 KiB [          ]  javascripts_2021_10_15-23_01_12_Standard_backupiobroker.tar.gz
                          744.0 KiB [          ]  javascripts_2021_10_17-23_01_16_Standard_backupiobroker.tar.gz
                           52.0 KiB [          ]  grafana_2021_07_17-23_00_51_backupiobroker.tar.gz
                           52.0 KiB [          ]  grafana_2021_07_07-23_00_51_backupiobroker.tar.gz
                           52.0 KiB [          ]  grafana_2021_07_10-23_00_49_backupiobroker.tar.gz
                           52.0 KiB [          ]  grafana_2021_07_08-23_00_50_backupiobroker.tar.gz
                           52.0 KiB [          ]  grafana_2021_07_11-23_00_49_backupiobroker.tar.gz
                           52.0 KiB [          ]  grafana_2021_07_09-23_00_49_backupiobroker.tar.gz
                          crunchipC Offline
                          crunchipC Offline
                          sollten sie, bzw...kommt darauf an, wie und wohin du ein backup erstellst und ob es Fehler gab.
                          Klappt ein backup nicht, bleibt es im backup ordner, erstellst du manuell ein backup, verbleibt das dort ebenfalls, in beiden Fällen musst du dies dann manuell löschen
                          also, hast du ja nun dein Problem gefunden und musst nicht zwangsläufig deinen LXC vergrößern (verkleinern ist nämlich offiziell nicht möglich)...falls du irgendwann auf die idee kommen solltest😉
                            NegaleinN Offline
                            NegaleinN Offline
                            Negalein
                            Ufff, gerade gesehen, dass nur noch auf den FTP gesichert wurde.
                            Lokal und Dropbox seit 10 Tagen nicht mehr, obwohl aktiviert. :(
                              crunchipC Offline
                              crunchipC Offline
                              @negalein da muss ich dich für heute leider alleine lassen mit deinem "Problem"😉 Bettchen ruft
                              gab aber die Tage die ein oder andere selbe Meldung im Backup Thread, dass das backup nicht funktionierte
                                NegaleinN Offline
                                NegaleinN Offline
                                Negalein
                                Bettchen ruft
                                bei mir auch 😴
                                • NegaleinN Offline
                                  NegaleinN Offline
                                  Negalein
                                  @crunchip
                                  kannst du dir denken, was das für Files sind?
                                    @crunchip
                                    @negalein Das sind 'Überreste' eines unsauberen umounts einer NFS-Freigabe.
                                    crunchipC NegaleinN 2 Antworten Letzte Antwort
                                      @crunchip
                                      crunchipC Offline
                                      crunchipC Offline
                                      @negalein hab ich oben schon gesehen und mich gewundert
                                      scheint das dein backup, doppelt da liegt, einmal das tar.gz und einmal .nfs, wobei ich mit letzterem nichts anfangen kann
                                        crunchipC Offline
                                        crunchipC Offline
                                        @thomas-braun davon hatte er aber nichts geschrieben,
                                          NegaleinN Offline
                                          NegaleinN Offline
                                          Negalein
                                          @thomas-braun sagte in Proxmox LXC Bootdisk vergrößern:
                                          kann ich die bedenkenlos löschen?
