  4. VM raspberryMatic und IoBroker
    6.3k
51 Beiträge 4 Kommentatoren 5.2k Aufrufe 3 Beobachtet
  • GlasfaserG Glasfaser
    @homoran sagte in VM raspberryMatic und IoBroker:
    und ip auf .0
    ich sage ja .. mal so .. dann so
    Metalesel
    @glasfaser
    hab ich gemacht.. und mal die Adapter (rega und den rpc neu gestartet.. log anbei ...
    2021-10-02 20:27:53.435 - info: host.raspberrypi stopInstance system.adapter.hm-rega.0 (force=false, process=true)
    2021-10-02 20:27:53.958 - info: hm-rega.0 (11559) Got terminate signal TERMINATE_YOURSELF
    2021-10-02 20:27:53.985 - info: host.raspberrypi stopInstance system.adapter.hm-rega.0 send kill signal
    2021-10-02 20:27:54.095 - info: hm-rega.0 (11559) terminating
    2021-10-02 20:27:54.099 - info: hm-rega.0 (11559) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    2021-10-02 20:27:55.198 - info: host.raspberrypi instance system.adapter.hm-rega.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2021-10-02 20:27:55.932 - info: host.raspberrypi stopInstance system.adapter.hm-rpc.1 (force=false, process=true)
    2021-10-02 20:27:55.942 - info: host.raspberrypi stopInstance system.adapter.hm-rpc.1 send kill signal
    2021-10-02 20:27:55.942 - info: hm-rpc.1 (11700) Got terminate signal TERMINATE_YOURSELF
    2021-10-02 20:27:55.946 - info: hm-rpc.1 (11700) xmlrpc -> 192.168.1.179:42010/ init ["http://192.168.1.230:42010",""]
    2021-10-02 20:27:55.986 - error: hm-rpc.1 (11700) Cannot call init: [http://192.168.1.230:42010, ""] Unknown XML-RPC tag 'TITLE'
    2021-10-02 20:27:55.989 - info: hm-rpc.1 (11700) terminating
    2021-10-02 20:27:55.992 - info: hm-rpc.1 (11700) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    2021-10-02 20:27:57.272 - info: host.raspberrypi instance system.adapter.hm-rpc.1 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2021-10-02 20:27:57.873 - info: host.raspberrypi instance system.adapter.hm-rega.0 started with pid 11728
    2021-10-02 20:28:01.639 - info: host.raspberrypi instance system.adapter.hm-rpc.1 started with pid 11741
    2021-10-02 20:28:03.488 - info: hm-rega.0 (11728) starting. Version 3.0.31 in /opt/iobroker/node_modules/iobroker.hm-rega, node: v12.22.1, js-controller: 3.2.16
    2021-10-02 20:28:04.267 - info: hm-rega.0 (11728) subscribe .BidCoS-RF.50.PRESS_SHORT
    2021-10-02 20:28:04.481 - info: hm-rega.0 (11728) ReGaHSS 192.168.1.179 up
    2021-10-02 20:28:06.613 - info: hm-rega.0 (11728) time difference local-ccu 1s
    2021-10-02 20:28:11.004 - info: hm-rega.0 (11728) request state values
    2021-10-02 20:28:11.041 - info: hm-rega.0 (11728) Updated all datapoints
    2021-10-02 20:28:11.549 - info: hm-rega.0 (11728) got 5 variables
    2021-10-02 20:28:11.611 - info: hm-rpc.1 (11741) starting. Version 1.14.45 in /opt/iobroker/node_modules/iobroker.hm-rpc, node: v12.22.1, js-controller: 3.2.16
    2021-10-02 20:28:11.619 - error: hm-rega.0 (11728) Cannot parse answer for variables: {"40":{"Name":"Alarmmeldungen","TypeName":"VARDP","DPInfo":"Anzahl%20Alarmmeldungen","Value":,"ValueMin":0,"ValueMax":65000,"ValueUnit":"","ValueType":16,"ValueSubType":0,"ValueList":""},
    "41":{"Name":"Servicemeldungen","TypeName":"VARDP","DPInfo":"Anzahl%20Servicemeldungen","Value":0,"ValueMin":0,"ValueMax":65000,"ValueUnit":"","ValueType":16,"ValueSubType":0,"ValueList":""},
    "40":{"Name":"%24%7BsysVarAlarmMessages%7D","TypeName":"VARDP","DPInfo":"%24%7BsysVarAlarmMessagesCount%7D","Value":0,"Timestamp":"1970-01-01 01:00:00","ValueMin":0,"ValueMax":65000,"ValueUnit":"","ValueType":16,"ValueSubType":0,"ValueList":""},
    "41":{"Name":"%24%7BsysVarServiceMessages%7D","TypeName":"VARDP","DPInfo":"%24%7BsysVarServiceMessagesCount%7D","Value":0,"Timestamp":"1970-01-01 01:00:00","ValueMin":0,"ValueMax":65000,"ValueUnit":"","ValueType":16,"ValueSubType":0,"ValueList":""},
    "1030":{"Name":"%24%7BsysVarAlarmZone1%7D","TypeName":"ALARMDP","DPInfo":"%24%7BsysVarAlarmZone1Msg%7D","Value":false,"Timestamp":"1970-01-01 01:00:00","ValueMin":null,"ValueMax":null,"ValueUnit":"","ValueType":2,"ValueSubType":6,"ValueList":"%24%7BsysVarAlarmZone1NotTriggered%7D%3B%24%7BsysVarAlarmZone1Triggered%7D"},
    "950":{"Name":"%24%7BsysVarPresence%7D","TypeName":"VARDP","DPInfo":"%24%7BsysVarPresenceMsg%7D","Value":true,"Timestamp":"2021-10-02 18:30:46","ValueMin":null,"ValueMax":null,"ValueUnit":"","ValueType":2,"ValueSubType":2,"ValueList":"%24%7BsysVarPresenceNotPresent%7D%3B%24%7BsysVarPresencePresent%7D"},
    "1032":{"Name":"DutyCycle","TypeName":"VARDP","DPInfo":"DutyCycle%20CCU","Value":-1.000000,"Timestamp":"2021-10-02 20:28:00","ValueMin":-1,"ValueMax":100,"ValueUnit":"%25","ValueType":4,"ValueSubType":0,"ValueList":""}}
    2021-10-02 20:28:12.133 - info: hm-rega.0 (11728) got 0 programs
    2021-10-02 20:28:12.151 - info: hm-rega.0 (11728) update rooms to enum.rooms
    2021-10-02 20:28:12.293 - info: hm-rega.0 (11728) added/updated 0 programs
    2021-10-02 20:28:12.297 - info: hm-rega.0 (11728) deleted 0 programs
    2021-10-02 20:28:12.808 - info: hm-rpc.1 (11741) xmlrpc server is trying to listen on 192.168.1.230:42010
    2021-10-02 20:28:12.810 - info: hm-rpc.1 (11741) xmlrpc client is trying to connect to 192.168.1.179:42010/ with ["http://192.168.1.230:42010","raspberrypi:hm-rpc.1"]
    2021-10-02 20:28:12.824 - info: hm-rega.0 (11728) update functions to enum.functions
    2021-10-02 20:28:12.904 - info: hm-rega.0 (11728) update favorites to enum.favorites
    2021-10-02 20:28:12.911 - error: hm-rega.0 (11728) Could not synchronize favorites of user "": Error: The id "enum.favorites." is invalid. Ids are not allowed to end in "."
    2021-10-02 20:28:42.987 - error: hm-rpc.1 (11741) Init not possible, going to stop: Unknown XML-RPC tag 'TITLE'
    2021-10-02 20:29:12.879 - error: hm-rpc.1 (11741) Init not possible, going to stop: Unknown XML-RPC tag 'TITLE'
    2021-10-02 20:29:12.991 - info: hm-rpc.1 (11741) xmlrpc -> 192.168.1.179:42010/ init ["http://192.168.1.230:42010",""]
    2021-10-02 20:29:13.031 - error: hm-rpc.1 (11741) Cannot call init: [http://192.168.1.230:42010, ""] Unknown XML-RPC tag 'TITLE'
    2021-10-02 20:29:13.042 - info: hm-rpc.1 (11741) terminating
    2021-10-02 20:29:13.045 - info: hm-rpc.1 (11741) Terminated (NO_ERROR): Without reason
    2021-10-02 20:29:14.185 - info: host.raspberrypi instance system.adapter.hm-rpc.1 terminated with code 0 (NO_ERROR)
    2021-10-02 20:29:14.193 - info: host.raspberrypi Restart adapter system.adapter.hm-rpc.1 because enabled
    http://metalesel.ddns.net
    -- ProxMox und IoBroker Hilfe !!
    • M Metalesel
      @glasfaser
      GlasfaserG Offline
      GlasfaserG Offline
      @metalesel
        @metalesel
        Metalesel
        @glasfaser
        gemacht... User in der RM als Admin angelegt.
        • M Metalesel
          @glasfaser
          Metalesel
          @metalesel
          Kann es sein.. weil ich noch keine Homematic Geräte habe, dass er deswegen die Fehlermeldung bringt. ??
          GlasfaserG HomoranH 2 Antworten Letzte Antwort
          • GlasfaserG Offline
            GlasfaserG Offline
            @metalesel
            Keine Ahnung was bei dir da so ist ...
            Mache noch den Haken da rein , bei HTTPS Nutzung
              @metalesel
              Metalesel
              @glasfaser
              gemacht
              • M Metalesel
                @metalesel
                GlasfaserG Offline
                GlasfaserG Offline
                @metalesel sagte in VM raspberryMatic und IoBroker:
                Da kann ich nichts zu sagen , den Fall habe ich noch nie gehabt
                  Metalesel
                  @glasfaser also.... ich bestell mal einen Homematic IP mit Lan anschluss (In der hoffnung das der sich dann als Lan -Router verbinden lässt) und dann binde ich mal was ein.
                  Dann melde ich mich wieder.. ;)
                  • M Metalesel
                    GlasfaserG Offline
                    GlasfaserG Offline
                    Dann musst du aber einen anderen Adapter nutzen .
                    https://github.com/iobroker-community-adapters/ioBroker.hmip
                      Metalesel
                      @glasfaser
                      brauch ich dann die RM nicht?
                      • M Metalesel
                        @metalesel
                        Eigentlich nicht!
                        Hab zwar noch nicht mit Raspberrymatic gearbeitet, aber eine jungfräuliche piVCCU hat immerhin die virtuellen kanäle
                        Außerdem ist die Meldung mit TITLE bekannt und liegt an der Konfiguration der Firewall. Ich habe nur die Lösung gerade nicht im Kopf.
                        • M Metalesel
                          @glasfaser
                          FeuersturmF Offline
                          FeuersturmF Offline
                          Feuersturm
                          @metalesel Hast du eigentlich an deinem Server, wo deine RM in einer VM läuft, ein Funkmodul angeschlossen welches auch funktioniert?
                          • FeuersturmF Feuersturm
                            Metalesel
                            @feuersturm
                            Hallo Zusammen,
                            lag wohl doch daran, dass ich noch keine Geräte an der CCU hatte.... nachdem der Raspberry mit RaspberryMatic gefüttert war und Geräte hatte, wurde auch die hm-rpc grün...
                            Mit der VM muss ich noch schauen .. habe ein Funkmodul .. problem ist nur, dass ich dieses erst downgraden muss ...
                            Danke für eure Hilfe.
