  4. VM raspberryMatic und IoBroker
    6.3k
51 Beiträge 4 Kommentatoren 5.2k Aufrufe 3 Beobachtet
  • M Metalesel
    @glasfaser
    2021-10-02 20:15:47.039 - error: hm-rpc.1 (11291) Init not possible, going to stop: Unknown XML-RPC tag 'TITLE'
    2021-10-02 20:15:47.074 - info: hm-rpc.1 (11291) xmlrpc -> 192.168.1.179:2001/ init ["http://192.168.1.230:2001",""]
    2021-10-02 20:15:47.101 - error: hm-rpc.1 (11291) Cannot call init: [http://192.168.1.230:2001, ""] Unknown XML-RPC tag 'TITLE'
    2021-10-02 20:15:47.112 - info: hm-rpc.1 (11291) terminating
    2021-10-02 20:15:47.115 - info: hm-rpc.1 (11291) Terminated (NO_ERROR): Without reason
    2021-10-02 20:15:48.242 - info: host.raspberrypi instance system.adapter.hm-rpc.1 terminated with code 0 (NO_ERROR)
    2021-10-02 20:15:48.244 - info: host.raspberrypi Restart adapter system.adapter.hm-rpc.1 because enabled
    2021-10-02 20:15:56.900 - error: hm-rpc.0 (11308) Init not possible, going to stop: Unknown XML-RPC tag 'TITLE'
    2021-10-02 20:15:56.925 - info: hm-rpc.0 (11308) xmlrpc -> 192.168.1.179:2010/ init ["http://192.168.1.230:2010",""]
    2021-10-02 20:15:56.950 - error: hm-rpc.0 (11308) Cannot call init: [http://192.168.1.230:2010, ""] Unknown XML-RPC tag 'TITLE'
    2021-10-02 20:15:56.960 - info: hm-rpc.0 (11308) terminating
    2021-10-02 20:15:56.962 - info: hm-rpc.0 (11308) Terminated (NO_ERROR): Without reason
    2021-10-02 20:15:58.071 - info: host.raspberrypi instance system.adapter.hm-rpc.0 terminated with code 0 (NO_ERROR)
    2021-10-02 20:15:58.073 - info: host.raspberrypi Restart adapter system.adapter.hm-rpc.0 because enabled
    2021-10-02 20:16:00.054 - info: host.raspberrypi instance system.adapter.hm-rpc.0 started with pid 11329
    2021-10-02 20:16:03.281 - info: hm-rpc.0 (11329) starting. Version 1.14.45 in /opt/iobroker/node_modules/iobroker.hm-rpc, node: v12.22.1, js-controller: 3.2.16
    2021-10-02 20:16:05.405 - info: hm-rpc.0 (11329) xmlrpc server is trying to listen on 192.168.1.230:2010
    2021-10-02 20:16:05.407 - info: hm-rpc.0 (11329) xmlrpc client is trying to connect to 192.168.1.179:2010/ with ["http://192.168.1.230:2010","raspberrypi:hm-rpc.0"]
    2021-10-02 20:16:05.544 - error: hm-rpc.0 (11329) Init not possible, going to stop: Unknown XML-RPC tag 'TITLE'
    2021-10-02 20:16:18.296 - info: host.raspberrypi instance system.adapter.hm-rpc.1 started with pid 11347
    2021-10-02 20:16:21.862 - info: hm-rpc.1 (11347) starting. Version 1.14.45 in /opt/iobroker/node_modules/iobroker.hm-rpc, node: v12.22.1, js-controller: 3.2.16
    2021-10-02 20:16:22.572 - info: hm-rpc.1 (11347) xmlrpc server is trying to listen on 192.168.1.230:2001
    2021-10-02 20:16:22.575 - info: hm-rpc.1 (11347) xmlrpc client is trying to connect to 192.168.1.179:2001/ with ["http://192.168.1.230:2001","raspberrypi:hm-rpc.1"]
    2021-10-02 20:16:22.647 - error: hm-rpc.1 (11347) Init not possible, going to stop: Unknown XML-RPC tag 'TITLE'
    2021-10-02 20:16:35.488 - error: hm-rpc.0 (11329) Init not possible, going to stop: Unknown XML-RPC tag 'TITLE'
    2021-10-02 20:16:35.550 - info: hm-rpc.0 (11329) xmlrpc -> 192.168.1.179:2010/ init ["http://192.168.1.230:2010",""]
    2021-10-02 20:16:35.586 - error: hm-rpc.0 (11329) Cannot call init: [http://192.168.1.230:2010, ""] Unknown XML-RPC tag 'TITLE'
    2021-10-02 20:16:35.598 - info: hm-rpc.0 (11329) terminating
    2021-10-02 20:16:35.602 - info: hm-rpc.0 (11329) Terminated (NO_ERROR): Without reason
    2021-10-02 20:16:36.761 - info: host.raspberrypi instance system.adapter.hm-rpc.0 terminated with code 0 (NO_ERROR)
    2021-10-02 20:16:36.762 - info: host.raspberrypi Restart adapter system.adapter.hm-rpc.0 because enabled
    GlasfaserG Offline
    GlasfaserG Offline
    @metalesel sagte in VM raspberryMatic und IoBroker:
    hm-rpc.1
    Wo kommt der jetzt her ?
    du hast doch nur
    hm-rpc.0
    HomoranH M 2 Antworten Letzte Antwort
    • GlasfaserG Glasfaser
      hm-rpc.1
      du hast doch nur
      hm-rpc.0
      @glasfaser sagte in VM raspberryMatic und IoBroker:
      hm-rpc.1
      du hast doch nur
      hm-rpc.0
      nein, er hat rf auf.1 und ip auf .0
        bei .1 kommt die Meldung mit TITLE, bei 0 klappt gar nix
          hm-rpc.1
          du hast doch nur
          hm-rpc.0
          Metalesel
          @glasfaser
          @Homoran
          genau.. ;)
          in der Hoffnung, dass er sich einem von beiden verbindet
          http://metalesel.ddns.net
          -- ProxMox und IoBroker Hilfe !!
            hm-rpc.1
            du hast doch nur
            hm-rpc.0
            GlasfaserG Offline
            GlasfaserG Offline
            @homoran sagte in VM raspberryMatic und IoBroker:
            und ip auf .0
            ich sage ja .. mal so .. dann so
              @Metalesel mach mal in der FW der RM den Haken bei automatische Umleitung auf https.
              den kenne ich gar nicht
                und ip auf .0
                Metalesel
                @glasfaser
                hab ich gemacht.. und mal die Adapter (rega und den rpc neu gestartet.. log anbei ...
                2021-10-02 20:27:53.435 - info: host.raspberrypi stopInstance system.adapter.hm-rega.0 (force=false, process=true)
                2021-10-02 20:27:53.958 - info: hm-rega.0 (11559) Got terminate signal TERMINATE_YOURSELF
                2021-10-02 20:27:53.985 - info: host.raspberrypi stopInstance system.adapter.hm-rega.0 send kill signal
                2021-10-02 20:27:54.095 - info: hm-rega.0 (11559) terminating
                2021-10-02 20:27:54.099 - info: hm-rega.0 (11559) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                2021-10-02 20:27:55.198 - info: host.raspberrypi instance system.adapter.hm-rega.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                2021-10-02 20:27:55.932 - info: host.raspberrypi stopInstance system.adapter.hm-rpc.1 (force=false, process=true)
                2021-10-02 20:27:55.942 - info: host.raspberrypi stopInstance system.adapter.hm-rpc.1 send kill signal
                2021-10-02 20:27:55.942 - info: hm-rpc.1 (11700) Got terminate signal TERMINATE_YOURSELF
                2021-10-02 20:27:55.946 - info: hm-rpc.1 (11700) xmlrpc -> 192.168.1.179:42010/ init ["http://192.168.1.230:42010",""]
                2021-10-02 20:27:55.986 - error: hm-rpc.1 (11700) Cannot call init: [http://192.168.1.230:42010, ""] Unknown XML-RPC tag 'TITLE'
                2021-10-02 20:27:55.989 - info: hm-rpc.1 (11700) terminating
                2021-10-02 20:27:55.992 - info: hm-rpc.1 (11700) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                2021-10-02 20:27:57.272 - info: host.raspberrypi instance system.adapter.hm-rpc.1 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                2021-10-02 20:27:57.873 - info: host.raspberrypi instance system.adapter.hm-rega.0 started with pid 11728
                2021-10-02 20:28:01.639 - info: host.raspberrypi instance system.adapter.hm-rpc.1 started with pid 11741
                2021-10-02 20:28:03.488 - info: hm-rega.0 (11728) starting. Version 3.0.31 in /opt/iobroker/node_modules/iobroker.hm-rega, node: v12.22.1, js-controller: 3.2.16
                2021-10-02 20:28:04.267 - info: hm-rega.0 (11728) subscribe .BidCoS-RF.50.PRESS_SHORT
                2021-10-02 20:28:04.481 - info: hm-rega.0 (11728) ReGaHSS 192.168.1.179 up
                2021-10-02 20:28:06.613 - info: hm-rega.0 (11728) time difference local-ccu 1s
                2021-10-02 20:28:11.004 - info: hm-rega.0 (11728) request state values
                2021-10-02 20:28:11.041 - info: hm-rega.0 (11728) Updated all datapoints
                2021-10-02 20:28:11.549 - info: hm-rega.0 (11728) got 5 variables
                2021-10-02 20:28:11.611 - info: hm-rpc.1 (11741) starting. Version 1.14.45 in /opt/iobroker/node_modules/iobroker.hm-rpc, node: v12.22.1, js-controller: 3.2.16
                2021-10-02 20:28:11.619 - error: hm-rega.0 (11728) Cannot parse answer for variables: {"40":{"Name":"Alarmmeldungen","TypeName":"VARDP","DPInfo":"Anzahl%20Alarmmeldungen","Value":,"ValueMin":0,"ValueMax":65000,"ValueUnit":"","ValueType":16,"ValueSubType":0,"ValueList":""},
                "41":{"Name":"Servicemeldungen","TypeName":"VARDP","DPInfo":"Anzahl%20Servicemeldungen","Value":0,"ValueMin":0,"ValueMax":65000,"ValueUnit":"","ValueType":16,"ValueSubType":0,"ValueList":""},
                "40":{"Name":"%24%7BsysVarAlarmMessages%7D","TypeName":"VARDP","DPInfo":"%24%7BsysVarAlarmMessagesCount%7D","Value":0,"Timestamp":"1970-01-01 01:00:00","ValueMin":0,"ValueMax":65000,"ValueUnit":"","ValueType":16,"ValueSubType":0,"ValueList":""},
                "41":{"Name":"%24%7BsysVarServiceMessages%7D","TypeName":"VARDP","DPInfo":"%24%7BsysVarServiceMessagesCount%7D","Value":0,"Timestamp":"1970-01-01 01:00:00","ValueMin":0,"ValueMax":65000,"ValueUnit":"","ValueType":16,"ValueSubType":0,"ValueList":""},
                "1030":{"Name":"%24%7BsysVarAlarmZone1%7D","TypeName":"ALARMDP","DPInfo":"%24%7BsysVarAlarmZone1Msg%7D","Value":false,"Timestamp":"1970-01-01 01:00:00","ValueMin":null,"ValueMax":null,"ValueUnit":"","ValueType":2,"ValueSubType":6,"ValueList":"%24%7BsysVarAlarmZone1NotTriggered%7D%3B%24%7BsysVarAlarmZone1Triggered%7D"},
                "950":{"Name":"%24%7BsysVarPresence%7D","TypeName":"VARDP","DPInfo":"%24%7BsysVarPresenceMsg%7D","Value":true,"Timestamp":"2021-10-02 18:30:46","ValueMin":null,"ValueMax":null,"ValueUnit":"","ValueType":2,"ValueSubType":2,"ValueList":"%24%7BsysVarPresenceNotPresent%7D%3B%24%7BsysVarPresencePresent%7D"},
                "1032":{"Name":"DutyCycle","TypeName":"VARDP","DPInfo":"DutyCycle%20CCU","Value":-1.000000,"Timestamp":"2021-10-02 20:28:00","ValueMin":-1,"ValueMax":100,"ValueUnit":"%25","ValueType":4,"ValueSubType":0,"ValueList":""}}
                2021-10-02 20:28:12.133 - info: hm-rega.0 (11728) got 0 programs
                2021-10-02 20:28:12.151 - info: hm-rega.0 (11728) update rooms to enum.rooms
                2021-10-02 20:28:12.293 - info: hm-rega.0 (11728) added/updated 0 programs
                2021-10-02 20:28:12.297 - info: hm-rega.0 (11728) deleted 0 programs
                2021-10-02 20:28:12.808 - info: hm-rpc.1 (11741) xmlrpc server is trying to listen on 192.168.1.230:42010
                2021-10-02 20:28:12.810 - info: hm-rpc.1 (11741) xmlrpc client is trying to connect to 192.168.1.179:42010/ with ["http://192.168.1.230:42010","raspberrypi:hm-rpc.1"]
                2021-10-02 20:28:12.824 - info: hm-rega.0 (11728) update functions to enum.functions
                2021-10-02 20:28:12.904 - info: hm-rega.0 (11728) update favorites to enum.favorites
                2021-10-02 20:28:12.911 - error: hm-rega.0 (11728) Could not synchronize favorites of user "": Error: The id "enum.favorites." is invalid. Ids are not allowed to end in "."
                2021-10-02 20:28:42.987 - error: hm-rpc.1 (11741) Init not possible, going to stop: Unknown XML-RPC tag 'TITLE'
                2021-10-02 20:29:12.879 - error: hm-rpc.1 (11741) Init not possible, going to stop: Unknown XML-RPC tag 'TITLE'
                2021-10-02 20:29:12.991 - info: hm-rpc.1 (11741) xmlrpc -> 192.168.1.179:42010/ init ["http://192.168.1.230:42010",""]
                2021-10-02 20:29:13.031 - error: hm-rpc.1 (11741) Cannot call init: [http://192.168.1.230:42010, ""] Unknown XML-RPC tag 'TITLE'
                2021-10-02 20:29:13.042 - info: hm-rpc.1 (11741) terminating
                2021-10-02 20:29:13.045 - info: hm-rpc.1 (11741) Terminated (NO_ERROR): Without reason
                2021-10-02 20:29:14.185 - info: host.raspberrypi instance system.adapter.hm-rpc.1 terminated with code 0 (NO_ERROR)
                2021-10-02 20:29:14.193 - info: host.raspberrypi Restart adapter system.adapter.hm-rpc.1 because enabled
                • M Metalesel
                  @glasfaser
                  GlasfaserG Offline
                  GlasfaserG Offline
                  @metalesel
                    @metalesel
                    Metalesel
                    @glasfaser
                    gemacht... User in der RM als Admin angelegt.
                    • M Metalesel
                      @glasfaser
                      Metalesel
                      @metalesel
                      Kann es sein.. weil ich noch keine Homematic Geräte habe, dass er deswegen die Fehlermeldung bringt. ??
                      GlasfaserG HomoranH 2 Antworten Letzte Antwort
                      • GlasfaserG Offline
                        GlasfaserG Offline
                        @metalesel
                        Keine Ahnung was bei dir da so ist ...
                        Mache noch den Haken da rein , bei HTTPS Nutzung
                          @metalesel
                          Metalesel
                          @glasfaser
                          gemacht
                          • M Metalesel
                            @metalesel
                            GlasfaserG Offline
                            GlasfaserG Offline
                            Da kann ich nichts zu sagen , den Fall habe ich noch nie gehabt
                              Metalesel
                              @glasfaser also.... ich bestell mal einen Homematic IP mit Lan anschluss (In der hoffnung das der sich dann als Lan -Router verbinden lässt) und dann binde ich mal was ein.
                              Dann melde ich mich wieder.. ;)
                              • M Metalesel
                                GlasfaserG Offline
                                GlasfaserG Offline
                                Dann musst du aber einen anderen Adapter nutzen .
                                https://github.com/iobroker-community-adapters/ioBroker.hmip
                                  Metalesel
                                  @glasfaser
                                  brauch ich dann die RM nicht?
                                  • M Metalesel
                                    @metalesel
                                    Eigentlich nicht!
                                    Hab zwar noch nicht mit Raspberrymatic gearbeitet, aber eine jungfräuliche piVCCU hat immerhin die virtuellen kanäle
                                    Außerdem ist die Meldung mit TITLE bekannt und liegt an der Konfiguration der Firewall. Ich habe nur die Lösung gerade nicht im Kopf.
                                    • M Metalesel
                                      @glasfaser
                                      FeuersturmF Offline
                                      FeuersturmF Offline
                                      Feuersturm
                                      @metalesel Hast du eigentlich an deinem Server, wo deine RM in einer VM läuft, ein Funkmodul angeschlossen welches auch funktioniert?
                                      • FeuersturmF Feuersturm
                                        Metalesel
                                        @feuersturm
                                        Hallo Zusammen,
                                        lag wohl doch daran, dass ich noch keine Geräte an der CCU hatte.... nachdem der Raspberry mit RaspberryMatic gefüttert war und Geräte hatte, wurde auch die hm-rpc grün...
                                        Mit der VM muss ich noch schauen .. habe ein Funkmodul .. problem ist nur, dass ich dieses erst downgraden muss ...
                                        Danke für eure Hilfe.
