VM raspberryMatic und IoBroker
@metalesel sagte in VM raspberryMatic und IoBroker:
@glasfaser
hab ich gemacht.. gleichesDie Logausgabe dazu
2021-10-02 20:15:47.039 - error: hm-rpc.1 (11291) Init not possible, going to stop: Unknown XML-RPC tag 'TITLE' 2021-10-02 20:15:47.074 - info: hm-rpc.1 (11291) xmlrpc -> 192.168.1.179:2001/ init ["http://192.168.1.230:2001",""] 2021-10-02 20:15:47.101 - error: hm-rpc.1 (11291) Cannot call init: [http://192.168.1.230:2001, ""] Unknown XML-RPC tag 'TITLE' 2021-10-02 20:15:47.112 - info: hm-rpc.1 (11291) terminating 2021-10-02 20:15:47.115 - info: hm-rpc.1 (11291) Terminated (NO_ERROR): Without reason 2021-10-02 20:15:48.242 - info: host.raspberrypi instance system.adapter.hm-rpc.1 terminated with code 0 (NO_ERROR) 2021-10-02 20:15:48.244 - info: host.raspberrypi Restart adapter system.adapter.hm-rpc.1 because enabled 2021-10-02 20:15:56.900 - error: hm-rpc.0 (11308) Init not possible, going to stop: Unknown XML-RPC tag 'TITLE' 2021-10-02 20:15:56.925 - info: hm-rpc.0 (11308) xmlrpc -> 192.168.1.179:2010/ init ["http://192.168.1.230:2010",""] 2021-10-02 20:15:56.950 - error: hm-rpc.0 (11308) Cannot call init: [http://192.168.1.230:2010, ""] Unknown XML-RPC tag 'TITLE' 2021-10-02 20:15:56.960 - info: hm-rpc.0 (11308) terminating 2021-10-02 20:15:56.962 - info: hm-rpc.0 (11308) Terminated (NO_ERROR): Without reason 2021-10-02 20:15:58.071 - info: host.raspberrypi instance system.adapter.hm-rpc.0 terminated with code 0 (NO_ERROR) 2021-10-02 20:15:58.073 - info: host.raspberrypi Restart adapter system.adapter.hm-rpc.0 because enabled 2021-10-02 20:16:00.054 - info: host.raspberrypi instance system.adapter.hm-rpc.0 started with pid 11329 2021-10-02 20:16:03.281 - info: hm-rpc.0 (11329) starting. Version 1.14.45 in /opt/iobroker/node_modules/iobroker.hm-rpc, node: v12.22.1, js-controller: 3.2.16 2021-10-02 20:16:05.405 - info: hm-rpc.0 (11329) xmlrpc server is trying to listen on 192.168.1.230:2010 2021-10-02 20:16:05.407 - info: hm-rpc.0 (11329) xmlrpc client is trying to connect to 192.168.1.179:2010/ with ["http://192.168.1.230:2010","raspberrypi:hm-rpc.0"] 2021-10-02 20:16:05.544 - error: hm-rpc.0 (11329) Init not possible, going to stop: Unknown XML-RPC tag 'TITLE' 2021-10-02 20:16:18.296 - info: host.raspberrypi instance system.adapter.hm-rpc.1 started with pid 11347 2021-10-02 20:16:21.862 - info: hm-rpc.1 (11347) starting. Version 1.14.45 in /opt/iobroker/node_modules/iobroker.hm-rpc, node: v12.22.1, js-controller: 3.2.16 2021-10-02 20:16:22.572 - info: hm-rpc.1 (11347) xmlrpc server is trying to listen on 192.168.1.230:2001 2021-10-02 20:16:22.575 - info: hm-rpc.1 (11347) xmlrpc client is trying to connect to 192.168.1.179:2001/ with ["http://192.168.1.230:2001","raspberrypi:hm-rpc.1"] 2021-10-02 20:16:22.647 - error: hm-rpc.1 (11347) Init not possible, going to stop: Unknown XML-RPC tag 'TITLE' 2021-10-02 20:16:35.488 - error: hm-rpc.0 (11329) Init not possible, going to stop: Unknown XML-RPC tag 'TITLE' 2021-10-02 20:16:35.550 - info: hm-rpc.0 (11329) xmlrpc -> 192.168.1.179:2010/ init ["http://192.168.1.230:2010",""] 2021-10-02 20:16:35.586 - error: hm-rpc.0 (11329) Cannot call init: [http://192.168.1.230:2010, ""] Unknown XML-RPC tag 'TITLE' 2021-10-02 20:16:35.598 - info: hm-rpc.0 (11329) terminating 2021-10-02 20:16:35.602 - info: hm-rpc.0 (11329) Terminated (NO_ERROR): Without reason 2021-10-02 20:16:36.761 - info: host.raspberrypi instance system.adapter.hm-rpc.0 terminated with code 0 (NO_ERROR) 2021-10-02 20:16:36.762 - info: host.raspberrypi Restart adapter system.adapter.hm-rpc.0 because enabled
@glasfaser sagte in VM raspberryMatic und IoBroker:
@glasfaser
... nach neustart von hm-rpc.0
hm-rpc.1
Wo kommt der jetzt her ?
du hast doch nur
hm-rpc.0
hm-rpc.1
du hast doch nur
hm-rpc.0
nein, er hat rf auf.1 und ip auf .0
bei .1 kommt die Meldung mit TITLE, bei 0 klappt gar nix
@Metalesel mach mal in der FW der RM den Haken bei automatische Umleitung auf https.
den kenne ich gar nicht
hab ich gemacht.. und mal die Adapter (rega und den rpc neu gestartet.. log anbei ...
2021-10-02 20:27:53.435 - info: host.raspberrypi stopInstance system.adapter.hm-rega.0 (force=false, process=true) 2021-10-02 20:27:53.958 - info: hm-rega.0 (11559) Got terminate signal TERMINATE_YOURSELF 2021-10-02 20:27:53.985 - info: host.raspberrypi stopInstance system.adapter.hm-rega.0 send kill signal 2021-10-02 20:27:54.095 - info: hm-rega.0 (11559) terminating 2021-10-02 20:27:54.099 - info: hm-rega.0 (11559) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason 2021-10-02 20:27:55.198 - info: host.raspberrypi instance system.adapter.hm-rega.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION) 2021-10-02 20:27:55.932 - info: host.raspberrypi stopInstance system.adapter.hm-rpc.1 (force=false, process=true) 2021-10-02 20:27:55.942 - info: host.raspberrypi stopInstance system.adapter.hm-rpc.1 send kill signal 2021-10-02 20:27:55.942 - info: hm-rpc.1 (11700) Got terminate signal TERMINATE_YOURSELF 2021-10-02 20:27:55.946 - info: hm-rpc.1 (11700) xmlrpc -> 192.168.1.179:42010/ init ["http://192.168.1.230:42010",""] 2021-10-02 20:27:55.986 - error: hm-rpc.1 (11700) Cannot call init: [http://192.168.1.230:42010, ""] Unknown XML-RPC tag 'TITLE' 2021-10-02 20:27:55.989 - info: hm-rpc.1 (11700) terminating 2021-10-02 20:27:55.992 - info: hm-rpc.1 (11700) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason 2021-10-02 20:27:57.272 - info: host.raspberrypi instance system.adapter.hm-rpc.1 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION) 2021-10-02 20:27:57.873 - info: host.raspberrypi instance system.adapter.hm-rega.0 started with pid 11728 2021-10-02 20:28:01.639 - info: host.raspberrypi instance system.adapter.hm-rpc.1 started with pid 11741 2021-10-02 20:28:03.488 - info: hm-rega.0 (11728) starting. Version 3.0.31 in /opt/iobroker/node_modules/iobroker.hm-rega, node: v12.22.1, js-controller: 3.2.16 2021-10-02 20:28:04.267 - info: hm-rega.0 (11728) subscribe .BidCoS-RF.50.PRESS_SHORT 2021-10-02 20:28:04.481 - info: hm-rega.0 (11728) ReGaHSS 192.168.1.179 up 2021-10-02 20:28:06.613 - info: hm-rega.0 (11728) time difference local-ccu 1s 2021-10-02 20:28:11.004 - info: hm-rega.0 (11728) request state values 2021-10-02 20:28:11.041 - info: hm-rega.0 (11728) Updated all datapoints 2021-10-02 20:28:11.549 - info: hm-rega.0 (11728) got 5 variables 2021-10-02 20:28:11.611 - info: hm-rpc.1 (11741) starting. Version 1.14.45 in /opt/iobroker/node_modules/iobroker.hm-rpc, node: v12.22.1, js-controller: 3.2.16 2021-10-02 20:28:11.619 - error: hm-rega.0 (11728) Cannot parse answer for variables: {"40":{"Name":"Alarmmeldungen","TypeName":"VARDP","DPInfo":"Anzahl%20Alarmmeldungen","Value":,"ValueMin":0,"ValueMax":65000,"ValueUnit":"","ValueType":16,"ValueSubType":0,"ValueList":""}, "41":{"Name":"Servicemeldungen","TypeName":"VARDP","DPInfo":"Anzahl%20Servicemeldungen","Value":0,"ValueMin":0,"ValueMax":65000,"ValueUnit":"","ValueType":16,"ValueSubType":0,"ValueList":""}, "40":{"Name":"%24%7BsysVarAlarmMessages%7D","TypeName":"VARDP","DPInfo":"%24%7BsysVarAlarmMessagesCount%7D","Value":0,"Timestamp":"1970-01-01 01:00:00","ValueMin":0,"ValueMax":65000,"ValueUnit":"","ValueType":16,"ValueSubType":0,"ValueList":""}, "41":{"Name":"%24%7BsysVarServiceMessages%7D","TypeName":"VARDP","DPInfo":"%24%7BsysVarServiceMessagesCount%7D","Value":0,"Timestamp":"1970-01-01 01:00:00","ValueMin":0,"ValueMax":65000,"ValueUnit":"","ValueType":16,"ValueSubType":0,"ValueList":""}, "1030":{"Name":"%24%7BsysVarAlarmZone1%7D","TypeName":"ALARMDP","DPInfo":"%24%7BsysVarAlarmZone1Msg%7D","Value":false,"Timestamp":"1970-01-01 01:00:00","ValueMin":null,"ValueMax":null,"ValueUnit":"","ValueType":2,"ValueSubType":6,"ValueList":"%24%7BsysVarAlarmZone1NotTriggered%7D%3B%24%7BsysVarAlarmZone1Triggered%7D"}, "950":{"Name":"%24%7BsysVarPresence%7D","TypeName":"VARDP","DPInfo":"%24%7BsysVarPresenceMsg%7D","Value":true,"Timestamp":"2021-10-02 18:30:46","ValueMin":null,"ValueMax":null,"ValueUnit":"","ValueType":2,"ValueSubType":2,"ValueList":"%24%7BsysVarPresenceNotPresent%7D%3B%24%7BsysVarPresencePresent%7D"}, "1032":{"Name":"DutyCycle","TypeName":"VARDP","DPInfo":"DutyCycle%20CCU","Value":-1.000000,"Timestamp":"2021-10-02 20:28:00","ValueMin":-1,"ValueMax":100,"ValueUnit":"%25","ValueType":4,"ValueSubType":0,"ValueList":""}} 2021-10-02 20:28:12.133 - info: hm-rega.0 (11728) got 0 programs 2021-10-02 20:28:12.151 - info: hm-rega.0 (11728) update rooms to enum.rooms 2021-10-02 20:28:12.293 - info: hm-rega.0 (11728) added/updated 0 programs 2021-10-02 20:28:12.297 - info: hm-rega.0 (11728) deleted 0 programs 2021-10-02 20:28:12.808 - info: hm-rpc.1 (11741) xmlrpc server is trying to listen on 192.168.1.230:42010 2021-10-02 20:28:12.810 - info: hm-rpc.1 (11741) xmlrpc client is trying to connect to 192.168.1.179:42010/ with ["http://192.168.1.230:42010","raspberrypi:hm-rpc.1"] 2021-10-02 20:28:12.824 - info: hm-rega.0 (11728) update functions to enum.functions 2021-10-02 20:28:12.904 - info: hm-rega.0 (11728) update favorites to enum.favorites 2021-10-02 20:28:12.911 - error: hm-rega.0 (11728) Could not synchronize favorites of user "": Error: The id "enum.favorites." is invalid. Ids are not allowed to end in "." 2021-10-02 20:28:42.987 - error: hm-rpc.1 (11741) Init not possible, going to stop: Unknown XML-RPC tag 'TITLE' 2021-10-02 20:29:12.879 - error: hm-rpc.1 (11741) Init not possible, going to stop: Unknown XML-RPC tag 'TITLE' 2021-10-02 20:29:12.991 - info: hm-rpc.1 (11741) xmlrpc -> 192.168.1.179:42010/ init ["http://192.168.1.230:42010",""] 2021-10-02 20:29:13.031 - error: hm-rpc.1 (11741) Cannot call init: [http://192.168.1.230:42010, ""] Unknown XML-RPC tag 'TITLE' 2021-10-02 20:29:13.042 - info: hm-rpc.1 (11741) terminating 2021-10-02 20:29:13.045 - info: hm-rpc.1 (11741) Terminated (NO_ERROR): Without reason 2021-10-02 20:29:14.185 - info: host.raspberrypi instance system.adapter.hm-rpc.1 terminated with code 0 (NO_ERROR) 2021-10-02 20:29:14.193 - info: host.raspberrypi Restart adapter system.adapter.hm-rpc.1 because enabled
@glasfaser
gemacht... User in der RM als Admin angelegt. -
Kann es sein.. weil ich noch keine Homematic Geräte habe, dass er deswegen die Fehlermeldung bringt. ??
gemacht
Da kann ich nichts zu sagen , den Fall habe ich noch nie gehabt
@glasfaser also.... ich bestell mal einen Homematic IP mit Lan anschluss (In der hoffnung das der sich dann als Lan -Router verbinden lässt) und dann binde ich mal was ein.
Dann melde ich mich wieder..
Dann musst du aber einen anderen Adapter nutzen .
https://github.com/iobroker-community-adapters/ioBroker.hmip
brauch ich dann die RM nicht?
Eigentlich nicht!
Hab zwar noch nicht mit Raspberrymatic gearbeitet, aber eine jungfräuliche piVCCU hat immerhin die virtuellen kanäleAußerdem ist die Meldung mit TITLE bekannt und liegt an der Konfiguration der Firewall. Ich habe nur die Lösung gerade nicht im Kopf.
